| 0003632 | FreeCAD | Bug | public | 2018-10-10 16:23 | 2018-10-11 19:51 |
| Reporter | hhassey | Assigned To | wmayer | ||
| Summary | 0003632: Drawing lines on top of an image will not save the work (Reason: ' &' in the file name) | ||||
| Description | Imported an image in a plane, proceed to draw on top of that image (pretty common for architectural work) Created walls out of these lines then saved the work, when you re open the file everything is messed up. and creates this error message:
Forum thread: https://forum.freecad.org/viewtopic.php?f=3&t=31470 | ||||
| Steps To Reproduce | 1.- Open new Document 2.- Switch to Image WB. 3.- Push "Createe Planar image in 3D space" Select a png image. on plane x-y 4.- Set the image position to -1m 5.- Switch to the Draft WB 6.- Draw a "Multiple point Draft Wire" on top of the image, don't close it 7.- Save your work and Re open | ||||
| Additional Information | OS: Debian GNU/Linux 9.5 (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14959 (Git) Build type: Debug Branch: master Hash: ff05101b68dc9a7d1e70dd69544f14ac8598a433 Python version: 2.7.13 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 Locale: English/UnitedStates (en_US) | ||||
| Tags | unicode | ||||
| has duplicate | 0003631 | closed | Drawing lines on top of an image will not save the work |
Found the BUG, the PNG image name had an & and that makes FreeCAD go crazy. Maybe something we want to fix maybe not. :) |
Put on the 0.18 roadmap |
@hhassey I added the forum thread to this ticket. Please do the same in the future. Thanks. |
@Kunda1 I did put the forum thread, Maybe it is now duplicated... |
https://github.com/FreeCAD/FreeCAD/commit/22ddbe0f8d61fcffbb8d3369a7bbb80a7515b558 |
| 2018-10-10 16:23 | hhassey | New Issue | |
| 2018-10-10 16:23 | hhassey | Tag Attached: Arch | |
| 2018-10-10 16:23 | hhassey | File Added: Correct.png | |
| 2018-10-10 16:23 | hhassey | File Added: wrong.png | |
| 2018-10-10 16:43 | hhassey | Note Added: 0011992 | |
| 2018-10-10 17:46 | Kunda1 | Relationship added | has duplicate 0003631 |
| 2018-10-10 17:47 | Kunda1 | Tag Attached: unicode | |
| 2018-10-10 17:48 | Kunda1 | Summary | Drawing lines on top of an image will not save the work => Drawing lines on top of an image will not save the work (Reason: Unicode issue: ' &' in the file name) |
| 2018-10-10 17:48 | Kunda1 | Relationship added | related to 0002973 |
| 2018-10-10 17:49 | Kunda1 | Tag Detached: Arch | |
| 2018-10-10 17:49 | Kunda1 | Target Version | => 0.18 |
| 2018-10-10 17:49 | Kunda1 | Note Added: 0011993 | |
| 2018-10-10 19:44 | Kunda1 | Description Updated | |
| 2018-10-10 19:45 | Kunda1 | Note Added: 0011998 | |
| 2018-10-10 19:48 | hhassey | Note Added: 0011999 | |
| 2018-10-11 13:02 | Kunda1 | Assigned To | => wmayer |
| 2018-10-11 13:02 | Kunda1 | Status | new => assigned |
| 2018-10-11 19:40 | wmayer | Relationship deleted | related to 0002973 |
| 2018-10-11 19:51 | wmayer | Summary | Drawing lines on top of an image will not save the work (Reason: Unicode issue: ' &' in the file name) => Drawing lines on top of an image will not save the work (Reason: ' &' in the file name) |
| 2018-10-11 19:51 | wmayer | Status | assigned => closed |
| 2018-10-11 19:51 | wmayer | Resolution | open => fixed |
| 2018-10-11 19:51 | wmayer | Fixed in Version | => 0.18 |
| 2018-10-11 19:51 | wmayer | Note Added: 0012004 |
