| 0003729 | FreeCAD | Bug | public | 2018-12-14 19:32 | 2018-12-24 16:28 |
| Reporter | mrnuke | Assigned To | wmayer | ||
| Summary | 0003729: REGRESSION: FreeCAD 0.17 does not export color information with STEP files | ||||
| Description | With FreeCAD 0.17, exporting a part as a STEP file does not preserve color information. Downgrading to FreeCAD 0.16 and exporting the same files produces the correct color information. | ||||
| Steps To Reproduce | Open a *.fcstd part. In the Model View, selecto the components to export. Select File->Export From "Files of Type" dropdown at the bottom select "STEP with colors (*.step *.stp)" Save as a new file. Open the new file in FreeCad. | ||||
Example file which causes the issue |
OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.Unknown Build type: Unknown Python version: 2.7.15 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.9.1.oce-0.18 Locale: English/UnitedStates (en_US) |
please check 0.18 dev version https://github.com/FreeCAD/FreeCAD/releases/tag/0.18_pre |
transforner-as1052-ac.step (854,515 bytes)
ISO-10303-21;
HEADER;
FILE_DESCRIPTION(('FreeCAD Model'),'2;1');
FILE_NAME('/home/mrnuke/transforner-as1052-ac.step',
'2018-12-14T13:22:41',('Author'),(''),
'Open CASCADE STEP processor 6.9','FreeCAD','Unknown');
FILE_SCHEMA(('AUTOMOTIVE_DESIGN { 1 0 10303 214 1 1 1 1 }'));
ENDSEC;
DATA;
#1 = APPLICATION_PROTOCOL_DEFINITION('international standard',
'automotive_design',2000,#2);
#2 = APPLICATION_CONTEXT(
'core data for automotive mechanical design processes');
#3 = SHAPE_DEFINITION_REPRESENTATION(#4,#10);
#4 = PRODUCT_DEFINITION_SHAPE('','',#5);
#5 = PRODUCT_DEFINITION('design','',#6,#9);
#6 = PRODUCT_DEFINITION_FORMATION('','',#7);
#7 = PRODUCT('ASSEMBLY','ASSEMBLY','',(#8));
#8 = PRODUCT_CONTEXT('',#2,'mechanical');
#9 = PRODUCT_DEFINITION_CONTEXT('part definition',#2,'design');
#10 = SHAPE_REPRESENTATION('',(#11,#15,#19,#23,#27),#31);
#11 = AXIS2_PLACEMENT_3D('',#12,#13,#14);
#12 = CARTESIAN_POINT('',(0.,0.,0.));
#13 = DIRECTION('',(0.,0.,1.));
#14 = DIRECTION('',(1.,0.,-0.));
#15 = AXIS2_PLACEMENT_3D('',#16,#17,#18);
#16 = CARTESIAN_POINT('',(-2.5,0.,0.));
#17 = DIRECTION('',(0.,0.,1.));
#18 = DIRECTION('',(1.,0.,0.));
#19 = AXIS2_PLACEMENT_3D('',#20,#21,#22);
#20 = CARTESIAN_POINT('',(2.5,-16.,0.));
#21 = DIRECTION('',(0.,0.,1.));
#22 = DIRECTION('',(-1.,0.,0.));
#23 = AXIS2_PLACEMENT_3D('',#24,#25,#26);
#24 = CARTESIAN_POINT('',(-2.5,-16.,0.));
#25 = DIRECTION('',(0.,0.,1.));
#26 = DIRECTION('',(-1.,0.,0.));
#27 = AXIS2_PLACEMENT_3D('',#28,#29,#30);
#28 = CARTESIAN_POINT('',(0.,0.,0.));
#29 = DIRECTION('',(0.,0.,1.));
#30 = DIRECTION('',(1.,0.,0.));
#31 = ( GEOMETRIC_REPRESENTATION_CONTEXT(3)
GLOBAL_UNCERTAINTY_ASSIGNED_CONTEXT((#35)) GLOBAL_UNIT_ASSIGNED_CONTEXT(
(#32,#33,#34)) REPRESENTATION_CONTEXT('Context #1',
'3D Context with UNIT and UNCERTAINTY') );
#32 = ( LENGTH_UNIT() NAMED_UNIT(*) SI_UNIT(.MILLI.,.METRE.) );
#33 = ( NAMED_UNIT(*) PLANE_ANGLE_UNIT() SI_UNIT($,.RADIAN.) );
#34 = ( NAMED_UNIT(*) SI_UNIT($,.STERADIAN.) SOLID_ANGLE_UNIT() );
#35 = UNCERTAINTY_MEASURE_WITH_UNIT(LENGTH_MEASURE(1.E-07),#32,
'distance_accuracy_value','confusion accuracy');
#36 = PRODUCT_RELATED_PRODUCT_CATEGORY('part',$,(#7));
#37 = ADVANCED_BREP_SHAPE_REPRESENTATION('',(#11,#38),#249);
#38 = MANIFOLD_SOLID_BREP('',#39);
#39 = CLOSED_SHELL('',(#40,#129,#183,#241,#245));
#40 = ADVANCED_FACE('',(#41),#55,.F.);
#41 = FACE_BOUND('',#42,.F.);
#42 = EDGE_LOOP('',(#43,#75,#101,#102));
#43 = ORIENTED_EDGE('',*,*,#44,.T.);
#44 = EDGE_CURVE('',#45,#47,#49,.T.);
#45 = VERTEX_POINT('',#46);
#46 = CARTESIAN_POINT('',(0.21,1.999999877601,-3.00001021268));
#47 = VERTEX_POINT('',#48);
#48 = CARTESIAN_POINT('',(0.21,1.999999877575,0.49998978732));
#49 = SEAM_CURVE('',#50,(#54,#68),.PCURVE_S1.);
#50 = LINE('',#51,#52);
#51 = CARTESIAN_POINT('',(0.21,1.999999877601,-3.00001021268));
#52 = VECTOR('',#53,1.);
#53 = DIRECTION('',(0.,0.,1.));
#54 = PCURVE('',#55,#63);
#55 = SURFACE_OF_LINEAR_EXTRUSION('',#56,#61);
#56 = CIRCLE('',#57,0.21);
#57 = AXIS2_PLACEMENT_3D('',#58,#59,#60);
#58 = CARTESIAN_POINT('',(0.,1.999999877601,-3.00001021268));
#59 = DIRECTION('',(0.,-1.009028106268E-05,-0.999999999949));
#60 = DIRECTION('',(1.,0.,0.));
#61 = VECTOR('',#62,1.);
#62 = DIRECTION('',(0.,0.,1.));
#63 = DEFINITIONAL_REPRESENTATION('',(#64),#67);
#64 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#65,#66),.UNSPECIFIED.,.F.,.F.,(2,
2),(0.,3.5),.PIECEWISE_BEZIER_KNOTS.);
#65 = CARTESIAN_POINT('',(6.28318530718,0.));
#66 = CARTESIAN_POINT('',(6.28318530718,3.5));
#67 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
PARAMETRIC_REPRESENTATION_CONTEXT() REPRESENTATION_CONTEXT('2D SPACE',''
#68 = PCURVE('',#55,#69);
#69 = DEFINITIONAL_REPRESENTATION('',(#70),#74);
#70 = LINE('',#71,#72);
#71 = CARTESIAN_POINT('',(0.,0.));
#72 = VECTOR('',#73,1.);
#73 = DIRECTION('',(0.,1.));
#74 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#75 = ORIENTED_EDGE('',*,*,#76,.F.);
#76 = EDGE_CURVE('',#47,#47,#77,.T.);
#77 = SURFACE_CURVE('',#78,(#83,#90),.PCURVE_S1.);
#78 = CIRCLE('',#79,0.21);
#79 = AXIS2_PLACEMENT_3D('',#80,#81,#82);
#80 = CARTESIAN_POINT('',(0.,1.999999877601,0.49998978732));
#81 = DIRECTION('',(0.,-1.009028106268E-05,-0.999999999949));
#82 = DIRECTION('',(1.,0.,0.));
#83 = PCURVE('',#55,#84);
#84 = DEFINITIONAL_REPRESENTATION('',(#85),#89);
#85 = LINE('',#86,#87);
#86 = CARTESIAN_POINT('',(0.,3.5));
#87 = VECTOR('',#88,1.);
#88 = DIRECTION('',(1.,0.));
#89 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#90 = PCURVE('',#91,#96);
#91 = TOROIDAL_SURFACE('',#92,1.,0.21);
#92 = AXIS2_PLACEMENT_3D('',#93,#94,#95);
#93 = CARTESIAN_POINT('',(0.,0.999999877601,0.5));
#94 = DIRECTION('',(1.,0.,-0.));
#95 = DIRECTION('',(-0.,1.,-1.1E-16));
#96 = DEFINITIONAL_REPRESENTATION('',(#97),#100);
#97 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#98,#99),.UNSPECIFIED.,.F.,.F.,(2,
2),(0.,6.28318530718),.PIECEWISE_BEZIER_KNOTS.);
#98 = CARTESIAN_POINT('',(6.2831750945,1.570796326795));
#99 = CARTESIAN_POINT('',(6.2831750945,7.853981633974));
#100 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#101 = ORIENTED_EDGE('',*,*,#44,.F.);
#102 = ORIENTED_EDGE('',*,*,#103,.T.);
#103 = EDGE_CURVE('',#45,#45,#104,.T.);
#104 = SURFACE_CURVE('',#105,(#110,#117),.PCURVE_S1.);
#105 = CIRCLE('',#106,0.21);
#106 = AXIS2_PLACEMENT_3D('',#107,#108,#109);
#107 = CARTESIAN_POINT('',(0.,1.999999877601,-3.00001021268));
#108 = DIRECTION('',(0.,-1.009028106268E-05,-0.999999999949));
#109 = DIRECTION('',(1.,0.,0.));
#110 = PCURVE('',#55,#111);
#111 = DEFINITIONAL_REPRESENTATION('',(#112),#116);
#112 = LINE('',#113,#114);
#113 = CARTESIAN_POINT('',(0.,0.));
#114 = VECTOR('',#115,1.);
#115 = DIRECTION('',(1.,0.));
#116 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#117 = PCURVE('',#118,#123);
#118 = PLANE('',#119);
#119 = AXIS2_PLACEMENT_3D('',#120,#121,#122);
#120 = CARTESIAN_POINT('',(-2.E-17,1.999999877601,-3.00001021268));
#121 = DIRECTION('',(-0.,-1.00902810639E-05,-0.999999999949));
#122 = DIRECTION('',(-0.,-0.999999999949,1.00902810639E-05));
#123 = DEFINITIONAL_REPRESENTATION('',(#124),#128);
#124 = CIRCLE('',#125,0.21);
#125 = AXIS2_PLACEMENT_2D('',#126,#127);
#126 = CARTESIAN_POINT('',(-2.2E-16,-2.E-17));
#127 = DIRECTION('',(0.,-1.));
#128 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#129 = ADVANCED_FACE('',(#130),#91,.T.);
#130 = FACE_BOUND('',#131,.T.);
#131 = EDGE_LOOP('',(#132,#155,#181,#182));
#132 = ORIENTED_EDGE('',*,*,#133,.T.);
#133 = EDGE_CURVE('',#47,#134,#136,.T.);
#134 = VERTEX_POINT('',#135);
#135 = CARTESIAN_POINT('',(0.21,1.,1.5));
#136 = SEAM_CURVE('',#137,(#142,#149),.PCURVE_S1.);
#137 = CIRCLE('',#138,1.);
#138 = AXIS2_PLACEMENT_3D('',#139,#140,#141);
#139 = CARTESIAN_POINT('',(0.21,0.999999877601,0.5));
#140 = DIRECTION('',(1.,0.,-0.));
#141 = DIRECTION('',(-0.,1.,-1.1E-16));
#142 = PCURVE('',#91,#143);
#143 = DEFINITIONAL_REPRESENTATION('',(#144),#148);
#144 = LINE('',#145,#146);
#145 = CARTESIAN_POINT('',(0.,1.570796326795));
#146 = VECTOR('',#147,1.);
#147 = DIRECTION('',(1.,0.));
#148 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#149 = PCURVE('',#91,#150);
#150 = DEFINITIONAL_REPRESENTATION('',(#151),#154);
#151 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#152,#153),.UNSPECIFIED.,.F.,.F.,
(2,2),(6.2831750945,7.853981511576),.PIECEWISE_BEZIER_KNOTS.);
#152 = CARTESIAN_POINT('',(6.2831750945,7.853981633974));
#153 = CARTESIAN_POINT('',(7.853981511576,7.853981633974));
#154 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#155 = ORIENTED_EDGE('',*,*,#156,.T.);
#156 = EDGE_CURVE('',#134,#134,#157,.T.);
#157 = SURFACE_CURVE('',#158,(#163,#170),.PCURVE_S1.);
#158 = CIRCLE('',#159,0.21);
#159 = AXIS2_PLACEMENT_3D('',#160,#161,#162);
#160 = CARTESIAN_POINT('',(0.,1.,1.5));
#161 = DIRECTION('',(-0.,1.,-1.2239874311E-07));
#162 = DIRECTION('',(0.,1.2239874311E-07,1.));
#163 = PCURVE('',#91,#164);
#164 = DEFINITIONAL_REPRESENTATION('',(#165),#169);
#165 = LINE('',#166,#167);
#166 = CARTESIAN_POINT('',(7.853981511576,0.));
#167 = VECTOR('',#168,1.);
#168 = DIRECTION('',(0.,1.));
#169 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#170 = PCURVE('',#171,#176);
#171 = CYLINDRICAL_SURFACE('',#172,0.21);
#172 = AXIS2_PLACEMENT_3D('',#173,#174,#175);
#173 = CARTESIAN_POINT('',(0.,1.,1.5));
#174 = DIRECTION('',(0.,-1.,0.));
#175 = DIRECTION('',(1.,0.,0.));
#176 = DEFINITIONAL_REPRESENTATION('',(#177),#180);
#177 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#178,#179),.UNSPECIFIED.,.F.,.F.,
(2,2),(1.570796326795,7.853981633974),.PIECEWISE_BEZIER_KNOTS.);
#178 = CARTESIAN_POINT('',(6.28318530718,0.));
#179 = CARTESIAN_POINT('',(0.,0.));
#180 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#181 = ORIENTED_EDGE('',*,*,#133,.F.);
#182 = ORIENTED_EDGE('',*,*,#76,.F.);
#183 = ADVANCED_FACE('',(#184),#171,.T.);
#184 = FACE_BOUND('',#185,.T.);
#185 = EDGE_LOOP('',(#186,#208,#239,#240));
#186 = ORIENTED_EDGE('',*,*,#187,.T.);
#187 = EDGE_CURVE('',#134,#188,#190,.T.);
#188 = VERTEX_POINT('',#189);
#189 = CARTESIAN_POINT('',(0.21,0.,1.5));
#190 = SEAM_CURVE('',#191,(#195,#202),.PCURVE_S1.);
#191 = LINE('',#192,#193);
#192 = CARTESIAN_POINT('',(0.21,1.,1.5));
#193 = VECTOR('',#194,1.);
#194 = DIRECTION('',(0.,-1.,0.));
#195 = PCURVE('',#171,#196);
#196 = DEFINITIONAL_REPRESENTATION('',(#197),#201);
#197 = LINE('',#198,#199);
#198 = CARTESIAN_POINT('',(6.28318530718,0.));
#199 = VECTOR('',#200,1.);
#200 = DIRECTION('',(0.,1.));
#201 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#202 = PCURVE('',#171,#203);
#203 = DEFINITIONAL_REPRESENTATION('',(#204),#207);
#204 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#205,#206),.UNSPECIFIED.,.F.,.F.,
(2,2),(0.,1.),.PIECEWISE_BEZIER_KNOTS.);
#205 = CARTESIAN_POINT('',(0.,0.));
#206 = CARTESIAN_POINT('',(0.,1.));
#207 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#208 = ORIENTED_EDGE('',*,*,#209,.F.);
#209 = EDGE_CURVE('',#188,#188,#210,.T.);
#210 = SURFACE_CURVE('',#211,(#216,#223),.PCURVE_S1.);
#211 = CIRCLE('',#212,0.21);
#212 = AXIS2_PLACEMENT_3D('',#213,#214,#215);
#213 = CARTESIAN_POINT('',(0.,0.,1.5));
#214 = DIRECTION('',(0.,-1.,0.));
#215 = DIRECTION('',(1.,0.,0.));
#216 = PCURVE('',#171,#217);
#217 = DEFINITIONAL_REPRESENTATION('',(#218),#222);
#218 = LINE('',#219,#220);
#219 = CARTESIAN_POINT('',(0.,1.));
#220 = VECTOR('',#221,1.);
#221 = DIRECTION('',(1.,0.));
#222 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#223 = PCURVE('',#224,#229);
#224 = PLANE('',#225);
#225 = AXIS2_PLACEMENT_3D('',#226,#227,#228);
#226 = CARTESIAN_POINT('',(-3.E-17,0.,1.5));
#227 = DIRECTION('',(0.,1.,0.));
#228 = DIRECTION('',(0.,-0.,1.));
#229 = DEFINITIONAL_REPRESENTATION('',(#230),#238);
#230 = ( BOUNDED_CURVE() B_SPLINE_CURVE(2,(#231,#232,#233,#234,#235,#236
,#237),.UNSPECIFIED.,.F.,.F.) B_SPLINE_CURVE_WITH_KNOTS((1,2,2,2,2,1),(
-2.094395102393,0.,2.094395102393,4.188790204786,6.28318530718,
8.377580409573),.UNSPECIFIED.) CURVE() GEOMETRIC_REPRESENTATION_ITEM()
RATIONAL_B_SPLINE_CURVE((1.,0.5,1.,0.5,1.,0.5,1.)) REPRESENTATION_ITEM(
#231 = CARTESIAN_POINT('',(2.2E-16,0.21));
#232 = CARTESIAN_POINT('',(0.363730669589,0.21));
#233 = CARTESIAN_POINT('',(0.181865334795,-0.105));
#234 = CARTESIAN_POINT('',(2.714351655642E-16,-0.42));
#235 = CARTESIAN_POINT('',(-0.181865334795,-0.105));
#236 = CARTESIAN_POINT('',(-0.363730669589,0.21));
#237 = CARTESIAN_POINT('',(2.2E-16,0.21));
#238 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#239 = ORIENTED_EDGE('',*,*,#187,.F.);
#240 = ORIENTED_EDGE('',*,*,#156,.F.);
#241 = ADVANCED_FACE('',(#242),#118,.T.);
#242 = FACE_BOUND('',#243,.T.);
#243 = EDGE_LOOP('',(#244));
#244 = ORIENTED_EDGE('',*,*,#103,.T.);
#245 = ADVANCED_FACE('',(#246),#224,.F.);
#246 = FACE_BOUND('',#247,.F.);
#247 = EDGE_LOOP('',(#248));
#248 = ORIENTED_EDGE('',*,*,#209,.F.);
#249 = ( GEOMETRIC_REPRESENTATION_CONTEXT(3)
GLOBAL_UNCERTAINTY_ASSIGNED_CONTEXT((#253)) GLOBAL_UNIT_ASSIGNED_CONTEXT
((#250,#251,#252)) REPRESENTATION_CONTEXT('Context #1',
#250 = ( LENGTH_UNIT() NAMED_UNIT(*) SI_UNIT(.MILLI.,.METRE.) );
#251 = ( NAMED_UNIT(*) PLANE_ANGLE_UNIT() SI_UNIT($,.RADIAN.) );
#252 = ( NAMED_UNIT(*) SI_UNIT($,.STERADIAN.) SOLID_ANGLE_UNIT() );
#253 = UNCERTAINTY_MEASURE_WITH_UNIT(LENGTH_MEASURE(1.E-07),#250,
#254 = SHAPE_DEFINITION_REPRESENTATION(#255,#37);
#255 = PRODUCT_DEFINITION_SHAPE('','',#256);
#256 = PRODUCT_DEFINITION('design','',#257,#260);
#257 = PRODUCT_DEFINITION_FORMATION('','',#258);
#258 = PRODUCT('terminal-2','terminal-2','',(#259));
#259 = PRODUCT_CONTEXT('',#2,'mechanical');
#260 = PRODUCT_DEFINITION_CONTEXT('part definition',#2,'design');
#261 = CONTEXT_DEPENDENT_SHAPE_REPRESENTATION(#262,#264);
#262 = ( REPRESENTATION_RELATIONSHIP('','',#37,#10)
REPRESENTATION_RELATIONSHIP_WITH_TRANSFORMATION(#263)
SHAPE_REPRESENTATION_RELATIONSHIP() );
#263 = ITEM_DEFINED_TRANSFORMATION('','',#11,#15);
#264 = PRODUCT_DEFINITION_SHAPE('Placement','Placement of an item',#265
#265 = NEXT_ASSEMBLY_USAGE_OCCURRENCE('1','=>[0:1:1:2]','',#5,#256,$);
#266 = PRODUCT_RELATED_PRODUCT_CATEGORY('part',$,(#258));
#267 = ADVANCED_BREP_SHAPE_REPRESENTATION('',(#11,#268),#479);
#268 = MANIFOLD_SOLID_BREP('',#269);
#269 = CLOSED_SHELL('',(#270,#359,#413,#471,#475));
#270 = ADVANCED_FACE('',(#271),#285,.F.);
#271 = FACE_BOUND('',#272,.F.);
#272 = EDGE_LOOP('',(#273,#305,#331,#332));
#273 = ORIENTED_EDGE('',*,*,#274,.T.);
#274 = EDGE_CURVE('',#275,#277,#279,.T.);
#275 = VERTEX_POINT('',#276);
#276 = CARTESIAN_POINT('',(0.21,1.999999877601,-3.00001021268));
#277 = VERTEX_POINT('',#278);
#278 = CARTESIAN_POINT('',(0.21,1.999999877575,0.49998978732));
#279 = SEAM_CURVE('',#280,(#284,#298),.PCURVE_S1.);
#280 = LINE('',#281,#282);
#281 = CARTESIAN_POINT('',(0.21,1.999999877601,-3.00001021268));
#282 = VECTOR('',#283,1.);
#283 = DIRECTION('',(0.,0.,1.));
#284 = PCURVE('',#285,#293);
#285 = SURFACE_OF_LINEAR_EXTRUSION('',#286,#291);
#286 = CIRCLE('',#287,0.21);
#287 = AXIS2_PLACEMENT_3D('',#288,#289,#290);
#288 = CARTESIAN_POINT('',(0.,1.999999877601,-3.00001021268));
#289 = DIRECTION('',(0.,-1.009028106268E-05,-0.999999999949));
#290 = DIRECTION('',(1.,0.,0.));
#291 = VECTOR('',#292,1.);
#292 = DIRECTION('',(0.,0.,1.));
#293 = DEFINITIONAL_REPRESENTATION('',(#294),#297);
#294 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#295,#296),.UNSPECIFIED.,.F.,.F.,
(2,2),(0.,3.5),.PIECEWISE_BEZIER_KNOTS.);
#295 = CARTESIAN_POINT('',(6.28318530718,0.));
#296 = CARTESIAN_POINT('',(6.28318530718,3.5));
#297 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#298 = PCURVE('',#285,#299);
#299 = DEFINITIONAL_REPRESENTATION('',(#300),#304);
#300 = LINE('',#301,#302);
#301 = CARTESIAN_POINT('',(0.,0.));
#302 = VECTOR('',#303,1.);
#303 = DIRECTION('',(0.,1.));
#304 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#305 = ORIENTED_EDGE('',*,*,#306,.F.);
#306 = EDGE_CURVE('',#277,#277,#307,.T.);
#307 = SURFACE_CURVE('',#308,(#313,#320),.PCURVE_S1.);
#308 = CIRCLE('',#309,0.21);
#309 = AXIS2_PLACEMENT_3D('',#310,#311,#312);
#310 = CARTESIAN_POINT('',(0.,1.999999877601,0.49998978732));
#311 = DIRECTION('',(0.,-1.009028106268E-05,-0.999999999949));
#312 = DIRECTION('',(1.,0.,0.));
#313 = PCURVE('',#285,#314);
#314 = DEFINITIONAL_REPRESENTATION('',(#315),#319);
#315 = LINE('',#316,#317);
#316 = CARTESIAN_POINT('',(0.,3.5));
#317 = VECTOR('',#318,1.);
#318 = DIRECTION('',(1.,0.));
#319 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#320 = PCURVE('',#321,#326);
#321 = TOROIDAL_SURFACE('',#322,1.,0.21);
#322 = AXIS2_PLACEMENT_3D('',#323,#324,#325);
#323 = CARTESIAN_POINT('',(0.,0.999999877601,0.5));
#324 = DIRECTION('',(1.,0.,-0.));
#325 = DIRECTION('',(-0.,1.,-1.1E-16));
#326 = DEFINITIONAL_REPRESENTATION('',(#327),#330);
#327 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#328,#329),.UNSPECIFIED.,.F.,.F.,
(2,2),(0.,6.28318530718),.PIECEWISE_BEZIER_KNOTS.);
#328 = CARTESIAN_POINT('',(6.2831750945,1.570796326795));
#329 = CARTESIAN_POINT('',(6.2831750945,7.853981633974));
#330 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#331 = ORIENTED_EDGE('',*,*,#274,.F.);
#332 = ORIENTED_EDGE('',*,*,#333,.T.);
#333 = EDGE_CURVE('',#275,#275,#334,.T.);
#334 = SURFACE_CURVE('',#335,(#340,#347),.PCURVE_S1.);
#335 = CIRCLE('',#336,0.21);
#336 = AXIS2_PLACEMENT_3D('',#337,#338,#339);
#337 = CARTESIAN_POINT('',(0.,1.999999877601,-3.00001021268));
#338 = DIRECTION('',(0.,-1.009028106268E-05,-0.999999999949));
#339 = DIRECTION('',(1.,0.,0.));
#340 = PCURVE('',#285,#341);
#341 = DEFINITIONAL_REPRESENTATION('',(#342),#346);
#342 = LINE('',#343,#344);
#343 = CARTESIAN_POINT('',(0.,0.));
#344 = VECTOR('',#345,1.);
#345 = DIRECTION('',(1.,0.));
#346 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#347 = PCURVE('',#348,#353);
#348 = PLANE('',#349);
#349 = AXIS2_PLACEMENT_3D('',#350,#351,#352);
#350 = CARTESIAN_POINT('',(-2.E-17,1.999999877601,-3.00001021268));
#351 = DIRECTION('',(-0.,-1.00902810639E-05,-0.999999999949));
#352 = DIRECTION('',(-0.,-0.999999999949,1.00902810639E-05));
#353 = DEFINITIONAL_REPRESENTATION('',(#354),#358);
#354 = CIRCLE('',#355,0.21);
#355 = AXIS2_PLACEMENT_2D('',#356,#357);
#356 = CARTESIAN_POINT('',(-2.2E-16,-2.E-17));
#357 = DIRECTION('',(0.,-1.));
#358 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#359 = ADVANCED_FACE('',(#360),#321,.T.);
#360 = FACE_BOUND('',#361,.T.);
#361 = EDGE_LOOP('',(#362,#385,#411,#412));
#362 = ORIENTED_EDGE('',*,*,#363,.T.);
#363 = EDGE_CURVE('',#277,#364,#366,.T.);
#364 = VERTEX_POINT('',#365);
#365 = CARTESIAN_POINT('',(0.21,1.,1.5));
#366 = SEAM_CURVE('',#367,(#372,#379),.PCURVE_S1.);
#367 = CIRCLE('',#368,1.);
#368 = AXIS2_PLACEMENT_3D('',#369,#370,#371);
#369 = CARTESIAN_POINT('',(0.21,0.999999877601,0.5));
#370 = DIRECTION('',(1.,0.,-0.));
#371 = DIRECTION('',(-0.,1.,-1.1E-16));
#372 = PCURVE('',#321,#373);
#373 = DEFINITIONAL_REPRESENTATION('',(#374),#378);
#374 = LINE('',#375,#376);
#375 = CARTESIAN_POINT('',(0.,1.570796326795));
#376 = VECTOR('',#377,1.);
#377 = DIRECTION('',(1.,0.));
#378 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#379 = PCURVE('',#321,#380);
#380 = DEFINITIONAL_REPRESENTATION('',(#381),#384);
#381 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#382,#383),.UNSPECIFIED.,.F.,.F.,
#382 = CARTESIAN_POINT('',(6.2831750945,7.853981633974));
#383 = CARTESIAN_POINT('',(7.853981511576,7.853981633974));
#384 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#385 = ORIENTED_EDGE('',*,*,#386,.T.);
#386 = EDGE_CURVE('',#364,#364,#387,.T.);
#387 = SURFACE_CURVE('',#388,(#393,#400),.PCURVE_S1.);
#388 = CIRCLE('',#389,0.21);
#389 = AXIS2_PLACEMENT_3D('',#390,#391,#392);
#390 = CARTESIAN_POINT('',(0.,1.,1.5));
#391 = DIRECTION('',(-0.,1.,-1.2239874311E-07));
#392 = DIRECTION('',(0.,1.2239874311E-07,1.));
#393 = PCURVE('',#321,#394);
#394 = DEFINITIONAL_REPRESENTATION('',(#395),#399);
#395 = LINE('',#396,#397);
#396 = CARTESIAN_POINT('',(7.853981511576,0.));
#397 = VECTOR('',#398,1.);
#398 = DIRECTION('',(0.,1.));
#399 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#400 = PCURVE('',#401,#406);
#401 = CYLINDRICAL_SURFACE('',#402,0.21);
#402 = AXIS2_PLACEMENT_3D('',#403,#404,#405);
#403 = CARTESIAN_POINT('',(0.,1.,1.5));
#404 = DIRECTION('',(0.,-1.,0.));
#405 = DIRECTION('',(1.,0.,0.));
#406 = DEFINITIONAL_REPRESENTATION('',(#407),#410);
#407 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#408,#409),.UNSPECIFIED.,.F.,.F.,
#408 = CARTESIAN_POINT('',(6.28318530718,0.));
#409 = CARTESIAN_POINT('',(0.,0.));
#410 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#411 = ORIENTED_EDGE('',*,*,#363,.F.);
#412 = ORIENTED_EDGE('',*,*,#306,.F.);
#413 = ADVANCED_FACE('',(#414),#401,.T.);
#414 = FACE_BOUND('',#415,.T.);
#415 = EDGE_LOOP('',(#416,#438,#469,#470));
#416 = ORIENTED_EDGE('',*,*,#417,.T.);
#417 = EDGE_CURVE('',#364,#418,#420,.T.);
#418 = VERTEX_POINT('',#419);
#419 = CARTESIAN_POINT('',(0.21,0.,1.5));
#420 = SEAM_CURVE('',#421,(#425,#432),.PCURVE_S1.);
#421 = LINE('',#422,#423);
#422 = CARTESIAN_POINT('',(0.21,1.,1.5));
#423 = VECTOR('',#424,1.);
#424 = DIRECTION('',(0.,-1.,0.));
#425 = PCURVE('',#401,#426);
#426 = DEFINITIONAL_REPRESENTATION('',(#427),#431);
#427 = LINE('',#428,#429);
#428 = CARTESIAN_POINT('',(6.28318530718,0.));
#429 = VECTOR('',#430,1.);
#430 = DIRECTION('',(0.,1.));
#431 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#432 = PCURVE('',#401,#433);
#433 = DEFINITIONAL_REPRESENTATION('',(#434),#437);
#434 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#435,#436),.UNSPECIFIED.,.F.,.F.,
#435 = CARTESIAN_POINT('',(0.,0.));
#436 = CARTESIAN_POINT('',(0.,1.));
#437 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#438 = ORIENTED_EDGE('',*,*,#439,.F.);
#439 = EDGE_CURVE('',#418,#418,#440,.T.);
#440 = SURFACE_CURVE('',#441,(#446,#453),.PCURVE_S1.);
#441 = CIRCLE('',#442,0.21);
#442 = AXIS2_PLACEMENT_3D('',#443,#444,#445);
#443 = CARTESIAN_POINT('',(0.,0.,1.5));
#444 = DIRECTION('',(0.,-1.,0.));
#445 = DIRECTION('',(1.,0.,0.));
#446 = PCURVE('',#401,#447);
#447 = DEFINITIONAL_REPRESENTATION('',(#448),#452);
#448 = LINE('',#449,#450);
#449 = CARTESIAN_POINT('',(0.,1.));
#450 = VECTOR('',#451,1.);
#451 = DIRECTION('',(1.,0.));
#452 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#453 = PCURVE('',#454,#459);
#454 = PLANE('',#455);
#455 = AXIS2_PLACEMENT_3D('',#456,#457,#458);
#456 = CARTESIAN_POINT('',(-3.E-17,0.,1.5));
#457 = DIRECTION('',(0.,1.,0.));
#458 = DIRECTION('',(0.,-0.,1.));
#459 = DEFINITIONAL_REPRESENTATION('',(#460),#468);
#460 = ( BOUNDED_CURVE() B_SPLINE_CURVE(2,(#461,#462,#463,#464,#465,#466
,#467),.UNSPECIFIED.,.F.,.F.) B_SPLINE_CURVE_WITH_KNOTS((1,2,2,2,2,1),(
#461 = CARTESIAN_POINT('',(2.2E-16,0.21));
#462 = CARTESIAN_POINT('',(0.363730669589,0.21));
#463 = CARTESIAN_POINT('',(0.181865334795,-0.105));
#464 = CARTESIAN_POINT('',(2.714351655642E-16,-0.42));
#465 = CARTESIAN_POINT('',(-0.181865334795,-0.105));
#466 = CARTESIAN_POINT('',(-0.363730669589,0.21));
#467 = CARTESIAN_POINT('',(2.2E-16,0.21));
#468 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#469 = ORIENTED_EDGE('',*,*,#417,.F.);
#470 = ORIENTED_EDGE('',*,*,#386,.F.);
#471 = ADVANCED_FACE('',(#472),#348,.T.);
#472 = FACE_BOUND('',#473,.T.);
#473 = EDGE_LOOP('',(#474));
#474 = ORIENTED_EDGE('',*,*,#333,.T.);
#475 = ADVANCED_FACE('',(#476),#454,.F.);
#476 = FACE_BOUND('',#477,.F.);
#477 = EDGE_LOOP('',(#478));
#478 = ORIENTED_EDGE('',*,*,#439,.F.);
#479 = ( GEOMETRIC_REPRESENTATION_CONTEXT(3)
GLOBAL_UNCERTAINTY_ASSIGNED_CONTEXT((#483)) GLOBAL_UNIT_ASSIGNED_CONTEXT
((#480,#481,#482)) REPRESENTATION_CONTEXT('Context #1',
#480 = ( LENGTH_UNIT() NAMED_UNIT(*) SI_UNIT(.MILLI.,.METRE.) );
#481 = ( NAMED_UNIT(*) PLANE_ANGLE_UNIT() SI_UNIT($,.RADIAN.) );
#482 = ( NAMED_UNIT(*) SI_UNIT($,.STERADIAN.) SOLID_ANGLE_UNIT() );
#483 = UNCERTAINTY_MEASURE_WITH_UNIT(LENGTH_MEASURE(1.E-07),#480,
#484 = SHAPE_DEFINITION_REPRESENTATION(#485,#267);
#485 = PRODUCT_DEFINITION_SHAPE('','',#486);
#486 = PRODUCT_DEFINITION('design','',#487,#490);
#487 = PRODUCT_DEFINITION_FORMATION('','',#488);
#488 = PRODUCT('terminal-3','terminal-3','',(#489));
#489 = PRODUCT_CONTEXT('',#2,'mechanical');
#490 = PRODUCT_DEFINITION_CONTEXT('part definition',#2,'design');
#491 = CONTEXT_DEPENDENT_SHAPE_REPRESENTATION(#492,#494);
#492 = ( REPRESENTATION_RELATIONSHIP('','',#267,#10)
REPRESENTATION_RELATIONSHIP_WITH_TRANSFORMATION(#493)
#493 = ITEM_DEFINED_TRANSFORMATION('','',#11,#19);
#494 = PRODUCT_DEFINITION_SHAPE('Placement','Placement of an item',#495
#495 = NEXT_ASSEMBLY_USAGE_OCCURRENCE('2','=>[0:1:1:3]','',#5,#486,$);
#496 = PRODUCT_RELATED_PRODUCT_CATEGORY('part',$,(#488));
#497 = ADVANCED_BREP_SHAPE_REPRESENTATION('',(#11,#498),#709);
#498 = MANIFOLD_SOLID_BREP('',#499);
#499 = CLOSED_SHELL('',(#500,#589,#643,#701,#705));
#500 = ADVANCED_FACE('',(#501),#515,.F.);
#501 = FACE_BOUND('',#502,.F.);
#502 = EDGE_LOOP('',(#503,#535,#561,#562));
#503 = ORIENTED_EDGE('',*,*,#504,.T.);
#504 = EDGE_CURVE('',#505,#507,#509,.T.);
#505 = VERTEX_POINT('',#506);
#506 = CARTESIAN_POINT('',(0.21,1.999999877601,-3.00001021268));
#507 = VERTEX_POINT('',#508);
#508 = CARTESIAN_POINT('',(0.21,1.999999877575,0.49998978732));
#509 = SEAM_CURVE('',#510,(#514,#528),.PCURVE_S1.);
#510 = LINE('',#511,#512);
#511 = CARTESIAN_POINT('',(0.21,1.999999877601,-3.00001021268));
#512 = VECTOR('',#513,1.);
#513 = DIRECTION('',(0.,0.,1.));
#514 = PCURVE('',#515,#523);
#515 = SURFACE_OF_LINEAR_EXTRUSION('',#516,#521);
#516 = CIRCLE('',#517,0.21);
#517 = AXIS2_PLACEMENT_3D('',#518,#519,#520);
#518 = CARTESIAN_POINT('',(0.,1.999999877601,-3.00001021268));
#519 = DIRECTION('',(0.,-1.009028106268E-05,-0.999999999949));
#520 = DIRECTION('',(1.,0.,0.));
#521 = VECTOR('',#522,1.);
#522 = DIRECTION('',(0.,0.,1.));
#523 = DEFINITIONAL_REPRESENTATION('',(#524),#527);
#524 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#525,#526),.UNSPECIFIED.,.F.,.F.,
#525 = CARTESIAN_POINT('',(6.28318530718,0.));
#526 = CARTESIAN_POINT('',(6.28318530718,3.5));
#527 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#528 = PCURVE('',#515,#529);
#529 = DEFINITIONAL_REPRESENTATION('',(#530),#534);
#530 = LINE('',#531,#532);
#531 = CARTESIAN_POINT('',(0.,0.));
#532 = VECTOR('',#533,1.);
#533 = DIRECTION('',(0.,1.));
#534 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#535 = ORIENTED_EDGE('',*,*,#536,.F.);
#536 = EDGE_CURVE('',#507,#507,#537,.T.);
#537 = SURFACE_CURVE('',#538,(#543,#550),.PCURVE_S1.);
#538 = CIRCLE('',#539,0.21);
#539 = AXIS2_PLACEMENT_3D('',#540,#541,#542);
#540 = CARTESIAN_POINT('',(0.,1.999999877601,0.49998978732));
#541 = DIRECTION('',(0.,-1.009028106268E-05,-0.999999999949));
#542 = DIRECTION('',(1.,0.,0.));
#543 = PCURVE('',#515,#544);
#544 = DEFINITIONAL_REPRESENTATION('',(#545),#549);
#545 = LINE('',#546,#547);
#546 = CARTESIAN_POINT('',(0.,3.5));
#547 = VECTOR('',#548,1.);
#548 = DIRECTION('',(1.,0.));
#549 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#550 = PCURVE('',#551,#556);
#551 = TOROIDAL_SURFACE('',#552,1.,0.21);
#552 = AXIS2_PLACEMENT_3D('',#553,#554,#555);
#553 = CARTESIAN_POINT('',(0.,0.999999877601,0.5));
#554 = DIRECTION('',(1.,0.,-0.));
#555 = DIRECTION('',(-0.,1.,-1.1E-16));
#556 = DEFINITIONAL_REPRESENTATION('',(#557),#560);
#557 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#558,#559),.UNSPECIFIED.,.F.,.F.,
#558 = CARTESIAN_POINT('',(6.2831750945,1.570796326795));
#559 = CARTESIAN_POINT('',(6.2831750945,7.853981633974));
#560 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#561 = ORIENTED_EDGE('',*,*,#504,.F.);
#562 = ORIENTED_EDGE('',*,*,#563,.T.);
#563 = EDGE_CURVE('',#505,#505,#564,.T.);
#564 = SURFACE_CURVE('',#565,(#570,#577),.PCURVE_S1.);
#565 = CIRCLE('',#566,0.21);
#566 = AXIS2_PLACEMENT_3D('',#567,#568,#569);
#567 = CARTESIAN_POINT('',(0.,1.999999877601,-3.00001021268));
#568 = DIRECTION('',(0.,-1.009028106268E-05,-0.999999999949));
#569 = DIRECTION('',(1.,0.,0.));
#570 = PCURVE('',#515,#571);
#571 = DEFINITIONAL_REPRESENTATION('',(#572),#576);
#572 = LINE('',#573,#574);
#573 = CARTESIAN_POINT('',(0.,0.));
#574 = VECTOR('',#575,1.);
#575 = DIRECTION('',(1.,0.));
#576 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#577 = PCURVE('',#578,#583);
#578 = PLANE('',#579);
#579 = AXIS2_PLACEMENT_3D('',#580,#581,#582);
#580 = CARTESIAN_POINT('',(-2.E-17,1.999999877601,-3.00001021268));
#581 = DIRECTION('',(-0.,-1.00902810639E-05,-0.999999999949));
#582 = DIRECTION('',(-0.,-0.999999999949,1.00902810639E-05));
#583 = DEFINITIONAL_REPRESENTATION('',(#584),#588);
#584 = CIRCLE('',#585,0.21);
#585 = AXIS2_PLACEMENT_2D('',#586,#587);
#586 = CARTESIAN_POINT('',(-2.2E-16,-2.E-17));
#587 = DIRECTION('',(0.,-1.));
#588 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#589 = ADVANCED_FACE('',(#590),#551,.T.);
#590 = FACE_BOUND('',#591,.T.);
#591 = EDGE_LOOP('',(#592,#615,#641,#642));
#592 = ORIENTED_EDGE('',*,*,#593,.T.);
#593 = EDGE_CURVE('',#507,#594,#596,.T.);
#594 = VERTEX_POINT('',#595);
#595 = CARTESIAN_POINT('',(0.21,1.,1.5));
#596 = SEAM_CURVE('',#597,(#602,#609),.PCURVE_S1.);
#597 = CIRCLE('',#598,1.);
#598 = AXIS2_PLACEMENT_3D('',#599,#600,#601);
#599 = CARTESIAN_POINT('',(0.21,0.999999877601,0.5));
#600 = DIRECTION('',(1.,0.,-0.));
#601 = DIRECTION('',(-0.,1.,-1.1E-16));
#602 = PCURVE('',#551,#603);
#603 = DEFINITIONAL_REPRESENTATION('',(#604),#608);
#604 = LINE('',#605,#606);
#605 = CARTESIAN_POINT('',(0.,1.570796326795));
#606 = VECTOR('',#607,1.);
#607 = DIRECTION('',(1.,0.));
#608 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#609 = PCURVE('',#551,#610);
#610 = DEFINITIONAL_REPRESENTATION('',(#611),#614);
#611 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#612,#613),.UNSPECIFIED.,.F.,.F.,
#612 = CARTESIAN_POINT('',(6.2831750945,7.853981633974));
#613 = CARTESIAN_POINT('',(7.853981511576,7.853981633974));
#614 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#615 = ORIENTED_EDGE('',*,*,#616,.T.);
#616 = EDGE_CURVE('',#594,#594,#617,.T.);
#617 = SURFACE_CURVE('',#618,(#623,#630),.PCURVE_S1.);
#618 = CIRCLE('',#619,0.21);
#619 = AXIS2_PLACEMENT_3D('',#620,#621,#622);
#620 = CARTESIAN_POINT('',(0.,1.,1.5));
#621 = DIRECTION('',(-0.,1.,-1.2239874311E-07));
#622 = DIRECTION('',(0.,1.2239874311E-07,1.));
#623 = PCURVE('',#551,#624);
#624 = DEFINITIONAL_REPRESENTATION('',(#625),#629);
#625 = LINE('',#626,#627);
#626 = CARTESIAN_POINT('',(7.853981511576,0.));
#627 = VECTOR('',#628,1.);
#628 = DIRECTION('',(0.,1.));
#629 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#630 = PCURVE('',#631,#636);
#631 = CYLINDRICAL_SURFACE('',#632,0.21);
#632 = AXIS2_PLACEMENT_3D('',#633,#634,#635);
#633 = CARTESIAN_POINT('',(0.,1.,1.5));
#634 = DIRECTION('',(0.,-1.,0.));
#635 = DIRECTION('',(1.,0.,0.));
#636 = DEFINITIONAL_REPRESENTATION('',(#637),#640);
#637 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#638,#639),.UNSPECIFIED.,.F.,.F.,
#638 = CARTESIAN_POINT('',(6.28318530718,0.));
#639 = CARTESIAN_POINT('',(0.,0.));
#640 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#641 = ORIENTED_EDGE('',*,*,#593,.F.);
#642 = ORIENTED_EDGE('',*,*,#536,.F.);
#643 = ADVANCED_FACE('',(#644),#631,.T.);
#644 = FACE_BOUND('',#645,.T.);
#645 = EDGE_LOOP('',(#646,#668,#699,#700));
#646 = ORIENTED_EDGE('',*,*,#647,.T.);
#647 = EDGE_CURVE('',#594,#648,#650,.T.);
#648 = VERTEX_POINT('',#649);
#649 = CARTESIAN_POINT('',(0.21,0.,1.5));
#650 = SEAM_CURVE('',#651,(#655,#662),.PCURVE_S1.);
#651 = LINE('',#652,#653);
#652 = CARTESIAN_POINT('',(0.21,1.,1.5));
#653 = VECTOR('',#654,1.);
#654 = DIRECTION('',(0.,-1.,0.));
#655 = PCURVE('',#631,#656);
#656 = DEFINITIONAL_REPRESENTATION('',(#657),#661);
#657 = LINE('',#658,#659);
#658 = CARTESIAN_POINT('',(6.28318530718,0.));
#659 = VECTOR('',#660,1.);
#660 = DIRECTION('',(0.,1.));
#661 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#662 = PCURVE('',#631,#663);
#663 = DEFINITIONAL_REPRESENTATION('',(#664),#667);
#664 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#665,#666),.UNSPECIFIED.,.F.,.F.,
#665 = CARTESIAN_POINT('',(0.,0.));
#666 = CARTESIAN_POINT('',(0.,1.));
#667 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#668 = ORIENTED_EDGE('',*,*,#669,.F.);
#669 = EDGE_CURVE('',#648,#648,#670,.T.);
#670 = SURFACE_CURVE('',#671,(#676,#683),.PCURVE_S1.);
#671 = CIRCLE('',#672,0.21);
#672 = AXIS2_PLACEMENT_3D('',#673,#674,#675);
#673 = CARTESIAN_POINT('',(0.,0.,1.5));
#674 = DIRECTION('',(0.,-1.,0.));
#675 = DIRECTION('',(1.,0.,0.));
#676 = PCURVE('',#631,#677);
#677 = DEFINITIONAL_REPRESENTATION('',(#678),#682);
#678 = LINE('',#679,#680);
#679 = CARTESIAN_POINT('',(0.,1.));
#680 = VECTOR('',#681,1.);
#681 = DIRECTION('',(1.,0.));
#682 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#683 = PCURVE('',#684,#689);
#684 = PLANE('',#685);
#685 = AXIS2_PLACEMENT_3D('',#686,#687,#688);
#686 = CARTESIAN_POINT('',(-3.E-17,0.,1.5));
#687 = DIRECTION('',(0.,1.,0.));
#688 = DIRECTION('',(0.,-0.,1.));
#689 = DEFINITIONAL_REPRESENTATION('',(#690),#698);
#690 = ( BOUNDED_CURVE() B_SPLINE_CURVE(2,(#691,#692,#693,#694,#695,#696
,#697),.UNSPECIFIED.,.F.,.F.) B_SPLINE_CURVE_WITH_KNOTS((1,2,2,2,2,1),(
#691 = CARTESIAN_POINT('',(2.2E-16,0.21));
#692 = CARTESIAN_POINT('',(0.363730669589,0.21));
#693 = CARTESIAN_POINT('',(0.181865334795,-0.105));
#694 = CARTESIAN_POINT('',(2.714351655642E-16,-0.42));
#695 = CARTESIAN_POINT('',(-0.181865334795,-0.105));
#696 = CARTESIAN_POINT('',(-0.363730669589,0.21));
#697 = CARTESIAN_POINT('',(2.2E-16,0.21));
#698 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#699 = ORIENTED_EDGE('',*,*,#647,.F.);
#700 = ORIENTED_EDGE('',*,*,#616,.F.);
#701 = ADVANCED_FACE('',(#702),#578,.T.);
#702 = FACE_BOUND('',#703,.T.);
#703 = EDGE_LOOP('',(#704));
#704 = ORIENTED_EDGE('',*,*,#563,.T.);
#705 = ADVANCED_FACE('',(#706),#684,.F.);
#706 = FACE_BOUND('',#707,.F.);
#707 = EDGE_LOOP('',(#708));
#708 = ORIENTED_EDGE('',*,*,#669,.F.);
#709 = ( GEOMETRIC_REPRESENTATION_CONTEXT(3)
GLOBAL_UNCERTAINTY_ASSIGNED_CONTEXT((#713)) GLOBAL_UNIT_ASSIGNED_CONTEXT
((#710,#711,#712)) REPRESENTATION_CONTEXT('Context #1',
#710 = ( LENGTH_UNIT() NAMED_UNIT(*) SI_UNIT(.MILLI.,.METRE.) );
#711 = ( NAMED_UNIT(*) PLANE_ANGLE_UNIT() SI_UNIT($,.RADIAN.) );
#712 = ( NAMED_UNIT(*) SI_UNIT($,.STERADIAN.) SOLID_ANGLE_UNIT() );
#713 = UNCERTAINTY_MEASURE_WITH_UNIT(LENGTH_MEASURE(1.E-07),#710,
#714 = SHAPE_DEFINITION_REPRESENTATION(#715,#497);
#715 = PRODUCT_DEFINITION_SHAPE('','',#716);
#716 = PRODUCT_DEFINITION('design','',#717,#720);
#717 = PRODUCT_DEFINITION_FORMATION('','',#718);
#718 = PRODUCT('terminal-1','terminal-1','',(#719));
#719 = PRODUCT_CONTEXT('',#2,'mechanical');
#720 = PRODUCT_DEFINITION_CONTEXT('part definition',#2,'design');
#721 = CONTEXT_DEPENDENT_SHAPE_REPRESENTATION(#722,#724);
#722 = ( REPRESENTATION_RELATIONSHIP('','',#497,#10)
REPRESENTATION_RELATIONSHIP_WITH_TRANSFORMATION(#723)
#723 = ITEM_DEFINED_TRANSFORMATION('','',#11,#23);
#724 = PRODUCT_DEFINITION_SHAPE('Placement','Placement of an item',#725
#725 = NEXT_ASSEMBLY_USAGE_OCCURRENCE('3','=>[0:1:1:4]','',#5,#716,$);
#726 = PRODUCT_RELATED_PRODUCT_CATEGORY('part',$,(#718));
#727 = SHAPE_REPRESENTATION('',(#11,#728,#2234,#4076,#7036,#9288,#10570,
#10900,#11230,#12512,#13886,#14766),#15096);
#728 = MANIFOLD_SOLID_BREP('',#729);
#729 = CLOSED_SHELL('',(#730,#852,#938,#1018,#1098,#1174,#1227,#1280,
#1358,#1522,#1548,#1712,#1738,#1816,#1842,#1868,#1944,#1970,#1996,
#2044,#2072,#2098,#2124,#2172,#2200,#2227));
#730 = ADVANCED_FACE('',(#731),#745,.T.);
#731 = FACE_BOUND('',#732,.F.);
#732 = EDGE_LOOP('',(#733,#768,#797,#825));
#733 = ORIENTED_EDGE('',*,*,#734,.T.);
#734 = EDGE_CURVE('',#735,#737,#739,.T.);
#735 = VERTEX_POINT('',#736);
#736 = CARTESIAN_POINT('',(-2.500000033173,-1.E-01,7.999986313559));
#737 = VERTEX_POINT('',#738);
#738 = CARTESIAN_POINT('',(-2.500000033173,-15.9,7.999986313559));
#739 = SURFACE_CURVE('',#740,(#744,#756),.PCURVE_S1.);
#740 = LINE('',#741,#742);
#741 = CARTESIAN_POINT('',(-2.500000033172,1.78E-15,7.999986313559));
#742 = VECTOR('',#743,1.);
#743 = DIRECTION('',(0.,-1.,0.));
#744 = PCURVE('',#745,#750);
#745 = CYLINDRICAL_SURFACE('',#746,1.5);
#746 = AXIS2_PLACEMENT_3D('',#747,#748,#749);
#747 = CARTESIAN_POINT('',(-2.5,1.44E-15,6.499986313559));
#748 = DIRECTION('',(0.,1.,-2.2E-16));
#749 = DIRECTION('',(1.,0.,0.));
#750 = DEFINITIONAL_REPRESENTATION('',(#751),#755);
#751 = LINE('',#752,#753);
#752 = CARTESIAN_POINT('',(-1.57079634891,0.));
#753 = VECTOR('',#754,1.);
#754 = DIRECTION('',(-0.,-1.));
#755 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#756 = PCURVE('',#757,#762);
#757 = PLANE('',#758);
#758 = AXIS2_PLACEMENT_3D('',#759,#760,#761);
#759 = CARTESIAN_POINT('',(-2.500000033172,1.78E-15,7.999986313559));
#760 = DIRECTION('',(0.,0.,1.));
#761 = DIRECTION('',(1.,0.,0.));
#762 = DEFINITIONAL_REPRESENTATION('',(#763),#767);
#763 = LINE('',#764,#765);
#764 = CARTESIAN_POINT('',(-3.2774E-13,-0.));
#765 = VECTOR('',#766,1.);
#766 = DIRECTION('',(0.,-1.));
#767 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#768 = ORIENTED_EDGE('',*,*,#769,.T.);
#769 = EDGE_CURVE('',#737,#770,#772,.T.);
#770 = VERTEX_POINT('',#771);
#771 = CARTESIAN_POINT('',(-4.,-15.9,6.499986280386));
#772 = SURFACE_CURVE('',#773,(#778,#785),.PCURVE_S1.);
#773 = CIRCLE('',#774,1.5);
#774 = AXIS2_PLACEMENT_3D('',#775,#776,#777);
#775 = CARTESIAN_POINT('',(-2.5,-15.9,6.499986313559));
#776 = DIRECTION('',(0.,-1.,2.2E-16));
#777 = DIRECTION('',(-2.211510353E-08,2.2E-16,1.));
#778 = PCURVE('',#745,#779);
#779 = DEFINITIONAL_REPRESENTATION('',(#780),#784);
#780 = LINE('',#781,#782);
#781 = CARTESIAN_POINT('',(-1.57079634891,-15.9));
#782 = VECTOR('',#783,1.);
#783 = DIRECTION('',(-1.,0.));
#784 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#785 = PCURVE('',#786,#791);
#786 = TOROIDAL_SURFACE('',#787,1.4,0.1);
#787 = AXIS2_PLACEMENT_3D('',#788,#789,#790);
#788 = CARTESIAN_POINT('',(-2.5,-15.9,6.499986313559));
#789 = DIRECTION('',(0.,-1.,2.2E-16));
#790 = DIRECTION('',(-2.211510353E-08,2.2E-16,1.));
#791 = DEFINITIONAL_REPRESENTATION('',(#792),#796);
#792 = LINE('',#793,#794);
#793 = CARTESIAN_POINT('',(0.,0.));
#794 = VECTOR('',#795,1.);
#795 = DIRECTION('',(1.,0.));
#796 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#797 = ORIENTED_EDGE('',*,*,#798,.F.);
#798 = EDGE_CURVE('',#799,#770,#801,.T.);
#799 = VERTEX_POINT('',#800);
#800 = CARTESIAN_POINT('',(-4.,-1.E-01,6.499986280386));
#801 = SURFACE_CURVE('',#802,(#806,#813),.PCURVE_S1.);
#802 = LINE('',#803,#804);
#803 = CARTESIAN_POINT('',(-4.,1.44E-15,6.499986280387));
#804 = VECTOR('',#805,1.);
#805 = DIRECTION('',(0.,-1.,0.));
#806 = PCURVE('',#745,#807);
#807 = DEFINITIONAL_REPRESENTATION('',(#808),#812);
#808 = LINE('',#809,#810);
#809 = CARTESIAN_POINT('',(-3.141592675705,0.));
#810 = VECTOR('',#811,1.);
#811 = DIRECTION('',(-0.,-1.));
#812 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#813 = PCURVE('',#814,#819);
#814 = PLANE('',#815);
#815 = AXIS2_PLACEMENT_3D('',#816,#817,#818);
#816 = CARTESIAN_POINT('',(-3.999999999937,3.3E-16,1.499986280386));
#817 = DIRECTION('',(-1.,-0.,-1.254854E-11));
#818 = DIRECTION('',(-1.254854E-11,2.2E-16,1.));
#819 = DEFINITIONAL_REPRESENTATION('',(#820),#824);
#820 = LINE('',#821,#822);
#821 = CARTESIAN_POINT('',(5.,0.));
#822 = VECTOR('',#823,1.);
#823 = DIRECTION('',(-2.2E-16,-1.));
#824 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#825 = ORIENTED_EDGE('',*,*,#826,.F.);
#826 = EDGE_CURVE('',#735,#799,#827,.T.);
#827 = SURFACE_CURVE('',#828,(#833,#840),.PCURVE_S1.);
#828 = CIRCLE('',#829,1.5);
#829 = AXIS2_PLACEMENT_3D('',#830,#831,#832);
#830 = CARTESIAN_POINT('',(-2.5,-1.E-01,6.499986313559));
#831 = DIRECTION('',(0.,-1.,2.2E-16));
#832 = DIRECTION('',(-2.211510353E-08,2.2E-16,1.));
#833 = PCURVE('',#745,#834);
#834 = DEFINITIONAL_REPRESENTATION('',(#835),#839);
#835 = LINE('',#836,#837);
#836 = CARTESIAN_POINT('',(-1.57079634891,-0.1));
#837 = VECTOR('',#838,1.);
#838 = DIRECTION('',(-1.,0.));
#839 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#840 = PCURVE('',#841,#846);
#841 = TOROIDAL_SURFACE('',#842,1.4,0.1);
#842 = AXIS2_PLACEMENT_3D('',#843,#844,#845);
#843 = CARTESIAN_POINT('',(-2.5,-1.E-01,6.499986313559));
#844 = DIRECTION('',(0.,1.,-2.2E-16));
#845 = DIRECTION('',(-2.211510353E-08,2.2E-16,1.));
#846 = DEFINITIONAL_REPRESENTATION('',(#847),#851);
#847 = LINE('',#848,#849);
#848 = CARTESIAN_POINT('',(-0.,0.));
#849 = VECTOR('',#850,1.);
#850 = DIRECTION('',(-1.,0.));
#851 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#852 = ADVANCED_FACE('',(#853),#757,.T.);
#853 = FACE_BOUND('',#854,.T.);
#854 = EDGE_LOOP('',(#855,#856,#884,#912));
#855 = ORIENTED_EDGE('',*,*,#734,.T.);
#856 = ORIENTED_EDGE('',*,*,#857,.F.);
#857 = EDGE_CURVE('',#858,#737,#860,.T.);
#858 = VERTEX_POINT('',#859);
#859 = CARTESIAN_POINT('',(2.499999955701,-15.9,7.999986313559));
#860 = SURFACE_CURVE('',#861,(#865,#872),.PCURVE_S1.);
#861 = LINE('',#862,#863);
#862 = CARTESIAN_POINT('',(2.499999955701,-15.9,7.999986313559));
#863 = VECTOR('',#864,1.);
#864 = DIRECTION('',(-1.,-0.,-0.));
#865 = PCURVE('',#757,#866);
#866 = DEFINITIONAL_REPRESENTATION('',(#867),#871);
#867 = LINE('',#868,#869);
#868 = CARTESIAN_POINT('',(4.999999988873,-15.9));
#869 = VECTOR('',#870,1.);
#870 = DIRECTION('',(-1.,-0.));
#871 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#872 = PCURVE('',#873,#878);
#873 = CYLINDRICAL_SURFACE('',#874,0.1);
#874 = AXIS2_PLACEMENT_3D('',#875,#876,#877);
#875 = CARTESIAN_POINT('',(2.499999955701,-15.9,7.899986313559));
#876 = DIRECTION('',(-1.,-0.,-0.));
#877 = DIRECTION('',(0.,0.,1.));
#878 = DEFINITIONAL_REPRESENTATION('',(#879),#883);
#879 = LINE('',#880,#881);
#880 = CARTESIAN_POINT('',(-0.,0.));
#881 = VECTOR('',#882,1.);
#882 = DIRECTION('',(-0.,1.));
#883 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#884 = ORIENTED_EDGE('',*,*,#885,.F.);
#885 = EDGE_CURVE('',#886,#858,#888,.T.);
#886 = VERTEX_POINT('',#887);
#887 = CARTESIAN_POINT('',(2.499999955701,-1.E-01,7.999986313559));
#888 = SURFACE_CURVE('',#889,(#893,#900),.PCURVE_S1.);
#889 = LINE('',#890,#891);
#890 = CARTESIAN_POINT('',(2.499999955701,1.78E-15,7.999986313559));
#891 = VECTOR('',#892,1.);
#892 = DIRECTION('',(0.,-1.,0.));
#893 = PCURVE('',#757,#894);
#894 = DEFINITIONAL_REPRESENTATION('',(#895),#899);
#895 = LINE('',#896,#897);
#896 = CARTESIAN_POINT('',(4.999999988873,0.));
#897 = VECTOR('',#898,1.);
#898 = DIRECTION('',(0.,-1.));
#899 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#900 = PCURVE('',#901,#906);
#901 = CYLINDRICAL_SURFACE('',#902,1.5);
#902 = AXIS2_PLACEMENT_3D('',#903,#904,#905);
#903 = CARTESIAN_POINT('',(2.499999978063,1.44E-15,6.499986313559));
#904 = DIRECTION('',(0.,1.,-2.2E-16));
#905 = DIRECTION('',(1.,0.,0.));
#906 = DEFINITIONAL_REPRESENTATION('',(#907),#911);
#907 = LINE('',#908,#909);
#908 = CARTESIAN_POINT('',(-1.570796341703,0.));
#909 = VECTOR('',#910,1.);
#910 = DIRECTION('',(-0.,-1.));
#911 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#912 = ORIENTED_EDGE('',*,*,#913,.T.);
#913 = EDGE_CURVE('',#886,#735,#914,.T.);
#914 = SURFACE_CURVE('',#915,(#919,#926),.PCURVE_S1.);
#915 = LINE('',#916,#917);
#916 = CARTESIAN_POINT('',(2.499999955701,-1.E-01,7.999986313559));
#917 = VECTOR('',#918,1.);
#918 = DIRECTION('',(-1.,-0.,-0.));
#919 = PCURVE('',#757,#920);
#920 = DEFINITIONAL_REPRESENTATION('',(#921),#925);
#921 = LINE('',#922,#923);
#922 = CARTESIAN_POINT('',(4.999999988873,-0.1));
#923 = VECTOR('',#924,1.);
#924 = DIRECTION('',(-1.,-0.));
#925 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#926 = PCURVE('',#927,#932);
#927 = CYLINDRICAL_SURFACE('',#928,0.1);
#928 = AXIS2_PLACEMENT_3D('',#929,#930,#931);
#929 = CARTESIAN_POINT('',(2.499999955701,-1.E-01,7.899986313559));
#930 = DIRECTION('',(-1.,-0.,-0.));
#931 = DIRECTION('',(0.,0.,1.));
#932 = DEFINITIONAL_REPRESENTATION('',(#933),#937);
#933 = LINE('',#934,#935);
#934 = CARTESIAN_POINT('',(0.,0.));
#935 = VECTOR('',#936,1.);
#936 = DIRECTION('',(0.,1.));
#937 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#938 = ADVANCED_FACE('',(#939),#841,.T.);
#939 = FACE_BOUND('',#940,.F.);
#940 = EDGE_LOOP('',(#941,#963,#964,#991));
#941 = ORIENTED_EDGE('',*,*,#942,.F.);
#942 = EDGE_CURVE('',#735,#943,#945,.T.);
#943 = VERTEX_POINT('',#944);
#944 = CARTESIAN_POINT('',(-2.500000030961,2.E-15,7.899986313559));
#945 = SURFACE_CURVE('',#946,(#951,#957),.PCURVE_S1.);
#946 = CIRCLE('',#947,0.1);
#947 = AXIS2_PLACEMENT_3D('',#948,#949,#950);
#948 = CARTESIAN_POINT('',(-2.500000030961,-1.E-01,7.899986313559));
#949 = DIRECTION('',(-1.,0.,-2.211510353E-08));
#950 = DIRECTION('',(-2.211510353E-08,2.2E-16,1.));
#951 = PCURVE('',#841,#952);
#952 = DEFINITIONAL_REPRESENTATION('',(#953),#956);
#953 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#954,#955),.UNSPECIFIED.,.F.,.F.,
(2,2),(0.,1.570796326795),.PIECEWISE_BEZIER_KNOTS.);
#954 = CARTESIAN_POINT('',(0.,0.));
#955 = CARTESIAN_POINT('',(0.,1.570796326795));
#956 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#957 = PCURVE('',#927,#958);
#958 = DEFINITIONAL_REPRESENTATION('',(#959),#962);
#959 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#960,#961),.UNSPECIFIED.,.F.,.F.,
#960 = CARTESIAN_POINT('',(0.,4.999999988873));
#961 = CARTESIAN_POINT('',(1.570796326795,4.999999988873));
#962 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#963 = ORIENTED_EDGE('',*,*,#826,.T.);
#964 = ORIENTED_EDGE('',*,*,#965,.T.);
#965 = EDGE_CURVE('',#799,#966,#968,.T.);
#966 = VERTEX_POINT('',#967);
#967 = CARTESIAN_POINT('',(-3.9,1.E-15,6.499986282598));
#968 = SURFACE_CURVE('',#969,(#974,#980),.PCURVE_S1.);
#969 = CIRCLE('',#970,0.1);
#970 = AXIS2_PLACEMENT_3D('',#971,#972,#973);
#971 = CARTESIAN_POINT('',(-3.9,-1.E-01,6.499986282598));
#972 = DIRECTION('',(2.211520694E-08,-2.2E-16,-1.));
#973 = DIRECTION('',(-1.,0.,-2.211520694E-08));
#974 = PCURVE('',#841,#975);
#975 = DEFINITIONAL_REPRESENTATION('',(#976),#979);
#976 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#977,#978),.UNSPECIFIED.,.F.,.F.,
#977 = CARTESIAN_POINT('',(-1.570796326795,0.));
#978 = CARTESIAN_POINT('',(-1.570796326795,1.570796326795));
#979 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#980 = PCURVE('',#981,#986);
#981 = CYLINDRICAL_SURFACE('',#982,0.1);
#982 = AXIS2_PLACEMENT_3D('',#983,#984,#985);
#983 = CARTESIAN_POINT('',(-3.9,-1.E-01,6.499986280388));
#984 = DIRECTION('',(1.254854E-11,-2.2E-16,-1.));
#985 = DIRECTION('',(-1.,0.,-1.254854E-11));
#986 = DEFINITIONAL_REPRESENTATION('',(#987),#990);
#987 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#988,#989),.UNSPECIFIED.,.F.,.F.,
#988 = CARTESIAN_POINT('',(0.,4.0592E-13));
#989 = CARTESIAN_POINT('',(1.570796326795,4.0592E-13));
#990 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#991 = ORIENTED_EDGE('',*,*,#992,.F.);
#992 = EDGE_CURVE('',#943,#966,#993,.T.);
#993 = SURFACE_CURVE('',#994,(#999,#1006),.PCURVE_S1.);
#994 = CIRCLE('',#995,1.4);
#995 = AXIS2_PLACEMENT_3D('',#996,#997,#998);
#996 = CARTESIAN_POINT('',(-2.5,1.44E-15,6.499986313559));
#997 = DIRECTION('',(0.,-1.,2.2E-16));
#998 = DIRECTION('',(-2.211510353E-08,2.2E-16,1.));
#999 = PCURVE('',#841,#1000);
#1000 = DEFINITIONAL_REPRESENTATION('',(#1001),#1005);
#1001 = LINE('',#1002,#1003);
#1002 = CARTESIAN_POINT('',(-0.,1.570796326795));
#1003 = VECTOR('',#1004,1.);
#1004 = DIRECTION('',(-1.,0.));
#1005 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1006 = PCURVE('',#1007,#1012);
#1007 = PLANE('',#1008);
#1008 = AXIS2_PLACEMENT_3D('',#1009,#1010,#1011);
#1009 = CARTESIAN_POINT('',(-1.0488875222E-07,8.9E-16,3.999993086486));
#1010 = DIRECTION('',(0.,-1.,2.2E-16));
#1011 = DIRECTION('',(0.,-2.2E-16,-1.));
#1012 = DEFINITIONAL_REPRESENTATION('',(#1013),#1017);
#1013 = CIRCLE('',#1014,1.4);
#1014 = AXIS2_PLACEMENT_2D('',#1015,#1016);
#1015 = CARTESIAN_POINT('',(-2.499993227073,-2.499999895111));
#1016 = DIRECTION('',(-1.,-2.21151034E-08));
#1017 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1018 = ADVANCED_FACE('',(#1019),#786,.T.);
#1019 = FACE_BOUND('',#1020,.T.);
#1020 = EDGE_LOOP('',(#1021,#1043,#1044,#1071));
#1021 = ORIENTED_EDGE('',*,*,#1022,.F.);
#1022 = EDGE_CURVE('',#737,#1023,#1025,.T.);
#1023 = VERTEX_POINT('',#1024);
#1024 = CARTESIAN_POINT('',(-2.500000030961,-16.,7.899986313559));
#1025 = SURFACE_CURVE('',#1026,(#1031,#1037),.PCURVE_S1.);
#1026 = CIRCLE('',#1027,0.1);
#1027 = AXIS2_PLACEMENT_3D('',#1028,#1029,#1030);
#1028 = CARTESIAN_POINT('',(-2.500000030961,-15.9,7.899986313559));
#1029 = DIRECTION('',(1.,0.,2.211510353E-08));
#1030 = DIRECTION('',(-2.211510353E-08,2.2E-16,1.));
#1031 = PCURVE('',#786,#1032);
#1032 = DEFINITIONAL_REPRESENTATION('',(#1033),#1036);
#1033 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1034,#1035),.UNSPECIFIED.,.F.,
.F.,(2,2),(0.,1.570796326795),.PIECEWISE_BEZIER_KNOTS.);
#1034 = CARTESIAN_POINT('',(0.,0.));
#1035 = CARTESIAN_POINT('',(0.,1.570796326795));
#1036 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1037 = PCURVE('',#873,#1038);
#1038 = DEFINITIONAL_REPRESENTATION('',(#1039),#1042);
#1039 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1040,#1041),.UNSPECIFIED.,.F.,
#1040 = CARTESIAN_POINT('',(0.,4.999999988873));
#1041 = CARTESIAN_POINT('',(-1.570796326795,4.999999988873));
#1042 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1043 = ORIENTED_EDGE('',*,*,#769,.T.);
#1044 = ORIENTED_EDGE('',*,*,#1045,.T.);
#1045 = EDGE_CURVE('',#770,#1046,#1048,.T.);
#1046 = VERTEX_POINT('',#1047);
#1047 = CARTESIAN_POINT('',(-3.9,-16.,6.499986282598));
#1048 = SURFACE_CURVE('',#1049,(#1054,#1060),.PCURVE_S1.);
#1049 = CIRCLE('',#1050,0.1);
#1050 = AXIS2_PLACEMENT_3D('',#1051,#1052,#1053);
#1051 = CARTESIAN_POINT('',(-3.9,-15.9,6.499986282598));
#1052 = DIRECTION('',(-2.211520694E-08,2.2E-16,1.));
#1053 = DIRECTION('',(-1.,0.,-2.211520694E-08));
#1054 = PCURVE('',#786,#1055);
#1055 = DEFINITIONAL_REPRESENTATION('',(#1056),#1059);
#1056 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1057,#1058),.UNSPECIFIED.,.F.,
#1057 = CARTESIAN_POINT('',(1.570796326795,0.));
#1058 = CARTESIAN_POINT('',(1.570796326795,1.570796326795));
#1059 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1060 = PCURVE('',#1061,#1066);
#1061 = CYLINDRICAL_SURFACE('',#1062,0.1);
#1062 = AXIS2_PLACEMENT_3D('',#1063,#1064,#1065);
#1063 = CARTESIAN_POINT('',(-3.9,-15.9,6.499986280388));
#1064 = DIRECTION('',(1.254854E-11,-2.2E-16,-1.));
#1065 = DIRECTION('',(-1.,0.,-1.254854E-11));
#1066 = DEFINITIONAL_REPRESENTATION('',(#1067),#1070);
#1067 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1068,#1069),.UNSPECIFIED.,.F.,
#1068 = CARTESIAN_POINT('',(0.,4.0588E-13));
#1069 = CARTESIAN_POINT('',(-1.570796326795,4.0588E-13));
#1070 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1071 = ORIENTED_EDGE('',*,*,#1072,.F.);
#1072 = EDGE_CURVE('',#1023,#1046,#1073,.T.);
#1073 = SURFACE_CURVE('',#1074,(#1079,#1086),.PCURVE_S1.);
#1074 = CIRCLE('',#1075,1.4);
#1075 = AXIS2_PLACEMENT_3D('',#1076,#1077,#1078);
#1076 = CARTESIAN_POINT('',(-2.5,-16.,6.499986313559));
#1077 = DIRECTION('',(0.,-1.,2.2E-16));
#1078 = DIRECTION('',(-2.211510353E-08,2.2E-16,1.));
#1079 = PCURVE('',#786,#1080);
#1080 = DEFINITIONAL_REPRESENTATION('',(#1081),#1085);
#1081 = LINE('',#1082,#1083);
#1082 = CARTESIAN_POINT('',(0.,1.570796326795));
#1083 = VECTOR('',#1084,1.);
#1084 = DIRECTION('',(1.,0.));
#1085 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1086 = PCURVE('',#1087,#1092);
#1087 = PLANE('',#1088);
#1088 = AXIS2_PLACEMENT_3D('',#1089,#1090,#1091);
#1089 = CARTESIAN_POINT('',(-1.0488875222E-07,-16.,3.999993086486));
#1090 = DIRECTION('',(0.,-1.,2.2E-16));
#1091 = DIRECTION('',(0.,-2.2E-16,-1.));
#1092 = DEFINITIONAL_REPRESENTATION('',(#1093),#1097);
#1093 = CIRCLE('',#1094,1.4);
#1094 = AXIS2_PLACEMENT_2D('',#1095,#1096);
#1095 = CARTESIAN_POINT('',(-2.499993227073,-2.499999895111));
#1096 = DIRECTION('',(-1.,-2.21151034E-08));
#1097 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1098 = ADVANCED_FACE('',(#1099),#814,.T.);
#1099 = FACE_BOUND('',#1100,.T.);
#1100 = EDGE_LOOP('',(#1101,#1131,#1152,#1153));
#1101 = ORIENTED_EDGE('',*,*,#1102,.T.);
#1102 = EDGE_CURVE('',#1103,#1105,#1107,.T.);
#1103 = VERTEX_POINT('',#1104);
#1104 = CARTESIAN_POINT('',(-3.999999999937,-0.1,1.499986280386));
#1105 = VERTEX_POINT('',#1106);
#1106 = CARTESIAN_POINT('',(-3.999999999937,-15.9,1.499986280386));
#1107 = SURFACE_CURVE('',#1108,(#1112,#1119),.PCURVE_S1.);
#1108 = LINE('',#1109,#1110);
#1109 = CARTESIAN_POINT('',(-3.999999999937,3.3E-16,1.499986280386));
#1110 = VECTOR('',#1111,1.);
#1111 = DIRECTION('',(0.,-1.,0.));
#1112 = PCURVE('',#814,#1113);
#1113 = DEFINITIONAL_REPRESENTATION('',(#1114),#1118);
#1114 = LINE('',#1115,#1116);
#1115 = CARTESIAN_POINT('',(0.,0.));
#1116 = VECTOR('',#1117,1.);
#1117 = DIRECTION('',(-2.2E-16,-1.));
#1118 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1119 = PCURVE('',#1120,#1125);
#1120 = CYLINDRICAL_SURFACE('',#1121,1.5);
#1121 = AXIS2_PLACEMENT_3D('',#1122,#1123,#1124);
#1122 = CARTESIAN_POINT('',(-2.5,3.3E-16,1.5));
#1123 = DIRECTION('',(0.,1.,-2.2E-16));
#1124 = DIRECTION('',(1.,0.,0.));
#1125 = DEFINITIONAL_REPRESENTATION('',(#1126),#1130);
#1126 = LINE('',#1127,#1128);
#1127 = CARTESIAN_POINT('',(-3.141601799999,0.));
#1128 = VECTOR('',#1129,1.);
#1129 = DIRECTION('',(-0.,-1.));
#1130 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1131 = ORIENTED_EDGE('',*,*,#1132,.F.);
#1132 = EDGE_CURVE('',#770,#1105,#1133,.T.);
#1133 = SURFACE_CURVE('',#1134,(#1138,#1145),.PCURVE_S1.);
#1134 = LINE('',#1135,#1136);
#1135 = CARTESIAN_POINT('',(-4.,-15.9,6.499986280387));
#1136 = VECTOR('',#1137,1.);
#1137 = DIRECTION('',(1.254854E-11,-2.2E-16,-1.));
#1138 = PCURVE('',#814,#1139);
#1139 = DEFINITIONAL_REPRESENTATION('',(#1140),#1144);
#1140 = LINE('',#1141,#1142);
#1141 = CARTESIAN_POINT('',(5.000000000001,-15.9));
#1142 = VECTOR('',#1143,1.);
#1143 = DIRECTION('',(-1.,0.));
#1144 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1145 = PCURVE('',#1061,#1146);
#1146 = DEFINITIONAL_REPRESENTATION('',(#1147),#1151);
#1147 = LINE('',#1148,#1149);
#1148 = CARTESIAN_POINT('',(-0.,0.));
#1149 = VECTOR('',#1150,1.);
#1150 = DIRECTION('',(-0.,1.));
#1151 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1152 = ORIENTED_EDGE('',*,*,#798,.F.);
#1153 = ORIENTED_EDGE('',*,*,#1154,.T.);
#1154 = EDGE_CURVE('',#799,#1103,#1155,.T.);
#1155 = SURFACE_CURVE('',#1156,(#1160,#1167),.PCURVE_S1.);
#1156 = LINE('',#1157,#1158);
#1157 = CARTESIAN_POINT('',(-4.,-1.E-01,6.499986280387));
#1158 = VECTOR('',#1159,1.);
#1159 = DIRECTION('',(1.254854E-11,-2.2E-16,-1.));
#1160 = PCURVE('',#814,#1161);
#1161 = DEFINITIONAL_REPRESENTATION('',(#1162),#1166);
#1162 = LINE('',#1163,#1164);
#1163 = CARTESIAN_POINT('',(5.000000000001,-1.E-01));
#1164 = VECTOR('',#1165,1.);
#1165 = DIRECTION('',(-1.,0.));
#1166 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1167 = PCURVE('',#981,#1168);
#1168 = DEFINITIONAL_REPRESENTATION('',(#1169),#1173);
#1169 = LINE('',#1170,#1171);
#1170 = CARTESIAN_POINT('',(0.,0.));
#1171 = VECTOR('',#1172,1.);
#1172 = DIRECTION('',(0.,1.));
#1173 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1174 = ADVANCED_FACE('',(#1175),#927,.T.);
#1175 = FACE_BOUND('',#1176,.T.);
#1176 = EDGE_LOOP('',(#1177,#1204,#1225,#1226));
#1177 = ORIENTED_EDGE('',*,*,#1178,.T.);
#1178 = EDGE_CURVE('',#886,#1179,#1181,.T.);
#1179 = VERTEX_POINT('',#1180);
#1180 = CARTESIAN_POINT('',(2.499999957192,2.E-15,7.899986313559));
#1181 = SURFACE_CURVE('',#1182,(#1187,#1193),.PCURVE_S1.);
#1182 = CIRCLE('',#1183,0.1);
#1183 = AXIS2_PLACEMENT_3D('',#1184,#1185,#1186);
#1184 = CARTESIAN_POINT('',(2.499999957192,-1.E-01,7.899986313559));
#1185 = DIRECTION('',(-1.,0.,-1.490810337E-08));
#1186 = DIRECTION('',(-1.490810337E-08,2.2E-16,1.));
#1187 = PCURVE('',#927,#1188);
#1188 = DEFINITIONAL_REPRESENTATION('',(#1189),#1192);
#1189 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1190,#1191),.UNSPECIFIED.,.F.,
#1190 = CARTESIAN_POINT('',(0.,-3.55E-15));
#1191 = CARTESIAN_POINT('',(1.570796326795,-3.55E-15));
#1192 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1193 = PCURVE('',#1194,#1199);
#1194 = TOROIDAL_SURFACE('',#1195,1.4,0.1);
#1195 = AXIS2_PLACEMENT_3D('',#1196,#1197,#1198);
#1196 = CARTESIAN_POINT('',(2.499999978063,-1.E-01,6.499986313559));
#1197 = DIRECTION('',(0.,1.,-2.2E-16));
#1198 = DIRECTION('',(1.,3.0643800418E-24,1.392900019E-08));
#1199 = DEFINITIONAL_REPRESENTATION('',(#1200),#1203);
#1200 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1201,#1202),.UNSPECIFIED.,.F.,
