| 0003631 | FreeCAD | Bug | public | 2018-10-10 16:19 | 2018-10-10 17:46 |
| Reporter | hhassey | Assigned To | |||
| Platform | Linux | OS | Debian Stretch | OS Version | 9 |
| Summary | 0003631: Drawing lines on top of an image will not save the work | ||||
| Description | Imported an image in a plane, proceed to draw on top of that image (pretty common for architectural work) Created walls out of these lines then saved the work, when you re open the file everything is messed up. | ||||
| Steps To Reproduce | 1.- Open new Document 2.- Switch to Image WB. 3.- Push "Createe Planar image in 3D space" Select a png image. on plane x-y 4.- Set the image position to -1m 5.- Switch to the Draft WB 6.- Draw a "Multiple point Draft Wire" on top of the image, don't close it 7.- Save your work and Re open | ||||
| Additional Information | OS: Debian GNU/Linux 9.5 (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14959 (Git) Build type: Debug Branch: master Hash: ff05101b68dc9a7d1e70dd69544f14ac8598a433 Python version: 2.7.13 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 Locale: English/UnitedStates (en_US) | ||||
