| 0003623 | TechDraw | Bug | public | 2018-10-04 18:18 | 2018-10-23 11:33 |
| Reporter | chapatt | Assigned To | wandererfan | ||
| Summary | 0003623: "Building US" unit system rounding issue (e.g. 1' 12" vs. 2') | ||||
| Description | Techdraw often shows dimensions of a length in even feet, n, as (n-1)' 12" instead of n'. It seems to be random when it does this. See attached screenshot and example file of a sketch and a drawing of it. | ||||
| Steps To Reproduce |
| Additional Information | OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13541 (Git) Build Type: Release Branch: releases/FreeCAD-0-17 Hash: 9948ee4f1570df9216862a79705afb367b2c6ffb Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: English/UnitedStates (en_US) | ||||
| Tags | units | ||||
The example file uses this drawing template. |
weird. Only some dimensions are affected. This only happens with "use system decimals" true. With "use alt decimals", the dimvalues are all 0.0 and no units appear. |
This seems to be fixed in v0.18? Same file in 17 shows 10' 12", in 18 shows 11'. Changes in Units subsystem? There is a problem with ft/in measurements in TD if "use alt decimals" is ticked. Measurements come out as 0 - issue with formatSpec for 1 value, but 2 values in input?? |
Yes, I've reproduced everything you've observed. I think 0.18 solves this issue. Thank you. |
Let's just leave this ticket here to remind me to fix the 0.0 display when AltDecimals is true. |
https://github.com/FreeCAD/FreeCAD/commit/f6e9faa62c45a9fc8a9f977235abed139c31ab9a |
| 2018-10-04 18:18 | chapatt | New Issue | |
| 2018-10-04 18:18 | chapatt | File Added: techdraw_dimension_bug.FCStd | |
| 2018-10-04 18:18 | chapatt | File Added: techdraw_dimension_bug.png | |
| 2018-10-04 18:23 | chapatt | File Added: us-letter_landscape_plain.svg | |
| 2018-10-04 18:23 | chapatt | Note Added: 0011923 | |
| 2018-10-05 12:35 | wandererfan | Note Added: 0011927 | |
| 2018-10-05 12:37 | wandererfan | Assigned To | => wandererfan |
| 2018-10-05 12:37 | wandererfan | Status | new => confirmed |
| 2018-10-05 12:37 | wandererfan | Target Version | => 0.18 |
| 2018-10-05 12:37 | wandererfan | Steps to Reproduce Updated | |
| 2018-10-05 12:37 | wandererfan | Additional Information Updated | |
| 2018-10-05 13:19 | wandererfan | Note Added: 0011931 | |
| 2018-10-05 17:55 | chapatt | Note Added: 0011932 | |
| 2018-10-06 12:53 | wandererfan | Note Added: 0011943 | |
| 2018-10-11 20:08 | wmayer | Status | confirmed => closed |
| 2018-10-11 20:08 | wmayer | Resolution | open => fixed |
| 2018-10-11 20:08 | wmayer | Fixed in Version | => 0.18 |
| 2018-10-11 20:08 | wmayer | Note Added: 0012005 | |
| 2018-10-23 11:33 | Kunda1 | Tag Attached: units |
