| 0003590 | Arch | Bug | public | 2018-09-11 17:10 | 2018-12-17 14:26 |
| Reporter | furti | Assigned To | yorik | ||
| Summary | 0003590: Arch Py3 unicode problems | ||||
| Description | Some commands in Arch workbench do not work with a 0.18 Py3 build because of problems with byte like object instead og unicode string. See: http://forum.freecadweb.org/viewtopic.php?t=30824 http://forum.freecadweb.org/viewtopic.php?t=30826 http://forum.freecadweb.org/viewtopic.php?t=30825 | ||||
| Tags | unicode | ||||
The linked forum threads contain the relevant informations like steps to reproduce and FreeCAD info |
assigning to yorik |
Set this as 'Block' since 0.18 will be py3 compliant. |
I think this is a pivy problem. I guess SoAsciiString.text.setValues() should work with bytes-objects. Currently it works with unicode-objects (py3) but doesn't show special-symbols. Can anyone approve this assumption? |
I guess this is the relevant part where the problem occurs:
No idea why swig creates this, as pivy defines the typemap in another way: https://github.com/FreeCAD/pivy/blob/master/Inventor/fields/SoMFString.i#L12 |
This should fix the problem. The reason for the problem: The c-function "PyObject_Str" is the same as "str" in python. Calling this function will convert any object to a unicode-object in python3. This results in things like "b'\xc2\abc...'" https://github.com/FreeCAD/pivy/pull/43 edit: solves only http://forum.freecadweb.org/viewtopic.php?t=30824 the other 2 are still there, but should be easier to fix. |
https://github.com/FreeCAD/FreeCAD/commit/1e6818b6fbf86ad08d8fc85252dddcae8891dd54 |
Remaining problems fixed in http://github.com/FreeCAD/FreeCAD/commit/175566d55 |
| 2018-09-11 17:10 | furti | New Issue | |
| 2018-09-11 17:15 | furti | Note Added: 0011710 | |
| 2018-09-11 17:42 | Kunda1 | Assigned To | => yorik |
| 2018-09-11 17:42 | Kunda1 | Status | new => assigned |
| 2018-09-11 17:42 | Kunda1 | Note Added: 0011711 | |
| 2018-09-11 17:42 | Kunda1 | Target Version | => 0.18 |
| 2018-09-11 17:43 | Kunda1 | Note Edited: 0011710 | |
| 2018-10-15 07:15 | Kunda1 | Tag Attached: unicode | |
| 2018-10-15 07:17 | Kunda1 | Severity | major => block |
| 2018-10-15 07:17 | Kunda1 | Note Added: 0012028 | |
| 2018-10-16 10:40 | looo | Note Added: 0012037 | |
| 2018-10-16 11:46 | looo | Note Added: 0012039 | |
| 2018-10-16 11:46 | looo | Note Edited: 0012039 | |
| 2018-10-16 12:59 | looo | Note Added: 0012040 | |
| 2018-10-16 13:02 | looo | Note Edited: 0012040 | |
| 2018-10-17 09:35 | wmayer | Note Added: 0012045 | |
| 2018-12-17 14:26 | yorik | Note Added: 0012291 | |
| 2018-12-17 14:26 | yorik | Status | assigned => closed |
| 2018-12-17 14:26 | yorik | Resolution | open => fixed |
| 2018-12-17 14:26 | yorik | Fixed in Version | => 0.18 |