#1201 = CARTESIAN_POINT('',(-1.570796327774,0.));
#1202 = CARTESIAN_POINT('',(-1.570796327774,1.570796326795));
#1203 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1204 = ORIENTED_EDGE('',*,*,#1205,.T.);
#1205 = EDGE_CURVE('',#1179,#943,#1206,.T.);
#1206 = SURFACE_CURVE('',#1207,(#1211,#1218),.PCURVE_S1.);
#1207 = LINE('',#1208,#1209);
#1208 = CARTESIAN_POINT('',(2.499999955701,1.76E-15,7.899986313559));
#1209 = VECTOR('',#1210,1.);
#1210 = DIRECTION('',(-1.,-0.,-0.));
#1211 = PCURVE('',#927,#1212);
#1212 = DEFINITIONAL_REPRESENTATION('',(#1213),#1217);
#1213 = LINE('',#1214,#1215);
#1214 = CARTESIAN_POINT('',(1.570796326795,0.));
#1215 = VECTOR('',#1216,1.);
#1216 = DIRECTION('',(0.,1.));
#1217 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1218 = PCURVE('',#1007,#1219);
#1219 = DEFINITIONAL_REPRESENTATION('',(#1220),#1224);
#1220 = LINE('',#1221,#1222);
#1221 = CARTESIAN_POINT('',(-3.899993227073,2.50000006059));
#1222 = VECTOR('',#1223,1.);
#1223 = DIRECTION('',(0.,-1.));
#1224 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1225 = ORIENTED_EDGE('',*,*,#942,.F.);
#1226 = ORIENTED_EDGE('',*,*,#913,.F.);
#1227 = ADVANCED_FACE('',(#1228),#873,.T.);
#1228 = FACE_BOUND('',#1229,.F.);
#1229 = EDGE_LOOP('',(#1230,#1257,#1278,#1279));
#1230 = ORIENTED_EDGE('',*,*,#1231,.T.);
#1231 = EDGE_CURVE('',#858,#1232,#1234,.T.);
#1232 = VERTEX_POINT('',#1233);
#1233 = CARTESIAN_POINT('',(2.499999957192,-16.,7.899986313559));
#1234 = SURFACE_CURVE('',#1235,(#1240,#1246),.PCURVE_S1.);
#1235 = CIRCLE('',#1236,0.1);
#1236 = AXIS2_PLACEMENT_3D('',#1237,#1238,#1239);
#1237 = CARTESIAN_POINT('',(2.499999957192,-15.9,7.899986313559));
#1238 = DIRECTION('',(1.,0.,1.49081012E-08));
#1239 = DIRECTION('',(-1.49081012E-08,2.2E-16,1.));
#1240 = PCURVE('',#873,#1241);
#1241 = DEFINITIONAL_REPRESENTATION('',(#1242),#1245);
#1242 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1243,#1244),.UNSPECIFIED.,.F.,
#1243 = CARTESIAN_POINT('',(0.,-3.55E-15));
#1244 = CARTESIAN_POINT('',(-1.570796326795,-3.55E-15));
#1245 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1246 = PCURVE('',#1247,#1252);
#1247 = TOROIDAL_SURFACE('',#1248,1.4,0.1);
#1248 = AXIS2_PLACEMENT_3D('',#1249,#1250,#1251);
#1249 = CARTESIAN_POINT('',(2.499999978063,-15.9,6.499986313559));
#1250 = DIRECTION('',(0.,-1.,2.2E-16));
#1251 = DIRECTION('',(1.,3.0643795138E-24,1.392899779E-08));
#1252 = DEFINITIONAL_REPRESENTATION('',(#1253),#1256);
#1253 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1254,#1255),.UNSPECIFIED.,.F.,
#1254 = CARTESIAN_POINT('',(1.570796327774,0.));
#1255 = CARTESIAN_POINT('',(1.570796327774,1.570796326795));
#1256 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1257 = ORIENTED_EDGE('',*,*,#1258,.T.);
#1258 = EDGE_CURVE('',#1232,#1023,#1259,.T.);
#1259 = SURFACE_CURVE('',#1260,(#1264,#1271),.PCURVE_S1.);
#1260 = LINE('',#1261,#1262);
#1261 = CARTESIAN_POINT('',(2.499999955701,-16.,7.899986313559));
#1262 = VECTOR('',#1263,1.);
#1263 = DIRECTION('',(-1.,-0.,-0.));
#1264 = PCURVE('',#873,#1265);
#1265 = DEFINITIONAL_REPRESENTATION('',(#1266),#1270);
#1266 = LINE('',#1267,#1268);
#1267 = CARTESIAN_POINT('',(-1.570796326795,0.));
#1268 = VECTOR('',#1269,1.);
#1269 = DIRECTION('',(-0.,1.));
#1270 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1271 = PCURVE('',#1087,#1272);
#1272 = DEFINITIONAL_REPRESENTATION('',(#1273),#1277);
#1273 = LINE('',#1274,#1275);
#1274 = CARTESIAN_POINT('',(-3.899993227073,2.50000006059));
#1275 = VECTOR('',#1276,1.);
#1276 = DIRECTION('',(0.,-1.));
#1277 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1278 = ORIENTED_EDGE('',*,*,#1022,.F.);
#1279 = ORIENTED_EDGE('',*,*,#857,.F.);
#1280 = ADVANCED_FACE('',(#1281),#901,.T.);
#1281 = FACE_BOUND('',#1282,.F.);
#1282 = EDGE_LOOP('',(#1283,#1313,#1335,#1336));
#1283 = ORIENTED_EDGE('',*,*,#1284,.T.);
#1284 = EDGE_CURVE('',#1285,#1287,#1289,.T.);
#1285 = VERTEX_POINT('',#1286);
#1286 = CARTESIAN_POINT('',(3.999999978063,-1.E-01,6.499986334453));
#1287 = VERTEX_POINT('',#1288);
#1288 = CARTESIAN_POINT('',(3.999999978063,-15.9,6.499986334453));
#1289 = SURFACE_CURVE('',#1290,(#1294,#1301),.PCURVE_S1.);
#1290 = LINE('',#1291,#1292);
#1291 = CARTESIAN_POINT('',(3.999999978063,1.44E-15,6.499986334453));
#1292 = VECTOR('',#1293,1.);
#1293 = DIRECTION('',(0.,-1.,0.));
#1294 = PCURVE('',#901,#1295);
#1295 = DEFINITIONAL_REPRESENTATION('',(#1296),#1300);
#1296 = LINE('',#1297,#1298);
#1297 = CARTESIAN_POINT('',(-1.3929E-08,0.));
#1298 = VECTOR('',#1299,1.);
#1299 = DIRECTION('',(-0.,-1.));
#1300 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1301 = PCURVE('',#1302,#1307);
#1302 = PLANE('',#1303);
#1303 = AXIS2_PLACEMENT_3D('',#1304,#1305,#1306);
#1304 = CARTESIAN_POINT('',(3.999999978063,1.44E-15,6.499986334453));
#1305 = DIRECTION('',(1.,0.,0.));
#1306 = DIRECTION('',(0.,-2.2E-16,-1.));
#1307 = DEFINITIONAL_REPRESENTATION('',(#1308),#1312);
#1308 = LINE('',#1309,#1310);
#1309 = CARTESIAN_POINT('',(0.,0.));
#1310 = VECTOR('',#1311,1.);
#1311 = DIRECTION('',(2.2E-16,-1.));
#1312 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1313 = ORIENTED_EDGE('',*,*,#1314,.T.);
#1314 = EDGE_CURVE('',#1287,#858,#1315,.T.);
#1315 = SURFACE_CURVE('',#1316,(#1321,#1328),.PCURVE_S1.);
#1316 = CIRCLE('',#1317,1.5);
#1317 = AXIS2_PLACEMENT_3D('',#1318,#1319,#1320);
#1318 = CARTESIAN_POINT('',(2.499999978063,-15.9,6.499986313559));
#1319 = DIRECTION('',(0.,-1.,2.2E-16));
#1320 = DIRECTION('',(1.,3.0643795138E-24,1.392899779E-08));
#1321 = PCURVE('',#901,#1322);
#1322 = DEFINITIONAL_REPRESENTATION('',(#1323),#1327);
#1323 = LINE('',#1324,#1325);
#1324 = CARTESIAN_POINT('',(-1.3929E-08,-15.9));
#1325 = VECTOR('',#1326,1.);
#1326 = DIRECTION('',(-1.,0.));
#1327 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1328 = PCURVE('',#1247,#1329);
#1329 = DEFINITIONAL_REPRESENTATION('',(#1330),#1334);
#1330 = LINE('',#1331,#1332);
#1331 = CARTESIAN_POINT('',(0.,0.));
#1332 = VECTOR('',#1333,1.);
#1333 = DIRECTION('',(1.,0.));
#1334 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1335 = ORIENTED_EDGE('',*,*,#885,.F.);
#1336 = ORIENTED_EDGE('',*,*,#1337,.F.);
#1337 = EDGE_CURVE('',#1285,#886,#1338,.T.);
#1338 = SURFACE_CURVE('',#1339,(#1344,#1351),.PCURVE_S1.);
#1339 = CIRCLE('',#1340,1.5);
#1340 = AXIS2_PLACEMENT_3D('',#1341,#1342,#1343);
#1341 = CARTESIAN_POINT('',(2.499999978063,-1.E-01,6.499986313559));
#1342 = DIRECTION('',(0.,-1.,2.2E-16));
#1343 = DIRECTION('',(1.,3.0643800418E-24,1.392900019E-08));
#1344 = PCURVE('',#901,#1345);
#1345 = DEFINITIONAL_REPRESENTATION('',(#1346),#1350);
#1346 = LINE('',#1347,#1348);
#1347 = CARTESIAN_POINT('',(-1.392900018E-08,-0.1));
#1348 = VECTOR('',#1349,1.);
#1349 = DIRECTION('',(-1.,0.));
#1350 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1351 = PCURVE('',#1194,#1352);
#1352 = DEFINITIONAL_REPRESENTATION('',(#1353),#1357);
#1353 = LINE('',#1354,#1355);
#1354 = CARTESIAN_POINT('',(-0.,0.));
#1355 = VECTOR('',#1356,1.);
#1356 = DIRECTION('',(-1.,0.));
#1357 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1358 = ADVANCED_FACE('',(#1359),#1007,.F.);
#1359 = FACE_BOUND('',#1360,.F.);
#1360 = EDGE_LOOP('',(#1361,#1362,#1385,#1414,#1442,#1471,#1499,#1521));
#1361 = ORIENTED_EDGE('',*,*,#992,.T.);
#1362 = ORIENTED_EDGE('',*,*,#1363,.T.);
#1363 = EDGE_CURVE('',#966,#1364,#1366,.T.);
#1364 = VERTEX_POINT('',#1365);
#1365 = CARTESIAN_POINT('',(-3.899999999937,0.,1.499986280387));
#1366 = SURFACE_CURVE('',#1367,(#1371,#1378),.PCURVE_S1.);
#1367 = LINE('',#1368,#1369);
#1368 = CARTESIAN_POINT('',(-3.9,1.46E-15,6.499986280388));
#1369 = VECTOR('',#1370,1.);
#1370 = DIRECTION('',(1.254854E-11,-2.2E-16,-1.));
#1371 = PCURVE('',#1007,#1372);
#1372 = DEFINITIONAL_REPRESENTATION('',(#1373),#1377);
#1373 = LINE('',#1374,#1375);
#1374 = CARTESIAN_POINT('',(-2.499993193902,-3.899999895111));
#1375 = VECTOR('',#1376,1.);
#1376 = DIRECTION('',(1.,1.254854E-11));
#1377 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1378 = PCURVE('',#981,#1379);
#1379 = DEFINITIONAL_REPRESENTATION('',(#1380),#1384);
#1380 = LINE('',#1381,#1382);
#1381 = CARTESIAN_POINT('',(1.570796326795,0.));
#1382 = VECTOR('',#1383,1.);
#1383 = DIRECTION('',(0.,1.));
#1384 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1385 = ORIENTED_EDGE('',*,*,#1386,.T.);
#1386 = EDGE_CURVE('',#1364,#1387,#1389,.T.);
#1387 = VERTEX_POINT('',#1388);
#1388 = CARTESIAN_POINT('',(-2.500000007043,0.,0.1));
#1389 = SURFACE_CURVE('',#1390,(#1395,#1402),.PCURVE_S1.);
#1390 = CIRCLE('',#1391,1.4);
#1391 = AXIS2_PLACEMENT_3D('',#1392,#1393,#1394);
#1392 = CARTESIAN_POINT('',(-2.5,3.3E-16,1.5));
#1393 = DIRECTION('',(0.,-1.,2.2E-16));
#1394 = DIRECTION('',(-0.999999999958,-2.012210025452E-21,
-9.1464092066E-06));
#1395 = PCURVE('',#1007,#1396);
#1396 = DEFINITIONAL_REPRESENTATION('',(#1397),#1401);
#1397 = CIRCLE('',#1398,1.4);
#1398 = AXIS2_PLACEMENT_2D('',#1399,#1400);
#1399 = CARTESIAN_POINT('',(2.499993086486,-2.499999895111));
#1400 = DIRECTION('',(9.14640920653E-06,-0.999999999958));
#1401 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1402 = PCURVE('',#1403,#1408);
#1403 = TOROIDAL_SURFACE('',#1404,1.4,0.1);
#1404 = AXIS2_PLACEMENT_3D('',#1405,#1406,#1407);
#1405 = CARTESIAN_POINT('',(-2.5,-1.E-01,1.5));
#1406 = DIRECTION('',(0.,1.,-2.2E-16));
#1407 = DIRECTION('',(-0.999999999958,-2.012210025452E-21,
#1408 = DEFINITIONAL_REPRESENTATION('',(#1409),#1413);
#1409 = LINE('',#1410,#1411);
#1410 = CARTESIAN_POINT('',(-0.,1.570796326795));
#1411 = VECTOR('',#1412,1.);
#1412 = DIRECTION('',(-1.,0.));
#1413 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1414 = ORIENTED_EDGE('',*,*,#1415,.T.);
#1415 = EDGE_CURVE('',#1387,#1416,#1418,.T.);
#1416 = VERTEX_POINT('',#1417);
#1417 = CARTESIAN_POINT('',(2.499999992453,0.,0.1));
#1418 = SURFACE_CURVE('',#1419,(#1423,#1430),.PCURVE_S1.);
#1419 = LINE('',#1420,#1421);
#1420 = CARTESIAN_POINT('',(-2.500000007546,1.E-17,1.E-01));
#1421 = VECTOR('',#1422,1.);
#1422 = DIRECTION('',(1.,0.,0.));
#1423 = PCURVE('',#1007,#1424);
#1424 = DEFINITIONAL_REPRESENTATION('',(#1425),#1429);
#1425 = LINE('',#1426,#1427);
#1426 = CARTESIAN_POINT('',(3.899993086486,-2.499999902657));
#1427 = VECTOR('',#1428,1.);
#1428 = DIRECTION('',(0.,1.));
#1429 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
PARAMETRIC_REPRESENTATION_CONTEXT() REPRESENTATION_CONTEXT('2D SPACE',''
#1430 = PCURVE('',#1431,#1436);
#1431 = CYLINDRICAL_SURFACE('',#1432,0.1);
#1432 = AXIS2_PLACEMENT_3D('',#1433,#1434,#1435);
#1433 = CARTESIAN_POINT('',(-2.500000007546,-1.E-01,0.1));
#1434 = DIRECTION('',(1.,0.,0.));
#1435 = DIRECTION('',(0.,0.,-1.));
#1436 = DEFINITIONAL_REPRESENTATION('',(#1437),#1441);
#1437 = LINE('',#1438,#1439);
#1438 = CARTESIAN_POINT('',(1.570796326795,0.));
#1439 = VECTOR('',#1440,1.);
#1440 = DIRECTION('',(0.,1.));
#1441 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1442 = ORIENTED_EDGE('',*,*,#1443,.T.);
#1443 = EDGE_CURVE('',#1416,#1444,#1446,.T.);
#1444 = VERTEX_POINT('',#1445);
#1445 = CARTESIAN_POINT('',(3.899999978063,0.,1.499999998055));
#1446 = SURFACE_CURVE('',#1447,(#1452,#1459),.PCURVE_S1.);
#1447 = CIRCLE('',#1448,1.4);
#1448 = AXIS2_PLACEMENT_3D('',#1449,#1450,#1451);
#1449 = CARTESIAN_POINT('',(2.499999978063,3.3E-16,1.5));
#1450 = DIRECTION('',(0.,-1.,2.2E-16));
#1451 = DIRECTION('',(9.59330985E-09,-2.2E-16,-1.));
#1452 = PCURVE('',#1007,#1453);
#1453 = DEFINITIONAL_REPRESENTATION('',(#1454),#1458);
#1454 = CIRCLE('',#1455,1.4);
#1455 = AXIS2_PLACEMENT_2D('',#1456,#1457);
#1456 = CARTESIAN_POINT('',(2.499993086486,2.500000082952));
#1457 = DIRECTION('',(1.,9.59330996E-09));
#1458 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1459 = PCURVE('',#1460,#1465);
#1460 = TOROIDAL_SURFACE('',#1461,1.4,0.1);
#1461 = AXIS2_PLACEMENT_3D('',#1462,#1463,#1464);
#1462 = CARTESIAN_POINT('',(2.499999978063,-1.E-01,1.5));
#1463 = DIRECTION('',(0.,1.,-2.2E-16));
#1464 = DIRECTION('',(9.59330985E-09,-2.2E-16,-1.));
#1465 = DEFINITIONAL_REPRESENTATION('',(#1466),#1470);
#1466 = LINE('',#1467,#1468);
#1467 = CARTESIAN_POINT('',(-0.,1.570796326795));
#1468 = VECTOR('',#1469,1.);
#1469 = DIRECTION('',(-1.,0.));
#1470 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1471 = ORIENTED_EDGE('',*,*,#1472,.T.);
#1472 = EDGE_CURVE('',#1444,#1473,#1475,.T.);
#1473 = VERTEX_POINT('',#1474);
#1474 = CARTESIAN_POINT('',(3.899999978063,1.E-15,6.499986334453));
#1475 = SURFACE_CURVE('',#1476,(#1480,#1487),.PCURVE_S1.);
#1476 = LINE('',#1477,#1478);
#1477 = CARTESIAN_POINT('',(3.899999978063,3.5E-16,1.499999997916));
#1478 = VECTOR('',#1479,1.);
#1479 = DIRECTION('',(0.,2.2E-16,1.));
#1480 = PCURVE('',#1007,#1481);
#1481 = DEFINITIONAL_REPRESENTATION('',(#1482),#1486);
#1482 = LINE('',#1483,#1484);
#1483 = CARTESIAN_POINT('',(2.49999308857,3.900000082952));
#1484 = VECTOR('',#1485,1.);
#1485 = DIRECTION('',(-1.,-0.));
#1486 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1487 = PCURVE('',#1488,#1493);
#1488 = CYLINDRICAL_SURFACE('',#1489,0.1);
#1489 = AXIS2_PLACEMENT_3D('',#1490,#1491,#1492);
#1490 = CARTESIAN_POINT('',(3.899999978063,-1.E-01,1.499999997916));
#1491 = DIRECTION('',(0.,2.2E-16,1.));
#1492 = DIRECTION('',(1.,0.,0.));
#1493 = DEFINITIONAL_REPRESENTATION('',(#1494),#1498);
#1494 = LINE('',#1495,#1496);
#1495 = CARTESIAN_POINT('',(1.570796326795,0.));
#1496 = VECTOR('',#1497,1.);
#1497 = DIRECTION('',(0.,1.));
#1498 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1499 = ORIENTED_EDGE('',*,*,#1500,.T.);
#1500 = EDGE_CURVE('',#1473,#1179,#1501,.T.);
#1501 = SURFACE_CURVE('',#1502,(#1507,#1514),.PCURVE_S1.);
#1502 = CIRCLE('',#1503,1.4);
#1503 = AXIS2_PLACEMENT_3D('',#1504,#1505,#1506);
#1504 = CARTESIAN_POINT('',(2.499999978063,1.44E-15,6.499986313559));
#1505 = DIRECTION('',(0.,-1.,2.2E-16));
#1506 = DIRECTION('',(1.,3.0643800418E-24,1.392900019E-08));
#1507 = PCURVE('',#1007,#1508);
#1508 = DEFINITIONAL_REPRESENTATION('',(#1509),#1513);
#1509 = CIRCLE('',#1510,1.4);
#1510 = AXIS2_PLACEMENT_2D('',#1511,#1512);
#1511 = CARTESIAN_POINT('',(-2.499993227073,2.500000082952));
#1512 = DIRECTION('',(-1.392900018E-08,1.));
#1513 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1514 = PCURVE('',#1194,#1515);
#1515 = DEFINITIONAL_REPRESENTATION('',(#1516),#1520);
#1516 = LINE('',#1517,#1518);
#1517 = CARTESIAN_POINT('',(-0.,1.570796326795));
#1518 = VECTOR('',#1519,1.);
#1519 = DIRECTION('',(-1.,0.));
#1520 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1521 = ORIENTED_EDGE('',*,*,#1205,.T.);
#1522 = ADVANCED_FACE('',(#1523),#981,.T.);
#1523 = FACE_BOUND('',#1524,.T.);
#1524 = EDGE_LOOP('',(#1525,#1526,#1527,#1547));
#1525 = ORIENTED_EDGE('',*,*,#965,.T.);
#1526 = ORIENTED_EDGE('',*,*,#1363,.T.);
#1527 = ORIENTED_EDGE('',*,*,#1528,.F.);
#1528 = EDGE_CURVE('',#1103,#1364,#1529,.T.);
#1529 = SURFACE_CURVE('',#1530,(#1535,#1541),.PCURVE_S1.);
#1530 = CIRCLE('',#1531,0.1);
#1531 = AXIS2_PLACEMENT_3D('',#1532,#1533,#1534);
#1532 = CARTESIAN_POINT('',(-3.899999999937,-1.E-01,1.499986280387));
#1533 = DIRECTION('',(1.254854E-11,-2.2E-16,-1.));
#1534 = DIRECTION('',(-1.,0.,-1.254854E-11));
#1535 = PCURVE('',#981,#1536);
#1536 = DEFINITIONAL_REPRESENTATION('',(#1537),#1540);
#1537 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1538,#1539),.UNSPECIFIED.,.F.,
#1538 = CARTESIAN_POINT('',(0.,5.000000000001));
#1539 = CARTESIAN_POINT('',(1.570796326795,5.000000000001));
#1540 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1541 = PCURVE('',#1403,#1542);
#1542 = DEFINITIONAL_REPRESENTATION('',(#1543),#1546);
#1543 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1544,#1545),.UNSPECIFIED.,.F.,
#1544 = CARTESIAN_POINT('',(0.,0.));
#1545 = CARTESIAN_POINT('',(0.,1.570796326795));
#1546 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1547 = ORIENTED_EDGE('',*,*,#1154,.F.);
#1548 = ADVANCED_FACE('',(#1549),#1087,.T.);
#1549 = FACE_BOUND('',#1550,.T.);
#1550 = EDGE_LOOP('',(#1551,#1552,#1575,#1604,#1632,#1661,#1689,#1711));
#1551 = ORIENTED_EDGE('',*,*,#1072,.T.);
#1552 = ORIENTED_EDGE('',*,*,#1553,.T.);
#1553 = EDGE_CURVE('',#1046,#1554,#1556,.T.);
#1554 = VERTEX_POINT('',#1555);
#1555 = CARTESIAN_POINT('',(-3.899999999937,-16.,1.499986280387));
#1556 = SURFACE_CURVE('',#1557,(#1561,#1568),.PCURVE_S1.);
#1557 = LINE('',#1558,#1559);
#1558 = CARTESIAN_POINT('',(-3.9,-16.,6.499986280388));
#1559 = VECTOR('',#1560,1.);
#1560 = DIRECTION('',(1.254854E-11,-2.2E-16,-1.));
#1561 = PCURVE('',#1087,#1562);
#1562 = DEFINITIONAL_REPRESENTATION('',(#1563),#1567);
#1563 = LINE('',#1564,#1565);
#1564 = CARTESIAN_POINT('',(-2.499993193902,-3.899999895111));
#1565 = VECTOR('',#1566,1.);
#1566 = DIRECTION('',(1.,1.254854E-11));
#1567 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1568 = PCURVE('',#1061,#1569);
#1569 = DEFINITIONAL_REPRESENTATION('',(#1570),#1574);
#1570 = LINE('',#1571,#1572);
#1571 = CARTESIAN_POINT('',(-1.570796326795,0.));
#1572 = VECTOR('',#1573,1.);
#1573 = DIRECTION('',(-0.,1.));
#1574 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1575 = ORIENTED_EDGE('',*,*,#1576,.T.);
#1576 = EDGE_CURVE('',#1554,#1577,#1579,.T.);
#1577 = VERTEX_POINT('',#1578);
#1578 = CARTESIAN_POINT('',(-2.500000007043,-16.,0.1));
#1579 = SURFACE_CURVE('',#1580,(#1585,#1592),.PCURVE_S1.);
#1580 = CIRCLE('',#1581,1.4);
#1581 = AXIS2_PLACEMENT_3D('',#1582,#1583,#1584);
#1582 = CARTESIAN_POINT('',(-2.5,-16.,1.5));
#1583 = DIRECTION('',(0.,-1.,2.2E-16));
#1584 = DIRECTION('',(-0.999999999958,-2.012210025978E-21,
-9.14640920899E-06));
#1585 = PCURVE('',#1087,#1586);
#1586 = DEFINITIONAL_REPRESENTATION('',(#1587),#1591);
#1587 = CIRCLE('',#1588,1.4);
#1588 = AXIS2_PLACEMENT_2D('',#1589,#1590);
#1589 = CARTESIAN_POINT('',(2.499993086486,-2.499999895111));
#1590 = DIRECTION('',(9.14640920906E-06,-0.999999999958));
#1591 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1592 = PCURVE('',#1593,#1598);
#1593 = TOROIDAL_SURFACE('',#1594,1.4,0.1);
#1594 = AXIS2_PLACEMENT_3D('',#1595,#1596,#1597);
#1595 = CARTESIAN_POINT('',(-2.5,-15.9,1.5));
#1596 = DIRECTION('',(0.,-1.,2.2E-16));
#1597 = DIRECTION('',(-0.999999999958,-2.012210025978E-21,
#1598 = DEFINITIONAL_REPRESENTATION('',(#1599),#1603);
#1599 = LINE('',#1600,#1601);
#1600 = CARTESIAN_POINT('',(0.,1.570796326795));
#1601 = VECTOR('',#1602,1.);
#1602 = DIRECTION('',(1.,0.));
#1603 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1604 = ORIENTED_EDGE('',*,*,#1605,.T.);
#1605 = EDGE_CURVE('',#1577,#1606,#1608,.T.);
#1606 = VERTEX_POINT('',#1607);
#1607 = CARTESIAN_POINT('',(2.499999992453,-16.,0.1));
#1608 = SURFACE_CURVE('',#1609,(#1613,#1620),.PCURVE_S1.);
#1609 = LINE('',#1610,#1611);
#1610 = CARTESIAN_POINT('',(-2.500000007546,-16.,0.1));
#1611 = VECTOR('',#1612,1.);
#1612 = DIRECTION('',(1.,0.,0.));
#1613 = PCURVE('',#1087,#1614);
#1614 = DEFINITIONAL_REPRESENTATION('',(#1615),#1619);
#1615 = LINE('',#1616,#1617);
#1616 = CARTESIAN_POINT('',(3.899993086486,-2.499999902657));
#1617 = VECTOR('',#1618,1.);
#1618 = DIRECTION('',(0.,1.));
#1619 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1620 = PCURVE('',#1621,#1626);
#1621 = CYLINDRICAL_SURFACE('',#1622,0.1);
#1622 = AXIS2_PLACEMENT_3D('',#1623,#1624,#1625);
#1623 = CARTESIAN_POINT('',(-2.500000007546,-15.9,0.1));
#1624 = DIRECTION('',(1.,0.,0.));
#1625 = DIRECTION('',(0.,0.,-1.));
#1626 = DEFINITIONAL_REPRESENTATION('',(#1627),#1631);
#1627 = LINE('',#1628,#1629);
#1628 = CARTESIAN_POINT('',(-1.570796326795,0.));
#1629 = VECTOR('',#1630,1.);
#1630 = DIRECTION('',(-0.,1.));
#1631 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1632 = ORIENTED_EDGE('',*,*,#1633,.T.);
#1633 = EDGE_CURVE('',#1606,#1634,#1636,.T.);
#1634 = VERTEX_POINT('',#1635);
#1635 = CARTESIAN_POINT('',(3.899999978063,-16.,1.499999998055));
#1636 = SURFACE_CURVE('',#1637,(#1642,#1649),.PCURVE_S1.);
#1637 = CIRCLE('',#1638,1.4);
#1638 = AXIS2_PLACEMENT_3D('',#1639,#1640,#1641);
#1639 = CARTESIAN_POINT('',(2.499999978063,-16.,1.5));
#1640 = DIRECTION('',(0.,-1.,2.2E-16));
#1641 = DIRECTION('',(9.59330985E-09,-2.2E-16,-1.));
#1642 = PCURVE('',#1087,#1643);
#1643 = DEFINITIONAL_REPRESENTATION('',(#1644),#1648);
#1644 = CIRCLE('',#1645,1.4);
#1645 = AXIS2_PLACEMENT_2D('',#1646,#1647);
#1646 = CARTESIAN_POINT('',(2.499993086486,2.500000082952));
#1647 = DIRECTION('',(1.,9.59330996E-09));
#1648 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1649 = PCURVE('',#1650,#1655);
#1650 = TOROIDAL_SURFACE('',#1651,1.4,0.1);
#1651 = AXIS2_PLACEMENT_3D('',#1652,#1653,#1654);
#1652 = CARTESIAN_POINT('',(2.499999978063,-15.9,1.5));
#1653 = DIRECTION('',(0.,-1.,2.2E-16));
#1654 = DIRECTION('',(9.59330985E-09,-2.2E-16,-1.));
#1655 = DEFINITIONAL_REPRESENTATION('',(#1656),#1660);
#1656 = LINE('',#1657,#1658);
#1657 = CARTESIAN_POINT('',(0.,1.570796326795));
#1658 = VECTOR('',#1659,1.);
#1659 = DIRECTION('',(1.,0.));
#1660 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1661 = ORIENTED_EDGE('',*,*,#1662,.T.);
#1662 = EDGE_CURVE('',#1634,#1663,#1665,.T.);
#1663 = VERTEX_POINT('',#1664);
#1664 = CARTESIAN_POINT('',(3.899999978063,-16.,6.499986334453));
#1665 = SURFACE_CURVE('',#1666,(#1670,#1677),.PCURVE_S1.);
#1666 = LINE('',#1667,#1668);
#1667 = CARTESIAN_POINT('',(3.899999978063,-16.,1.499999997916));
#1668 = VECTOR('',#1669,1.);
#1669 = DIRECTION('',(0.,2.2E-16,1.));
#1670 = PCURVE('',#1087,#1671);
#1671 = DEFINITIONAL_REPRESENTATION('',(#1672),#1676);
#1672 = LINE('',#1673,#1674);
#1673 = CARTESIAN_POINT('',(2.49999308857,3.900000082952));
#1674 = VECTOR('',#1675,1.);
#1675 = DIRECTION('',(-1.,-0.));
#1676 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1677 = PCURVE('',#1678,#1683);
#1678 = CYLINDRICAL_SURFACE('',#1679,0.1);
#1679 = AXIS2_PLACEMENT_3D('',#1680,#1681,#1682);
#1680 = CARTESIAN_POINT('',(3.899999978063,-15.9,1.499999997916));
#1681 = DIRECTION('',(0.,2.2E-16,1.));
#1682 = DIRECTION('',(1.,0.,0.));
#1683 = DEFINITIONAL_REPRESENTATION('',(#1684),#1688);
#1684 = LINE('',#1685,#1686);
#1685 = CARTESIAN_POINT('',(-1.570796326795,0.));
#1686 = VECTOR('',#1687,1.);
#1687 = DIRECTION('',(-0.,1.));
#1688 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1689 = ORIENTED_EDGE('',*,*,#1690,.T.);
#1690 = EDGE_CURVE('',#1663,#1232,#1691,.T.);
#1691 = SURFACE_CURVE('',#1692,(#1697,#1704),.PCURVE_S1.);
#1692 = CIRCLE('',#1693,1.4);
#1693 = AXIS2_PLACEMENT_3D('',#1694,#1695,#1696);
#1694 = CARTESIAN_POINT('',(2.499999978063,-16.,6.499986313559));
#1695 = DIRECTION('',(0.,-1.,2.2E-16));
#1696 = DIRECTION('',(1.,3.0643795138E-24,1.392899779E-08));
#1697 = PCURVE('',#1087,#1698);
#1698 = DEFINITIONAL_REPRESENTATION('',(#1699),#1703);
#1699 = CIRCLE('',#1700,1.4);
#1700 = AXIS2_PLACEMENT_2D('',#1701,#1702);
#1701 = CARTESIAN_POINT('',(-2.499993227073,2.500000082952));
#1702 = DIRECTION('',(-1.392899764E-08,1.));
#1703 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1704 = PCURVE('',#1247,#1705);
#1705 = DEFINITIONAL_REPRESENTATION('',(#1706),#1710);
#1706 = LINE('',#1707,#1708);
#1707 = CARTESIAN_POINT('',(0.,1.570796326795));
#1708 = VECTOR('',#1709,1.);
#1709 = DIRECTION('',(1.,0.));
#1710 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1711 = ORIENTED_EDGE('',*,*,#1258,.T.);
#1712 = ADVANCED_FACE('',(#1713),#1061,.T.);
#1713 = FACE_BOUND('',#1714,.F.);
#1714 = EDGE_LOOP('',(#1715,#1716,#1717,#1737));
#1715 = ORIENTED_EDGE('',*,*,#1045,.T.);
#1716 = ORIENTED_EDGE('',*,*,#1553,.T.);
#1717 = ORIENTED_EDGE('',*,*,#1718,.F.);
#1718 = EDGE_CURVE('',#1105,#1554,#1719,.T.);
#1719 = SURFACE_CURVE('',#1720,(#1725,#1731),.PCURVE_S1.);
#1720 = CIRCLE('',#1721,0.1);
#1721 = AXIS2_PLACEMENT_3D('',#1722,#1723,#1724);
#1722 = CARTESIAN_POINT('',(-3.899999999937,-15.9,1.499986280387));
#1723 = DIRECTION('',(-1.254854E-11,2.2E-16,1.));
#1724 = DIRECTION('',(-1.,0.,-1.254854E-11));
#1725 = PCURVE('',#1061,#1726);
#1726 = DEFINITIONAL_REPRESENTATION('',(#1727),#1730);
#1727 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1728,#1729),.UNSPECIFIED.,.F.,
#1728 = CARTESIAN_POINT('',(0.,5.000000000001));
#1729 = CARTESIAN_POINT('',(-1.570796326795,5.000000000001));
#1730 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1731 = PCURVE('',#1593,#1732);
#1732 = DEFINITIONAL_REPRESENTATION('',(#1733),#1736);
#1733 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1734,#1735),.UNSPECIFIED.,.F.,
#1734 = CARTESIAN_POINT('',(-2.22E-15,0.));
#1735 = CARTESIAN_POINT('',(-2.22E-15,1.570796326795));
#1736 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1737 = ORIENTED_EDGE('',*,*,#1132,.F.);
#1738 = ADVANCED_FACE('',(#1739),#1120,.T.);
#1739 = FACE_BOUND('',#1740,.F.);
#1740 = EDGE_LOOP('',(#1741,#1742,#1766,#1794));
#1741 = ORIENTED_EDGE('',*,*,#1102,.T.);
#1742 = ORIENTED_EDGE('',*,*,#1743,.T.);
#1743 = EDGE_CURVE('',#1105,#1744,#1746,.T.);
#1744 = VERTEX_POINT('',#1745);
#1745 = CARTESIAN_POINT('',(-2.500000007546,-15.9,3.E-15));
#1746 = SURFACE_CURVE('',#1747,(#1752,#1759),.PCURVE_S1.);
#1747 = CIRCLE('',#1748,1.5);
#1748 = AXIS2_PLACEMENT_3D('',#1749,#1750,#1751);
#1749 = CARTESIAN_POINT('',(-2.5,-15.9,1.5));
#1750 = DIRECTION('',(0.,-1.,2.2E-16));
#1751 = DIRECTION('',(-0.999999999958,-2.012210025978E-21,
#1752 = PCURVE('',#1120,#1753);
#1753 = DEFINITIONAL_REPRESENTATION('',(#1754),#1758);
#1754 = LINE('',#1755,#1756);
#1755 = CARTESIAN_POINT('',(-3.141601799999,-15.9));
#1756 = VECTOR('',#1757,1.);
#1757 = DIRECTION('',(-1.,0.));
#1758 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1759 = PCURVE('',#1593,#1760);
#1760 = DEFINITIONAL_REPRESENTATION('',(#1761),#1765);
#1761 = LINE('',#1762,#1763);
#1762 = CARTESIAN_POINT('',(0.,0.));
#1763 = VECTOR('',#1764,1.);
#1764 = DIRECTION('',(1.,0.));
#1765 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1766 = ORIENTED_EDGE('',*,*,#1767,.F.);
#1767 = EDGE_CURVE('',#1768,#1744,#1770,.T.);
#1768 = VERTEX_POINT('',#1769);
#1769 = CARTESIAN_POINT('',(-2.500000007546,-0.1,-0.));
#1770 = SURFACE_CURVE('',#1771,(#1775,#1782),.PCURVE_S1.);
#1771 = LINE('',#1772,#1773);
#1772 = CARTESIAN_POINT('',(-2.500000007546,0.,0.));
#1773 = VECTOR('',#1774,1.);
#1774 = DIRECTION('',(0.,-1.,0.));
#1775 = PCURVE('',#1120,#1776);
#1776 = DEFINITIONAL_REPRESENTATION('',(#1777),#1781);
#1777 = LINE('',#1778,#1779);
#1778 = CARTESIAN_POINT('',(-4.712388975354,0.));
#1779 = VECTOR('',#1780,1.);
#1780 = DIRECTION('',(-0.,-1.));
#1781 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1782 = PCURVE('',#1783,#1788);
#1783 = PLANE('',#1784);
#1784 = AXIS2_PLACEMENT_3D('',#1785,#1786,#1787);
#1785 = CARTESIAN_POINT('',(-2.500000007546,0.,0.));
#1786 = DIRECTION('',(0.,0.,1.));
#1787 = DIRECTION('',(1.,0.,0.));
#1788 = DEFINITIONAL_REPRESENTATION('',(#1789),#1793);
#1789 = LINE('',#1790,#1791);
#1790 = CARTESIAN_POINT('',(0.,0.));
#1791 = VECTOR('',#1792,1.);
#1792 = DIRECTION('',(0.,-1.));
#1793 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1794 = ORIENTED_EDGE('',*,*,#1795,.F.);
#1795 = EDGE_CURVE('',#1103,#1768,#1796,.T.);
#1796 = SURFACE_CURVE('',#1797,(#1802,#1809),.PCURVE_S1.);
#1797 = CIRCLE('',#1798,1.5);
#1798 = AXIS2_PLACEMENT_3D('',#1799,#1800,#1801);
#1799 = CARTESIAN_POINT('',(-2.5,-1.E-01,1.5));
#1800 = DIRECTION('',(0.,-1.,2.2E-16));
#1801 = DIRECTION('',(-0.999999999958,-2.012210025452E-21,
#1802 = PCURVE('',#1120,#1803);
#1803 = DEFINITIONAL_REPRESENTATION('',(#1804),#1808);
#1804 = LINE('',#1805,#1806);
#1805 = CARTESIAN_POINT('',(-3.141601799999,-0.1));
#1806 = VECTOR('',#1807,1.);
#1807 = DIRECTION('',(-1.,0.));
#1808 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1809 = PCURVE('',#1403,#1810);
#1810 = DEFINITIONAL_REPRESENTATION('',(#1811),#1815);
#1811 = LINE('',#1812,#1813);
#1812 = CARTESIAN_POINT('',(-0.,0.));
#1813 = VECTOR('',#1814,1.);
#1814 = DIRECTION('',(-1.,0.));
#1815 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1816 = ADVANCED_FACE('',(#1817),#1194,.T.);
#1817 = FACE_BOUND('',#1818,.F.);
#1818 = EDGE_LOOP('',(#1819,#1839,#1840,#1841));
#1819 = ORIENTED_EDGE('',*,*,#1820,.F.);
#1820 = EDGE_CURVE('',#1285,#1473,#1821,.T.);
#1821 = SURFACE_CURVE('',#1822,(#1827,#1833),.PCURVE_S1.);
#1822 = CIRCLE('',#1823,0.1);
#1823 = AXIS2_PLACEMENT_3D('',#1824,#1825,#1826);
#1824 = CARTESIAN_POINT('',(3.899999978063,-1.E-01,6.499986334453));
#1825 = DIRECTION('',(-0.,2.2E-16,1.));
#1826 = DIRECTION('',(1.,0.,0.));
#1827 = PCURVE('',#1194,#1828);
#1828 = DEFINITIONAL_REPRESENTATION('',(#1829),#1832);
#1829 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1830,#1831),.UNSPECIFIED.,.F.,
#1830 = CARTESIAN_POINT('',(1.8E-16,0.));
#1831 = CARTESIAN_POINT('',(1.8E-16,1.570796326795));
#1832 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1833 = PCURVE('',#1488,#1834);
#1834 = DEFINITIONAL_REPRESENTATION('',(#1835),#1838);
#1835 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1836,#1837),.UNSPECIFIED.,.F.,
#1836 = CARTESIAN_POINT('',(0.,4.999986336536));
#1837 = CARTESIAN_POINT('',(1.570796326795,4.999986336536));
#1838 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1839 = ORIENTED_EDGE('',*,*,#1337,.T.);
#1840 = ORIENTED_EDGE('',*,*,#1178,.T.);
#1841 = ORIENTED_EDGE('',*,*,#1500,.F.);
#1842 = ADVANCED_FACE('',(#1843),#1247,.T.);
#1843 = FACE_BOUND('',#1844,.T.);
#1844 = EDGE_LOOP('',(#1845,#1865,#1866,#1867));
#1845 = ORIENTED_EDGE('',*,*,#1846,.F.);
#1846 = EDGE_CURVE('',#1287,#1663,#1847,.T.);
#1847 = SURFACE_CURVE('',#1848,(#1853,#1859),.PCURVE_S1.);
#1848 = CIRCLE('',#1849,0.1);
#1849 = AXIS2_PLACEMENT_3D('',#1850,#1851,#1852);
#1850 = CARTESIAN_POINT('',(3.899999978063,-15.9,6.499986334453));
#1851 = DIRECTION('',(0.,-2.2E-16,-1.));
#1852 = DIRECTION('',(1.,0.,0.));
#1853 = PCURVE('',#1247,#1854);
#1854 = DEFINITIONAL_REPRESENTATION('',(#1855),#1858);
#1855 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1856,#1857),.UNSPECIFIED.,.F.,
#1856 = CARTESIAN_POINT('',(0.,0.));
#1857 = CARTESIAN_POINT('',(0.,1.570796326795));
#1858 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1859 = PCURVE('',#1678,#1860);
#1860 = DEFINITIONAL_REPRESENTATION('',(#1861),#1864);
#1861 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1862,#1863),.UNSPECIFIED.,.F.,
#1862 = CARTESIAN_POINT('',(0.,4.999986336536));
#1863 = CARTESIAN_POINT('',(-1.570796326795,4.999986336536));
#1864 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1865 = ORIENTED_EDGE('',*,*,#1314,.T.);
#1866 = ORIENTED_EDGE('',*,*,#1231,.T.);
#1867 = ORIENTED_EDGE('',*,*,#1690,.F.);
#1868 = ADVANCED_FACE('',(#1869),#1302,.T.);
#1869 = FACE_BOUND('',#1870,.T.);
#1870 = EDGE_LOOP('',(#1871,#1872,#1895,#1923));
#1871 = ORIENTED_EDGE('',*,*,#1284,.T.);
#1872 = ORIENTED_EDGE('',*,*,#1873,.F.);
#1873 = EDGE_CURVE('',#1874,#1287,#1876,.T.);
#1874 = VERTEX_POINT('',#1875);
#1875 = CARTESIAN_POINT('',(3.999999978063,-15.9,1.499999997916));
#1876 = SURFACE_CURVE('',#1877,(#1881,#1888),.PCURVE_S1.);
#1877 = LINE('',#1878,#1879);
#1878 = CARTESIAN_POINT('',(3.999999978063,-15.9,1.499999997916));
#1879 = VECTOR('',#1880,1.);
#1880 = DIRECTION('',(0.,2.2E-16,1.));
#1881 = PCURVE('',#1302,#1882);
#1882 = DEFINITIONAL_REPRESENTATION('',(#1883),#1887);
#1883 = LINE('',#1884,#1885);
#1884 = CARTESIAN_POINT('',(4.999986336537,-15.9));
#1885 = VECTOR('',#1886,1.);
#1886 = DIRECTION('',(-1.,-0.));
#1887 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1888 = PCURVE('',#1678,#1889);
#1889 = DEFINITIONAL_REPRESENTATION('',(#1890),#1894);
#1890 = LINE('',#1891,#1892);
#1891 = CARTESIAN_POINT('',(-0.,0.));
#1892 = VECTOR('',#1893,1.);
#1893 = DIRECTION('',(-0.,1.));
#1894 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1895 = ORIENTED_EDGE('',*,*,#1896,.F.);
#1896 = EDGE_CURVE('',#1897,#1874,#1899,.T.);
#1897 = VERTEX_POINT('',#1898);
#1898 = CARTESIAN_POINT('',(3.999999978063,-0.1,1.499999997916));
#1899 = SURFACE_CURVE('',#1900,(#1904,#1911),.PCURVE_S1.);
#1900 = LINE('',#1901,#1902);
#1901 = CARTESIAN_POINT('',(3.999999978063,3.3E-16,1.499999997916));
#1902 = VECTOR('',#1903,1.);
#1903 = DIRECTION('',(0.,-1.,0.));
#1904 = PCURVE('',#1302,#1905);
#1905 = DEFINITIONAL_REPRESENTATION('',(#1906),#1910);
#1906 = LINE('',#1907,#1908);
#1907 = CARTESIAN_POINT('',(4.999986336537,0.));
#1908 = VECTOR('',#1909,1.);
#1909 = DIRECTION('',(2.2E-16,-1.));
#1910 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1911 = PCURVE('',#1912,#1917);
#1912 = CYLINDRICAL_SURFACE('',#1913,1.5);
#1913 = AXIS2_PLACEMENT_3D('',#1914,#1915,#1916);
#1914 = CARTESIAN_POINT('',(2.499999978063,3.3E-16,1.5));
#1915 = DIRECTION('',(0.,1.,-2.2E-16));
#1916 = DIRECTION('',(1.,0.,0.));
#1917 = DEFINITIONAL_REPRESENTATION('',(#1918),#1922);
#1918 = LINE('',#1919,#1920);
#1919 = CARTESIAN_POINT('',(-6.28318530579,0.));
#1920 = VECTOR('',#1921,1.);
#1921 = DIRECTION('',(-0.,-1.));
#1922 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1923 = ORIENTED_EDGE('',*,*,#1924,.T.);
#1924 = EDGE_CURVE('',#1897,#1285,#1925,.T.);
#1925 = SURFACE_CURVE('',#1926,(#1930,#1937),.PCURVE_S1.);
#1926 = LINE('',#1927,#1928);
#1927 = CARTESIAN_POINT('',(3.999999978063,-1.E-01,1.499999997916));
#1928 = VECTOR('',#1929,1.);
#1929 = DIRECTION('',(0.,2.2E-16,1.));
#1930 = PCURVE('',#1302,#1931);
#1931 = DEFINITIONAL_REPRESENTATION('',(#1932),#1936);
#1932 = LINE('',#1933,#1934);
#1933 = CARTESIAN_POINT('',(4.999986336536,-1.E-01));
#1934 = VECTOR('',#1935,1.);
#1935 = DIRECTION('',(-1.,-0.));
#1936 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1937 = PCURVE('',#1488,#1938);
#1938 = DEFINITIONAL_REPRESENTATION('',(#1939),#1943);
#1939 = LINE('',#1940,#1941);
#1940 = CARTESIAN_POINT('',(0.,0.));
#1941 = VECTOR('',#1942,1.);
#1942 = DIRECTION('',(0.,1.));
#1943 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1944 = ADVANCED_FACE('',(#1945),#1403,.T.);
#1945 = FACE_BOUND('',#1946,.F.);
#1946 = EDGE_LOOP('',(#1947,#1948,#1949,#1969));
#1947 = ORIENTED_EDGE('',*,*,#1528,.F.);
#1948 = ORIENTED_EDGE('',*,*,#1795,.T.);
#1949 = ORIENTED_EDGE('',*,*,#1950,.T.);
#1950 = EDGE_CURVE('',#1768,#1387,#1951,.T.);
#1951 = SURFACE_CURVE('',#1952,(#1957,#1963),.PCURVE_S1.);
#1952 = CIRCLE('',#1953,0.1);
#1953 = AXIS2_PLACEMENT_3D('',#1954,#1955,#1956);
#1954 = CARTESIAN_POINT('',(-2.500000007043,-1.E-01,0.1));
#1955 = DIRECTION('',(1.,0.,-5.03068989E-09));
#1956 = DIRECTION('',(-5.03068989E-09,-2.2E-16,-1.));
#1957 = PCURVE('',#1403,#1958);
#1958 = DEFINITIONAL_REPRESENTATION('',(#1959),#1962);
#1959 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1960,#1961),.UNSPECIFIED.,.F.,
#1960 = CARTESIAN_POINT('',(-1.570787175355,0.));
#1961 = CARTESIAN_POINT('',(-1.570787175355,1.570796326795));
#1962 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1963 = PCURVE('',#1431,#1964);
#1964 = DEFINITIONAL_REPRESENTATION('',(#1965),#1968);
#1965 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1966,#1967),.UNSPECIFIED.,.F.,
#1966 = CARTESIAN_POINT('',(0.,0.));
#1967 = CARTESIAN_POINT('',(1.570796326795,0.));
#1968 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1969 = ORIENTED_EDGE('',*,*,#1386,.F.);
#1970 = ADVANCED_FACE('',(#1971),#1488,.T.);
#1971 = FACE_BOUND('',#1972,.T.);
#1972 = EDGE_LOOP('',(#1973,#1993,#1994,#1995));
#1973 = ORIENTED_EDGE('',*,*,#1974,.T.);
#1974 = EDGE_CURVE('',#1897,#1444,#1975,.T.);
#1975 = SURFACE_CURVE('',#1976,(#1981,#1987),.PCURVE_S1.);
#1976 = CIRCLE('',#1977,0.1);
#1977 = AXIS2_PLACEMENT_3D('',#1978,#1979,#1980);
#1978 = CARTESIAN_POINT('',(3.899999978063,-1.E-01,1.499999998055));
#1979 = DIRECTION('',(1.38958658E-09,2.2E-16,1.));
#1980 = DIRECTION('',(1.,0.,-1.38958658E-09));
#1981 = PCURVE('',#1488,#1982);
#1982 = DEFINITIONAL_REPRESENTATION('',(#1983),#1986);
#1983 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1984,#1985),.UNSPECIFIED.,.F.,
#1984 = CARTESIAN_POINT('',(0.,-1.9009E-13));
#1985 = CARTESIAN_POINT('',(1.570796326795,-1.9009E-13));
#1986 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1987 = PCURVE('',#1460,#1988);
#1988 = DEFINITIONAL_REPRESENTATION('',(#1989),#1992);
#1989 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#1990,#1991),.UNSPECIFIED.,.F.,
#1990 = CARTESIAN_POINT('',(-1.570796315812,0.));
#1991 = CARTESIAN_POINT('',(-1.570796315812,1.570796326795));
#1992 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#1993 = ORIENTED_EDGE('',*,*,#1472,.T.);
#1994 = ORIENTED_EDGE('',*,*,#1820,.F.);
#1995 = ORIENTED_EDGE('',*,*,#1924,.F.);
#1996 = ADVANCED_FACE('',(#1997),#1431,.T.);
#1997 = FACE_BOUND('',#1998,.T.);
#1998 = EDGE_LOOP('',(#1999,#2000,#2001,#2023));
#1999 = ORIENTED_EDGE('',*,*,#1950,.T.);
#2000 = ORIENTED_EDGE('',*,*,#1415,.T.);
#2001 = ORIENTED_EDGE('',*,*,#2002,.F.);
#2002 = EDGE_CURVE('',#2003,#1416,#2005,.T.);
#2003 = VERTEX_POINT('',#2004);
#2004 = CARTESIAN_POINT('',(2.499999992453,-0.1,0.));
#2005 = SURFACE_CURVE('',#2006,(#2011,#2017),.PCURVE_S1.);
#2006 = CIRCLE('',#2007,0.1);
#2007 = AXIS2_PLACEMENT_3D('',#2008,#2009,#2010);
#2008 = CARTESIAN_POINT('',(2.499999992453,-1.E-01,0.1));
#2009 = DIRECTION('',(1.,-0.,0.));
#2010 = DIRECTION('',(0.,0.,-1.));
#2011 = PCURVE('',#1431,#2012);
#2012 = DEFINITIONAL_REPRESENTATION('',(#2013),#2016);
#2013 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#2014,#2015),.UNSPECIFIED.,.F.,
#2014 = CARTESIAN_POINT('',(0.,4.999999999999));
#2015 = CARTESIAN_POINT('',(1.570796326795,4.999999999999));
#2016 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2017 = PCURVE('',#1460,#2018);
#2018 = DEFINITIONAL_REPRESENTATION('',(#2019),#2022);
#2019 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#2020,#2021),.UNSPECIFIED.,.F.,
#2020 = CARTESIAN_POINT('',(0.,0.));
#2021 = CARTESIAN_POINT('',(0.,1.570796326795));
#2022 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2023 = ORIENTED_EDGE('',*,*,#2024,.F.);
#2024 = EDGE_CURVE('',#1768,#2003,#2025,.T.);
#2025 = SURFACE_CURVE('',#2026,(#2030,#2037),.PCURVE_S1.);
#2026 = LINE('',#2027,#2028);
#2027 = CARTESIAN_POINT('',(-2.500000007546,-1.E-01,1.E-17));
#2028 = VECTOR('',#2029,1.);
#2029 = DIRECTION('',(1.,0.,0.));
#2030 = PCURVE('',#1431,#2031);
#2031 = DEFINITIONAL_REPRESENTATION('',(#2032),#2036);
#2032 = LINE('',#2033,#2034);
#2033 = CARTESIAN_POINT('',(0.,0.));
#2034 = VECTOR('',#2035,1.);
#2035 = DIRECTION('',(0.,1.));
#2036 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2037 = PCURVE('',#1783,#2038);
#2038 = DEFINITIONAL_REPRESENTATION('',(#2039),#2043);
#2039 = LINE('',#2040,#2041);
#2040 = CARTESIAN_POINT('',(0.,-1.E-01));
#2041 = VECTOR('',#2042,1.);
#2042 = DIRECTION('',(1.,0.));
#2043 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2044 = ADVANCED_FACE('',(#2045),#1460,.T.);
#2045 = FACE_BOUND('',#2046,.F.);
#2046 = EDGE_LOOP('',(#2047,#2048,#2070,#2071));
#2047 = ORIENTED_EDGE('',*,*,#2002,.F.);
#2048 = ORIENTED_EDGE('',*,*,#2049,.T.);
#2049 = EDGE_CURVE('',#2003,#1897,#2050,.T.);
#2050 = SURFACE_CURVE('',#2051,(#2056,#2063),.PCURVE_S1.);
#2051 = CIRCLE('',#2052,1.5);
#2052 = AXIS2_PLACEMENT_3D('',#2053,#2054,#2055);
#2053 = CARTESIAN_POINT('',(2.499999978063,-1.E-01,1.5));
#2054 = DIRECTION('',(0.,-1.,2.2E-16));
#2055 = DIRECTION('',(9.59330985E-09,-2.2E-16,-1.));
#2056 = PCURVE('',#1460,#2057);
#2057 = DEFINITIONAL_REPRESENTATION('',(#2058),#2062);
#2058 = LINE('',#2059,#2060);
#2059 = CARTESIAN_POINT('',(-0.,0.));
#2060 = VECTOR('',#2061,1.);
#2061 = DIRECTION('',(-1.,0.));
#2062 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2063 = PCURVE('',#1912,#2064);
#2064 = DEFINITIONAL_REPRESENTATION('',(#2065),#2069);
#2065 = LINE('',#2066,#2067);
#2066 = CARTESIAN_POINT('',(-4.712388989978,-0.1));
#2067 = VECTOR('',#2068,1.);
#2068 = DIRECTION('',(-1.,0.));
#2069 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2070 = ORIENTED_EDGE('',*,*,#1974,.T.);
#2071 = ORIENTED_EDGE('',*,*,#1443,.F.);
#2072 = ADVANCED_FACE('',(#2073),#1593,.T.);
#2073 = FACE_BOUND('',#2074,.T.);
#2074 = EDGE_LOOP('',(#2075,#2076,#2077,#2097));
#2075 = ORIENTED_EDGE('',*,*,#1718,.F.);
#2076 = ORIENTED_EDGE('',*,*,#1743,.T.);
#2077 = ORIENTED_EDGE('',*,*,#2078,.T.);
#2078 = EDGE_CURVE('',#1744,#1577,#2079,.T.);
#2079 = SURFACE_CURVE('',#2080,(#2085,#2091),.PCURVE_S1.);
#2080 = CIRCLE('',#2081,0.1);
#2081 = AXIS2_PLACEMENT_3D('',#2082,#2083,#2084);
#2082 = CARTESIAN_POINT('',(-2.500000007043,-15.9,0.1));
#2083 = DIRECTION('',(-1.,0.,5.03068971E-09));
#2084 = DIRECTION('',(-5.03068971E-09,-2.2E-16,-1.));
#2085 = PCURVE('',#1593,#2086);
#2086 = DEFINITIONAL_REPRESENTATION('',(#2087),#2090);
#2087 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#2088,#2089),.UNSPECIFIED.,.F.,
#2088 = CARTESIAN_POINT('',(1.570787175355,0.));
#2089 = CARTESIAN_POINT('',(1.570787175355,1.570796326795));
#2090 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2091 = PCURVE('',#1621,#2092);
#2092 = DEFINITIONAL_REPRESENTATION('',(#2093),#2096);
#2093 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#2094,#2095),.UNSPECIFIED.,.F.,
#2094 = CARTESIAN_POINT('',(0.,0.));
#2095 = CARTESIAN_POINT('',(-1.570796326795,0.));
#2096 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2097 = ORIENTED_EDGE('',*,*,#1576,.F.);
#2098 = ADVANCED_FACE('',(#2099),#1678,.T.);
#2099 = FACE_BOUND('',#2100,.F.);
#2100 = EDGE_LOOP('',(#2101,#2121,#2122,#2123));
#2101 = ORIENTED_EDGE('',*,*,#2102,.T.);
#2102 = EDGE_CURVE('',#1874,#1634,#2103,.T.);
#2103 = SURFACE_CURVE('',#2104,(#2109,#2115),.PCURVE_S1.);
#2104 = CIRCLE('',#2105,0.1);
#2105 = AXIS2_PLACEMENT_3D('',#2106,#2107,#2108);
#2106 = CARTESIAN_POINT('',(3.899999978063,-15.9,1.499999998055));
#2107 = DIRECTION('',(-1.38958658E-09,-2.2E-16,-1.));
#2108 = DIRECTION('',(1.,0.,-1.38958658E-09));
#2109 = PCURVE('',#1678,#2110);
#2110 = DEFINITIONAL_REPRESENTATION('',(#2111),#2114);
#2111 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#2112,#2113),.UNSPECIFIED.,.F.,
#2112 = CARTESIAN_POINT('',(0.,-1.9005E-13));
#2113 = CARTESIAN_POINT('',(-1.570796326795,-1.9005E-13));
#2114 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2115 = PCURVE('',#1650,#2116);
#2116 = DEFINITIONAL_REPRESENTATION('',(#2117),#2120);
#2117 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#2118,#2119),.UNSPECIFIED.,.F.,
#2118 = CARTESIAN_POINT('',(1.570796315812,0.));
#2119 = CARTESIAN_POINT('',(1.570796315812,1.570796326795));
#2120 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2121 = ORIENTED_EDGE('',*,*,#1662,.T.);
#2122 = ORIENTED_EDGE('',*,*,#1846,.F.);
#2123 = ORIENTED_EDGE('',*,*,#1873,.F.);
#2124 = ADVANCED_FACE('',(#2125),#1621,.T.);
#2125 = FACE_BOUND('',#2126,.F.);
#2126 = EDGE_LOOP('',(#2127,#2128,#2129,#2151));
#2127 = ORIENTED_EDGE('',*,*,#2078,.T.);
#2128 = ORIENTED_EDGE('',*,*,#1605,.T.);
#2129 = ORIENTED_EDGE('',*,*,#2130,.F.);
#2130 = EDGE_CURVE('',#2131,#1606,#2133,.T.);
#2131 = VERTEX_POINT('',#2132);
#2132 = CARTESIAN_POINT('',(2.499999992453,-15.9,0.));
#2133 = SURFACE_CURVE('',#2134,(#2139,#2145),.PCURVE_S1.);
#2134 = CIRCLE('',#2135,0.1);
#2135 = AXIS2_PLACEMENT_3D('',#2136,#2137,#2138);
#2136 = CARTESIAN_POINT('',(2.499999992453,-15.9,0.1));
#2137 = DIRECTION('',(-1.,-0.,-0.));
#2138 = DIRECTION('',(0.,0.,-1.));
#2139 = PCURVE('',#1621,#2140);
#2140 = DEFINITIONAL_REPRESENTATION('',(#2141),#2144);
#2141 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#2142,#2143),.UNSPECIFIED.,.F.,
#2142 = CARTESIAN_POINT('',(0.,4.999999999999));
#2143 = CARTESIAN_POINT('',(-1.570796326795,4.999999999999));
#2144 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2145 = PCURVE('',#1650,#2146);
#2146 = DEFINITIONAL_REPRESENTATION('',(#2147),#2150);
#2147 = B_SPLINE_CURVE_WITH_KNOTS('',1,(#2148,#2149),.UNSPECIFIED.,.F.,
#2148 = CARTESIAN_POINT('',(0.,0.));
#2149 = CARTESIAN_POINT('',(0.,1.570796326795));
#2150 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2151 = ORIENTED_EDGE('',*,*,#2152,.F.);
#2152 = EDGE_CURVE('',#1744,#2131,#2153,.T.);
#2153 = SURFACE_CURVE('',#2154,(#2158,#2165),.PCURVE_S1.);
#2154 = LINE('',#2155,#2156);
#2155 = CARTESIAN_POINT('',(-2.500000007546,-15.9,0.));
#2156 = VECTOR('',#2157,1.);
#2157 = DIRECTION('',(1.,0.,0.));
#2158 = PCURVE('',#1621,#2159);
#2159 = DEFINITIONAL_REPRESENTATION('',(#2160),#2164);
#2160 = LINE('',#2161,#2162);
#2161 = CARTESIAN_POINT('',(-0.,0.));
#2162 = VECTOR('',#2163,1.);
#2163 = DIRECTION('',(-0.,1.));
#2164 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2165 = PCURVE('',#1783,#2166);
#2166 = DEFINITIONAL_REPRESENTATION('',(#2167),#2171);
#2167 = LINE('',#2168,#2169);
#2168 = CARTESIAN_POINT('',(0.,-15.9));
#2169 = VECTOR('',#2170,1.);
#2170 = DIRECTION('',(1.,0.));
#2171 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2172 = ADVANCED_FACE('',(#2173),#1650,.T.);
#2173 = FACE_BOUND('',#2174,.T.);
#2174 = EDGE_LOOP('',(#2175,#2176,#2198,#2199));
#2175 = ORIENTED_EDGE('',*,*,#2130,.F.);
#2176 = ORIENTED_EDGE('',*,*,#2177,.T.);
#2177 = EDGE_CURVE('',#2131,#1874,#2178,.T.);
#2178 = SURFACE_CURVE('',#2179,(#2184,#2191),.PCURVE_S1.);
#2179 = CIRCLE('',#2180,1.5);
#2180 = AXIS2_PLACEMENT_3D('',#2181,#2182,#2183);
#2181 = CARTESIAN_POINT('',(2.499999978063,-15.9,1.5));
#2182 = DIRECTION('',(0.,-1.,2.2E-16));
#2183 = DIRECTION('',(9.59330985E-09,-2.2E-16,-1.));
#2184 = PCURVE('',#1650,#2185);
#2185 = DEFINITIONAL_REPRESENTATION('',(#2186),#2190);
#2186 = LINE('',#2187,#2188);
#2187 = CARTESIAN_POINT('',(0.,0.));
#2188 = VECTOR('',#2189,1.);
#2189 = DIRECTION('',(1.,0.));
#2190 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2191 = PCURVE('',#1912,#2192);
#2192 = DEFINITIONAL_REPRESENTATION('',(#2193),#2197);
#2193 = LINE('',#2194,#2195);
#2194 = CARTESIAN_POINT('',(-4.712388989978,-15.9));
#2195 = VECTOR('',#2196,1.);
#2196 = DIRECTION('',(-1.,0.));
#2197 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2198 = ORIENTED_EDGE('',*,*,#2102,.T.);
#2199 = ORIENTED_EDGE('',*,*,#1633,.F.);
#2200 = ADVANCED_FACE('',(#2201),#1783,.F.);
#2201 = FACE_BOUND('',#2202,.F.);
#2202 = EDGE_LOOP('',(#2203,#2204,#2205,#2226));
#2203 = ORIENTED_EDGE('',*,*,#1767,.T.);
#2204 = ORIENTED_EDGE('',*,*,#2152,.T.);
#2205 = ORIENTED_EDGE('',*,*,#2206,.F.);
#2206 = EDGE_CURVE('',#2003,#2131,#2207,.T.);
#2207 = SURFACE_CURVE('',#2208,(#2212,#2219),.PCURVE_S1.);
#2208 = LINE('',#2209,#2210);
#2209 = CARTESIAN_POINT('',(2.499999992453,0.,0.));
#2210 = VECTOR('',#2211,1.);
#2211 = DIRECTION('',(0.,-1.,0.));
#2212 = PCURVE('',#1783,#2213);
#2213 = DEFINITIONAL_REPRESENTATION('',(#2214),#2218);
#2214 = LINE('',#2215,#2216);
#2215 = CARTESIAN_POINT('',(4.999999999999,0.));
#2216 = VECTOR('',#2217,1.);
#2217 = DIRECTION('',(0.,-1.));
#2218 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2219 = PCURVE('',#1912,#2220);
#2220 = DEFINITIONAL_REPRESENTATION('',(#2221),#2225);
#2221 = LINE('',#2222,#2223);
#2222 = CARTESIAN_POINT('',(-4.712388989978,0.));
#2223 = VECTOR('',#2224,1.);
#2224 = DIRECTION('',(-0.,-1.));
#2225 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2226 = ORIENTED_EDGE('',*,*,#2024,.F.);
#2227 = ADVANCED_FACE('',(#2228),#1912,.T.);
#2228 = FACE_BOUND('',#2229,.F.);
#2229 = EDGE_LOOP('',(#2230,#2231,#2232,#2233));
#2230 = ORIENTED_EDGE('',*,*,#2206,.T.);
#2231 = ORIENTED_EDGE('',*,*,#2177,.T.);
#2232 = ORIENTED_EDGE('',*,*,#1896,.F.);
#2233 = ORIENTED_EDGE('',*,*,#2049,.F.);
#2234 = MANIFOLD_SOLID_BREP('',#2235);
#2235 = CLOSED_SHELL('',(#2236,#2362,#2440,#2518,#2594,#2670,#2746,#2822
,#2898,#2974,#3050,#3128,#3206,#3284,#3362,#3440,#3518,#3596,#3672,
#3750,#3828,#3906,#3977,#4024,#4050));
#2236 = ADVANCED_FACE('',(#2237),#2251,.T.);
#2237 = FACE_BOUND('',#2238,.T.);
#2238 = EDGE_LOOP('',(#2239,#2278,#2306,#2336));
#2239 = ORIENTED_EDGE('',*,*,#2240,.T.);
#2240 = EDGE_CURVE('',#2241,#2243,#2245,.T.);
#2241 = VERTEX_POINT('',#2242);
#2242 = CARTESIAN_POINT('',(-0.471,-1.009,8.));
#2243 = VERTEX_POINT('',#2244);
#2244 = CARTESIAN_POINT('',(-0.471,-1.009,8.2));
#2245 = SURFACE_CURVE('',#2246,(#2250,#2264),.PCURVE_S1.);
#2246 = LINE('',#2247,#2248);
#2247 = CARTESIAN_POINT('',(-0.471,-1.009,8.));
#2248 = VECTOR('',#2249,1.);
#2249 = DIRECTION('',(0.,0.,1.));
#2250 = PCURVE('',#2251,#2258);
#2251 = SURFACE_OF_LINEAR_EXTRUSION('',#2252,#2256);
#2252 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2253,#2254,#2255),
.UNSPECIFIED.,.F.,.F.,(3,3),(0.,1.),.PIECEWISE_BEZIER_KNOTS.);
#2253 = CARTESIAN_POINT('',(-0.471,-1.009,8.));
#2254 = CARTESIAN_POINT('',(-0.873,-1.009,8.));
#2255 = CARTESIAN_POINT('',(-1.136,-1.212,8.));
#2256 = VECTOR('',#2257,1.);
#2257 = DIRECTION('',(-0.,-0.,-1.));
#2258 = DEFINITIONAL_REPRESENTATION('',(#2259),#2263);
#2259 = LINE('',#2260,#2261);
#2260 = CARTESIAN_POINT('',(0.,0.));
#2261 = VECTOR('',#2262,1.);
#2262 = DIRECTION('',(0.,-1.));
#2263 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2264 = PCURVE('',#2265,#2272);
#2265 = SURFACE_OF_LINEAR_EXTRUSION('',#2266,#2270);
#2266 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2267,#2268,#2269),
#2267 = CARTESIAN_POINT('',(0.126,-1.172,8.));
#2268 = CARTESIAN_POINT('',(-0.118,-1.009,8.));
#2269 = CARTESIAN_POINT('',(-0.471,-1.009,8.));
#2270 = VECTOR('',#2271,1.);
#2271 = DIRECTION('',(-0.,-0.,-1.));
#2272 = DEFINITIONAL_REPRESENTATION('',(#2273),#2277);
#2273 = LINE('',#2274,#2275);
#2274 = CARTESIAN_POINT('',(1.,0.));
#2275 = VECTOR('',#2276,1.);
#2276 = DIRECTION('',(0.,-1.));
#2277 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2278 = ORIENTED_EDGE('',*,*,#2279,.T.);
#2279 = EDGE_CURVE('',#2243,#2280,#2282,.T.);
#2280 = VERTEX_POINT('',#2281);
#2281 = CARTESIAN_POINT('',(-1.136,-1.212,8.2));
#2282 = SURFACE_CURVE('',#2283,(#2287,#2294),.PCURVE_S1.);
#2283 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2284,#2285,#2286),
#2284 = CARTESIAN_POINT('',(-0.471,-1.009,8.2));
#2285 = CARTESIAN_POINT('',(-0.873,-1.009,8.2));
#2286 = CARTESIAN_POINT('',(-1.136,-1.212,8.2));
#2287 = PCURVE('',#2251,#2288);
#2288 = DEFINITIONAL_REPRESENTATION('',(#2289),#2293);
#2289 = LINE('',#2290,#2291);
#2290 = CARTESIAN_POINT('',(0.,-0.2));
#2291 = VECTOR('',#2292,1.);
#2292 = DIRECTION('',(1.,0.));
#2293 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2294 = PCURVE('',#2295,#2300);
#2295 = PLANE('',#2296);
#2296 = AXIS2_PLACEMENT_3D('',#2297,#2298,#2299);
#2297 = CARTESIAN_POINT('',(-0.528339117954,-1.819638447779,8.2));
#2298 = DIRECTION('',(-0.,0.,-1.));
#2299 = DIRECTION('',(0.,1.,0.));
#2300 = DEFINITIONAL_REPRESENTATION('',(#2301),#2305);
#2301 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2302,#2303,#2304),
#2302 = CARTESIAN_POINT('',(0.810638447779,5.733911795393E-02));
#2303 = CARTESIAN_POINT('',(0.810638447779,-0.344660882046));
#2304 = CARTESIAN_POINT('',(0.607638447779,-0.607660882046));
#2305 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2306 = ORIENTED_EDGE('',*,*,#2307,.F.);
#2307 = EDGE_CURVE('',#2308,#2280,#2310,.T.);
#2308 = VERTEX_POINT('',#2309);
#2309 = CARTESIAN_POINT('',(-1.136,-1.212,8.));
#2310 = SURFACE_CURVE('',#2311,(#2315,#2322),.PCURVE_S1.);
#2311 = LINE('',#2312,#2313);
#2312 = CARTESIAN_POINT('',(-1.136,-1.212,8.));
#2313 = VECTOR('',#2314,1.);
#2314 = DIRECTION('',(0.,0.,1.));
#2315 = PCURVE('',#2251,#2316);
#2316 = DEFINITIONAL_REPRESENTATION('',(#2317),#2321);
#2317 = LINE('',#2318,#2319);
#2318 = CARTESIAN_POINT('',(1.,0.));
#2319 = VECTOR('',#2320,1.);
#2320 = DIRECTION('',(0.,-1.));
#2321 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2322 = PCURVE('',#2323,#2330);
#2323 = SURFACE_OF_LINEAR_EXTRUSION('',#2324,#2328);
#2324 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2325,#2326,#2327),
#2325 = CARTESIAN_POINT('',(-1.136,-1.212,8.));
#2326 = CARTESIAN_POINT('',(-1.408,-1.423,8.));
#2327 = CARTESIAN_POINT('',(-1.408,-1.81,8.));
#2328 = VECTOR('',#2329,1.);
#2329 = DIRECTION('',(-0.,-0.,-1.));
#2330 = DEFINITIONAL_REPRESENTATION('',(#2331),#2335);
#2331 = LINE('',#2332,#2333);
#2332 = CARTESIAN_POINT('',(0.,0.));
#2333 = VECTOR('',#2334,1.);
#2334 = DIRECTION('',(0.,-1.));
#2335 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2336 = ORIENTED_EDGE('',*,*,#2337,.F.);
#2337 = EDGE_CURVE('',#2241,#2308,#2338,.T.);
#2338 = SURFACE_CURVE('',#2339,(#2343,#2350),.PCURVE_S1.);
#2339 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2340,#2341,#2342),
#2340 = CARTESIAN_POINT('',(-0.471,-1.009,8.));
#2341 = CARTESIAN_POINT('',(-0.873,-1.009,8.));
#2342 = CARTESIAN_POINT('',(-1.136,-1.212,8.));
#2343 = PCURVE('',#2251,#2344);
#2344 = DEFINITIONAL_REPRESENTATION('',(#2345),#2349);
#2345 = LINE('',#2346,#2347);
#2346 = CARTESIAN_POINT('',(0.,0.));
#2347 = VECTOR('',#2348,1.);
#2348 = DIRECTION('',(1.,0.));
#2349 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2350 = PCURVE('',#2351,#2356);
#2351 = PLANE('',#2352);
#2352 = AXIS2_PLACEMENT_3D('',#2353,#2354,#2355);
#2353 = CARTESIAN_POINT('',(-0.528339117954,-1.819638447779,8.));
#2354 = DIRECTION('',(-0.,0.,-1.));
#2355 = DIRECTION('',(0.,1.,0.));
#2356 = DEFINITIONAL_REPRESENTATION('',(#2357),#2361);
#2357 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2358,#2359,#2360),
#2358 = CARTESIAN_POINT('',(0.810638447779,5.733911795393E-02));
#2359 = CARTESIAN_POINT('',(0.810638447779,-0.344660882046));
#2360 = CARTESIAN_POINT('',(0.607638447779,-0.607660882046));
#2361 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2362 = ADVANCED_FACE('',(#2363),#2323,.T.);
#2363 = FACE_BOUND('',#2364,.T.);
#2364 = EDGE_LOOP('',(#2365,#2366,#2389,#2419));
#2365 = ORIENTED_EDGE('',*,*,#2307,.T.);
#2366 = ORIENTED_EDGE('',*,*,#2367,.T.);
#2367 = EDGE_CURVE('',#2280,#2368,#2370,.T.);
#2368 = VERTEX_POINT('',#2369);
#2369 = CARTESIAN_POINT('',(-1.408,-1.81,8.2));
#2370 = SURFACE_CURVE('',#2371,(#2375,#2382),.PCURVE_S1.);
#2371 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2372,#2373,#2374),
#2372 = CARTESIAN_POINT('',(-1.136,-1.212,8.2));
#2373 = CARTESIAN_POINT('',(-1.408,-1.423,8.2));
#2374 = CARTESIAN_POINT('',(-1.408,-1.81,8.2));
#2375 = PCURVE('',#2323,#2376);
#2376 = DEFINITIONAL_REPRESENTATION('',(#2377),#2381);
#2377 = LINE('',#2378,#2379);
#2378 = CARTESIAN_POINT('',(0.,-0.2));
#2379 = VECTOR('',#2380,1.);
#2380 = DIRECTION('',(1.,0.));
#2381 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2382 = PCURVE('',#2295,#2383);
#2383 = DEFINITIONAL_REPRESENTATION('',(#2384),#2388);
#2384 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2385,#2386,#2387),
#2385 = CARTESIAN_POINT('',(0.607638447779,-0.607660882046));
#2386 = CARTESIAN_POINT('',(0.396638447779,-0.879660882046));
#2387 = CARTESIAN_POINT('',(9.638447779179E-03,-0.879660882046));
#2388 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2389 = ORIENTED_EDGE('',*,*,#2390,.F.);
#2390 = EDGE_CURVE('',#2391,#2368,#2393,.T.);
#2391 = VERTEX_POINT('',#2392);
#2392 = CARTESIAN_POINT('',(-1.408,-1.81,8.));
#2393 = SURFACE_CURVE('',#2394,(#2398,#2405),.PCURVE_S1.);
#2394 = LINE('',#2395,#2396);
#2395 = CARTESIAN_POINT('',(-1.408,-1.81,8.));
#2396 = VECTOR('',#2397,1.);
#2397 = DIRECTION('',(0.,0.,1.));
#2398 = PCURVE('',#2323,#2399);
#2399 = DEFINITIONAL_REPRESENTATION('',(#2400),#2404);
#2400 = LINE('',#2401,#2402);
#2401 = CARTESIAN_POINT('',(1.,0.));
#2402 = VECTOR('',#2403,1.);
#2403 = DIRECTION('',(0.,-1.));
#2404 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2405 = PCURVE('',#2406,#2413);
#2406 = SURFACE_OF_LINEAR_EXTRUSION('',#2407,#2411);
#2407 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2408,#2409,#2410),
#2408 = CARTESIAN_POINT('',(-1.408,-1.81,8.));
#2409 = CARTESIAN_POINT('',(-1.408,-2.16,8.));
#2410 = CARTESIAN_POINT('',(-1.156,-2.363,8.));
#2411 = VECTOR('',#2412,1.);
#2412 = DIRECTION('',(-0.,-0.,-1.));
#2413 = DEFINITIONAL_REPRESENTATION('',(#2414),#2418);
#2414 = LINE('',#2415,#2416);
#2415 = CARTESIAN_POINT('',(0.,0.));
#2416 = VECTOR('',#2417,1.);
#2417 = DIRECTION('',(0.,-1.));
#2418 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2419 = ORIENTED_EDGE('',*,*,#2420,.F.);
#2420 = EDGE_CURVE('',#2308,#2391,#2421,.T.);
#2421 = SURFACE_CURVE('',#2422,(#2426,#2433),.PCURVE_S1.);
#2422 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2423,#2424,#2425),
#2423 = CARTESIAN_POINT('',(-1.136,-1.212,8.));
#2424 = CARTESIAN_POINT('',(-1.408,-1.423,8.));
#2425 = CARTESIAN_POINT('',(-1.408,-1.81,8.));
#2426 = PCURVE('',#2323,#2427);
#2427 = DEFINITIONAL_REPRESENTATION('',(#2428),#2432);
#2428 = LINE('',#2429,#2430);
#2429 = CARTESIAN_POINT('',(0.,0.));
#2430 = VECTOR('',#2431,1.);
#2431 = DIRECTION('',(1.,0.));
#2432 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2433 = PCURVE('',#2351,#2434);
#2434 = DEFINITIONAL_REPRESENTATION('',(#2435),#2439);
#2435 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2436,#2437,#2438),
#2436 = CARTESIAN_POINT('',(0.607638447779,-0.607660882046));
#2437 = CARTESIAN_POINT('',(0.396638447779,-0.879660882046));
#2438 = CARTESIAN_POINT('',(9.638447779179E-03,-0.879660882046));
#2439 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2440 = ADVANCED_FACE('',(#2441),#2406,.T.);
