| 0003691 | Draft | Bug | public | 2018-11-14 06:52 | 2021-02-21 03:08 |
| Reporter | JaneE | Assigned To | |||
| Platform | 64 bit | OS | Windows | OS Version | 10 Home |
| Target Version | 0.19 | Fixed in Version | 0.19 | ||
| Summary | 0003691: Draft Scale only scales up but not down | ||||
| Description | When using "Draft Scale" on a shape all decimal points for scale vector ignored. I can only make shapes larger but not smaller than the original. | ||||
| Steps To Reproduce | Reset preferences Create New Document Select Draft Workspace Create a Rectangle (or any other geometry) Highlight the created Rectangle Select "Draft Scale" Choose point In the scale task window any X, Y, Z factors changes "1" to any higher number works fine. But typing numbers less than 1 does not work (like 0.75). I have tried using "." and "," but none work. | ||||
| Tags | Draft, units | ||||
I am in a project that relies on scaling down and encounter the same problem (the alternative being importing scaled point clouds from Excel and making scaled BSplines). Is there an idea if and when this bug can be fixed. I prefer an internal FreeCAD solution because of the excellent posibilities to adapt earlier features. |
@JaneE and @AbdeJong please discuss this on the FC forum as per our guidelines (big yellow banner at the top of this bugtracker). Please make sure you also test this issue on the latest 0.18_pre version. Report back your findings please. |
Works as designed, OP might have set decimal places wrong. Tested with OS: Ubuntu 16.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15780 (Git) Build type: Release Branch: master Hash: f94e76c1116ec3b818961ff65131b3d86fa5b95e Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) |
Initial settings of a vanilla FreeCAD with 2 decimals do not apply to the scale dialog, where decimals are even more important as in length values. I can fix this by - open Preferences - open General->Units without changing anything! - conform settings with ok Now the scale dialog shows 6 decimals. Corresponding forum discussion. |
Another report: https://forum.freecad.org/viewtopic.php?f=29&t=40148 I edited the ticket to include "reset preferences" in steps. |
This bug was fixed: https://github.com/FreeCAD/FreeCAD/pull/4115 The ticket should be closed @Kunda1 |
FreeCAD master dd580a49 |
Fixed. Closed manually. |
| 2018-11-14 06:52 | JaneE | New Issue | |
| 2018-11-14 06:52 | JaneE | Tag Attached: Draft | |
| 2019-01-02 18:56 | AbdeJong | Note Added: 0012362 | |
| 2019-01-04 18:45 | Kunda1 | Status | new => feedback |
| 2019-01-04 18:45 | Kunda1 | Note Added: 0012368 | |
| 2019-02-03 22:30 | chrisb | Assigned To | => chrisb |
| 2019-02-03 22:30 | chrisb | Status | feedback => closed |
| 2019-02-03 22:30 | chrisb | Resolution | open => no change required |
| 2019-02-03 22:30 | chrisb | Note Added: 0012580 | |
| 2019-02-04 10:34 | chrisb | Status | closed => feedback |
| 2019-02-04 10:34 | chrisb | Resolution | no change required => reopened |
| 2019-02-04 10:34 | chrisb | Note Added: 0012581 | |
| 2019-02-04 10:35 | chrisb | Status | feedback => new |
| 2019-10-17 12:49 | DeepSOIC | Steps to Reproduce Updated | |
| 2019-10-17 12:50 | DeepSOIC | Note Added: 0013763 | |
| 2021-02-11 17:41 | Kunda1 | Tag Attached: units | |
| 2021-02-21 02:57 | marioalexis | Note Added: 0015398 | |
| 2021-02-21 03:05 | Kunda1 | Note Added: 0015399 | |
| 2021-02-21 03:06 | Kunda1 | Changeset attached | => FreeCAD master dd580a49 |
| 2021-02-21 03:07 | Kunda1 | Target Version | 0.20 => 0.19 |
| 2021-02-21 03:08 | Kunda1 | Assigned To | chrisb => |
| 2021-02-21 03:08 | Kunda1 | Status | new => closed |
| 2021-02-21 03:08 | Kunda1 | Fixed in Version | => 0.19 |
| 2021-02-21 03:08 | Kunda1 | Note Added: 0015400 |
