| 0003605 | FreeCAD | Bug | public | 2018-09-19 16:50 | 2019-02-21 12:32 |
| Reporter | David_D | Assigned To | wmayer | ||
| Priority | low | Severity | tweak | Reproducibility | always |
| OS | Solus | ||||
| Summary | 0003605: Scrolling on length inputs with "Building Euro" unit system has max value | ||||
| Description | When using my mouse scroll wheel to increase or decrease GUI input boxes for length values, the maximum value that can be reached is 0.11cm, and the minimum is -0.11cm. Here is a video demonstrating the issue: https://gfycat.com/DemandingAdorableKudu After some testing, I discovered this issue only occurs: * When the Building Euro units user system is selected. (Preferences>General>Units>User system) Expected behavior occurs with all other unit systems, eg: Metric small parts. * With length values. Degrees input boxes work as expected. * Within task panels. Editing the data within a property or hybrid view panel directly has the expected behavior. There was only one error with the TestApp.All test. The forum discussion: https://forum.freecadweb.org/viewtopic.php?f=3&t=30991&p=257340 | ||||
| Steps To Reproduce |
| Additional Information | Tested with both 0.17 and 0.18: OS: "Solus" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13541 (Git) AppImage Build type: None Branch: releases/FreeCAD-0-17 Hash: 9948ee4f1570df9216862a79705afb367b2c6ffb Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/NewZealand (en_NZ) OS: "Solus" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14766 (Git) AppImage Build type: Release Branch: master Hash: 17d36cecc992cfa9c9a4a831f23a6e4dcd6cc41e Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/NewZealand (en_NZ) OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14727 (Git) Build type: Release Branch: master Hash: c6df59969bfb3ae2027e2b47ddd559852f6e9a4e Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
| Tags | units | ||||
wmayer, I assigned this to you. Hope that's OK. |
This is not a bug in the "Building Euro" unit system. It is a bug in InputField which only occurs in combination with the above unit system. The reason for this misbehaviour is an inconsistent interpretation of the numbers: When the input field shows the number 0.11 cm and you scroll then the number becomes 1.11 but when passing it to the unit system translator the number wasn't calculated in mm beforehand. Because internally all lengths are in mm (independent of any user settings) the unit system translator correctly assumes the value in mm and when translating it into cm it becomes 0.111 and because of a precision of two again becomes 0.11. |
https://github.com/FreeCAD/FreeCAD/commit/66da83ef92b7ea6d0656eb66c5a9c6b4e57efaa0 |
| 2018-09-19 16:50 | David_D | New Issue | |
| 2018-09-19 16:50 | David_D | Tag Attached: units | |
| 2018-09-19 16:50 | David_D | File Added: ranch_plan.fcstd | |
| 2018-10-02 21:28 | Kunda1 | Status | new => confirmed |
| 2018-10-02 21:30 | Kunda1 | Assigned To | => wmayer |
| 2018-10-02 21:30 | Kunda1 | Status | confirmed => assigned |
| 2018-10-02 21:31 | Kunda1 | Note Added: 0011897 | |
| 2018-10-02 21:32 | Kunda1 | Description Updated | |
| 2019-02-21 07:05 | wmayer | Note Added: 0012710 | |
| 2019-02-21 12:32 | wmayer | Status | assigned => closed |
| 2019-02-21 12:32 | wmayer | Resolution | open => fixed |
| 2019-02-21 12:32 | wmayer | Fixed in Version | => 0.18 |
| 2019-02-21 12:32 | wmayer | Note Added: 0012711 |