#2441 = FACE_BOUND('',#2442,.T.);
#2442 = EDGE_LOOP('',(#2443,#2444,#2467,#2497));
#2443 = ORIENTED_EDGE('',*,*,#2390,.T.);
#2444 = ORIENTED_EDGE('',*,*,#2445,.T.);
#2445 = EDGE_CURVE('',#2368,#2446,#2448,.T.);
#2446 = VERTEX_POINT('',#2447);
#2447 = CARTESIAN_POINT('',(-1.156,-2.363,8.2));
#2448 = SURFACE_CURVE('',#2449,(#2453,#2460),.PCURVE_S1.);
#2449 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2450,#2451,#2452),
#2450 = CARTESIAN_POINT('',(-1.408,-1.81,8.2));
#2451 = CARTESIAN_POINT('',(-1.408,-2.16,8.2));
#2452 = CARTESIAN_POINT('',(-1.156,-2.363,8.2));
#2453 = PCURVE('',#2406,#2454);
#2454 = DEFINITIONAL_REPRESENTATION('',(#2455),#2459);
#2455 = LINE('',#2456,#2457);
#2456 = CARTESIAN_POINT('',(0.,-0.2));
#2457 = VECTOR('',#2458,1.);
#2458 = DIRECTION('',(1.,0.));
#2459 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2460 = PCURVE('',#2295,#2461);
#2461 = DEFINITIONAL_REPRESENTATION('',(#2462),#2466);
#2462 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2463,#2464,#2465),
#2463 = CARTESIAN_POINT('',(9.638447779179E-03,-0.879660882046));
#2464 = CARTESIAN_POINT('',(-0.340361552221,-0.879660882046));
#2465 = CARTESIAN_POINT('',(-0.543361552221,-0.627660882046));
#2466 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2467 = ORIENTED_EDGE('',*,*,#2468,.F.);
#2468 = EDGE_CURVE('',#2469,#2446,#2471,.T.);
#2469 = VERTEX_POINT('',#2470);
#2470 = CARTESIAN_POINT('',(-1.156,-2.363,8.));
#2471 = SURFACE_CURVE('',#2472,(#2476,#2483),.PCURVE_S1.);
#2472 = LINE('',#2473,#2474);
#2473 = CARTESIAN_POINT('',(-1.156,-2.363,8.));
#2474 = VECTOR('',#2475,1.);
#2475 = DIRECTION('',(0.,0.,1.));
#2476 = PCURVE('',#2406,#2477);
#2477 = DEFINITIONAL_REPRESENTATION('',(#2478),#2482);
#2478 = LINE('',#2479,#2480);
#2479 = CARTESIAN_POINT('',(1.,0.));
#2480 = VECTOR('',#2481,1.);
#2481 = DIRECTION('',(0.,-1.));
#2482 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2483 = PCURVE('',#2484,#2491);
#2484 = SURFACE_OF_LINEAR_EXTRUSION('',#2485,#2489);
#2485 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2486,#2487,#2488),
#2486 = CARTESIAN_POINT('',(-1.156,-2.363,8.));
#2487 = CARTESIAN_POINT('',(-0.964,-2.514,8.));
#2488 = CARTESIAN_POINT('',(-0.703,-2.514,8.));
#2489 = VECTOR('',#2490,1.);
#2490 = DIRECTION('',(-0.,-0.,-1.));
#2491 = DEFINITIONAL_REPRESENTATION('',(#2492),#2496);
#2492 = LINE('',#2493,#2494);
#2493 = CARTESIAN_POINT('',(0.,0.));
#2494 = VECTOR('',#2495,1.);
#2495 = DIRECTION('',(0.,-1.));
#2496 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2497 = ORIENTED_EDGE('',*,*,#2498,.F.);
#2498 = EDGE_CURVE('',#2391,#2469,#2499,.T.);
#2499 = SURFACE_CURVE('',#2500,(#2504,#2511),.PCURVE_S1.);
#2500 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2501,#2502,#2503),
#2501 = CARTESIAN_POINT('',(-1.408,-1.81,8.));
#2502 = CARTESIAN_POINT('',(-1.408,-2.16,8.));
#2503 = CARTESIAN_POINT('',(-1.156,-2.363,8.));
#2504 = PCURVE('',#2406,#2505);
#2505 = DEFINITIONAL_REPRESENTATION('',(#2506),#2510);
#2506 = LINE('',#2507,#2508);
#2507 = CARTESIAN_POINT('',(0.,0.));
#2508 = VECTOR('',#2509,1.);
#2509 = DIRECTION('',(1.,0.));
#2510 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2511 = PCURVE('',#2351,#2512);
#2512 = DEFINITIONAL_REPRESENTATION('',(#2513),#2517);
#2513 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2514,#2515,#2516),
#2514 = CARTESIAN_POINT('',(9.638447779179E-03,-0.879660882046));
#2515 = CARTESIAN_POINT('',(-0.340361552221,-0.879660882046));
#2516 = CARTESIAN_POINT('',(-0.543361552221,-0.627660882046));
#2517 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2518 = ADVANCED_FACE('',(#2519),#2484,.T.);
#2519 = FACE_BOUND('',#2520,.T.);
#2520 = EDGE_LOOP('',(#2521,#2522,#2545,#2573));
#2521 = ORIENTED_EDGE('',*,*,#2468,.T.);
#2522 = ORIENTED_EDGE('',*,*,#2523,.T.);
#2523 = EDGE_CURVE('',#2446,#2524,#2526,.T.);
#2524 = VERTEX_POINT('',#2525);
#2525 = CARTESIAN_POINT('',(-0.703,-2.514,8.2));
#2526 = SURFACE_CURVE('',#2527,(#2531,#2538),.PCURVE_S1.);
#2527 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2528,#2529,#2530),
#2528 = CARTESIAN_POINT('',(-1.156,-2.363,8.2));
#2529 = CARTESIAN_POINT('',(-0.964,-2.514,8.2));
#2530 = CARTESIAN_POINT('',(-0.703,-2.514,8.2));
#2531 = PCURVE('',#2484,#2532);
#2532 = DEFINITIONAL_REPRESENTATION('',(#2533),#2537);
#2533 = LINE('',#2534,#2535);
#2534 = CARTESIAN_POINT('',(0.,-0.2));
#2535 = VECTOR('',#2536,1.);
#2536 = DIRECTION('',(1.,0.));
#2537 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2538 = PCURVE('',#2295,#2539);
#2539 = DEFINITIONAL_REPRESENTATION('',(#2540),#2544);
#2540 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2541,#2542,#2543),
#2541 = CARTESIAN_POINT('',(-0.543361552221,-0.627660882046));
#2542 = CARTESIAN_POINT('',(-0.694361552221,-0.435660882046));
#2543 = CARTESIAN_POINT('',(-0.694361552221,-0.174660882046));
#2544 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2545 = ORIENTED_EDGE('',*,*,#2546,.F.);
#2546 = EDGE_CURVE('',#2547,#2524,#2549,.T.);
#2547 = VERTEX_POINT('',#2548);
#2548 = CARTESIAN_POINT('',(-0.703,-2.514,8.));
#2549 = SURFACE_CURVE('',#2550,(#2554,#2561),.PCURVE_S1.);
#2550 = LINE('',#2551,#2552);
#2551 = CARTESIAN_POINT('',(-0.703,-2.514,8.));
#2552 = VECTOR('',#2553,1.);
#2553 = DIRECTION('',(0.,0.,1.));
#2554 = PCURVE('',#2484,#2555);
#2555 = DEFINITIONAL_REPRESENTATION('',(#2556),#2560);
#2556 = LINE('',#2557,#2558);
#2557 = CARTESIAN_POINT('',(1.,0.));
#2558 = VECTOR('',#2559,1.);
#2559 = DIRECTION('',(0.,-1.));
#2560 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2561 = PCURVE('',#2562,#2567);
#2562 = PLANE('',#2563);
#2563 = AXIS2_PLACEMENT_3D('',#2564,#2565,#2566);
#2564 = CARTESIAN_POINT('',(-0.703,-2.514,8.));
#2565 = DIRECTION('',(2.2E-16,1.,0.));
#2566 = DIRECTION('',(1.,-2.2E-16,0.));
#2567 = DEFINITIONAL_REPRESENTATION('',(#2568),#2572);
#2568 = LINE('',#2569,#2570);
#2569 = CARTESIAN_POINT('',(-4.4E-16,0.));
#2570 = VECTOR('',#2571,1.);
#2571 = DIRECTION('',(0.,-1.));
#2572 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2573 = ORIENTED_EDGE('',*,*,#2574,.F.);
#2574 = EDGE_CURVE('',#2469,#2547,#2575,.T.);
#2575 = SURFACE_CURVE('',#2576,(#2580,#2587),.PCURVE_S1.);
#2576 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2577,#2578,#2579),
#2577 = CARTESIAN_POINT('',(-1.156,-2.363,8.));
#2578 = CARTESIAN_POINT('',(-0.964,-2.514,8.));
#2579 = CARTESIAN_POINT('',(-0.703,-2.514,8.));
#2580 = PCURVE('',#2484,#2581);
#2581 = DEFINITIONAL_REPRESENTATION('',(#2582),#2586);
#2582 = LINE('',#2583,#2584);
#2583 = CARTESIAN_POINT('',(0.,0.));
#2584 = VECTOR('',#2585,1.);
#2585 = DIRECTION('',(1.,0.));
#2586 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2587 = PCURVE('',#2351,#2588);
#2588 = DEFINITIONAL_REPRESENTATION('',(#2589),#2593);
#2589 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#2590,#2591,#2592),
#2590 = CARTESIAN_POINT('',(-0.543361552221,-0.627660882046));
#2591 = CARTESIAN_POINT('',(-0.694361552221,-0.435660882046));
#2592 = CARTESIAN_POINT('',(-0.694361552221,-0.174660882046));
#2593 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2594 = ADVANCED_FACE('',(#2595),#2562,.T.);
#2595 = FACE_BOUND('',#2596,.T.);
#2596 = EDGE_LOOP('',(#2597,#2598,#2621,#2649));
#2597 = ORIENTED_EDGE('',*,*,#2546,.T.);
#2598 = ORIENTED_EDGE('',*,*,#2599,.T.);
#2599 = EDGE_CURVE('',#2524,#2600,#2602,.T.);
#2600 = VERTEX_POINT('',#2601);
#2601 = CARTESIAN_POINT('',(-0.64,-2.514,8.2));
#2602 = SURFACE_CURVE('',#2603,(#2607,#2614),.PCURVE_S1.);
#2603 = LINE('',#2604,#2605);
#2604 = CARTESIAN_POINT('',(-0.703,-2.514,8.2));
#2605 = VECTOR('',#2606,1.);
#2606 = DIRECTION('',(1.,0.,0.));
#2607 = PCURVE('',#2562,#2608);
#2608 = DEFINITIONAL_REPRESENTATION('',(#2609),#2613);
#2609 = LINE('',#2610,#2611);
#2610 = CARTESIAN_POINT('',(0.,-0.2));
#2611 = VECTOR('',#2612,1.);
#2612 = DIRECTION('',(1.,0.));
#2613 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2614 = PCURVE('',#2295,#2615);
#2615 = DEFINITIONAL_REPRESENTATION('',(#2616),#2620);
#2616 = LINE('',#2617,#2618);
#2617 = CARTESIAN_POINT('',(-0.694361552221,-0.174660882046));
#2618 = VECTOR('',#2619,1.);
#2619 = DIRECTION('',(0.,1.));
#2620 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2621 = ORIENTED_EDGE('',*,*,#2622,.F.);
#2622 = EDGE_CURVE('',#2623,#2600,#2625,.T.);
#2623 = VERTEX_POINT('',#2624);
#2624 = CARTESIAN_POINT('',(-0.64,-2.514,8.));
#2625 = SURFACE_CURVE('',#2626,(#2630,#2637),.PCURVE_S1.);
#2626 = LINE('',#2627,#2628);
#2627 = CARTESIAN_POINT('',(-0.64,-2.514,8.));
#2628 = VECTOR('',#2629,1.);
#2629 = DIRECTION('',(0.,0.,1.));
#2630 = PCURVE('',#2562,#2631);
#2631 = DEFINITIONAL_REPRESENTATION('',(#2632),#2636);
#2632 = LINE('',#2633,#2634);
#2633 = CARTESIAN_POINT('',(6.3E-02,0.));
#2634 = VECTOR('',#2635,1.);
#2635 = DIRECTION('',(0.,-1.));
#2636 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2637 = PCURVE('',#2638,#2643);
#2638 = PLANE('',#2639);
#2639 = AXIS2_PLACEMENT_3D('',#2640,#2641,#2642);
#2640 = CARTESIAN_POINT('',(-0.64,-2.514,8.));
#2641 = DIRECTION('',(-1.,2.2E-16,0.));
#2642 = DIRECTION('',(2.2E-16,1.,0.));
#2643 = DEFINITIONAL_REPRESENTATION('',(#2644),#2648);
#2644 = LINE('',#2645,#2646);
#2645 = CARTESIAN_POINT('',(4.4E-16,0.));
#2646 = VECTOR('',#2647,1.);
#2647 = DIRECTION('',(0.,-1.));
#2648 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2649 = ORIENTED_EDGE('',*,*,#2650,.F.);
#2650 = EDGE_CURVE('',#2547,#2623,#2651,.T.);
#2651 = SURFACE_CURVE('',#2652,(#2656,#2663),.PCURVE_S1.);
#2652 = LINE('',#2653,#2654);
#2653 = CARTESIAN_POINT('',(-0.703,-2.514,8.));
#2654 = VECTOR('',#2655,1.);
#2655 = DIRECTION('',(1.,0.,0.));
#2656 = PCURVE('',#2562,#2657);
#2657 = DEFINITIONAL_REPRESENTATION('',(#2658),#2662);
#2658 = LINE('',#2659,#2660);
#2659 = CARTESIAN_POINT('',(0.,0.));
#2660 = VECTOR('',#2661,1.);
#2661 = DIRECTION('',(1.,0.));
#2662 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2663 = PCURVE('',#2351,#2664);
#2664 = DEFINITIONAL_REPRESENTATION('',(#2665),#2669);
#2665 = LINE('',#2666,#2667);
#2666 = CARTESIAN_POINT('',(-0.694361552221,-0.174660882046));
#2667 = VECTOR('',#2668,1.);
#2668 = DIRECTION('',(0.,1.));
#2669 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2670 = ADVANCED_FACE('',(#2671),#2638,.T.);
#2671 = FACE_BOUND('',#2672,.T.);
#2672 = EDGE_LOOP('',(#2673,#2674,#2697,#2725));
#2673 = ORIENTED_EDGE('',*,*,#2622,.T.);
#2674 = ORIENTED_EDGE('',*,*,#2675,.T.);
#2675 = EDGE_CURVE('',#2600,#2676,#2678,.T.);
#2676 = VERTEX_POINT('',#2677);
#2677 = CARTESIAN_POINT('',(-0.64,-1.832,8.2));
#2678 = SURFACE_CURVE('',#2679,(#2683,#2690),.PCURVE_S1.);
#2679 = LINE('',#2680,#2681);
#2680 = CARTESIAN_POINT('',(-0.64,-2.514,8.2));
#2681 = VECTOR('',#2682,1.);
#2682 = DIRECTION('',(0.,1.,0.));
#2683 = PCURVE('',#2638,#2684);
#2684 = DEFINITIONAL_REPRESENTATION('',(#2685),#2689);
#2685 = LINE('',#2686,#2687);
#2686 = CARTESIAN_POINT('',(0.,-0.2));
#2687 = VECTOR('',#2688,1.);
#2688 = DIRECTION('',(1.,0.));
#2689 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2690 = PCURVE('',#2295,#2691);
#2691 = DEFINITIONAL_REPRESENTATION('',(#2692),#2696);
#2692 = LINE('',#2693,#2694);
#2693 = CARTESIAN_POINT('',(-0.694361552221,-0.111660882046));
#2694 = VECTOR('',#2695,1.);
#2695 = DIRECTION('',(1.,0.));
#2696 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2697 = ORIENTED_EDGE('',*,*,#2698,.F.);
#2698 = EDGE_CURVE('',#2699,#2676,#2701,.T.);
#2699 = VERTEX_POINT('',#2700);
#2700 = CARTESIAN_POINT('',(-0.64,-1.832,8.));
#2701 = SURFACE_CURVE('',#2702,(#2706,#2713),.PCURVE_S1.);
#2702 = LINE('',#2703,#2704);
#2703 = CARTESIAN_POINT('',(-0.64,-1.832,8.));
#2704 = VECTOR('',#2705,1.);
#2705 = DIRECTION('',(0.,0.,1.));
#2706 = PCURVE('',#2638,#2707);
#2707 = DEFINITIONAL_REPRESENTATION('',(#2708),#2712);
#2708 = LINE('',#2709,#2710);
#2709 = CARTESIAN_POINT('',(0.682,0.));
#2710 = VECTOR('',#2711,1.);
#2711 = DIRECTION('',(0.,-1.));
#2712 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2713 = PCURVE('',#2714,#2719);
#2714 = PLANE('',#2715);
#2715 = AXIS2_PLACEMENT_3D('',#2716,#2717,#2718);
#2716 = CARTESIAN_POINT('',(-0.64,-1.832,8.));
#2717 = DIRECTION('',(2.2E-16,1.,0.));
#2718 = DIRECTION('',(1.,-2.2E-16,0.));
#2719 = DEFINITIONAL_REPRESENTATION('',(#2720),#2724);
#2720 = LINE('',#2721,#2722);
#2721 = CARTESIAN_POINT('',(3.3E-16,0.));
#2722 = VECTOR('',#2723,1.);
#2723 = DIRECTION('',(0.,-1.));
#2724 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2725 = ORIENTED_EDGE('',*,*,#2726,.F.);
#2726 = EDGE_CURVE('',#2623,#2699,#2727,.T.);
#2727 = SURFACE_CURVE('',#2728,(#2732,#2739),.PCURVE_S1.);
#2728 = LINE('',#2729,#2730);
#2729 = CARTESIAN_POINT('',(-0.64,-2.514,8.));
#2730 = VECTOR('',#2731,1.);
#2731 = DIRECTION('',(0.,1.,0.));
#2732 = PCURVE('',#2638,#2733);
#2733 = DEFINITIONAL_REPRESENTATION('',(#2734),#2738);
#2734 = LINE('',#2735,#2736);
#2735 = CARTESIAN_POINT('',(0.,0.));
#2736 = VECTOR('',#2737,1.);
#2737 = DIRECTION('',(1.,0.));
#2738 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2739 = PCURVE('',#2351,#2740);
#2740 = DEFINITIONAL_REPRESENTATION('',(#2741),#2745);
#2741 = LINE('',#2742,#2743);
#2742 = CARTESIAN_POINT('',(-0.694361552221,-0.111660882046));
#2743 = VECTOR('',#2744,1.);
#2744 = DIRECTION('',(1.,0.));
#2745 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2746 = ADVANCED_FACE('',(#2747),#2714,.T.);
#2747 = FACE_BOUND('',#2748,.T.);
#2748 = EDGE_LOOP('',(#2749,#2750,#2773,#2801));
#2749 = ORIENTED_EDGE('',*,*,#2698,.T.);
#2750 = ORIENTED_EDGE('',*,*,#2751,.T.);
#2751 = EDGE_CURVE('',#2676,#2752,#2754,.T.);
#2752 = VERTEX_POINT('',#2753);
#2753 = CARTESIAN_POINT('',(-0.384,-1.832,8.2));
#2754 = SURFACE_CURVE('',#2755,(#2759,#2766),.PCURVE_S1.);
#2755 = LINE('',#2756,#2757);
#2756 = CARTESIAN_POINT('',(-0.64,-1.832,8.2));
#2757 = VECTOR('',#2758,1.);
#2758 = DIRECTION('',(1.,0.,0.));
#2759 = PCURVE('',#2714,#2760);
#2760 = DEFINITIONAL_REPRESENTATION('',(#2761),#2765);
#2761 = LINE('',#2762,#2763);
#2762 = CARTESIAN_POINT('',(0.,-0.2));
#2763 = VECTOR('',#2764,1.);
#2764 = DIRECTION('',(1.,0.));
#2765 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2766 = PCURVE('',#2295,#2767);
#2767 = DEFINITIONAL_REPRESENTATION('',(#2768),#2772);
#2768 = LINE('',#2769,#2770);
#2769 = CARTESIAN_POINT('',(-1.236155222082E-02,-0.111660882046));
#2770 = VECTOR('',#2771,1.);
#2771 = DIRECTION('',(0.,1.));
#2772 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2773 = ORIENTED_EDGE('',*,*,#2774,.F.);
#2774 = EDGE_CURVE('',#2775,#2752,#2777,.T.);
#2775 = VERTEX_POINT('',#2776);
#2776 = CARTESIAN_POINT('',(-0.384,-1.832,8.));
#2777 = SURFACE_CURVE('',#2778,(#2782,#2789),.PCURVE_S1.);
#2778 = LINE('',#2779,#2780);
#2779 = CARTESIAN_POINT('',(-0.384,-1.832,8.));
#2780 = VECTOR('',#2781,1.);
#2781 = DIRECTION('',(0.,0.,1.));
#2782 = PCURVE('',#2714,#2783);
#2783 = DEFINITIONAL_REPRESENTATION('',(#2784),#2788);
#2784 = LINE('',#2785,#2786);
#2785 = CARTESIAN_POINT('',(0.256,0.));
#2786 = VECTOR('',#2787,1.);
#2787 = DIRECTION('',(0.,-1.));
#2788 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2789 = PCURVE('',#2790,#2795);
#2790 = PLANE('',#2791);
#2791 = AXIS2_PLACEMENT_3D('',#2792,#2793,#2794);
#2792 = CARTESIAN_POINT('',(-0.384,-1.832,8.));
#2793 = DIRECTION('',(1.,-2.2E-16,0.));
#2794 = DIRECTION('',(-2.2E-16,-1.,0.));
#2795 = DEFINITIONAL_REPRESENTATION('',(#2796),#2800);
#2796 = LINE('',#2797,#2798);
#2797 = CARTESIAN_POINT('',(-2.2E-16,0.));
#2798 = VECTOR('',#2799,1.);
#2799 = DIRECTION('',(0.,-1.));
#2800 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2801 = ORIENTED_EDGE('',*,*,#2802,.F.);
#2802 = EDGE_CURVE('',#2699,#2775,#2803,.T.);
#2803 = SURFACE_CURVE('',#2804,(#2808,#2815),.PCURVE_S1.);
#2804 = LINE('',#2805,#2806);
#2805 = CARTESIAN_POINT('',(-0.64,-1.832,8.));
#2806 = VECTOR('',#2807,1.);
#2807 = DIRECTION('',(1.,0.,0.));
#2808 = PCURVE('',#2714,#2809);
#2809 = DEFINITIONAL_REPRESENTATION('',(#2810),#2814);
#2810 = LINE('',#2811,#2812);
#2811 = CARTESIAN_POINT('',(0.,0.));
#2812 = VECTOR('',#2813,1.);
#2813 = DIRECTION('',(1.,0.));
#2814 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
PARAMETRIC_REPRESENTATION_CONTEXT() REPRESENTATION_CONTEXT('2D SPACE',''
#2815 = PCURVE('',#2351,#2816);
#2816 = DEFINITIONAL_REPRESENTATION('',(#2817),#2821);
#2817 = LINE('',#2818,#2819);
#2818 = CARTESIAN_POINT('',(-1.236155222082E-02,-0.111660882046));
#2819 = VECTOR('',#2820,1.);
#2820 = DIRECTION('',(0.,1.));
#2821 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2822 = ADVANCED_FACE('',(#2823),#2790,.T.);
#2823 = FACE_BOUND('',#2824,.T.);
#2824 = EDGE_LOOP('',(#2825,#2826,#2849,#2877));
#2825 = ORIENTED_EDGE('',*,*,#2774,.T.);
#2826 = ORIENTED_EDGE('',*,*,#2827,.T.);
#2827 = EDGE_CURVE('',#2752,#2828,#2830,.T.);
#2828 = VERTEX_POINT('',#2829);
#2829 = CARTESIAN_POINT('',(-0.384,-2.766,8.2));
#2830 = SURFACE_CURVE('',#2831,(#2835,#2842),.PCURVE_S1.);
#2831 = LINE('',#2832,#2833);
#2832 = CARTESIAN_POINT('',(-0.384,-1.832,8.2));
#2833 = VECTOR('',#2834,1.);
#2834 = DIRECTION('',(0.,-1.,0.));
#2835 = PCURVE('',#2790,#2836);
#2836 = DEFINITIONAL_REPRESENTATION('',(#2837),#2841);
#2837 = LINE('',#2838,#2839);
#2838 = CARTESIAN_POINT('',(0.,-0.2));
#2839 = VECTOR('',#2840,1.);
#2840 = DIRECTION('',(1.,-0.));
#2841 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2842 = PCURVE('',#2295,#2843);
#2843 = DEFINITIONAL_REPRESENTATION('',(#2844),#2848);
#2844 = LINE('',#2845,#2846);
#2845 = CARTESIAN_POINT('',(-1.236155222082E-02,0.144339117954));
#2846 = VECTOR('',#2847,1.);
#2847 = DIRECTION('',(-1.,0.));
#2848 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2849 = ORIENTED_EDGE('',*,*,#2850,.F.);
#2850 = EDGE_CURVE('',#2851,#2828,#2853,.T.);
#2851 = VERTEX_POINT('',#2852);
#2852 = CARTESIAN_POINT('',(-0.384,-2.766,8.));
#2853 = SURFACE_CURVE('',#2854,(#2858,#2865),.PCURVE_S1.);
#2854 = LINE('',#2855,#2856);
#2855 = CARTESIAN_POINT('',(-0.384,-2.766,8.));
#2856 = VECTOR('',#2857,1.);
#2857 = DIRECTION('',(0.,0.,1.));
#2858 = PCURVE('',#2790,#2859);
#2859 = DEFINITIONAL_REPRESENTATION('',(#2860),#2864);
#2860 = LINE('',#2861,#2862);
#2861 = CARTESIAN_POINT('',(0.934,-0.));
#2862 = VECTOR('',#2863,1.);
#2863 = DIRECTION('',(0.,-1.));
#2864 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2865 = PCURVE('',#2866,#2871);
#2866 = PLANE('',#2867);
#2867 = AXIS2_PLACEMENT_3D('',#2868,#2869,#2870);
#2868 = CARTESIAN_POINT('',(-0.384,-2.766,8.));
#2869 = DIRECTION('',(-2.2E-16,-1.,0.));
#2870 = DIRECTION('',(-1.,2.2E-16,0.));
#2871 = DEFINITIONAL_REPRESENTATION('',(#2872),#2876);
#2872 = LINE('',#2873,#2874);
#2873 = CARTESIAN_POINT('',(4.4E-16,0.));
#2874 = VECTOR('',#2875,1.);
#2875 = DIRECTION('',(0.,-1.));
#2876 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2877 = ORIENTED_EDGE('',*,*,#2878,.F.);
#2878 = EDGE_CURVE('',#2775,#2851,#2879,.T.);
#2879 = SURFACE_CURVE('',#2880,(#2884,#2891),.PCURVE_S1.);
#2880 = LINE('',#2881,#2882);
#2881 = CARTESIAN_POINT('',(-0.384,-1.832,8.));
#2882 = VECTOR('',#2883,1.);
#2883 = DIRECTION('',(0.,-1.,0.));
#2884 = PCURVE('',#2790,#2885);
#2885 = DEFINITIONAL_REPRESENTATION('',(#2886),#2890);
#2886 = LINE('',#2887,#2888);
#2887 = CARTESIAN_POINT('',(0.,0.));
#2888 = VECTOR('',#2889,1.);
#2889 = DIRECTION('',(1.,-0.));
#2890 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2891 = PCURVE('',#2351,#2892);
#2892 = DEFINITIONAL_REPRESENTATION('',(#2893),#2897);
#2893 = LINE('',#2894,#2895);
#2894 = CARTESIAN_POINT('',(-1.236155222082E-02,0.144339117954));
#2895 = VECTOR('',#2896,1.);
#2896 = DIRECTION('',(-1.,0.));
#2897 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2898 = ADVANCED_FACE('',(#2899),#2866,.T.);
#2899 = FACE_BOUND('',#2900,.T.);
#2900 = EDGE_LOOP('',(#2901,#2902,#2925,#2953));
#2901 = ORIENTED_EDGE('',*,*,#2850,.T.);
#2902 = ORIENTED_EDGE('',*,*,#2903,.T.);
#2903 = EDGE_CURVE('',#2828,#2904,#2906,.T.);
#2904 = VERTEX_POINT('',#2905);
#2905 = CARTESIAN_POINT('',(-1.6,-2.766,8.2));
#2906 = SURFACE_CURVE('',#2907,(#2911,#2918),.PCURVE_S1.);
#2907 = LINE('',#2908,#2909);
#2908 = CARTESIAN_POINT('',(-0.384,-2.766,8.2));
#2909 = VECTOR('',#2910,1.);
#2910 = DIRECTION('',(-1.,-0.,0.));
#2911 = PCURVE('',#2866,#2912);
#2912 = DEFINITIONAL_REPRESENTATION('',(#2913),#2917);
#2913 = LINE('',#2914,#2915);
#2914 = CARTESIAN_POINT('',(0.,-0.2));
#2915 = VECTOR('',#2916,1.);
#2916 = DIRECTION('',(1.,0.));
#2917 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2918 = PCURVE('',#2295,#2919);
#2919 = DEFINITIONAL_REPRESENTATION('',(#2920),#2924);
#2920 = LINE('',#2921,#2922);
#2921 = CARTESIAN_POINT('',(-0.946361552221,0.144339117954));
#2922 = VECTOR('',#2923,1.);
#2923 = DIRECTION('',(0.,-1.));
#2924 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2925 = ORIENTED_EDGE('',*,*,#2926,.F.);
#2926 = EDGE_CURVE('',#2927,#2904,#2929,.T.);
#2927 = VERTEX_POINT('',#2928);
#2928 = CARTESIAN_POINT('',(-1.6,-2.766,8.));
#2929 = SURFACE_CURVE('',#2930,(#2934,#2941),.PCURVE_S1.);
#2930 = LINE('',#2931,#2932);
#2931 = CARTESIAN_POINT('',(-1.6,-2.766,8.));
#2932 = VECTOR('',#2933,1.);
#2933 = DIRECTION('',(0.,0.,1.));
#2934 = PCURVE('',#2866,#2935);
#2935 = DEFINITIONAL_REPRESENTATION('',(#2936),#2940);
#2936 = LINE('',#2937,#2938);
#2937 = CARTESIAN_POINT('',(1.216,0.));
#2938 = VECTOR('',#2939,1.);
#2939 = DIRECTION('',(0.,-1.));
#2940 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2941 = PCURVE('',#2942,#2947);
#2942 = PLANE('',#2943);
#2943 = AXIS2_PLACEMENT_3D('',#2944,#2945,#2946);
#2944 = CARTESIAN_POINT('',(-1.6,-2.766,8.));
#2945 = DIRECTION('',(-1.,2.2E-16,0.));
#2946 = DIRECTION('',(2.2E-16,1.,0.));
#2947 = DEFINITIONAL_REPRESENTATION('',(#2948),#2952);
#2948 = LINE('',#2949,#2950);
#2949 = CARTESIAN_POINT('',(0.,0.));
#2950 = VECTOR('',#2951,1.);
#2951 = DIRECTION('',(0.,-1.));
#2952 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2953 = ORIENTED_EDGE('',*,*,#2954,.F.);
#2954 = EDGE_CURVE('',#2851,#2927,#2955,.T.);
#2955 = SURFACE_CURVE('',#2956,(#2960,#2967),.PCURVE_S1.);
#2956 = LINE('',#2957,#2958);
#2957 = CARTESIAN_POINT('',(-0.384,-2.766,8.));
#2958 = VECTOR('',#2959,1.);
#2959 = DIRECTION('',(-1.,-0.,0.));
#2960 = PCURVE('',#2866,#2961);
#2961 = DEFINITIONAL_REPRESENTATION('',(#2962),#2966);
#2962 = LINE('',#2963,#2964);
#2963 = CARTESIAN_POINT('',(0.,0.));
#2964 = VECTOR('',#2965,1.);
#2965 = DIRECTION('',(1.,0.));
#2966 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2967 = PCURVE('',#2351,#2968);
#2968 = DEFINITIONAL_REPRESENTATION('',(#2969),#2973);
#2969 = LINE('',#2970,#2971);
#2970 = CARTESIAN_POINT('',(-0.946361552221,0.144339117954));
#2971 = VECTOR('',#2972,1.);
#2972 = DIRECTION('',(0.,-1.));
#2973 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2974 = ADVANCED_FACE('',(#2975),#2942,.T.);
#2975 = FACE_BOUND('',#2976,.T.);
#2976 = EDGE_LOOP('',(#2977,#2978,#3001,#3029));
#2977 = ORIENTED_EDGE('',*,*,#2926,.T.);
#2978 = ORIENTED_EDGE('',*,*,#2979,.T.);
#2979 = EDGE_CURVE('',#2904,#2980,#2982,.T.);
#2980 = VERTEX_POINT('',#2981);
#2981 = CARTESIAN_POINT('',(-1.6,-2.585,8.2));
#2982 = SURFACE_CURVE('',#2983,(#2987,#2994),.PCURVE_S1.);
#2983 = LINE('',#2984,#2985);
#2984 = CARTESIAN_POINT('',(-1.6,-2.766,8.2));
#2985 = VECTOR('',#2986,1.);
#2986 = DIRECTION('',(0.,1.,0.));
#2987 = PCURVE('',#2942,#2988);
#2988 = DEFINITIONAL_REPRESENTATION('',(#2989),#2993);
#2989 = LINE('',#2990,#2991);
#2990 = CARTESIAN_POINT('',(0.,-0.2));
#2991 = VECTOR('',#2992,1.);
#2992 = DIRECTION('',(1.,0.));
#2993 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#2994 = PCURVE('',#2295,#2995);
#2995 = DEFINITIONAL_REPRESENTATION('',(#2996),#3000);
#2996 = LINE('',#2997,#2998);
#2997 = CARTESIAN_POINT('',(-0.946361552221,-1.071660882046));
#2998 = VECTOR('',#2999,1.);
#2999 = DIRECTION('',(1.,0.));
#3000 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3001 = ORIENTED_EDGE('',*,*,#3002,.F.);
#3002 = EDGE_CURVE('',#3003,#2980,#3005,.T.);
#3003 = VERTEX_POINT('',#3004);
#3004 = CARTESIAN_POINT('',(-1.6,-2.585,8.));
#3005 = SURFACE_CURVE('',#3006,(#3010,#3017),.PCURVE_S1.);
#3006 = LINE('',#3007,#3008);
#3007 = CARTESIAN_POINT('',(-1.6,-2.585,8.));
#3008 = VECTOR('',#3009,1.);
#3009 = DIRECTION('',(0.,0.,1.));
#3010 = PCURVE('',#2942,#3011);
#3011 = DEFINITIONAL_REPRESENTATION('',(#3012),#3016);
#3012 = LINE('',#3013,#3014);
#3013 = CARTESIAN_POINT('',(0.181,0.));
#3014 = VECTOR('',#3015,1.);
#3015 = DIRECTION('',(0.,-1.));
#3016 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3017 = PCURVE('',#3018,#3023);
#3018 = PLANE('',#3019);
#3019 = AXIS2_PLACEMENT_3D('',#3020,#3021,#3022);
#3020 = CARTESIAN_POINT('',(-1.6,-2.585,8.));
#3021 = DIRECTION('',(-0.231033927447,0.97294569446,0.));
#3022 = DIRECTION('',(0.97294569446,0.231033927447,0.));
#3023 = DEFINITIONAL_REPRESENTATION('',(#3024),#3028);
#3024 = LINE('',#3025,#3026);
#3025 = CARTESIAN_POINT('',(4.3E-16,0.));
#3026 = VECTOR('',#3027,1.);
#3027 = DIRECTION('',(0.,-1.));
#3028 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3029 = ORIENTED_EDGE('',*,*,#3030,.F.);
#3030 = EDGE_CURVE('',#2927,#3003,#3031,.T.);
#3031 = SURFACE_CURVE('',#3032,(#3036,#3043),.PCURVE_S1.);
#3032 = LINE('',#3033,#3034);
#3033 = CARTESIAN_POINT('',(-1.6,-2.766,8.));
#3034 = VECTOR('',#3035,1.);
#3035 = DIRECTION('',(0.,1.,0.));
#3036 = PCURVE('',#2942,#3037);
#3037 = DEFINITIONAL_REPRESENTATION('',(#3038),#3042);
#3038 = LINE('',#3039,#3040);
#3039 = CARTESIAN_POINT('',(0.,0.));
#3040 = VECTOR('',#3041,1.);
#3041 = DIRECTION('',(1.,0.));
#3042 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3043 = PCURVE('',#2351,#3044);
#3044 = DEFINITIONAL_REPRESENTATION('',(#3045),#3049);
#3045 = LINE('',#3046,#3047);
#3046 = CARTESIAN_POINT('',(-0.946361552221,-1.071660882046));
#3047 = VECTOR('',#3048,1.);
#3048 = DIRECTION('',(1.,0.));
#3049 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3050 = ADVANCED_FACE('',(#3051),#3018,.T.);
#3051 = FACE_BOUND('',#3052,.T.);
#3052 = EDGE_LOOP('',(#3053,#3054,#3077,#3107));
#3053 = ORIENTED_EDGE('',*,*,#3002,.T.);
#3054 = ORIENTED_EDGE('',*,*,#3055,.T.);
#3055 = EDGE_CURVE('',#2980,#3056,#3058,.T.);
#3056 = VERTEX_POINT('',#3057);
#3057 = CARTESIAN_POINT('',(-1.301,-2.514,8.2));
#3058 = SURFACE_CURVE('',#3059,(#3063,#3070),.PCURVE_S1.);
#3059 = LINE('',#3060,#3061);
#3060 = CARTESIAN_POINT('',(-1.6,-2.585,8.2));
#3061 = VECTOR('',#3062,1.);
#3062 = DIRECTION('',(0.97294569446,0.231033927447,0.));
#3063 = PCURVE('',#3018,#3064);
#3064 = DEFINITIONAL_REPRESENTATION('',(#3065),#3069);
#3065 = LINE('',#3066,#3067);
#3066 = CARTESIAN_POINT('',(0.,-0.2));
#3067 = VECTOR('',#3068,1.);
#3068 = DIRECTION('',(1.,0.));
#3069 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3070 = PCURVE('',#2295,#3071);
#3071 = DEFINITIONAL_REPRESENTATION('',(#3072),#3076);
#3072 = LINE('',#3073,#3074);
#3073 = CARTESIAN_POINT('',(-0.765361552221,-1.071660882046));
#3074 = VECTOR('',#3075,1.);
#3075 = DIRECTION('',(0.231033927447,0.97294569446));
#3076 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3077 = ORIENTED_EDGE('',*,*,#3078,.F.);
#3078 = EDGE_CURVE('',#3079,#3056,#3081,.T.);
#3079 = VERTEX_POINT('',#3080);
#3080 = CARTESIAN_POINT('',(-1.301,-2.514,8.));
#3081 = SURFACE_CURVE('',#3082,(#3086,#3093),.PCURVE_S1.);
#3082 = LINE('',#3083,#3084);
#3083 = CARTESIAN_POINT('',(-1.301,-2.514,8.));
#3084 = VECTOR('',#3085,1.);
#3085 = DIRECTION('',(0.,0.,1.));
#3086 = PCURVE('',#3018,#3087);
#3087 = DEFINITIONAL_REPRESENTATION('',(#3088),#3092);
#3088 = LINE('',#3089,#3090);
#3089 = CARTESIAN_POINT('',(0.307314171492,0.));
#3090 = VECTOR('',#3091,1.);
#3091 = DIRECTION('',(0.,-1.));
#3092 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3093 = PCURVE('',#3094,#3101);
#3094 = SURFACE_OF_LINEAR_EXTRUSION('',#3095,#3099);
#3095 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3096,#3097,#3098),
#3096 = CARTESIAN_POINT('',(-1.301,-2.514,8.));
#3097 = CARTESIAN_POINT('',(-1.664,-2.191,8.));
#3098 = CARTESIAN_POINT('',(-1.664,-1.749,8.));
#3099 = VECTOR('',#3100,1.);
#3100 = DIRECTION('',(-0.,-0.,-1.));
#3101 = DEFINITIONAL_REPRESENTATION('',(#3102),#3106);
#3102 = LINE('',#3103,#3104);
#3103 = CARTESIAN_POINT('',(0.,0.));
#3104 = VECTOR('',#3105,1.);
#3105 = DIRECTION('',(0.,-1.));
#3106 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3107 = ORIENTED_EDGE('',*,*,#3108,.F.);
#3108 = EDGE_CURVE('',#3003,#3079,#3109,.T.);
#3109 = SURFACE_CURVE('',#3110,(#3114,#3121),.PCURVE_S1.);
#3110 = LINE('',#3111,#3112);
#3111 = CARTESIAN_POINT('',(-1.6,-2.585,8.));
#3112 = VECTOR('',#3113,1.);
#3113 = DIRECTION('',(0.97294569446,0.231033927447,0.));
#3114 = PCURVE('',#3018,#3115);
#3115 = DEFINITIONAL_REPRESENTATION('',(#3116),#3120);
#3116 = LINE('',#3117,#3118);
#3117 = CARTESIAN_POINT('',(0.,0.));
#3118 = VECTOR('',#3119,1.);
#3119 = DIRECTION('',(1.,0.));
#3120 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3121 = PCURVE('',#2351,#3122);
#3122 = DEFINITIONAL_REPRESENTATION('',(#3123),#3127);
#3123 = LINE('',#3124,#3125);
#3124 = CARTESIAN_POINT('',(-0.765361552221,-1.071660882046));
#3125 = VECTOR('',#3126,1.);
#3126 = DIRECTION('',(0.231033927447,0.97294569446));
#3127 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3128 = ADVANCED_FACE('',(#3129),#3094,.T.);
#3129 = FACE_BOUND('',#3130,.T.);
#3130 = EDGE_LOOP('',(#3131,#3132,#3155,#3185));
#3131 = ORIENTED_EDGE('',*,*,#3078,.T.);
#3132 = ORIENTED_EDGE('',*,*,#3133,.T.);
#3133 = EDGE_CURVE('',#3056,#3134,#3136,.T.);
#3134 = VERTEX_POINT('',#3135);
#3135 = CARTESIAN_POINT('',(-1.664,-1.749,8.2));
#3136 = SURFACE_CURVE('',#3137,(#3141,#3148),.PCURVE_S1.);
#3137 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3138,#3139,#3140),
#3138 = CARTESIAN_POINT('',(-1.301,-2.514,8.2));
#3139 = CARTESIAN_POINT('',(-1.664,-2.191,8.2));
#3140 = CARTESIAN_POINT('',(-1.664,-1.749,8.2));
#3141 = PCURVE('',#3094,#3142);
#3142 = DEFINITIONAL_REPRESENTATION('',(#3143),#3147);
#3143 = LINE('',#3144,#3145);
#3144 = CARTESIAN_POINT('',(0.,-0.2));
#3145 = VECTOR('',#3146,1.);
#3146 = DIRECTION('',(1.,0.));
#3147 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3148 = PCURVE('',#2295,#3149);
#3149 = DEFINITIONAL_REPRESENTATION('',(#3150),#3154);
#3150 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3151,#3152,#3153),
#3151 = CARTESIAN_POINT('',(-0.694361552221,-0.772660882046));
#3152 = CARTESIAN_POINT('',(-0.371361552221,-1.135660882046));
#3153 = CARTESIAN_POINT('',(7.063844777918E-02,-1.135660882046));
#3154 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3155 = ORIENTED_EDGE('',*,*,#3156,.F.);
#3156 = EDGE_CURVE('',#3157,#3134,#3159,.T.);
#3157 = VERTEX_POINT('',#3158);
#3158 = CARTESIAN_POINT('',(-1.664,-1.749,8.));
#3159 = SURFACE_CURVE('',#3160,(#3164,#3171),.PCURVE_S1.);
#3160 = LINE('',#3161,#3162);
#3161 = CARTESIAN_POINT('',(-1.664,-1.749,8.));
#3162 = VECTOR('',#3163,1.);
#3163 = DIRECTION('',(0.,0.,1.));
#3164 = PCURVE('',#3094,#3165);
#3165 = DEFINITIONAL_REPRESENTATION('',(#3166),#3170);
#3166 = LINE('',#3167,#3168);
#3167 = CARTESIAN_POINT('',(1.,0.));
#3168 = VECTOR('',#3169,1.);
#3169 = DIRECTION('',(0.,-1.));
#3170 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3171 = PCURVE('',#3172,#3179);
#3172 = SURFACE_OF_LINEAR_EXTRUSION('',#3173,#3177);
#3173 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3174,#3175,#3176),
#3174 = CARTESIAN_POINT('',(-1.664,-1.749,8.));
#3175 = CARTESIAN_POINT('',(-1.664,-1.279,8.));
#3176 = CARTESIAN_POINT('',(-1.311,-0.99,8.));
#3177 = VECTOR('',#3178,1.);
#3178 = DIRECTION('',(-0.,-0.,-1.));
#3179 = DEFINITIONAL_REPRESENTATION('',(#3180),#3184);
#3180 = LINE('',#3181,#3182);
#3181 = CARTESIAN_POINT('',(0.,0.));
#3182 = VECTOR('',#3183,1.);
#3183 = DIRECTION('',(0.,-1.));
#3184 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3185 = ORIENTED_EDGE('',*,*,#3186,.F.);
#3186 = EDGE_CURVE('',#3079,#3157,#3187,.T.);
#3187 = SURFACE_CURVE('',#3188,(#3192,#3199),.PCURVE_S1.);
#3188 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3189,#3190,#3191),
#3189 = CARTESIAN_POINT('',(-1.301,-2.514,8.));
#3190 = CARTESIAN_POINT('',(-1.664,-2.191,8.));
#3191 = CARTESIAN_POINT('',(-1.664,-1.749,8.));
#3192 = PCURVE('',#3094,#3193);
#3193 = DEFINITIONAL_REPRESENTATION('',(#3194),#3198);
#3194 = LINE('',#3195,#3196);
#3195 = CARTESIAN_POINT('',(0.,0.));
#3196 = VECTOR('',#3197,1.);
#3197 = DIRECTION('',(1.,0.));
#3198 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3199 = PCURVE('',#2351,#3200);
#3200 = DEFINITIONAL_REPRESENTATION('',(#3201),#3205);
#3201 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3202,#3203,#3204),
#3202 = CARTESIAN_POINT('',(-0.694361552221,-0.772660882046));
#3203 = CARTESIAN_POINT('',(-0.371361552221,-1.135660882046));
#3204 = CARTESIAN_POINT('',(7.063844777918E-02,-1.135660882046));
#3205 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3206 = ADVANCED_FACE('',(#3207),#3172,.T.);
#3207 = FACE_BOUND('',#3208,.T.);
#3208 = EDGE_LOOP('',(#3209,#3210,#3233,#3263));
#3209 = ORIENTED_EDGE('',*,*,#3156,.T.);
#3210 = ORIENTED_EDGE('',*,*,#3211,.T.);
#3211 = EDGE_CURVE('',#3134,#3212,#3214,.T.);
#3212 = VERTEX_POINT('',#3213);
#3213 = CARTESIAN_POINT('',(-1.311,-0.99,8.2));
#3214 = SURFACE_CURVE('',#3215,(#3219,#3226),.PCURVE_S1.);
#3215 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3216,#3217,#3218),
#3216 = CARTESIAN_POINT('',(-1.664,-1.749,8.2));
#3217 = CARTESIAN_POINT('',(-1.664,-1.279,8.2));
#3218 = CARTESIAN_POINT('',(-1.311,-0.99,8.2));
#3219 = PCURVE('',#3172,#3220);
#3220 = DEFINITIONAL_REPRESENTATION('',(#3221),#3225);
#3221 = LINE('',#3222,#3223);
#3222 = CARTESIAN_POINT('',(0.,-0.2));
#3223 = VECTOR('',#3224,1.);
#3224 = DIRECTION('',(1.,0.));
#3225 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3226 = PCURVE('',#2295,#3227);
#3227 = DEFINITIONAL_REPRESENTATION('',(#3228),#3232);
#3228 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3229,#3230,#3231),
#3229 = CARTESIAN_POINT('',(7.063844777918E-02,-1.135660882046));
#3230 = CARTESIAN_POINT('',(0.540638447779,-1.135660882046));
#3231 = CARTESIAN_POINT('',(0.829638447779,-0.782660882046));
#3232 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3233 = ORIENTED_EDGE('',*,*,#3234,.F.);
#3234 = EDGE_CURVE('',#3235,#3212,#3237,.T.);
#3235 = VERTEX_POINT('',#3236);
#3236 = CARTESIAN_POINT('',(-1.311,-0.99,8.));
#3237 = SURFACE_CURVE('',#3238,(#3242,#3249),.PCURVE_S1.);
#3238 = LINE('',#3239,#3240);
#3239 = CARTESIAN_POINT('',(-1.311,-0.99,8.));
#3240 = VECTOR('',#3241,1.);
#3241 = DIRECTION('',(0.,0.,1.));
#3242 = PCURVE('',#3172,#3243);
#3243 = DEFINITIONAL_REPRESENTATION('',(#3244),#3248);
#3244 = LINE('',#3245,#3246);
#3245 = CARTESIAN_POINT('',(1.,0.));
#3246 = VECTOR('',#3247,1.);
#3247 = DIRECTION('',(0.,-1.));
#3248 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3249 = PCURVE('',#3250,#3257);
#3250 = SURFACE_OF_LINEAR_EXTRUSION('',#3251,#3255);
#3251 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3252,#3253,#3254),
#3252 = CARTESIAN_POINT('',(-1.311,-0.99,8.));
#3253 = CARTESIAN_POINT('',(-0.985,-0.723,8.));
#3254 = CARTESIAN_POINT('',(-0.486,-0.723,8.));
#3255 = VECTOR('',#3256,1.);
#3256 = DIRECTION('',(-0.,-0.,-1.));
#3257 = DEFINITIONAL_REPRESENTATION('',(#3258),#3262);
#3258 = LINE('',#3259,#3260);
#3259 = CARTESIAN_POINT('',(0.,0.));
#3260 = VECTOR('',#3261,1.);
#3261 = DIRECTION('',(0.,-1.));
#3262 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3263 = ORIENTED_EDGE('',*,*,#3264,.F.);
#3264 = EDGE_CURVE('',#3157,#3235,#3265,.T.);
#3265 = SURFACE_CURVE('',#3266,(#3270,#3277),.PCURVE_S1.);
#3266 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3267,#3268,#3269),
#3267 = CARTESIAN_POINT('',(-1.664,-1.749,8.));
#3268 = CARTESIAN_POINT('',(-1.664,-1.279,8.));
#3269 = CARTESIAN_POINT('',(-1.311,-0.99,8.));
#3270 = PCURVE('',#3172,#3271);
#3271 = DEFINITIONAL_REPRESENTATION('',(#3272),#3276);
#3272 = LINE('',#3273,#3274);
#3273 = CARTESIAN_POINT('',(0.,0.));
#3274 = VECTOR('',#3275,1.);
#3275 = DIRECTION('',(1.,0.));
#3276 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3277 = PCURVE('',#2351,#3278);
#3278 = DEFINITIONAL_REPRESENTATION('',(#3279),#3283);
#3279 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3280,#3281,#3282),
#3280 = CARTESIAN_POINT('',(7.063844777918E-02,-1.135660882046));
#3281 = CARTESIAN_POINT('',(0.540638447779,-1.135660882046));
#3282 = CARTESIAN_POINT('',(0.829638447779,-0.782660882046));
#3283 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3284 = ADVANCED_FACE('',(#3285),#3250,.T.);
#3285 = FACE_BOUND('',#3286,.T.);
#3286 = EDGE_LOOP('',(#3287,#3288,#3311,#3341));
#3287 = ORIENTED_EDGE('',*,*,#3234,.T.);
#3288 = ORIENTED_EDGE('',*,*,#3289,.T.);
#3289 = EDGE_CURVE('',#3212,#3290,#3292,.T.);
#3290 = VERTEX_POINT('',#3291);
#3291 = CARTESIAN_POINT('',(-0.486,-0.723,8.2));
#3292 = SURFACE_CURVE('',#3293,(#3297,#3304),.PCURVE_S1.);
#3293 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3294,#3295,#3296),
#3294 = CARTESIAN_POINT('',(-1.311,-0.99,8.2));
#3295 = CARTESIAN_POINT('',(-0.985,-0.723,8.2));
#3296 = CARTESIAN_POINT('',(-0.486,-0.723,8.2));
#3297 = PCURVE('',#3250,#3298);
#3298 = DEFINITIONAL_REPRESENTATION('',(#3299),#3303);
#3299 = LINE('',#3300,#3301);
#3300 = CARTESIAN_POINT('',(0.,-0.2));
#3301 = VECTOR('',#3302,1.);
#3302 = DIRECTION('',(1.,0.));
#3303 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3304 = PCURVE('',#2295,#3305);
#3305 = DEFINITIONAL_REPRESENTATION('',(#3306),#3310);
#3306 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3307,#3308,#3309),
#3307 = CARTESIAN_POINT('',(0.829638447779,-0.782660882046));
#3308 = CARTESIAN_POINT('',(1.096638447779,-0.456660882046));
#3309 = CARTESIAN_POINT('',(1.096638447779,4.233911795393E-02));
#3310 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3311 = ORIENTED_EDGE('',*,*,#3312,.F.);
#3312 = EDGE_CURVE('',#3313,#3290,#3315,.T.);
#3313 = VERTEX_POINT('',#3314);
#3314 = CARTESIAN_POINT('',(-0.486,-0.723,8.));
#3315 = SURFACE_CURVE('',#3316,(#3320,#3327),.PCURVE_S1.);
#3316 = LINE('',#3317,#3318);
#3317 = CARTESIAN_POINT('',(-0.486,-0.723,8.));
#3318 = VECTOR('',#3319,1.);
#3319 = DIRECTION('',(0.,0.,1.));
#3320 = PCURVE('',#3250,#3321);
#3321 = DEFINITIONAL_REPRESENTATION('',(#3322),#3326);
#3322 = LINE('',#3323,#3324);
#3323 = CARTESIAN_POINT('',(1.,0.));
#3324 = VECTOR('',#3325,1.);
#3325 = DIRECTION('',(0.,-1.));
#3326 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3327 = PCURVE('',#3328,#3335);
#3328 = SURFACE_OF_LINEAR_EXTRUSION('',#3329,#3333);
#3329 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3330,#3331,#3332),
#3330 = CARTESIAN_POINT('',(-0.486,-0.723,8.));
#3331 = CARTESIAN_POINT('',(-3.7E-02,-0.723,8.));
#3332 = CARTESIAN_POINT('',(0.286,-0.944,8.));
#3333 = VECTOR('',#3334,1.);
#3334 = DIRECTION('',(-0.,-0.,-1.));
#3335 = DEFINITIONAL_REPRESENTATION('',(#3336),#3340);
#3336 = LINE('',#3337,#3338);
#3337 = CARTESIAN_POINT('',(0.,0.));
#3338 = VECTOR('',#3339,1.);
#3339 = DIRECTION('',(0.,-1.));
#3340 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3341 = ORIENTED_EDGE('',*,*,#3342,.F.);
#3342 = EDGE_CURVE('',#3235,#3313,#3343,.T.);
#3343 = SURFACE_CURVE('',#3344,(#3348,#3355),.PCURVE_S1.);
#3344 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3345,#3346,#3347),
#3345 = CARTESIAN_POINT('',(-1.311,-0.99,8.));
#3346 = CARTESIAN_POINT('',(-0.985,-0.723,8.));
#3347 = CARTESIAN_POINT('',(-0.486,-0.723,8.));
#3348 = PCURVE('',#3250,#3349);
#3349 = DEFINITIONAL_REPRESENTATION('',(#3350),#3354);
#3350 = LINE('',#3351,#3352);
#3351 = CARTESIAN_POINT('',(0.,0.));
#3352 = VECTOR('',#3353,1.);
#3353 = DIRECTION('',(1.,0.));
#3354 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3355 = PCURVE('',#2351,#3356);
#3356 = DEFINITIONAL_REPRESENTATION('',(#3357),#3361);
#3357 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3358,#3359,#3360),
#3358 = CARTESIAN_POINT('',(0.829638447779,-0.782660882046));
#3359 = CARTESIAN_POINT('',(1.096638447779,-0.456660882046));
#3360 = CARTESIAN_POINT('',(1.096638447779,4.233911795393E-02));
#3361 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3362 = ADVANCED_FACE('',(#3363),#3328,.T.);
#3363 = FACE_BOUND('',#3364,.T.);
#3364 = EDGE_LOOP('',(#3365,#3366,#3389,#3419));
#3365 = ORIENTED_EDGE('',*,*,#3312,.T.);
#3366 = ORIENTED_EDGE('',*,*,#3367,.T.);
#3367 = EDGE_CURVE('',#3290,#3368,#3370,.T.);
#3368 = VERTEX_POINT('',#3369);
#3369 = CARTESIAN_POINT('',(0.286,-0.944,8.2));
#3370 = SURFACE_CURVE('',#3371,(#3375,#3382),.PCURVE_S1.);
#3371 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3372,#3373,#3374),
#3372 = CARTESIAN_POINT('',(-0.486,-0.723,8.2));
#3373 = CARTESIAN_POINT('',(-3.7E-02,-0.723,8.2));
#3374 = CARTESIAN_POINT('',(0.286,-0.944,8.2));
#3375 = PCURVE('',#3328,#3376);
#3376 = DEFINITIONAL_REPRESENTATION('',(#3377),#3381);
#3377 = LINE('',#3378,#3379);
#3378 = CARTESIAN_POINT('',(0.,-0.2));
#3379 = VECTOR('',#3380,1.);
#3380 = DIRECTION('',(1.,0.));
#3381 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3382 = PCURVE('',#2295,#3383);
#3383 = DEFINITIONAL_REPRESENTATION('',(#3384),#3388);
#3384 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3385,#3386,#3387),
#3385 = CARTESIAN_POINT('',(1.096638447779,4.233911795393E-02));
#3386 = CARTESIAN_POINT('',(1.096638447779,0.491339117954));
#3387 = CARTESIAN_POINT('',(0.875638447779,0.814339117954));
#3388 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3389 = ORIENTED_EDGE('',*,*,#3390,.F.);
#3390 = EDGE_CURVE('',#3391,#3368,#3393,.T.);
#3391 = VERTEX_POINT('',#3392);
#3392 = CARTESIAN_POINT('',(0.286,-0.944,8.));
#3393 = SURFACE_CURVE('',#3394,(#3398,#3405),.PCURVE_S1.);
#3394 = LINE('',#3395,#3396);
#3395 = CARTESIAN_POINT('',(0.286,-0.944,8.));
#3396 = VECTOR('',#3397,1.);
#3397 = DIRECTION('',(0.,0.,1.));
#3398 = PCURVE('',#3328,#3399);
#3399 = DEFINITIONAL_REPRESENTATION('',(#3400),#3404);
#3400 = LINE('',#3401,#3402);
#3401 = CARTESIAN_POINT('',(1.,0.));
#3402 = VECTOR('',#3403,1.);
#3403 = DIRECTION('',(0.,-1.));
#3404 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3405 = PCURVE('',#3406,#3413);
#3406 = SURFACE_OF_LINEAR_EXTRUSION('',#3407,#3411);
#3407 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3408,#3409,#3410),
#3408 = CARTESIAN_POINT('',(0.286,-0.944,8.));
#3409 = CARTESIAN_POINT('',(0.701,-1.233,8.));
#3410 = CARTESIAN_POINT('',(0.704,-1.798,8.));
#3411 = VECTOR('',#3412,1.);
#3412 = DIRECTION('',(-0.,-0.,-1.));
#3413 = DEFINITIONAL_REPRESENTATION('',(#3414),#3418);
#3414 = LINE('',#3415,#3416);
#3415 = CARTESIAN_POINT('',(0.,0.));
#3416 = VECTOR('',#3417,1.);
#3417 = DIRECTION('',(0.,-1.));
#3418 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3419 = ORIENTED_EDGE('',*,*,#3420,.F.);
#3420 = EDGE_CURVE('',#3313,#3391,#3421,.T.);
#3421 = SURFACE_CURVE('',#3422,(#3426,#3433),.PCURVE_S1.);
#3422 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3423,#3424,#3425),
#3423 = CARTESIAN_POINT('',(-0.486,-0.723,8.));
#3424 = CARTESIAN_POINT('',(-3.7E-02,-0.723,8.));
#3425 = CARTESIAN_POINT('',(0.286,-0.944,8.));
#3426 = PCURVE('',#3328,#3427);
#3427 = DEFINITIONAL_REPRESENTATION('',(#3428),#3432);
#3428 = LINE('',#3429,#3430);
#3429 = CARTESIAN_POINT('',(0.,0.));
#3430 = VECTOR('',#3431,1.);
#3431 = DIRECTION('',(1.,0.));
#3432 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3433 = PCURVE('',#2351,#3434);
#3434 = DEFINITIONAL_REPRESENTATION('',(#3435),#3439);
#3435 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3436,#3437,#3438),
#3436 = CARTESIAN_POINT('',(1.096638447779,4.233911795393E-02));
#3437 = CARTESIAN_POINT('',(1.096638447779,0.491339117954));
#3438 = CARTESIAN_POINT('',(0.875638447779,0.814339117954));
#3439 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3440 = ADVANCED_FACE('',(#3441),#3406,.T.);
#3441 = FACE_BOUND('',#3442,.T.);
#3442 = EDGE_LOOP('',(#3443,#3444,#3467,#3497));
#3443 = ORIENTED_EDGE('',*,*,#3390,.T.);
#3444 = ORIENTED_EDGE('',*,*,#3445,.T.);
#3445 = EDGE_CURVE('',#3368,#3446,#3448,.T.);
#3446 = VERTEX_POINT('',#3447);
#3447 = CARTESIAN_POINT('',(0.704,-1.798,8.2));
#3448 = SURFACE_CURVE('',#3449,(#3453,#3460),.PCURVE_S1.);
#3449 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3450,#3451,#3452),
#3450 = CARTESIAN_POINT('',(0.286,-0.944,8.2));
#3451 = CARTESIAN_POINT('',(0.701,-1.233,8.2));
#3452 = CARTESIAN_POINT('',(0.704,-1.798,8.2));
#3453 = PCURVE('',#3406,#3454);
#3454 = DEFINITIONAL_REPRESENTATION('',(#3455),#3459);
#3455 = LINE('',#3456,#3457);
#3456 = CARTESIAN_POINT('',(0.,-0.2));
#3457 = VECTOR('',#3458,1.);
#3458 = DIRECTION('',(1.,0.));
#3459 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3460 = PCURVE('',#2295,#3461);
#3461 = DEFINITIONAL_REPRESENTATION('',(#3462),#3466);
#3462 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3463,#3464,#3465),
#3463 = CARTESIAN_POINT('',(0.875638447779,0.814339117954));
#3464 = CARTESIAN_POINT('',(0.586638447779,1.229339117954));
#3465 = CARTESIAN_POINT('',(2.163844777918E-02,1.232339117954));
#3466 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3467 = ORIENTED_EDGE('',*,*,#3468,.F.);
#3468 = EDGE_CURVE('',#3469,#3446,#3471,.T.);
#3469 = VERTEX_POINT('',#3470);
#3470 = CARTESIAN_POINT('',(0.704,-1.798,8.));
#3471 = SURFACE_CURVE('',#3472,(#3476,#3483),.PCURVE_S1.);
#3472 = LINE('',#3473,#3474);
#3473 = CARTESIAN_POINT('',(0.704,-1.798,8.));
#3474 = VECTOR('',#3475,1.);
#3475 = DIRECTION('',(0.,0.,1.));
#3476 = PCURVE('',#3406,#3477);
#3477 = DEFINITIONAL_REPRESENTATION('',(#3478),#3482);
#3478 = LINE('',#3479,#3480);
#3479 = CARTESIAN_POINT('',(1.,0.));
#3480 = VECTOR('',#3481,1.);
#3481 = DIRECTION('',(0.,-1.));
#3482 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3483 = PCURVE('',#3484,#3491);
#3484 = SURFACE_OF_LINEAR_EXTRUSION('',#3485,#3489);
#3485 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3486,#3487,#3488),
#3486 = CARTESIAN_POINT('',(0.704,-1.798,8.));
#3487 = CARTESIAN_POINT('',(0.704,-2.348,8.));
#3488 = CARTESIAN_POINT('',(0.347,-2.597,8.));
#3489 = VECTOR('',#3490,1.);
#3490 = DIRECTION('',(-0.,-0.,-1.));
#3491 = DEFINITIONAL_REPRESENTATION('',(#3492),#3496);
#3492 = LINE('',#3493,#3494);
#3493 = CARTESIAN_POINT('',(0.,0.));
#3494 = VECTOR('',#3495,1.);
#3495 = DIRECTION('',(0.,-1.));
#3496 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3497 = ORIENTED_EDGE('',*,*,#3498,.F.);
#3498 = EDGE_CURVE('',#3391,#3469,#3499,.T.);
#3499 = SURFACE_CURVE('',#3500,(#3504,#3511),.PCURVE_S1.);
#3500 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3501,#3502,#3503),
#3501 = CARTESIAN_POINT('',(0.286,-0.944,8.));
#3502 = CARTESIAN_POINT('',(0.701,-1.233,8.));
#3503 = CARTESIAN_POINT('',(0.704,-1.798,8.));
#3504 = PCURVE('',#3406,#3505);
#3505 = DEFINITIONAL_REPRESENTATION('',(#3506),#3510);
#3506 = LINE('',#3507,#3508);
#3507 = CARTESIAN_POINT('',(0.,0.));
#3508 = VECTOR('',#3509,1.);
#3509 = DIRECTION('',(1.,0.));
#3510 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3511 = PCURVE('',#2351,#3512);
#3512 = DEFINITIONAL_REPRESENTATION('',(#3513),#3517);
#3513 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3514,#3515,#3516),
#3514 = CARTESIAN_POINT('',(0.875638447779,0.814339117954));
#3515 = CARTESIAN_POINT('',(0.586638447779,1.229339117954));
#3516 = CARTESIAN_POINT('',(2.163844777918E-02,1.232339117954));
#3517 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3518 = ADVANCED_FACE('',(#3519),#3484,.T.);
#3519 = FACE_BOUND('',#3520,.T.);
#3520 = EDGE_LOOP('',(#3521,#3522,#3545,#3575));
#3521 = ORIENTED_EDGE('',*,*,#3468,.T.);
#3522 = ORIENTED_EDGE('',*,*,#3523,.T.);
#3523 = EDGE_CURVE('',#3446,#3524,#3526,.T.);
#3524 = VERTEX_POINT('',#3525);
#3525 = CARTESIAN_POINT('',(0.347,-2.597,8.2));
#3526 = SURFACE_CURVE('',#3527,(#3531,#3538),.PCURVE_S1.);
#3527 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3528,#3529,#3530),
#3528 = CARTESIAN_POINT('',(0.704,-1.798,8.2));
#3529 = CARTESIAN_POINT('',(0.704,-2.348,8.2));
#3530 = CARTESIAN_POINT('',(0.347,-2.597,8.2));
#3531 = PCURVE('',#3484,#3532);
#3532 = DEFINITIONAL_REPRESENTATION('',(#3533),#3537);
#3533 = LINE('',#3534,#3535);
#3534 = CARTESIAN_POINT('',(0.,-0.2));
#3535 = VECTOR('',#3536,1.);
#3536 = DIRECTION('',(1.,0.));
#3537 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3538 = PCURVE('',#2295,#3539);
#3539 = DEFINITIONAL_REPRESENTATION('',(#3540),#3544);
#3540 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3541,#3542,#3543),
#3541 = CARTESIAN_POINT('',(2.163844777918E-02,1.232339117954));
#3542 = CARTESIAN_POINT('',(-0.528361552221,1.232339117954));
#3543 = CARTESIAN_POINT('',(-0.777361552221,0.875339117954));
#3544 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3545 = ORIENTED_EDGE('',*,*,#3546,.F.);
#3546 = EDGE_CURVE('',#3547,#3524,#3549,.T.);
#3547 = VERTEX_POINT('',#3548);
#3548 = CARTESIAN_POINT('',(0.347,-2.597,8.));
#3549 = SURFACE_CURVE('',#3550,(#3554,#3561),.PCURVE_S1.);
#3550 = LINE('',#3551,#3552);
#3551 = CARTESIAN_POINT('',(0.347,-2.597,8.));
#3552 = VECTOR('',#3553,1.);
#3553 = DIRECTION('',(0.,0.,1.));
#3554 = PCURVE('',#3484,#3555);
#3555 = DEFINITIONAL_REPRESENTATION('',(#3556),#3560);
#3556 = LINE('',#3557,#3558);
#3557 = CARTESIAN_POINT('',(1.,0.));
#3558 = VECTOR('',#3559,1.);
#3559 = DIRECTION('',(0.,-1.));
#3560 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3561 = PCURVE('',#3562,#3569);
#3562 = SURFACE_OF_LINEAR_EXTRUSION('',#3563,#3567);
#3563 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3564,#3565,#3566),
#3564 = CARTESIAN_POINT('',(0.347,-2.597,8.));
#3565 = CARTESIAN_POINT('',(0.196,-2.698,8.));
#3566 = CARTESIAN_POINT('',(-4.4E-16,-2.735,8.));
#3567 = VECTOR('',#3568,1.);
#3568 = DIRECTION('',(-0.,-0.,-1.));
#3569 = DEFINITIONAL_REPRESENTATION('',(#3570),#3574);
#3570 = LINE('',#3571,#3572);
#3571 = CARTESIAN_POINT('',(0.,0.));
#3572 = VECTOR('',#3573,1.);
#3573 = DIRECTION('',(0.,-1.));
#3574 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3575 = ORIENTED_EDGE('',*,*,#3576,.F.);
#3576 = EDGE_CURVE('',#3469,#3547,#3577,.T.);
#3577 = SURFACE_CURVE('',#3578,(#3582,#3589),.PCURVE_S1.);
#3578 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3579,#3580,#3581),
#3579 = CARTESIAN_POINT('',(0.704,-1.798,8.));
#3580 = CARTESIAN_POINT('',(0.704,-2.348,8.));
#3581 = CARTESIAN_POINT('',(0.347,-2.597,8.));
#3582 = PCURVE('',#3484,#3583);
#3583 = DEFINITIONAL_REPRESENTATION('',(#3584),#3588);
#3584 = LINE('',#3585,#3586);
#3585 = CARTESIAN_POINT('',(0.,0.));
#3586 = VECTOR('',#3587,1.);
#3587 = DIRECTION('',(1.,0.));
#3588 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3589 = PCURVE('',#2351,#3590);
#3590 = DEFINITIONAL_REPRESENTATION('',(#3591),#3595);
#3591 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3592,#3593,#3594),
#3592 = CARTESIAN_POINT('',(2.163844777918E-02,1.232339117954));
#3593 = CARTESIAN_POINT('',(-0.528361552221,1.232339117954));
#3594 = CARTESIAN_POINT('',(-0.777361552221,0.875339117954));
#3595 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3596 = ADVANCED_FACE('',(#3597),#3562,.T.);
#3597 = FACE_BOUND('',#3598,.T.);
#3598 = EDGE_LOOP('',(#3599,#3600,#3623,#3651));
#3599 = ORIENTED_EDGE('',*,*,#3546,.T.);
#3600 = ORIENTED_EDGE('',*,*,#3601,.T.);
#3601 = EDGE_CURVE('',#3524,#3602,#3604,.T.);
#3602 = VERTEX_POINT('',#3603);
#3603 = CARTESIAN_POINT('',(0.,-2.735,8.2));
#3604 = SURFACE_CURVE('',#3605,(#3609,#3616),.PCURVE_S1.);
#3605 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3606,#3607,#3608),
#3606 = CARTESIAN_POINT('',(0.347,-2.597,8.2));
#3607 = CARTESIAN_POINT('',(0.196,-2.698,8.2));
#3608 = CARTESIAN_POINT('',(0.,-2.735,8.2));
#3609 = PCURVE('',#3562,#3610);
#3610 = DEFINITIONAL_REPRESENTATION('',(#3611),#3615);
#3611 = LINE('',#3612,#3613);
#3612 = CARTESIAN_POINT('',(0.,-0.2));
#3613 = VECTOR('',#3614,1.);
#3614 = DIRECTION('',(1.,0.));
#3615 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3616 = PCURVE('',#2295,#3617);
#3617 = DEFINITIONAL_REPRESENTATION('',(#3618),#3622);
#3618 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3619,#3620,#3621),
#3619 = CARTESIAN_POINT('',(-0.777361552221,0.875339117954));
#3620 = CARTESIAN_POINT('',(-0.878361552221,0.724339117954));
#3621 = CARTESIAN_POINT('',(-0.915361552221,0.528339117954));
#3622 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3623 = ORIENTED_EDGE('',*,*,#3624,.F.);
#3624 = EDGE_CURVE('',#3625,#3602,#3627,.T.);
#3625 = VERTEX_POINT('',#3626);
#3626 = CARTESIAN_POINT('',(0.,-2.735,8.));
#3627 = SURFACE_CURVE('',#3628,(#3632,#3639),.PCURVE_S1.);
#3628 = LINE('',#3629,#3630);
#3629 = CARTESIAN_POINT('',(-4.4E-16,-2.735,8.));
#3630 = VECTOR('',#3631,1.);
#3631 = DIRECTION('',(0.,0.,1.));
#3632 = PCURVE('',#3562,#3633);
#3633 = DEFINITIONAL_REPRESENTATION('',(#3634),#3638);
#3634 = LINE('',#3635,#3636);
#3635 = CARTESIAN_POINT('',(1.,0.));
#3636 = VECTOR('',#3637,1.);
#3637 = DIRECTION('',(0.,-1.));
#3638 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3639 = PCURVE('',#3640,#3645);
#3640 = PLANE('',#3641);
#3641 = AXIS2_PLACEMENT_3D('',#3642,#3643,#3644);
#3642 = CARTESIAN_POINT('',(-4.4E-16,-2.735,8.));
#3643 = DIRECTION('',(-1.,2.2E-16,0.));
#3644 = DIRECTION('',(2.2E-16,1.,0.));
#3645 = DEFINITIONAL_REPRESENTATION('',(#3646),#3650);
#3646 = LINE('',#3647,#3648);
#3647 = CARTESIAN_POINT('',(8.9E-16,0.));
#3648 = VECTOR('',#3649,1.);
#3649 = DIRECTION('',(0.,-1.));
#3650 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3651 = ORIENTED_EDGE('',*,*,#3652,.F.);
#3652 = EDGE_CURVE('',#3547,#3625,#3653,.T.);
#3653 = SURFACE_CURVE('',#3654,(#3658,#3665),.PCURVE_S1.);
#3654 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3655,#3656,#3657),
#3655 = CARTESIAN_POINT('',(0.347,-2.597,8.));
#3656 = CARTESIAN_POINT('',(0.196,-2.698,8.));
#3657 = CARTESIAN_POINT('',(0.,-2.735,8.));
#3658 = PCURVE('',#3562,#3659);
#3659 = DEFINITIONAL_REPRESENTATION('',(#3660),#3664);
#3660 = LINE('',#3661,#3662);
#3661 = CARTESIAN_POINT('',(0.,0.));
#3662 = VECTOR('',#3663,1.);
#3663 = DIRECTION('',(1.,0.));
#3664 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3665 = PCURVE('',#2351,#3666);
#3666 = DEFINITIONAL_REPRESENTATION('',(#3667),#3671);
#3667 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3668,#3669,#3670),
.UNSPECIFIED.,.F.,.F.,(3,3),(0.,1.),.PIECEWISE_BEZIER_KNOTS.);
#3668 = CARTESIAN_POINT('',(-0.777361552221,0.875339117954));
#3669 = CARTESIAN_POINT('',(-0.878361552221,0.724339117954));
#3670 = CARTESIAN_POINT('',(-0.915361552221,0.528339117954));
#3671 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3672 = ADVANCED_FACE('',(#3673),#3640,.T.);
#3673 = FACE_BOUND('',#3674,.T.);
#3674 = EDGE_LOOP('',(#3675,#3676,#3699,#3729));
#3675 = ORIENTED_EDGE('',*,*,#3624,.T.);
#3676 = ORIENTED_EDGE('',*,*,#3677,.T.);
#3677 = EDGE_CURVE('',#3602,#3678,#3680,.T.);
#3678 = VERTEX_POINT('',#3679);
#3679 = CARTESIAN_POINT('',(0.,-2.443,8.2));
#3680 = SURFACE_CURVE('',#3681,(#3685,#3692),.PCURVE_S1.);
#3681 = LINE('',#3682,#3683);
#3682 = CARTESIAN_POINT('',(0.,-2.735,8.2));
#3683 = VECTOR('',#3684,1.);
#3684 = DIRECTION('',(0.,1.,0.));
#3685 = PCURVE('',#3640,#3686);
#3686 = DEFINITIONAL_REPRESENTATION('',(#3687),#3691);
#3687 = LINE('',#3688,#3689);
#3688 = CARTESIAN_POINT('',(0.,-0.2));
#3689 = VECTOR('',#3690,1.);
#3690 = DIRECTION('',(1.,0.));
#3691 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3692 = PCURVE('',#2295,#3693);
#3693 = DEFINITIONAL_REPRESENTATION('',(#3694),#3698);
#3694 = LINE('',#3695,#3696);
#3695 = CARTESIAN_POINT('',(-0.915361552221,0.528339117954));
#3696 = VECTOR('',#3697,1.);
#3697 = DIRECTION('',(1.,0.));
#3698 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3699 = ORIENTED_EDGE('',*,*,#3700,.F.);
#3700 = EDGE_CURVE('',#3701,#3678,#3703,.T.);
#3701 = VERTEX_POINT('',#3702);
#3702 = CARTESIAN_POINT('',(0.,-2.443,8.));
#3703 = SURFACE_CURVE('',#3704,(#3708,#3715),.PCURVE_S1.);
#3704 = LINE('',#3705,#3706);
#3705 = CARTESIAN_POINT('',(-4.4E-16,-2.443,8.));
#3706 = VECTOR('',#3707,1.);
#3707 = DIRECTION('',(0.,0.,1.));
#3708 = PCURVE('',#3640,#3709);
#3709 = DEFINITIONAL_REPRESENTATION('',(#3710),#3714);
#3710 = LINE('',#3711,#3712);
#3711 = CARTESIAN_POINT('',(0.292,0.));
#3712 = VECTOR('',#3713,1.);
#3713 = DIRECTION('',(0.,-1.));
#3714 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3715 = PCURVE('',#3716,#3723);
#3716 = SURFACE_OF_LINEAR_EXTRUSION('',#3717,#3721);
#3717 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3718,#3719,#3720),
#3718 = CARTESIAN_POINT('',(-4.4E-16,-2.443,8.));
#3719 = CARTESIAN_POINT('',(0.291,-2.379,8.));
#3720 = CARTESIAN_POINT('',(0.398,-2.087,8.));
#3721 = VECTOR('',#3722,1.);
#3722 = DIRECTION('',(-0.,-0.,-1.));
#3723 = DEFINITIONAL_REPRESENTATION('',(#3724),#3728);
#3724 = LINE('',#3725,#3726);
#3725 = CARTESIAN_POINT('',(0.,0.));
