| 0003686 | FreeCAD | Bug | public | 2018-11-13 02:09 | 2018-11-13 20:02 |
| Reporter | mtdew365 | Assigned To | wmayer | ||
| Summary | 0003686: Version c18785fdb (github) will not compile | ||||
| Description | Fedora 29. Trying to compile FreeCAD. The latest versions I receive errors and will not compile. Specifically FreeCad version c18785fdb from github. | ||||
| Steps To Reproduce | 1. Download latest.... 2. cd FreeCad/build 3. cmake -DBUILD_SURFACE=OFF -DCMAKE_BUILD_TYPE=Release 4. make -j4 Results... -- Compiler: GNU, version: 8.2.1 -- prefix: /usr/local -- datadir: data -- docdir: doc -- includedir: include -- libdir: /usr/local/lib -- cmake: 3.12.1 -- Boost version: 1.66.0 -- Found the following Boost libraries: -- filesystem -- program_options -- regex -- system -- thread -- chrono -- date_time -- atomic -- Found Xerces-C: /usr/lib64/libxerces-c.so -- PyCXX found: -- Headers: /home/jbergmann/FreeCAD/src -- Sources: /home/jbergmann/FreeCAD/src/CXX -- Version: 6.2.8 -- -- OpenCASCADE Community Edition has been found. -- -- Found OCE/OpenCASCADE version: 6.9.1 -- -- OCE/OpenCASCADE include directory: /usr/lib64/oce-0.18/../../include/oce -- -- OCE/OpenCASCADE shared libraries directory: -- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2 -- Checking for one of the modules 'hdf5-serial' -- HDF5: Using hdf5 compiler wrapper to determine C configuration -- Check for medfile (libmed and libmedc) ... CMake Warning (dev) at /usr/share/cmake/Modules/FindOpenGL.cmake:270 (message): Policy CMP0072 is not set: FindOpenGL prefers GLVND by default when available. Run "cmake --help-policy CMP0072" for policy details. Use the cmake_policy command to set the policy and suppress this warning. FindOpenGL found both a legacy GL library: OPENGL_gl_LIBRARY: /usr/lib64/libGL.so and GLVND libraries for OpenGL and GLX: OPENGL_opengl_LIBRARY: /usr/lib64/libOpenGL.so OPENGL_glx_LIBRARY: /usr/lib64/libGLX.so OpenGL_GL_PREFERENCE has not been set to "GLVND" or "LEGACY", so for compatibility with CMake 3.10 and below the legacy GL library will be used. Call Stack (most recent call first): CMakeLists.txt:912 (find_package) This warning is for project developers. Use -Wno-dev to suppress it. -- Checking for module 'Coin' -- Found Coin, version 3.1.3 -- Using default python: -python2.7 -- libshiboken built for Release -- Found PySide Tools: /usr/bin/pyside-uic, /usr/bin/pyside-rcc -- -- matplotlib-2.2.3 has been found. -- Platform is 64-bit, set -D_OCC64 -- Build type: Release git /home/jbergmann/FreeCAD/build/src/Build/Version.h.out written -- setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors -- Could NOT find Boost -- Could NOT find Boost -- Boost version: 1.66.0 -- Found the following Boost libraries: -- python -- found Boost: 1_66 -- boost-incude dirs are: /usr/include -- boost-python lib is: /usr/lib64/libboost_python.a -- boost_LIBRARY_DIRS is: /usr/lib64 -- Boost_LIBRARIES is: /usr/lib64/libboost_python.a -- area module (for Path Workbench) will be installed to: /usr/local/lib -- Coin3D doc is not installed ======================================= Now run 'make' to build FreeCAD ======================================= -- Configuring done -- Generating done -- Build files have been written to: /home/jbergmann/FreeCAD/build jbergmann ~ FreeCAD build make -j4 [ 0%] Built target Driver [ 0%] Built target MEFISTO2 [ 0%] Built target Complete [ 1%] Built target SMDS [ 1%] Built target