| 0003643 | Arch | Feature | public | 2018-10-19 13:50 | 2019-05-09 18:19 |
| Reporter | amarao | Assigned To | yorik | ||
| Priority | low | Severity | tweak | Reproducibility | always |
| Summary | 0003643: Add' button in Arch section does nothing for an empty selection | ||||
| Description | Double click on arch. section open a dialog to add and remove object into section. To add objects it expects user to select something and then press 'add'. It was really, really confusing for me, I thought it was broken, until I found that I need to select some objects beforehand. My proposal is to add some notification (f.e. popup 'No object was selected to add') or to disable button with tooltip saying that 'Select an object and press add'). | ||||
| Steps To Reproduce | 1. Create arch. section 2. Double click on it in tree view 3. Click 'add' Expected behavior: a) Add is inactive before something was selected b) or there is a message that 'nothing was added because selection is empty' | ||||
| Additional Information | I know, it sound as a minor issue for an experienced user, but for a beginner is was a major blocker. | ||||
A discussion thread on the forum: https://forum.freecadweb.org/viewtopic.php?f=3&t=31572 |
Indeed, the same problem also exists with other Arch objects, although there the button stays greyed out if no object is selected, which helps. The best is of course for all these cases to allow the user to pick an object if none is selected when pressing the add button. I'll add that ASAP Note to self - also, grey out the "remove" button if none is selected in the above list, and pre-select a default category to add to in std arch components |
| 2018-10-19 13:50 | amarao | New Issue | |
| 2018-10-19 13:51 | amarao | Note Added: 0012072 | |
| 2018-10-19 14:15 | Kunda1 | Assigned To | => yorik |
| 2018-10-19 14:15 | Kunda1 | Status | new => assigned |
| 2018-10-19 14:15 | Kunda1 | Target Version | => 0.18 |
| 2018-10-22 18:20 | yorik | Note Added: 0012083 | |
| 2019-02-15 00:25 | yorik | Target Version | 0.18 => 0.19 |
| 2019-05-09 18:19 | yorik | Changeset attached | => FreeCAD master 8b4d6c0e |
| 2019-05-09 18:19 | yorik | Note Added: 0013095 | |
| 2019-05-09 18:19 | yorik | Status | assigned => closed |
| 2019-05-09 18:19 | yorik | Resolution | open => fixed |