#3726 = VECTOR('',#3727,1.);
#3727 = DIRECTION('',(0.,-1.));
#3728 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3729 = ORIENTED_EDGE('',*,*,#3730,.F.);
#3730 = EDGE_CURVE('',#3625,#3701,#3731,.T.);
#3731 = SURFACE_CURVE('',#3732,(#3736,#3743),.PCURVE_S1.);
#3732 = LINE('',#3733,#3734);
#3733 = CARTESIAN_POINT('',(0.,-2.735,8.));
#3734 = VECTOR('',#3735,1.);
#3735 = DIRECTION('',(0.,1.,0.));
#3736 = PCURVE('',#3640,#3737);
#3737 = DEFINITIONAL_REPRESENTATION('',(#3738),#3742);
#3738 = LINE('',#3739,#3740);
#3739 = CARTESIAN_POINT('',(0.,0.));
#3740 = VECTOR('',#3741,1.);
#3741 = DIRECTION('',(1.,0.));
#3742 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3743 = PCURVE('',#2351,#3744);
#3744 = DEFINITIONAL_REPRESENTATION('',(#3745),#3749);
#3745 = LINE('',#3746,#3747);
#3746 = CARTESIAN_POINT('',(-0.915361552221,0.528339117954));
#3747 = VECTOR('',#3748,1.);
#3748 = DIRECTION('',(1.,0.));
#3749 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3750 = ADVANCED_FACE('',(#3751),#3716,.T.);
#3751 = FACE_BOUND('',#3752,.T.);
#3752 = EDGE_LOOP('',(#3753,#3754,#3777,#3807));
#3753 = ORIENTED_EDGE('',*,*,#3700,.T.);
#3754 = ORIENTED_EDGE('',*,*,#3755,.T.);
#3755 = EDGE_CURVE('',#3678,#3756,#3758,.T.);
#3756 = VERTEX_POINT('',#3757);
#3757 = CARTESIAN_POINT('',(0.398,-2.087,8.2));
#3758 = SURFACE_CURVE('',#3759,(#3763,#3770),.PCURVE_S1.);
#3759 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3760,#3761,#3762),
#3760 = CARTESIAN_POINT('',(0.,-2.443,8.2));
#3761 = CARTESIAN_POINT('',(0.291,-2.379,8.2));
#3762 = CARTESIAN_POINT('',(0.398,-2.087,8.2));
#3763 = PCURVE('',#3716,#3764);
#3764 = DEFINITIONAL_REPRESENTATION('',(#3765),#3769);
#3765 = LINE('',#3766,#3767);
#3766 = CARTESIAN_POINT('',(0.,-0.2));
#3767 = VECTOR('',#3768,1.);
#3768 = DIRECTION('',(1.,0.));
#3769 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3770 = PCURVE('',#2295,#3771);
#3771 = DEFINITIONAL_REPRESENTATION('',(#3772),#3776);
#3772 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3773,#3774,#3775),
#3773 = CARTESIAN_POINT('',(-0.623361552221,0.528339117954));
#3774 = CARTESIAN_POINT('',(-0.559361552221,0.819339117954));
#3775 = CARTESIAN_POINT('',(-0.267361552221,0.926339117954));
#3776 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3777 = ORIENTED_EDGE('',*,*,#3778,.F.);
#3778 = EDGE_CURVE('',#3779,#3756,#3781,.T.);
#3779 = VERTEX_POINT('',#3780);
#3780 = CARTESIAN_POINT('',(0.398,-2.087,8.));
#3781 = SURFACE_CURVE('',#3782,(#3786,#3793),.PCURVE_S1.);
#3782 = LINE('',#3783,#3784);
#3783 = CARTESIAN_POINT('',(0.398,-2.087,8.));
#3784 = VECTOR('',#3785,1.);
#3785 = DIRECTION('',(0.,0.,1.));
#3786 = PCURVE('',#3716,#3787);
#3787 = DEFINITIONAL_REPRESENTATION('',(#3788),#3792);
#3788 = LINE('',#3789,#3790);
#3789 = CARTESIAN_POINT('',(1.,0.));
#3790 = VECTOR('',#3791,1.);
#3791 = DIRECTION('',(0.,-1.));
#3792 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3793 = PCURVE('',#3794,#3801);
#3794 = SURFACE_OF_LINEAR_EXTRUSION('',#3795,#3799);
#3795 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3796,#3797,#3798),
#3796 = CARTESIAN_POINT('',(0.398,-2.087,8.));
#3797 = CARTESIAN_POINT('',(0.448,-1.955,8.));
#3798 = CARTESIAN_POINT('',(0.448,-1.795,8.));
#3799 = VECTOR('',#3800,1.);
#3800 = DIRECTION('',(-0.,-0.,-1.));
#3801 = DEFINITIONAL_REPRESENTATION('',(#3802),#3806);
#3802 = LINE('',#3803,#3804);
#3803 = CARTESIAN_POINT('',(0.,0.));
#3804 = VECTOR('',#3805,1.);
#3805 = DIRECTION('',(0.,-1.));
#3806 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3807 = ORIENTED_EDGE('',*,*,#3808,.F.);
#3808 = EDGE_CURVE('',#3701,#3779,#3809,.T.);
#3809 = SURFACE_CURVE('',#3810,(#3814,#3821),.PCURVE_S1.);
#3810 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3811,#3812,#3813),
#3811 = CARTESIAN_POINT('',(0.,-2.443,8.));
#3812 = CARTESIAN_POINT('',(0.291,-2.379,8.));
#3813 = CARTESIAN_POINT('',(0.398,-2.087,8.));
#3814 = PCURVE('',#3716,#3815);
#3815 = DEFINITIONAL_REPRESENTATION('',(#3816),#3820);
#3816 = LINE('',#3817,#3818);
#3817 = CARTESIAN_POINT('',(0.,0.));
#3818 = VECTOR('',#3819,1.);
#3819 = DIRECTION('',(1.,0.));
#3820 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3821 = PCURVE('',#2351,#3822);
#3822 = DEFINITIONAL_REPRESENTATION('',(#3823),#3827);
#3823 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3824,#3825,#3826),
#3824 = CARTESIAN_POINT('',(-0.623361552221,0.528339117954));
#3825 = CARTESIAN_POINT('',(-0.559361552221,0.819339117954));
#3826 = CARTESIAN_POINT('',(-0.267361552221,0.926339117954));
#3827 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3828 = ADVANCED_FACE('',(#3829),#3794,.T.);
#3829 = FACE_BOUND('',#3830,.T.);
#3830 = EDGE_LOOP('',(#3831,#3832,#3855,#3885));
#3831 = ORIENTED_EDGE('',*,*,#3778,.T.);
#3832 = ORIENTED_EDGE('',*,*,#3833,.T.);
#3833 = EDGE_CURVE('',#3756,#3834,#3836,.T.);
#3834 = VERTEX_POINT('',#3835);
#3835 = CARTESIAN_POINT('',(0.448,-1.795,8.2));
#3836 = SURFACE_CURVE('',#3837,(#3841,#3848),.PCURVE_S1.);
#3837 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3838,#3839,#3840),
#3838 = CARTESIAN_POINT('',(0.398,-2.087,8.2));
#3839 = CARTESIAN_POINT('',(0.448,-1.955,8.2));
#3840 = CARTESIAN_POINT('',(0.448,-1.795,8.2));
#3841 = PCURVE('',#3794,#3842);
#3842 = DEFINITIONAL_REPRESENTATION('',(#3843),#3847);
#3843 = LINE('',#3844,#3845);
#3844 = CARTESIAN_POINT('',(0.,-0.2));
#3845 = VECTOR('',#3846,1.);
#3846 = DIRECTION('',(1.,0.));
#3847 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3848 = PCURVE('',#2295,#3849);
#3849 = DEFINITIONAL_REPRESENTATION('',(#3850),#3854);
#3850 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3851,#3852,#3853),
#3851 = CARTESIAN_POINT('',(-0.267361552221,0.926339117954));
#3852 = CARTESIAN_POINT('',(-0.135361552221,0.976339117954));
#3853 = CARTESIAN_POINT('',(2.463844777918E-02,0.976339117954));
#3854 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3855 = ORIENTED_EDGE('',*,*,#3856,.F.);
#3856 = EDGE_CURVE('',#3857,#3834,#3859,.T.);
#3857 = VERTEX_POINT('',#3858);
#3858 = CARTESIAN_POINT('',(0.448,-1.795,8.));
#3859 = SURFACE_CURVE('',#3860,(#3864,#3871),.PCURVE_S1.);
#3860 = LINE('',#3861,#3862);
#3861 = CARTESIAN_POINT('',(0.448,-1.795,8.));
#3862 = VECTOR('',#3863,1.);
#3863 = DIRECTION('',(0.,0.,1.));
#3864 = PCURVE('',#3794,#3865);
#3865 = DEFINITIONAL_REPRESENTATION('',(#3866),#3870);
#3866 = LINE('',#3867,#3868);
#3867 = CARTESIAN_POINT('',(1.,0.));
#3868 = VECTOR('',#3869,1.);
#3869 = DIRECTION('',(0.,-1.));
#3870 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3871 = PCURVE('',#3872,#3879);
#3872 = SURFACE_OF_LINEAR_EXTRUSION('',#3873,#3877);
#3873 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3874,#3875,#3876),
#3874 = CARTESIAN_POINT('',(0.448,-1.795,8.));
#3875 = CARTESIAN_POINT('',(0.448,-1.39,8.));
#3876 = CARTESIAN_POINT('',(0.126,-1.172,8.));
#3877 = VECTOR('',#3878,1.);
#3878 = DIRECTION('',(-0.,-0.,-1.));
#3879 = DEFINITIONAL_REPRESENTATION('',(#3880),#3884);
#3880 = LINE('',#3881,#3882);
#3881 = CARTESIAN_POINT('',(0.,0.));
#3882 = VECTOR('',#3883,1.);
#3883 = DIRECTION('',(0.,-1.));
#3884 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3885 = ORIENTED_EDGE('',*,*,#3886,.F.);
#3886 = EDGE_CURVE('',#3779,#3857,#3887,.T.);
#3887 = SURFACE_CURVE('',#3888,(#3892,#3899),.PCURVE_S1.);
#3888 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3889,#3890,#3891),
#3889 = CARTESIAN_POINT('',(0.398,-2.087,8.));
#3890 = CARTESIAN_POINT('',(0.448,-1.955,8.));
#3891 = CARTESIAN_POINT('',(0.448,-1.795,8.));
#3892 = PCURVE('',#3794,#3893);
#3893 = DEFINITIONAL_REPRESENTATION('',(#3894),#3898);
#3894 = LINE('',#3895,#3896);
#3895 = CARTESIAN_POINT('',(0.,0.));
#3896 = VECTOR('',#3897,1.);
#3897 = DIRECTION('',(1.,0.));
#3898 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3899 = PCURVE('',#2351,#3900);
#3900 = DEFINITIONAL_REPRESENTATION('',(#3901),#3905);
#3901 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3902,#3903,#3904),
#3902 = CARTESIAN_POINT('',(-0.267361552221,0.926339117954));
#3903 = CARTESIAN_POINT('',(-0.135361552221,0.976339117954));
#3904 = CARTESIAN_POINT('',(2.463844777918E-02,0.976339117954));
#3905 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3906 = ADVANCED_FACE('',(#3907),#3872,.T.);
#3907 = FACE_BOUND('',#3908,.T.);
#3908 = EDGE_LOOP('',(#3909,#3910,#3933,#3956));
#3909 = ORIENTED_EDGE('',*,*,#3856,.T.);
#3910 = ORIENTED_EDGE('',*,*,#3911,.T.);
#3911 = EDGE_CURVE('',#3834,#3912,#3914,.T.);
#3912 = VERTEX_POINT('',#3913);
#3913 = CARTESIAN_POINT('',(0.126,-1.172,8.2));
#3914 = SURFACE_CURVE('',#3915,(#3919,#3926),.PCURVE_S1.);
#3915 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3916,#3917,#3918),
#3916 = CARTESIAN_POINT('',(0.448,-1.795,8.2));
#3917 = CARTESIAN_POINT('',(0.448,-1.39,8.2));
#3918 = CARTESIAN_POINT('',(0.126,-1.172,8.2));
#3919 = PCURVE('',#3872,#3920);
#3920 = DEFINITIONAL_REPRESENTATION('',(#3921),#3925);
#3921 = LINE('',#3922,#3923);
#3922 = CARTESIAN_POINT('',(0.,-0.2));
#3923 = VECTOR('',#3924,1.);
#3924 = DIRECTION('',(1.,0.));
#3925 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3926 = PCURVE('',#2295,#3927);
#3927 = DEFINITIONAL_REPRESENTATION('',(#3928),#3932);
#3928 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3929,#3930,#3931),
#3929 = CARTESIAN_POINT('',(2.463844777918E-02,0.976339117954));
#3930 = CARTESIAN_POINT('',(0.429638447779,0.976339117954));
#3931 = CARTESIAN_POINT('',(0.647638447779,0.654339117954));
#3932 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3933 = ORIENTED_EDGE('',*,*,#3934,.F.);
#3934 = EDGE_CURVE('',#3935,#3912,#3937,.T.);
#3935 = VERTEX_POINT('',#3936);
#3936 = CARTESIAN_POINT('',(0.126,-1.172,8.));
#3937 = SURFACE_CURVE('',#3938,(#3942,#3949),.PCURVE_S1.);
#3938 = LINE('',#3939,#3940);
#3939 = CARTESIAN_POINT('',(0.126,-1.172,8.));
#3940 = VECTOR('',#3941,1.);
#3941 = DIRECTION('',(0.,0.,1.));
#3942 = PCURVE('',#3872,#3943);
#3943 = DEFINITIONAL_REPRESENTATION('',(#3944),#3948);
#3944 = LINE('',#3945,#3946);
#3945 = CARTESIAN_POINT('',(1.,0.));
#3946 = VECTOR('',#3947,1.);
#3947 = DIRECTION('',(0.,-1.));
#3948 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3949 = PCURVE('',#2265,#3950);
#3950 = DEFINITIONAL_REPRESENTATION('',(#3951),#3955);
#3951 = LINE('',#3952,#3953);
#3952 = CARTESIAN_POINT('',(0.,0.));
#3953 = VECTOR('',#3954,1.);
#3954 = DIRECTION('',(0.,-1.));
#3955 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3956 = ORIENTED_EDGE('',*,*,#3957,.F.);
#3957 = EDGE_CURVE('',#3857,#3935,#3958,.T.);
#3958 = SURFACE_CURVE('',#3959,(#3963,#3970),.PCURVE_S1.);
#3959 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3960,#3961,#3962),
#3960 = CARTESIAN_POINT('',(0.448,-1.795,8.));
#3961 = CARTESIAN_POINT('',(0.448,-1.39,8.));
#3962 = CARTESIAN_POINT('',(0.126,-1.172,8.));
#3963 = PCURVE('',#3872,#3964);
#3964 = DEFINITIONAL_REPRESENTATION('',(#3965),#3969);
#3965 = LINE('',#3966,#3967);
#3966 = CARTESIAN_POINT('',(0.,0.));
#3967 = VECTOR('',#3968,1.);
#3968 = DIRECTION('',(1.,0.));
#3969 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3970 = PCURVE('',#2351,#3971);
#3971 = DEFINITIONAL_REPRESENTATION('',(#3972),#3976);
#3972 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3973,#3974,#3975),
#3973 = CARTESIAN_POINT('',(2.463844777918E-02,0.976339117954));
#3974 = CARTESIAN_POINT('',(0.429638447779,0.976339117954));
#3975 = CARTESIAN_POINT('',(0.647638447779,0.654339117954));
#3976 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3977 = ADVANCED_FACE('',(#3978),#2265,.T.);
#3978 = FACE_BOUND('',#3979,.T.);
#3979 = EDGE_LOOP('',(#3980,#3981,#4002,#4003));
#3980 = ORIENTED_EDGE('',*,*,#3934,.T.);
#3981 = ORIENTED_EDGE('',*,*,#3982,.T.);
#3982 = EDGE_CURVE('',#3912,#2243,#3983,.T.);
#3983 = SURFACE_CURVE('',#3984,(#3988,#3995),.PCURVE_S1.);
#3984 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3985,#3986,#3987),
#3985 = CARTESIAN_POINT('',(0.126,-1.172,8.2));
#3986 = CARTESIAN_POINT('',(-0.118,-1.009,8.2));
#3987 = CARTESIAN_POINT('',(-0.471,-1.009,8.2));
#3988 = PCURVE('',#2265,#3989);
#3989 = DEFINITIONAL_REPRESENTATION('',(#3990),#3994);
#3990 = LINE('',#3991,#3992);
#3991 = CARTESIAN_POINT('',(0.,-0.2));
#3992 = VECTOR('',#3993,1.);
#3993 = DIRECTION('',(1.,0.));
#3994 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#3995 = PCURVE('',#2295,#3996);
#3996 = DEFINITIONAL_REPRESENTATION('',(#3997),#4001);
#3997 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#3998,#3999,#4000),
#3998 = CARTESIAN_POINT('',(0.647638447779,0.654339117954));
#3999 = CARTESIAN_POINT('',(0.810638447779,0.410339117954));
#4000 = CARTESIAN_POINT('',(0.810638447779,5.733911795393E-02));
#4001 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4002 = ORIENTED_EDGE('',*,*,#2240,.F.);
#4003 = ORIENTED_EDGE('',*,*,#4004,.F.);
#4004 = EDGE_CURVE('',#3935,#2241,#4005,.T.);
#4005 = SURFACE_CURVE('',#4006,(#4010,#4017),.PCURVE_S1.);
#4006 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4007,#4008,#4009),
#4007 = CARTESIAN_POINT('',(0.126,-1.172,8.));
#4008 = CARTESIAN_POINT('',(-0.118,-1.009,8.));
#4009 = CARTESIAN_POINT('',(-0.471,-1.009,8.));
#4010 = PCURVE('',#2265,#4011);
#4011 = DEFINITIONAL_REPRESENTATION('',(#4012),#4016);
#4012 = LINE('',#4013,#4014);
#4013 = CARTESIAN_POINT('',(0.,0.));
#4014 = VECTOR('',#4015,1.);
#4015 = DIRECTION('',(1.,0.));
#4016 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4017 = PCURVE('',#2351,#4018);
#4018 = DEFINITIONAL_REPRESENTATION('',(#4019),#4023);
#4019 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4020,#4021,#4022),
#4020 = CARTESIAN_POINT('',(0.647638447779,0.654339117954));
#4021 = CARTESIAN_POINT('',(0.810638447779,0.410339117954));
#4022 = CARTESIAN_POINT('',(0.810638447779,5.733911795393E-02));
#4023 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4024 = ADVANCED_FACE('',(#4025),#2351,.T.);
#4025 = FACE_BOUND('',#4026,.T.);
#4026 = EDGE_LOOP('',(#4027,#4028,#4029,#4030,#4031,#4032,#4033,#4034,
#4035,#4036,#4037,#4038,#4039,#4040,#4041,#4042,#4043,#4044,#4045,
#4046,#4047,#4048,#4049));
#4027 = ORIENTED_EDGE('',*,*,#2337,.T.);
#4028 = ORIENTED_EDGE('',*,*,#2420,.T.);
#4029 = ORIENTED_EDGE('',*,*,#2498,.T.);
#4030 = ORIENTED_EDGE('',*,*,#2574,.T.);
#4031 = ORIENTED_EDGE('',*,*,#2650,.T.);
#4032 = ORIENTED_EDGE('',*,*,#2726,.T.);
#4033 = ORIENTED_EDGE('',*,*,#2802,.T.);
#4034 = ORIENTED_EDGE('',*,*,#2878,.T.);
#4035 = ORIENTED_EDGE('',*,*,#2954,.T.);
#4036 = ORIENTED_EDGE('',*,*,#3030,.T.);
#4037 = ORIENTED_EDGE('',*,*,#3108,.T.);
#4038 = ORIENTED_EDGE('',*,*,#3186,.T.);
#4039 = ORIENTED_EDGE('',*,*,#3264,.T.);
#4040 = ORIENTED_EDGE('',*,*,#3342,.T.);
#4041 = ORIENTED_EDGE('',*,*,#3420,.T.);
#4042 = ORIENTED_EDGE('',*,*,#3498,.T.);
#4043 = ORIENTED_EDGE('',*,*,#3576,.T.);
#4044 = ORIENTED_EDGE('',*,*,#3652,.T.);
#4045 = ORIENTED_EDGE('',*,*,#3730,.T.);
#4046 = ORIENTED_EDGE('',*,*,#3808,.T.);
#4047 = ORIENTED_EDGE('',*,*,#3886,.T.);
#4048 = ORIENTED_EDGE('',*,*,#3957,.T.);
#4049 = ORIENTED_EDGE('',*,*,#4004,.T.);
#4050 = ADVANCED_FACE('',(#4051),#2295,.F.);
#4051 = FACE_BOUND('',#4052,.F.);
#4052 = EDGE_LOOP('',(#4053,#4054,#4055,#4056,#4057,#4058,#4059,#4060,
#4061,#4062,#4063,#4064,#4065,#4066,#4067,#4068,#4069,#4070,#4071,
#4072,#4073,#4074,#4075));
#4053 = ORIENTED_EDGE('',*,*,#2279,.T.);
#4054 = ORIENTED_EDGE('',*,*,#2367,.T.);
#4055 = ORIENTED_EDGE('',*,*,#2445,.T.);
#4056 = ORIENTED_EDGE('',*,*,#2523,.T.);
#4057 = ORIENTED_EDGE('',*,*,#2599,.T.);
#4058 = ORIENTED_EDGE('',*,*,#2675,.T.);
#4059 = ORIENTED_EDGE('',*,*,#2751,.T.);
#4060 = ORIENTED_EDGE('',*,*,#2827,.T.);
#4061 = ORIENTED_EDGE('',*,*,#2903,.T.);
#4062 = ORIENTED_EDGE('',*,*,#2979,.T.);
#4063 = ORIENTED_EDGE('',*,*,#3055,.T.);
#4064 = ORIENTED_EDGE('',*,*,#3133,.T.);
#4065 = ORIENTED_EDGE('',*,*,#3211,.T.);
#4066 = ORIENTED_EDGE('',*,*,#3289,.T.);
#4067 = ORIENTED_EDGE('',*,*,#3367,.T.);
#4068 = ORIENTED_EDGE('',*,*,#3445,.T.);
#4069 = ORIENTED_EDGE('',*,*,#3523,.T.);
#4070 = ORIENTED_EDGE('',*,*,#3601,.T.);
#4071 = ORIENTED_EDGE('',*,*,#3677,.T.);
#4072 = ORIENTED_EDGE('',*,*,#3755,.T.);
#4073 = ORIENTED_EDGE('',*,*,#3833,.T.);
#4074 = ORIENTED_EDGE('',*,*,#3911,.T.);
#4075 = ORIENTED_EDGE('',*,*,#3982,.T.);
#4076 = MANIFOLD_SOLID_BREP('',#4077);
#4077 = CLOSED_SHELL('',(#4078,#4202,#4280,#4356,#4434,#4512,#4588,#4666
,#4744,#4822,#4900,#4978,#5056,#5134,#5212,#5288,#5364,#5440,#5516,
#5592,#5668,#5746,#5824,#5900,#5978,#6056,#6134,#6212,#6283,#6330,
#6446,#6522,#6600,#6678,#6756,#6834,#6905,#6952,#6994));
#4078 = ADVANCED_FACE('',(#4079),#4093,.T.);
#4079 = FACE_BOUND('',#4080,.T.);
#4080 = EDGE_LOOP('',(#4081,#4118,#4146,#4176));
#4081 = ORIENTED_EDGE('',*,*,#4082,.T.);
#4082 = EDGE_CURVE('',#4083,#4085,#4087,.T.);
#4083 = VERTEX_POINT('',#4084);
#4084 = CARTESIAN_POINT('',(-0.448,-3.131,8.));
#4085 = VERTEX_POINT('',#4086);
#4086 = CARTESIAN_POINT('',(-0.448,-3.131,8.2));
#4087 = SURFACE_CURVE('',#4088,(#4092,#4106),.PCURVE_S1.);
#4088 = LINE('',#4089,#4090);
#4089 = CARTESIAN_POINT('',(-0.448,-3.131,8.));
#4090 = VECTOR('',#4091,1.);
#4091 = DIRECTION('',(0.,0.,1.));
#4092 = PCURVE('',#4093,#4100);
#4093 = SURFACE_OF_LINEAR_EXTRUSION('',#4094,#4098);
#4094 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4095,#4096,#4097),
#4095 = CARTESIAN_POINT('',(-0.448,-3.131,8.));
#4096 = CARTESIAN_POINT('',(6.1E-02,-3.152,8.));
#4097 = CARTESIAN_POINT('',(6.4E-02,-3.776,8.));
#4098 = VECTOR('',#4099,1.);
#4099 = DIRECTION('',(-0.,-0.,-1.));
#4100 = DEFINITIONAL_REPRESENTATION('',(#4101),#4105);
#4101 = LINE('',#4102,#4103);
#4102 = CARTESIAN_POINT('',(0.,0.));
#4103 = VECTOR('',#4104,1.);
#4104 = DIRECTION('',(0.,-1.));
#4105 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4106 = PCURVE('',#4107,#4112);
#4107 = PLANE('',#4108);
#4108 = AXIS2_PLACEMENT_3D('',#4109,#4110,#4111);
#4109 = CARTESIAN_POINT('',(-0.448,-3.389,8.));
#4110 = DIRECTION('',(-1.,2.2E-16,0.));
#4111 = DIRECTION('',(2.2E-16,1.,0.));
#4112 = DEFINITIONAL_REPRESENTATION('',(#4113),#4117);
#4113 = LINE('',#4114,#4115);
#4114 = CARTESIAN_POINT('',(0.258,0.));
#4115 = VECTOR('',#4116,1.);
#4116 = DIRECTION('',(0.,-1.));
#4117 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4118 = ORIENTED_EDGE('',*,*,#4119,.T.);
#4119 = EDGE_CURVE('',#4085,#4120,#4122,.T.);
#4120 = VERTEX_POINT('',#4121);
#4121 = CARTESIAN_POINT('',(6.4E-02,-3.776,8.2));
#4122 = SURFACE_CURVE('',#4123,(#4127,#4134),.PCURVE_S1.);
#4123 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4124,#4125,#4126),
#4124 = CARTESIAN_POINT('',(-0.448,-3.131,8.2));
#4125 = CARTESIAN_POINT('',(6.1E-02,-3.152,8.2));
#4126 = CARTESIAN_POINT('',(6.4E-02,-3.776,8.2));
#4127 = PCURVE('',#4093,#4128);
#4128 = DEFINITIONAL_REPRESENTATION('',(#4129),#4133);
#4129 = LINE('',#4130,#4131);
#4130 = CARTESIAN_POINT('',(0.,-0.2));
#4131 = VECTOR('',#4132,1.);
#4132 = DIRECTION('',(1.,0.));
#4133 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4134 = PCURVE('',#4135,#4140);
#4135 = PLANE('',#4136);
#4136 = AXIS2_PLACEMENT_3D('',#4137,#4138,#4139);
#4137 = CARTESIAN_POINT('',(-0.762682722252,-3.805321172048,8.2));
#4138 = DIRECTION('',(-0.,0.,-1.));
#4139 = DIRECTION('',(0.,1.,0.));
#4140 = DEFINITIONAL_REPRESENTATION('',(#4141),#4145);
#4141 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4142,#4143,#4144),
#4142 = CARTESIAN_POINT('',(0.674321172048,0.314682722252));
#4143 = CARTESIAN_POINT('',(0.653321172048,0.823682722252));
#4144 = CARTESIAN_POINT('',(2.93211720483E-02,0.826682722252));
#4145 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4146 = ORIENTED_EDGE('',*,*,#4147,.F.);
#4147 = EDGE_CURVE('',#4148,#4120,#4150,.T.);
#4148 = VERTEX_POINT('',#4149);
#4149 = CARTESIAN_POINT('',(6.4E-02,-3.776,8.));
#4150 = SURFACE_CURVE('',#4151,(#4155,#4162),.PCURVE_S1.);
#4151 = LINE('',#4152,#4153);
#4152 = CARTESIAN_POINT('',(6.4E-02,-3.776,8.));
#4153 = VECTOR('',#4154,1.);
#4154 = DIRECTION('',(0.,0.,1.));
#4155 = PCURVE('',#4093,#4156);
#4156 = DEFINITIONAL_REPRESENTATION('',(#4157),#4161);
#4157 = LINE('',#4158,#4159);
#4158 = CARTESIAN_POINT('',(1.,0.));
#4159 = VECTOR('',#4160,1.);
#4160 = DIRECTION('',(0.,-1.));
#4161 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4162 = PCURVE('',#4163,#4170);
#4163 = SURFACE_OF_LINEAR_EXTRUSION('',#4164,#4168);
#4164 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4165,#4166,#4167),
#4165 = CARTESIAN_POINT('',(6.4E-02,-3.776,8.));
#4166 = CARTESIAN_POINT('',(6.4E-02,-4.316,8.));
#4167 = CARTESIAN_POINT('',(-0.3,-4.375,8.));
#4168 = VECTOR('',#4169,1.);
#4169 = DIRECTION('',(-0.,-0.,-1.));
#4170 = DEFINITIONAL_REPRESENTATION('',(#4171),#4175);
#4171 = LINE('',#4172,#4173);
#4172 = CARTESIAN_POINT('',(0.,0.));
#4173 = VECTOR('',#4174,1.);
#4174 = DIRECTION('',(0.,-1.));
#4175 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4176 = ORIENTED_EDGE('',*,*,#4177,.F.);
#4177 = EDGE_CURVE('',#4083,#4148,#4178,.T.);
#4178 = SURFACE_CURVE('',#4179,(#4183,#4190),.PCURVE_S1.);
#4179 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4180,#4181,#4182),
#4180 = CARTESIAN_POINT('',(-0.448,-3.131,8.));
#4181 = CARTESIAN_POINT('',(6.1E-02,-3.152,8.));
#4182 = CARTESIAN_POINT('',(6.4E-02,-3.776,8.));
#4183 = PCURVE('',#4093,#4184);
#4184 = DEFINITIONAL_REPRESENTATION('',(#4185),#4189);
#4185 = LINE('',#4186,#4187);
#4186 = CARTESIAN_POINT('',(0.,0.));
#4187 = VECTOR('',#4188,1.);
#4188 = DIRECTION('',(1.,0.));
#4189 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4190 = PCURVE('',#4191,#4196);
#4191 = PLANE('',#4192);
#4192 = AXIS2_PLACEMENT_3D('',#4193,#4194,#4195);
#4193 = CARTESIAN_POINT('',(-0.762682722252,-3.805321172048,8.));
#4194 = DIRECTION('',(-0.,0.,-1.));
#4195 = DIRECTION('',(0.,1.,0.));
#4196 = DEFINITIONAL_REPRESENTATION('',(#4197),#4201);
#4197 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4198,#4199,#4200),
#4198 = CARTESIAN_POINT('',(0.674321172048,0.314682722252));
#4199 = CARTESIAN_POINT('',(0.653321172048,0.823682722252));
#4200 = CARTESIAN_POINT('',(2.93211720483E-02,0.826682722252));
#4201 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
PARAMETRIC_REPRESENTATION_CONTEXT() REPRESENTATION_CONTEXT('2D SPACE',''
#4202 = ADVANCED_FACE('',(#4203),#4163,.T.);
#4203 = FACE_BOUND('',#4204,.T.);
#4204 = EDGE_LOOP('',(#4205,#4206,#4229,#4259));
#4205 = ORIENTED_EDGE('',*,*,#4147,.T.);
#4206 = ORIENTED_EDGE('',*,*,#4207,.T.);
#4207 = EDGE_CURVE('',#4120,#4208,#4210,.T.);
#4208 = VERTEX_POINT('',#4209);
#4209 = CARTESIAN_POINT('',(-0.3,-4.375,8.2));
#4210 = SURFACE_CURVE('',#4211,(#4215,#4222),.PCURVE_S1.);
#4211 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4212,#4213,#4214),
#4212 = CARTESIAN_POINT('',(6.4E-02,-3.776,8.2));
#4213 = CARTESIAN_POINT('',(6.4E-02,-4.316,8.2));
#4214 = CARTESIAN_POINT('',(-0.3,-4.375,8.2));
#4215 = PCURVE('',#4163,#4216);
#4216 = DEFINITIONAL_REPRESENTATION('',(#4217),#4221);
#4217 = LINE('',#4218,#4219);
#4218 = CARTESIAN_POINT('',(0.,-0.2));
#4219 = VECTOR('',#4220,1.);
#4220 = DIRECTION('',(1.,0.));
#4221 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4222 = PCURVE('',#4135,#4223);
#4223 = DEFINITIONAL_REPRESENTATION('',(#4224),#4228);
#4224 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4225,#4226,#4227),
#4225 = CARTESIAN_POINT('',(2.93211720483E-02,0.826682722252));
#4226 = CARTESIAN_POINT('',(-0.510678827952,0.826682722252));
#4227 = CARTESIAN_POINT('',(-0.569678827952,0.462682722252));
#4228 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4229 = ORIENTED_EDGE('',*,*,#4230,.F.);
#4230 = EDGE_CURVE('',#4231,#4208,#4233,.T.);
#4231 = VERTEX_POINT('',#4232);
#4232 = CARTESIAN_POINT('',(-0.3,-4.375,8.));
#4233 = SURFACE_CURVE('',#4234,(#4238,#4245),.PCURVE_S1.);
#4234 = LINE('',#4235,#4236);
#4235 = CARTESIAN_POINT('',(-0.3,-4.375,8.));
#4236 = VECTOR('',#4237,1.);
#4237 = DIRECTION('',(0.,0.,1.));
#4238 = PCURVE('',#4163,#4239);
#4239 = DEFINITIONAL_REPRESENTATION('',(#4240),#4244);
#4240 = LINE('',#4241,#4242);
#4241 = CARTESIAN_POINT('',(1.,0.));
#4242 = VECTOR('',#4243,1.);
#4243 = DIRECTION('',(0.,-1.));
#4244 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4245 = PCURVE('',#4246,#4253);
#4246 = SURFACE_OF_LINEAR_EXTRUSION('',#4247,#4251);
#4247 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4248,#4249,#4250),
#4248 = CARTESIAN_POINT('',(-0.3,-4.375,8.));
#4249 = CARTESIAN_POINT('',(-0.341,-4.381,8.));
#4250 = CARTESIAN_POINT('',(-0.385,-4.381,8.));
#4251 = VECTOR('',#4252,1.);
#4252 = DIRECTION('',(-0.,-0.,-1.));
#4253 = DEFINITIONAL_REPRESENTATION('',(#4254),#4258);
#4254 = LINE('',#4255,#4256);
#4255 = CARTESIAN_POINT('',(0.,0.));
#4256 = VECTOR('',#4257,1.);
#4257 = DIRECTION('',(0.,-1.));
#4258 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4259 = ORIENTED_EDGE('',*,*,#4260,.F.);
#4260 = EDGE_CURVE('',#4148,#4231,#4261,.T.);
#4261 = SURFACE_CURVE('',#4262,(#4266,#4273),.PCURVE_S1.);
#4262 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4263,#4264,#4265),
#4263 = CARTESIAN_POINT('',(6.4E-02,-3.776,8.));
#4264 = CARTESIAN_POINT('',(6.4E-02,-4.316,8.));
#4265 = CARTESIAN_POINT('',(-0.3,-4.375,8.));
#4266 = PCURVE('',#4163,#4267);
#4267 = DEFINITIONAL_REPRESENTATION('',(#4268),#4272);
#4268 = LINE('',#4269,#4270);
#4269 = CARTESIAN_POINT('',(0.,0.));
#4270 = VECTOR('',#4271,1.);
#4271 = DIRECTION('',(1.,0.));
#4272 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4273 = PCURVE('',#4191,#4274);
#4274 = DEFINITIONAL_REPRESENTATION('',(#4275),#4279);
#4275 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4276,#4277,#4278),
#4276 = CARTESIAN_POINT('',(2.93211720483E-02,0.826682722252));
#4277 = CARTESIAN_POINT('',(-0.510678827952,0.826682722252));
#4278 = CARTESIAN_POINT('',(-0.569678827952,0.462682722252));
#4279 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4280 = ADVANCED_FACE('',(#4281),#4246,.T.);
#4281 = FACE_BOUND('',#4282,.T.);
#4282 = EDGE_LOOP('',(#4283,#4284,#4307,#4335));
#4283 = ORIENTED_EDGE('',*,*,#4230,.T.);
#4284 = ORIENTED_EDGE('',*,*,#4285,.T.);
#4285 = EDGE_CURVE('',#4208,#4286,#4288,.T.);
#4286 = VERTEX_POINT('',#4287);
#4287 = CARTESIAN_POINT('',(-0.385,-4.381,8.2));
#4288 = SURFACE_CURVE('',#4289,(#4293,#4300),.PCURVE_S1.);
#4289 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4290,#4291,#4292),
#4290 = CARTESIAN_POINT('',(-0.3,-4.375,8.2));
#4291 = CARTESIAN_POINT('',(-0.341,-4.381,8.2));
#4292 = CARTESIAN_POINT('',(-0.385,-4.381,8.2));
#4293 = PCURVE('',#4246,#4294);
#4294 = DEFINITIONAL_REPRESENTATION('',(#4295),#4299);
#4295 = LINE('',#4296,#4297);
#4296 = CARTESIAN_POINT('',(0.,-0.2));
#4297 = VECTOR('',#4298,1.);
#4298 = DIRECTION('',(1.,0.));
#4299 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4300 = PCURVE('',#4135,#4301);
#4301 = DEFINITIONAL_REPRESENTATION('',(#4302),#4306);
#4302 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4303,#4304,#4305),
#4303 = CARTESIAN_POINT('',(-0.569678827952,0.462682722252));
#4304 = CARTESIAN_POINT('',(-0.575678827952,0.421682722252));
#4305 = CARTESIAN_POINT('',(-0.575678827952,0.377682722252));
#4306 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4307 = ORIENTED_EDGE('',*,*,#4308,.F.);
#4308 = EDGE_CURVE('',#4309,#4286,#4311,.T.);
#4309 = VERTEX_POINT('',#4310);
#4310 = CARTESIAN_POINT('',(-0.385,-4.381,8.));
#4311 = SURFACE_CURVE('',#4312,(#4316,#4323),.PCURVE_S1.);
#4312 = LINE('',#4313,#4314);
#4313 = CARTESIAN_POINT('',(-0.385,-4.381,8.));
#4314 = VECTOR('',#4315,1.);
#4315 = DIRECTION('',(0.,0.,1.));
#4316 = PCURVE('',#4246,#4317);
#4317 = DEFINITIONAL_REPRESENTATION('',(#4318),#4322);
#4318 = LINE('',#4319,#4320);
#4319 = CARTESIAN_POINT('',(1.,0.));
#4320 = VECTOR('',#4321,1.);
#4321 = DIRECTION('',(0.,-1.));
#4322 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4323 = PCURVE('',#4324,#4329);
#4324 = PLANE('',#4325);
#4325 = AXIS2_PLACEMENT_3D('',#4326,#4327,#4328);
#4326 = CARTESIAN_POINT('',(-0.385,-4.381,8.));
#4327 = DIRECTION('',(-2.2E-16,-1.,0.));
#4328 = DIRECTION('',(-1.,2.2E-16,0.));
#4329 = DEFINITIONAL_REPRESENTATION('',(#4330),#4334);
#4330 = LINE('',#4331,#4332);
#4331 = CARTESIAN_POINT('',(1.1E-16,0.));
#4332 = VECTOR('',#4333,1.);
#4333 = DIRECTION('',(0.,-1.));
#4334 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4335 = ORIENTED_EDGE('',*,*,#4336,.F.);
#4336 = EDGE_CURVE('',#4231,#4309,#4337,.T.);
#4337 = SURFACE_CURVE('',#4338,(#4342,#4349),.PCURVE_S1.);
#4338 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4339,#4340,#4341),
#4339 = CARTESIAN_POINT('',(-0.3,-4.375,8.));
#4340 = CARTESIAN_POINT('',(-0.341,-4.381,8.));
#4341 = CARTESIAN_POINT('',(-0.385,-4.381,8.));
#4342 = PCURVE('',#4246,#4343);
#4343 = DEFINITIONAL_REPRESENTATION('',(#4344),#4348);
#4344 = LINE('',#4345,#4346);
#4345 = CARTESIAN_POINT('',(0.,0.));
#4346 = VECTOR('',#4347,1.);
#4347 = DIRECTION('',(1.,0.));
#4348 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4349 = PCURVE('',#4191,#4350);
#4350 = DEFINITIONAL_REPRESENTATION('',(#4351),#4355);
#4351 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4352,#4353,#4354),
#4352 = CARTESIAN_POINT('',(-0.569678827952,0.462682722252));
#4353 = CARTESIAN_POINT('',(-0.575678827952,0.421682722252));
#4354 = CARTESIAN_POINT('',(-0.575678827952,0.377682722252));
#4355 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4356 = ADVANCED_FACE('',(#4357),#4324,.T.);
#4357 = FACE_BOUND('',#4358,.T.);
#4358 = EDGE_LOOP('',(#4359,#4360,#4383,#4413));
#4359 = ORIENTED_EDGE('',*,*,#4308,.T.);
#4360 = ORIENTED_EDGE('',*,*,#4361,.T.);
#4361 = EDGE_CURVE('',#4286,#4362,#4364,.T.);
#4362 = VERTEX_POINT('',#4363);
#4363 = CARTESIAN_POINT('',(-1.288,-4.381,8.2));
#4364 = SURFACE_CURVE('',#4365,(#4369,#4376),.PCURVE_S1.);
#4365 = LINE('',#4366,#4367);
#4366 = CARTESIAN_POINT('',(-0.385,-4.381,8.2));
#4367 = VECTOR('',#4368,1.);
#4368 = DIRECTION('',(-1.,0.,0.));
#4369 = PCURVE('',#4324,#4370);
#4370 = DEFINITIONAL_REPRESENTATION('',(#4371),#4375);
#4371 = LINE('',#4372,#4373);
#4372 = CARTESIAN_POINT('',(0.,-0.2));
#4373 = VECTOR('',#4374,1.);
#4374 = DIRECTION('',(1.,0.));
#4375 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4376 = PCURVE('',#4135,#4377);
#4377 = DEFINITIONAL_REPRESENTATION('',(#4378),#4382);
#4378 = LINE('',#4379,#4380);
#4379 = CARTESIAN_POINT('',(-0.575678827952,0.377682722252));
#4380 = VECTOR('',#4381,1.);
#4381 = DIRECTION('',(0.,-1.));
#4382 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4383 = ORIENTED_EDGE('',*,*,#4384,.F.);
#4384 = EDGE_CURVE('',#4385,#4362,#4387,.T.);
#4385 = VERTEX_POINT('',#4386);
#4386 = CARTESIAN_POINT('',(-1.288,-4.381,8.));
#4387 = SURFACE_CURVE('',#4388,(#4392,#4399),.PCURVE_S1.);
#4388 = LINE('',#4389,#4390);
#4389 = CARTESIAN_POINT('',(-1.288,-4.381,8.));
#4390 = VECTOR('',#4391,1.);
#4391 = DIRECTION('',(0.,0.,1.));
#4392 = PCURVE('',#4324,#4393);
#4393 = DEFINITIONAL_REPRESENTATION('',(#4394),#4398);
#4394 = LINE('',#4395,#4396);
#4395 = CARTESIAN_POINT('',(0.903,0.));
#4396 = VECTOR('',#4397,1.);
#4397 = DIRECTION('',(0.,-1.));
#4398 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4399 = PCURVE('',#4400,#4407);
#4400 = SURFACE_OF_LINEAR_EXTRUSION('',#4401,#4405);
#4401 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4402,#4403,#4404),
#4402 = CARTESIAN_POINT('',(-1.288,-4.381,8.));
#4403 = CARTESIAN_POINT('',(-1.405,-4.387,8.));
#4404 = CARTESIAN_POINT('',(-1.408,-4.519,8.));
#4405 = VECTOR('',#4406,1.);
#4406 = DIRECTION('',(-0.,-0.,-1.));
#4407 = DEFINITIONAL_REPRESENTATION('',(#4408),#4412);
#4408 = LINE('',#4409,#4410);
#4409 = CARTESIAN_POINT('',(0.,0.));
#4410 = VECTOR('',#4411,1.);
#4411 = DIRECTION('',(0.,-1.));
#4412 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4413 = ORIENTED_EDGE('',*,*,#4414,.F.);
#4414 = EDGE_CURVE('',#4309,#4385,#4415,.T.);
#4415 = SURFACE_CURVE('',#4416,(#4420,#4427),.PCURVE_S1.);
#4416 = LINE('',#4417,#4418);
#4417 = CARTESIAN_POINT('',(-0.385,-4.381,8.));
#4418 = VECTOR('',#4419,1.);
#4419 = DIRECTION('',(-1.,0.,0.));
#4420 = PCURVE('',#4324,#4421);
#4421 = DEFINITIONAL_REPRESENTATION('',(#4422),#4426);
#4422 = LINE('',#4423,#4424);
#4423 = CARTESIAN_POINT('',(0.,0.));
#4424 = VECTOR('',#4425,1.);
#4425 = DIRECTION('',(1.,0.));
#4426 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4427 = PCURVE('',#4191,#4428);
#4428 = DEFINITIONAL_REPRESENTATION('',(#4429),#4433);
#4429 = LINE('',#4430,#4431);
#4430 = CARTESIAN_POINT('',(-0.575678827952,0.377682722252));
#4431 = VECTOR('',#4432,1.);
#4432 = DIRECTION('',(0.,-1.));
#4433 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4434 = ADVANCED_FACE('',(#4435),#4400,.T.);
#4435 = FACE_BOUND('',#4436,.T.);
#4436 = EDGE_LOOP('',(#4437,#4438,#4461,#4491));
#4437 = ORIENTED_EDGE('',*,*,#4384,.T.);
#4438 = ORIENTED_EDGE('',*,*,#4439,.T.);
#4439 = EDGE_CURVE('',#4362,#4440,#4442,.T.);
#4440 = VERTEX_POINT('',#4441);
#4441 = CARTESIAN_POINT('',(-1.408,-4.519,8.2));
#4442 = SURFACE_CURVE('',#4443,(#4447,#4454),.PCURVE_S1.);
#4443 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4444,#4445,#4446),
#4444 = CARTESIAN_POINT('',(-1.288,-4.381,8.2));
#4445 = CARTESIAN_POINT('',(-1.405,-4.387,8.2));
#4446 = CARTESIAN_POINT('',(-1.408,-4.519,8.2));
#4447 = PCURVE('',#4400,#4448);
#4448 = DEFINITIONAL_REPRESENTATION('',(#4449),#4453);
#4449 = LINE('',#4450,#4451);
#4450 = CARTESIAN_POINT('',(0.,-0.2));
#4451 = VECTOR('',#4452,1.);
#4452 = DIRECTION('',(1.,0.));
#4453 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4454 = PCURVE('',#4135,#4455);
#4455 = DEFINITIONAL_REPRESENTATION('',(#4456),#4460);
#4456 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4457,#4458,#4459),
#4457 = CARTESIAN_POINT('',(-0.575678827952,-0.525317277748));
#4458 = CARTESIAN_POINT('',(-0.581678827952,-0.642317277748));
#4459 = CARTESIAN_POINT('',(-0.713678827952,-0.645317277748));
#4460 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4461 = ORIENTED_EDGE('',*,*,#4462,.F.);
#4462 = EDGE_CURVE('',#4463,#4440,#4465,.T.);
#4463 = VERTEX_POINT('',#4464);
#4464 = CARTESIAN_POINT('',(-1.408,-4.519,8.));
#4465 = SURFACE_CURVE('',#4466,(#4470,#4477),.PCURVE_S1.);
#4466 = LINE('',#4467,#4468);
#4467 = CARTESIAN_POINT('',(-1.408,-4.519,8.));
#4468 = VECTOR('',#4469,1.);
#4469 = DIRECTION('',(0.,0.,1.));
#4470 = PCURVE('',#4400,#4471);
#4471 = DEFINITIONAL_REPRESENTATION('',(#4472),#4476);
#4472 = LINE('',#4473,#4474);
#4473 = CARTESIAN_POINT('',(1.,0.));
#4474 = VECTOR('',#4475,1.);
#4475 = DIRECTION('',(0.,-1.));
#4476 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4477 = PCURVE('',#4478,#4485);
#4478 = SURFACE_OF_LINEAR_EXTRUSION('',#4479,#4483);
#4479 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4480,#4481,#4482),
#4480 = CARTESIAN_POINT('',(-1.408,-4.519,8.));
#4481 = CARTESIAN_POINT('',(-1.408,-4.55,8.));
#4482 = CARTESIAN_POINT('',(-1.401,-4.575,8.));
#4483 = VECTOR('',#4484,1.);
#4484 = DIRECTION('',(-0.,-0.,-1.));
#4485 = DEFINITIONAL_REPRESENTATION('',(#4486),#4490);
#4486 = LINE('',#4487,#4488);
#4487 = CARTESIAN_POINT('',(0.,0.));
#4488 = VECTOR('',#4489,1.);
#4489 = DIRECTION('',(0.,-1.));
#4490 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4491 = ORIENTED_EDGE('',*,*,#4492,.F.);
#4492 = EDGE_CURVE('',#4385,#4463,#4493,.T.);
#4493 = SURFACE_CURVE('',#4494,(#4498,#4505),.PCURVE_S1.);
#4494 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4495,#4496,#4497),
#4495 = CARTESIAN_POINT('',(-1.288,-4.381,8.));
#4496 = CARTESIAN_POINT('',(-1.405,-4.387,8.));
#4497 = CARTESIAN_POINT('',(-1.408,-4.519,8.));
#4498 = PCURVE('',#4400,#4499);
#4499 = DEFINITIONAL_REPRESENTATION('',(#4500),#4504);
#4500 = LINE('',#4501,#4502);
#4501 = CARTESIAN_POINT('',(0.,0.));
#4502 = VECTOR('',#4503,1.);
#4503 = DIRECTION('',(1.,0.));
#4504 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4505 = PCURVE('',#4191,#4506);
#4506 = DEFINITIONAL_REPRESENTATION('',(#4507),#4511);
#4507 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4508,#4509,#4510),
#4508 = CARTESIAN_POINT('',(-0.575678827952,-0.525317277748));
#4509 = CARTESIAN_POINT('',(-0.581678827952,-0.642317277748));
#4510 = CARTESIAN_POINT('',(-0.713678827952,-0.645317277748));
#4511 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4512 = ADVANCED_FACE('',(#4513),#4478,.T.);
#4513 = FACE_BOUND('',#4514,.T.);
#4514 = EDGE_LOOP('',(#4515,#4516,#4539,#4567));
#4515 = ORIENTED_EDGE('',*,*,#4462,.T.);
#4516 = ORIENTED_EDGE('',*,*,#4517,.T.);
#4517 = EDGE_CURVE('',#4440,#4518,#4520,.T.);
#4518 = VERTEX_POINT('',#4519);
#4519 = CARTESIAN_POINT('',(-1.401,-4.575,8.2));
#4520 = SURFACE_CURVE('',#4521,(#4525,#4532),.PCURVE_S1.);
#4521 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4522,#4523,#4524),
#4522 = CARTESIAN_POINT('',(-1.408,-4.519,8.2));
#4523 = CARTESIAN_POINT('',(-1.408,-4.55,8.2));
#4524 = CARTESIAN_POINT('',(-1.401,-4.575,8.2));
#4525 = PCURVE('',#4478,#4526);
#4526 = DEFINITIONAL_REPRESENTATION('',(#4527),#4531);
#4527 = LINE('',#4528,#4529);
#4528 = CARTESIAN_POINT('',(0.,-0.2));
#4529 = VECTOR('',#4530,1.);
#4530 = DIRECTION('',(1.,0.));
#4531 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4532 = PCURVE('',#4135,#4533);
#4533 = DEFINITIONAL_REPRESENTATION('',(#4534),#4538);
#4534 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4535,#4536,#4537),
#4535 = CARTESIAN_POINT('',(-0.713678827952,-0.645317277748));
#4536 = CARTESIAN_POINT('',(-0.744678827952,-0.645317277748));
#4537 = CARTESIAN_POINT('',(-0.769678827952,-0.638317277748));
#4538 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4539 = ORIENTED_EDGE('',*,*,#4540,.F.);
#4540 = EDGE_CURVE('',#4541,#4518,#4543,.T.);
#4541 = VERTEX_POINT('',#4542);
#4542 = CARTESIAN_POINT('',(-1.401,-4.575,8.));
#4543 = SURFACE_CURVE('',#4544,(#4548,#4555),.PCURVE_S1.);
#4544 = LINE('',#4545,#4546);
#4545 = CARTESIAN_POINT('',(-1.401,-4.575,8.));
#4546 = VECTOR('',#4547,1.);
#4547 = DIRECTION('',(0.,0.,1.));
#4548 = PCURVE('',#4478,#4549);
#4549 = DEFINITIONAL_REPRESENTATION('',(#4550),#4554);
#4550 = LINE('',#4551,#4552);
#4551 = CARTESIAN_POINT('',(1.,0.));
#4552 = VECTOR('',#4553,1.);
#4553 = DIRECTION('',(0.,-1.));
#4554 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4555 = PCURVE('',#4556,#4561);
#4556 = PLANE('',#4557);
#4557 = AXIS2_PLACEMENT_3D('',#4558,#4559,#4560);
#4558 = CARTESIAN_POINT('',(-1.401,-4.575,8.));
#4559 = DIRECTION('',(-2.2E-16,-1.,0.));
#4560 = DIRECTION('',(-1.,2.2E-16,0.));
#4561 = DEFINITIONAL_REPRESENTATION('',(#4562),#4566);
#4562 = LINE('',#4563,#4564);
#4563 = CARTESIAN_POINT('',(-8.9E-16,0.));
#4564 = VECTOR('',#4565,1.);
#4565 = DIRECTION('',(0.,-1.));
#4566 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4567 = ORIENTED_EDGE('',*,*,#4568,.F.);
#4568 = EDGE_CURVE('',#4463,#4541,#4569,.T.);
#4569 = SURFACE_CURVE('',#4570,(#4574,#4581),.PCURVE_S1.);
#4570 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4571,#4572,#4573),
#4571 = CARTESIAN_POINT('',(-1.408,-4.519,8.));
#4572 = CARTESIAN_POINT('',(-1.408,-4.55,8.));
#4573 = CARTESIAN_POINT('',(-1.401,-4.575,8.));
#4574 = PCURVE('',#4478,#4575);
#4575 = DEFINITIONAL_REPRESENTATION('',(#4576),#4580);
#4576 = LINE('',#4577,#4578);
#4577 = CARTESIAN_POINT('',(0.,0.));
#4578 = VECTOR('',#4579,1.);
#4579 = DIRECTION('',(1.,0.));
#4580 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4581 = PCURVE('',#4191,#4582);
#4582 = DEFINITIONAL_REPRESENTATION('',(#4583),#4587);
#4583 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4584,#4585,#4586),
#4584 = CARTESIAN_POINT('',(-0.713678827952,-0.645317277748));
#4585 = CARTESIAN_POINT('',(-0.744678827952,-0.645317277748));
#4586 = CARTESIAN_POINT('',(-0.769678827952,-0.638317277748));
#4587 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4588 = ADVANCED_FACE('',(#4589),#4556,.T.);
#4589 = FACE_BOUND('',#4590,.T.);
#4590 = EDGE_LOOP('',(#4591,#4592,#4615,#4645));
#4591 = ORIENTED_EDGE('',*,*,#4540,.T.);
#4592 = ORIENTED_EDGE('',*,*,#4593,.T.);
#4593 = EDGE_CURVE('',#4518,#4594,#4596,.T.);
#4594 = VERTEX_POINT('',#4595);
#4595 = CARTESIAN_POINT('',(-1.631,-4.575,8.2));
#4596 = SURFACE_CURVE('',#4597,(#4601,#4608),.PCURVE_S1.);
#4597 = LINE('',#4598,#4599);
#4598 = CARTESIAN_POINT('',(-1.401,-4.575,8.2));
#4599 = VECTOR('',#4600,1.);
#4600 = DIRECTION('',(-1.,0.,0.));
#4601 = PCURVE('',#4556,#4602);
#4602 = DEFINITIONAL_REPRESENTATION('',(#4603),#4607);
#4603 = LINE('',#4604,#4605);
#4604 = CARTESIAN_POINT('',(0.,-0.2));
#4605 = VECTOR('',#4606,1.);
#4606 = DIRECTION('',(1.,0.));
#4607 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4608 = PCURVE('',#4135,#4609);
#4609 = DEFINITIONAL_REPRESENTATION('',(#4610),#4614);
#4610 = LINE('',#4611,#4612);
#4611 = CARTESIAN_POINT('',(-0.769678827952,-0.638317277748));
#4612 = VECTOR('',#4613,1.);
#4613 = DIRECTION('',(0.,-1.));
#4614 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4615 = ORIENTED_EDGE('',*,*,#4616,.F.);
#4616 = EDGE_CURVE('',#4617,#4594,#4619,.T.);
#4617 = VERTEX_POINT('',#4618);
#4618 = CARTESIAN_POINT('',(-1.631,-4.575,8.));
#4619 = SURFACE_CURVE('',#4620,(#4624,#4631),.PCURVE_S1.);
#4620 = LINE('',#4621,#4622);
#4621 = CARTESIAN_POINT('',(-1.631,-4.575,8.));
#4622 = VECTOR('',#4623,1.);
#4623 = DIRECTION('',(0.,0.,1.));
#4624 = PCURVE('',#4556,#4625);
#4625 = DEFINITIONAL_REPRESENTATION('',(#4626),#4630);
#4626 = LINE('',#4627,#4628);
#4627 = CARTESIAN_POINT('',(0.23,0.));
#4628 = VECTOR('',#4629,1.);
#4629 = DIRECTION('',(0.,-1.));
#4630 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4631 = PCURVE('',#4632,#4639);
#4632 = SURFACE_OF_LINEAR_EXTRUSION('',#4633,#4637);
#4633 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4634,#4635,#4636),
#4634 = CARTESIAN_POINT('',(-1.631,-4.575,8.));
#4635 = CARTESIAN_POINT('',(-1.664,-4.467,8.));
#4636 = CARTESIAN_POINT('',(-1.664,-4.4,8.));
#4637 = VECTOR('',#4638,1.);
#4638 = DIRECTION('',(-0.,-0.,-1.));
#4639 = DEFINITIONAL_REPRESENTATION('',(#4640),#4644);
#4640 = LINE('',#4641,#4642);
#4641 = CARTESIAN_POINT('',(0.,0.));
#4642 = VECTOR('',#4643,1.);
#4643 = DIRECTION('',(0.,-1.));
#4644 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4645 = ORIENTED_EDGE('',*,*,#4646,.F.);
#4646 = EDGE_CURVE('',#4541,#4617,#4647,.T.);
#4647 = SURFACE_CURVE('',#4648,(#4652,#4659),.PCURVE_S1.);
#4648 = LINE('',#4649,#4650);
#4649 = CARTESIAN_POINT('',(-1.401,-4.575,8.));
#4650 = VECTOR('',#4651,1.);
#4651 = DIRECTION('',(-1.,0.,0.));
#4652 = PCURVE('',#4556,#4653);
#4653 = DEFINITIONAL_REPRESENTATION('',(#4654),#4658);
#4654 = LINE('',#4655,#4656);
#4655 = CARTESIAN_POINT('',(0.,0.));
#4656 = VECTOR('',#4657,1.);
#4657 = DIRECTION('',(1.,0.));
#4658 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4659 = PCURVE('',#4191,#4660);
#4660 = DEFINITIONAL_REPRESENTATION('',(#4661),#4665);
#4661 = LINE('',#4662,#4663);
#4662 = CARTESIAN_POINT('',(-0.769678827952,-0.638317277748));
#4663 = VECTOR('',#4664,1.);
#4664 = DIRECTION('',(0.,-1.));
#4665 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4666 = ADVANCED_FACE('',(#4667),#4632,.T.);
#4667 = FACE_BOUND('',#4668,.T.);
#4668 = EDGE_LOOP('',(#4669,#4670,#4693,#4723));
#4669 = ORIENTED_EDGE('',*,*,#4616,.T.);
#4670 = ORIENTED_EDGE('',*,*,#4671,.T.);
#4671 = EDGE_CURVE('',#4594,#4672,#4674,.T.);
#4672 = VERTEX_POINT('',#4673);
#4673 = CARTESIAN_POINT('',(-1.664,-4.4,8.2));
#4674 = SURFACE_CURVE('',#4675,(#4679,#4686),.PCURVE_S1.);
#4675 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4676,#4677,#4678),
#4676 = CARTESIAN_POINT('',(-1.631,-4.575,8.2));
#4677 = CARTESIAN_POINT('',(-1.664,-4.467,8.2));
#4678 = CARTESIAN_POINT('',(-1.664,-4.4,8.2));
#4679 = PCURVE('',#4632,#4680);
#4680 = DEFINITIONAL_REPRESENTATION('',(#4681),#4685);
#4681 = LINE('',#4682,#4683);
#4682 = CARTESIAN_POINT('',(0.,-0.2));
#4683 = VECTOR('',#4684,1.);
#4684 = DIRECTION('',(1.,0.));
#4685 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4686 = PCURVE('',#4135,#4687);
#4687 = DEFINITIONAL_REPRESENTATION('',(#4688),#4692);
#4688 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4689,#4690,#4691),
#4689 = CARTESIAN_POINT('',(-0.769678827952,-0.868317277748));
#4690 = CARTESIAN_POINT('',(-0.661678827952,-0.901317277748));
#4691 = CARTESIAN_POINT('',(-0.594678827952,-0.901317277748));
#4692 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4693 = ORIENTED_EDGE('',*,*,#4694,.F.);
#4694 = EDGE_CURVE('',#4695,#4672,#4697,.T.);
#4695 = VERTEX_POINT('',#4696);
#4696 = CARTESIAN_POINT('',(-1.664,-4.4,8.));
#4697 = SURFACE_CURVE('',#4698,(#4702,#4709),.PCURVE_S1.);
#4698 = LINE('',#4699,#4700);
#4699 = CARTESIAN_POINT('',(-1.664,-4.4,8.));
#4700 = VECTOR('',#4701,1.);
#4701 = DIRECTION('',(0.,0.,1.));
#4702 = PCURVE('',#4632,#4703);
#4703 = DEFINITIONAL_REPRESENTATION('',(#4704),#4708);
#4704 = LINE('',#4705,#4706);
#4705 = CARTESIAN_POINT('',(1.,0.));
#4706 = VECTOR('',#4707,1.);
#4707 = DIRECTION('',(0.,-1.));
#4708 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4709 = PCURVE('',#4710,#4717);
#4710 = SURFACE_OF_LINEAR_EXTRUSION('',#4711,#4715);
#4711 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4712,#4713,#4714),
#4712 = CARTESIAN_POINT('',(-1.664,-4.4,8.));
#4713 = CARTESIAN_POINT('',(-1.664,-4.181,8.));
#4714 = CARTESIAN_POINT('',(-1.437,-4.141,8.));
#4715 = VECTOR('',#4716,1.);
#4716 = DIRECTION('',(-0.,-0.,-1.));
#4717 = DEFINITIONAL_REPRESENTATION('',(#4718),#4722);
#4718 = LINE('',#4719,#4720);
#4719 = CARTESIAN_POINT('',(0.,0.));
#4720 = VECTOR('',#4721,1.);
#4721 = DIRECTION('',(0.,-1.));
#4722 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4723 = ORIENTED_EDGE('',*,*,#4724,.F.);
#4724 = EDGE_CURVE('',#4617,#4695,#4725,.T.);
#4725 = SURFACE_CURVE('',#4726,(#4730,#4737),.PCURVE_S1.);
#4726 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4727,#4728,#4729),
#4727 = CARTESIAN_POINT('',(-1.631,-4.575,8.));
#4728 = CARTESIAN_POINT('',(-1.664,-4.467,8.));
#4729 = CARTESIAN_POINT('',(-1.664,-4.4,8.));
#4730 = PCURVE('',#4632,#4731);
#4731 = DEFINITIONAL_REPRESENTATION('',(#4732),#4736);
#4732 = LINE('',#4733,#4734);
#4733 = CARTESIAN_POINT('',(0.,0.));
#4734 = VECTOR('',#4735,1.);
#4735 = DIRECTION('',(1.,0.));
#4736 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4737 = PCURVE('',#4191,#4738);
#4738 = DEFINITIONAL_REPRESENTATION('',(#4739),#4743);
#4739 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4740,#4741,#4742),
#4740 = CARTESIAN_POINT('',(-0.769678827952,-0.868317277748));
#4741 = CARTESIAN_POINT('',(-0.661678827952,-0.901317277748));
#4742 = CARTESIAN_POINT('',(-0.594678827952,-0.901317277748));
#4743 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4744 = ADVANCED_FACE('',(#4745),#4710,.T.);
#4745 = FACE_BOUND('',#4746,.T.);
#4746 = EDGE_LOOP('',(#4747,#4748,#4771,#4801));
#4747 = ORIENTED_EDGE('',*,*,#4694,.T.);
#4748 = ORIENTED_EDGE('',*,*,#4749,.T.);
#4749 = EDGE_CURVE('',#4672,#4750,#4752,.T.);
#4750 = VERTEX_POINT('',#4751);
#4751 = CARTESIAN_POINT('',(-1.437,-4.141,8.2));
#4752 = SURFACE_CURVE('',#4753,(#4757,#4764),.PCURVE_S1.);
#4753 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4754,#4755,#4756),
#4754 = CARTESIAN_POINT('',(-1.664,-4.4,8.2));
#4755 = CARTESIAN_POINT('',(-1.664,-4.181,8.2));
#4756 = CARTESIAN_POINT('',(-1.437,-4.141,8.2));
#4757 = PCURVE('',#4710,#4758);
#4758 = DEFINITIONAL_REPRESENTATION('',(#4759),#4763);
#4759 = LINE('',#4760,#4761);
#4760 = CARTESIAN_POINT('',(0.,-0.2));
#4761 = VECTOR('',#4762,1.);
#4762 = DIRECTION('',(1.,0.));
#4763 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4764 = PCURVE('',#4135,#4765);
#4765 = DEFINITIONAL_REPRESENTATION('',(#4766),#4770);
#4766 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4767,#4768,#4769),
#4767 = CARTESIAN_POINT('',(-0.594678827952,-0.901317277748));
#4768 = CARTESIAN_POINT('',(-0.375678827952,-0.901317277748));
#4769 = CARTESIAN_POINT('',(-0.335678827952,-0.674317277748));
#4770 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4771 = ORIENTED_EDGE('',*,*,#4772,.F.);
#4772 = EDGE_CURVE('',#4773,#4750,#4775,.T.);
#4773 = VERTEX_POINT('',#4774);
#4774 = CARTESIAN_POINT('',(-1.437,-4.141,8.));
#4775 = SURFACE_CURVE('',#4776,(#4780,#4787),.PCURVE_S1.);
#4776 = LINE('',#4777,#4778);
#4777 = CARTESIAN_POINT('',(-1.437,-4.141,8.));
#4778 = VECTOR('',#4779,1.);
#4779 = DIRECTION('',(0.,0.,1.));
#4780 = PCURVE('',#4710,#4781);
#4781 = DEFINITIONAL_REPRESENTATION('',(#4782),#4786);
#4782 = LINE('',#4783,#4784);
#4783 = CARTESIAN_POINT('',(1.,0.));
#4784 = VECTOR('',#4785,1.);
#4785 = DIRECTION('',(0.,-1.));
#4786 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4787 = PCURVE('',#4788,#4795);
#4788 = SURFACE_OF_LINEAR_EXTRUSION('',#4789,#4793);
#4789 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4790,#4791,#4792),
#4790 = CARTESIAN_POINT('',(-1.437,-4.141,8.));
#4791 = CARTESIAN_POINT('',(-1.412,-4.138,8.));
#4792 = CARTESIAN_POINT('',(-1.387,-4.135,8.));
#4793 = VECTOR('',#4794,1.);
#4794 = DIRECTION('',(-0.,-0.,-1.));
#4795 = DEFINITIONAL_REPRESENTATION('',(#4796),#4800);
#4796 = LINE('',#4797,#4798);
#4797 = CARTESIAN_POINT('',(0.,0.));
#4798 = VECTOR('',#4799,1.);
#4799 = DIRECTION('',(0.,-1.));
#4800 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4801 = ORIENTED_EDGE('',*,*,#4802,.F.);
#4802 = EDGE_CURVE('',#4695,#4773,#4803,.T.);
#4803 = SURFACE_CURVE('',#4804,(#4808,#4815),.PCURVE_S1.);
#4804 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4805,#4806,#4807),
#4805 = CARTESIAN_POINT('',(-1.664,-4.4,8.));
#4806 = CARTESIAN_POINT('',(-1.664,-4.181,8.));
#4807 = CARTESIAN_POINT('',(-1.437,-4.141,8.));
#4808 = PCURVE('',#4710,#4809);
#4809 = DEFINITIONAL_REPRESENTATION('',(#4810),#4814);
#4810 = LINE('',#4811,#4812);
#4811 = CARTESIAN_POINT('',(0.,0.));
#4812 = VECTOR('',#4813,1.);
#4813 = DIRECTION('',(1.,0.));
#4814 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4815 = PCURVE('',#4191,#4816);
#4816 = DEFINITIONAL_REPRESENTATION('',(#4817),#4821);
#4817 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4818,#4819,#4820),
#4818 = CARTESIAN_POINT('',(-0.594678827952,-0.901317277748));
#4819 = CARTESIAN_POINT('',(-0.375678827952,-0.901317277748));
#4820 = CARTESIAN_POINT('',(-0.335678827952,-0.674317277748));
#4821 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4822 = ADVANCED_FACE('',(#4823),#4788,.T.);
#4823 = FACE_BOUND('',#4824,.T.);
#4824 = EDGE_LOOP('',(#4825,#4826,#4849,#4879));
#4825 = ORIENTED_EDGE('',*,*,#4772,.T.);
#4826 = ORIENTED_EDGE('',*,*,#4827,.T.);
#4827 = EDGE_CURVE('',#4750,#4828,#4830,.T.);
#4828 = VERTEX_POINT('',#4829);
#4829 = CARTESIAN_POINT('',(-1.387,-4.135,8.2));
#4830 = SURFACE_CURVE('',#4831,(#4835,#4842),.PCURVE_S1.);
#4831 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4832,#4833,#4834),
#4832 = CARTESIAN_POINT('',(-1.437,-4.141,8.2));
#4833 = CARTESIAN_POINT('',(-1.412,-4.138,8.2));
#4834 = CARTESIAN_POINT('',(-1.387,-4.135,8.2));
#4835 = PCURVE('',#4788,#4836);
#4836 = DEFINITIONAL_REPRESENTATION('',(#4837),#4841);
#4837 = LINE('',#4838,#4839);
#4838 = CARTESIAN_POINT('',(0.,-0.2));
#4839 = VECTOR('',#4840,1.);
#4840 = DIRECTION('',(1.,0.));
#4841 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4842 = PCURVE('',#4135,#4843);
#4843 = DEFINITIONAL_REPRESENTATION('',(#4844),#4848);
#4844 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4845,#4846,#4847),
#4845 = CARTESIAN_POINT('',(-0.335678827952,-0.674317277748));
#4846 = CARTESIAN_POINT('',(-0.332678827952,-0.649317277748));
#4847 = CARTESIAN_POINT('',(-0.329678827952,-0.624317277748));
#4848 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4849 = ORIENTED_EDGE('',*,*,#4850,.F.);
#4850 = EDGE_CURVE('',#4851,#4828,#4853,.T.);
#4851 = VERTEX_POINT('',#4852);
#4852 = CARTESIAN_POINT('',(-1.387,-4.135,8.));
#4853 = SURFACE_CURVE('',#4854,(#4858,#4865),.PCURVE_S1.);
#4854 = LINE('',#4855,#4856);
#4855 = CARTESIAN_POINT('',(-1.387,-4.135,8.));
#4856 = VECTOR('',#4857,1.);
#4857 = DIRECTION('',(0.,0.,1.));
#4858 = PCURVE('',#4788,#4859);
#4859 = DEFINITIONAL_REPRESENTATION('',(#4860),#4864);
#4860 = LINE('',#4861,#4862);
#4861 = CARTESIAN_POINT('',(1.,0.));
#4862 = VECTOR('',#4863,1.);
#4863 = DIRECTION('',(0.,-1.));
#4864 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4865 = PCURVE('',#4866,#4873);
#4866 = SURFACE_OF_LINEAR_EXTRUSION('',#4867,#4871);
#4867 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4868,#4869,#4870),
#4868 = CARTESIAN_POINT('',(-1.387,-4.135,8.));
#4869 = CARTESIAN_POINT('',(-1.66,-3.868,8.));
#4870 = CARTESIAN_POINT('',(-1.664,-3.588,8.));
#4871 = VECTOR('',#4872,1.);
#4872 = DIRECTION('',(-0.,-0.,-1.));
#4873 = DEFINITIONAL_REPRESENTATION('',(#4874),#4878);
#4874 = LINE('',#4875,#4876);
#4875 = CARTESIAN_POINT('',(0.,0.));
#4876 = VECTOR('',#4877,1.);
#4877 = DIRECTION('',(0.,-1.));
#4878 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4879 = ORIENTED_EDGE('',*,*,#4880,.F.);
#4880 = EDGE_CURVE('',#4773,#4851,#4881,.T.);
#4881 = SURFACE_CURVE('',#4882,(#4886,#4893),.PCURVE_S1.);
#4882 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4883,#4884,#4885),
#4883 = CARTESIAN_POINT('',(-1.437,-4.141,8.));
#4884 = CARTESIAN_POINT('',(-1.412,-4.138,8.));
#4885 = CARTESIAN_POINT('',(-1.387,-4.135,8.));
#4886 = PCURVE('',#4788,#4887);
#4887 = DEFINITIONAL_REPRESENTATION('',(#4888),#4892);
#4888 = LINE('',#4889,#4890);
#4889 = CARTESIAN_POINT('',(0.,0.));
#4890 = VECTOR('',#4891,1.);
#4891 = DIRECTION('',(1.,0.));
#4892 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4893 = PCURVE('',#4191,#4894);
#4894 = DEFINITIONAL_REPRESENTATION('',(#4895),#4899);
#4895 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4896,#4897,#4898),
#4896 = CARTESIAN_POINT('',(-0.335678827952,-0.674317277748));
#4897 = CARTESIAN_POINT('',(-0.332678827952,-0.649317277748));
#4898 = CARTESIAN_POINT('',(-0.329678827952,-0.624317277748));
#4899 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4900 = ADVANCED_FACE('',(#4901),#4866,.T.);
#4901 = FACE_BOUND('',#4902,.T.);
#4902 = EDGE_LOOP('',(#4903,#4904,#4927,#4957));
#4903 = ORIENTED_EDGE('',*,*,#4850,.T.);
#4904 = ORIENTED_EDGE('',*,*,#4905,.T.);
#4905 = EDGE_CURVE('',#4828,#4906,#4908,.T.);
#4906 = VERTEX_POINT('',#4907);
#4907 = CARTESIAN_POINT('',(-1.664,-3.588,8.2));
#4908 = SURFACE_CURVE('',#4909,(#4913,#4920),.PCURVE_S1.);
#4909 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4910,#4911,#4912),
#4910 = CARTESIAN_POINT('',(-1.387,-4.135,8.2));
#4911 = CARTESIAN_POINT('',(-1.66,-3.868,8.2));
#4912 = CARTESIAN_POINT('',(-1.664,-3.588,8.2));
#4913 = PCURVE('',#4866,#4914);
#4914 = DEFINITIONAL_REPRESENTATION('',(#4915),#4919);
#4915 = LINE('',#4916,#4917);
#4916 = CARTESIAN_POINT('',(0.,-0.2));
#4917 = VECTOR('',#4918,1.);
#4918 = DIRECTION('',(1.,0.));
#4919 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4920 = PCURVE('',#4135,#4921);
#4921 = DEFINITIONAL_REPRESENTATION('',(#4922),#4926);
#4922 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4923,#4924,#4925),
#4923 = CARTESIAN_POINT('',(-0.329678827952,-0.624317277748));
#4924 = CARTESIAN_POINT('',(-6.26788279517E-02,-0.897317277748));
#4925 = CARTESIAN_POINT('',(0.217321172048,-0.901317277748));
#4926 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4927 = ORIENTED_EDGE('',*,*,#4928,.F.);
#4928 = EDGE_CURVE('',#4929,#4906,#4931,.T.);
#4929 = VERTEX_POINT('',#4930);
#4930 = CARTESIAN_POINT('',(-1.664,-3.588,8.));
#4931 = SURFACE_CURVE('',#4932,(#4936,#4943),.PCURVE_S1.);
#4932 = LINE('',#4933,#4934);
#4933 = CARTESIAN_POINT('',(-1.664,-3.588,8.));
#4934 = VECTOR('',#4935,1.);
#4935 = DIRECTION('',(0.,0.,1.));
#4936 = PCURVE('',#4866,#4937);
#4937 = DEFINITIONAL_REPRESENTATION('',(#4938),#4942);
#4938 = LINE('',#4939,#4940);
#4939 = CARTESIAN_POINT('',(1.,0.));
#4940 = VECTOR('',#4941,1.);
#4941 = DIRECTION('',(0.,-1.));
#4942 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4943 = PCURVE('',#4944,#4951);
#4944 = SURFACE_OF_LINEAR_EXTRUSION('',#4945,#4949);
#4945 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4946,#4947,#4948),
#4946 = CARTESIAN_POINT('',(-1.664,-3.588,8.));
#4947 = CARTESIAN_POINT('',(-1.664,-3.25,8.));
#4948 = CARTESIAN_POINT('',(-1.433,-3.118,8.));
#4949 = VECTOR('',#4950,1.);
#4950 = DIRECTION('',(-0.,-0.,-1.));
#4951 = DEFINITIONAL_REPRESENTATION('',(#4952),#4956);
#4952 = LINE('',#4953,#4954);
#4953 = CARTESIAN_POINT('',(0.,0.));
#4954 = VECTOR('',#4955,1.);
#4955 = DIRECTION('',(0.,-1.));
#4956 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4957 = ORIENTED_EDGE('',*,*,#4958,.F.);
#4958 = EDGE_CURVE('',#4851,#4929,#4959,.T.);
#4959 = SURFACE_CURVE('',#4960,(#4964,#4971),.PCURVE_S1.);
#4960 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4961,#4962,#4963),
#4961 = CARTESIAN_POINT('',(-1.387,-4.135,8.));
#4962 = CARTESIAN_POINT('',(-1.66,-3.868,8.));
#4963 = CARTESIAN_POINT('',(-1.664,-3.588,8.));
#4964 = PCURVE('',#4866,#4965);
