| 0003602 | PartDesign | General | public | 2018-09-18 09:56 | 2018-09-22 15:01 |
| Reporter | yimingwu | Assigned To | normandc | ||
| OS | Windows 10 | ||||
| Summary | 0003602: Clone doesn't accept part anymore. | ||||
| Description | Clone tool in part design doesn't accept part object anymore. It displays gery icon when I select the part, but body works fine. I used to make bodies and clone several times into one part, (which contains multiple instance of that body). Then I clone the part to put it at other places in an assembly. I used this method fine in 0.16, but in 0.17 it seems that this feature is disabled? I can still open files created using this method, but the part object is no longer clone-able. (existing cloned part remains normal) If this feature is removed, the How can I achieve linked duplication of a part which contains several bodies? Thanks. | ||||
| Steps To Reproduce | Create a part. Create a body. Drag the body into the part. Select the part. Clone shows grey. | ||||
Please signal someone on the forums to confirm your issue. Then please report back. (Per our tracker guidelines) |
@chrisb care to address this? |
Part and Body containers, as well as PartDesign CLone were introduced in v0.17. How could you have "used this method fine" in v0.16??? |
You are most probably mistaking PartDesign Clone with Draft Clone, which existed back in v0.16. A Part container has no shape, which is why the PartDesign Clone does not recognize it. But Draft Clone works on a Part container. So you've got a workaround. This is not a bug therefore I'm closing it. |
| 2018-09-18 09:56 | yimingwu | New Issue | |
| 2018-09-18 09:56 | yimingwu | File Added: TIM图片20180918175535.png | |
| 2018-09-18 11:40 | Kunda1 | Note Added: 0011792 | |
| 2018-09-18 11:41 | Kunda1 | Status | new => feedback |
| 2018-09-20 14:39 | Kunda1 | Note Added: 0011798 | |
| 2018-09-22 14:24 | normandc | Note Added: 0011813 | |
| 2018-09-22 15:01 | normandc | Assigned To | => normandc |
| 2018-09-22 15:01 | normandc | Status | feedback => closed |
| 2018-09-22 15:01 | normandc | Resolution | open => no change required |
| 2018-09-22 15:01 | normandc | Note Added: 0011814 |