CompleteGui [ 2%] Built target Test [ 2%] Built target ImageScripts [ 6%] Built target FreeCADBase [ 7%] Built target MeshScripts [ 8%] Built target PartScripts [ 8%] Built target MaterialLib [ 8%] Built target Material [ 8%] Built target FluidMaterialLib [ 8%] Built target WizardShaft [ 9%] Built target PartDesignScripts [ 9%] Built target RaytracingScripts [ 9%] Built target SketcherScripts [ 10%] Built target DrawingScripts [ 11%] Built target RobotScripts [ 11%] Built target ReverseEngineeringScripts [ 12%] Built target Draft [ 12%] Built target WebScripts [ 12%] Built target StartScripts [ 13%] Built target StartPage [ 14%] Built target Idf [ 14%] Built target ImportScripts [ 15%] Built target ImportPy [ 16%] Built target Arch [ 16%] Built target FemGuiScriptsTarget [ 20%] Built target FemScriptsTarget [ 21%] Built target FemPythonUi [ 22%] Built target Ship [ 22%] Built target OpenSCAD [ 22%] Built target Plot [ 23%] Built target PathTests [ 23%] Built target SpreadsheetScripts [ 27%] Built target PathScripts [ 27%] Built target area-native [ 28%] Built target Show [ 28%] Built target TDTestTarget [ 28%] Built target TechDraw_Data [ 28%] Built target AddonManager [ 28%] Built target Tux [ 29%] Built target freecad_COPY_SOURCE [ 31%] Built target Stylesheets_data [ 31%] Built target Example_data [ 31%] Built target DriverDAT [ 31%] Built target DriverSTL [ 32%] Built target SMESHDS [ 32%] Linking CXX shared module ../../../../lib/area.so [ 33%] Built target DriverUNV [ 35%] Built target FreeCADApp [ 36%] Built target FreeCADMainCmd [ 36%] Built target FreeCADMainPy /usr/bin/ld: /usr/lib/gcc/x86_64-redhat-linux/8/../../../../lib64/libboost_python.a(list.o): relocation R_X86_64_PC32 against symbol `PyList_Type' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: final link failed: bad value collect2: error: ld returned 1 exit status make[2]: *** [src/Mod/Path/libarea/CMakeFiles/area.dir/build.make:87: lib/area.so] Error 1 make[1]: *** [CMakeFiles/Makefile2:5125: src/Mod/Path/libarea/CMakeFiles/area.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... [ 37%] Built target Points [ 38%] Built target SMESH [ 52%] Built target FreeCADGui make: *** [Makefile:130: all] Error 2 | ||||
/usr/bin/ld: /usr/lib/gcc/x86_64-redhat-linux/8/../../../../lib64/libboost_python.a(list.o): relocation R_X86_64_PC32 against symbol `PyList_Type' can not be used when making a shared object; recompile with -fPICYou are using the static boost.python library. Install the shared version and try again. |
setting status to 'feedback' (wmayer, quick favor, in the future..do you mind setting the status to 'feedback' when replying. That way we don't lose sight of tickets that require info from their OPs. Thanks!) |
Installed boost-python2-devel and recompiled. Strange that I have not needed that package before.... Compiled correctly and runs. |
| 2018-11-13 02:09 | mtdew365 | New Issue | |
| 2018-11-13 11:21 | wmayer | Note Added: 0012186 | |
| 2018-11-13 14:56 | Kunda1 | Status | new => feedback |
| 2018-11-13 14:56 | Kunda1 | Note Added: 0012188 | |
| 2018-11-13 14:58 | Kunda1 | Note Edited: 0012188 | |
| 2018-11-13 19:18 | mtdew365 | Note Added: 0012192 | |
| 2018-11-13 19:18 | mtdew365 | Status | feedback => new |
| 2018-11-13 20:02 | wmayer | Assigned To | => wmayer |
| 2018-11-13 20:02 | wmayer | Status | new => closed |
| 2018-11-13 20:02 | wmayer | Resolution | open => no change required |