#4965 = DEFINITIONAL_REPRESENTATION('',(#4966),#4970);
#4966 = LINE('',#4967,#4968);
#4967 = CARTESIAN_POINT('',(0.,0.));
#4968 = VECTOR('',#4969,1.);
#4969 = DIRECTION('',(1.,0.));
#4970 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4971 = PCURVE('',#4191,#4972);
#4972 = DEFINITIONAL_REPRESENTATION('',(#4973),#4977);
#4973 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4974,#4975,#4976),
#4974 = CARTESIAN_POINT('',(-0.329678827952,-0.624317277748));
#4975 = CARTESIAN_POINT('',(-6.26788279517E-02,-0.897317277748));
#4976 = CARTESIAN_POINT('',(0.217321172048,-0.901317277748));
#4977 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4978 = ADVANCED_FACE('',(#4979),#4944,.T.);
#4979 = FACE_BOUND('',#4980,.T.);
#4980 = EDGE_LOOP('',(#4981,#4982,#5005,#5035));
#4981 = ORIENTED_EDGE('',*,*,#4928,.T.);
#4982 = ORIENTED_EDGE('',*,*,#4983,.T.);
#4983 = EDGE_CURVE('',#4906,#4984,#4986,.T.);
#4984 = VERTEX_POINT('',#4985);
#4985 = CARTESIAN_POINT('',(-1.433,-3.118,8.2));
#4986 = SURFACE_CURVE('',#4987,(#4991,#4998),.PCURVE_S1.);
#4987 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#4988,#4989,#4990),
#4988 = CARTESIAN_POINT('',(-1.664,-3.588,8.2));
#4989 = CARTESIAN_POINT('',(-1.664,-3.25,8.2));
#4990 = CARTESIAN_POINT('',(-1.433,-3.118,8.2));
#4991 = PCURVE('',#4944,#4992);
#4992 = DEFINITIONAL_REPRESENTATION('',(#4993),#4997);
#4993 = LINE('',#4994,#4995);
#4994 = CARTESIAN_POINT('',(0.,-0.2));
#4995 = VECTOR('',#4996,1.);
#4996 = DIRECTION('',(1.,0.));
#4997 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#4998 = PCURVE('',#4135,#4999);
#4999 = DEFINITIONAL_REPRESENTATION('',(#5000),#5004);
#5000 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5001,#5002,#5003),
#5001 = CARTESIAN_POINT('',(0.217321172048,-0.901317277748));
#5002 = CARTESIAN_POINT('',(0.555321172048,-0.901317277748));
#5003 = CARTESIAN_POINT('',(0.687321172048,-0.670317277748));
#5004 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5005 = ORIENTED_EDGE('',*,*,#5006,.F.);
#5006 = EDGE_CURVE('',#5007,#4984,#5009,.T.);
#5007 = VERTEX_POINT('',#5008);
#5008 = CARTESIAN_POINT('',(-1.433,-3.118,8.));
#5009 = SURFACE_CURVE('',#5010,(#5014,#5021),.PCURVE_S1.);
#5010 = LINE('',#5011,#5012);
#5011 = CARTESIAN_POINT('',(-1.433,-3.118,8.));
#5012 = VECTOR('',#5013,1.);
#5013 = DIRECTION('',(0.,0.,1.));
#5014 = PCURVE('',#4944,#5015);
#5015 = DEFINITIONAL_REPRESENTATION('',(#5016),#5020);
#5016 = LINE('',#5017,#5018);
#5017 = CARTESIAN_POINT('',(1.,0.));
#5018 = VECTOR('',#5019,1.);
#5019 = DIRECTION('',(0.,-1.));
#5020 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5021 = PCURVE('',#5022,#5029);
#5022 = SURFACE_OF_LINEAR_EXTRUSION('',#5023,#5027);
#5023 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5024,#5025,#5026),
#5024 = CARTESIAN_POINT('',(-1.433,-3.118,8.));
#5025 = CARTESIAN_POINT('',(-1.325,-3.06,8.));
#5026 = CARTESIAN_POINT('',(-1.186,-3.06,8.));
#5027 = VECTOR('',#5028,1.);
#5028 = DIRECTION('',(-0.,-0.,-1.));
#5029 = DEFINITIONAL_REPRESENTATION('',(#5030),#5034);
#5030 = LINE('',#5031,#5032);
#5031 = CARTESIAN_POINT('',(0.,0.));
#5032 = VECTOR('',#5033,1.);
#5033 = DIRECTION('',(0.,-1.));
#5034 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5035 = ORIENTED_EDGE('',*,*,#5036,.F.);
#5036 = EDGE_CURVE('',#4929,#5007,#5037,.T.);
#5037 = SURFACE_CURVE('',#5038,(#5042,#5049),.PCURVE_S1.);
#5038 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5039,#5040,#5041),
#5039 = CARTESIAN_POINT('',(-1.664,-3.588,8.));
#5040 = CARTESIAN_POINT('',(-1.664,-3.25,8.));
#5041 = CARTESIAN_POINT('',(-1.433,-3.118,8.));
#5042 = PCURVE('',#4944,#5043);
#5043 = DEFINITIONAL_REPRESENTATION('',(#5044),#5048);
#5044 = LINE('',#5045,#5046);
#5045 = CARTESIAN_POINT('',(0.,0.));
#5046 = VECTOR('',#5047,1.);
#5047 = DIRECTION('',(1.,0.));
#5048 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5049 = PCURVE('',#4191,#5050);
#5050 = DEFINITIONAL_REPRESENTATION('',(#5051),#5055);
#5051 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5052,#5053,#5054),
.UNSPECIFIED.,.F.,.F.,(3,3),(0.,1.),.PIECEWISE_BEZIER_KNOTS.);
#5052 = CARTESIAN_POINT('',(0.217321172048,-0.901317277748));
#5053 = CARTESIAN_POINT('',(0.555321172048,-0.901317277748));
#5054 = CARTESIAN_POINT('',(0.687321172048,-0.670317277748));
#5055 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5056 = ADVANCED_FACE('',(#5057),#5022,.T.);
#5057 = FACE_BOUND('',#5058,.T.);
#5058 = EDGE_LOOP('',(#5059,#5060,#5083,#5113));
#5059 = ORIENTED_EDGE('',*,*,#5006,.T.);
#5060 = ORIENTED_EDGE('',*,*,#5061,.T.);
#5061 = EDGE_CURVE('',#4984,#5062,#5064,.T.);
#5062 = VERTEX_POINT('',#5063);
#5063 = CARTESIAN_POINT('',(-1.186,-3.06,8.2));
#5064 = SURFACE_CURVE('',#5065,(#5069,#5076),.PCURVE_S1.);
#5065 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5066,#5067,#5068),
#5066 = CARTESIAN_POINT('',(-1.433,-3.118,8.2));
#5067 = CARTESIAN_POINT('',(-1.325,-3.06,8.2));
#5068 = CARTESIAN_POINT('',(-1.186,-3.06,8.2));
#5069 = PCURVE('',#5022,#5070);
#5070 = DEFINITIONAL_REPRESENTATION('',(#5071),#5075);
#5071 = LINE('',#5072,#5073);
#5072 = CARTESIAN_POINT('',(0.,-0.2));
#5073 = VECTOR('',#5074,1.);
#5074 = DIRECTION('',(1.,0.));
#5075 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5076 = PCURVE('',#4135,#5077);
#5077 = DEFINITIONAL_REPRESENTATION('',(#5078),#5082);
#5078 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5079,#5080,#5081),
#5079 = CARTESIAN_POINT('',(0.687321172048,-0.670317277748));
#5080 = CARTESIAN_POINT('',(0.745321172048,-0.562317277748));
#5081 = CARTESIAN_POINT('',(0.745321172048,-0.423317277748));
#5082 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5083 = ORIENTED_EDGE('',*,*,#5084,.F.);
#5084 = EDGE_CURVE('',#5085,#5062,#5087,.T.);
#5085 = VERTEX_POINT('',#5086);
#5086 = CARTESIAN_POINT('',(-1.186,-3.06,8.));
#5087 = SURFACE_CURVE('',#5088,(#5092,#5099),.PCURVE_S1.);
#5088 = LINE('',#5089,#5090);
#5089 = CARTESIAN_POINT('',(-1.186,-3.06,8.));
#5090 = VECTOR('',#5091,1.);
#5091 = DIRECTION('',(0.,0.,1.));
#5092 = PCURVE('',#5022,#5093);
#5093 = DEFINITIONAL_REPRESENTATION('',(#5094),#5098);
#5094 = LINE('',#5095,#5096);
#5095 = CARTESIAN_POINT('',(1.,0.));
#5096 = VECTOR('',#5097,1.);
#5097 = DIRECTION('',(0.,-1.));
#5098 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5099 = PCURVE('',#5100,#5107);
#5100 = SURFACE_OF_LINEAR_EXTRUSION('',#5101,#5105);
#5101 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5102,#5103,#5104),
#5102 = CARTESIAN_POINT('',(-1.186,-3.06,8.));
#5103 = CARTESIAN_POINT('',(-0.883,-3.06,8.));
#5104 = CARTESIAN_POINT('',(-0.772,-3.3,8.));
#5105 = VECTOR('',#5106,1.);
#5106 = DIRECTION('',(-0.,-0.,-1.));
#5107 = DEFINITIONAL_REPRESENTATION('',(#5108),#5112);
#5108 = LINE('',#5109,#5110);
#5109 = CARTESIAN_POINT('',(0.,0.));
#5110 = VECTOR('',#5111,1.);
#5111 = DIRECTION('',(0.,-1.));
#5112 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5113 = ORIENTED_EDGE('',*,*,#5114,.F.);
#5114 = EDGE_CURVE('',#5007,#5085,#5115,.T.);
#5115 = SURFACE_CURVE('',#5116,(#5120,#5127),.PCURVE_S1.);
#5116 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5117,#5118,#5119),
#5117 = CARTESIAN_POINT('',(-1.433,-3.118,8.));
#5118 = CARTESIAN_POINT('',(-1.325,-3.06,8.));
#5119 = CARTESIAN_POINT('',(-1.186,-3.06,8.));
#5120 = PCURVE('',#5022,#5121);
#5121 = DEFINITIONAL_REPRESENTATION('',(#5122),#5126);
#5122 = LINE('',#5123,#5124);
#5123 = CARTESIAN_POINT('',(0.,0.));
#5124 = VECTOR('',#5125,1.);
#5125 = DIRECTION('',(1.,0.));
#5126 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5127 = PCURVE('',#4191,#5128);
#5128 = DEFINITIONAL_REPRESENTATION('',(#5129),#5133);
#5129 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5130,#5131,#5132),
#5130 = CARTESIAN_POINT('',(0.687321172048,-0.670317277748));
#5131 = CARTESIAN_POINT('',(0.745321172048,-0.562317277748));
#5132 = CARTESIAN_POINT('',(0.745321172048,-0.423317277748));
#5133 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5134 = ADVANCED_FACE('',(#5135),#5100,.T.);
#5135 = FACE_BOUND('',#5136,.T.);
#5136 = EDGE_LOOP('',(#5137,#5138,#5161,#5191));
#5137 = ORIENTED_EDGE('',*,*,#5084,.T.);
#5138 = ORIENTED_EDGE('',*,*,#5139,.T.);
#5139 = EDGE_CURVE('',#5062,#5140,#5142,.T.);
#5140 = VERTEX_POINT('',#5141);
#5141 = CARTESIAN_POINT('',(-0.772,-3.3,8.2));
#5142 = SURFACE_CURVE('',#5143,(#5147,#5154),.PCURVE_S1.);
#5143 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5144,#5145,#5146),
#5144 = CARTESIAN_POINT('',(-1.186,-3.06,8.2));
#5145 = CARTESIAN_POINT('',(-0.883,-3.06,8.2));
#5146 = CARTESIAN_POINT('',(-0.772,-3.3,8.2));
#5147 = PCURVE('',#5100,#5148);
#5148 = DEFINITIONAL_REPRESENTATION('',(#5149),#5153);
#5149 = LINE('',#5150,#5151);
#5150 = CARTESIAN_POINT('',(0.,-0.2));
#5151 = VECTOR('',#5152,1.);
#5152 = DIRECTION('',(1.,0.));
#5153 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5154 = PCURVE('',#4135,#5155);
#5155 = DEFINITIONAL_REPRESENTATION('',(#5156),#5160);
#5156 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5157,#5158,#5159),
#5157 = CARTESIAN_POINT('',(0.745321172048,-0.423317277748));
#5158 = CARTESIAN_POINT('',(0.745321172048,-0.120317277748));
#5159 = CARTESIAN_POINT('',(0.505321172048,-9.317277748121E-03));
#5160 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5161 = ORIENTED_EDGE('',*,*,#5162,.F.);
#5162 = EDGE_CURVE('',#5163,#5140,#5165,.T.);
#5163 = VERTEX_POINT('',#5164);
#5164 = CARTESIAN_POINT('',(-0.772,-3.3,8.));
#5165 = SURFACE_CURVE('',#5166,(#5170,#5177),.PCURVE_S1.);
#5166 = LINE('',#5167,#5168);
#5167 = CARTESIAN_POINT('',(-0.772,-3.3,8.));
#5168 = VECTOR('',#5169,1.);
#5169 = DIRECTION('',(0.,0.,1.));
#5170 = PCURVE('',#5100,#5171);
#5171 = DEFINITIONAL_REPRESENTATION('',(#5172),#5176);
#5172 = LINE('',#5173,#5174);
#5173 = CARTESIAN_POINT('',(1.,0.));
#5174 = VECTOR('',#5175,1.);
#5175 = DIRECTION('',(0.,-1.));
#5176 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5177 = PCURVE('',#5178,#5185);
#5178 = SURFACE_OF_LINEAR_EXTRUSION('',#5179,#5183);
#5179 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5180,#5181,#5182),
#5180 = CARTESIAN_POINT('',(-0.772,-3.3,8.));
#5181 = CARTESIAN_POINT('',(-0.71,-3.435,8.));
#5182 = CARTESIAN_POINT('',(-0.658,-3.841,8.));
#5183 = VECTOR('',#5184,1.);
#5184 = DIRECTION('',(-0.,-0.,-1.));
#5185 = DEFINITIONAL_REPRESENTATION('',(#5186),#5190);
#5186 = LINE('',#5187,#5188);
#5187 = CARTESIAN_POINT('',(0.,0.));
#5188 = VECTOR('',#5189,1.);
#5189 = DIRECTION('',(0.,-1.));
#5190 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5191 = ORIENTED_EDGE('',*,*,#5192,.F.);
#5192 = EDGE_CURVE('',#5085,#5163,#5193,.T.);
#5193 = SURFACE_CURVE('',#5194,(#5198,#5205),.PCURVE_S1.);
#5194 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5195,#5196,#5197),
#5195 = CARTESIAN_POINT('',(-1.186,-3.06,8.));
#5196 = CARTESIAN_POINT('',(-0.883,-3.06,8.));
#5197 = CARTESIAN_POINT('',(-0.772,-3.3,8.));
#5198 = PCURVE('',#5100,#5199);
#5199 = DEFINITIONAL_REPRESENTATION('',(#5200),#5204);
#5200 = LINE('',#5201,#5202);
#5201 = CARTESIAN_POINT('',(0.,0.));
#5202 = VECTOR('',#5203,1.);
#5203 = DIRECTION('',(1.,0.));
#5204 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5205 = PCURVE('',#4191,#5206);
#5206 = DEFINITIONAL_REPRESENTATION('',(#5207),#5211);
#5207 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5208,#5209,#5210),
#5208 = CARTESIAN_POINT('',(0.745321172048,-0.423317277748));
#5209 = CARTESIAN_POINT('',(0.745321172048,-0.120317277748));
#5210 = CARTESIAN_POINT('',(0.505321172048,-9.317277748121E-03));
#5211 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5212 = ADVANCED_FACE('',(#5213),#5178,.T.);
#5213 = FACE_BOUND('',#5214,.T.);
#5214 = EDGE_LOOP('',(#5215,#5216,#5239,#5267));
#5215 = ORIENTED_EDGE('',*,*,#5162,.T.);
#5216 = ORIENTED_EDGE('',*,*,#5217,.T.);
#5217 = EDGE_CURVE('',#5140,#5218,#5220,.T.);
#5218 = VERTEX_POINT('',#5219);
#5219 = CARTESIAN_POINT('',(-0.658,-3.841,8.2));
#5220 = SURFACE_CURVE('',#5221,(#5225,#5232),.PCURVE_S1.);
#5221 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5222,#5223,#5224),
#5222 = CARTESIAN_POINT('',(-0.772,-3.3,8.2));
#5223 = CARTESIAN_POINT('',(-0.71,-3.435,8.2));
#5224 = CARTESIAN_POINT('',(-0.658,-3.841,8.2));
#5225 = PCURVE('',#5178,#5226);
#5226 = DEFINITIONAL_REPRESENTATION('',(#5227),#5231);
#5227 = LINE('',#5228,#5229);
#5228 = CARTESIAN_POINT('',(0.,-0.2));
#5229 = VECTOR('',#5230,1.);
#5230 = DIRECTION('',(1.,0.));
#5231 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5232 = PCURVE('',#4135,#5233);
#5233 = DEFINITIONAL_REPRESENTATION('',(#5234),#5238);
#5234 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5235,#5236,#5237),
#5235 = CARTESIAN_POINT('',(0.505321172048,-9.317277748121E-03));
#5236 = CARTESIAN_POINT('',(0.370321172048,5.268272225188E-02));
#5237 = CARTESIAN_POINT('',(-3.56788279517E-02,0.104682722252));
#5238 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5239 = ORIENTED_EDGE('',*,*,#5240,.F.);
#5240 = EDGE_CURVE('',#5241,#5218,#5243,.T.);
#5241 = VERTEX_POINT('',#5242);
#5242 = CARTESIAN_POINT('',(-0.658,-3.841,8.));
#5243 = SURFACE_CURVE('',#5244,(#5248,#5255),.PCURVE_S1.);
#5244 = LINE('',#5245,#5246);
#5245 = CARTESIAN_POINT('',(-0.658,-3.841,8.));
#5246 = VECTOR('',#5247,1.);
#5247 = DIRECTION('',(0.,0.,1.));
#5248 = PCURVE('',#5178,#5249);
#5249 = DEFINITIONAL_REPRESENTATION('',(#5250),#5254);
#5250 = LINE('',#5251,#5252);
#5251 = CARTESIAN_POINT('',(1.,0.));
#5252 = VECTOR('',#5253,1.);
#5253 = DIRECTION('',(0.,-1.));
#5254 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5255 = PCURVE('',#5256,#5261);
#5256 = PLANE('',#5257);
#5257 = AXIS2_PLACEMENT_3D('',#5258,#5259,#5260);
#5258 = CARTESIAN_POINT('',(-0.658,-3.841,8.));
#5259 = DIRECTION('',(1.,-2.2E-16,0.));
#5260 = DIRECTION('',(-2.2E-16,-1.,0.));
#5261 = DEFINITIONAL_REPRESENTATION('',(#5262),#5266);
#5262 = LINE('',#5263,#5264);
#5263 = CARTESIAN_POINT('',(4.4E-16,0.));
#5264 = VECTOR('',#5265,1.);
#5265 = DIRECTION('',(0.,-1.));
#5266 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5267 = ORIENTED_EDGE('',*,*,#5268,.F.);
#5268 = EDGE_CURVE('',#5163,#5241,#5269,.T.);
#5269 = SURFACE_CURVE('',#5270,(#5274,#5281),.PCURVE_S1.);
#5270 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5271,#5272,#5273),
#5271 = CARTESIAN_POINT('',(-0.772,-3.3,8.));
#5272 = CARTESIAN_POINT('',(-0.71,-3.435,8.));
#5273 = CARTESIAN_POINT('',(-0.658,-3.841,8.));
#5274 = PCURVE('',#5178,#5275);
#5275 = DEFINITIONAL_REPRESENTATION('',(#5276),#5280);
#5276 = LINE('',#5277,#5278);
#5277 = CARTESIAN_POINT('',(0.,0.));
#5278 = VECTOR('',#5279,1.);
#5279 = DIRECTION('',(1.,0.));
#5280 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5281 = PCURVE('',#4191,#5282);
#5282 = DEFINITIONAL_REPRESENTATION('',(#5283),#5287);
#5283 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5284,#5285,#5286),
#5284 = CARTESIAN_POINT('',(0.505321172048,-9.317277748121E-03));
#5285 = CARTESIAN_POINT('',(0.370321172048,5.268272225188E-02));
#5286 = CARTESIAN_POINT('',(-3.56788279517E-02,0.104682722252));
#5287 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5288 = ADVANCED_FACE('',(#5289),#5256,.T.);
#5289 = FACE_BOUND('',#5290,.T.);
#5290 = EDGE_LOOP('',(#5291,#5292,#5315,#5343));
#5291 = ORIENTED_EDGE('',*,*,#5240,.T.);
#5292 = ORIENTED_EDGE('',*,*,#5293,.T.);
#5293 = EDGE_CURVE('',#5218,#5294,#5296,.T.);
#5294 = VERTEX_POINT('',#5295);
#5295 = CARTESIAN_POINT('',(-0.658,-3.844,8.2));
#5296 = SURFACE_CURVE('',#5297,(#5301,#5308),.PCURVE_S1.);
#5297 = LINE('',#5298,#5299);
#5298 = CARTESIAN_POINT('',(-0.658,-3.841,8.2));
#5299 = VECTOR('',#5300,1.);
#5300 = DIRECTION('',(0.,-1.,0.));
#5301 = PCURVE('',#5256,#5302);
#5302 = DEFINITIONAL_REPRESENTATION('',(#5303),#5307);
#5303 = LINE('',#5304,#5305);
#5304 = CARTESIAN_POINT('',(0.,-0.2));
#5305 = VECTOR('',#5306,1.);
#5306 = DIRECTION('',(1.,-0.));
#5307 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5308 = PCURVE('',#4135,#5309);
#5309 = DEFINITIONAL_REPRESENTATION('',(#5310),#5314);
#5310 = LINE('',#5311,#5312);
#5311 = CARTESIAN_POINT('',(-3.56788279517E-02,0.104682722252));
#5312 = VECTOR('',#5313,1.);
#5313 = DIRECTION('',(-1.,0.));
#5314 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5315 = ORIENTED_EDGE('',*,*,#5316,.F.);
#5316 = EDGE_CURVE('',#5317,#5294,#5319,.T.);
#5317 = VERTEX_POINT('',#5318);
#5318 = CARTESIAN_POINT('',(-0.658,-3.844,8.));
#5319 = SURFACE_CURVE('',#5320,(#5324,#5331),.PCURVE_S1.);
#5320 = LINE('',#5321,#5322);
#5321 = CARTESIAN_POINT('',(-0.658,-3.844,8.));
#5322 = VECTOR('',#5323,1.);
#5323 = DIRECTION('',(0.,0.,1.));
#5324 = PCURVE('',#5256,#5325);
#5325 = DEFINITIONAL_REPRESENTATION('',(#5326),#5330);
#5326 = LINE('',#5327,#5328);
#5327 = CARTESIAN_POINT('',(3.E-03,0.));
#5328 = VECTOR('',#5329,1.);
#5329 = DIRECTION('',(0.,-1.));
#5330 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5331 = PCURVE('',#5332,#5337);
#5332 = PLANE('',#5333);
#5333 = AXIS2_PLACEMENT_3D('',#5334,#5335,#5336);
#5334 = CARTESIAN_POINT('',(-0.658,-3.844,8.));
#5335 = DIRECTION('',(1.,-2.2E-16,0.));
#5336 = DIRECTION('',(-2.2E-16,-1.,0.));
#5337 = DEFINITIONAL_REPRESENTATION('',(#5338),#5342);
#5338 = LINE('',#5339,#5340);
#5339 = CARTESIAN_POINT('',(0.,0.));
#5340 = VECTOR('',#5341,1.);
#5341 = DIRECTION('',(0.,-1.));
#5342 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5343 = ORIENTED_EDGE('',*,*,#5344,.F.);
#5344 = EDGE_CURVE('',#5241,#5317,#5345,.T.);
#5345 = SURFACE_CURVE('',#5346,(#5350,#5357),.PCURVE_S1.);
#5346 = LINE('',#5347,#5348);
#5347 = CARTESIAN_POINT('',(-0.658,-3.841,8.));
#5348 = VECTOR('',#5349,1.);
#5349 = DIRECTION('',(0.,-1.,0.));
#5350 = PCURVE('',#5256,#5351);
#5351 = DEFINITIONAL_REPRESENTATION('',(#5352),#5356);
#5352 = LINE('',#5353,#5354);
#5353 = CARTESIAN_POINT('',(0.,0.));
#5354 = VECTOR('',#5355,1.);
#5355 = DIRECTION('',(1.,-0.));
#5356 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5357 = PCURVE('',#4191,#5358);
#5358 = DEFINITIONAL_REPRESENTATION('',(#5359),#5363);
#5359 = LINE('',#5360,#5361);
#5360 = CARTESIAN_POINT('',(-3.56788279517E-02,0.104682722252));
#5361 = VECTOR('',#5362,1.);
#5362 = DIRECTION('',(-1.,0.));
#5363 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5364 = ADVANCED_FACE('',(#5365),#5332,.T.);
#5365 = FACE_BOUND('',#5366,.T.);
#5366 = EDGE_LOOP('',(#5367,#5368,#5391,#5419));
#5367 = ORIENTED_EDGE('',*,*,#5316,.T.);
#5368 = ORIENTED_EDGE('',*,*,#5369,.T.);
#5369 = EDGE_CURVE('',#5294,#5370,#5372,.T.);
#5370 = VERTEX_POINT('',#5371);
#5371 = CARTESIAN_POINT('',(-0.658,-3.847,8.2));
#5372 = SURFACE_CURVE('',#5373,(#5377,#5384),.PCURVE_S1.);
#5373 = LINE('',#5374,#5375);
#5374 = CARTESIAN_POINT('',(-0.658,-3.844,8.2));
#5375 = VECTOR('',#5376,1.);
#5376 = DIRECTION('',(0.,-1.,0.));
#5377 = PCURVE('',#5332,#5378);
#5378 = DEFINITIONAL_REPRESENTATION('',(#5379),#5383);
#5379 = LINE('',#5380,#5381);
#5380 = CARTESIAN_POINT('',(0.,-0.2));
#5381 = VECTOR('',#5382,1.);
#5382 = DIRECTION('',(1.,-0.));
#5383 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5384 = PCURVE('',#4135,#5385);
#5385 = DEFINITIONAL_REPRESENTATION('',(#5386),#5390);
#5386 = LINE('',#5387,#5388);
#5387 = CARTESIAN_POINT('',(-3.86788279517E-02,0.104682722252));
#5388 = VECTOR('',#5389,1.);
#5389 = DIRECTION('',(-1.,0.));
#5390 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5391 = ORIENTED_EDGE('',*,*,#5392,.F.);
#5392 = EDGE_CURVE('',#5393,#5370,#5395,.T.);
#5393 = VERTEX_POINT('',#5394);
#5394 = CARTESIAN_POINT('',(-0.658,-3.847,8.));
#5395 = SURFACE_CURVE('',#5396,(#5400,#5407),.PCURVE_S1.);
#5396 = LINE('',#5397,#5398);
#5397 = CARTESIAN_POINT('',(-0.658,-3.847,8.));
#5398 = VECTOR('',#5399,1.);
#5399 = DIRECTION('',(0.,0.,1.));
#5400 = PCURVE('',#5332,#5401);
#5401 = DEFINITIONAL_REPRESENTATION('',(#5402),#5406);
#5402 = LINE('',#5403,#5404);
#5403 = CARTESIAN_POINT('',(3.E-03,0.));
#5404 = VECTOR('',#5405,1.);
#5405 = DIRECTION('',(0.,-1.));
#5406 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5407 = PCURVE('',#5408,#5413);
#5408 = PLANE('',#5409);
#5409 = AXIS2_PLACEMENT_3D('',#5410,#5411,#5412);
#5410 = CARTESIAN_POINT('',(-0.658,-3.847,8.));
#5411 = DIRECTION('',(0.707106781187,0.707106781187,0.));
#5412 = DIRECTION('',(0.707106781187,-0.707106781187,0.));
#5413 = DEFINITIONAL_REPRESENTATION('',(#5414),#5418);
#5414 = LINE('',#5415,#5416);
#5415 = CARTESIAN_POINT('',(-8.E-17,0.));
#5416 = VECTOR('',#5417,1.);
#5417 = DIRECTION('',(0.,-1.));
#5418 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5419 = ORIENTED_EDGE('',*,*,#5420,.F.);
#5420 = EDGE_CURVE('',#5317,#5393,#5421,.T.);
#5421 = SURFACE_CURVE('',#5422,(#5426,#5433),.PCURVE_S1.);
#5422 = LINE('',#5423,#5424);
#5423 = CARTESIAN_POINT('',(-0.658,-3.844,8.));
#5424 = VECTOR('',#5425,1.);
#5425 = DIRECTION('',(0.,-1.,0.));
#5426 = PCURVE('',#5332,#5427);
#5427 = DEFINITIONAL_REPRESENTATION('',(#5428),#5432);
#5428 = LINE('',#5429,#5430);
#5429 = CARTESIAN_POINT('',(0.,0.));
#5430 = VECTOR('',#5431,1.);
#5431 = DIRECTION('',(1.,-0.));
#5432 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5433 = PCURVE('',#4191,#5434);
#5434 = DEFINITIONAL_REPRESENTATION('',(#5435),#5439);
#5435 = LINE('',#5436,#5437);
#5436 = CARTESIAN_POINT('',(-3.86788279517E-02,0.104682722252));
#5437 = VECTOR('',#5438,1.);
#5438 = DIRECTION('',(-1.,0.));
#5439 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5440 = ADVANCED_FACE('',(#5441),#5408,.T.);
#5441 = FACE_BOUND('',#5442,.T.);
#5442 = EDGE_LOOP('',(#5443,#5444,#5467,#5495));
#5443 = ORIENTED_EDGE('',*,*,#5392,.T.);
#5444 = ORIENTED_EDGE('',*,*,#5445,.T.);
#5445 = EDGE_CURVE('',#5370,#5446,#5448,.T.);
#5446 = VERTEX_POINT('',#5447);
#5447 = CARTESIAN_POINT('',(-0.655,-3.85,8.2));
#5448 = SURFACE_CURVE('',#5449,(#5453,#5460),.PCURVE_S1.);
#5449 = LINE('',#5450,#5451);
#5450 = CARTESIAN_POINT('',(-0.658,-3.847,8.2));
#5451 = VECTOR('',#5452,1.);
#5452 = DIRECTION('',(0.707106781187,-0.707106781187,0.));
#5453 = PCURVE('',#5408,#5454);
#5454 = DEFINITIONAL_REPRESENTATION('',(#5455),#5459);
#5455 = LINE('',#5456,#5457);
#5456 = CARTESIAN_POINT('',(0.,-0.2));
#5457 = VECTOR('',#5458,1.);
#5458 = DIRECTION('',(1.,0.));
#5459 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5460 = PCURVE('',#4135,#5461);
#5461 = DEFINITIONAL_REPRESENTATION('',(#5462),#5466);
#5462 = LINE('',#5463,#5464);
#5463 = CARTESIAN_POINT('',(-4.16788279517E-02,0.104682722252));
#5464 = VECTOR('',#5465,1.);
#5465 = DIRECTION('',(-0.707106781187,0.707106781187));
#5466 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5467 = ORIENTED_EDGE('',*,*,#5468,.F.);
#5468 = EDGE_CURVE('',#5469,#5446,#5471,.T.);
#5469 = VERTEX_POINT('',#5470);
#5470 = CARTESIAN_POINT('',(-0.655,-3.85,8.));
#5471 = SURFACE_CURVE('',#5472,(#5476,#5483),.PCURVE_S1.);
#5472 = LINE('',#5473,#5474);
#5473 = CARTESIAN_POINT('',(-0.655,-3.85,8.));
#5474 = VECTOR('',#5475,1.);
#5475 = DIRECTION('',(0.,0.,1.));
#5476 = PCURVE('',#5408,#5477);
#5477 = DEFINITIONAL_REPRESENTATION('',(#5478),#5482);
#5478 = LINE('',#5479,#5480);
#5479 = CARTESIAN_POINT('',(4.242640687119E-03,0.));
#5480 = VECTOR('',#5481,1.);
#5481 = DIRECTION('',(0.,-1.));
#5482 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5483 = PCURVE('',#5484,#5489);
#5484 = PLANE('',#5485);
#5485 = AXIS2_PLACEMENT_3D('',#5486,#5487,#5488);
#5486 = CARTESIAN_POINT('',(-0.655,-3.85,8.));
#5487 = DIRECTION('',(1.,-2.2E-16,0.));
#5488 = DIRECTION('',(-2.2E-16,-1.,0.));
#5489 = DEFINITIONAL_REPRESENTATION('',(#5490),#5494);
#5490 = LINE('',#5491,#5492);
#5491 = CARTESIAN_POINT('',(0.,0.));
#5492 = VECTOR('',#5493,1.);
#5493 = DIRECTION('',(0.,-1.));
#5494 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5495 = ORIENTED_EDGE('',*,*,#5496,.F.);
#5496 = EDGE_CURVE('',#5393,#5469,#5497,.T.);
#5497 = SURFACE_CURVE('',#5498,(#5502,#5509),.PCURVE_S1.);
#5498 = LINE('',#5499,#5500);
#5499 = CARTESIAN_POINT('',(-0.658,-3.847,8.));
#5500 = VECTOR('',#5501,1.);
#5501 = DIRECTION('',(0.707106781187,-0.707106781187,0.));
#5502 = PCURVE('',#5408,#5503);
#5503 = DEFINITIONAL_REPRESENTATION('',(#5504),#5508);
#5504 = LINE('',#5505,#5506);
#5505 = CARTESIAN_POINT('',(0.,0.));
#5506 = VECTOR('',#5507,1.);
#5507 = DIRECTION('',(1.,0.));
#5508 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5509 = PCURVE('',#4191,#5510);
#5510 = DEFINITIONAL_REPRESENTATION('',(#5511),#5515);
#5511 = LINE('',#5512,#5513);
#5512 = CARTESIAN_POINT('',(-4.16788279517E-02,0.104682722252));
#5513 = VECTOR('',#5514,1.);
#5514 = DIRECTION('',(-0.707106781187,0.707106781187));
#5515 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5516 = ADVANCED_FACE('',(#5517),#5484,.T.);
#5517 = FACE_BOUND('',#5518,.T.);
#5518 = EDGE_LOOP('',(#5519,#5520,#5543,#5571));
#5519 = ORIENTED_EDGE('',*,*,#5468,.T.);
#5520 = ORIENTED_EDGE('',*,*,#5521,.T.);
#5521 = EDGE_CURVE('',#5446,#5522,#5524,.T.);
#5522 = VERTEX_POINT('',#5523);
#5523 = CARTESIAN_POINT('',(-0.655,-3.853,8.2));
#5524 = SURFACE_CURVE('',#5525,(#5529,#5536),.PCURVE_S1.);
#5525 = LINE('',#5526,#5527);
#5526 = CARTESIAN_POINT('',(-0.655,-3.85,8.2));
#5527 = VECTOR('',#5528,1.);
#5528 = DIRECTION('',(0.,-1.,0.));
#5529 = PCURVE('',#5484,#5530);
#5530 = DEFINITIONAL_REPRESENTATION('',(#5531),#5535);
#5531 = LINE('',#5532,#5533);
#5532 = CARTESIAN_POINT('',(0.,-0.2));
#5533 = VECTOR('',#5534,1.);
#5534 = DIRECTION('',(1.,-0.));
#5535 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5536 = PCURVE('',#4135,#5537);
#5537 = DEFINITIONAL_REPRESENTATION('',(#5538),#5542);
#5538 = LINE('',#5539,#5540);
#5539 = CARTESIAN_POINT('',(-4.46788279517E-02,0.107682722252));
#5540 = VECTOR('',#5541,1.);
#5541 = DIRECTION('',(-1.,0.));
#5542 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5543 = ORIENTED_EDGE('',*,*,#5544,.F.);
#5544 = EDGE_CURVE('',#5545,#5522,#5547,.T.);
#5545 = VERTEX_POINT('',#5546);
#5546 = CARTESIAN_POINT('',(-0.655,-3.853,8.));
#5547 = SURFACE_CURVE('',#5548,(#5552,#5559),.PCURVE_S1.);
#5548 = LINE('',#5549,#5550);
#5549 = CARTESIAN_POINT('',(-0.655,-3.853,8.));
#5550 = VECTOR('',#5551,1.);
#5551 = DIRECTION('',(0.,0.,1.));
#5552 = PCURVE('',#5484,#5553);
#5553 = DEFINITIONAL_REPRESENTATION('',(#5554),#5558);
#5554 = LINE('',#5555,#5556);
#5555 = CARTESIAN_POINT('',(3.E-03,0.));
#5556 = VECTOR('',#5557,1.);
#5557 = DIRECTION('',(0.,-1.));
#5558 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5559 = PCURVE('',#5560,#5565);
#5560 = PLANE('',#5561);
#5561 = AXIS2_PLACEMENT_3D('',#5562,#5563,#5564);
#5562 = CARTESIAN_POINT('',(-0.655,-3.853,8.));
#5563 = DIRECTION('',(1.,-2.2E-16,0.));
#5564 = DIRECTION('',(-2.2E-16,-1.,0.));
#5565 = DEFINITIONAL_REPRESENTATION('',(#5566),#5570);
#5566 = LINE('',#5567,#5568);
#5567 = CARTESIAN_POINT('',(0.,0.));
#5568 = VECTOR('',#5569,1.);
#5569 = DIRECTION('',(0.,-1.));
#5570 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5571 = ORIENTED_EDGE('',*,*,#5572,.F.);
#5572 = EDGE_CURVE('',#5469,#5545,#5573,.T.);
#5573 = SURFACE_CURVE('',#5574,(#5578,#5585),.PCURVE_S1.);
#5574 = LINE('',#5575,#5576);
#5575 = CARTESIAN_POINT('',(-0.655,-3.85,8.));
#5576 = VECTOR('',#5577,1.);
#5577 = DIRECTION('',(0.,-1.,0.));
#5578 = PCURVE('',#5484,#5579);
#5579 = DEFINITIONAL_REPRESENTATION('',(#5580),#5584);
#5580 = LINE('',#5581,#5582);
#5581 = CARTESIAN_POINT('',(0.,0.));
#5582 = VECTOR('',#5583,1.);
#5583 = DIRECTION('',(1.,-0.));
#5584 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5585 = PCURVE('',#4191,#5586);
#5586 = DEFINITIONAL_REPRESENTATION('',(#5587),#5591);
#5587 = LINE('',#5588,#5589);
#5588 = CARTESIAN_POINT('',(-4.46788279517E-02,0.107682722252));
#5589 = VECTOR('',#5590,1.);
#5590 = DIRECTION('',(-1.,0.));
#5591 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5592 = ADVANCED_FACE('',(#5593),#5560,.T.);
#5593 = FACE_BOUND('',#5594,.T.);
#5594 = EDGE_LOOP('',(#5595,#5596,#5619,#5647));
#5595 = ORIENTED_EDGE('',*,*,#5544,.T.);
#5596 = ORIENTED_EDGE('',*,*,#5597,.T.);
#5597 = EDGE_CURVE('',#5522,#5598,#5600,.T.);
#5598 = VERTEX_POINT('',#5599);
#5599 = CARTESIAN_POINT('',(-0.655,-3.856,8.2));
#5600 = SURFACE_CURVE('',#5601,(#5605,#5612),.PCURVE_S1.);
#5601 = LINE('',#5602,#5603);
#5602 = CARTESIAN_POINT('',(-0.655,-3.853,8.2));
#5603 = VECTOR('',#5604,1.);
#5604 = DIRECTION('',(0.,-1.,0.));
#5605 = PCURVE('',#5560,#5606);
#5606 = DEFINITIONAL_REPRESENTATION('',(#5607),#5611);
#5607 = LINE('',#5608,#5609);
#5608 = CARTESIAN_POINT('',(0.,-0.2));
#5609 = VECTOR('',#5610,1.);
#5610 = DIRECTION('',(1.,-0.));
#5611 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
PARAMETRIC_REPRESENTATION_CONTEXT() REPRESENTATION_CONTEXT('2D SPACE',''
#5612 = PCURVE('',#4135,#5613);
#5613 = DEFINITIONAL_REPRESENTATION('',(#5614),#5618);
#5614 = LINE('',#5615,#5616);
#5615 = CARTESIAN_POINT('',(-4.76788279517E-02,0.107682722252));
#5616 = VECTOR('',#5617,1.);
#5617 = DIRECTION('',(-1.,0.));
#5618 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5619 = ORIENTED_EDGE('',*,*,#5620,.F.);
#5620 = EDGE_CURVE('',#5621,#5598,#5623,.T.);
#5621 = VERTEX_POINT('',#5622);
#5622 = CARTESIAN_POINT('',(-0.655,-3.856,8.));
#5623 = SURFACE_CURVE('',#5624,(#5628,#5635),.PCURVE_S1.);
#5624 = LINE('',#5625,#5626);
#5625 = CARTESIAN_POINT('',(-0.655,-3.856,8.));
#5626 = VECTOR('',#5627,1.);
#5627 = DIRECTION('',(0.,0.,1.));
#5628 = PCURVE('',#5560,#5629);
#5629 = DEFINITIONAL_REPRESENTATION('',(#5630),#5634);
#5630 = LINE('',#5631,#5632);
#5631 = CARTESIAN_POINT('',(3.E-03,0.));
#5632 = VECTOR('',#5633,1.);
#5633 = DIRECTION('',(0.,-1.));
#5634 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5635 = PCURVE('',#5636,#5641);
#5636 = PLANE('',#5637);
#5637 = AXIS2_PLACEMENT_3D('',#5638,#5639,#5640);
#5638 = CARTESIAN_POINT('',(-0.655,-3.856,8.));
#5639 = DIRECTION('',(1.,-2.2E-16,0.));
#5640 = DIRECTION('',(-2.2E-16,-1.,0.));
#5641 = DEFINITIONAL_REPRESENTATION('',(#5642),#5646);
#5642 = LINE('',#5643,#5644);
#5643 = CARTESIAN_POINT('',(0.,0.));
#5644 = VECTOR('',#5645,1.);
#5645 = DIRECTION('',(0.,-1.));
#5646 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5647 = ORIENTED_EDGE('',*,*,#5648,.F.);
#5648 = EDGE_CURVE('',#5545,#5621,#5649,.T.);
#5649 = SURFACE_CURVE('',#5650,(#5654,#5661),.PCURVE_S1.);
#5650 = LINE('',#5651,#5652);
#5651 = CARTESIAN_POINT('',(-0.655,-3.853,8.));
#5652 = VECTOR('',#5653,1.);
#5653 = DIRECTION('',(0.,-1.,0.));
#5654 = PCURVE('',#5560,#5655);
#5655 = DEFINITIONAL_REPRESENTATION('',(#5656),#5660);
#5656 = LINE('',#5657,#5658);
#5657 = CARTESIAN_POINT('',(0.,0.));
#5658 = VECTOR('',#5659,1.);
#5659 = DIRECTION('',(1.,-0.));
#5660 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5661 = PCURVE('',#4191,#5662);
#5662 = DEFINITIONAL_REPRESENTATION('',(#5663),#5667);
#5663 = LINE('',#5664,#5665);
#5664 = CARTESIAN_POINT('',(-4.76788279517E-02,0.107682722252));
#5665 = VECTOR('',#5666,1.);
#5666 = DIRECTION('',(-1.,0.));
#5667 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5668 = ADVANCED_FACE('',(#5669),#5636,.T.);
#5669 = FACE_BOUND('',#5670,.T.);
#5670 = EDGE_LOOP('',(#5671,#5672,#5695,#5725));
#5671 = ORIENTED_EDGE('',*,*,#5620,.T.);
#5672 = ORIENTED_EDGE('',*,*,#5673,.T.);
#5673 = EDGE_CURVE('',#5598,#5674,#5676,.T.);
#5674 = VERTEX_POINT('',#5675);
#5675 = CARTESIAN_POINT('',(-0.655,-3.859,8.2));
#5676 = SURFACE_CURVE('',#5677,(#5681,#5688),.PCURVE_S1.);
#5677 = LINE('',#5678,#5679);
#5678 = CARTESIAN_POINT('',(-0.655,-3.856,8.2));
#5679 = VECTOR('',#5680,1.);
#5680 = DIRECTION('',(0.,-1.,0.));
#5681 = PCURVE('',#5636,#5682);
#5682 = DEFINITIONAL_REPRESENTATION('',(#5683),#5687);
#5683 = LINE('',#5684,#5685);
#5684 = CARTESIAN_POINT('',(0.,-0.2));
#5685 = VECTOR('',#5686,1.);
#5686 = DIRECTION('',(1.,-0.));
#5687 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5688 = PCURVE('',#4135,#5689);
#5689 = DEFINITIONAL_REPRESENTATION('',(#5690),#5694);
#5690 = LINE('',#5691,#5692);
#5691 = CARTESIAN_POINT('',(-5.06788279517E-02,0.107682722252));
#5692 = VECTOR('',#5693,1.);
#5693 = DIRECTION('',(-1.,0.));
#5694 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5695 = ORIENTED_EDGE('',*,*,#5696,.F.);
#5696 = EDGE_CURVE('',#5697,#5674,#5699,.T.);
#5697 = VERTEX_POINT('',#5698);
#5698 = CARTESIAN_POINT('',(-0.655,-3.859,8.));
#5699 = SURFACE_CURVE('',#5700,(#5704,#5711),.PCURVE_S1.);
#5700 = LINE('',#5701,#5702);
#5701 = CARTESIAN_POINT('',(-0.655,-3.859,8.));
#5702 = VECTOR('',#5703,1.);
#5703 = DIRECTION('',(0.,0.,1.));
#5704 = PCURVE('',#5636,#5705);
#5705 = DEFINITIONAL_REPRESENTATION('',(#5706),#5710);
#5706 = LINE('',#5707,#5708);
#5707 = CARTESIAN_POINT('',(3.E-03,0.));
#5708 = VECTOR('',#5709,1.);
#5709 = DIRECTION('',(0.,-1.));
#5710 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5711 = PCURVE('',#5712,#5719);
#5712 = SURFACE_OF_LINEAR_EXTRUSION('',#5713,#5717);
#5713 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5714,#5715,#5716),
#5714 = CARTESIAN_POINT('',(-0.655,-3.859,8.));
#5715 = CARTESIAN_POINT('',(-0.629,-4.083,8.));
#5716 = CARTESIAN_POINT('',(-0.544,-4.117,8.));
#5717 = VECTOR('',#5718,1.);
#5718 = DIRECTION('',(-0.,-0.,-1.));
#5719 = DEFINITIONAL_REPRESENTATION('',(#5720),#5724);
#5720 = LINE('',#5721,#5722);
#5721 = CARTESIAN_POINT('',(0.,0.));
#5722 = VECTOR('',#5723,1.);
#5723 = DIRECTION('',(0.,-1.));
#5724 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5725 = ORIENTED_EDGE('',*,*,#5726,.F.);
#5726 = EDGE_CURVE('',#5621,#5697,#5727,.T.);
#5727 = SURFACE_CURVE('',#5728,(#5732,#5739),.PCURVE_S1.);
#5728 = LINE('',#5729,#5730);
#5729 = CARTESIAN_POINT('',(-0.655,-3.856,8.));
#5730 = VECTOR('',#5731,1.);
#5731 = DIRECTION('',(0.,-1.,0.));
#5732 = PCURVE('',#5636,#5733);
#5733 = DEFINITIONAL_REPRESENTATION('',(#5734),#5738);
#5734 = LINE('',#5735,#5736);
#5735 = CARTESIAN_POINT('',(0.,0.));
#5736 = VECTOR('',#5737,1.);
#5737 = DIRECTION('',(1.,-0.));
#5738 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5739 = PCURVE('',#4191,#5740);
#5740 = DEFINITIONAL_REPRESENTATION('',(#5741),#5745);
#5741 = LINE('',#5742,#5743);
#5742 = CARTESIAN_POINT('',(-5.06788279517E-02,0.107682722252));
#5743 = VECTOR('',#5744,1.);
#5744 = DIRECTION('',(-1.,0.));
#5745 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5746 = ADVANCED_FACE('',(#5747),#5712,.T.);
#5747 = FACE_BOUND('',#5748,.T.);
#5748 = EDGE_LOOP('',(#5749,#5750,#5773,#5803));
#5749 = ORIENTED_EDGE('',*,*,#5696,.T.);
#5750 = ORIENTED_EDGE('',*,*,#5751,.T.);
#5751 = EDGE_CURVE('',#5674,#5752,#5754,.T.);
#5752 = VERTEX_POINT('',#5753);
#5753 = CARTESIAN_POINT('',(-0.544,-4.117,8.2));
#5754 = SURFACE_CURVE('',#5755,(#5759,#5766),.PCURVE_S1.);
#5755 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5756,#5757,#5758),
#5756 = CARTESIAN_POINT('',(-0.655,-3.859,8.2));
#5757 = CARTESIAN_POINT('',(-0.629,-4.083,8.2));
#5758 = CARTESIAN_POINT('',(-0.544,-4.117,8.2));
#5759 = PCURVE('',#5712,#5760);
#5760 = DEFINITIONAL_REPRESENTATION('',(#5761),#5765);
#5761 = LINE('',#5762,#5763);
#5762 = CARTESIAN_POINT('',(0.,-0.2));
#5763 = VECTOR('',#5764,1.);
#5764 = DIRECTION('',(1.,0.));
#5765 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5766 = PCURVE('',#4135,#5767);
#5767 = DEFINITIONAL_REPRESENTATION('',(#5768),#5772);
#5768 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5769,#5770,#5771),
#5769 = CARTESIAN_POINT('',(-5.36788279517E-02,0.107682722252));
#5770 = CARTESIAN_POINT('',(-0.277678827952,0.133682722252));
#5771 = CARTESIAN_POINT('',(-0.311678827952,0.218682722252));
#5772 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5773 = ORIENTED_EDGE('',*,*,#5774,.F.);
#5774 = EDGE_CURVE('',#5775,#5752,#5777,.T.);
#5775 = VERTEX_POINT('',#5776);
#5776 = CARTESIAN_POINT('',(-0.544,-4.117,8.));
#5777 = SURFACE_CURVE('',#5778,(#5782,#5789),.PCURVE_S1.);
#5778 = LINE('',#5779,#5780);
#5779 = CARTESIAN_POINT('',(-0.544,-4.117,8.));
#5780 = VECTOR('',#5781,1.);
#5781 = DIRECTION('',(0.,0.,1.));
#5782 = PCURVE('',#5712,#5783);
#5783 = DEFINITIONAL_REPRESENTATION('',(#5784),#5788);
#5784 = LINE('',#5785,#5786);
#5785 = CARTESIAN_POINT('',(1.,0.));
#5786 = VECTOR('',#5787,1.);
#5787 = DIRECTION('',(0.,-1.));
#5788 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5789 = PCURVE('',#5790,#5797);
#5790 = SURFACE_OF_LINEAR_EXTRUSION('',#5791,#5795);
#5791 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5792,#5793,#5794),
#5792 = CARTESIAN_POINT('',(-0.544,-4.117,8.));
#5793 = CARTESIAN_POINT('',(-0.517,-4.126,8.));
#5794 = CARTESIAN_POINT('',(-0.485,-4.126,8.));
#5795 = VECTOR('',#5796,1.);
#5796 = DIRECTION('',(-0.,-0.,-1.));
#5797 = DEFINITIONAL_REPRESENTATION('',(#5798),#5802);
#5798 = LINE('',#5799,#5800);
#5799 = CARTESIAN_POINT('',(0.,0.));
#5800 = VECTOR('',#5801,1.);
#5801 = DIRECTION('',(0.,-1.));
#5802 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5803 = ORIENTED_EDGE('',*,*,#5804,.F.);
#5804 = EDGE_CURVE('',#5697,#5775,#5805,.T.);
#5805 = SURFACE_CURVE('',#5806,(#5810,#5817),.PCURVE_S1.);
#5806 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5807,#5808,#5809),
#5807 = CARTESIAN_POINT('',(-0.655,-3.859,8.));
#5808 = CARTESIAN_POINT('',(-0.629,-4.083,8.));
#5809 = CARTESIAN_POINT('',(-0.544,-4.117,8.));
#5810 = PCURVE('',#5712,#5811);
#5811 = DEFINITIONAL_REPRESENTATION('',(#5812),#5816);
#5812 = LINE('',#5813,#5814);
#5813 = CARTESIAN_POINT('',(0.,0.));
#5814 = VECTOR('',#5815,1.);
#5815 = DIRECTION('',(1.,0.));
#5816 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5817 = PCURVE('',#4191,#5818);
#5818 = DEFINITIONAL_REPRESENTATION('',(#5819),#5823);
#5819 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5820,#5821,#5822),
#5820 = CARTESIAN_POINT('',(-5.36788279517E-02,0.107682722252));
#5821 = CARTESIAN_POINT('',(-0.277678827952,0.133682722252));
#5822 = CARTESIAN_POINT('',(-0.311678827952,0.218682722252));
#5823 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5824 = ADVANCED_FACE('',(#5825),#5790,.T.);
#5825 = FACE_BOUND('',#5826,.T.);
#5826 = EDGE_LOOP('',(#5827,#5828,#5851,#5879));
#5827 = ORIENTED_EDGE('',*,*,#5774,.T.);
#5828 = ORIENTED_EDGE('',*,*,#5829,.T.);
#5829 = EDGE_CURVE('',#5752,#5830,#5832,.T.);
#5830 = VERTEX_POINT('',#5831);
#5831 = CARTESIAN_POINT('',(-0.485,-4.126,8.2));
#5832 = SURFACE_CURVE('',#5833,(#5837,#5844),.PCURVE_S1.);
#5833 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5834,#5835,#5836),
#5834 = CARTESIAN_POINT('',(-0.544,-4.117,8.2));
#5835 = CARTESIAN_POINT('',(-0.517,-4.126,8.2));
#5836 = CARTESIAN_POINT('',(-0.485,-4.126,8.2));
#5837 = PCURVE('',#5790,#5838);
#5838 = DEFINITIONAL_REPRESENTATION('',(#5839),#5843);
#5839 = LINE('',#5840,#5841);
#5840 = CARTESIAN_POINT('',(0.,-0.2));
#5841 = VECTOR('',#5842,1.);
#5842 = DIRECTION('',(1.,0.));
#5843 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5844 = PCURVE('',#4135,#5845);
#5845 = DEFINITIONAL_REPRESENTATION('',(#5846),#5850);
#5846 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5847,#5848,#5849),
#5847 = CARTESIAN_POINT('',(-0.311678827952,0.218682722252));
#5848 = CARTESIAN_POINT('',(-0.320678827952,0.245682722252));
#5849 = CARTESIAN_POINT('',(-0.320678827952,0.277682722252));
#5850 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5851 = ORIENTED_EDGE('',*,*,#5852,.F.);
#5852 = EDGE_CURVE('',#5853,#5830,#5855,.T.);
#5853 = VERTEX_POINT('',#5854);
#5854 = CARTESIAN_POINT('',(-0.485,-4.126,8.));
#5855 = SURFACE_CURVE('',#5856,(#5860,#5867),.PCURVE_S1.);
#5856 = LINE('',#5857,#5858);
#5857 = CARTESIAN_POINT('',(-0.485,-4.126,8.));
#5858 = VECTOR('',#5859,1.);
#5859 = DIRECTION('',(0.,0.,1.));
#5860 = PCURVE('',#5790,#5861);
#5861 = DEFINITIONAL_REPRESENTATION('',(#5862),#5866);
#5862 = LINE('',#5863,#5864);
#5863 = CARTESIAN_POINT('',(1.,0.));
#5864 = VECTOR('',#5865,1.);
#5865 = DIRECTION('',(0.,-1.));
#5866 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5867 = PCURVE('',#5868,#5873);
#5868 = PLANE('',#5869);
#5869 = AXIS2_PLACEMENT_3D('',#5870,#5871,#5872);
#5870 = CARTESIAN_POINT('',(-0.485,-4.126,8.));
#5871 = DIRECTION('',(2.2E-16,1.,0.));
#5872 = DIRECTION('',(1.,-2.2E-16,0.));
#5873 = DEFINITIONAL_REPRESENTATION('',(#5874),#5878);
#5874 = LINE('',#5875,#5876);
#5875 = CARTESIAN_POINT('',(0.,0.));
#5876 = VECTOR('',#5877,1.);
#5877 = DIRECTION('',(0.,-1.));
#5878 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5879 = ORIENTED_EDGE('',*,*,#5880,.F.);
#5880 = EDGE_CURVE('',#5775,#5853,#5881,.T.);
#5881 = SURFACE_CURVE('',#5882,(#5886,#5893),.PCURVE_S1.);
#5882 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5883,#5884,#5885),
#5883 = CARTESIAN_POINT('',(-0.544,-4.117,8.));
#5884 = CARTESIAN_POINT('',(-0.517,-4.126,8.));
#5885 = CARTESIAN_POINT('',(-0.485,-4.126,8.));
#5886 = PCURVE('',#5790,#5887);
#5887 = DEFINITIONAL_REPRESENTATION('',(#5888),#5892);
#5888 = LINE('',#5889,#5890);
#5889 = CARTESIAN_POINT('',(0.,0.));
#5890 = VECTOR('',#5891,1.);
#5891 = DIRECTION('',(1.,0.));
#5892 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5893 = PCURVE('',#4191,#5894);
#5894 = DEFINITIONAL_REPRESENTATION('',(#5895),#5899);
#5895 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5896,#5897,#5898),
#5896 = CARTESIAN_POINT('',(-0.311678827952,0.218682722252));
#5897 = CARTESIAN_POINT('',(-0.320678827952,0.245682722252));
#5898 = CARTESIAN_POINT('',(-0.320678827952,0.277682722252));
#5899 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5900 = ADVANCED_FACE('',(#5901),#5868,.T.);
#5901 = FACE_BOUND('',#5902,.T.);
#5902 = EDGE_LOOP('',(#5903,#5904,#5927,#5957));
#5903 = ORIENTED_EDGE('',*,*,#5852,.T.);
#5904 = ORIENTED_EDGE('',*,*,#5905,.T.);
#5905 = EDGE_CURVE('',#5830,#5906,#5908,.T.);
#5906 = VERTEX_POINT('',#5907);
#5907 = CARTESIAN_POINT('',(-0.421,-4.126,8.2));
#5908 = SURFACE_CURVE('',#5909,(#5913,#5920),.PCURVE_S1.);
#5909 = LINE('',#5910,#5911);
#5910 = CARTESIAN_POINT('',(-0.485,-4.126,8.2));
#5911 = VECTOR('',#5912,1.);
#5912 = DIRECTION('',(1.,0.,0.));
#5913 = PCURVE('',#5868,#5914);
#5914 = DEFINITIONAL_REPRESENTATION('',(#5915),#5919);
#5915 = LINE('',#5916,#5917);
#5916 = CARTESIAN_POINT('',(0.,-0.2));
#5917 = VECTOR('',#5918,1.);
#5918 = DIRECTION('',(1.,0.));
#5919 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5920 = PCURVE('',#4135,#5921);
#5921 = DEFINITIONAL_REPRESENTATION('',(#5922),#5926);
#5922 = LINE('',#5923,#5924);
#5923 = CARTESIAN_POINT('',(-0.320678827952,0.277682722252));
#5924 = VECTOR('',#5925,1.);
#5925 = DIRECTION('',(0.,1.));
#5926 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5927 = ORIENTED_EDGE('',*,*,#5928,.F.);
#5928 = EDGE_CURVE('',#5929,#5906,#5931,.T.);
#5929 = VERTEX_POINT('',#5930);
#5930 = CARTESIAN_POINT('',(-0.421,-4.126,8.));
#5931 = SURFACE_CURVE('',#5932,(#5936,#5943),.PCURVE_S1.);
#5932 = LINE('',#5933,#5934);
#5933 = CARTESIAN_POINT('',(-0.421,-4.126,8.));
#5934 = VECTOR('',#5935,1.);
#5935 = DIRECTION('',(0.,0.,1.));
#5936 = PCURVE('',#5868,#5937);
#5937 = DEFINITIONAL_REPRESENTATION('',(#5938),#5942);
#5938 = LINE('',#5939,#5940);
#5939 = CARTESIAN_POINT('',(6.4E-02,0.));
#5940 = VECTOR('',#5941,1.);
#5941 = DIRECTION('',(0.,-1.));
#5942 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5943 = PCURVE('',#5944,#5951);
#5944 = SURFACE_OF_LINEAR_EXTRUSION('',#5945,#5949);
#5945 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5946,#5947,#5948),
#5946 = CARTESIAN_POINT('',(-0.421,-4.126,8.));
#5947 = CARTESIAN_POINT('',(-0.233,-4.126,8.));
#5948 = CARTESIAN_POINT('',(-0.198,-3.877,8.));
#5949 = VECTOR('',#5950,1.);
#5950 = DIRECTION('',(-0.,-0.,-1.));
#5951 = DEFINITIONAL_REPRESENTATION('',(#5952),#5956);
#5952 = LINE('',#5953,#5954);
#5953 = CARTESIAN_POINT('',(0.,0.));
#5954 = VECTOR('',#5955,1.);
#5955 = DIRECTION('',(0.,-1.));
#5956 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5957 = ORIENTED_EDGE('',*,*,#5958,.F.);
#5958 = EDGE_CURVE('',#5853,#5929,#5959,.T.);
#5959 = SURFACE_CURVE('',#5960,(#5964,#5971),.PCURVE_S1.);
#5960 = LINE('',#5961,#5962);
#5961 = CARTESIAN_POINT('',(-0.485,-4.126,8.));
#5962 = VECTOR('',#5963,1.);
#5963 = DIRECTION('',(1.,0.,0.));
#5964 = PCURVE('',#5868,#5965);
#5965 = DEFINITIONAL_REPRESENTATION('',(#5966),#5970);
#5966 = LINE('',#5967,#5968);
#5967 = CARTESIAN_POINT('',(0.,0.));
#5968 = VECTOR('',#5969,1.);
#5969 = DIRECTION('',(1.,0.));
#5970 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5971 = PCURVE('',#4191,#5972);
#5972 = DEFINITIONAL_REPRESENTATION('',(#5973),#5977);
#5973 = LINE('',#5974,#5975);
#5974 = CARTESIAN_POINT('',(-0.320678827952,0.277682722252));
#5975 = VECTOR('',#5976,1.);
#5976 = DIRECTION('',(0.,1.));
#5977 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5978 = ADVANCED_FACE('',(#5979),#5944,.T.);
#5979 = FACE_BOUND('',#5980,.T.);
#5980 = EDGE_LOOP('',(#5981,#5982,#6005,#6035));
#5981 = ORIENTED_EDGE('',*,*,#5928,.T.);
#5982 = ORIENTED_EDGE('',*,*,#5983,.T.);
#5983 = EDGE_CURVE('',#5906,#5984,#5986,.T.);
#5984 = VERTEX_POINT('',#5985);
#5985 = CARTESIAN_POINT('',(-0.198,-3.877,8.2));
#5986 = SURFACE_CURVE('',#5987,(#5991,#5998),.PCURVE_S1.);
#5987 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#5988,#5989,#5990),
#5988 = CARTESIAN_POINT('',(-0.421,-4.126,8.2));
#5989 = CARTESIAN_POINT('',(-0.233,-4.126,8.2));
#5990 = CARTESIAN_POINT('',(-0.198,-3.877,8.2));
#5991 = PCURVE('',#5944,#5992);
#5992 = DEFINITIONAL_REPRESENTATION('',(#5993),#5997);
#5993 = LINE('',#5994,#5995);
#5994 = CARTESIAN_POINT('',(0.,-0.2));
#5995 = VECTOR('',#5996,1.);
#5996 = DIRECTION('',(1.,0.));
#5997 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#5998 = PCURVE('',#4135,#5999);
#5999 = DEFINITIONAL_REPRESENTATION('',(#6000),#6004);
#6000 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6001,#6002,#6003),
#6001 = CARTESIAN_POINT('',(-0.320678827952,0.341682722252));
#6002 = CARTESIAN_POINT('',(-0.320678827952,0.529682722252));
#6003 = CARTESIAN_POINT('',(-7.16788279517E-02,0.564682722252));
#6004 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6005 = ORIENTED_EDGE('',*,*,#6006,.F.);
#6006 = EDGE_CURVE('',#6007,#5984,#6009,.T.);
#6007 = VERTEX_POINT('',#6008);
#6008 = CARTESIAN_POINT('',(-0.198,-3.877,8.));
#6009 = SURFACE_CURVE('',#6010,(#6014,#6021),.PCURVE_S1.);
#6010 = LINE('',#6011,#6012);
#6011 = CARTESIAN_POINT('',(-0.198,-3.877,8.));
#6012 = VECTOR('',#6013,1.);
#6013 = DIRECTION('',(0.,0.,1.));
#6014 = PCURVE('',#5944,#6015);
#6015 = DEFINITIONAL_REPRESENTATION('',(#6016),#6020);
#6016 = LINE('',#6017,#6018);
#6017 = CARTESIAN_POINT('',(1.,0.));
#6018 = VECTOR('',#6019,1.);
#6019 = DIRECTION('',(0.,-1.));
#6020 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6021 = PCURVE('',#6022,#6029);
#6022 = SURFACE_OF_LINEAR_EXTRUSION('',#6023,#6027);
#6023 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6024,#6025,#6026),
#6024 = CARTESIAN_POINT('',(-0.198,-3.877,8.));
#6025 = CARTESIAN_POINT('',(-0.192,-3.825,8.));
#6026 = CARTESIAN_POINT('',(-0.192,-3.767,8.));
#6027 = VECTOR('',#6028,1.);
#6028 = DIRECTION('',(-0.,-0.,-1.));
#6029 = DEFINITIONAL_REPRESENTATION('',(#6030),#6034);
#6030 = LINE('',#6031,#6032);
#6031 = CARTESIAN_POINT('',(0.,0.));
#6032 = VECTOR('',#6033,1.);
#6033 = DIRECTION('',(0.,-1.));
#6034 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6035 = ORIENTED_EDGE('',*,*,#6036,.F.);
#6036 = EDGE_CURVE('',#5929,#6007,#6037,.T.);
#6037 = SURFACE_CURVE('',#6038,(#6042,#6049),.PCURVE_S1.);
#6038 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6039,#6040,#6041),
#6039 = CARTESIAN_POINT('',(-0.421,-4.126,8.));
#6040 = CARTESIAN_POINT('',(-0.233,-4.126,8.));
#6041 = CARTESIAN_POINT('',(-0.198,-3.877,8.));
#6042 = PCURVE('',#5944,#6043);
#6043 = DEFINITIONAL_REPRESENTATION('',(#6044),#6048);
#6044 = LINE('',#6045,#6046);
#6045 = CARTESIAN_POINT('',(0.,0.));
#6046 = VECTOR('',#6047,1.);
#6047 = DIRECTION('',(1.,0.));
#6048 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6049 = PCURVE('',#4191,#6050);
#6050 = DEFINITIONAL_REPRESENTATION('',(#6051),#6055);
#6051 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6052,#6053,#6054),
#6052 = CARTESIAN_POINT('',(-0.320678827952,0.341682722252));
#6053 = CARTESIAN_POINT('',(-0.320678827952,0.529682722252));
#6054 = CARTESIAN_POINT('',(-7.16788279517E-02,0.564682722252));
#6055 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6056 = ADVANCED_FACE('',(#6057),#6022,.T.);
#6057 = FACE_BOUND('',#6058,.T.);
#6058 = EDGE_LOOP('',(#6059,#6060,#6083,#6113));
#6059 = ORIENTED_EDGE('',*,*,#6006,.T.);
#6060 = ORIENTED_EDGE('',*,*,#6061,.T.);
#6061 = EDGE_CURVE('',#5984,#6062,#6064,.T.);
#6062 = VERTEX_POINT('',#6063);
#6063 = CARTESIAN_POINT('',(-0.192,-3.767,8.2));
#6064 = SURFACE_CURVE('',#6065,(#6069,#6076),.PCURVE_S1.);
#6065 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6066,#6067,#6068),
#6066 = CARTESIAN_POINT('',(-0.198,-3.877,8.2));
#6067 = CARTESIAN_POINT('',(-0.192,-3.825,8.2));
#6068 = CARTESIAN_POINT('',(-0.192,-3.767,8.2));
#6069 = PCURVE('',#6022,#6070);
#6070 = DEFINITIONAL_REPRESENTATION('',(#6071),#6075);
#6071 = LINE('',#6072,#6073);
#6072 = CARTESIAN_POINT('',(0.,-0.2));
#6073 = VECTOR('',#6074,1.);
#6074 = DIRECTION('',(1.,0.));
#6075 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6076 = PCURVE('',#4135,#6077);
#6077 = DEFINITIONAL_REPRESENTATION('',(#6078),#6082);
#6078 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6079,#6080,#6081),
#6079 = CARTESIAN_POINT('',(-7.16788279517E-02,0.564682722252));
#6080 = CARTESIAN_POINT('',(-1.96788279517E-02,0.570682722252));
#6081 = CARTESIAN_POINT('',(3.83211720483E-02,0.570682722252));
#6082 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6083 = ORIENTED_EDGE('',*,*,#6084,.F.);
#6084 = EDGE_CURVE('',#6085,#6062,#6087,.T.);
#6085 = VERTEX_POINT('',#6086);
#6086 = CARTESIAN_POINT('',(-0.192,-3.767,8.));
#6087 = SURFACE_CURVE('',#6088,(#6092,#6099),.PCURVE_S1.);
#6088 = LINE('',#6089,#6090);
#6089 = CARTESIAN_POINT('',(-0.192,-3.767,8.));
#6090 = VECTOR('',#6091,1.);
#6091 = DIRECTION('',(0.,0.,1.));
#6092 = PCURVE('',#6022,#6093);
#6093 = DEFINITIONAL_REPRESENTATION('',(#6094),#6098);
#6094 = LINE('',#6095,#6096);
#6095 = CARTESIAN_POINT('',(1.,0.));
#6096 = VECTOR('',#6097,1.);
#6097 = DIRECTION('',(0.,-1.));
#6098 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6099 = PCURVE('',#6100,#6107);
#6100 = SURFACE_OF_LINEAR_EXTRUSION('',#6101,#6105);
#6101 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6102,#6103,#6104),
#6102 = CARTESIAN_POINT('',(-0.192,-3.767,8.));
#6103 = CARTESIAN_POINT('',(-0.192,-3.45,8.));
#6104 = CARTESIAN_POINT('',(-0.398,-3.398,8.));
#6105 = VECTOR('',#6106,1.);
#6106 = DIRECTION('',(-0.,-0.,-1.));
#6107 = DEFINITIONAL_REPRESENTATION('',(#6108),#6112);
#6108 = LINE('',#6109,#6110);
#6109 = CARTESIAN_POINT('',(0.,0.));
#6110 = VECTOR('',#6111,1.);
#6111 = DIRECTION('',(0.,-1.));
#6112 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6113 = ORIENTED_EDGE('',*,*,#6114,.F.);
#6114 = EDGE_CURVE('',#6007,#6085,#6115,.T.);
#6115 = SURFACE_CURVE('',#6116,(#6120,#6127),.PCURVE_S1.);
#6116 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6117,#6118,#6119),
#6117 = CARTESIAN_POINT('',(-0.198,-3.877,8.));
#6118 = CARTESIAN_POINT('',(-0.192,-3.825,8.));
#6119 = CARTESIAN_POINT('',(-0.192,-3.767,8.));
#6120 = PCURVE('',#6022,#6121);
#6121 = DEFINITIONAL_REPRESENTATION('',(#6122),#6126);
#6122 = LINE('',#6123,#6124);
#6123 = CARTESIAN_POINT('',(0.,0.));
#6124 = VECTOR('',#6125,1.);
#6125 = DIRECTION('',(1.,0.));
#6126 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6127 = PCURVE('',#4191,#6128);
#6128 = DEFINITIONAL_REPRESENTATION('',(#6129),#6133);
#6129 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6130,#6131,#6132),
#6130 = CARTESIAN_POINT('',(-7.16788279517E-02,0.564682722252));
#6131 = CARTESIAN_POINT('',(-1.96788279517E-02,0.570682722252));
#6132 = CARTESIAN_POINT('',(3.83211720483E-02,0.570682722252));
#6133 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6134 = ADVANCED_FACE('',(#6135),#6100,.T.);
#6135 = FACE_BOUND('',#6136,.T.);
#6136 = EDGE_LOOP('',(#6137,#6138,#6161,#6191));
#6137 = ORIENTED_EDGE('',*,*,#6084,.T.);
#6138 = ORIENTED_EDGE('',*,*,#6139,.T.);
#6139 = EDGE_CURVE('',#6062,#6140,#6142,.T.);
#6140 = VERTEX_POINT('',#6141);
#6141 = CARTESIAN_POINT('',(-0.398,-3.398,8.2));
#6142 = SURFACE_CURVE('',#6143,(#6147,#6154),.PCURVE_S1.);
#6143 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6144,#6145,#6146),
#6144 = CARTESIAN_POINT('',(-0.192,-3.767,8.2));
#6145 = CARTESIAN_POINT('',(-0.192,-3.45,8.2));
#6146 = CARTESIAN_POINT('',(-0.398,-3.398,8.2));
#6147 = PCURVE('',#6100,#6148);
#6148 = DEFINITIONAL_REPRESENTATION('',(#6149),#6153);
#6149 = LINE('',#6150,#6151);
#6150 = CARTESIAN_POINT('',(0.,-0.2));
#6151 = VECTOR('',#6152,1.);
#6152 = DIRECTION('',(1.,0.));
#6153 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6154 = PCURVE('',#4135,#6155);
#6155 = DEFINITIONAL_REPRESENTATION('',(#6156),#6160);
#6156 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6157,#6158,#6159),
#6157 = CARTESIAN_POINT('',(3.83211720483E-02,0.570682722252));
#6158 = CARTESIAN_POINT('',(0.355321172048,0.570682722252));
#6159 = CARTESIAN_POINT('',(0.407321172048,0.364682722252));
#6160 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6161 = ORIENTED_EDGE('',*,*,#6162,.F.);
#6162 = EDGE_CURVE('',#6163,#6140,#6165,.T.);
#6163 = VERTEX_POINT('',#6164);
#6164 = CARTESIAN_POINT('',(-0.398,-3.398,8.));
#6165 = SURFACE_CURVE('',#6166,(#6170,#6177),.PCURVE_S1.);
#6166 = LINE('',#6167,#6168);
#6167 = CARTESIAN_POINT('',(-0.398,-3.398,8.));
#6168 = VECTOR('',#6169,1.);
#6169 = DIRECTION('',(0.,0.,1.));
#6170 = PCURVE('',#6100,#6171);
#6171 = DEFINITIONAL_REPRESENTATION('',(#6172),#6176);
#6172 = LINE('',#6173,#6174);
#6173 = CARTESIAN_POINT('',(1.,0.));
#6174 = VECTOR('',#6175,1.);
#6175 = DIRECTION('',(0.,-1.));
#6176 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6177 = PCURVE('',#6178,#6185);
#6178 = SURFACE_OF_LINEAR_EXTRUSION('',#6179,#6183);
#6179 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6180,#6181,#6182),
#6180 = CARTESIAN_POINT('',(-0.398,-3.398,8.));
#6181 = CARTESIAN_POINT('',(-0.423,-3.392,8.));
#6182 = CARTESIAN_POINT('',(-0.448,-3.389,8.));
#6183 = VECTOR('',#6184,1.);
#6184 = DIRECTION('',(-0.,-0.,-1.));
#6185 = DEFINITIONAL_REPRESENTATION('',(#6186),#6190);
#6186 = LINE('',#6187,#6188);
#6187 = CARTESIAN_POINT('',(0.,0.));
#6188 = VECTOR('',#6189,1.);
#6189 = DIRECTION('',(0.,-1.));
#6190 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6191 = ORIENTED_EDGE('',*,*,#6192,.F.);
#6192 = EDGE_CURVE('',#6085,#6163,#6193,.T.);
#6193 = SURFACE_CURVE('',#6194,(#6198,#6205),.PCURVE_S1.);
#6194 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6195,#6196,#6197),
#6195 = CARTESIAN_POINT('',(-0.192,-3.767,8.));
#6196 = CARTESIAN_POINT('',(-0.192,-3.45,8.));
#6197 = CARTESIAN_POINT('',(-0.398,-3.398,8.));
#6198 = PCURVE('',#6100,#6199);
#6199 = DEFINITIONAL_REPRESENTATION('',(#6200),#6204);
#6200 = LINE('',#6201,#6202);
#6201 = CARTESIAN_POINT('',(0.,0.));
#6202 = VECTOR('',#6203,1.);
#6203 = DIRECTION('',(1.,0.));
#6204 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6205 = PCURVE('',#4191,#6206);
#6206 = DEFINITIONAL_REPRESENTATION('',(#6207),#6211);
#6207 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6208,#6209,#6210),
#6208 = CARTESIAN_POINT('',(3.83211720483E-02,0.570682722252));
#6209 = CARTESIAN_POINT('',(0.355321172048,0.570682722252));
#6210 = CARTESIAN_POINT('',(0.407321172048,0.364682722252));
#6211 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6212 = ADVANCED_FACE('',(#6213),#6178,.T.);
#6213 = FACE_BOUND('',#6214,.T.);
#6214 = EDGE_LOOP('',(#6215,#6216,#6239,#6262));
#6215 = ORIENTED_EDGE('',*,*,#6162,.T.);
#6216 = ORIENTED_EDGE('',*,*,#6217,.T.);
#6217 = EDGE_CURVE('',#6140,#6218,#6220,.T.);
#6218 = VERTEX_POINT('',#6219);
#6219 = CARTESIAN_POINT('',(-0.448,-3.389,8.2));
#6220 = SURFACE_CURVE('',#6221,(#6225,#6232),.PCURVE_S1.);
#6221 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6222,#6223,#6224),
#6222 = CARTESIAN_POINT('',(-0.398,-3.398,8.2));
#6223 = CARTESIAN_POINT('',(-0.423,-3.392,8.2));
#6224 = CARTESIAN_POINT('',(-0.448,-3.389,8.2));
#6225 = PCURVE('',#6178,#6226);
#6226 = DEFINITIONAL_REPRESENTATION('',(#6227),#6231);
#6227 = LINE('',#6228,#6229);
#6228 = CARTESIAN_POINT('',(0.,-0.2));
#6229 = VECTOR('',#6230,1.);
#6230 = DIRECTION('',(1.,0.));
#6231 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6232 = PCURVE('',#4135,#6233);
#6233 = DEFINITIONAL_REPRESENTATION('',(#6234),#6238);
#6234 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6235,#6236,#6237),
#6235 = CARTESIAN_POINT('',(0.407321172048,0.364682722252));
#6236 = CARTESIAN_POINT('',(0.413321172048,0.339682722252));
#6237 = CARTESIAN_POINT('',(0.416321172048,0.314682722252));
#6238 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6239 = ORIENTED_EDGE('',*,*,#6240,.F.);
