| 0003634 | TechDraw | Bug | public | 2018-10-11 12:19 | 2018-10-13 00:17 |
| Reporter | aapo | Assigned To | wandererfan | ||
| Platform | x64 | OS | Windows | OS Version | 10 |
| Summary | 0003634: Techdraw module loses the dimension field "Format Spec" on save-load cycle | ||||
| Description | Techdraw workbench loses the dimension field "Format Spec" on save-load cycle. The field "Format Spec" resets to the default value "%.2f", which should not happen. | ||||
| Steps To Reproduce | 1. Open FreeCAD. 2. Create a new document. 3. Create a new part, and a new cube inside the part in PartDesign workbench. 4. Create a default page in TechDraw workbench. 5. Create a ProjGroup Front-view of the cube in TechDraw page. 6. Add a dimension for one side of the cube. 7. Edit the dimension properties: "Arbitrary=true" and "Format Spec=ThisIsACube". The specified text will show on the dimension now, as expected. 8. Save the document. 9. Close FreeCAD. 10. Open FreeCAD and load the saved document. The field "Format Spec" has been reset to the default value "%.2f", which should not happen. | ||||
| Additional Information | OS: Windows 8 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14957 (Git) Build type: Release Branch: master Hash: 22513600ddc11a8d0d392f67225d443b7dc2e5bb Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: English/UnitedKingdom (en_GB) | ||||
| Tags | TechDraw | ||||
@aapo thanks for the ticket. In the future, per our bugtracker guidelines, please open a forum thread about this issue before opening a ticket. Many times the devs will fix it before it needs to become a ticket. CC @wandererfan |
https://github.com/FreeCAD/FreeCAD/commit/cb30a82969215e8ca88f2fa9d491648401e5b4bb |
| 2018-10-11 12:19 | aapo | New Issue | |
| 2018-10-11 12:19 | aapo | Tag Attached: TechDraw | |
| 2018-10-11 13:03 | Kunda1 | Product Version | 0.19 => 0.18 |
| 2018-10-11 13:05 | Kunda1 | Note Added: 0012003 | |
| 2018-10-13 00:17 | wmayer | Assigned To | => wandererfan |
| 2018-10-13 00:17 | wmayer | Status | new => closed |
| 2018-10-13 00:17 | wmayer | Resolution | open => fixed |
| 2018-10-13 00:17 | wmayer | Fixed in Version | => 0.18 |
| 2018-10-13 00:17 | wmayer | Note Added: 0012016 |