#6240 = EDGE_CURVE('',#6241,#6218,#6243,.T.);
#6241 = VERTEX_POINT('',#6242);
#6242 = CARTESIAN_POINT('',(-0.448,-3.389,8.));
#6243 = SURFACE_CURVE('',#6244,(#6248,#6255),.PCURVE_S1.);
#6244 = LINE('',#6245,#6246);
#6245 = CARTESIAN_POINT('',(-0.448,-3.389,8.));
#6246 = VECTOR('',#6247,1.);
#6247 = DIRECTION('',(0.,0.,1.));
#6248 = PCURVE('',#6178,#6249);
#6249 = DEFINITIONAL_REPRESENTATION('',(#6250),#6254);
#6250 = LINE('',#6251,#6252);
#6251 = CARTESIAN_POINT('',(1.,0.));
#6252 = VECTOR('',#6253,1.);
#6253 = DIRECTION('',(0.,-1.));
#6254 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6255 = PCURVE('',#4107,#6256);
#6256 = DEFINITIONAL_REPRESENTATION('',(#6257),#6261);
#6257 = LINE('',#6258,#6259);
#6258 = CARTESIAN_POINT('',(4.4E-16,0.));
#6259 = VECTOR('',#6260,1.);
#6260 = DIRECTION('',(0.,-1.));
#6261 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6262 = ORIENTED_EDGE('',*,*,#6263,.F.);
#6263 = EDGE_CURVE('',#6163,#6241,#6264,.T.);
#6264 = SURFACE_CURVE('',#6265,(#6269,#6276),.PCURVE_S1.);
#6265 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6266,#6267,#6268),
#6266 = CARTESIAN_POINT('',(-0.398,-3.398,8.));
#6267 = CARTESIAN_POINT('',(-0.423,-3.392,8.));
#6268 = CARTESIAN_POINT('',(-0.448,-3.389,8.));
#6269 = PCURVE('',#6178,#6270);
#6270 = DEFINITIONAL_REPRESENTATION('',(#6271),#6275);
#6271 = LINE('',#6272,#6273);
#6272 = CARTESIAN_POINT('',(0.,0.));
#6273 = VECTOR('',#6274,1.);
#6274 = DIRECTION('',(1.,0.));
#6275 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6276 = PCURVE('',#4191,#6277);
#6277 = DEFINITIONAL_REPRESENTATION('',(#6278),#6282);
#6278 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6279,#6280,#6281),
#6279 = CARTESIAN_POINT('',(0.407321172048,0.364682722252));
#6280 = CARTESIAN_POINT('',(0.413321172048,0.339682722252));
#6281 = CARTESIAN_POINT('',(0.416321172048,0.314682722252));
#6282 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6283 = ADVANCED_FACE('',(#6284),#4107,.T.);
#6284 = FACE_BOUND('',#6285,.T.);
#6285 = EDGE_LOOP('',(#6286,#6287,#6308,#6309));
#6286 = ORIENTED_EDGE('',*,*,#6240,.T.);
#6287 = ORIENTED_EDGE('',*,*,#6288,.T.);
#6288 = EDGE_CURVE('',#6218,#4085,#6289,.T.);
#6289 = SURFACE_CURVE('',#6290,(#6294,#6301),.PCURVE_S1.);
#6290 = LINE('',#6291,#6292);
#6291 = CARTESIAN_POINT('',(-0.448,-3.389,8.2));
#6292 = VECTOR('',#6293,1.);
#6293 = DIRECTION('',(0.,1.,0.));
#6294 = PCURVE('',#4107,#6295);
#6295 = DEFINITIONAL_REPRESENTATION('',(#6296),#6300);
#6296 = LINE('',#6297,#6298);
#6297 = CARTESIAN_POINT('',(0.,-0.2));
#6298 = VECTOR('',#6299,1.);
#6299 = DIRECTION('',(1.,0.));
#6300 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6301 = PCURVE('',#4135,#6302);
#6302 = DEFINITIONAL_REPRESENTATION('',(#6303),#6307);
#6303 = LINE('',#6304,#6305);
#6304 = CARTESIAN_POINT('',(0.416321172048,0.314682722252));
#6305 = VECTOR('',#6306,1.);
#6306 = DIRECTION('',(1.,0.));
#6307 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6308 = ORIENTED_EDGE('',*,*,#4082,.F.);
#6309 = ORIENTED_EDGE('',*,*,#6310,.F.);
#6310 = EDGE_CURVE('',#6241,#4083,#6311,.T.);
#6311 = SURFACE_CURVE('',#6312,(#6316,#6323),.PCURVE_S1.);
#6312 = LINE('',#6313,#6314);
#6313 = CARTESIAN_POINT('',(-0.448,-3.389,8.));
#6314 = VECTOR('',#6315,1.);
#6315 = DIRECTION('',(0.,1.,0.));
#6316 = PCURVE('',#4107,#6317);
#6317 = DEFINITIONAL_REPRESENTATION('',(#6318),#6322);
#6318 = LINE('',#6319,#6320);
#6319 = CARTESIAN_POINT('',(0.,0.));
#6320 = VECTOR('',#6321,1.);
#6321 = DIRECTION('',(1.,0.));
#6322 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6323 = PCURVE('',#4191,#6324);
#6324 = DEFINITIONAL_REPRESENTATION('',(#6325),#6329);
#6325 = LINE('',#6326,#6327);
#6326 = CARTESIAN_POINT('',(0.416321172048,0.314682722252));
#6327 = VECTOR('',#6328,1.);
#6328 = DIRECTION('',(1.,0.));
#6329 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6330 = ADVANCED_FACE('',(#6331),#6345,.T.);
#6331 = FACE_BOUND('',#6332,.T.);
#6332 = EDGE_LOOP('',(#6333,#6372,#6395,#6425));
#6333 = ORIENTED_EDGE('',*,*,#6334,.T.);
#6334 = EDGE_CURVE('',#6335,#6337,#6339,.T.);
#6335 = VERTEX_POINT('',#6336);
#6336 = CARTESIAN_POINT('',(-1.398,-3.644,8.));
#6337 = VERTEX_POINT('',#6338);
#6338 = CARTESIAN_POINT('',(-1.398,-3.644,8.2));
#6339 = SURFACE_CURVE('',#6340,(#6344,#6358),.PCURVE_S1.);
#6340 = LINE('',#6341,#6342);
#6341 = CARTESIAN_POINT('',(-1.398,-3.644,8.));
#6342 = VECTOR('',#6343,1.);
#6343 = DIRECTION('',(0.,0.,1.));
#6344 = PCURVE('',#6345,#6352);
#6345 = SURFACE_OF_LINEAR_EXTRUSION('',#6346,#6350);
#6346 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6347,#6348,#6349),
#6347 = CARTESIAN_POINT('',(-1.398,-3.644,8.));
#6348 = CARTESIAN_POINT('',(-1.398,-3.914,8.));
#6349 = CARTESIAN_POINT('',(-1.231,-4.055,8.));
#6350 = VECTOR('',#6351,1.);
#6351 = DIRECTION('',(-0.,-0.,-1.));
#6352 = DEFINITIONAL_REPRESENTATION('',(#6353),#6357);
#6353 = LINE('',#6354,#6355);
#6354 = CARTESIAN_POINT('',(0.,0.));
#6355 = VECTOR('',#6356,1.);
#6356 = DIRECTION('',(0.,-1.));
#6357 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6358 = PCURVE('',#6359,#6366);
#6359 = SURFACE_OF_LINEAR_EXTRUSION('',#6360,#6364);
#6360 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6361,#6362,#6363),
#6361 = CARTESIAN_POINT('',(-1.386,-3.533,8.));
#6362 = CARTESIAN_POINT('',(-1.398,-3.582,8.));
#6363 = CARTESIAN_POINT('',(-1.398,-3.644,8.));
#6364 = VECTOR('',#6365,1.);
#6365 = DIRECTION('',(-0.,-0.,-1.));
#6366 = DEFINITIONAL_REPRESENTATION('',(#6367),#6371);
#6367 = LINE('',#6368,#6369);
#6368 = CARTESIAN_POINT('',(1.,0.));
#6369 = VECTOR('',#6370,1.);
#6370 = DIRECTION('',(0.,-1.));
#6371 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6372 = ORIENTED_EDGE('',*,*,#6373,.T.);
#6373 = EDGE_CURVE('',#6337,#6374,#6376,.T.);
#6374 = VERTEX_POINT('',#6375);
#6375 = CARTESIAN_POINT('',(-1.231,-4.055,8.2));
#6376 = SURFACE_CURVE('',#6377,(#6381,#6388),.PCURVE_S1.);
#6377 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6378,#6379,#6380),
#6378 = CARTESIAN_POINT('',(-1.398,-3.644,8.2));
#6379 = CARTESIAN_POINT('',(-1.398,-3.914,8.2));
#6380 = CARTESIAN_POINT('',(-1.231,-4.055,8.2));
#6381 = PCURVE('',#6345,#6382);
#6382 = DEFINITIONAL_REPRESENTATION('',(#6383),#6387);
#6383 = LINE('',#6384,#6385);
#6384 = CARTESIAN_POINT('',(0.,-0.2));
#6385 = VECTOR('',#6386,1.);
#6386 = DIRECTION('',(1.,0.));
#6387 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6388 = PCURVE('',#4135,#6389);
#6389 = DEFINITIONAL_REPRESENTATION('',(#6390),#6394);
#6390 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6391,#6392,#6393),
#6391 = CARTESIAN_POINT('',(0.161321172048,-0.635317277748));
#6392 = CARTESIAN_POINT('',(-0.108678827952,-0.635317277748));
#6393 = CARTESIAN_POINT('',(-0.249678827952,-0.468317277748));
#6394 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6395 = ORIENTED_EDGE('',*,*,#6396,.F.);
#6396 = EDGE_CURVE('',#6397,#6374,#6399,.T.);
#6397 = VERTEX_POINT('',#6398);
#6398 = CARTESIAN_POINT('',(-1.231,-4.055,8.));
#6399 = SURFACE_CURVE('',#6400,(#6404,#6411),.PCURVE_S1.);
#6400 = LINE('',#6401,#6402);
#6401 = CARTESIAN_POINT('',(-1.231,-4.055,8.));
#6402 = VECTOR('',#6403,1.);
#6403 = DIRECTION('',(0.,0.,1.));
#6404 = PCURVE('',#6345,#6405);
#6405 = DEFINITIONAL_REPRESENTATION('',(#6406),#6410);
#6406 = LINE('',#6407,#6408);
#6407 = CARTESIAN_POINT('',(1.,0.));
#6408 = VECTOR('',#6409,1.);
#6409 = DIRECTION('',(0.,-1.));
#6410 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6411 = PCURVE('',#6412,#6419);
#6412 = SURFACE_OF_LINEAR_EXTRUSION('',#6413,#6417);
#6413 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6414,#6415,#6416),
#6414 = CARTESIAN_POINT('',(-1.231,-4.055,8.));
#6415 = CARTESIAN_POINT('',(-1.147,-4.126,8.));
#6416 = CARTESIAN_POINT('',(-1.062,-4.126,8.));
#6417 = VECTOR('',#6418,1.);
#6418 = DIRECTION('',(-0.,-0.,-1.));
#6419 = DEFINITIONAL_REPRESENTATION('',(#6420),#6424);
#6420 = LINE('',#6421,#6422);
#6421 = CARTESIAN_POINT('',(0.,0.));
#6422 = VECTOR('',#6423,1.);
#6423 = DIRECTION('',(0.,-1.));
#6424 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6425 = ORIENTED_EDGE('',*,*,#6426,.F.);
#6426 = EDGE_CURVE('',#6335,#6397,#6427,.T.);
#6427 = SURFACE_CURVE('',#6428,(#6432,#6439),.PCURVE_S1.);
#6428 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6429,#6430,#6431),
#6429 = CARTESIAN_POINT('',(-1.398,-3.644,8.));
#6430 = CARTESIAN_POINT('',(-1.398,-3.914,8.));
#6431 = CARTESIAN_POINT('',(-1.231,-4.055,8.));
#6432 = PCURVE('',#6345,#6433);
#6433 = DEFINITIONAL_REPRESENTATION('',(#6434),#6438);
#6434 = LINE('',#6435,#6436);
#6435 = CARTESIAN_POINT('',(0.,0.));
#6436 = VECTOR('',#6437,1.);
#6437 = DIRECTION('',(1.,0.));
#6438 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6439 = PCURVE('',#4191,#6440);
#6440 = DEFINITIONAL_REPRESENTATION('',(#6441),#6445);
#6441 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6442,#6443,#6444),
#6442 = CARTESIAN_POINT('',(0.161321172048,-0.635317277748));
#6443 = CARTESIAN_POINT('',(-0.108678827952,-0.635317277748));
#6444 = CARTESIAN_POINT('',(-0.249678827952,-0.468317277748));
#6445 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6446 = ADVANCED_FACE('',(#6447),#6412,.T.);
#6447 = FACE_BOUND('',#6448,.T.);
#6448 = EDGE_LOOP('',(#6449,#6450,#6473,#6501));
#6449 = ORIENTED_EDGE('',*,*,#6396,.T.);
#6450 = ORIENTED_EDGE('',*,*,#6451,.T.);
#6451 = EDGE_CURVE('',#6374,#6452,#6454,.T.);
#6452 = VERTEX_POINT('',#6453);
#6453 = CARTESIAN_POINT('',(-1.062,-4.126,8.2));
#6454 = SURFACE_CURVE('',#6455,(#6459,#6466),.PCURVE_S1.);
#6455 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6456,#6457,#6458),
#6456 = CARTESIAN_POINT('',(-1.231,-4.055,8.2));
#6457 = CARTESIAN_POINT('',(-1.147,-4.126,8.2));
#6458 = CARTESIAN_POINT('',(-1.062,-4.126,8.2));
#6459 = PCURVE('',#6412,#6460);
#6460 = DEFINITIONAL_REPRESENTATION('',(#6461),#6465);
#6461 = LINE('',#6462,#6463);
#6462 = CARTESIAN_POINT('',(0.,-0.2));
#6463 = VECTOR('',#6464,1.);
#6464 = DIRECTION('',(1.,0.));
#6465 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6466 = PCURVE('',#4135,#6467);
#6467 = DEFINITIONAL_REPRESENTATION('',(#6468),#6472);
#6468 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6469,#6470,#6471),
.UNSPECIFIED.,.F.,.F.,(3,3),(0.,1.),.PIECEWISE_BEZIER_KNOTS.);
#6469 = CARTESIAN_POINT('',(-0.249678827952,-0.468317277748));
#6470 = CARTESIAN_POINT('',(-0.320678827952,-0.384317277748));
#6471 = CARTESIAN_POINT('',(-0.320678827952,-0.299317277748));
#6472 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6473 = ORIENTED_EDGE('',*,*,#6474,.F.);
#6474 = EDGE_CURVE('',#6475,#6452,#6477,.T.);
#6475 = VERTEX_POINT('',#6476);
#6476 = CARTESIAN_POINT('',(-1.062,-4.126,8.));
#6477 = SURFACE_CURVE('',#6478,(#6482,#6489),.PCURVE_S1.);
#6478 = LINE('',#6479,#6480);
#6479 = CARTESIAN_POINT('',(-1.062,-4.126,8.));
#6480 = VECTOR('',#6481,1.);
#6481 = DIRECTION('',(0.,0.,1.));
#6482 = PCURVE('',#6412,#6483);
#6483 = DEFINITIONAL_REPRESENTATION('',(#6484),#6488);
#6484 = LINE('',#6485,#6486);
#6485 = CARTESIAN_POINT('',(1.,0.));
#6486 = VECTOR('',#6487,1.);
#6487 = DIRECTION('',(0.,-1.));
#6488 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6489 = PCURVE('',#6490,#6495);
#6490 = PLANE('',#6491);
#6491 = AXIS2_PLACEMENT_3D('',#6492,#6493,#6494);
#6492 = CARTESIAN_POINT('',(-1.062,-4.126,8.));
#6493 = DIRECTION('',(2.2E-16,1.,0.));
#6494 = DIRECTION('',(1.,-2.2E-16,0.));
#6495 = DEFINITIONAL_REPRESENTATION('',(#6496),#6500);
#6496 = LINE('',#6497,#6498);
#6497 = CARTESIAN_POINT('',(6.7E-16,0.));
#6498 = VECTOR('',#6499,1.);
#6499 = DIRECTION('',(0.,-1.));
#6500 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6501 = ORIENTED_EDGE('',*,*,#6502,.F.);
#6502 = EDGE_CURVE('',#6397,#6475,#6503,.T.);
#6503 = SURFACE_CURVE('',#6504,(#6508,#6515),.PCURVE_S1.);
#6504 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6505,#6506,#6507),
#6505 = CARTESIAN_POINT('',(-1.231,-4.055,8.));
#6506 = CARTESIAN_POINT('',(-1.147,-4.126,8.));
#6507 = CARTESIAN_POINT('',(-1.062,-4.126,8.));
#6508 = PCURVE('',#6412,#6509);
#6509 = DEFINITIONAL_REPRESENTATION('',(#6510),#6514);
#6510 = LINE('',#6511,#6512);
#6511 = CARTESIAN_POINT('',(0.,0.));
#6512 = VECTOR('',#6513,1.);
#6513 = DIRECTION('',(1.,0.));
#6514 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6515 = PCURVE('',#4191,#6516);
#6516 = DEFINITIONAL_REPRESENTATION('',(#6517),#6521);
#6517 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6518,#6519,#6520),
#6518 = CARTESIAN_POINT('',(-0.249678827952,-0.468317277748));
#6519 = CARTESIAN_POINT('',(-0.320678827952,-0.384317277748));
#6520 = CARTESIAN_POINT('',(-0.320678827952,-0.299317277748));
#6521 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6522 = ADVANCED_FACE('',(#6523),#6490,.T.);
#6523 = FACE_BOUND('',#6524,.T.);
#6524 = EDGE_LOOP('',(#6525,#6526,#6549,#6579));
#6525 = ORIENTED_EDGE('',*,*,#6474,.T.);
#6526 = ORIENTED_EDGE('',*,*,#6527,.T.);
#6527 = EDGE_CURVE('',#6452,#6528,#6530,.T.);
#6528 = VERTEX_POINT('',#6529);
#6529 = CARTESIAN_POINT('',(-0.787,-4.126,8.2));
#6530 = SURFACE_CURVE('',#6531,(#6535,#6542),.PCURVE_S1.);
#6531 = LINE('',#6532,#6533);
#6532 = CARTESIAN_POINT('',(-1.062,-4.126,8.2));
#6533 = VECTOR('',#6534,1.);
#6534 = DIRECTION('',(1.,0.,0.));
#6535 = PCURVE('',#6490,#6536);
#6536 = DEFINITIONAL_REPRESENTATION('',(#6537),#6541);
#6537 = LINE('',#6538,#6539);
#6538 = CARTESIAN_POINT('',(0.,-0.2));
#6539 = VECTOR('',#6540,1.);
#6540 = DIRECTION('',(1.,0.));
#6541 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6542 = PCURVE('',#4135,#6543);
#6543 = DEFINITIONAL_REPRESENTATION('',(#6544),#6548);
#6544 = LINE('',#6545,#6546);
#6545 = CARTESIAN_POINT('',(-0.320678827952,-0.299317277748));
#6546 = VECTOR('',#6547,1.);
#6547 = DIRECTION('',(0.,1.));
#6548 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6549 = ORIENTED_EDGE('',*,*,#6550,.F.);
#6550 = EDGE_CURVE('',#6551,#6528,#6553,.T.);
#6551 = VERTEX_POINT('',#6552);
#6552 = CARTESIAN_POINT('',(-0.787,-4.126,8.));
#6553 = SURFACE_CURVE('',#6554,(#6558,#6565),.PCURVE_S1.);
#6554 = LINE('',#6555,#6556);
#6555 = CARTESIAN_POINT('',(-0.787,-4.126,8.));
#6556 = VECTOR('',#6557,1.);
#6557 = DIRECTION('',(0.,0.,1.));
#6558 = PCURVE('',#6490,#6559);
#6559 = DEFINITIONAL_REPRESENTATION('',(#6560),#6564);
#6560 = LINE('',#6561,#6562);
#6561 = CARTESIAN_POINT('',(0.275,0.));
#6562 = VECTOR('',#6563,1.);
#6563 = DIRECTION('',(0.,-1.));
#6564 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6565 = PCURVE('',#6566,#6573);
#6566 = SURFACE_OF_LINEAR_EXTRUSION('',#6567,#6571);
#6567 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6568,#6569,#6570),
#6568 = CARTESIAN_POINT('',(-0.787,-4.126,8.));
#6569 = CARTESIAN_POINT('',(-0.822,-4.046,8.));
#6570 = CARTESIAN_POINT('',(-0.863,-3.761,8.));
#6571 = VECTOR('',#6572,1.);
#6572 = DIRECTION('',(-0.,-0.,-1.));
#6573 = DEFINITIONAL_REPRESENTATION('',(#6574),#6578);
#6574 = LINE('',#6575,#6576);
#6575 = CARTESIAN_POINT('',(0.,0.));
#6576 = VECTOR('',#6577,1.);
#6577 = DIRECTION('',(0.,-1.));
#6578 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6579 = ORIENTED_EDGE('',*,*,#6580,.F.);
#6580 = EDGE_CURVE('',#6475,#6551,#6581,.T.);
#6581 = SURFACE_CURVE('',#6582,(#6586,#6593),.PCURVE_S1.);
#6582 = LINE('',#6583,#6584);
#6583 = CARTESIAN_POINT('',(-1.062,-4.126,8.));
#6584 = VECTOR('',#6585,1.);
#6585 = DIRECTION('',(1.,0.,0.));
#6586 = PCURVE('',#6490,#6587);
#6587 = DEFINITIONAL_REPRESENTATION('',(#6588),#6592);
#6588 = LINE('',#6589,#6590);
#6589 = CARTESIAN_POINT('',(0.,0.));
#6590 = VECTOR('',#6591,1.);
#6591 = DIRECTION('',(1.,0.));
#6592 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6593 = PCURVE('',#4191,#6594);
#6594 = DEFINITIONAL_REPRESENTATION('',(#6595),#6599);
#6595 = LINE('',#6596,#6597);
#6596 = CARTESIAN_POINT('',(-0.320678827952,-0.299317277748));
#6597 = VECTOR('',#6598,1.);
#6598 = DIRECTION('',(0.,1.));
#6599 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6600 = ADVANCED_FACE('',(#6601),#6566,.T.);
#6601 = FACE_BOUND('',#6602,.T.);
#6602 = EDGE_LOOP('',(#6603,#6604,#6627,#6657));
#6603 = ORIENTED_EDGE('',*,*,#6550,.T.);
#6604 = ORIENTED_EDGE('',*,*,#6605,.T.);
#6605 = EDGE_CURVE('',#6528,#6606,#6608,.T.);
#6606 = VERTEX_POINT('',#6607);
#6607 = CARTESIAN_POINT('',(-0.863,-3.761,8.2));
#6608 = SURFACE_CURVE('',#6609,(#6613,#6620),.PCURVE_S1.);
#6609 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6610,#6611,#6612),
#6610 = CARTESIAN_POINT('',(-0.787,-4.126,8.2));
#6611 = CARTESIAN_POINT('',(-0.822,-4.046,8.2));
#6612 = CARTESIAN_POINT('',(-0.863,-3.761,8.2));
#6613 = PCURVE('',#6566,#6614);
#6614 = DEFINITIONAL_REPRESENTATION('',(#6615),#6619);
#6615 = LINE('',#6616,#6617);
#6616 = CARTESIAN_POINT('',(0.,-0.2));
#6617 = VECTOR('',#6618,1.);
#6618 = DIRECTION('',(1.,0.));
#6619 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6620 = PCURVE('',#4135,#6621);
#6621 = DEFINITIONAL_REPRESENTATION('',(#6622),#6626);
#6622 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6623,#6624,#6625),
#6623 = CARTESIAN_POINT('',(-0.320678827952,-2.431727774812E-02));
#6624 = CARTESIAN_POINT('',(-0.240678827952,-5.931727774812E-02));
#6625 = CARTESIAN_POINT('',(4.43211720483E-02,-0.100317277748));
#6626 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6627 = ORIENTED_EDGE('',*,*,#6628,.F.);
#6628 = EDGE_CURVE('',#6629,#6606,#6631,.T.);
#6629 = VERTEX_POINT('',#6630);
#6630 = CARTESIAN_POINT('',(-0.863,-3.761,8.));
#6631 = SURFACE_CURVE('',#6632,(#6636,#6643),.PCURVE_S1.);
#6632 = LINE('',#6633,#6634);
#6633 = CARTESIAN_POINT('',(-0.863,-3.761,8.));
#6634 = VECTOR('',#6635,1.);
#6635 = DIRECTION('',(0.,0.,1.));
#6636 = PCURVE('',#6566,#6637);
#6637 = DEFINITIONAL_REPRESENTATION('',(#6638),#6642);
#6638 = LINE('',#6639,#6640);
#6639 = CARTESIAN_POINT('',(1.,0.));
#6640 = VECTOR('',#6641,1.);
#6641 = DIRECTION('',(0.,-1.));
#6642 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6643 = PCURVE('',#6644,#6651);
#6644 = SURFACE_OF_LINEAR_EXTRUSION('',#6645,#6649);
#6645 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6646,#6647,#6648),
#6646 = CARTESIAN_POINT('',(-0.863,-3.761,8.));
#6647 = CARTESIAN_POINT('',(-0.907,-3.472,8.));
#6648 = CARTESIAN_POINT('',(-0.997,-3.386,8.));
#6649 = VECTOR('',#6650,1.);
#6650 = DIRECTION('',(-0.,-0.,-1.));
#6651 = DEFINITIONAL_REPRESENTATION('',(#6652),#6656);
#6652 = LINE('',#6653,#6654);
#6653 = CARTESIAN_POINT('',(0.,0.));
#6654 = VECTOR('',#6655,1.);
#6655 = DIRECTION('',(0.,-1.));
#6656 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6657 = ORIENTED_EDGE('',*,*,#6658,.F.);
#6658 = EDGE_CURVE('',#6551,#6629,#6659,.T.);
#6659 = SURFACE_CURVE('',#6660,(#6664,#6671),.PCURVE_S1.);
#6660 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6661,#6662,#6663),
#6661 = CARTESIAN_POINT('',(-0.787,-4.126,8.));
#6662 = CARTESIAN_POINT('',(-0.822,-4.046,8.));
#6663 = CARTESIAN_POINT('',(-0.863,-3.761,8.));
#6664 = PCURVE('',#6566,#6665);
#6665 = DEFINITIONAL_REPRESENTATION('',(#6666),#6670);
#6666 = LINE('',#6667,#6668);
#6667 = CARTESIAN_POINT('',(0.,0.));
#6668 = VECTOR('',#6669,1.);
#6669 = DIRECTION('',(1.,0.));
#6670 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6671 = PCURVE('',#4191,#6672);
#6672 = DEFINITIONAL_REPRESENTATION('',(#6673),#6677);
#6673 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6674,#6675,#6676),
#6674 = CARTESIAN_POINT('',(-0.320678827952,-2.431727774812E-02));
#6675 = CARTESIAN_POINT('',(-0.240678827952,-5.931727774812E-02));
#6676 = CARTESIAN_POINT('',(4.43211720483E-02,-0.100317277748));
#6677 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6678 = ADVANCED_FACE('',(#6679),#6644,.T.);
#6679 = FACE_BOUND('',#6680,.T.);
#6680 = EDGE_LOOP('',(#6681,#6682,#6705,#6735));
#6681 = ORIENTED_EDGE('',*,*,#6628,.T.);
#6682 = ORIENTED_EDGE('',*,*,#6683,.T.);
#6683 = EDGE_CURVE('',#6606,#6684,#6686,.T.);
#6684 = VERTEX_POINT('',#6685);
#6685 = CARTESIAN_POINT('',(-0.997,-3.386,8.2));
#6686 = SURFACE_CURVE('',#6687,(#6691,#6698),.PCURVE_S1.);
#6687 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6688,#6689,#6690),
#6688 = CARTESIAN_POINT('',(-0.863,-3.761,8.2));
#6689 = CARTESIAN_POINT('',(-0.907,-3.472,8.2));
#6690 = CARTESIAN_POINT('',(-0.997,-3.386,8.2));
#6691 = PCURVE('',#6644,#6692);
#6692 = DEFINITIONAL_REPRESENTATION('',(#6693),#6697);
#6693 = LINE('',#6694,#6695);
#6694 = CARTESIAN_POINT('',(0.,-0.2));
#6695 = VECTOR('',#6696,1.);
#6696 = DIRECTION('',(1.,0.));
#6697 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6698 = PCURVE('',#4135,#6699);
#6699 = DEFINITIONAL_REPRESENTATION('',(#6700),#6704);
#6700 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6701,#6702,#6703),
#6701 = CARTESIAN_POINT('',(4.43211720483E-02,-0.100317277748));
#6702 = CARTESIAN_POINT('',(0.333321172048,-0.144317277748));
#6703 = CARTESIAN_POINT('',(0.419321172048,-0.234317277748));
#6704 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6705 = ORIENTED_EDGE('',*,*,#6706,.F.);
#6706 = EDGE_CURVE('',#6707,#6684,#6709,.T.);
#6707 = VERTEX_POINT('',#6708);
#6708 = CARTESIAN_POINT('',(-0.997,-3.386,8.));
#6709 = SURFACE_CURVE('',#6710,(#6714,#6721),.PCURVE_S1.);
#6710 = LINE('',#6711,#6712);
#6711 = CARTESIAN_POINT('',(-0.997,-3.386,8.));
#6712 = VECTOR('',#6713,1.);
#6713 = DIRECTION('',(0.,0.,1.));
#6714 = PCURVE('',#6644,#6715);
#6715 = DEFINITIONAL_REPRESENTATION('',(#6716),#6720);
#6716 = LINE('',#6717,#6718);
#6717 = CARTESIAN_POINT('',(1.,0.));
#6718 = VECTOR('',#6719,1.);
#6719 = DIRECTION('',(0.,-1.));
#6720 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6721 = PCURVE('',#6722,#6729);
#6722 = SURFACE_OF_LINEAR_EXTRUSION('',#6723,#6727);
#6723 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6724,#6725,#6726),
#6724 = CARTESIAN_POINT('',(-0.997,-3.386,8.));
#6725 = CARTESIAN_POINT('',(-1.059,-3.327,8.));
#6726 = CARTESIAN_POINT('',(-1.152,-3.327,8.));
#6727 = VECTOR('',#6728,1.);
#6728 = DIRECTION('',(-0.,-0.,-1.));
#6729 = DEFINITIONAL_REPRESENTATION('',(#6730),#6734);
#6730 = LINE('',#6731,#6732);
#6731 = CARTESIAN_POINT('',(0.,0.));
#6732 = VECTOR('',#6733,1.);
#6733 = DIRECTION('',(0.,-1.));
#6734 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6735 = ORIENTED_EDGE('',*,*,#6736,.F.);
#6736 = EDGE_CURVE('',#6629,#6707,#6737,.T.);
#6737 = SURFACE_CURVE('',#6738,(#6742,#6749),.PCURVE_S1.);
#6738 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6739,#6740,#6741),
#6739 = CARTESIAN_POINT('',(-0.863,-3.761,8.));
#6740 = CARTESIAN_POINT('',(-0.907,-3.472,8.));
#6741 = CARTESIAN_POINT('',(-0.997,-3.386,8.));
#6742 = PCURVE('',#6644,#6743);
#6743 = DEFINITIONAL_REPRESENTATION('',(#6744),#6748);
#6744 = LINE('',#6745,#6746);
#6745 = CARTESIAN_POINT('',(0.,0.));
#6746 = VECTOR('',#6747,1.);
#6747 = DIRECTION('',(1.,0.));
#6748 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6749 = PCURVE('',#4191,#6750);
#6750 = DEFINITIONAL_REPRESENTATION('',(#6751),#6755);
#6751 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6752,#6753,#6754),
#6752 = CARTESIAN_POINT('',(4.43211720483E-02,-0.100317277748));
#6753 = CARTESIAN_POINT('',(0.333321172048,-0.144317277748));
#6754 = CARTESIAN_POINT('',(0.419321172048,-0.234317277748));
#6755 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6756 = ADVANCED_FACE('',(#6757),#6722,.T.);
#6757 = FACE_BOUND('',#6758,.T.);
#6758 = EDGE_LOOP('',(#6759,#6760,#6783,#6813));
#6759 = ORIENTED_EDGE('',*,*,#6706,.T.);
#6760 = ORIENTED_EDGE('',*,*,#6761,.T.);
#6761 = EDGE_CURVE('',#6684,#6762,#6764,.T.);
#6762 = VERTEX_POINT('',#6763);
#6763 = CARTESIAN_POINT('',(-1.152,-3.327,8.2));
#6764 = SURFACE_CURVE('',#6765,(#6769,#6776),.PCURVE_S1.);
#6765 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6766,#6767,#6768),
#6766 = CARTESIAN_POINT('',(-0.997,-3.386,8.2));
#6767 = CARTESIAN_POINT('',(-1.059,-3.327,8.2));
#6768 = CARTESIAN_POINT('',(-1.152,-3.327,8.2));
#6769 = PCURVE('',#6722,#6770);
#6770 = DEFINITIONAL_REPRESENTATION('',(#6771),#6775);
#6771 = LINE('',#6772,#6773);
#6772 = CARTESIAN_POINT('',(0.,-0.2));
#6773 = VECTOR('',#6774,1.);
#6774 = DIRECTION('',(1.,0.));
#6775 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6776 = PCURVE('',#4135,#6777);
#6777 = DEFINITIONAL_REPRESENTATION('',(#6778),#6782);
#6778 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6779,#6780,#6781),
#6779 = CARTESIAN_POINT('',(0.419321172048,-0.234317277748));
#6780 = CARTESIAN_POINT('',(0.478321172048,-0.296317277748));
#6781 = CARTESIAN_POINT('',(0.478321172048,-0.389317277748));
#6782 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6783 = ORIENTED_EDGE('',*,*,#6784,.F.);
#6784 = EDGE_CURVE('',#6785,#6762,#6787,.T.);
#6785 = VERTEX_POINT('',#6786);
#6786 = CARTESIAN_POINT('',(-1.152,-3.327,8.));
#6787 = SURFACE_CURVE('',#6788,(#6792,#6799),.PCURVE_S1.);
#6788 = LINE('',#6789,#6790);
#6789 = CARTESIAN_POINT('',(-1.152,-3.327,8.));
#6790 = VECTOR('',#6791,1.);
#6791 = DIRECTION('',(0.,0.,1.));
#6792 = PCURVE('',#6722,#6793);
#6793 = DEFINITIONAL_REPRESENTATION('',(#6794),#6798);
#6794 = LINE('',#6795,#6796);
#6795 = CARTESIAN_POINT('',(1.,0.));
#6796 = VECTOR('',#6797,1.);
#6797 = DIRECTION('',(0.,-1.));
#6798 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6799 = PCURVE('',#6800,#6807);
#6800 = SURFACE_OF_LINEAR_EXTRUSION('',#6801,#6805);
#6801 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6802,#6803,#6804),
#6802 = CARTESIAN_POINT('',(-1.152,-3.327,8.));
#6803 = CARTESIAN_POINT('',(-1.342,-3.327,8.));
#6804 = CARTESIAN_POINT('',(-1.386,-3.533,8.));
#6805 = VECTOR('',#6806,1.);
#6806 = DIRECTION('',(-0.,-0.,-1.));
#6807 = DEFINITIONAL_REPRESENTATION('',(#6808),#6812);
#6808 = LINE('',#6809,#6810);
#6809 = CARTESIAN_POINT('',(0.,0.));
#6810 = VECTOR('',#6811,1.);
#6811 = DIRECTION('',(0.,-1.));
#6812 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6813 = ORIENTED_EDGE('',*,*,#6814,.F.);
#6814 = EDGE_CURVE('',#6707,#6785,#6815,.T.);
#6815 = SURFACE_CURVE('',#6816,(#6820,#6827),.PCURVE_S1.);
#6816 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6817,#6818,#6819),
#6817 = CARTESIAN_POINT('',(-0.997,-3.386,8.));
#6818 = CARTESIAN_POINT('',(-1.059,-3.327,8.));
#6819 = CARTESIAN_POINT('',(-1.152,-3.327,8.));
#6820 = PCURVE('',#6722,#6821);
#6821 = DEFINITIONAL_REPRESENTATION('',(#6822),#6826);
#6822 = LINE('',#6823,#6824);
#6823 = CARTESIAN_POINT('',(0.,0.));
#6824 = VECTOR('',#6825,1.);
#6825 = DIRECTION('',(1.,0.));
#6826 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6827 = PCURVE('',#4191,#6828);
#6828 = DEFINITIONAL_REPRESENTATION('',(#6829),#6833);
#6829 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6830,#6831,#6832),
#6830 = CARTESIAN_POINT('',(0.419321172048,-0.234317277748));
#6831 = CARTESIAN_POINT('',(0.478321172048,-0.296317277748));
#6832 = CARTESIAN_POINT('',(0.478321172048,-0.389317277748));
#6833 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6834 = ADVANCED_FACE('',(#6835),#6800,.T.);
#6835 = FACE_BOUND('',#6836,.T.);
#6836 = EDGE_LOOP('',(#6837,#6838,#6861,#6884));
#6837 = ORIENTED_EDGE('',*,*,#6784,.T.);
#6838 = ORIENTED_EDGE('',*,*,#6839,.T.);
#6839 = EDGE_CURVE('',#6762,#6840,#6842,.T.);
#6840 = VERTEX_POINT('',#6841);
#6841 = CARTESIAN_POINT('',(-1.386,-3.533,8.2));
#6842 = SURFACE_CURVE('',#6843,(#6847,#6854),.PCURVE_S1.);
#6843 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6844,#6845,#6846),
#6844 = CARTESIAN_POINT('',(-1.152,-3.327,8.2));
#6845 = CARTESIAN_POINT('',(-1.342,-3.327,8.2));
#6846 = CARTESIAN_POINT('',(-1.386,-3.533,8.2));
#6847 = PCURVE('',#6800,#6848);
#6848 = DEFINITIONAL_REPRESENTATION('',(#6849),#6853);
#6849 = LINE('',#6850,#6851);
#6850 = CARTESIAN_POINT('',(0.,-0.2));
#6851 = VECTOR('',#6852,1.);
#6852 = DIRECTION('',(1.,0.));
#6853 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6854 = PCURVE('',#4135,#6855);
#6855 = DEFINITIONAL_REPRESENTATION('',(#6856),#6860);
#6856 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6857,#6858,#6859),
#6857 = CARTESIAN_POINT('',(0.478321172048,-0.389317277748));
#6858 = CARTESIAN_POINT('',(0.478321172048,-0.579317277748));
#6859 = CARTESIAN_POINT('',(0.272321172048,-0.623317277748));
#6860 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6861 = ORIENTED_EDGE('',*,*,#6862,.F.);
#6862 = EDGE_CURVE('',#6863,#6840,#6865,.T.);
#6863 = VERTEX_POINT('',#6864);
#6864 = CARTESIAN_POINT('',(-1.386,-3.533,8.));
#6865 = SURFACE_CURVE('',#6866,(#6870,#6877),.PCURVE_S1.);
#6866 = LINE('',#6867,#6868);
#6867 = CARTESIAN_POINT('',(-1.386,-3.533,8.));
#6868 = VECTOR('',#6869,1.);
#6869 = DIRECTION('',(0.,0.,1.));
#6870 = PCURVE('',#6800,#6871);
#6871 = DEFINITIONAL_REPRESENTATION('',(#6872),#6876);
#6872 = LINE('',#6873,#6874);
#6873 = CARTESIAN_POINT('',(1.,0.));
#6874 = VECTOR('',#6875,1.);
#6875 = DIRECTION('',(0.,-1.));
#6876 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6877 = PCURVE('',#6359,#6878);
#6878 = DEFINITIONAL_REPRESENTATION('',(#6879),#6883);
#6879 = LINE('',#6880,#6881);
#6880 = CARTESIAN_POINT('',(0.,0.));
#6881 = VECTOR('',#6882,1.);
#6882 = DIRECTION('',(0.,-1.));
#6883 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6884 = ORIENTED_EDGE('',*,*,#6885,.F.);
#6885 = EDGE_CURVE('',#6785,#6863,#6886,.T.);
#6886 = SURFACE_CURVE('',#6887,(#6891,#6898),.PCURVE_S1.);
#6887 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6888,#6889,#6890),
#6888 = CARTESIAN_POINT('',(-1.152,-3.327,8.));
#6889 = CARTESIAN_POINT('',(-1.342,-3.327,8.));
#6890 = CARTESIAN_POINT('',(-1.386,-3.533,8.));
#6891 = PCURVE('',#6800,#6892);
#6892 = DEFINITIONAL_REPRESENTATION('',(#6893),#6897);
#6893 = LINE('',#6894,#6895);
#6894 = CARTESIAN_POINT('',(0.,0.));
#6895 = VECTOR('',#6896,1.);
#6896 = DIRECTION('',(1.,0.));
#6897 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6898 = PCURVE('',#4191,#6899);
#6899 = DEFINITIONAL_REPRESENTATION('',(#6900),#6904);
#6900 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6901,#6902,#6903),
#6901 = CARTESIAN_POINT('',(0.478321172048,-0.389317277748));
#6902 = CARTESIAN_POINT('',(0.478321172048,-0.579317277748));
#6903 = CARTESIAN_POINT('',(0.272321172048,-0.623317277748));
#6904 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6905 = ADVANCED_FACE('',(#6906),#6359,.T.);
#6906 = FACE_BOUND('',#6907,.T.);
#6907 = EDGE_LOOP('',(#6908,#6909,#6930,#6931));
#6908 = ORIENTED_EDGE('',*,*,#6862,.T.);
#6909 = ORIENTED_EDGE('',*,*,#6910,.T.);
#6910 = EDGE_CURVE('',#6840,#6337,#6911,.T.);
#6911 = SURFACE_CURVE('',#6912,(#6916,#6923),.PCURVE_S1.);
#6912 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6913,#6914,#6915),
#6913 = CARTESIAN_POINT('',(-1.386,-3.533,8.2));
#6914 = CARTESIAN_POINT('',(-1.398,-3.582,8.2));
#6915 = CARTESIAN_POINT('',(-1.398,-3.644,8.2));
#6916 = PCURVE('',#6359,#6917);
#6917 = DEFINITIONAL_REPRESENTATION('',(#6918),#6922);
#6918 = LINE('',#6919,#6920);
#6919 = CARTESIAN_POINT('',(0.,-0.2));
#6920 = VECTOR('',#6921,1.);
#6921 = DIRECTION('',(1.,0.));
#6922 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6923 = PCURVE('',#4135,#6924);
#6924 = DEFINITIONAL_REPRESENTATION('',(#6925),#6929);
#6925 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6926,#6927,#6928),
#6926 = CARTESIAN_POINT('',(0.272321172048,-0.623317277748));
#6927 = CARTESIAN_POINT('',(0.223321172048,-0.635317277748));
#6928 = CARTESIAN_POINT('',(0.161321172048,-0.635317277748));
#6929 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6930 = ORIENTED_EDGE('',*,*,#6334,.F.);
#6931 = ORIENTED_EDGE('',*,*,#6932,.F.);
#6932 = EDGE_CURVE('',#6863,#6335,#6933,.T.);
#6933 = SURFACE_CURVE('',#6934,(#6938,#6945),.PCURVE_S1.);
#6934 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6935,#6936,#6937),
#6935 = CARTESIAN_POINT('',(-1.386,-3.533,8.));
#6936 = CARTESIAN_POINT('',(-1.398,-3.582,8.));
#6937 = CARTESIAN_POINT('',(-1.398,-3.644,8.));
#6938 = PCURVE('',#6359,#6939);
#6939 = DEFINITIONAL_REPRESENTATION('',(#6940),#6944);
#6940 = LINE('',#6941,#6942);
#6941 = CARTESIAN_POINT('',(0.,0.));
#6942 = VECTOR('',#6943,1.);
#6943 = DIRECTION('',(1.,0.));
#6944 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6945 = PCURVE('',#4191,#6946);
#6946 = DEFINITIONAL_REPRESENTATION('',(#6947),#6951);
#6947 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#6948,#6949,#6950),
#6948 = CARTESIAN_POINT('',(0.272321172048,-0.623317277748));
#6949 = CARTESIAN_POINT('',(0.223321172048,-0.635317277748));
#6950 = CARTESIAN_POINT('',(0.161321172048,-0.635317277748));
#6951 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#6952 = ADVANCED_FACE('',(#6953,#6984),#4191,.T.);
#6953 = FACE_BOUND('',#6954,.T.);
#6954 = EDGE_LOOP('',(#6955,#6956,#6957,#6958,#6959,#6960,#6961,#6962,
#6963,#6964,#6965,#6966,#6967,#6968,#6969,#6970,#6971,#6972,#6973,
#6974,#6975,#6976,#6977,#6978,#6979,#6980,#6981,#6982,#6983));
#6955 = ORIENTED_EDGE('',*,*,#4177,.T.);
#6956 = ORIENTED_EDGE('',*,*,#4260,.T.);
#6957 = ORIENTED_EDGE('',*,*,#4336,.T.);
#6958 = ORIENTED_EDGE('',*,*,#4414,.T.);
#6959 = ORIENTED_EDGE('',*,*,#4492,.T.);
#6960 = ORIENTED_EDGE('',*,*,#4568,.T.);
#6961 = ORIENTED_EDGE('',*,*,#4646,.T.);
#6962 = ORIENTED_EDGE('',*,*,#4724,.T.);
#6963 = ORIENTED_EDGE('',*,*,#4802,.T.);
#6964 = ORIENTED_EDGE('',*,*,#4880,.T.);
#6965 = ORIENTED_EDGE('',*,*,#4958,.T.);
#6966 = ORIENTED_EDGE('',*,*,#5036,.T.);
#6967 = ORIENTED_EDGE('',*,*,#5114,.T.);
#6968 = ORIENTED_EDGE('',*,*,#5192,.T.);
#6969 = ORIENTED_EDGE('',*,*,#5268,.T.);
#6970 = ORIENTED_EDGE('',*,*,#5344,.T.);
#6971 = ORIENTED_EDGE('',*,*,#5420,.T.);
#6972 = ORIENTED_EDGE('',*,*,#5496,.T.);
#6973 = ORIENTED_EDGE('',*,*,#5572,.T.);
#6974 = ORIENTED_EDGE('',*,*,#5648,.T.);
#6975 = ORIENTED_EDGE('',*,*,#5726,.T.);
#6976 = ORIENTED_EDGE('',*,*,#5804,.T.);
#6977 = ORIENTED_EDGE('',*,*,#5880,.T.);
#6978 = ORIENTED_EDGE('',*,*,#5958,.T.);
#6979 = ORIENTED_EDGE('',*,*,#6036,.T.);
#6980 = ORIENTED_EDGE('',*,*,#6114,.T.);
#6981 = ORIENTED_EDGE('',*,*,#6192,.T.);
#6982 = ORIENTED_EDGE('',*,*,#6263,.T.);
#6983 = ORIENTED_EDGE('',*,*,#6310,.T.);
#6984 = FACE_BOUND('',#6985,.T.);
#6985 = EDGE_LOOP('',(#6986,#6987,#6988,#6989,#6990,#6991,#6992,#6993));
#6986 = ORIENTED_EDGE('',*,*,#6426,.T.);
#6987 = ORIENTED_EDGE('',*,*,#6502,.T.);
#6988 = ORIENTED_EDGE('',*,*,#6580,.T.);
#6989 = ORIENTED_EDGE('',*,*,#6658,.T.);
#6990 = ORIENTED_EDGE('',*,*,#6736,.T.);
#6991 = ORIENTED_EDGE('',*,*,#6814,.T.);
#6992 = ORIENTED_EDGE('',*,*,#6885,.T.);
#6993 = ORIENTED_EDGE('',*,*,#6932,.T.);
#6994 = ADVANCED_FACE('',(#6995,#7026),#4135,.F.);
#6995 = FACE_BOUND('',#6996,.F.);
#6996 = EDGE_LOOP('',(#6997,#6998,#6999,#7000,#7001,#7002,#7003,#7004,
#7005,#7006,#7007,#7008,#7009,#7010,#7011,#7012,#7013,#7014,#7015,
#7016,#7017,#7018,#7019,#7020,#7021,#7022,#7023,#7024,#7025));
#6997 = ORIENTED_EDGE('',*,*,#4119,.T.);
#6998 = ORIENTED_EDGE('',*,*,#4207,.T.);
#6999 = ORIENTED_EDGE('',*,*,#4285,.T.);
#7000 = ORIENTED_EDGE('',*,*,#4361,.T.);
#7001 = ORIENTED_EDGE('',*,*,#4439,.T.);
#7002 = ORIENTED_EDGE('',*,*,#4517,.T.);
#7003 = ORIENTED_EDGE('',*,*,#4593,.T.);
#7004 = ORIENTED_EDGE('',*,*,#4671,.T.);
#7005 = ORIENTED_EDGE('',*,*,#4749,.T.);
#7006 = ORIENTED_EDGE('',*,*,#4827,.T.);
#7007 = ORIENTED_EDGE('',*,*,#4905,.T.);
#7008 = ORIENTED_EDGE('',*,*,#4983,.T.);
#7009 = ORIENTED_EDGE('',*,*,#5061,.T.);
#7010 = ORIENTED_EDGE('',*,*,#5139,.T.);
#7011 = ORIENTED_EDGE('',*,*,#5217,.T.);
#7012 = ORIENTED_EDGE('',*,*,#5293,.T.);
#7013 = ORIENTED_EDGE('',*,*,#5369,.T.);
#7014 = ORIENTED_EDGE('',*,*,#5445,.T.);
#7015 = ORIENTED_EDGE('',*,*,#5521,.T.);
#7016 = ORIENTED_EDGE('',*,*,#5597,.T.);
#7017 = ORIENTED_EDGE('',*,*,#5673,.T.);
#7018 = ORIENTED_EDGE('',*,*,#5751,.T.);
#7019 = ORIENTED_EDGE('',*,*,#5829,.T.);
#7020 = ORIENTED_EDGE('',*,*,#5905,.T.);
#7021 = ORIENTED_EDGE('',*,*,#5983,.T.);
#7022 = ORIENTED_EDGE('',*,*,#6061,.T.);
#7023 = ORIENTED_EDGE('',*,*,#6139,.T.);
#7024 = ORIENTED_EDGE('',*,*,#6217,.T.);
#7025 = ORIENTED_EDGE('',*,*,#6288,.T.);
#7026 = FACE_BOUND('',#7027,.F.);
#7027 = EDGE_LOOP('',(#7028,#7029,#7030,#7031,#7032,#7033,#7034,#7035));
#7028 = ORIENTED_EDGE('',*,*,#6373,.T.);
#7029 = ORIENTED_EDGE('',*,*,#6451,.T.);
#7030 = ORIENTED_EDGE('',*,*,#6527,.T.);
#7031 = ORIENTED_EDGE('',*,*,#6605,.T.);
#7032 = ORIENTED_EDGE('',*,*,#6683,.T.);
#7033 = ORIENTED_EDGE('',*,*,#6761,.T.);
#7034 = ORIENTED_EDGE('',*,*,#6839,.T.);
#7035 = ORIENTED_EDGE('',*,*,#6910,.T.);
#7036 = MANIFOLD_SOLID_BREP('',#7037);
#7037 = CLOSED_SHELL('',(#7038,#7164,#7242,#7320,#7398,#7474,#7550,#7626
,#7704,#7782,#7860,#7938,#8014,#8092,#8170,#8248,#8326,#8402,#8480,
#8551,#8598,#8714,#8792,#8870,#8948,#9026,#9104,#9175,#9222,#9255));
#7038 = ADVANCED_FACE('',(#7039),#7053,.T.);
#7039 = FACE_BOUND('',#7040,.T.);
#7040 = EDGE_LOOP('',(#7041,#7080,#7108,#7138));
#7041 = ORIENTED_EDGE('',*,*,#7042,.T.);
#7042 = EDGE_CURVE('',#7043,#7045,#7047,.T.);
#7043 = VERTEX_POINT('',#7044);
#7044 = CARTESIAN_POINT('',(-1.664,-5.388,8.));
#7045 = VERTEX_POINT('',#7046);
#7046 = CARTESIAN_POINT('',(-1.664,-5.388,8.2));
#7047 = SURFACE_CURVE('',#7048,(#7052,#7066),.PCURVE_S1.);
#7048 = LINE('',#7049,#7050);
#7049 = CARTESIAN_POINT('',(-1.664,-5.388,8.));
#7050 = VECTOR('',#7051,1.);
#7051 = DIRECTION('',(0.,0.,1.));
#7052 = PCURVE('',#7053,#7060);
#7053 = SURFACE_OF_LINEAR_EXTRUSION('',#7054,#7058);
#7054 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7055,#7056,#7057),
#7055 = CARTESIAN_POINT('',(-1.664,-5.388,8.));
#7056 = CARTESIAN_POINT('',(-1.664,-5.077,8.));
#7057 = CARTESIAN_POINT('',(-1.396,-4.89,8.));
#7058 = VECTOR('',#7059,1.);
#7059 = DIRECTION('',(-0.,-0.,-1.));
#7060 = DEFINITIONAL_REPRESENTATION('',(#7061),#7065);
#7061 = LINE('',#7062,#7063);
#7062 = CARTESIAN_POINT('',(0.,0.));
#7063 = VECTOR('',#7064,1.);
#7064 = DIRECTION('',(0.,-1.));
#7065 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
PARAMETRIC_REPRESENTATION_CONTEXT() REPRESENTATION_CONTEXT('2D SPACE',''
#7066 = PCURVE('',#7067,#7074);
#7067 = SURFACE_OF_LINEAR_EXTRUSION('',#7068,#7072);
#7068 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7069,#7070,#7071),
#7069 = CARTESIAN_POINT('',(-1.657,-5.47,8.));
#7070 = CARTESIAN_POINT('',(-1.664,-5.431,8.));
#7071 = CARTESIAN_POINT('',(-1.664,-5.388,8.));
#7072 = VECTOR('',#7073,1.);
#7073 = DIRECTION('',(-0.,-0.,-1.));
#7074 = DEFINITIONAL_REPRESENTATION('',(#7075),#7079);
#7075 = LINE('',#7076,#7077);
#7076 = CARTESIAN_POINT('',(1.,0.));
#7077 = VECTOR('',#7078,1.);
#7078 = DIRECTION('',(0.,-1.));
#7079 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7080 = ORIENTED_EDGE('',*,*,#7081,.T.);
#7081 = EDGE_CURVE('',#7045,#7082,#7084,.T.);
#7082 = VERTEX_POINT('',#7083);
#7083 = CARTESIAN_POINT('',(-1.396,-4.89,8.2));
#7084 = SURFACE_CURVE('',#7085,(#7089,#7096),.PCURVE_S1.);
#7085 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7086,#7087,#7088),
#7086 = CARTESIAN_POINT('',(-1.664,-5.388,8.2));
#7087 = CARTESIAN_POINT('',(-1.664,-5.077,8.2));
#7088 = CARTESIAN_POINT('',(-1.396,-4.89,8.2));
#7089 = PCURVE('',#7053,#7090);
#7090 = DEFINITIONAL_REPRESENTATION('',(#7091),#7095);
#7091 = LINE('',#7092,#7093);
#7092 = CARTESIAN_POINT('',(0.,-0.2));
#7093 = VECTOR('',#7094,1.);
#7094 = DIRECTION('',(1.,0.));
#7095 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7096 = PCURVE('',#7097,#7102);
#7097 = PLANE('',#7098);
#7098 = AXIS2_PLACEMENT_3D('',#7099,#7100,#7101);
#7099 = CARTESIAN_POINT('',(-1.214096280614,-5.492314335189,8.2));
#7100 = DIRECTION('',(-0.,0.,-1.));
#7101 = DIRECTION('',(0.,1.,0.));
#7102 = DEFINITIONAL_REPRESENTATION('',(#7103),#7107);
#7103 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7104,#7105,#7106),
#7104 = CARTESIAN_POINT('',(0.104314335189,-0.449903719386));
#7105 = CARTESIAN_POINT('',(0.415314335189,-0.449903719386));
#7106 = CARTESIAN_POINT('',(0.602314335189,-0.181903719386));
#7107 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7108 = ORIENTED_EDGE('',*,*,#7109,.F.);
#7109 = EDGE_CURVE('',#7110,#7082,#7112,.T.);
#7110 = VERTEX_POINT('',#7111);
#7111 = CARTESIAN_POINT('',(-1.396,-4.89,8.));
#7112 = SURFACE_CURVE('',#7113,(#7117,#7124),.PCURVE_S1.);
#7113 = LINE('',#7114,#7115);
#7114 = CARTESIAN_POINT('',(-1.396,-4.89,8.));
#7115 = VECTOR('',#7116,1.);
#7116 = DIRECTION('',(0.,0.,1.));
#7117 = PCURVE('',#7053,#7118);
#7118 = DEFINITIONAL_REPRESENTATION('',(#7119),#7123);
#7119 = LINE('',#7120,#7121);
#7120 = CARTESIAN_POINT('',(1.,0.));
#7121 = VECTOR('',#7122,1.);
#7122 = DIRECTION('',(0.,-1.));
#7123 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7124 = PCURVE('',#7125,#7132);
#7125 = SURFACE_OF_LINEAR_EXTRUSION('',#7126,#7130);
#7126 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7127,#7128,#7129),
#7127 = CARTESIAN_POINT('',(-1.396,-4.89,8.));
#7128 = CARTESIAN_POINT('',(-1.163,-4.724,8.));
#7129 = CARTESIAN_POINT('',(-0.815,-4.724,8.));
#7130 = VECTOR('',#7131,1.);
#7131 = DIRECTION('',(-0.,-0.,-1.));
#7132 = DEFINITIONAL_REPRESENTATION('',(#7133),#7137);
#7133 = LINE('',#7134,#7135);
#7134 = CARTESIAN_POINT('',(0.,0.));
#7135 = VECTOR('',#7136,1.);
#7136 = DIRECTION('',(0.,-1.));
#7137 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7138 = ORIENTED_EDGE('',*,*,#7139,.F.);
#7139 = EDGE_CURVE('',#7043,#7110,#7140,.T.);
#7140 = SURFACE_CURVE('',#7141,(#7145,#7152),.PCURVE_S1.);
#7141 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7142,#7143,#7144),
#7142 = CARTESIAN_POINT('',(-1.664,-5.388,8.));
#7143 = CARTESIAN_POINT('',(-1.664,-5.077,8.));
#7144 = CARTESIAN_POINT('',(-1.396,-4.89,8.));
#7145 = PCURVE('',#7053,#7146);
#7146 = DEFINITIONAL_REPRESENTATION('',(#7147),#7151);
#7147 = LINE('',#7148,#7149);
#7148 = CARTESIAN_POINT('',(0.,0.));
#7149 = VECTOR('',#7150,1.);
#7150 = DIRECTION('',(1.,0.));
#7151 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7152 = PCURVE('',#7153,#7158);
#7153 = PLANE('',#7154);
#7154 = AXIS2_PLACEMENT_3D('',#7155,#7156,#7157);
#7155 = CARTESIAN_POINT('',(-1.214096280614,-5.492314335189,8.));
#7156 = DIRECTION('',(-0.,0.,-1.));
#7157 = DIRECTION('',(0.,1.,0.));
#7158 = DEFINITIONAL_REPRESENTATION('',(#7159),#7163);
#7159 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7160,#7161,#7162),
#7160 = CARTESIAN_POINT('',(0.104314335189,-0.449903719386));
#7161 = CARTESIAN_POINT('',(0.415314335189,-0.449903719386));
#7162 = CARTESIAN_POINT('',(0.602314335189,-0.181903719386));
#7163 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7164 = ADVANCED_FACE('',(#7165),#7125,.T.);
#7165 = FACE_BOUND('',#7166,.T.);
#7166 = EDGE_LOOP('',(#7167,#7168,#7191,#7221));
#7167 = ORIENTED_EDGE('',*,*,#7109,.T.);
#7168 = ORIENTED_EDGE('',*,*,#7169,.T.);
#7169 = EDGE_CURVE('',#7082,#7170,#7172,.T.);
#7170 = VERTEX_POINT('',#7171);
#7171 = CARTESIAN_POINT('',(-0.815,-4.724,8.2));
#7172 = SURFACE_CURVE('',#7173,(#7177,#7184),.PCURVE_S1.);
#7173 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7174,#7175,#7176),
#7174 = CARTESIAN_POINT('',(-1.396,-4.89,8.2));
#7175 = CARTESIAN_POINT('',(-1.163,-4.724,8.2));
#7176 = CARTESIAN_POINT('',(-0.815,-4.724,8.2));
#7177 = PCURVE('',#7125,#7178);
#7178 = DEFINITIONAL_REPRESENTATION('',(#7179),#7183);
#7179 = LINE('',#7180,#7181);
#7180 = CARTESIAN_POINT('',(0.,-0.2));
#7181 = VECTOR('',#7182,1.);
#7182 = DIRECTION('',(1.,0.));
#7183 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7184 = PCURVE('',#7097,#7185);
#7185 = DEFINITIONAL_REPRESENTATION('',(#7186),#7190);
#7186 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7187,#7188,#7189),
#7187 = CARTESIAN_POINT('',(0.602314335189,-0.181903719386));
#7188 = CARTESIAN_POINT('',(0.768314335189,5.109628061397E-02));
#7189 = CARTESIAN_POINT('',(0.768314335189,0.399096280614));
#7190 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7191 = ORIENTED_EDGE('',*,*,#7192,.F.);
#7192 = EDGE_CURVE('',#7193,#7170,#7195,.T.);
#7193 = VERTEX_POINT('',#7194);
#7194 = CARTESIAN_POINT('',(-0.815,-4.724,8.));
#7195 = SURFACE_CURVE('',#7196,(#7200,#7207),.PCURVE_S1.);
#7196 = LINE('',#7197,#7198);
#7197 = CARTESIAN_POINT('',(-0.815,-4.724,8.));
#7198 = VECTOR('',#7199,1.);
#7199 = DIRECTION('',(0.,0.,1.));
#7200 = PCURVE('',#7125,#7201);
#7201 = DEFINITIONAL_REPRESENTATION('',(#7202),#7206);
#7202 = LINE('',#7203,#7204);
#7203 = CARTESIAN_POINT('',(1.,0.));
#7204 = VECTOR('',#7205,1.);
#7205 = DIRECTION('',(0.,-1.));
#7206 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7207 = PCURVE('',#7208,#7215);
#7208 = SURFACE_OF_LINEAR_EXTRUSION('',#7209,#7213);
#7209 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7210,#7211,#7212),
#7210 = CARTESIAN_POINT('',(-0.815,-4.724,8.));
#7211 = CARTESIAN_POINT('',(-0.345,-4.724,8.));
#7212 = CARTESIAN_POINT('',(-0.102,-4.985,8.));
#7213 = VECTOR('',#7214,1.);
#7214 = DIRECTION('',(-0.,-0.,-1.));
#7215 = DEFINITIONAL_REPRESENTATION('',(#7216),#7220);
#7216 = LINE('',#7217,#7218);
#7217 = CARTESIAN_POINT('',(0.,0.));
#7218 = VECTOR('',#7219,1.);
#7219 = DIRECTION('',(0.,-1.));
#7220 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7221 = ORIENTED_EDGE('',*,*,#7222,.F.);
#7222 = EDGE_CURVE('',#7110,#7193,#7223,.T.);
#7223 = SURFACE_CURVE('',#7224,(#7228,#7235),.PCURVE_S1.);
#7224 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7225,#7226,#7227),
#7225 = CARTESIAN_POINT('',(-1.396,-4.89,8.));
#7226 = CARTESIAN_POINT('',(-1.163,-4.724,8.));
#7227 = CARTESIAN_POINT('',(-0.815,-4.724,8.));
#7228 = PCURVE('',#7125,#7229);
#7229 = DEFINITIONAL_REPRESENTATION('',(#7230),#7234);
#7230 = LINE('',#7231,#7232);
#7231 = CARTESIAN_POINT('',(0.,0.));
#7232 = VECTOR('',#7233,1.);
#7233 = DIRECTION('',(1.,0.));
#7234 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7235 = PCURVE('',#7153,#7236);
#7236 = DEFINITIONAL_REPRESENTATION('',(#7237),#7241);
#7237 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7238,#7239,#7240),
#7238 = CARTESIAN_POINT('',(0.602314335189,-0.181903719386));
#7239 = CARTESIAN_POINT('',(0.768314335189,5.109628061397E-02));
#7240 = CARTESIAN_POINT('',(0.768314335189,0.399096280614));
#7241 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7242 = ADVANCED_FACE('',(#7243),#7208,.T.);
#7243 = FACE_BOUND('',#7244,.T.);
#7244 = EDGE_LOOP('',(#7245,#7246,#7269,#7299));
#7245 = ORIENTED_EDGE('',*,*,#7192,.T.);
#7246 = ORIENTED_EDGE('',*,*,#7247,.T.);
#7247 = EDGE_CURVE('',#7170,#7248,#7250,.T.);
#7248 = VERTEX_POINT('',#7249);
#7249 = CARTESIAN_POINT('',(-0.102,-4.985,8.2));
#7250 = SURFACE_CURVE('',#7251,(#7255,#7262),.PCURVE_S1.);
#7251 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7252,#7253,#7254),
#7252 = CARTESIAN_POINT('',(-0.815,-4.724,8.2));
#7253 = CARTESIAN_POINT('',(-0.345,-4.724,8.2));
#7254 = CARTESIAN_POINT('',(-0.102,-4.985,8.2));
#7255 = PCURVE('',#7208,#7256);
#7256 = DEFINITIONAL_REPRESENTATION('',(#7257),#7261);
#7257 = LINE('',#7258,#7259);
#7258 = CARTESIAN_POINT('',(0.,-0.2));
#7259 = VECTOR('',#7260,1.);
#7260 = DIRECTION('',(1.,0.));
#7261 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7262 = PCURVE('',#7097,#7263);
#7263 = DEFINITIONAL_REPRESENTATION('',(#7264),#7268);
#7264 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7265,#7266,#7267),
#7265 = CARTESIAN_POINT('',(0.768314335189,0.399096280614));
#7266 = CARTESIAN_POINT('',(0.768314335189,0.869096280614));
#7267 = CARTESIAN_POINT('',(0.507314335189,1.112096280614));
#7268 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7269 = ORIENTED_EDGE('',*,*,#7270,.F.);
#7270 = EDGE_CURVE('',#7271,#7248,#7273,.T.);
#7271 = VERTEX_POINT('',#7272);
#7272 = CARTESIAN_POINT('',(-0.102,-4.985,8.));
#7273 = SURFACE_CURVE('',#7274,(#7278,#7285),.PCURVE_S1.);
#7274 = LINE('',#7275,#7276);
#7275 = CARTESIAN_POINT('',(-0.102,-4.985,8.));
#7276 = VECTOR('',#7277,1.);
#7277 = DIRECTION('',(0.,0.,1.));
#7278 = PCURVE('',#7208,#7279);
#7279 = DEFINITIONAL_REPRESENTATION('',(#7280),#7284);
#7280 = LINE('',#7281,#7282);
#7281 = CARTESIAN_POINT('',(1.,0.));
#7282 = VECTOR('',#7283,1.);
#7283 = DIRECTION('',(0.,-1.));
#7284 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7285 = PCURVE('',#7286,#7293);
#7286 = SURFACE_OF_LINEAR_EXTRUSION('',#7287,#7291);
#7287 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7288,#7289,#7290),
#7288 = CARTESIAN_POINT('',(-0.102,-4.985,8.));
#7289 = CARTESIAN_POINT('',(6.4E-02,-5.163,8.));
#7290 = CARTESIAN_POINT('',(6.4E-02,-5.409,8.));
#7291 = VECTOR('',#7292,1.);
#7292 = DIRECTION('',(-0.,-0.,-1.));
#7293 = DEFINITIONAL_REPRESENTATION('',(#7294),#7298);
#7294 = LINE('',#7295,#7296);
#7295 = CARTESIAN_POINT('',(0.,0.));
#7296 = VECTOR('',#7297,1.);
#7297 = DIRECTION('',(0.,-1.));
#7298 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7299 = ORIENTED_EDGE('',*,*,#7300,.F.);
#7300 = EDGE_CURVE('',#7193,#7271,#7301,.T.);
#7301 = SURFACE_CURVE('',#7302,(#7306,#7313),.PCURVE_S1.);
#7302 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7303,#7304,#7305),
#7303 = CARTESIAN_POINT('',(-0.815,-4.724,8.));
#7304 = CARTESIAN_POINT('',(-0.345,-4.724,8.));
#7305 = CARTESIAN_POINT('',(-0.102,-4.985,8.));
#7306 = PCURVE('',#7208,#7307);
#7307 = DEFINITIONAL_REPRESENTATION('',(#7308),#7312);
#7308 = LINE('',#7309,#7310);
#7309 = CARTESIAN_POINT('',(0.,0.));
#7310 = VECTOR('',#7311,1.);
#7311 = DIRECTION('',(1.,0.));
#7312 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7313 = PCURVE('',#7153,#7314);
#7314 = DEFINITIONAL_REPRESENTATION('',(#7315),#7319);
#7315 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7316,#7317,#7318),
#7316 = CARTESIAN_POINT('',(0.768314335189,0.399096280614));
#7317 = CARTESIAN_POINT('',(0.768314335189,0.869096280614));
#7318 = CARTESIAN_POINT('',(0.507314335189,1.112096280614));
#7319 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7320 = ADVANCED_FACE('',(#7321),#7286,.T.);
#7321 = FACE_BOUND('',#7322,.T.);
#7322 = EDGE_LOOP('',(#7323,#7324,#7347,#7377));
#7323 = ORIENTED_EDGE('',*,*,#7270,.T.);
#7324 = ORIENTED_EDGE('',*,*,#7325,.T.);
#7325 = EDGE_CURVE('',#7248,#7326,#7328,.T.);
#7326 = VERTEX_POINT('',#7327);
#7327 = CARTESIAN_POINT('',(6.4E-02,-5.409,8.2));
#7328 = SURFACE_CURVE('',#7329,(#7333,#7340),.PCURVE_S1.);
#7329 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7330,#7331,#7332),
#7330 = CARTESIAN_POINT('',(-0.102,-4.985,8.2));
#7331 = CARTESIAN_POINT('',(6.4E-02,-5.163,8.2));
#7332 = CARTESIAN_POINT('',(6.4E-02,-5.409,8.2));
#7333 = PCURVE('',#7286,#7334);
#7334 = DEFINITIONAL_REPRESENTATION('',(#7335),#7339);
#7335 = LINE('',#7336,#7337);
#7336 = CARTESIAN_POINT('',(0.,-0.2));
#7337 = VECTOR('',#7338,1.);
#7338 = DIRECTION('',(1.,0.));
#7339 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7340 = PCURVE('',#7097,#7341);
#7341 = DEFINITIONAL_REPRESENTATION('',(#7342),#7346);
#7342 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7343,#7344,#7345),
#7343 = CARTESIAN_POINT('',(0.507314335189,1.112096280614));
#7344 = CARTESIAN_POINT('',(0.329314335189,1.278096280614));
#7345 = CARTESIAN_POINT('',(8.331433518944E-02,1.278096280614));
#7346 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7347 = ORIENTED_EDGE('',*,*,#7348,.F.);
#7348 = EDGE_CURVE('',#7349,#7326,#7351,.T.);
#7349 = VERTEX_POINT('',#7350);
#7350 = CARTESIAN_POINT('',(6.4E-02,-5.409,8.));
#7351 = SURFACE_CURVE('',#7352,(#7356,#7363),.PCURVE_S1.);
#7352 = LINE('',#7353,#7354);
#7353 = CARTESIAN_POINT('',(6.4E-02,-5.409,8.));
#7354 = VECTOR('',#7355,1.);
#7355 = DIRECTION('',(0.,0.,1.));
#7356 = PCURVE('',#7286,#7357);
#7357 = DEFINITIONAL_REPRESENTATION('',(#7358),#7362);
#7358 = LINE('',#7359,#7360);
#7359 = CARTESIAN_POINT('',(1.,0.));
#7360 = VECTOR('',#7361,1.);
#7361 = DIRECTION('',(0.,-1.));
#7362 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7363 = PCURVE('',#7364,#7371);
#7364 = SURFACE_OF_LINEAR_EXTRUSION('',#7365,#7369);
#7365 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7366,#7367,#7368),
#7366 = CARTESIAN_POINT('',(6.4E-02,-5.409,8.));
#7367 = CARTESIAN_POINT('',(6.1E-02,-5.714,8.));
#7368 = CARTESIAN_POINT('',(-0.234,-5.901,8.));
#7369 = VECTOR('',#7370,1.);
#7370 = DIRECTION('',(-0.,-0.,-1.));
#7371 = DEFINITIONAL_REPRESENTATION('',(#7372),#7376);
#7372 = LINE('',#7373,#7374);
#7373 = CARTESIAN_POINT('',(0.,0.));
#7374 = VECTOR('',#7375,1.);
#7375 = DIRECTION('',(0.,-1.));
#7376 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7377 = ORIENTED_EDGE('',*,*,#7378,.F.);
#7378 = EDGE_CURVE('',#7271,#7349,#7379,.T.);
#7379 = SURFACE_CURVE('',#7380,(#7384,#7391),.PCURVE_S1.);
#7380 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7381,#7382,#7383),
#7381 = CARTESIAN_POINT('',(-0.102,-4.985,8.));
#7382 = CARTESIAN_POINT('',(6.4E-02,-5.163,8.));
#7383 = CARTESIAN_POINT('',(6.4E-02,-5.409,8.));
#7384 = PCURVE('',#7286,#7385);
#7385 = DEFINITIONAL_REPRESENTATION('',(#7386),#7390);
#7386 = LINE('',#7387,#7388);
#7387 = CARTESIAN_POINT('',(0.,0.));
#7388 = VECTOR('',#7389,1.);
#7389 = DIRECTION('',(1.,0.));
#7390 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7391 = PCURVE('',#7153,#7392);
#7392 = DEFINITIONAL_REPRESENTATION('',(#7393),#7397);
#7393 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7394,#7395,#7396),
#7394 = CARTESIAN_POINT('',(0.507314335189,1.112096280614));
#7395 = CARTESIAN_POINT('',(0.329314335189,1.278096280614));
#7396 = CARTESIAN_POINT('',(8.331433518944E-02,1.278096280614));
#7397 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7398 = ADVANCED_FACE('',(#7399),#7364,.T.);
#7399 = FACE_BOUND('',#7400,.T.);
#7400 = EDGE_LOOP('',(#7401,#7402,#7425,#7453));
#7401 = ORIENTED_EDGE('',*,*,#7348,.T.);
#7402 = ORIENTED_EDGE('',*,*,#7403,.T.);
#7403 = EDGE_CURVE('',#7326,#7404,#7406,.T.);
#7404 = VERTEX_POINT('',#7405);
#7405 = CARTESIAN_POINT('',(-0.234,-5.901,8.2));
#7406 = SURFACE_CURVE('',#7407,(#7411,#7418),.PCURVE_S1.);
#7407 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7408,#7409,#7410),
#7408 = CARTESIAN_POINT('',(6.4E-02,-5.409,8.2));
#7409 = CARTESIAN_POINT('',(6.1E-02,-5.714,8.2));
#7410 = CARTESIAN_POINT('',(-0.234,-5.901,8.2));
#7411 = PCURVE('',#7364,#7412);
#7412 = DEFINITIONAL_REPRESENTATION('',(#7413),#7417);
#7413 = LINE('',#7414,#7415);
#7414 = CARTESIAN_POINT('',(0.,-0.2));
#7415 = VECTOR('',#7416,1.);
#7416 = DIRECTION('',(1.,0.));
#7417 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7418 = PCURVE('',#7097,#7419);
#7419 = DEFINITIONAL_REPRESENTATION('',(#7420),#7424);
#7420 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7421,#7422,#7423),
#7421 = CARTESIAN_POINT('',(8.331433518944E-02,1.278096280614));
#7422 = CARTESIAN_POINT('',(-0.221685664811,1.275096280614));
#7423 = CARTESIAN_POINT('',(-0.408685664811,0.980096280614));
#7424 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7425 = ORIENTED_EDGE('',*,*,#7426,.F.);
#7426 = EDGE_CURVE('',#7427,#7404,#7429,.T.);
#7427 = VERTEX_POINT('',#7428);
#7428 = CARTESIAN_POINT('',(-0.234,-5.901,8.));
#7429 = SURFACE_CURVE('',#7430,(#7434,#7441),.PCURVE_S1.);
#7430 = LINE('',#7431,#7432);
#7431 = CARTESIAN_POINT('',(-0.234,-5.901,8.));
#7432 = VECTOR('',#7433,1.);
#7433 = DIRECTION('',(0.,0.,1.));
#7434 = PCURVE('',#7364,#7435);
#7435 = DEFINITIONAL_REPRESENTATION('',(#7436),#7440);
#7436 = LINE('',#7437,#7438);
#7437 = CARTESIAN_POINT('',(1.,0.));
#7438 = VECTOR('',#7439,1.);
#7439 = DIRECTION('',(0.,-1.));
#7440 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7441 = PCURVE('',#7442,#7447);
#7442 = PLANE('',#7443);
#7443 = AXIS2_PLACEMENT_3D('',#7444,#7445,#7446);
#7444 = CARTESIAN_POINT('',(-0.234,-5.901,8.));
#7445 = DIRECTION('',(-0.131331175535,0.991338550815,0.));
#7446 = DIRECTION('',(0.991338550815,0.131331175535,0.));
#7447 = DEFINITIONAL_REPRESENTATION('',(#7448),#7452);
#7448 = LINE('',#7449,#7450);
#7449 = CARTESIAN_POINT('',(8.E-17,0.));
#7450 = VECTOR('',#7451,1.);
#7451 = DIRECTION('',(0.,-1.));
#7452 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7453 = ORIENTED_EDGE('',*,*,#7454,.F.);
#7454 = EDGE_CURVE('',#7349,#7427,#7455,.T.);
#7455 = SURFACE_CURVE('',#7456,(#7460,#7467),.PCURVE_S1.);
#7456 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7457,#7458,#7459),
#7457 = CARTESIAN_POINT('',(6.4E-02,-5.409,8.));
#7458 = CARTESIAN_POINT('',(6.1E-02,-5.714,8.));
#7459 = CARTESIAN_POINT('',(-0.234,-5.901,8.));
#7460 = PCURVE('',#7364,#7461);
#7461 = DEFINITIONAL_REPRESENTATION('',(#7462),#7466);
#7462 = LINE('',#7463,#7464);
#7463 = CARTESIAN_POINT('',(0.,0.));
#7464 = VECTOR('',#7465,1.);
#7465 = DIRECTION('',(1.,0.));
#7466 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7467 = PCURVE('',#7153,#7468);
#7468 = DEFINITIONAL_REPRESENTATION('',(#7469),#7473);
#7469 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7470,#7471,#7472),
#7470 = CARTESIAN_POINT('',(8.331433518944E-02,1.278096280614));
#7471 = CARTESIAN_POINT('',(-0.221685664811,1.275096280614));
#7472 = CARTESIAN_POINT('',(-0.408685664811,0.980096280614));
#7473 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7474 = ADVANCED_FACE('',(#7475),#7442,.T.);
#7475 = FACE_BOUND('',#7476,.T.);
#7476 = EDGE_LOOP('',(#7477,#7478,#7501,#7529));
#7477 = ORIENTED_EDGE('',*,*,#7426,.T.);
#7478 = ORIENTED_EDGE('',*,*,#7479,.T.);
#7479 = EDGE_CURVE('',#7404,#7480,#7482,.T.);
#7480 = VERTEX_POINT('',#7481);
#7481 = CARTESIAN_POINT('',(-1.E-15,-5.87,8.2));
#7482 = SURFACE_CURVE('',#7483,(#7487,#7494),.PCURVE_S1.);
#7483 = LINE('',#7484,#7485);
#7484 = CARTESIAN_POINT('',(-0.234,-5.901,8.2));
#7485 = VECTOR('',#7486,1.);
#7486 = DIRECTION('',(0.991338550815,0.131331175535,0.));
#7487 = PCURVE('',#7442,#7488);
#7488 = DEFINITIONAL_REPRESENTATION('',(#7489),#7493);
#7489 = LINE('',#7490,#7491);
#7490 = CARTESIAN_POINT('',(0.,-0.2));
#7491 = VECTOR('',#7492,1.);
#7492 = DIRECTION('',(1.,0.));
#7493 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7494 = PCURVE('',#7097,#7495);
#7495 = DEFINITIONAL_REPRESENTATION('',(#7496),#7500);
#7496 = LINE('',#7497,#7498);
#7497 = CARTESIAN_POINT('',(-0.408685664811,0.980096280614));
#7498 = VECTOR('',#7499,1.);
#7499 = DIRECTION('',(0.131331175535,0.991338550815));
#7500 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7501 = ORIENTED_EDGE('',*,*,#7502,.F.);
#7502 = EDGE_CURVE('',#7503,#7480,#7505,.T.);
#7503 = VERTEX_POINT('',#7504);
#7504 = CARTESIAN_POINT('',(-1.E-15,-5.87,8.));
#7505 = SURFACE_CURVE('',#7506,(#7510,#7517),.PCURVE_S1.);
#7506 = LINE('',#7507,#7508);
#7507 = CARTESIAN_POINT('',(-1.11E-15,-5.87,8.));
#7508 = VECTOR('',#7509,1.);
#7509 = DIRECTION('',(0.,0.,1.));
#7510 = PCURVE('',#7442,#7511);
#7511 = DEFINITIONAL_REPRESENTATION('',(#7512),#7516);
#7512 = LINE('',#7513,#7514);
#7513 = CARTESIAN_POINT('',(0.236044487332,0.));
#7514 = VECTOR('',#7515,1.);
#7515 = DIRECTION('',(0.,-1.));
#7516 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7517 = PCURVE('',#7518,#7523);
#7518 = PLANE('',#7519);
#7519 = AXIS2_PLACEMENT_3D('',#7520,#7521,#7522);
#7520 = CARTESIAN_POINT('',(-1.11E-15,-5.87,8.));
#7521 = DIRECTION('',(1.,-2.2E-16,0.));
#7522 = DIRECTION('',(-2.2E-16,-1.,0.));
#7523 = DEFINITIONAL_REPRESENTATION('',(#7524),#7528);
#7524 = LINE('',#7525,#7526);
#7525 = CARTESIAN_POINT('',(8.9E-16,-0.));
#7526 = VECTOR('',#7527,1.);
#7527 = DIRECTION('',(0.,-1.));
#7528 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7529 = ORIENTED_EDGE('',*,*,#7530,.F.);
#7530 = EDGE_CURVE('',#7427,#7503,#7531,.T.);
#7531 = SURFACE_CURVE('',#7532,(#7536,#7543),.PCURVE_S1.);
#7532 = LINE('',#7533,#7534);
#7533 = CARTESIAN_POINT('',(-0.234,-5.901,8.));
#7534 = VECTOR('',#7535,1.);
#7535 = DIRECTION('',(0.991338550815,0.131331175535,0.));
#7536 = PCURVE('',#7442,#7537);
#7537 = DEFINITIONAL_REPRESENTATION('',(#7538),#7542);
#7538 = LINE('',#7539,#7540);
#7539 = CARTESIAN_POINT('',(0.,0.));
#7540 = VECTOR('',#7541,1.);
#7541 = DIRECTION('',(1.,0.));
#7542 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7543 = PCURVE('',#7153,#7544);
#7544 = DEFINITIONAL_REPRESENTATION('',(#7545),#7549);
#7545 = LINE('',#7546,#7547);
#7546 = CARTESIAN_POINT('',(-0.408685664811,0.980096280614));
#7547 = VECTOR('',#7548,1.);
#7548 = DIRECTION('',(0.131331175535,0.991338550815));
#7549 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7550 = ADVANCED_FACE('',(#7551),#7518,.T.);
#7551 = FACE_BOUND('',#7552,.T.);
#7552 = EDGE_LOOP('',(#7553,#7554,#7577,#7605));
#7553 = ORIENTED_EDGE('',*,*,#7502,.T.);
#7554 = ORIENTED_EDGE('',*,*,#7555,.T.);
#7555 = EDGE_CURVE('',#7480,#7556,#7558,.T.);
#7556 = VERTEX_POINT('',#7557);
#7557 = CARTESIAN_POINT('',(-1.E-15,-6.137,8.2));
#7558 = SURFACE_CURVE('',#7559,(#7563,#7570),.PCURVE_S1.);
#7559 = LINE('',#7560,#7561);
#7560 = CARTESIAN_POINT('',(0.,-5.87,8.2));
#7561 = VECTOR('',#7562,1.);
#7562 = DIRECTION('',(0.,-1.,0.));
#7563 = PCURVE('',#7518,#7564);
#7564 = DEFINITIONAL_REPRESENTATION('',(#7565),#7569);
#7565 = LINE('',#7566,#7567);
#7566 = CARTESIAN_POINT('',(0.,-0.2));
#7567 = VECTOR('',#7568,1.);
#7568 = DIRECTION('',(1.,-0.));
#7569 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7570 = PCURVE('',#7097,#7571);
#7571 = DEFINITIONAL_REPRESENTATION('',(#7572),#7576);
#7572 = LINE('',#7573,#7574);
#7573 = CARTESIAN_POINT('',(-0.377685664811,1.214096280614));
#7574 = VECTOR('',#7575,1.);
#7575 = DIRECTION('',(-1.,0.));
#7576 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7577 = ORIENTED_EDGE('',*,*,#7578,.F.);
#7578 = EDGE_CURVE('',#7579,#7556,#7581,.T.);
#7579 = VERTEX_POINT('',#7580);
#7580 = CARTESIAN_POINT('',(-1.E-15,-6.137,8.));
#7581 = SURFACE_CURVE('',#7582,(#7586,#7593),.PCURVE_S1.);
#7582 = LINE('',#7583,#7584);
#7583 = CARTESIAN_POINT('',(-1.33E-15,-6.137,8.));
#7584 = VECTOR('',#7585,1.);
#7585 = DIRECTION('',(0.,0.,1.));
#7586 = PCURVE('',#7518,#7587);
#7587 = DEFINITIONAL_REPRESENTATION('',(#7588),#7592);
#7588 = LINE('',#7589,#7590);
#7589 = CARTESIAN_POINT('',(0.267,-0.));
#7590 = VECTOR('',#7591,1.);
#7591 = DIRECTION('',(0.,-1.));
#7592 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7593 = PCURVE('',#7594,#7599);
#7594 = PLANE('',#7595);
#7595 = AXIS2_PLACEMENT_3D('',#7596,#7597,#7598);
#7596 = CARTESIAN_POINT('',(-1.33E-15,-6.137,8.));
#7597 = DIRECTION('',(-2.2E-16,-1.,0.));
#7598 = DIRECTION('',(-1.,2.2E-16,0.));
#7599 = DEFINITIONAL_REPRESENTATION('',(#7600),#7604);
#7600 = LINE('',#7601,#7602);
#7601 = CARTESIAN_POINT('',(0.,0.));
#7602 = VECTOR('',#7603,1.);
#7603 = DIRECTION('',(0.,-1.));
#7604 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7605 = ORIENTED_EDGE('',*,*,#7606,.F.);
#7606 = EDGE_CURVE('',#7503,#7579,#7607,.T.);
#7607 = SURFACE_CURVE('',#7608,(#7612,#7619),.PCURVE_S1.);
#7608 = LINE('',#7609,#7610);
#7609 = CARTESIAN_POINT('',(0.,-5.87,8.));
#7610 = VECTOR('',#7611,1.);
#7611 = DIRECTION('',(0.,-1.,0.));
#7612 = PCURVE('',#7518,#7613);
#7613 = DEFINITIONAL_REPRESENTATION('',(#7614),#7618);
#7614 = LINE('',#7615,#7616);
#7615 = CARTESIAN_POINT('',(0.,0.));
#7616 = VECTOR('',#7617,1.);
#7617 = DIRECTION('',(1.,-0.));
#7618 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7619 = PCURVE('',#7153,#7620);
#7620 = DEFINITIONAL_REPRESENTATION('',(#7621),#7625);
#7621 = LINE('',#7622,#7623);
#7622 = CARTESIAN_POINT('',(-0.377685664811,1.214096280614));
#7623 = VECTOR('',#7624,1.);
#7624 = DIRECTION('',(-1.,0.));
#7625 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7626 = ADVANCED_FACE('',(#7627),#7594,.T.);
#7627 = FACE_BOUND('',#7628,.T.);
#7628 = EDGE_LOOP('',(#7629,#7630,#7653,#7683));
#7629 = ORIENTED_EDGE('',*,*,#7578,.T.);
#7630 = ORIENTED_EDGE('',*,*,#7631,.T.);
#7631 = EDGE_CURVE('',#7556,#7632,#7634,.T.);
#7632 = VERTEX_POINT('',#7633);
#7633 = CARTESIAN_POINT('',(-1.322,-6.137,8.2));
#7634 = SURFACE_CURVE('',#7635,(#7639,#7646),.PCURVE_S1.);
#7635 = LINE('',#7636,#7637);
#7636 = CARTESIAN_POINT('',(0.,-6.137,8.2));
#7637 = VECTOR('',#7638,1.);
#7638 = DIRECTION('',(-1.,0.,0.));
#7639 = PCURVE('',#7594,#7640);
#7640 = DEFINITIONAL_REPRESENTATION('',(#7641),#7645);
#7641 = LINE('',#7642,#7643);
#7642 = CARTESIAN_POINT('',(0.,-0.2));
#7643 = VECTOR('',#7644,1.);
#7644 = DIRECTION('',(1.,0.));
#7645 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7646 = PCURVE('',#7097,#7647);
#7647 = DEFINITIONAL_REPRESENTATION('',(#7648),#7652);
#7648 = LINE('',#7649,#7650);
#7649 = CARTESIAN_POINT('',(-0.644685664811,1.214096280614));
#7650 = VECTOR('',#7651,1.);
#7651 = DIRECTION('',(0.,-1.));
#7652 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7653 = ORIENTED_EDGE('',*,*,#7654,.F.);
#7654 = EDGE_CURVE('',#7655,#7632,#7657,.T.);
#7655 = VERTEX_POINT('',#7656);
#7656 = CARTESIAN_POINT('',(-1.322,-6.137,8.));
#7657 = SURFACE_CURVE('',#7658,(#7662,#7669),.PCURVE_S1.);
#7658 = LINE('',#7659,#7660);
#7659 = CARTESIAN_POINT('',(-1.322,-6.137,8.));
#7660 = VECTOR('',#7661,1.);
#7661 = DIRECTION('',(0.,0.,1.));
#7662 = PCURVE('',#7594,#7663);
#7663 = DEFINITIONAL_REPRESENTATION('',(#7664),#7668);
#7664 = LINE('',#7665,#7666);
#7665 = CARTESIAN_POINT('',(1.322,0.));
#7666 = VECTOR('',#7667,1.);
#7667 = DIRECTION('',(0.,-1.));
#7668 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7669 = PCURVE('',#7670,#7677);
#7670 = SURFACE_OF_LINEAR_EXTRUSION('',#7671,#7675);
#7671 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7672,#7673,#7674),
#7672 = CARTESIAN_POINT('',(-1.322,-6.137,8.));
#7673 = CARTESIAN_POINT('',(-1.832,-6.137,8.));
#7674 = CARTESIAN_POINT('',(-2.032,-5.974,8.));
#7675 = VECTOR('',#7676,1.);
#7676 = DIRECTION('',(-0.,-0.,-1.));
#7677 = DEFINITIONAL_REPRESENTATION('',(#7678),#7682);
#7678 = LINE('',#7679,#7680);
#7679 = CARTESIAN_POINT('',(0.,0.));
#7680 = VECTOR('',#7681,1.);
#7681 = DIRECTION('',(0.,-1.));
#7682 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7683 = ORIENTED_EDGE('',*,*,#7684,.F.);
#7684 = EDGE_CURVE('',#7579,#7655,#7685,.T.);
#7685 = SURFACE_CURVE('',#7686,(#7690,#7697),.PCURVE_S1.);
#7686 = LINE('',#7687,#7688);
#7687 = CARTESIAN_POINT('',(0.,-6.137,8.));
#7688 = VECTOR('',#7689,1.);
#7689 = DIRECTION('',(-1.,0.,0.));
#7690 = PCURVE('',#7594,#7691);
#7691 = DEFINITIONAL_REPRESENTATION('',(#7692),#7696);
#7692 = LINE('',#7693,#7694);
#7693 = CARTESIAN_POINT('',(0.,0.));
#7694 = VECTOR('',#7695,1.);
#7695 = DIRECTION('',(1.,0.));
#7696 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7697 = PCURVE('',#7153,#7698);
#7698 = DEFINITIONAL_REPRESENTATION('',(#7699),#7703);
#7699 = LINE('',#7700,#7701);
#7700 = CARTESIAN_POINT('',(-0.644685664811,1.214096280614));
#7701 = VECTOR('',#7702,1.);
#7702 = DIRECTION('',(0.,-1.));
#7703 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7704 = ADVANCED_FACE('',(#7705),#7670,.T.);
#7705 = FACE_BOUND('',#7706,.T.);
#7706 = EDGE_LOOP('',(#7707,#7708,#7731,#7761));
#7707 = ORIENTED_EDGE('',*,*,#7654,.T.);
#7708 = ORIENTED_EDGE('',*,*,#7709,.T.);
#7709 = EDGE_CURVE('',#7632,#7710,#7712,.T.);
#7710 = VERTEX_POINT('',#7711);
#7711 = CARTESIAN_POINT('',(-2.032,-5.974,8.2));
#7712 = SURFACE_CURVE('',#7713,(#7717,#7724),.PCURVE_S1.);
#7713 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7714,#7715,#7716),
#7714 = CARTESIAN_POINT('',(-1.322,-6.137,8.2));
#7715 = CARTESIAN_POINT('',(-1.832,-6.137,8.2));
#7716 = CARTESIAN_POINT('',(-2.032,-5.974,8.2));
#7717 = PCURVE('',#7670,#7718);
#7718 = DEFINITIONAL_REPRESENTATION('',(#7719),#7723);
#7719 = LINE('',#7720,#7721);
#7720 = CARTESIAN_POINT('',(0.,-0.2));
#7721 = VECTOR('',#7722,1.);
#7722 = DIRECTION('',(1.,0.));
#7723 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7724 = PCURVE('',#7097,#7725);
#7725 = DEFINITIONAL_REPRESENTATION('',(#7726),#7730);
#7726 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7727,#7728,#7729),
#7727 = CARTESIAN_POINT('',(-0.644685664811,-0.107903719386));
#7728 = CARTESIAN_POINT('',(-0.644685664811,-0.617903719386));
#7729 = CARTESIAN_POINT('',(-0.481685664811,-0.817903719386));
#7730 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7731 = ORIENTED_EDGE('',*,*,#7732,.F.);
#7732 = EDGE_CURVE('',#7733,#7710,#7735,.T.);
#7733 = VERTEX_POINT('',#7734);
#7734 = CARTESIAN_POINT('',(-2.032,-5.974,8.));
#7735 = SURFACE_CURVE('',#7736,(#7740,#7747),.PCURVE_S1.);
#7736 = LINE('',#7737,#7738);
#7737 = CARTESIAN_POINT('',(-2.032,-5.974,8.));
#7738 = VECTOR('',#7739,1.);
#7739 = DIRECTION('',(0.,0.,1.));
#7740 = PCURVE('',#7670,#7741);
#7741 = DEFINITIONAL_REPRESENTATION('',(#7742),#7746);
#7742 = LINE('',#7743,#7744);
#7743 = CARTESIAN_POINT('',(1.,0.));
#7744 = VECTOR('',#7745,1.);
#7745 = DIRECTION('',(0.,-1.));
#7746 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7747 = PCURVE('',#7748,#7755);
#7748 = SURFACE_OF_LINEAR_EXTRUSION('',#7749,#7753);
#7749 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7750,#7751,#7752),
#7750 = CARTESIAN_POINT('',(-2.032,-5.974,8.));
#7751 = CARTESIAN_POINT('',(-2.24,-5.802,8.));
#7752 = CARTESIAN_POINT('',(-2.24,-5.418,8.));
#7753 = VECTOR('',#7754,1.);
#7754 = DIRECTION('',(-0.,-0.,-1.));
#7755 = DEFINITIONAL_REPRESENTATION('',(#7756),#7760);
#7756 = LINE('',#7757,#7758);
#7757 = CARTESIAN_POINT('',(0.,0.));
#7758 = VECTOR('',#7759,1.);
#7759 = DIRECTION('',(0.,-1.));
#7760 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7761 = ORIENTED_EDGE('',*,*,#7762,.F.);
#7762 = EDGE_CURVE('',#7655,#7733,#7763,.T.);
#7763 = SURFACE_CURVE('',#7764,(#7768,#7775),.PCURVE_S1.);
#7764 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7765,#7766,#7767),
#7765 = CARTESIAN_POINT('',(-1.322,-6.137,8.));
#7766 = CARTESIAN_POINT('',(-1.832,-6.137,8.));
#7767 = CARTESIAN_POINT('',(-2.032,-5.974,8.));
#7768 = PCURVE('',#7670,#7769);
#7769 = DEFINITIONAL_REPRESENTATION('',(#7770),#7774);
#7770 = LINE('',#7771,#7772);
#7771 = CARTESIAN_POINT('',(0.,0.));
#7772 = VECTOR('',#7773,1.);
#7773 = DIRECTION('',(1.,0.));
#7774 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7775 = PCURVE('',#7153,#7776);
#7776 = DEFINITIONAL_REPRESENTATION('',(#7777),#7781);
#7777 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7778,#7779,#7780),
#7778 = CARTESIAN_POINT('',(-0.644685664811,-0.107903719386));
#7779 = CARTESIAN_POINT('',(-0.644685664811,-0.617903719386));
#7780 = CARTESIAN_POINT('',(-0.481685664811,-0.817903719386));
#7781 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7782 = ADVANCED_FACE('',(#7783),#7748,.T.);
#7783 = FACE_BOUND('',#7784,.T.);
#7784 = EDGE_LOOP('',(#7785,#7786,#7809,#7839));
#7785 = ORIENTED_EDGE('',*,*,#7732,.T.);
#7786 = ORIENTED_EDGE('',*,*,#7787,.T.);
#7787 = EDGE_CURVE('',#7710,#7788,#7790,.T.);
#7788 = VERTEX_POINT('',#7789);
#7789 = CARTESIAN_POINT('',(-2.24,-5.418,8.2));
#7790 = SURFACE_CURVE('',#7791,(#7795,#7802),.PCURVE_S1.);
#7791 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7792,#7793,#7794),
#7792 = CARTESIAN_POINT('',(-2.032,-5.974,8.2));
#7793 = CARTESIAN_POINT('',(-2.24,-5.802,8.2));
#7794 = CARTESIAN_POINT('',(-2.24,-5.418,8.2));
#7795 = PCURVE('',#7748,#7796);
#7796 = DEFINITIONAL_REPRESENTATION('',(#7797),#7801);
#7797 = LINE('',#7798,#7799);
#7798 = CARTESIAN_POINT('',(0.,-0.2));
#7799 = VECTOR('',#7800,1.);
#7800 = DIRECTION('',(1.,0.));
#7801 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7802 = PCURVE('',#7097,#7803);
#7803 = DEFINITIONAL_REPRESENTATION('',(#7804),#7808);
#7804 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7805,#7806,#7807),
#7805 = CARTESIAN_POINT('',(-0.481685664811,-0.817903719386));
#7806 = CARTESIAN_POINT('',(-0.309685664811,-1.025903719386));
#7807 = CARTESIAN_POINT('',(7.431433518944E-02,-1.025903719386));
#7808 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7809 = ORIENTED_EDGE('',*,*,#7810,.F.);
#7810 = EDGE_CURVE('',#7811,#7788,#7813,.T.);
#7811 = VERTEX_POINT('',#7812);
#7812 = CARTESIAN_POINT('',(-2.24,-5.418,8.));
#7813 = SURFACE_CURVE('',#7814,(#7818,#7825),.PCURVE_S1.);
#7814 = LINE('',#7815,#7816);
#7815 = CARTESIAN_POINT('',(-2.24,-5.418,8.));
#7816 = VECTOR('',#7817,1.);
#7817 = DIRECTION('',(0.,0.,1.));
#7818 = PCURVE('',#7748,#7819);
#7819 = DEFINITIONAL_REPRESENTATION('',(#7820),#7824);
#7820 = LINE('',#7821,#7822);
#7821 = CARTESIAN_POINT('',(1.,0.));
#7822 = VECTOR('',#7823,1.);
#7823 = DIRECTION('',(0.,-1.));
#7824 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7825 = PCURVE('',#7826,#7833);
#7826 = SURFACE_OF_LINEAR_EXTRUSION('',#7827,#7831);
#7827 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7828,#7829,#7830),
#7828 = CARTESIAN_POINT('',(-2.24,-5.418,8.));
#7829 = CARTESIAN_POINT('',(-2.24,-4.994,8.));
#7830 = CARTESIAN_POINT('',(-1.99,-4.841,8.));
#7831 = VECTOR('',#7832,1.);
#7832 = DIRECTION('',(-0.,-0.,-1.));
#7833 = DEFINITIONAL_REPRESENTATION('',(#7834),#7838);
#7834 = LINE('',#7835,#7836);
#7835 = CARTESIAN_POINT('',(0.,0.));
#7836 = VECTOR('',#7837,1.);
#7837 = DIRECTION('',(0.,-1.));
#7838 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7839 = ORIENTED_EDGE('',*,*,#7840,.F.);
#7840 = EDGE_CURVE('',#7733,#7811,#7841,.T.);
#7841 = SURFACE_CURVE('',#7842,(#7846,#7853),.PCURVE_S1.);
#7842 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7843,#7844,#7845),
#7843 = CARTESIAN_POINT('',(-2.032,-5.974,8.));
#7844 = CARTESIAN_POINT('',(-2.24,-5.802,8.));
#7845 = CARTESIAN_POINT('',(-2.24,-5.418,8.));
#7846 = PCURVE('',#7748,#7847);
#7847 = DEFINITIONAL_REPRESENTATION('',(#7848),#7852);
#7848 = LINE('',#7849,#7850);
#7849 = CARTESIAN_POINT('',(0.,0.));
#7850 = VECTOR('',#7851,1.);
#7851 = DIRECTION('',(1.,0.));
#7852 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7853 = PCURVE('',#7153,#7854);
#7854 = DEFINITIONAL_REPRESENTATION('',(#7855),#7859);
#7855 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7856,#7857,#7858),
.UNSPECIFIED.,.F.,.F.,(3,3),(0.,1.),.PIECEWISE_BEZIER_KNOTS.);
#7856 = CARTESIAN_POINT('',(-0.481685664811,-0.817903719386));
#7857 = CARTESIAN_POINT('',(-0.309685664811,-1.025903719386));
#7858 = CARTESIAN_POINT('',(7.431433518944E-02,-1.025903719386));
#7859 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7860 = ADVANCED_FACE('',(#7861),#7826,.T.);
#7861 = FACE_BOUND('',#7862,.T.);
#7862 = EDGE_LOOP('',(#7863,#7864,#7887,#7917));
#7863 = ORIENTED_EDGE('',*,*,#7810,.T.);
#7864 = ORIENTED_EDGE('',*,*,#7865,.T.);
#7865 = EDGE_CURVE('',#7788,#7866,#7868,.T.);
#7866 = VERTEX_POINT('',#7867);
#7867 = CARTESIAN_POINT('',(-1.99,-4.841,8.2));
#7868 = SURFACE_CURVE('',#7869,(#7873,#7880),.PCURVE_S1.);
#7869 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7870,#7871,#7872),
#7870 = CARTESIAN_POINT('',(-2.24,-5.418,8.2));
#7871 = CARTESIAN_POINT('',(-2.24,-4.994,8.2));
#7872 = CARTESIAN_POINT('',(-1.99,-4.841,8.2));
#7873 = PCURVE('',#7826,#7874);
#7874 = DEFINITIONAL_REPRESENTATION('',(#7875),#7879);
#7875 = LINE('',#7876,#7877);
#7876 = CARTESIAN_POINT('',(0.,-0.2));
#7877 = VECTOR('',#7878,1.);
#7878 = DIRECTION('',(1.,0.));
#7879 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7880 = PCURVE('',#7097,#7881);
#7881 = DEFINITIONAL_REPRESENTATION('',(#7882),#7886);
#7882 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7883,#7884,#7885),
#7883 = CARTESIAN_POINT('',(7.431433518944E-02,-1.025903719386));
#7884 = CARTESIAN_POINT('',(0.498314335189,-1.025903719386));
#7885 = CARTESIAN_POINT('',(0.651314335189,-0.775903719386));
#7886 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7887 = ORIENTED_EDGE('',*,*,#7888,.F.);
#7888 = EDGE_CURVE('',#7889,#7866,#7891,.T.);
#7889 = VERTEX_POINT('',#7890);
#7890 = CARTESIAN_POINT('',(-1.99,-4.841,8.));
#7891 = SURFACE_CURVE('',#7892,(#7896,#7903),.PCURVE_S1.);
#7892 = LINE('',#7893,#7894);
#7893 = CARTESIAN_POINT('',(-1.99,-4.841,8.));
#7894 = VECTOR('',#7895,1.);
#7895 = DIRECTION('',(0.,0.,1.));
#7896 = PCURVE('',#7826,#7897);
#7897 = DEFINITIONAL_REPRESENTATION('',(#7898),#7902);
#7898 = LINE('',#7899,#7900);
#7899 = CARTESIAN_POINT('',(1.,0.));
#7900 = VECTOR('',#7901,1.);
#7901 = DIRECTION('',(0.,-1.));
#7902 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7903 = PCURVE('',#7904,#7911);
#7904 = SURFACE_OF_LINEAR_EXTRUSION('',#7905,#7909);
#7905 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7906,#7907,#7908),
#7906 = CARTESIAN_POINT('',(-1.99,-4.841,8.));
#7907 = CARTESIAN_POINT('',(-1.9,-4.788,8.));
#7908 = CARTESIAN_POINT('',(-1.792,-4.776,8.));
#7909 = VECTOR('',#7910,1.);
#7910 = DIRECTION('',(-0.,-0.,-1.));
#7911 = DEFINITIONAL_REPRESENTATION('',(#7912),#7916);
#7912 = LINE('',#7913,#7914);
#7913 = CARTESIAN_POINT('',(0.,0.));
#7914 = VECTOR('',#7915,1.);
#7915 = DIRECTION('',(0.,-1.));
#7916 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7917 = ORIENTED_EDGE('',*,*,#7918,.F.);
#7918 = EDGE_CURVE('',#7811,#7889,#7919,.T.);
#7919 = SURFACE_CURVE('',#7920,(#7924,#7931),.PCURVE_S1.);
#7920 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7921,#7922,#7923),
#7921 = CARTESIAN_POINT('',(-2.24,-5.418,8.));
#7922 = CARTESIAN_POINT('',(-2.24,-4.994,8.));
#7923 = CARTESIAN_POINT('',(-1.99,-4.841,8.));
#7924 = PCURVE('',#7826,#7925);
#7925 = DEFINITIONAL_REPRESENTATION('',(#7926),#7930);
#7926 = LINE('',#7927,#7928);
#7927 = CARTESIAN_POINT('',(0.,0.));
#7928 = VECTOR('',#7929,1.);
#7929 = DIRECTION('',(1.,0.));
#7930 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7931 = PCURVE('',#7153,#7932);
#7932 = DEFINITIONAL_REPRESENTATION('',(#7933),#7937);
#7933 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7934,#7935,#7936),
#7934 = CARTESIAN_POINT('',(7.431433518944E-02,-1.025903719386));
#7935 = CARTESIAN_POINT('',(0.498314335189,-1.025903719386));
#7936 = CARTESIAN_POINT('',(0.651314335189,-0.775903719386));
#7937 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7938 = ADVANCED_FACE('',(#7939),#7904,.T.);
#7939 = FACE_BOUND('',#7940,.T.);
#7940 = EDGE_LOOP('',(#7941,#7942,#7965,#7993));
#7941 = ORIENTED_EDGE('',*,*,#7888,.T.);
#7942 = ORIENTED_EDGE('',*,*,#7943,.T.);
#7943 = EDGE_CURVE('',#7866,#7944,#7946,.T.);
#7944 = VERTEX_POINT('',#7945);
#7945 = CARTESIAN_POINT('',(-1.792,-4.776,8.2));
#7946 = SURFACE_CURVE('',#7947,(#7951,#7958),.PCURVE_S1.);
#7947 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7948,#7949,#7950),
#7948 = CARTESIAN_POINT('',(-1.99,-4.841,8.2));
#7949 = CARTESIAN_POINT('',(-1.9,-4.788,8.2));
#7950 = CARTESIAN_POINT('',(-1.792,-4.776,8.2));
#7951 = PCURVE('',#7904,#7952);
#7952 = DEFINITIONAL_REPRESENTATION('',(#7953),#7957);
#7953 = LINE('',#7954,#7955);
#7954 = CARTESIAN_POINT('',(0.,-0.2));
#7955 = VECTOR('',#7956,1.);
#7956 = DIRECTION('',(1.,0.));
#7957 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7958 = PCURVE('',#7097,#7959);
#7959 = DEFINITIONAL_REPRESENTATION('',(#7960),#7964);
#7960 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7961,#7962,#7963),
#7961 = CARTESIAN_POINT('',(0.651314335189,-0.775903719386));
#7962 = CARTESIAN_POINT('',(0.704314335189,-0.685903719386));
#7963 = CARTESIAN_POINT('',(0.716314335189,-0.577903719386));
#7964 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7965 = ORIENTED_EDGE('',*,*,#7966,.F.);
#7966 = EDGE_CURVE('',#7967,#7944,#7969,.T.);
#7967 = VERTEX_POINT('',#7968);
#7968 = CARTESIAN_POINT('',(-1.792,-4.776,8.));
#7969 = SURFACE_CURVE('',#7970,(#7974,#7981),.PCURVE_S1.);
#7970 = LINE('',#7971,#7972);
#7971 = CARTESIAN_POINT('',(-1.792,-4.776,8.));
#7972 = VECTOR('',#7973,1.);
#7973 = DIRECTION('',(0.,0.,1.));
#7974 = PCURVE('',#7904,#7975);
#7975 = DEFINITIONAL_REPRESENTATION('',(#7976),#7980);
#7976 = LINE('',#7977,#7978);
#7977 = CARTESIAN_POINT('',(1.,0.));
#7978 = VECTOR('',#7979,1.);
#7979 = DIRECTION('',(0.,-1.));
#7980 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7981 = PCURVE('',#7982,#7987);
#7982 = PLANE('',#7983);
#7983 = AXIS2_PLACEMENT_3D('',#7984,#7985,#7986);
#7984 = CARTESIAN_POINT('',(-1.792,-4.776,8.));
#7985 = DIRECTION('',(1.,-2.2E-16,0.));
#7986 = DIRECTION('',(-2.2E-16,-1.,0.));
#7987 = DEFINITIONAL_REPRESENTATION('',(#7988),#7992);
#7988 = LINE('',#7989,#7990);
#7989 = CARTESIAN_POINT('',(0.,0.));
#7990 = VECTOR('',#7991,1.);
#7991 = DIRECTION('',(0.,-1.));
#7992 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#7993 = ORIENTED_EDGE('',*,*,#7994,.F.);
#7994 = EDGE_CURVE('',#7889,#7967,#7995,.T.);
#7995 = SURFACE_CURVE('',#7996,(#8000,#8007),.PCURVE_S1.);
#7996 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#7997,#7998,#7999),
#7997 = CARTESIAN_POINT('',(-1.99,-4.841,8.));
#7998 = CARTESIAN_POINT('',(-1.9,-4.788,8.));
#7999 = CARTESIAN_POINT('',(-1.792,-4.776,8.));
#8000 = PCURVE('',#7904,#8001);
#8001 = DEFINITIONAL_REPRESENTATION('',(#8002),#8006);
#8002 = LINE('',#8003,#8004);
#8003 = CARTESIAN_POINT('',(0.,0.));
#8004 = VECTOR('',#8005,1.);
#8005 = DIRECTION('',(1.,0.));
#8006 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8007 = PCURVE('',#7153,#8008);
#8008 = DEFINITIONAL_REPRESENTATION('',(#8009),#8013);
#8009 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8010,#8011,#8012),
#8010 = CARTESIAN_POINT('',(0.651314335189,-0.775903719386));
#8011 = CARTESIAN_POINT('',(0.704314335189,-0.685903719386));
#8012 = CARTESIAN_POINT('',(0.716314335189,-0.577903719386));
#8013 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8014 = ADVANCED_FACE('',(#8015),#7982,.T.);
#8015 = FACE_BOUND('',#8016,.T.);
#8016 = EDGE_LOOP('',(#8017,#8018,#8041,#8071));
#8017 = ORIENTED_EDGE('',*,*,#7966,.T.);
#8018 = ORIENTED_EDGE('',*,*,#8019,.T.);
#8019 = EDGE_CURVE('',#7944,#8020,#8022,.T.);
#8020 = VERTEX_POINT('',#8021);
#8021 = CARTESIAN_POINT('',(-1.792,-5.038,8.2));
#8022 = SURFACE_CURVE('',#8023,(#8027,#8034),.PCURVE_S1.);
#8023 = LINE('',#8024,#8025);
#8024 = CARTESIAN_POINT('',(-1.792,-4.776,8.2));
#8025 = VECTOR('',#8026,1.);
#8026 = DIRECTION('',(0.,-1.,0.));
#8027 = PCURVE('',#7982,#8028);
#8028 = DEFINITIONAL_REPRESENTATION('',(#8029),#8033);
#8029 = LINE('',#8030,#8031);
#8030 = CARTESIAN_POINT('',(0.,-0.2));
#8031 = VECTOR('',#8032,1.);
#8032 = DIRECTION('',(1.,-0.));
#8033 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8034 = PCURVE('',#7097,#8035);
#8035 = DEFINITIONAL_REPRESENTATION('',(#8036),#8040);
#8036 = LINE('',#8037,#8038);
#8037 = CARTESIAN_POINT('',(0.716314335189,-0.577903719386));
#8038 = VECTOR('',#8039,1.);
#8039 = DIRECTION('',(-1.,0.));
#8040 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8041 = ORIENTED_EDGE('',*,*,#8042,.F.);
#8042 = EDGE_CURVE('',#8043,#8020,#8045,.T.);
#8043 = VERTEX_POINT('',#8044);
#8044 = CARTESIAN_POINT('',(-1.792,-5.038,8.));
#8045 = SURFACE_CURVE('',#8046,(#8050,#8057),.PCURVE_S1.);
#8046 = LINE('',#8047,#8048);
#8047 = CARTESIAN_POINT('',(-1.792,-5.038,8.));
#8048 = VECTOR('',#8049,1.);
#8049 = DIRECTION('',(0.,0.,1.));
#8050 = PCURVE('',#7982,#8051);
#8051 = DEFINITIONAL_REPRESENTATION('',(#8052),#8056);
#8052 = LINE('',#8053,#8054);
#8053 = CARTESIAN_POINT('',(0.262,0.));
#8054 = VECTOR('',#8055,1.);
#8055 = DIRECTION('',(0.,-1.));
#8056 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8057 = PCURVE('',#8058,#8065);
#8058 = SURFACE_OF_LINEAR_EXTRUSION('',#8059,#8063);
#8059 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8060,#8061,#8062),
#8060 = CARTESIAN_POINT('',(-1.792,-5.038,8.));
#8061 = CARTESIAN_POINT('',(-1.973,-5.081,8.));
#8062 = CARTESIAN_POINT('',(-1.984,-5.391,8.));
#8063 = VECTOR('',#8064,1.);
#8064 = DIRECTION('',(-0.,-0.,-1.));
#8065 = DEFINITIONAL_REPRESENTATION('',(#8066),#8070);
#8066 = LINE('',#8067,#8068);
#8067 = CARTESIAN_POINT('',(0.,0.));
#8068 = VECTOR('',#8069,1.);
#8069 = DIRECTION('',(0.,-1.));
#8070 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8071 = ORIENTED_EDGE('',*,*,#8072,.F.);
#8072 = EDGE_CURVE('',#7967,#8043,#8073,.T.);
#8073 = SURFACE_CURVE('',#8074,(#8078,#8085),.PCURVE_S1.);
#8074 = LINE('',#8075,#8076);
#8075 = CARTESIAN_POINT('',(-1.792,-4.776,8.));
#8076 = VECTOR('',#8077,1.);
#8077 = DIRECTION('',(0.,-1.,0.));
#8078 = PCURVE('',#7982,#8079);
#8079 = DEFINITIONAL_REPRESENTATION('',(#8080),#8084);
#8080 = LINE('',#8081,#8082);
#8081 = CARTESIAN_POINT('',(0.,0.));
#8082 = VECTOR('',#8083,1.);
#8083 = DIRECTION('',(1.,-0.));
#8084 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8085 = PCURVE('',#7153,#8086);
#8086 = DEFINITIONAL_REPRESENTATION('',(#8087),#8091);
#8087 = LINE('',#8088,#8089);
#8088 = CARTESIAN_POINT('',(0.716314335189,-0.577903719386));
#8089 = VECTOR('',#8090,1.);
#8090 = DIRECTION('',(-1.,0.));
#8091 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8092 = ADVANCED_FACE('',(#8093),#8058,.T.);
#8093 = FACE_BOUND('',#8094,.T.);
#8094 = EDGE_LOOP('',(#8095,#8096,#8119,#8149));
#8095 = ORIENTED_EDGE('',*,*,#8042,.T.);
#8096 = ORIENTED_EDGE('',*,*,#8097,.T.);
#8097 = EDGE_CURVE('',#8020,#8098,#8100,.T.);
#8098 = VERTEX_POINT('',#8099);
#8099 = CARTESIAN_POINT('',(-1.984,-5.391,8.2));
#8100 = SURFACE_CURVE('',#8101,(#8105,#8112),.PCURVE_S1.);
#8101 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8102,#8103,#8104),
#8102 = CARTESIAN_POINT('',(-1.792,-5.038,8.2));
#8103 = CARTESIAN_POINT('',(-1.973,-5.081,8.2));
#8104 = CARTESIAN_POINT('',(-1.984,-5.391,8.2));
#8105 = PCURVE('',#8058,#8106);
#8106 = DEFINITIONAL_REPRESENTATION('',(#8107),#8111);
#8107 = LINE('',#8108,#8109);
#8108 = CARTESIAN_POINT('',(0.,-0.2));
#8109 = VECTOR('',#8110,1.);
#8110 = DIRECTION('',(1.,0.));
#8111 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8112 = PCURVE('',#7097,#8113);
#8113 = DEFINITIONAL_REPRESENTATION('',(#8114),#8118);
#8114 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8115,#8116,#8117),
#8115 = CARTESIAN_POINT('',(0.454314335189,-0.577903719386));
#8116 = CARTESIAN_POINT('',(0.411314335189,-0.758903719386));
#8117 = CARTESIAN_POINT('',(0.101314335189,-0.769903719386));
#8118 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8119 = ORIENTED_EDGE('',*,*,#8120,.F.);
#8120 = EDGE_CURVE('',#8121,#8098,#8123,.T.);
#8121 = VERTEX_POINT('',#8122);
#8122 = CARTESIAN_POINT('',(-1.984,-5.391,8.));
#8123 = SURFACE_CURVE('',#8124,(#8128,#8135),.PCURVE_S1.);
#8124 = LINE('',#8125,#8126);
#8125 = CARTESIAN_POINT('',(-1.984,-5.391,8.));
#8126 = VECTOR('',#8127,1.);
#8127 = DIRECTION('',(0.,0.,1.));
#8128 = PCURVE('',#8058,#8129);
#8129 = DEFINITIONAL_REPRESENTATION('',(#8130),#8134);
#8130 = LINE('',#8131,#8132);
#8131 = CARTESIAN_POINT('',(1.,0.));
#8132 = VECTOR('',#8133,1.);
#8133 = DIRECTION('',(0.,-1.));
#8134 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8135 = PCURVE('',#8136,#8143);
#8136 = SURFACE_OF_LINEAR_EXTRUSION('',#8137,#8141);
#8137 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8138,#8139,#8140),
#8138 = CARTESIAN_POINT('',(-1.984,-5.391,8.));
#8139 = CARTESIAN_POINT('',(-1.984,-5.409,8.));
#8140 = CARTESIAN_POINT('',(-1.984,-5.428,8.));
#8141 = VECTOR('',#8142,1.);
#8142 = DIRECTION('',(-0.,-0.,-1.));
#8143 = DEFINITIONAL_REPRESENTATION('',(#8144),#8148);
#8144 = LINE('',#8145,#8146);
#8145 = CARTESIAN_POINT('',(0.,0.));
#8146 = VECTOR('',#8147,1.);
#8147 = DIRECTION('',(0.,-1.));
#8148 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8149 = ORIENTED_EDGE('',*,*,#8150,.F.);
#8150 = EDGE_CURVE('',#8043,#8121,#8151,.T.);
#8151 = SURFACE_CURVE('',#8152,(#8156,#8163),.PCURVE_S1.);
#8152 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8153,#8154,#8155),
#8153 = CARTESIAN_POINT('',(-1.792,-5.038,8.));
#8154 = CARTESIAN_POINT('',(-1.973,-5.081,8.));
#8155 = CARTESIAN_POINT('',(-1.984,-5.391,8.));
#8156 = PCURVE('',#8058,#8157);
#8157 = DEFINITIONAL_REPRESENTATION('',(#8158),#8162);
#8158 = LINE('',#8159,#8160);
#8159 = CARTESIAN_POINT('',(0.,0.));
#8160 = VECTOR('',#8161,1.);
#8161 = DIRECTION('',(1.,0.));
#8162 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8163 = PCURVE('',#7153,#8164);
#8164 = DEFINITIONAL_REPRESENTATION('',(#8165),#8169);
#8165 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8166,#8167,#8168),
#8166 = CARTESIAN_POINT('',(0.454314335189,-0.577903719386));
#8167 = CARTESIAN_POINT('',(0.411314335189,-0.758903719386));
#8168 = CARTESIAN_POINT('',(0.101314335189,-0.769903719386));
#8169 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8170 = ADVANCED_FACE('',(#8171),#8136,.T.);
#8171 = FACE_BOUND('',#8172,.T.);
#8172 = EDGE_LOOP('',(#8173,#8174,#8197,#8227));
#8173 = ORIENTED_EDGE('',*,*,#8120,.T.);
#8174 = ORIENTED_EDGE('',*,*,#8175,.T.);
#8175 = EDGE_CURVE('',#8098,#8176,#8178,.T.);
#8176 = VERTEX_POINT('',#8177);
#8177 = CARTESIAN_POINT('',(-1.984,-5.428,8.2));
#8178 = SURFACE_CURVE('',#8179,(#8183,#8190),.PCURVE_S1.);
#8179 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8180,#8181,#8182),
#8180 = CARTESIAN_POINT('',(-1.984,-5.391,8.2));
#8181 = CARTESIAN_POINT('',(-1.984,-5.409,8.2));
#8182 = CARTESIAN_POINT('',(-1.984,-5.428,8.2));
#8183 = PCURVE('',#8136,#8184);
#8184 = DEFINITIONAL_REPRESENTATION('',(#8185),#8189);
#8185 = LINE('',#8186,#8187);
#8186 = CARTESIAN_POINT('',(0.,-0.2));
#8187 = VECTOR('',#8188,1.);
#8188 = DIRECTION('',(1.,0.));
#8189 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8190 = PCURVE('',#7097,#8191);
#8191 = DEFINITIONAL_REPRESENTATION('',(#8192),#8196);
#8192 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8193,#8194,#8195),
#8193 = CARTESIAN_POINT('',(0.101314335189,-0.769903719386));
#8194 = CARTESIAN_POINT('',(8.331433518944E-02,-0.769903719386));
#8195 = CARTESIAN_POINT('',(6.431433518944E-02,-0.769903719386));
#8196 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8197 = ORIENTED_EDGE('',*,*,#8198,.F.);
#8198 = EDGE_CURVE('',#8199,#8176,#8201,.T.);
#8199 = VERTEX_POINT('',#8200);
#8200 = CARTESIAN_POINT('',(-1.984,-5.428,8.));
#8201 = SURFACE_CURVE('',#8202,(#8206,#8213),.PCURVE_S1.);
#8202 = LINE('',#8203,#8204);
#8203 = CARTESIAN_POINT('',(-1.984,-5.428,8.));
#8204 = VECTOR('',#8205,1.);
#8205 = DIRECTION('',(0.,0.,1.));
#8206 = PCURVE('',#8136,#8207);
#8207 = DEFINITIONAL_REPRESENTATION('',(#8208),#8212);
#8208 = LINE('',#8209,#8210);
#8209 = CARTESIAN_POINT('',(1.,0.));
#8210 = VECTOR('',#8211,1.);
#8211 = DIRECTION('',(0.,-1.));
#8212 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8213 = PCURVE('',#8214,#8221);
#8214 = SURFACE_OF_LINEAR_EXTRUSION('',#8215,#8219);
#8215 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8216,#8217,#8218),
#8216 = CARTESIAN_POINT('',(-1.984,-5.428,8.));
#8217 = CARTESIAN_POINT('',(-1.984,-5.753,8.));
#8218 = CARTESIAN_POINT('',(-1.741,-5.836,8.));
#8219 = VECTOR('',#8220,1.);
#8220 = DIRECTION('',(-0.,-0.,-1.));
#8221 = DEFINITIONAL_REPRESENTATION('',(#8222),#8226);
#8222 = LINE('',#8223,#8224);
#8223 = CARTESIAN_POINT('',(0.,0.));
#8224 = VECTOR('',#8225,1.);
#8225 = DIRECTION('',(0.,-1.));
#8226 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8227 = ORIENTED_EDGE('',*,*,#8228,.F.);
#8228 = EDGE_CURVE('',#8121,#8199,#8229,.T.);
#8229 = SURFACE_CURVE('',#8230,(#8234,#8241),.PCURVE_S1.);
#8230 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8231,#8232,#8233),
#8231 = CARTESIAN_POINT('',(-1.984,-5.391,8.));
#8232 = CARTESIAN_POINT('',(-1.984,-5.409,8.));
#8233 = CARTESIAN_POINT('',(-1.984,-5.428,8.));
#8234 = PCURVE('',#8136,#8235);
#8235 = DEFINITIONAL_REPRESENTATION('',(#8236),#8240);
#8236 = LINE('',#8237,#8238);
#8237 = CARTESIAN_POINT('',(0.,0.));
#8238 = VECTOR('',#8239,1.);
#8239 = DIRECTION('',(1.,0.));
#8240 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8241 = PCURVE('',#7153,#8242);
#8242 = DEFINITIONAL_REPRESENTATION('',(#8243),#8247);
#8243 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8244,#8245,#8246),
#8244 = CARTESIAN_POINT('',(0.101314335189,-0.769903719386));
#8245 = CARTESIAN_POINT('',(8.331433518944E-02,-0.769903719386));
#8246 = CARTESIAN_POINT('',(6.431433518944E-02,-0.769903719386));
#8247 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8248 = ADVANCED_FACE('',(#8249),#8214,.T.);
#8249 = FACE_BOUND('',#8250,.T.);
#8250 = EDGE_LOOP('',(#8251,#8252,#8275,#8305));
#8251 = ORIENTED_EDGE('',*,*,#8198,.T.);
#8252 = ORIENTED_EDGE('',*,*,#8253,.T.);
#8253 = EDGE_CURVE('',#8176,#8254,#8256,.T.);
#8254 = VERTEX_POINT('',#8255);
#8255 = CARTESIAN_POINT('',(-1.741,-5.836,8.2));
#8256 = SURFACE_CURVE('',#8257,(#8261,#8268),.PCURVE_S1.);
#8257 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8258,#8259,#8260),
#8258 = CARTESIAN_POINT('',(-1.984,-5.428,8.2));
#8259 = CARTESIAN_POINT('',(-1.984,-5.753,8.2));
#8260 = CARTESIAN_POINT('',(-1.741,-5.836,8.2));
#8261 = PCURVE('',#8214,#8262);
#8262 = DEFINITIONAL_REPRESENTATION('',(#8263),#8267);
#8263 = LINE('',#8264,#8265);
#8264 = CARTESIAN_POINT('',(0.,-0.2));
#8265 = VECTOR('',#8266,1.);
#8266 = DIRECTION('',(1.,0.));
#8267 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8268 = PCURVE('',#7097,#8269);
#8269 = DEFINITIONAL_REPRESENTATION('',(#8270),#8274);
#8270 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8271,#8272,#8273),
#8271 = CARTESIAN_POINT('',(6.431433518944E-02,-0.769903719386));
#8272 = CARTESIAN_POINT('',(-0.260685664811,-0.769903719386));
#8273 = CARTESIAN_POINT('',(-0.343685664811,-0.526903719386));
#8274 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8275 = ORIENTED_EDGE('',*,*,#8276,.F.);
#8276 = EDGE_CURVE('',#8277,#8254,#8279,.T.);
#8277 = VERTEX_POINT('',#8278);
#8278 = CARTESIAN_POINT('',(-1.741,-5.836,8.));
#8279 = SURFACE_CURVE('',#8280,(#8284,#8291),.PCURVE_S1.);
#8280 = LINE('',#8281,#8282);
#8281 = CARTESIAN_POINT('',(-1.741,-5.836,8.));
#8282 = VECTOR('',#8283,1.);
#8283 = DIRECTION('',(0.,0.,1.));
#8284 = PCURVE('',#8214,#8285);
#8285 = DEFINITIONAL_REPRESENTATION('',(#8286),#8290);
#8286 = LINE('',#8287,#8288);
#8287 = CARTESIAN_POINT('',(1.,0.));
#8288 = VECTOR('',#8289,1.);
#8289 = DIRECTION('',(0.,-1.));
#8290 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8291 = PCURVE('',#8292,#8299);
#8292 = SURFACE_OF_LINEAR_EXTRUSION('',#8293,#8297);
#8293 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8294,#8295,#8296),
#8294 = CARTESIAN_POINT('',(-1.741,-5.836,8.));
#8295 = CARTESIAN_POINT('',(-1.626,-5.876,8.));
#8296 = CARTESIAN_POINT('',(-1.434,-5.876,8.));
#8297 = VECTOR('',#8298,1.);
#8298 = DIRECTION('',(-0.,-0.,-1.));
#8299 = DEFINITIONAL_REPRESENTATION('',(#8300),#8304);
#8300 = LINE('',#8301,#8302);
#8301 = CARTESIAN_POINT('',(0.,0.));
#8302 = VECTOR('',#8303,1.);
#8303 = DIRECTION('',(0.,-1.));
#8304 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8305 = ORIENTED_EDGE('',*,*,#8306,.F.);
#8306 = EDGE_CURVE('',#8199,#8277,#8307,.T.);
#8307 = SURFACE_CURVE('',#8308,(#8312,#8319),.PCURVE_S1.);
#8308 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8309,#8310,#8311),
#8309 = CARTESIAN_POINT('',(-1.984,-5.428,8.));
#8310 = CARTESIAN_POINT('',(-1.984,-5.753,8.));
#8311 = CARTESIAN_POINT('',(-1.741,-5.836,8.));
#8312 = PCURVE('',#8214,#8313);
#8313 = DEFINITIONAL_REPRESENTATION('',(#8314),#8318);
#8314 = LINE('',#8315,#8316);
#8315 = CARTESIAN_POINT('',(0.,0.));
#8316 = VECTOR('',#8317,1.);
#8317 = DIRECTION('',(1.,0.));
#8318 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8319 = PCURVE('',#7153,#8320);
#8320 = DEFINITIONAL_REPRESENTATION('',(#8321),#8325);
#8321 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8322,#8323,#8324),
#8322 = CARTESIAN_POINT('',(6.431433518944E-02,-0.769903719386));
#8323 = CARTESIAN_POINT('',(-0.260685664811,-0.769903719386));
#8324 = CARTESIAN_POINT('',(-0.343685664811,-0.526903719386));
#8325 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8326 = ADVANCED_FACE('',(#8327),#8292,.T.);
#8327 = FACE_BOUND('',#8328,.T.);
#8328 = EDGE_LOOP('',(#8329,#8330,#8353,#8381));
#8329 = ORIENTED_EDGE('',*,*,#8276,.T.);
#8330 = ORIENTED_EDGE('',*,*,#8331,.T.);
#8331 = EDGE_CURVE('',#8254,#8332,#8334,.T.);
#8332 = VERTEX_POINT('',#8333);
#8333 = CARTESIAN_POINT('',(-1.434,-5.876,8.2));
#8334 = SURFACE_CURVE('',#8335,(#8339,#8346),.PCURVE_S1.);
#8335 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8336,#8337,#8338),
#8336 = CARTESIAN_POINT('',(-1.741,-5.836,8.2));
#8337 = CARTESIAN_POINT('',(-1.626,-5.876,8.2));
#8338 = CARTESIAN_POINT('',(-1.434,-5.876,8.2));
#8339 = PCURVE('',#8292,#8340);
#8340 = DEFINITIONAL_REPRESENTATION('',(#8341),#8345);
#8341 = LINE('',#8342,#8343);
#8342 = CARTESIAN_POINT('',(0.,-0.2));
#8343 = VECTOR('',#8344,1.);
#8344 = DIRECTION('',(1.,0.));
#8345 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8346 = PCURVE('',#7097,#8347);
#8347 = DEFINITIONAL_REPRESENTATION('',(#8348),#8352);
#8348 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8349,#8350,#8351),
#8349 = CARTESIAN_POINT('',(-0.343685664811,-0.526903719386));
#8350 = CARTESIAN_POINT('',(-0.383685664811,-0.411903719386));
#8351 = CARTESIAN_POINT('',(-0.383685664811,-0.219903719386));
#8352 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8353 = ORIENTED_EDGE('',*,*,#8354,.F.);
#8354 = EDGE_CURVE('',#8355,#8332,#8357,.T.);
#8355 = VERTEX_POINT('',#8356);
#8356 = CARTESIAN_POINT('',(-1.434,-5.876,8.));
#8357 = SURFACE_CURVE('',#8358,(#8362,#8369),.PCURVE_S1.);
#8358 = LINE('',#8359,#8360);
#8359 = CARTESIAN_POINT('',(-1.434,-5.876,8.));
#8360 = VECTOR('',#8361,1.);
#8361 = DIRECTION('',(0.,0.,1.));
#8362 = PCURVE('',#8292,#8363);
#8363 = DEFINITIONAL_REPRESENTATION('',(#8364),#8368);
#8364 = LINE('',#8365,#8366);
#8365 = CARTESIAN_POINT('',(1.,0.));
#8366 = VECTOR('',#8367,1.);
#8367 = DIRECTION('',(0.,-1.));
#8368 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8369 = PCURVE('',#8370,#8375);
#8370 = PLANE('',#8371);
#8371 = AXIS2_PLACEMENT_3D('',#8372,#8373,#8374);
#8372 = CARTESIAN_POINT('',(-1.434,-5.876,8.));
#8373 = DIRECTION('',(2.2E-16,1.,0.));
#8374 = DIRECTION('',(1.,-2.2E-16,0.));
#8375 = DEFINITIONAL_REPRESENTATION('',(#8376),#8380);
#8376 = LINE('',#8377,#8378);
#8377 = CARTESIAN_POINT('',(1.33E-15,0.));
#8378 = VECTOR('',#8379,1.);
#8379 = DIRECTION('',(0.,-1.));
#8380 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8381 = ORIENTED_EDGE('',*,*,#8382,.F.);
#8382 = EDGE_CURVE('',#8277,#8355,#8383,.T.);
#8383 = SURFACE_CURVE('',#8384,(#8388,#8395),.PCURVE_S1.);
#8384 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8385,#8386,#8387),
#8385 = CARTESIAN_POINT('',(-1.741,-5.836,8.));
#8386 = CARTESIAN_POINT('',(-1.626,-5.876,8.));
#8387 = CARTESIAN_POINT('',(-1.434,-5.876,8.));
#8388 = PCURVE('',#8292,#8389);
#8389 = DEFINITIONAL_REPRESENTATION('',(#8390),#8394);
#8390 = LINE('',#8391,#8392);
#8391 = CARTESIAN_POINT('',(0.,0.));
#8392 = VECTOR('',#8393,1.);
#8393 = DIRECTION('',(1.,0.));
#8394 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8395 = PCURVE('',#7153,#8396);
#8396 = DEFINITIONAL_REPRESENTATION('',(#8397),#8401);
#8397 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8398,#8399,#8400),
#8398 = CARTESIAN_POINT('',(-0.343685664811,-0.526903719386));
#8399 = CARTESIAN_POINT('',(-0.383685664811,-0.411903719386));
#8400 = CARTESIAN_POINT('',(-0.383685664811,-0.219903719386));
#8401 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8402 = ADVANCED_FACE('',(#8403),#8370,.T.);
#8403 = FACE_BOUND('',#8404,.T.);
#8404 = EDGE_LOOP('',(#8405,#8406,#8429,#8459));
#8405 = ORIENTED_EDGE('',*,*,#8354,.T.);
#8406 = ORIENTED_EDGE('',*,*,#8407,.T.);
#8407 = EDGE_CURVE('',#8332,#8408,#8410,.T.);
#8408 = VERTEX_POINT('',#8409);
#8409 = CARTESIAN_POINT('',(-1.357,-5.876,8.2));
#8410 = SURFACE_CURVE('',#8411,(#8415,#8422),.PCURVE_S1.);
#8411 = LINE('',#8412,#8413);
#8412 = CARTESIAN_POINT('',(-1.434,-5.876,8.2));
#8413 = VECTOR('',#8414,1.);
#8414 = DIRECTION('',(1.,0.,0.));
#8415 = PCURVE('',#8370,#8416);
#8416 = DEFINITIONAL_REPRESENTATION('',(#8417),#8421);
#8417 = LINE('',#8418,#8419);
#8418 = CARTESIAN_POINT('',(0.,-0.2));
#8419 = VECTOR('',#8420,1.);
#8420 = DIRECTION('',(1.,0.));
#8421 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8422 = PCURVE('',#7097,#8423);
#8423 = DEFINITIONAL_REPRESENTATION('',(#8424),#8428);
#8424 = LINE('',#8425,#8426);
#8425 = CARTESIAN_POINT('',(-0.383685664811,-0.219903719386));
#8426 = VECTOR('',#8427,1.);
#8427 = DIRECTION('',(0.,1.));
#8428 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8429 = ORIENTED_EDGE('',*,*,#8430,.F.);
#8430 = EDGE_CURVE('',#8431,#8408,#8433,.T.);
#8431 = VERTEX_POINT('',#8432);
#8432 = CARTESIAN_POINT('',(-1.357,-5.876,8.));
#8433 = SURFACE_CURVE('',#8434,(#8438,#8445),.PCURVE_S1.);
#8434 = LINE('',#8435,#8436);
#8435 = CARTESIAN_POINT('',(-1.357,-5.876,8.));
#8436 = VECTOR('',#8437,1.);
#8437 = DIRECTION('',(0.,0.,1.));
#8438 = PCURVE('',#8370,#8439);
#8439 = DEFINITIONAL_REPRESENTATION('',(#8440),#8444);
#8440 = LINE('',#8441,#8442);
#8441 = CARTESIAN_POINT('',(7.7E-02,0.));
#8442 = VECTOR('',#8443,1.);
#8443 = DIRECTION('',(0.,-1.));
#8444 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8445 = PCURVE('',#8446,#8453);
#8446 = SURFACE_OF_LINEAR_EXTRUSION('',#8447,#8451);
#8447 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8448,#8449,#8450),
#8448 = CARTESIAN_POINT('',(-1.357,-5.876,8.));
#8449 = CARTESIAN_POINT('',(-1.625,-5.695,8.));
#8450 = CARTESIAN_POINT('',(-1.657,-5.47,8.));
#8451 = VECTOR('',#8452,1.);
#8452 = DIRECTION('',(-0.,-0.,-1.));
#8453 = DEFINITIONAL_REPRESENTATION('',(#8454),#8458);
#8454 = LINE('',#8455,#8456);
#8455 = CARTESIAN_POINT('',(0.,0.));
#8456 = VECTOR('',#8457,1.);
#8457 = DIRECTION('',(0.,-1.));
#8458 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
PARAMETRIC_REPRESENTATION_CONTEXT() REPRESENTATION_CONTEXT('2D SPACE',''
#8459 = ORIENTED_EDGE('',*,*,#8460,.F.);
#8460 = EDGE_CURVE('',#8355,#8431,#8461,.T.);
#8461 = SURFACE_CURVE('',#8462,(#8466,#8473),.PCURVE_S1.);
#8462 = LINE('',#8463,#8464);
#8463 = CARTESIAN_POINT('',(-1.434,-5.876,8.));
#8464 = VECTOR('',#8465,1.);
#8465 = DIRECTION('',(1.,0.,0.));
#8466 = PCURVE('',#8370,#8467);
#8467 = DEFINITIONAL_REPRESENTATION('',(#8468),#8472);
#8468 = LINE('',#8469,#8470);
#8469 = CARTESIAN_POINT('',(0.,0.));
#8470 = VECTOR('',#8471,1.);
#8471 = DIRECTION('',(1.,0.));
#8472 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8473 = PCURVE('',#7153,#8474);
#8474 = DEFINITIONAL_REPRESENTATION('',(#8475),#8479);
#8475 = LINE('',#8476,#8477);
#8476 = CARTESIAN_POINT('',(-0.383685664811,-0.219903719386));
#8477 = VECTOR('',#8478,1.);
#8478 = DIRECTION('',(0.,1.));
#8479 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8480 = ADVANCED_FACE('',(#8481),#8446,.T.);
#8481 = FACE_BOUND('',#8482,.T.);
#8482 = EDGE_LOOP('',(#8483,#8484,#8507,#8530));
#8483 = ORIENTED_EDGE('',*,*,#8430,.T.);
#8484 = ORIENTED_EDGE('',*,*,#8485,.T.);
#8485 = EDGE_CURVE('',#8408,#8486,#8488,.T.);
#8486 = VERTEX_POINT('',#8487);
#8487 = CARTESIAN_POINT('',(-1.657,-5.47,8.2));
#8488 = SURFACE_CURVE('',#8489,(#8493,#8500),.PCURVE_S1.);
#8489 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8490,#8491,#8492),
#8490 = CARTESIAN_POINT('',(-1.357,-5.876,8.2));
#8491 = CARTESIAN_POINT('',(-1.625,-5.695,8.2));
#8492 = CARTESIAN_POINT('',(-1.657,-5.47,8.2));
#8493 = PCURVE('',#8446,#8494);
#8494 = DEFINITIONAL_REPRESENTATION('',(#8495),#8499);
#8495 = LINE('',#8496,#8497);
#8496 = CARTESIAN_POINT('',(0.,-0.2));
#8497 = VECTOR('',#8498,1.);
#8498 = DIRECTION('',(1.,0.));
#8499 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8500 = PCURVE('',#7097,#8501);
#8501 = DEFINITIONAL_REPRESENTATION('',(#8502),#8506);
#8502 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8503,#8504,#8505),
#8503 = CARTESIAN_POINT('',(-0.383685664811,-0.142903719386));
#8504 = CARTESIAN_POINT('',(-0.202685664811,-0.410903719386));
#8505 = CARTESIAN_POINT('',(2.231433518944E-02,-0.442903719386));
#8506 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8507 = ORIENTED_EDGE('',*,*,#8508,.F.);
#8508 = EDGE_CURVE('',#8509,#8486,#8511,.T.);
#8509 = VERTEX_POINT('',#8510);
#8510 = CARTESIAN_POINT('',(-1.657,-5.47,8.));
#8511 = SURFACE_CURVE('',#8512,(#8516,#8523),.PCURVE_S1.);
#8512 = LINE('',#8513,#8514);
#8513 = CARTESIAN_POINT('',(-1.657,-5.47,8.));
#8514 = VECTOR('',#8515,1.);
#8515 = DIRECTION('',(0.,0.,1.));
#8516 = PCURVE('',#8446,#8517);
#8517 = DEFINITIONAL_REPRESENTATION('',(#8518),#8522);
#8518 = LINE('',#8519,#8520);
#8519 = CARTESIAN_POINT('',(1.,0.));
#8520 = VECTOR('',#8521,1.);
#8521 = DIRECTION('',(0.,-1.));
#8522 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8523 = PCURVE('',#7067,#8524);
#8524 = DEFINITIONAL_REPRESENTATION('',(#8525),#8529);
#8525 = LINE('',#8526,#8527);
#8526 = CARTESIAN_POINT('',(0.,0.));
#8527 = VECTOR('',#8528,1.);
#8528 = DIRECTION('',(0.,-1.));
#8529 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8530 = ORIENTED_EDGE('',*,*,#8531,.F.);
#8531 = EDGE_CURVE('',#8431,#8509,#8532,.T.);
#8532 = SURFACE_CURVE('',#8533,(#8537,#8544),.PCURVE_S1.);
#8533 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8534,#8535,#8536),
#8534 = CARTESIAN_POINT('',(-1.357,-5.876,8.));
#8535 = CARTESIAN_POINT('',(-1.625,-5.695,8.));
#8536 = CARTESIAN_POINT('',(-1.657,-5.47,8.));
#8537 = PCURVE('',#8446,#8538);
#8538 = DEFINITIONAL_REPRESENTATION('',(#8539),#8543);
#8539 = LINE('',#8540,#8541);
#8540 = CARTESIAN_POINT('',(0.,0.));
#8541 = VECTOR('',#8542,1.);
#8542 = DIRECTION('',(1.,0.));
#8543 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8544 = PCURVE('',#7153,#8545);
#8545 = DEFINITIONAL_REPRESENTATION('',(#8546),#8550);
#8546 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8547,#8548,#8549),
#8547 = CARTESIAN_POINT('',(-0.383685664811,-0.142903719386));
#8548 = CARTESIAN_POINT('',(-0.202685664811,-0.410903719386));
#8549 = CARTESIAN_POINT('',(2.231433518944E-02,-0.442903719386));
#8550 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8551 = ADVANCED_FACE('',(#8552),#7067,.T.);
#8552 = FACE_BOUND('',#8553,.T.);
#8553 = EDGE_LOOP('',(#8554,#8555,#8576,#8577));
#8554 = ORIENTED_EDGE('',*,*,#8508,.T.);
#8555 = ORIENTED_EDGE('',*,*,#8556,.T.);
#8556 = EDGE_CURVE('',#8486,#7045,#8557,.T.);
#8557 = SURFACE_CURVE('',#8558,(#8562,#8569),.PCURVE_S1.);
#8558 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8559,#8560,#8561),
#8559 = CARTESIAN_POINT('',(-1.657,-5.47,8.2));
#8560 = CARTESIAN_POINT('',(-1.664,-5.431,8.2));
#8561 = CARTESIAN_POINT('',(-1.664,-5.388,8.2));
#8562 = PCURVE('',#7067,#8563);
#8563 = DEFINITIONAL_REPRESENTATION('',(#8564),#8568);
#8564 = LINE('',#8565,#8566);
#8565 = CARTESIAN_POINT('',(0.,-0.2));
#8566 = VECTOR('',#8567,1.);
#8567 = DIRECTION('',(1.,0.));
#8568 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8569 = PCURVE('',#7097,#8570);
#8570 = DEFINITIONAL_REPRESENTATION('',(#8571),#8575);
#8571 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8572,#8573,#8574),
#8572 = CARTESIAN_POINT('',(2.231433518944E-02,-0.442903719386));
#8573 = CARTESIAN_POINT('',(6.131433518944E-02,-0.449903719386));
#8574 = CARTESIAN_POINT('',(0.104314335189,-0.449903719386));
#8575 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8576 = ORIENTED_EDGE('',*,*,#7042,.F.);
#8577 = ORIENTED_EDGE('',*,*,#8578,.F.);
#8578 = EDGE_CURVE('',#8509,#7043,#8579,.T.);
#8579 = SURFACE_CURVE('',#8580,(#8584,#8591),.PCURVE_S1.);
#8580 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8581,#8582,#8583),
#8581 = CARTESIAN_POINT('',(-1.657,-5.47,8.));
#8582 = CARTESIAN_POINT('',(-1.664,-5.431,8.));
#8583 = CARTESIAN_POINT('',(-1.664,-5.388,8.));
#8584 = PCURVE('',#7067,#8585);
#8585 = DEFINITIONAL_REPRESENTATION('',(#8586),#8590);
#8586 = LINE('',#8587,#8588);
#8587 = CARTESIAN_POINT('',(0.,0.));
#8588 = VECTOR('',#8589,1.);
#8589 = DIRECTION('',(1.,0.));
#8590 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8591 = PCURVE('',#7153,#8592);
#8592 = DEFINITIONAL_REPRESENTATION('',(#8593),#8597);
#8593 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8594,#8595,#8596),
#8594 = CARTESIAN_POINT('',(2.231433518944E-02,-0.442903719386));
#8595 = CARTESIAN_POINT('',(6.131433518944E-02,-0.449903719386));
#8596 = CARTESIAN_POINT('',(0.104314335189,-0.449903719386));
#8597 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8598 = ADVANCED_FACE('',(#8599),#8613,.T.);
#8599 = FACE_BOUND('',#8600,.T.);
#8600 = EDGE_LOOP('',(#8601,#8640,#8663,#8693));
#8601 = ORIENTED_EDGE('',*,*,#8602,.T.);
#8602 = EDGE_CURVE('',#8603,#8605,#8607,.T.);
#8603 = VERTEX_POINT('',#8604);
#8604 = CARTESIAN_POINT('',(-0.192,-5.437,8.));
#8605 = VERTEX_POINT('',#8606);
#8606 = CARTESIAN_POINT('',(-0.192,-5.437,8.2));
#8607 = SURFACE_CURVE('',#8608,(#8612,#8626),.PCURVE_S1.);
#8608 = LINE('',#8609,#8610);
#8609 = CARTESIAN_POINT('',(-0.192,-5.437,8.));
#8610 = VECTOR('',#8611,1.);
#8611 = DIRECTION('',(0.,0.,1.));
#8612 = PCURVE('',#8613,#8620);
#8613 = SURFACE_OF_LINEAR_EXTRUSION('',#8614,#8618);
#8614 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8615,#8616,#8617),
#8615 = CARTESIAN_POINT('',(-0.192,-5.437,8.));
#8616 = CARTESIAN_POINT('',(-0.192,-5.166,8.));
#8617 = CARTESIAN_POINT('',(-0.46,-5.052,8.));
#8618 = VECTOR('',#8619,1.);
#8619 = DIRECTION('',(-0.,-0.,-1.));
#8620 = DEFINITIONAL_REPRESENTATION('',(#8621),#8625);
#8621 = LINE('',#8622,#8623);
#8622 = CARTESIAN_POINT('',(0.,0.));
#8623 = VECTOR('',#8624,1.);
#8624 = DIRECTION('',(0.,-1.));
#8625 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8626 = PCURVE('',#8627,#8634);
#8627 = SURFACE_OF_LINEAR_EXTRUSION('',#8628,#8632);
#8628 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8629,#8630,#8631),
#8629 = CARTESIAN_POINT('',(-0.234,-5.624,8.));
#8630 = CARTESIAN_POINT('',(-0.192,-5.538,8.));
#8631 = CARTESIAN_POINT('',(-0.192,-5.437,8.));
#8632 = VECTOR('',#8633,1.);
#8633 = DIRECTION('',(-0.,-0.,-1.));
#8634 = DEFINITIONAL_REPRESENTATION('',(#8635),#8639);
#8635 = LINE('',#8636,#8637);
#8636 = CARTESIAN_POINT('',(1.,0.));
#8637 = VECTOR('',#8638,1.);
#8638 = DIRECTION('',(0.,-1.));
#8639 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8640 = ORIENTED_EDGE('',*,*,#8641,.T.);
#8641 = EDGE_CURVE('',#8605,#8642,#8644,.T.);
#8642 = VERTEX_POINT('',#8643);
#8643 = CARTESIAN_POINT('',(-0.46,-5.052,8.2));
#8644 = SURFACE_CURVE('',#8645,(#8649,#8656),.PCURVE_S1.);
#8645 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8646,#8647,#8648),
#8646 = CARTESIAN_POINT('',(-0.192,-5.437,8.2));
#8647 = CARTESIAN_POINT('',(-0.192,-5.166,8.2));
#8648 = CARTESIAN_POINT('',(-0.46,-5.052,8.2));
#8649 = PCURVE('',#8613,#8650);
#8650 = DEFINITIONAL_REPRESENTATION('',(#8651),#8655);
#8651 = LINE('',#8652,#8653);
#8652 = CARTESIAN_POINT('',(0.,-0.2));
#8653 = VECTOR('',#8654,1.);
#8654 = DIRECTION('',(1.,0.));
#8655 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8656 = PCURVE('',#7097,#8657);
#8657 = DEFINITIONAL_REPRESENTATION('',(#8658),#8662);
#8658 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8659,#8660,#8661),
#8659 = CARTESIAN_POINT('',(5.531433518944E-02,1.022096280614));
#8660 = CARTESIAN_POINT('',(0.326314335189,1.022096280614));
#8661 = CARTESIAN_POINT('',(0.440314335189,0.754096280614));
#8662 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8663 = ORIENTED_EDGE('',*,*,#8664,.F.);
#8664 = EDGE_CURVE('',#8665,#8642,#8667,.T.);
#8665 = VERTEX_POINT('',#8666);
#8666 = CARTESIAN_POINT('',(-0.46,-5.052,8.));
#8667 = SURFACE_CURVE('',#8668,(#8672,#8679),.PCURVE_S1.);
#8668 = LINE('',#8669,#8670);
#8669 = CARTESIAN_POINT('',(-0.46,-5.052,8.));
#8670 = VECTOR('',#8671,1.);
#8671 = DIRECTION('',(0.,0.,1.));
#8672 = PCURVE('',#8613,#8673);
#8673 = DEFINITIONAL_REPRESENTATION('',(#8674),#8678);
#8674 = LINE('',#8675,#8676);
#8675 = CARTESIAN_POINT('',(1.,0.));
#8676 = VECTOR('',#8677,1.);
#8677 = DIRECTION('',(0.,-1.));
#8678 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8679 = PCURVE('',#8680,#8687);
#8680 = SURFACE_OF_LINEAR_EXTRUSION('',#8681,#8685);
#8681 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8682,#8683,#8684),
#8682 = CARTESIAN_POINT('',(-0.46,-5.052,8.));
#8683 = CARTESIAN_POINT('',(-0.606,-4.991,8.));
#8684 = CARTESIAN_POINT('',(-0.8,-4.991,8.));
#8685 = VECTOR('',#8686,1.);
#8686 = DIRECTION('',(-0.,-0.,-1.));
#8687 = DEFINITIONAL_REPRESENTATION('',(#8688),#8692);
#8688 = LINE('',#8689,#8690);
#8689 = CARTESIAN_POINT('',(0.,0.));
#8690 = VECTOR('',#8691,1.);
#8691 = DIRECTION('',(0.,-1.));
#8692 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8693 = ORIENTED_EDGE('',*,*,#8694,.F.);
#8694 = EDGE_CURVE('',#8603,#8665,#8695,.T.);
#8695 = SURFACE_CURVE('',#8696,(#8700,#8707),.PCURVE_S1.);
#8696 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8697,#8698,#8699),
#8697 = CARTESIAN_POINT('',(-0.192,-5.437,8.));
#8698 = CARTESIAN_POINT('',(-0.192,-5.166,8.));
#8699 = CARTESIAN_POINT('',(-0.46,-5.052,8.));
#8700 = PCURVE('',#8613,#8701);
#8701 = DEFINITIONAL_REPRESENTATION('',(#8702),#8706);
#8702 = LINE('',#8703,#8704);
#8703 = CARTESIAN_POINT('',(0.,0.));
#8704 = VECTOR('',#8705,1.);
#8705 = DIRECTION('',(1.,0.));
#8706 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8707 = PCURVE('',#7153,#8708);
#8708 = DEFINITIONAL_REPRESENTATION('',(#8709),#8713);
#8709 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8710,#8711,#8712),
#8710 = CARTESIAN_POINT('',(5.531433518944E-02,1.022096280614));
#8711 = CARTESIAN_POINT('',(0.326314335189,1.022096280614));
#8712 = CARTESIAN_POINT('',(0.440314335189,0.754096280614));
#8713 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8714 = ADVANCED_FACE('',(#8715),#8680,.T.);
#8715 = FACE_BOUND('',#8716,.T.);
#8716 = EDGE_LOOP('',(#8717,#8718,#8741,#8771));
#8717 = ORIENTED_EDGE('',*,*,#8664,.T.);
#8718 = ORIENTED_EDGE('',*,*,#8719,.T.);
#8719 = EDGE_CURVE('',#8642,#8720,#8722,.T.);
#8720 = VERTEX_POINT('',#8721);
#8721 = CARTESIAN_POINT('',(-0.8,-4.991,8.2));
#8722 = SURFACE_CURVE('',#8723,(#8727,#8734),.PCURVE_S1.);
#8723 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8724,#8725,#8726),
#8724 = CARTESIAN_POINT('',(-0.46,-5.052,8.2));
#8725 = CARTESIAN_POINT('',(-0.606,-4.991,8.2));
#8726 = CARTESIAN_POINT('',(-0.8,-4.991,8.2));
#8727 = PCURVE('',#8680,#8728);
#8728 = DEFINITIONAL_REPRESENTATION('',(#8729),#8733);
#8729 = LINE('',#8730,#8731);
#8730 = CARTESIAN_POINT('',(0.,-0.2));
#8731 = VECTOR('',#8732,1.);
#8732 = DIRECTION('',(1.,0.));
#8733 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8734 = PCURVE('',#7097,#8735);
#8735 = DEFINITIONAL_REPRESENTATION('',(#8736),#8740);
#8736 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8737,#8738,#8739),
#8737 = CARTESIAN_POINT('',(0.440314335189,0.754096280614));
#8738 = CARTESIAN_POINT('',(0.501314335189,0.608096280614));
#8739 = CARTESIAN_POINT('',(0.501314335189,0.414096280614));
#8740 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8741 = ORIENTED_EDGE('',*,*,#8742,.F.);
#8742 = EDGE_CURVE('',#8743,#8720,#8745,.T.);
#8743 = VERTEX_POINT('',#8744);
#8744 = CARTESIAN_POINT('',(-0.8,-4.991,8.));
#8745 = SURFACE_CURVE('',#8746,(#8750,#8757),.PCURVE_S1.);
#8746 = LINE('',#8747,#8748);
#8747 = CARTESIAN_POINT('',(-0.8,-4.991,8.));
#8748 = VECTOR('',#8749,1.);
#8749 = DIRECTION('',(0.,0.,1.));
#8750 = PCURVE('',#8680,#8751);
#8751 = DEFINITIONAL_REPRESENTATION('',(#8752),#8756);
#8752 = LINE('',#8753,#8754);
#8753 = CARTESIAN_POINT('',(1.,0.));
#8754 = VECTOR('',#8755,1.);
#8755 = DIRECTION('',(0.,-1.));
#8756 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8757 = PCURVE('',#8758,#8765);
#8758 = SURFACE_OF_LINEAR_EXTRUSION('',#8759,#8763);
#8759 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8760,#8761,#8762),
#8760 = CARTESIAN_POINT('',(-0.8,-4.991,8.));
#8761 = CARTESIAN_POINT('',(-1.214,-4.991,8.));
#8762 = CARTESIAN_POINT('',(-1.354,-5.231,8.));
#8763 = VECTOR('',#8764,1.);
#8764 = DIRECTION('',(-0.,-0.,-1.));
#8765 = DEFINITIONAL_REPRESENTATION('',(#8766),#8770);
#8766 = LINE('',#8767,#8768);
#8767 = CARTESIAN_POINT('',(0.,0.));
#8768 = VECTOR('',#8769,1.);
#8769 = DIRECTION('',(0.,-1.));
#8770 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8771 = ORIENTED_EDGE('',*,*,#8772,.F.);
#8772 = EDGE_CURVE('',#8665,#8743,#8773,.T.);
#8773 = SURFACE_CURVE('',#8774,(#8778,#8785),.PCURVE_S1.);
#8774 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8775,#8776,#8777),
#8775 = CARTESIAN_POINT('',(-0.46,-5.052,8.));
#8776 = CARTESIAN_POINT('',(-0.606,-4.991,8.));
#8777 = CARTESIAN_POINT('',(-0.8,-4.991,8.));
#8778 = PCURVE('',#8680,#8779);
#8779 = DEFINITIONAL_REPRESENTATION('',(#8780),#8784);
#8780 = LINE('',#8781,#8782);
#8781 = CARTESIAN_POINT('',(0.,0.));
#8782 = VECTOR('',#8783,1.);
#8783 = DIRECTION('',(1.,0.));
#8784 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8785 = PCURVE('',#7153,#8786);
#8786 = DEFINITIONAL_REPRESENTATION('',(#8787),#8791);
#8787 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8788,#8789,#8790),
#8788 = CARTESIAN_POINT('',(0.440314335189,0.754096280614));
#8789 = CARTESIAN_POINT('',(0.501314335189,0.608096280614));
#8790 = CARTESIAN_POINT('',(0.501314335189,0.414096280614));
#8791 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8792 = ADVANCED_FACE('',(#8793),#8758,.T.);
#8793 = FACE_BOUND('',#8794,.T.);
#8794 = EDGE_LOOP('',(#8795,#8796,#8819,#8849));
#8795 = ORIENTED_EDGE('',*,*,#8742,.T.);
#8796 = ORIENTED_EDGE('',*,*,#8797,.T.);
#8797 = EDGE_CURVE('',#8720,#8798,#8800,.T.);
#8798 = VERTEX_POINT('',#8799);
#8799 = CARTESIAN_POINT('',(-1.354,-5.231,8.2));
#8800 = SURFACE_CURVE('',#8801,(#8805,#8812),.PCURVE_S1.);
#8801 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8802,#8803,#8804),
#8802 = CARTESIAN_POINT('',(-0.8,-4.991,8.2));
#8803 = CARTESIAN_POINT('',(-1.214,-4.991,8.2));
#8804 = CARTESIAN_POINT('',(-1.354,-5.231,8.2));
#8805 = PCURVE('',#8758,#8806);
#8806 = DEFINITIONAL_REPRESENTATION('',(#8807),#8811);
#8807 = LINE('',#8808,#8809);
#8808 = CARTESIAN_POINT('',(0.,-0.2));
#8809 = VECTOR('',#8810,1.);
#8810 = DIRECTION('',(1.,0.));
#8811 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8812 = PCURVE('',#7097,#8813);
#8813 = DEFINITIONAL_REPRESENTATION('',(#8814),#8818);
#8814 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8815,#8816,#8817),
#8815 = CARTESIAN_POINT('',(0.501314335189,0.414096280614));
#8816 = CARTESIAN_POINT('',(0.501314335189,9.628061396749E-05));
#8817 = CARTESIAN_POINT('',(0.261314335189,-0.139903719386));
#8818 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8819 = ORIENTED_EDGE('',*,*,#8820,.F.);
#8820 = EDGE_CURVE('',#8821,#8798,#8823,.T.);
#8821 = VERTEX_POINT('',#8822);
#8822 = CARTESIAN_POINT('',(-1.354,-5.231,8.));
#8823 = SURFACE_CURVE('',#8824,(#8828,#8835),.PCURVE_S1.);
#8824 = LINE('',#8825,#8826);
#8825 = CARTESIAN_POINT('',(-1.354,-5.231,8.));
#8826 = VECTOR('',#8827,1.);
#8827 = DIRECTION('',(0.,0.,1.));
#8828 = PCURVE('',#8758,#8829);
#8829 = DEFINITIONAL_REPRESENTATION('',(#8830),#8834);
#8830 = LINE('',#8831,#8832);
#8831 = CARTESIAN_POINT('',(1.,0.));
#8832 = VECTOR('',#8833,1.);
#8833 = DIRECTION('',(0.,-1.));
#8834 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8835 = PCURVE('',#8836,#8843);
#8836 = SURFACE_OF_LINEAR_EXTRUSION('',#8837,#8841);
#8837 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8838,#8839,#8840),
#8838 = CARTESIAN_POINT('',(-1.354,-5.231,8.));
#8839 = CARTESIAN_POINT('',(-1.408,-5.323,8.));
#8840 = CARTESIAN_POINT('',(-1.408,-5.44,8.));
#8841 = VECTOR('',#8842,1.);
#8842 = DIRECTION('',(-0.,-0.,-1.));
#8843 = DEFINITIONAL_REPRESENTATION('',(#8844),#8848);
#8844 = LINE('',#8845,#8846);
#8845 = CARTESIAN_POINT('',(0.,0.));
#8846 = VECTOR('',#8847,1.);
#8847 = DIRECTION('',(0.,-1.));
#8848 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8849 = ORIENTED_EDGE('',*,*,#8850,.F.);
#8850 = EDGE_CURVE('',#8743,#8821,#8851,.T.);
#8851 = SURFACE_CURVE('',#8852,(#8856,#8863),.PCURVE_S1.);
#8852 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8853,#8854,#8855),
#8853 = CARTESIAN_POINT('',(-0.8,-4.991,8.));
#8854 = CARTESIAN_POINT('',(-1.214,-4.991,8.));
#8855 = CARTESIAN_POINT('',(-1.354,-5.231,8.));
#8856 = PCURVE('',#8758,#8857);
#8857 = DEFINITIONAL_REPRESENTATION('',(#8858),#8862);
#8858 = LINE('',#8859,#8860);
#8859 = CARTESIAN_POINT('',(0.,0.));
#8860 = VECTOR('',#8861,1.);
#8861 = DIRECTION('',(1.,0.));
#8862 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8863 = PCURVE('',#7153,#8864);
#8864 = DEFINITIONAL_REPRESENTATION('',(#8865),#8869);
#8865 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8866,#8867,#8868),
#8866 = CARTESIAN_POINT('',(0.501314335189,0.414096280614));
#8867 = CARTESIAN_POINT('',(0.501314335189,9.628061396749E-05));
#8868 = CARTESIAN_POINT('',(0.261314335189,-0.139903719386));
#8869 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8870 = ADVANCED_FACE('',(#8871),#8836,.T.);
#8871 = FACE_BOUND('',#8872,.T.);
#8872 = EDGE_LOOP('',(#8873,#8874,#8897,#8927));
#8873 = ORIENTED_EDGE('',*,*,#8820,.T.);
#8874 = ORIENTED_EDGE('',*,*,#8875,.T.);
#8875 = EDGE_CURVE('',#8798,#8876,#8878,.T.);
#8876 = VERTEX_POINT('',#8877);
#8877 = CARTESIAN_POINT('',(-1.408,-5.44,8.2));
#8878 = SURFACE_CURVE('',#8879,(#8883,#8890),.PCURVE_S1.);
#8879 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8880,#8881,#8882),
#8880 = CARTESIAN_POINT('',(-1.354,-5.231,8.2));
#8881 = CARTESIAN_POINT('',(-1.408,-5.323,8.2));
#8882 = CARTESIAN_POINT('',(-1.408,-5.44,8.2));
#8883 = PCURVE('',#8836,#8884);
#8884 = DEFINITIONAL_REPRESENTATION('',(#8885),#8889);
#8885 = LINE('',#8886,#8887);
#8886 = CARTESIAN_POINT('',(0.,-0.2));
#8887 = VECTOR('',#8888,1.);
#8888 = DIRECTION('',(1.,0.));
#8889 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8890 = PCURVE('',#7097,#8891);
#8891 = DEFINITIONAL_REPRESENTATION('',(#8892),#8896);
#8892 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8893,#8894,#8895),
#8893 = CARTESIAN_POINT('',(0.261314335189,-0.139903719386));
#8894 = CARTESIAN_POINT('',(0.169314335189,-0.193903719386));
#8895 = CARTESIAN_POINT('',(5.231433518944E-02,-0.193903719386));
#8896 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8897 = ORIENTED_EDGE('',*,*,#8898,.F.);
#8898 = EDGE_CURVE('',#8899,#8876,#8901,.T.);
#8899 = VERTEX_POINT('',#8900);
#8900 = CARTESIAN_POINT('',(-1.408,-5.44,8.));
#8901 = SURFACE_CURVE('',#8902,(#8906,#8913),.PCURVE_S1.);
#8902 = LINE('',#8903,#8904);
#8903 = CARTESIAN_POINT('',(-1.408,-5.44,8.));
#8904 = VECTOR('',#8905,1.);
#8905 = DIRECTION('',(0.,0.,1.));
#8906 = PCURVE('',#8836,#8907);
#8907 = DEFINITIONAL_REPRESENTATION('',(#8908),#8912);
#8908 = LINE('',#8909,#8910);
#8909 = CARTESIAN_POINT('',(1.,0.));
#8910 = VECTOR('',#8911,1.);
#8911 = DIRECTION('',(0.,-1.));
#8912 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8913 = PCURVE('',#8914,#8921);
#8914 = SURFACE_OF_LINEAR_EXTRUSION('',#8915,#8919);
#8915 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8916,#8917,#8918),
#8916 = CARTESIAN_POINT('',(-1.408,-5.44,8.));
#8917 = CARTESIAN_POINT('',(-1.408,-5.713,8.));
#8918 = CARTESIAN_POINT('',(-1.134,-5.821,8.));
#8919 = VECTOR('',#8920,1.);
#8920 = DIRECTION('',(-0.,-0.,-1.));
#8921 = DEFINITIONAL_REPRESENTATION('',(#8922),#8926);
#8922 = LINE('',#8923,#8924);
#8923 = CARTESIAN_POINT('',(0.,0.));
#8924 = VECTOR('',#8925,1.);
#8925 = DIRECTION('',(0.,-1.));
#8926 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8927 = ORIENTED_EDGE('',*,*,#8928,.F.);
#8928 = EDGE_CURVE('',#8821,#8899,#8929,.T.);
#8929 = SURFACE_CURVE('',#8930,(#8934,#8941),.PCURVE_S1.);
#8930 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8931,#8932,#8933),
#8931 = CARTESIAN_POINT('',(-1.354,-5.231,8.));
#8932 = CARTESIAN_POINT('',(-1.408,-5.323,8.));
#8933 = CARTESIAN_POINT('',(-1.408,-5.44,8.));
#8934 = PCURVE('',#8836,#8935);
#8935 = DEFINITIONAL_REPRESENTATION('',(#8936),#8940);
#8936 = LINE('',#8937,#8938);
#8937 = CARTESIAN_POINT('',(0.,0.));
#8938 = VECTOR('',#8939,1.);
#8939 = DIRECTION('',(1.,0.));
#8940 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8941 = PCURVE('',#7153,#8942);
#8942 = DEFINITIONAL_REPRESENTATION('',(#8943),#8947);
#8943 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8944,#8945,#8946),
#8944 = CARTESIAN_POINT('',(0.261314335189,-0.139903719386));
#8945 = CARTESIAN_POINT('',(0.169314335189,-0.193903719386));
#8946 = CARTESIAN_POINT('',(5.231433518944E-02,-0.193903719386));
#8947 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8948 = ADVANCED_FACE('',(#8949),#8914,.T.);
#8949 = FACE_BOUND('',#8950,.T.);
#8950 = EDGE_LOOP('',(#8951,#8952,#8975,#9005));
#8951 = ORIENTED_EDGE('',*,*,#8898,.T.);
#8952 = ORIENTED_EDGE('',*,*,#8953,.T.);
#8953 = EDGE_CURVE('',#8876,#8954,#8956,.T.);
#8954 = VERTEX_POINT('',#8955);
#8955 = CARTESIAN_POINT('',(-1.134,-5.821,8.2));
#8956 = SURFACE_CURVE('',#8957,(#8961,#8968),.PCURVE_S1.);
#8957 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8958,#8959,#8960),
#8958 = CARTESIAN_POINT('',(-1.408,-5.44,8.2));
#8959 = CARTESIAN_POINT('',(-1.408,-5.713,8.2));
#8960 = CARTESIAN_POINT('',(-1.134,-5.821,8.2));
#8961 = PCURVE('',#8914,#8962);
#8962 = DEFINITIONAL_REPRESENTATION('',(#8963),#8967);
#8963 = LINE('',#8964,#8965);
#8964 = CARTESIAN_POINT('',(0.,-0.2));
#8965 = VECTOR('',#8966,1.);
#8966 = DIRECTION('',(1.,0.));
#8967 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8968 = PCURVE('',#7097,#8969);
#8969 = DEFINITIONAL_REPRESENTATION('',(#8970),#8974);
#8970 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8971,#8972,#8973),
#8971 = CARTESIAN_POINT('',(5.231433518944E-02,-0.193903719386));
#8972 = CARTESIAN_POINT('',(-0.220685664811,-0.193903719386));
#8973 = CARTESIAN_POINT('',(-0.328685664811,8.009628061397E-02));
#8974 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8975 = ORIENTED_EDGE('',*,*,#8976,.F.);
#8976 = EDGE_CURVE('',#8977,#8954,#8979,.T.);
#8977 = VERTEX_POINT('',#8978);
#8978 = CARTESIAN_POINT('',(-1.134,-5.821,8.));
#8979 = SURFACE_CURVE('',#8980,(#8984,#8991),.PCURVE_S1.);
#8980 = LINE('',#8981,#8982);
#8981 = CARTESIAN_POINT('',(-1.134,-5.821,8.));
#8982 = VECTOR('',#8983,1.);
#8983 = DIRECTION('',(0.,0.,1.));
#8984 = PCURVE('',#8914,#8985);
#8985 = DEFINITIONAL_REPRESENTATION('',(#8986),#8990);
#8986 = LINE('',#8987,#8988);
#8987 = CARTESIAN_POINT('',(1.,0.));
#8988 = VECTOR('',#8989,1.);
#8989 = DIRECTION('',(0.,-1.));
#8990 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#8991 = PCURVE('',#8992,#8999);
#8992 = SURFACE_OF_LINEAR_EXTRUSION('',#8993,#8997);
#8993 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#8994,#8995,#8996),
#8994 = CARTESIAN_POINT('',(-1.134,-5.821,8.));
#8995 = CARTESIAN_POINT('',(-0.994,-5.876,8.));
#8996 = CARTESIAN_POINT('',(-0.809,-5.876,8.));
#8997 = VECTOR('',#8998,1.);
#8998 = DIRECTION('',(-0.,-0.,-1.));
#8999 = DEFINITIONAL_REPRESENTATION('',(#9000),#9004);
#9000 = LINE('',#9001,#9002);
#9001 = CARTESIAN_POINT('',(0.,0.));
#9002 = VECTOR('',#9003,1.);
#9003 = DIRECTION('',(0.,-1.));
#9004 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9005 = ORIENTED_EDGE('',*,*,#9006,.F.);
#9006 = EDGE_CURVE('',#8899,#8977,#9007,.T.);
#9007 = SURFACE_CURVE('',#9008,(#9012,#9019),.PCURVE_S1.);
#9008 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9009,#9010,#9011),
#9009 = CARTESIAN_POINT('',(-1.408,-5.44,8.));
#9010 = CARTESIAN_POINT('',(-1.408,-5.713,8.));
#9011 = CARTESIAN_POINT('',(-1.134,-5.821,8.));
#9012 = PCURVE('',#8914,#9013);
#9013 = DEFINITIONAL_REPRESENTATION('',(#9014),#9018);
#9014 = LINE('',#9015,#9016);
#9015 = CARTESIAN_POINT('',(0.,0.));
#9016 = VECTOR('',#9017,1.);
#9017 = DIRECTION('',(1.,0.));
#9018 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9019 = PCURVE('',#7153,#9020);
#9020 = DEFINITIONAL_REPRESENTATION('',(#9021),#9025);
#9021 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9022,#9023,#9024),
#9022 = CARTESIAN_POINT('',(5.231433518944E-02,-0.193903719386));
#9023 = CARTESIAN_POINT('',(-0.220685664811,-0.193903719386));
#9024 = CARTESIAN_POINT('',(-0.328685664811,8.009628061397E-02));
#9025 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9026 = ADVANCED_FACE('',(#9027),#8992,.T.);
#9027 = FACE_BOUND('',#9028,.T.);
#9028 = EDGE_LOOP('',(#9029,#9030,#9053,#9083));
#9029 = ORIENTED_EDGE('',*,*,#8976,.T.);
#9030 = ORIENTED_EDGE('',*,*,#9031,.T.);
#9031 = EDGE_CURVE('',#8954,#9032,#9034,.T.);
#9032 = VERTEX_POINT('',#9033);
#9033 = CARTESIAN_POINT('',(-0.809,-5.876,8.2));
#9034 = SURFACE_CURVE('',#9035,(#9039,#9046),.PCURVE_S1.);
#9035 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9036,#9037,#9038),
#9036 = CARTESIAN_POINT('',(-1.134,-5.821,8.2));
#9037 = CARTESIAN_POINT('',(-0.994,-5.876,8.2));
#9038 = CARTESIAN_POINT('',(-0.809,-5.876,8.2));
#9039 = PCURVE('',#8992,#9040);
#9040 = DEFINITIONAL_REPRESENTATION('',(#9041),#9045);
#9041 = LINE('',#9042,#9043);
#9042 = CARTESIAN_POINT('',(0.,-0.2));
#9043 = VECTOR('',#9044,1.);
#9044 = DIRECTION('',(1.,0.));
#9045 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9046 = PCURVE('',#7097,#9047);
#9047 = DEFINITIONAL_REPRESENTATION('',(#9048),#9052);
#9048 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9049,#9050,#9051),
#9049 = CARTESIAN_POINT('',(-0.328685664811,8.009628061397E-02));
#9050 = CARTESIAN_POINT('',(-0.383685664811,0.220096280614));
#9051 = CARTESIAN_POINT('',(-0.383685664811,0.405096280614));
#9052 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9053 = ORIENTED_EDGE('',*,*,#9054,.F.);
#9054 = EDGE_CURVE('',#9055,#9032,#9057,.T.);
#9055 = VERTEX_POINT('',#9056);
#9056 = CARTESIAN_POINT('',(-0.809,-5.876,8.));
#9057 = SURFACE_CURVE('',#9058,(#9062,#9069),.PCURVE_S1.);
#9058 = LINE('',#9059,#9060);
#9059 = CARTESIAN_POINT('',(-0.809,-5.876,8.));
#9060 = VECTOR('',#9061,1.);
#9061 = DIRECTION('',(0.,0.,1.));
#9062 = PCURVE('',#8992,#9063);
#9063 = DEFINITIONAL_REPRESENTATION('',(#9064),#9068);
#9064 = LINE('',#9065,#9066);
#9065 = CARTESIAN_POINT('',(1.,0.));
#9066 = VECTOR('',#9067,1.);
#9067 = DIRECTION('',(0.,-1.));
#9068 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9069 = PCURVE('',#9070,#9077);
#9070 = SURFACE_OF_LINEAR_EXTRUSION('',#9071,#9075);
#9071 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9072,#9073,#9074),
#9072 = CARTESIAN_POINT('',(-0.809,-5.876,8.));
#9073 = CARTESIAN_POINT('',(-0.362,-5.876,8.));
#9074 = CARTESIAN_POINT('',(-0.234,-5.624,8.));
#9075 = VECTOR('',#9076,1.);
#9076 = DIRECTION('',(-0.,-0.,-1.));
#9077 = DEFINITIONAL_REPRESENTATION('',(#9078),#9082);
#9078 = LINE('',#9079,#9080);
#9079 = CARTESIAN_POINT('',(0.,0.));
#9080 = VECTOR('',#9081,1.);
#9081 = DIRECTION('',(0.,-1.));
#9082 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9083 = ORIENTED_EDGE('',*,*,#9084,.F.);
#9084 = EDGE_CURVE('',#8977,#9055,#9085,.T.);
#9085 = SURFACE_CURVE('',#9086,(#9090,#9097),.PCURVE_S1.);
#9086 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9087,#9088,#9089),
#9087 = CARTESIAN_POINT('',(-1.134,-5.821,8.));
#9088 = CARTESIAN_POINT('',(-0.994,-5.876,8.));
#9089 = CARTESIAN_POINT('',(-0.809,-5.876,8.));
#9090 = PCURVE('',#8992,#9091);
#9091 = DEFINITIONAL_REPRESENTATION('',(#9092),#9096);
#9092 = LINE('',#9093,#9094);
#9093 = CARTESIAN_POINT('',(0.,0.));
#9094 = VECTOR('',#9095,1.);
#9095 = DIRECTION('',(1.,0.));
#9096 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9097 = PCURVE('',#7153,#9098);
#9098 = DEFINITIONAL_REPRESENTATION('',(#9099),#9103);
#9099 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9100,#9101,#9102),
#9100 = CARTESIAN_POINT('',(-0.328685664811,8.009628061397E-02));
#9101 = CARTESIAN_POINT('',(-0.383685664811,0.220096280614));
#9102 = CARTESIAN_POINT('',(-0.383685664811,0.405096280614));
#9103 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9104 = ADVANCED_FACE('',(#9105),#9070,.T.);
#9105 = FACE_BOUND('',#9106,.T.);
#9106 = EDGE_LOOP('',(#9107,#9108,#9131,#9154));
#9107 = ORIENTED_EDGE('',*,*,#9054,.T.);
#9108 = ORIENTED_EDGE('',*,*,#9109,.T.);
#9109 = EDGE_CURVE('',#9032,#9110,#9112,.T.);
#9110 = VERTEX_POINT('',#9111);
#9111 = CARTESIAN_POINT('',(-0.234,-5.624,8.2));
#9112 = SURFACE_CURVE('',#9113,(#9117,#9124),.PCURVE_S1.);
#9113 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9114,#9115,#9116),
#9114 = CARTESIAN_POINT('',(-0.809,-5.876,8.2));
#9115 = CARTESIAN_POINT('',(-0.362,-5.876,8.2));
#9116 = CARTESIAN_POINT('',(-0.234,-5.624,8.2));
#9117 = PCURVE('',#9070,#9118);
#9118 = DEFINITIONAL_REPRESENTATION('',(#9119),#9123);
#9119 = LINE('',#9120,#9121);
#9120 = CARTESIAN_POINT('',(0.,-0.2));
#9121 = VECTOR('',#9122,1.);
#9122 = DIRECTION('',(1.,0.));
#9123 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9124 = PCURVE('',#7097,#9125);
#9125 = DEFINITIONAL_REPRESENTATION('',(#9126),#9130);
#9126 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9127,#9128,#9129),
#9127 = CARTESIAN_POINT('',(-0.383685664811,0.405096280614));
#9128 = CARTESIAN_POINT('',(-0.383685664811,0.852096280614));
#9129 = CARTESIAN_POINT('',(-0.131685664811,0.980096280614));
#9130 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9131 = ORIENTED_EDGE('',*,*,#9132,.F.);
#9132 = EDGE_CURVE('',#9133,#9110,#9135,.T.);
#9133 = VERTEX_POINT('',#9134);
#9134 = CARTESIAN_POINT('',(-0.234,-5.624,8.));
#9135 = SURFACE_CURVE('',#9136,(#9140,#9147),.PCURVE_S1.);
#9136 = LINE('',#9137,#9138);
#9137 = CARTESIAN_POINT('',(-0.234,-5.624,8.));
#9138 = VECTOR('',#9139,1.);
#9139 = DIRECTION('',(0.,0.,1.));
#9140 = PCURVE('',#9070,#9141);
#9141 = DEFINITIONAL_REPRESENTATION('',(#9142),#9146);
#9142 = LINE('',#9143,#9144);
#9143 = CARTESIAN_POINT('',(1.,0.));
#9144 = VECTOR('',#9145,1.);
#9145 = DIRECTION('',(0.,-1.));
#9146 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9147 = PCURVE('',#8627,#9148);
#9148 = DEFINITIONAL_REPRESENTATION('',(#9149),#9153);
#9149 = LINE('',#9150,#9151);
#9150 = CARTESIAN_POINT('',(0.,0.));
#9151 = VECTOR('',#9152,1.);
#9152 = DIRECTION('',(0.,-1.));
#9153 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9154 = ORIENTED_EDGE('',*,*,#9155,.F.);
#9155 = EDGE_CURVE('',#9055,#9133,#9156,.T.);
#9156 = SURFACE_CURVE('',#9157,(#9161,#9168),.PCURVE_S1.);
#9157 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9158,#9159,#9160),
#9158 = CARTESIAN_POINT('',(-0.809,-5.876,8.));
#9159 = CARTESIAN_POINT('',(-0.362,-5.876,8.));
#9160 = CARTESIAN_POINT('',(-0.234,-5.624,8.));
#9161 = PCURVE('',#9070,#9162);
#9162 = DEFINITIONAL_REPRESENTATION('',(#9163),#9167);
#9163 = LINE('',#9164,#9165);
#9164 = CARTESIAN_POINT('',(0.,0.));
#9165 = VECTOR('',#9166,1.);
#9166 = DIRECTION('',(1.,0.));
#9167 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9168 = PCURVE('',#7153,#9169);
#9169 = DEFINITIONAL_REPRESENTATION('',(#9170),#9174);
#9170 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9171,#9172,#9173),
#9171 = CARTESIAN_POINT('',(-0.383685664811,0.405096280614));
#9172 = CARTESIAN_POINT('',(-0.383685664811,0.852096280614));
#9173 = CARTESIAN_POINT('',(-0.131685664811,0.980096280614));
#9174 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9175 = ADVANCED_FACE('',(#9176),#8627,.T.);
#9176 = FACE_BOUND('',#9177,.T.);
#9177 = EDGE_LOOP('',(#9178,#9179,#9200,#9201));
#9178 = ORIENTED_EDGE('',*,*,#9132,.T.);
#9179 = ORIENTED_EDGE('',*,*,#9180,.T.);
#9180 = EDGE_CURVE('',#9110,#8605,#9181,.T.);
#9181 = SURFACE_CURVE('',#9182,(#9186,#9193),.PCURVE_S1.);
#9182 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9183,#9184,#9185),
#9183 = CARTESIAN_POINT('',(-0.234,-5.624,8.2));
#9184 = CARTESIAN_POINT('',(-0.192,-5.538,8.2));
#9185 = CARTESIAN_POINT('',(-0.192,-5.437,8.2));
#9186 = PCURVE('',#8627,#9187);
#9187 = DEFINITIONAL_REPRESENTATION('',(#9188),#9192);
#9188 = LINE('',#9189,#9190);
#9189 = CARTESIAN_POINT('',(0.,-0.2));
#9190 = VECTOR('',#9191,1.);
#9191 = DIRECTION('',(1.,0.));
#9192 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9193 = PCURVE('',#7097,#9194);
#9194 = DEFINITIONAL_REPRESENTATION('',(#9195),#9199);
#9195 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9196,#9197,#9198),
#9196 = CARTESIAN_POINT('',(-0.131685664811,0.980096280614));
#9197 = CARTESIAN_POINT('',(-4.568566481056E-02,1.022096280614));
#9198 = CARTESIAN_POINT('',(5.531433518944E-02,1.022096280614));
#9199 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9200 = ORIENTED_EDGE('',*,*,#8602,.F.);
#9201 = ORIENTED_EDGE('',*,*,#9202,.F.);
#9202 = EDGE_CURVE('',#9133,#8603,#9203,.T.);
#9203 = SURFACE_CURVE('',#9204,(#9208,#9215),.PCURVE_S1.);
#9204 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9205,#9206,#9207),
#9205 = CARTESIAN_POINT('',(-0.234,-5.624,8.));
#9206 = CARTESIAN_POINT('',(-0.192,-5.538,8.));
#9207 = CARTESIAN_POINT('',(-0.192,-5.437,8.));
#9208 = PCURVE('',#8627,#9209);
#9209 = DEFINITIONAL_REPRESENTATION('',(#9210),#9214);
#9210 = LINE('',#9211,#9212);
#9211 = CARTESIAN_POINT('',(0.,0.));
#9212 = VECTOR('',#9213,1.);
#9213 = DIRECTION('',(1.,0.));
#9214 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9215 = PCURVE('',#7153,#9216);
#9216 = DEFINITIONAL_REPRESENTATION('',(#9217),#9221);
#9217 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9218,#9219,#9220),
#9218 = CARTESIAN_POINT('',(-0.131685664811,0.980096280614));
#9219 = CARTESIAN_POINT('',(-4.568566481056E-02,1.022096280614));
#9220 = CARTESIAN_POINT('',(5.531433518944E-02,1.022096280614));
#9221 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9222 = ADVANCED_FACE('',(#9223,#9245),#7153,.T.);
#9223 = FACE_BOUND('',#9224,.T.);
#9224 = EDGE_LOOP('',(#9225,#9226,#9227,#9228,#9229,#9230,#9231,#9232,
#9233,#9234,#9235,#9236,#9237,#9238,#9239,#9240,#9241,#9242,#9243,
#9244));
#9225 = ORIENTED_EDGE('',*,*,#7139,.T.);
#9226 = ORIENTED_EDGE('',*,*,#7222,.T.);
#9227 = ORIENTED_EDGE('',*,*,#7300,.T.);
#9228 = ORIENTED_EDGE('',*,*,#7378,.T.);
#9229 = ORIENTED_EDGE('',*,*,#7454,.T.);
#9230 = ORIENTED_EDGE('',*,*,#7530,.T.);
#9231 = ORIENTED_EDGE('',*,*,#7606,.T.);
#9232 = ORIENTED_EDGE('',*,*,#7684,.T.);
#9233 = ORIENTED_EDGE('',*,*,#7762,.T.);
#9234 = ORIENTED_EDGE('',*,*,#7840,.T.);
#9235 = ORIENTED_EDGE('',*,*,#7918,.T.);
#9236 = ORIENTED_EDGE('',*,*,#7994,.T.);
#9237 = ORIENTED_EDGE('',*,*,#8072,.T.);
#9238 = ORIENTED_EDGE('',*,*,#8150,.T.);
#9239 = ORIENTED_EDGE('',*,*,#8228,.T.);
#9240 = ORIENTED_EDGE('',*,*,#8306,.T.);
#9241 = ORIENTED_EDGE('',*,*,#8382,.T.);
#9242 = ORIENTED_EDGE('',*,*,#8460,.T.);
#9243 = ORIENTED_EDGE('',*,*,#8531,.T.);
#9244 = ORIENTED_EDGE('',*,*,#8578,.T.);
#9245 = FACE_BOUND('',#9246,.T.);
#9246 = EDGE_LOOP('',(#9247,#9248,#9249,#9250,#9251,#9252,#9253,#9254));
#9247 = ORIENTED_EDGE('',*,*,#8694,.T.);
#9248 = ORIENTED_EDGE('',*,*,#8772,.T.);
#9249 = ORIENTED_EDGE('',*,*,#8850,.T.);
#9250 = ORIENTED_EDGE('',*,*,#8928,.T.);
#9251 = ORIENTED_EDGE('',*,*,#9006,.T.);
#9252 = ORIENTED_EDGE('',*,*,#9084,.T.);
#9253 = ORIENTED_EDGE('',*,*,#9155,.T.);
#9254 = ORIENTED_EDGE('',*,*,#9202,.T.);
#9255 = ADVANCED_FACE('',(#9256,#9278),#7097,.F.);
#9256 = FACE_BOUND('',#9257,.F.);
#9257 = EDGE_LOOP('',(#9258,#9259,#9260,#9261,#9262,#9263,#9264,#9265,
#9266,#9267,#9268,#9269,#9270,#9271,#9272,#9273,#9274,#9275,#9276,
#9277));
#9258 = ORIENTED_EDGE('',*,*,#7081,.T.);
#9259 = ORIENTED_EDGE('',*,*,#7169,.T.);
#9260 = ORIENTED_EDGE('',*,*,#7247,.T.);
#9261 = ORIENTED_EDGE('',*,*,#7325,.T.);
#9262 = ORIENTED_EDGE('',*,*,#7403,.T.);
#9263 = ORIENTED_EDGE('',*,*,#7479,.T.);
#9264 = ORIENTED_EDGE('',*,*,#7555,.T.);
#9265 = ORIENTED_EDGE('',*,*,#7631,.T.);
#9266 = ORIENTED_EDGE('',*,*,#7709,.T.);
#9267 = ORIENTED_EDGE('',*,*,#7787,.T.);
#9268 = ORIENTED_EDGE('',*,*,#7865,.T.);
#9269 = ORIENTED_EDGE('',*,*,#7943,.T.);
#9270 = ORIENTED_EDGE('',*,*,#8019,.T.);
#9271 = ORIENTED_EDGE('',*,*,#8097,.T.);
#9272 = ORIENTED_EDGE('',*,*,#8175,.T.);
#9273 = ORIENTED_EDGE('',*,*,#8253,.T.);
#9274 = ORIENTED_EDGE('',*,*,#8331,.T.);
#9275 = ORIENTED_EDGE('',*,*,#8407,.T.);
#9276 = ORIENTED_EDGE('',*,*,#8485,.T.);
#9277 = ORIENTED_EDGE('',*,*,#8556,.T.);
#9278 = FACE_BOUND('',#9279,.F.);
#9279 = EDGE_LOOP('',(#9280,#9281,#9282,#9283,#9284,#9285,#9286,#9287));
#9280 = ORIENTED_EDGE('',*,*,#8641,.T.);
#9281 = ORIENTED_EDGE('',*,*,#8719,.T.);
#9282 = ORIENTED_EDGE('',*,*,#8797,.T.);
#9283 = ORIENTED_EDGE('',*,*,#8875,.T.);
#9284 = ORIENTED_EDGE('',*,*,#8953,.T.);
#9285 = ORIENTED_EDGE('',*,*,#9031,.T.);
#9286 = ORIENTED_EDGE('',*,*,#9109,.T.);
#9287 = ORIENTED_EDGE('',*,*,#9180,.T.);
#9288 = MANIFOLD_SOLID_BREP('',#9289);
#9289 = CLOSED_SHELL('',(#9290,#9410,#9488,#9566,#9644,#9722,#9798,#9874
,#9950,#10028,#10106,#10184,#10262,#10338,#10414,#10485,#10532,
#10551));
#9290 = ADVANCED_FACE('',(#9291),#9305,.T.);
#9291 = FACE_BOUND('',#9292,.T.);
#9292 = EDGE_LOOP('',(#9293,#9328,#9356,#9384));
#9293 = ORIENTED_EDGE('',*,*,#9294,.T.);
#9294 = EDGE_CURVE('',#9295,#9297,#9299,.T.);
#9295 = VERTEX_POINT('',#9296);
#9296 = CARTESIAN_POINT('',(-1.E-15,-6.48,8.));
#9297 = VERTEX_POINT('',#9298);
#9298 = CARTESIAN_POINT('',(-1.E-15,-6.48,8.2));
#9299 = SURFACE_CURVE('',#9300,(#9304,#9316),.PCURVE_S1.);
#9300 = LINE('',#9301,#9302);
#9301 = CARTESIAN_POINT('',(-1.33E-15,-6.48,8.));
#9302 = VECTOR('',#9303,1.);
#9303 = DIRECTION('',(0.,0.,1.));
#9304 = PCURVE('',#9305,#9310);
#9305 = PLANE('',#9306);
#9306 = AXIS2_PLACEMENT_3D('',#9307,#9308,#9309);
#9307 = CARTESIAN_POINT('',(-1.33E-15,-6.48,8.));
#9308 = DIRECTION('',(1.,-2.2E-16,0.));
#9309 = DIRECTION('',(-2.2E-16,-1.,0.));
#9310 = DEFINITIONAL_REPRESENTATION('',(#9311),#9315);
#9311 = LINE('',#9312,#9313);
#9312 = CARTESIAN_POINT('',(8.9E-16,-0.));
#9313 = VECTOR('',#9314,1.);
#9314 = DIRECTION('',(0.,-1.));
#9315 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9316 = PCURVE('',#9317,#9322);
#9317 = PLANE('',#9318);
#9318 = AXIS2_PLACEMENT_3D('',#9319,#9320,#9321);
#9319 = CARTESIAN_POINT('',(-1.6,-6.48,8.));
#9320 = DIRECTION('',(2.2E-16,1.,0.));
#9321 = DIRECTION('',(1.,-2.2E-16,0.));
#9322 = DEFINITIONAL_REPRESENTATION('',(#9323),#9327);
#9323 = LINE('',#9324,#9325);
#9324 = CARTESIAN_POINT('',(1.6,0.));
#9325 = VECTOR('',#9326,1.);
#9326 = DIRECTION('',(0.,-1.));
#9327 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9328 = ORIENTED_EDGE('',*,*,#9329,.T.);
#9329 = EDGE_CURVE('',#9297,#9330,#9332,.T.);
#9330 = VERTEX_POINT('',#9331);
#9331 = CARTESIAN_POINT('',(-1.E-15,-6.717,8.2));
#9332 = SURFACE_CURVE('',#9333,(#9337,#9344),.PCURVE_S1.);
#9333 = LINE('',#9334,#9335);
#9334 = CARTESIAN_POINT('',(0.,-6.48,8.2));
#9335 = VECTOR('',#9336,1.);
#9336 = DIRECTION('',(0.,-1.,0.));
#9337 = PCURVE('',#9305,#9338);
#9338 = DEFINITIONAL_REPRESENTATION('',(#9339),#9343);
#9339 = LINE('',#9340,#9341);
#9340 = CARTESIAN_POINT('',(0.,-0.2));
#9341 = VECTOR('',#9342,1.);
#9342 = DIRECTION('',(1.,-0.));
#9343 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9344 = PCURVE('',#9345,#9350);
#9345 = PLANE('',#9346);
#9346 = AXIS2_PLACEMENT_3D('',#9347,#9348,#9349);
#9347 = CARTESIAN_POINT('',(-0.69534490695,-7.099141886942,8.2));
#9348 = DIRECTION('',(-0.,0.,-1.));
#9349 = DIRECTION('',(0.,1.,0.));
#9350 = DEFINITIONAL_REPRESENTATION('',(#9351),#9355);
#9351 = LINE('',#9352,#9353);
#9352 = CARTESIAN_POINT('',(0.619141886942,0.69534490695));
#9353 = VECTOR('',#9354,1.);
#9354 = DIRECTION('',(-1.,0.));
#9355 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9356 = ORIENTED_EDGE('',*,*,#9357,.F.);
#9357 = EDGE_CURVE('',#9358,#9330,#9360,.T.);
#9358 = VERTEX_POINT('',#9359);
#9359 = CARTESIAN_POINT('',(-1.E-15,-6.717,8.));
#9360 = SURFACE_CURVE('',#9361,(#9365,#9372),.PCURVE_S1.);
#9361 = LINE('',#9362,#9363);
#9362 = CARTESIAN_POINT('',(-1.33E-15,-6.717,8.));
#9363 = VECTOR('',#9364,1.);
#9364 = DIRECTION('',(0.,0.,1.));
#9365 = PCURVE('',#9305,#9366);
#9366 = DEFINITIONAL_REPRESENTATION('',(#9367),#9371);
#9367 = LINE('',#9368,#9369);
#9368 = CARTESIAN_POINT('',(0.237,-0.));
#9369 = VECTOR('',#9370,1.);
#9370 = DIRECTION('',(0.,-1.));
#9371 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9372 = PCURVE('',#9373,#9378);
#9373 = PLANE('',#9374);
#9374 = AXIS2_PLACEMENT_3D('',#9375,#9376,#9377);
#9375 = CARTESIAN_POINT('',(-1.33E-15,-6.717,8.));
#9376 = DIRECTION('',(-2.2E-16,-1.,0.));
#9377 = DIRECTION('',(-1.,2.2E-16,0.));
#9378 = DEFINITIONAL_REPRESENTATION('',(#9379),#9383);
#9379 = LINE('',#9380,#9381);
#9380 = CARTESIAN_POINT('',(0.,0.));
#9381 = VECTOR('',#9382,1.);
#9382 = DIRECTION('',(0.,-1.));
#9383 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9384 = ORIENTED_EDGE('',*,*,#9385,.F.);
#9385 = EDGE_CURVE('',#9295,#9358,#9386,.T.);
#9386 = SURFACE_CURVE('',#9387,(#9391,#9398),.PCURVE_S1.);
#9387 = LINE('',#9388,#9389);
#9388 = CARTESIAN_POINT('',(0.,-6.48,8.));
#9389 = VECTOR('',#9390,1.);
#9390 = DIRECTION('',(0.,-1.,0.));
#9391 = PCURVE('',#9305,#9392);
#9392 = DEFINITIONAL_REPRESENTATION('',(#9393),#9397);
#9393 = LINE('',#9394,#9395);
#9394 = CARTESIAN_POINT('',(0.,0.));
#9395 = VECTOR('',#9396,1.);
#9396 = DIRECTION('',(1.,-0.));
#9397 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9398 = PCURVE('',#9399,#9404);
#9399 = PLANE('',#9400);
#9400 = AXIS2_PLACEMENT_3D('',#9401,#9402,#9403);
#9401 = CARTESIAN_POINT('',(-0.69534490695,-7.099141886942,8.));
#9402 = DIRECTION('',(-0.,0.,-1.));
#9403 = DIRECTION('',(0.,1.,0.));
#9404 = DEFINITIONAL_REPRESENTATION('',(#9405),#9409);
#9405 = LINE('',#9406,#9407);
#9406 = CARTESIAN_POINT('',(0.619141886942,0.69534490695));
#9407 = VECTOR('',#9408,1.);
#9408 = DIRECTION('',(-1.,0.));
#9409 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9410 = ADVANCED_FACE('',(#9411),#9373,.T.);
#9411 = FACE_BOUND('',#9412,.T.);
#9412 = EDGE_LOOP('',(#9413,#9414,#9437,#9467));
#9413 = ORIENTED_EDGE('',*,*,#9357,.T.);
#9414 = ORIENTED_EDGE('',*,*,#9415,.T.);
#9415 = EDGE_CURVE('',#9330,#9416,#9418,.T.);
#9416 = VERTEX_POINT('',#9417);
#9417 = CARTESIAN_POINT('',(-0.283,-6.717,8.2));
#9418 = SURFACE_CURVE('',#9419,(#9423,#9430),.PCURVE_S1.);
#9419 = LINE('',#9420,#9421);
#9420 = CARTESIAN_POINT('',(0.,-6.717,8.2));
#9421 = VECTOR('',#9422,1.);
#9422 = DIRECTION('',(-1.,0.,0.));
#9423 = PCURVE('',#9373,#9424);
#9424 = DEFINITIONAL_REPRESENTATION('',(#9425),#9429);
#9425 = LINE('',#9426,#9427);
#9426 = CARTESIAN_POINT('',(0.,-0.2));
#9427 = VECTOR('',#9428,1.);
#9428 = DIRECTION('',(1.,0.));
#9429 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9430 = PCURVE('',#9345,#9431);
#9431 = DEFINITIONAL_REPRESENTATION('',(#9432),#9436);
#9432 = LINE('',#9433,#9434);
#9433 = CARTESIAN_POINT('',(0.382141886942,0.69534490695));
#9434 = VECTOR('',#9435,1.);
#9435 = DIRECTION('',(0.,-1.));
#9436 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9437 = ORIENTED_EDGE('',*,*,#9438,.F.);
#9438 = EDGE_CURVE('',#9439,#9416,#9441,.T.);
#9439 = VERTEX_POINT('',#9440);
#9440 = CARTESIAN_POINT('',(-0.283,-6.717,8.));
#9441 = SURFACE_CURVE('',#9442,(#9446,#9453),.PCURVE_S1.);
#9442 = LINE('',#9443,#9444);
#9443 = CARTESIAN_POINT('',(-0.283,-6.717,8.));
#9444 = VECTOR('',#9445,1.);
#9445 = DIRECTION('',(0.,0.,1.));
#9446 = PCURVE('',#9373,#9447);
#9447 = DEFINITIONAL_REPRESENTATION('',(#9448),#9452);
#9448 = LINE('',#9449,#9450);
#9449 = CARTESIAN_POINT('',(0.283,0.));
#9450 = VECTOR('',#9451,1.);
#9451 = DIRECTION('',(0.,-1.));
#9452 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9453 = PCURVE('',#9454,#9461);
#9454 = SURFACE_OF_LINEAR_EXTRUSION('',#9455,#9459);
#9455 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9456,#9457,#9458),
.UNSPECIFIED.,.F.,.F.,(3,3),(0.,1.),.PIECEWISE_BEZIER_KNOTS.);
#9456 = CARTESIAN_POINT('',(-0.283,-6.717,8.));
#9457 = CARTESIAN_POINT('',(2.999999999999E-03,-6.883,8.));
#9458 = CARTESIAN_POINT('',(5.1E-02,-7.116,8.));
#9459 = VECTOR('',#9460,1.);
#9460 = DIRECTION('',(-0.,-0.,-1.));
#9461 = DEFINITIONAL_REPRESENTATION('',(#9462),#9466);
#9462 = LINE('',#9463,#9464);
#9463 = CARTESIAN_POINT('',(0.,0.));
#9464 = VECTOR('',#9465,1.);
#9465 = DIRECTION('',(0.,-1.));
#9466 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9467 = ORIENTED_EDGE('',*,*,#9468,.F.);
#9468 = EDGE_CURVE('',#9358,#9439,#9469,.T.);
#9469 = SURFACE_CURVE('',#9470,(#9474,#9481),.PCURVE_S1.);
#9470 = LINE('',#9471,#9472);
#9471 = CARTESIAN_POINT('',(0.,-6.717,8.));
#9472 = VECTOR('',#9473,1.);
#9473 = DIRECTION('',(-1.,0.,0.));
#9474 = PCURVE('',#9373,#9475);
#9475 = DEFINITIONAL_REPRESENTATION('',(#9476),#9480);
#9476 = LINE('',#9477,#9478);
#9477 = CARTESIAN_POINT('',(0.,0.));
#9478 = VECTOR('',#9479,1.);
#9479 = DIRECTION('',(1.,0.));
#9480 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9481 = PCURVE('',#9399,#9482);
#9482 = DEFINITIONAL_REPRESENTATION('',(#9483),#9487);
#9483 = LINE('',#9484,#9485);
#9484 = CARTESIAN_POINT('',(0.382141886942,0.69534490695));
#9485 = VECTOR('',#9486,1.);
#9486 = DIRECTION('',(0.,-1.));
#9487 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9488 = ADVANCED_FACE('',(#9489),#9454,.T.);
#9489 = FACE_BOUND('',#9490,.T.);
#9490 = EDGE_LOOP('',(#9491,#9492,#9515,#9545));
#9491 = ORIENTED_EDGE('',*,*,#9438,.T.);
#9492 = ORIENTED_EDGE('',*,*,#9493,.T.);
#9493 = EDGE_CURVE('',#9416,#9494,#9496,.T.);
#9494 = VERTEX_POINT('',#9495);
#9495 = CARTESIAN_POINT('',(5.1E-02,-7.116,8.2));
#9496 = SURFACE_CURVE('',#9497,(#9501,#9508),.PCURVE_S1.);
#9497 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9498,#9499,#9500),
#9498 = CARTESIAN_POINT('',(-0.283,-6.717,8.2));
#9499 = CARTESIAN_POINT('',(3.E-03,-6.883,8.2));
#9500 = CARTESIAN_POINT('',(5.1E-02,-7.116,8.2));
#9501 = PCURVE('',#9454,#9502);
#9502 = DEFINITIONAL_REPRESENTATION('',(#9503),#9507);
#9503 = LINE('',#9504,#9505);
#9504 = CARTESIAN_POINT('',(0.,-0.2));
#9505 = VECTOR('',#9506,1.);
#9506 = DIRECTION('',(1.,0.));
#9507 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9508 = PCURVE('',#9345,#9509);
#9509 = DEFINITIONAL_REPRESENTATION('',(#9510),#9514);
#9510 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9511,#9512,#9513),
#9511 = CARTESIAN_POINT('',(0.382141886942,0.41234490695));
#9512 = CARTESIAN_POINT('',(0.216141886942,0.69834490695));
#9513 = CARTESIAN_POINT('',(-1.685811305773E-02,0.74634490695));
#9514 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9515 = ORIENTED_EDGE('',*,*,#9516,.F.);
#9516 = EDGE_CURVE('',#9517,#9494,#9519,.T.);
#9517 = VERTEX_POINT('',#9518);
#9518 = CARTESIAN_POINT('',(5.1E-02,-7.116,8.));
#9519 = SURFACE_CURVE('',#9520,(#9524,#9531),.PCURVE_S1.);
#9520 = LINE('',#9521,#9522);
#9521 = CARTESIAN_POINT('',(5.1E-02,-7.116,8.));
#9522 = VECTOR('',#9523,1.);
#9523 = DIRECTION('',(0.,0.,1.));
#9524 = PCURVE('',#9454,#9525);
#9525 = DEFINITIONAL_REPRESENTATION('',(#9526),#9530);
#9526 = LINE('',#9527,#9528);
#9527 = CARTESIAN_POINT('',(1.,0.));
#9528 = VECTOR('',#9529,1.);
#9529 = DIRECTION('',(0.,-1.));
#9530 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9531 = PCURVE('',#9532,#9539);
#9532 = SURFACE_OF_LINEAR_EXTRUSION('',#9533,#9537);
#9533 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9534,#9535,#9536),
#9534 = CARTESIAN_POINT('',(5.1E-02,-7.116,8.));
#9535 = CARTESIAN_POINT('',(6.4E-02,-7.181,8.));
#9536 = CARTESIAN_POINT('',(6.4E-02,-7.251,8.));
#9537 = VECTOR('',#9538,1.);
#9538 = DIRECTION('',(-0.,-0.,-1.));
#9539 = DEFINITIONAL_REPRESENTATION('',(#9540),#9544);
#9540 = LINE('',#9541,#9542);
#9541 = CARTESIAN_POINT('',(0.,0.));
#9542 = VECTOR('',#9543,1.);
#9543 = DIRECTION('',(0.,-1.));
#9544 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9545 = ORIENTED_EDGE('',*,*,#9546,.F.);
#9546 = EDGE_CURVE('',#9439,#9517,#9547,.T.);
#9547 = SURFACE_CURVE('',#9548,(#9552,#9559),.PCURVE_S1.);
#9548 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9549,#9550,#9551),
#9549 = CARTESIAN_POINT('',(-0.283,-6.717,8.));
#9550 = CARTESIAN_POINT('',(3.E-03,-6.883,8.));
#9551 = CARTESIAN_POINT('',(5.1E-02,-7.116,8.));
#9552 = PCURVE('',#9454,#9553);
#9553 = DEFINITIONAL_REPRESENTATION('',(#9554),#9558);
#9554 = LINE('',#9555,#9556);
#9555 = CARTESIAN_POINT('',(0.,0.));
#9556 = VECTOR('',#9557,1.);
#9557 = DIRECTION('',(1.,0.));
#9558 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9559 = PCURVE('',#9399,#9560);
#9560 = DEFINITIONAL_REPRESENTATION('',(#9561),#9565);
#9561 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9562,#9563,#9564),
#9562 = CARTESIAN_POINT('',(0.382141886942,0.41234490695));
#9563 = CARTESIAN_POINT('',(0.216141886942,0.69834490695));
#9564 = CARTESIAN_POINT('',(-1.685811305773E-02,0.74634490695));
#9565 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9566 = ADVANCED_FACE('',(#9567),#9532,.T.);
#9567 = FACE_BOUND('',#9568,.T.);
#9568 = EDGE_LOOP('',(#9569,#9570,#9593,#9623));
#9569 = ORIENTED_EDGE('',*,*,#9516,.T.);
#9570 = ORIENTED_EDGE('',*,*,#9571,.T.);
#9571 = EDGE_CURVE('',#9494,#9572,#9574,.T.);
#9572 = VERTEX_POINT('',#9573);
#9573 = CARTESIAN_POINT('',(6.4E-02,-7.251,8.2));
#9574 = SURFACE_CURVE('',#9575,(#9579,#9586),.PCURVE_S1.);
#9575 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9576,#9577,#9578),
#9576 = CARTESIAN_POINT('',(5.1E-02,-7.116,8.2));
#9577 = CARTESIAN_POINT('',(6.4E-02,-7.181,8.2));
#9578 = CARTESIAN_POINT('',(6.4E-02,-7.251,8.2));
#9579 = PCURVE('',#9532,#9580);
#9580 = DEFINITIONAL_REPRESENTATION('',(#9581),#9585);
#9581 = LINE('',#9582,#9583);
#9582 = CARTESIAN_POINT('',(0.,-0.2));
#9583 = VECTOR('',#9584,1.);
#9584 = DIRECTION('',(1.,0.));
#9585 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9586 = PCURVE('',#9345,#9587);
#9587 = DEFINITIONAL_REPRESENTATION('',(#9588),#9592);
#9588 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9589,#9590,#9591),
#9589 = CARTESIAN_POINT('',(-1.685811305773E-02,0.74634490695));
#9590 = CARTESIAN_POINT('',(-8.185811305773E-02,0.75934490695));
#9591 = CARTESIAN_POINT('',(-0.151858113058,0.75934490695));
#9592 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9593 = ORIENTED_EDGE('',*,*,#9594,.F.);
#9594 = EDGE_CURVE('',#9595,#9572,#9597,.T.);
#9595 = VERTEX_POINT('',#9596);
#9596 = CARTESIAN_POINT('',(6.4E-02,-7.251,8.));
#9597 = SURFACE_CURVE('',#9598,(#9602,#9609),.PCURVE_S1.);
#9598 = LINE('',#9599,#9600);
#9599 = CARTESIAN_POINT('',(6.4E-02,-7.251,8.));
#9600 = VECTOR('',#9601,1.);
#9601 = DIRECTION('',(0.,0.,1.));
#9602 = PCURVE('',#9532,#9603);
#9603 = DEFINITIONAL_REPRESENTATION('',(#9604),#9608);
#9604 = LINE('',#9605,#9606);
#9605 = CARTESIAN_POINT('',(1.,0.));
#9606 = VECTOR('',#9607,1.);
#9607 = DIRECTION('',(0.,-1.));
#9608 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9609 = PCURVE('',#9610,#9617);
#9610 = SURFACE_OF_LINEAR_EXTRUSION('',#9611,#9615);
#9611 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9612,#9613,#9614),
#9612 = CARTESIAN_POINT('',(6.4E-02,-7.251,8.));
#9613 = CARTESIAN_POINT('',(6.4E-02,-7.574,8.));
#9614 = CARTESIAN_POINT('',(-0.152,-7.703,8.));
#9615 = VECTOR('',#9616,1.);
#9616 = DIRECTION('',(-0.,-0.,-1.));
#9617 = DEFINITIONAL_REPRESENTATION('',(#9618),#9622);
#9618 = LINE('',#9619,#9620);
#9619 = CARTESIAN_POINT('',(0.,0.));
#9620 = VECTOR('',#9621,1.);
#9621 = DIRECTION('',(0.,-1.));
#9622 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9623 = ORIENTED_EDGE('',*,*,#9624,.F.);
#9624 = EDGE_CURVE('',#9517,#9595,#9625,.T.);
#9625 = SURFACE_CURVE('',#9626,(#9630,#9637),.PCURVE_S1.);
#9626 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9627,#9628,#9629),
#9627 = CARTESIAN_POINT('',(5.1E-02,-7.116,8.));
#9628 = CARTESIAN_POINT('',(6.4E-02,-7.181,8.));
#9629 = CARTESIAN_POINT('',(6.4E-02,-7.251,8.));
#9630 = PCURVE('',#9532,#9631);
#9631 = DEFINITIONAL_REPRESENTATION('',(#9632),#9636);
#9632 = LINE('',#9633,#9634);
#9633 = CARTESIAN_POINT('',(0.,0.));
#9634 = VECTOR('',#9635,1.);
#9635 = DIRECTION('',(1.,0.));
#9636 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9637 = PCURVE('',#9399,#9638);
#9638 = DEFINITIONAL_REPRESENTATION('',(#9639),#9643);
#9639 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9640,#9641,#9642),
#9640 = CARTESIAN_POINT('',(-1.685811305773E-02,0.74634490695));
#9641 = CARTESIAN_POINT('',(-8.185811305773E-02,0.75934490695));
#9642 = CARTESIAN_POINT('',(-0.151858113058,0.75934490695));
#9643 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9644 = ADVANCED_FACE('',(#9645),#9610,.T.);
#9645 = FACE_BOUND('',#9646,.T.);
#9646 = EDGE_LOOP('',(#9647,#9648,#9671,#9701));
#9647 = ORIENTED_EDGE('',*,*,#9594,.T.);
#9648 = ORIENTED_EDGE('',*,*,#9649,.T.);
#9649 = EDGE_CURVE('',#9572,#9650,#9652,.T.);
#9650 = VERTEX_POINT('',#9651);
#9651 = CARTESIAN_POINT('',(-0.152,-7.703,8.2));
#9652 = SURFACE_CURVE('',#9653,(#9657,#9664),.PCURVE_S1.);
#9653 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9654,#9655,#9656),
#9654 = CARTESIAN_POINT('',(6.4E-02,-7.251,8.2));
#9655 = CARTESIAN_POINT('',(6.4E-02,-7.574,8.2));
#9656 = CARTESIAN_POINT('',(-0.152,-7.703,8.2));
#9657 = PCURVE('',#9610,#9658);
#9658 = DEFINITIONAL_REPRESENTATION('',(#9659),#9663);
#9659 = LINE('',#9660,#9661);
#9660 = CARTESIAN_POINT('',(0.,-0.2));
#9661 = VECTOR('',#9662,1.);
#9662 = DIRECTION('',(1.,0.));
#9663 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9664 = PCURVE('',#9345,#9665);
#9665 = DEFINITIONAL_REPRESENTATION('',(#9666),#9670);
#9666 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9667,#9668,#9669),
#9667 = CARTESIAN_POINT('',(-0.151858113058,0.75934490695));
#9668 = CARTESIAN_POINT('',(-0.474858113058,0.75934490695));
#9669 = CARTESIAN_POINT('',(-0.603858113058,0.54334490695));
#9670 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9671 = ORIENTED_EDGE('',*,*,#9672,.F.);
#9672 = EDGE_CURVE('',#9673,#9650,#9675,.T.);
#9673 = VERTEX_POINT('',#9674);
#9674 = CARTESIAN_POINT('',(-0.152,-7.703,8.));
#9675 = SURFACE_CURVE('',#9676,(#9680,#9687),.PCURVE_S1.);
#9676 = LINE('',#9677,#9678);
#9677 = CARTESIAN_POINT('',(-0.152,-7.703,8.));
#9678 = VECTOR('',#9679,1.);
#9679 = DIRECTION('',(0.,0.,1.));
#9680 = PCURVE('',#9610,#9681);
#9681 = DEFINITIONAL_REPRESENTATION('',(#9682),#9686);
#9682 = LINE('',#9683,#9684);
#9683 = CARTESIAN_POINT('',(1.,0.));
#9684 = VECTOR('',#9685,1.);
#9685 = DIRECTION('',(0.,-1.));
#9686 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9687 = PCURVE('',#9688,#9695);
#9688 = SURFACE_OF_LINEAR_EXTRUSION('',#9689,#9693);
#9689 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9690,#9691,#9692),
#9690 = CARTESIAN_POINT('',(-0.152,-7.703,8.));
#9691 = CARTESIAN_POINT('',(-0.251,-7.761,8.));
#9692 = CARTESIAN_POINT('',(-0.377,-7.761,8.));
#9693 = VECTOR('',#9694,1.);
#9694 = DIRECTION('',(-0.,-0.,-1.));
#9695 = DEFINITIONAL_REPRESENTATION('',(#9696),#9700);
#9696 = LINE('',#9697,#9698);
#9697 = CARTESIAN_POINT('',(0.,0.));
#9698 = VECTOR('',#9699,1.);
#9699 = DIRECTION('',(0.,-1.));
#9700 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9701 = ORIENTED_EDGE('',*,*,#9702,.F.);
#9702 = EDGE_CURVE('',#9595,#9673,#9703,.T.);
#9703 = SURFACE_CURVE('',#9704,(#9708,#9715),.PCURVE_S1.);
#9704 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9705,#9706,#9707),
#9705 = CARTESIAN_POINT('',(6.4E-02,-7.251,8.));
#9706 = CARTESIAN_POINT('',(6.4E-02,-7.574,8.));
#9707 = CARTESIAN_POINT('',(-0.152,-7.703,8.));
#9708 = PCURVE('',#9610,#9709);
#9709 = DEFINITIONAL_REPRESENTATION('',(#9710),#9714);
#9710 = LINE('',#9711,#9712);
#9711 = CARTESIAN_POINT('',(0.,0.));
#9712 = VECTOR('',#9713,1.);
#9713 = DIRECTION('',(1.,0.));
#9714 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9715 = PCURVE('',#9399,#9716);
#9716 = DEFINITIONAL_REPRESENTATION('',(#9717),#9721);
#9717 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9718,#9719,#9720),
#9718 = CARTESIAN_POINT('',(-0.151858113058,0.75934490695));
#9719 = CARTESIAN_POINT('',(-0.474858113058,0.75934490695));
#9720 = CARTESIAN_POINT('',(-0.603858113058,0.54334490695));
#9721 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9722 = ADVANCED_FACE('',(#9723),#9688,.T.);
#9723 = FACE_BOUND('',#9724,.T.);
#9724 = EDGE_LOOP('',(#9725,#9726,#9749,#9777));
#9725 = ORIENTED_EDGE('',*,*,#9672,.T.);
#9726 = ORIENTED_EDGE('',*,*,#9727,.T.);
#9727 = EDGE_CURVE('',#9650,#9728,#9730,.T.);
#9728 = VERTEX_POINT('',#9729);
#9729 = CARTESIAN_POINT('',(-0.377,-7.761,8.2));
#9730 = SURFACE_CURVE('',#9731,(#9735,#9742),.PCURVE_S1.);
#9731 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9732,#9733,#9734),
#9732 = CARTESIAN_POINT('',(-0.152,-7.703,8.2));
#9733 = CARTESIAN_POINT('',(-0.251,-7.761,8.2));
#9734 = CARTESIAN_POINT('',(-0.377,-7.761,8.2));
#9735 = PCURVE('',#9688,#9736);
#9736 = DEFINITIONAL_REPRESENTATION('',(#9737),#9741);
#9737 = LINE('',#9738,#9739);
#9738 = CARTESIAN_POINT('',(0.,-0.2));
#9739 = VECTOR('',#9740,1.);
#9740 = DIRECTION('',(1.,0.));
#9741 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9742 = PCURVE('',#9345,#9743);
#9743 = DEFINITIONAL_REPRESENTATION('',(#9744),#9748);
#9744 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9745,#9746,#9747),
#9745 = CARTESIAN_POINT('',(-0.603858113058,0.54334490695));
#9746 = CARTESIAN_POINT('',(-0.661858113058,0.44434490695));
#9747 = CARTESIAN_POINT('',(-0.661858113058,0.31834490695));
#9748 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9749 = ORIENTED_EDGE('',*,*,#9750,.F.);
#9750 = EDGE_CURVE('',#9751,#9728,#9753,.T.);
#9751 = VERTEX_POINT('',#9752);
#9752 = CARTESIAN_POINT('',(-0.377,-7.761,8.));
#9753 = SURFACE_CURVE('',#9754,(#9758,#9765),.PCURVE_S1.);
#9754 = LINE('',#9755,#9756);
#9755 = CARTESIAN_POINT('',(-0.377,-7.761,8.));
#9756 = VECTOR('',#9757,1.);
#9757 = DIRECTION('',(0.,0.,1.));
#9758 = PCURVE('',#9688,#9759);
#9759 = DEFINITIONAL_REPRESENTATION('',(#9760),#9764);
#9760 = LINE('',#9761,#9762);
#9761 = CARTESIAN_POINT('',(1.,0.));
#9762 = VECTOR('',#9763,1.);
#9763 = DIRECTION('',(0.,-1.));
#9764 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9765 = PCURVE('',#9766,#9771);
#9766 = PLANE('',#9767);
#9767 = AXIS2_PLACEMENT_3D('',#9768,#9769,#9770);
#9768 = CARTESIAN_POINT('',(-0.377,-7.761,8.));
#9769 = DIRECTION('',(-2.2E-16,-1.,0.));
#9770 = DIRECTION('',(-1.,2.2E-16,0.));
#9771 = DEFINITIONAL_REPRESENTATION('',(#9772),#9776);
#9772 = LINE('',#9773,#9774);
#9773 = CARTESIAN_POINT('',(4.4E-16,0.));
#9774 = VECTOR('',#9775,1.);
#9775 = DIRECTION('',(0.,-1.));
#9776 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9777 = ORIENTED_EDGE('',*,*,#9778,.F.);
#9778 = EDGE_CURVE('',#9673,#9751,#9779,.T.);
#9779 = SURFACE_CURVE('',#9780,(#9784,#9791),.PCURVE_S1.);
#9780 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9781,#9782,#9783),
#9781 = CARTESIAN_POINT('',(-0.152,-7.703,8.));
#9782 = CARTESIAN_POINT('',(-0.251,-7.761,8.));
#9783 = CARTESIAN_POINT('',(-0.377,-7.761,8.));
#9784 = PCURVE('',#9688,#9785);
#9785 = DEFINITIONAL_REPRESENTATION('',(#9786),#9790);
#9786 = LINE('',#9787,#9788);
#9787 = CARTESIAN_POINT('',(0.,0.));
#9788 = VECTOR('',#9789,1.);
#9789 = DIRECTION('',(1.,0.));
#9790 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9791 = PCURVE('',#9399,#9792);
#9792 = DEFINITIONAL_REPRESENTATION('',(#9793),#9797);
#9793 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9794,#9795,#9796),
#9794 = CARTESIAN_POINT('',(-0.603858113058,0.54334490695));
#9795 = CARTESIAN_POINT('',(-0.661858113058,0.44434490695));
#9796 = CARTESIAN_POINT('',(-0.661858113058,0.31834490695));
#9797 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9798 = ADVANCED_FACE('',(#9799),#9766,.T.);
#9799 = FACE_BOUND('',#9800,.T.);
#9800 = EDGE_LOOP('',(#9801,#9802,#9825,#9853));
#9801 = ORIENTED_EDGE('',*,*,#9750,.T.);
#9802 = ORIENTED_EDGE('',*,*,#9803,.T.);
#9803 = EDGE_CURVE('',#9728,#9804,#9806,.T.);
#9804 = VERTEX_POINT('',#9805);
#9805 = CARTESIAN_POINT('',(-1.6,-7.761,8.2));
#9806 = SURFACE_CURVE('',#9807,(#9811,#9818),.PCURVE_S1.);
#9807 = LINE('',#9808,#9809);
#9808 = CARTESIAN_POINT('',(-0.377,-7.761,8.2));
#9809 = VECTOR('',#9810,1.);
#9810 = DIRECTION('',(-1.,0.,0.));
#9811 = PCURVE('',#9766,#9812);
#9812 = DEFINITIONAL_REPRESENTATION('',(#9813),#9817);
#9813 = LINE('',#9814,#9815);
#9814 = CARTESIAN_POINT('',(0.,-0.2));
#9815 = VECTOR('',#9816,1.);
#9816 = DIRECTION('',(1.,0.));
#9817 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9818 = PCURVE('',#9345,#9819);
#9819 = DEFINITIONAL_REPRESENTATION('',(#9820),#9824);
#9820 = LINE('',#9821,#9822);
#9821 = CARTESIAN_POINT('',(-0.661858113058,0.31834490695));
#9822 = VECTOR('',#9823,1.);
#9823 = DIRECTION('',(0.,-1.));
#9824 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9825 = ORIENTED_EDGE('',*,*,#9826,.F.);
#9826 = EDGE_CURVE('',#9827,#9804,#9829,.T.);
#9827 = VERTEX_POINT('',#9828);
#9828 = CARTESIAN_POINT('',(-1.6,-7.761,8.));
#9829 = SURFACE_CURVE('',#9830,(#9834,#9841),.PCURVE_S1.);
#9830 = LINE('',#9831,#9832);
#9831 = CARTESIAN_POINT('',(-1.6,-7.761,8.));
#9832 = VECTOR('',#9833,1.);
#9833 = DIRECTION('',(0.,0.,1.));
#9834 = PCURVE('',#9766,#9835);
#9835 = DEFINITIONAL_REPRESENTATION('',(#9836),#9840);
#9836 = LINE('',#9837,#9838);
#9837 = CARTESIAN_POINT('',(1.223,0.));
#9838 = VECTOR('',#9839,1.);
#9839 = DIRECTION('',(0.,-1.));
#9840 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
PARAMETRIC_REPRESENTATION_CONTEXT() REPRESENTATION_CONTEXT('2D SPACE',''
#9841 = PCURVE('',#9842,#9847);
#9842 = PLANE('',#9843);
#9843 = AXIS2_PLACEMENT_3D('',#9844,#9845,#9846);
#9844 = CARTESIAN_POINT('',(-1.6,-7.761,8.));
#9845 = DIRECTION('',(-1.,2.2E-16,0.));
#9846 = DIRECTION('',(2.2E-16,1.,0.));
#9847 = DEFINITIONAL_REPRESENTATION('',(#9848),#9852);
#9848 = LINE('',#9849,#9850);
#9849 = CARTESIAN_POINT('',(-8.9E-16,0.));
#9850 = VECTOR('',#9851,1.);
#9851 = DIRECTION('',(0.,-1.));
#9852 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9853 = ORIENTED_EDGE('',*,*,#9854,.F.);
#9854 = EDGE_CURVE('',#9751,#9827,#9855,.T.);
#9855 = SURFACE_CURVE('',#9856,(#9860,#9867),.PCURVE_S1.);
#9856 = LINE('',#9857,#9858);
#9857 = CARTESIAN_POINT('',(-0.377,-7.761,8.));
#9858 = VECTOR('',#9859,1.);
#9859 = DIRECTION('',(-1.,0.,0.));
#9860 = PCURVE('',#9766,#9861);
#9861 = DEFINITIONAL_REPRESENTATION('',(#9862),#9866);
#9862 = LINE('',#9863,#9864);
#9863 = CARTESIAN_POINT('',(0.,0.));
#9864 = VECTOR('',#9865,1.);
#9865 = DIRECTION('',(1.,0.));
#9866 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9867 = PCURVE('',#9399,#9868);
#9868 = DEFINITIONAL_REPRESENTATION('',(#9869),#9873);
#9869 = LINE('',#9870,#9871);
#9870 = CARTESIAN_POINT('',(-0.661858113058,0.31834490695));
#9871 = VECTOR('',#9872,1.);
#9872 = DIRECTION('',(0.,-1.));
#9873 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9874 = ADVANCED_FACE('',(#9875),#9842,.T.);
#9875 = FACE_BOUND('',#9876,.T.);
#9876 = EDGE_LOOP('',(#9877,#9878,#9901,#9929));
#9877 = ORIENTED_EDGE('',*,*,#9826,.T.);
#9878 = ORIENTED_EDGE('',*,*,#9879,.T.);
#9879 = EDGE_CURVE('',#9804,#9880,#9882,.T.);
#9880 = VERTEX_POINT('',#9881);
#9881 = CARTESIAN_POINT('',(-1.6,-7.506,8.2));
#9882 = SURFACE_CURVE('',#9883,(#9887,#9894),.PCURVE_S1.);
#9883 = LINE('',#9884,#9885);
#9884 = CARTESIAN_POINT('',(-1.6,-7.761,8.2));
#9885 = VECTOR('',#9886,1.);
#9886 = DIRECTION('',(0.,1.,0.));
#9887 = PCURVE('',#9842,#9888);
#9888 = DEFINITIONAL_REPRESENTATION('',(#9889),#9893);
#9889 = LINE('',#9890,#9891);
#9890 = CARTESIAN_POINT('',(0.,-0.2));
#9891 = VECTOR('',#9892,1.);
#9892 = DIRECTION('',(1.,0.));
#9893 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9894 = PCURVE('',#9345,#9895);
#9895 = DEFINITIONAL_REPRESENTATION('',(#9896),#9900);
#9896 = LINE('',#9897,#9898);
#9897 = CARTESIAN_POINT('',(-0.661858113058,-0.90465509305));
#9898 = VECTOR('',#9899,1.);
#9899 = DIRECTION('',(1.,0.));
#9900 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9901 = ORIENTED_EDGE('',*,*,#9902,.F.);
#9902 = EDGE_CURVE('',#9903,#9880,#9905,.T.);
#9903 = VERTEX_POINT('',#9904);
#9904 = CARTESIAN_POINT('',(-1.6,-7.506,8.));
#9905 = SURFACE_CURVE('',#9906,(#9910,#9917),.PCURVE_S1.);
#9906 = LINE('',#9907,#9908);
#9907 = CARTESIAN_POINT('',(-1.6,-7.506,8.));
#9908 = VECTOR('',#9909,1.);
#9909 = DIRECTION('',(0.,0.,1.));
#9910 = PCURVE('',#9842,#9911);
#9911 = DEFINITIONAL_REPRESENTATION('',(#9912),#9916);
#9912 = LINE('',#9913,#9914);
#9913 = CARTESIAN_POINT('',(0.255,0.));
#9914 = VECTOR('',#9915,1.);
#9915 = DIRECTION('',(0.,-1.));
#9916 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9917 = PCURVE('',#9918,#9923);
#9918 = PLANE('',#9919);
#9919 = AXIS2_PLACEMENT_3D('',#9920,#9921,#9922);
#9920 = CARTESIAN_POINT('',(-1.6,-7.506,8.));
#9921 = DIRECTION('',(2.2E-16,1.,0.));
#9922 = DIRECTION('',(1.,-2.2E-16,0.));
#9923 = DEFINITIONAL_REPRESENTATION('',(#9924),#9928);
#9924 = LINE('',#9925,#9926);
#9925 = CARTESIAN_POINT('',(1.55E-15,0.));
#9926 = VECTOR('',#9927,1.);
#9927 = DIRECTION('',(0.,-1.));
#9928 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9929 = ORIENTED_EDGE('',*,*,#9930,.F.);
#9930 = EDGE_CURVE('',#9827,#9903,#9931,.T.);
#9931 = SURFACE_CURVE('',#9932,(#9936,#9943),.PCURVE_S1.);
#9932 = LINE('',#9933,#9934);
#9933 = CARTESIAN_POINT('',(-1.6,-7.761,8.));
#9934 = VECTOR('',#9935,1.);
#9935 = DIRECTION('',(0.,1.,0.));
#9936 = PCURVE('',#9842,#9937);
#9937 = DEFINITIONAL_REPRESENTATION('',(#9938),#9942);
#9938 = LINE('',#9939,#9940);
#9939 = CARTESIAN_POINT('',(0.,0.));
#9940 = VECTOR('',#9941,1.);
#9941 = DIRECTION('',(1.,0.));
#9942 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9943 = PCURVE('',#9399,#9944);
#9944 = DEFINITIONAL_REPRESENTATION('',(#9945),#9949);
#9945 = LINE('',#9946,#9947);
#9946 = CARTESIAN_POINT('',(-0.661858113058,-0.90465509305));
#9947 = VECTOR('',#9948,1.);
#9948 = DIRECTION('',(1.,0.));
#9949 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9950 = ADVANCED_FACE('',(#9951),#9918,.T.);
#9951 = FACE_BOUND('',#9952,.T.);
#9952 = EDGE_LOOP('',(#9953,#9954,#9977,#10007));
#9953 = ORIENTED_EDGE('',*,*,#9902,.T.);
#9954 = ORIENTED_EDGE('',*,*,#9955,.T.);
#9955 = EDGE_CURVE('',#9880,#9956,#9958,.T.);
#9956 = VERTEX_POINT('',#9957);
#9957 = CARTESIAN_POINT('',(-0.503,-7.506,8.2));
#9958 = SURFACE_CURVE('',#9959,(#9963,#9970),.PCURVE_S1.);
#9959 = LINE('',#9960,#9961);
#9960 = CARTESIAN_POINT('',(-1.6,-7.506,8.2));
#9961 = VECTOR('',#9962,1.);
#9962 = DIRECTION('',(1.,0.,0.));
#9963 = PCURVE('',#9918,#9964);
#9964 = DEFINITIONAL_REPRESENTATION('',(#9965),#9969);
#9965 = LINE('',#9966,#9967);
#9966 = CARTESIAN_POINT('',(0.,-0.2));
#9967 = VECTOR('',#9968,1.);
#9968 = DIRECTION('',(1.,0.));
#9969 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9970 = PCURVE('',#9345,#9971);
#9971 = DEFINITIONAL_REPRESENTATION('',(#9972),#9976);
#9972 = LINE('',#9973,#9974);
#9973 = CARTESIAN_POINT('',(-0.406858113058,-0.90465509305));
#9974 = VECTOR('',#9975,1.);
#9975 = DIRECTION('',(0.,1.));
#9976 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9977 = ORIENTED_EDGE('',*,*,#9978,.F.);
#9978 = EDGE_CURVE('',#9979,#9956,#9981,.T.);
#9979 = VERTEX_POINT('',#9980);
#9980 = CARTESIAN_POINT('',(-0.503,-7.506,8.));
#9981 = SURFACE_CURVE('',#9982,(#9986,#9993),.PCURVE_S1.);
#9982 = LINE('',#9983,#9984);
#9983 = CARTESIAN_POINT('',(-0.503,-7.506,8.));
#9984 = VECTOR('',#9985,1.);
#9985 = DIRECTION('',(0.,0.,1.));
#9986 = PCURVE('',#9918,#9987);
#9987 = DEFINITIONAL_REPRESENTATION('',(#9988),#9992);
#9988 = LINE('',#9989,#9990);
#9989 = CARTESIAN_POINT('',(1.097,0.));
#9990 = VECTOR('',#9991,1.);
#9991 = DIRECTION('',(0.,-1.));
#9992 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#9993 = PCURVE('',#9994,#10001);
#9994 = SURFACE_OF_LINEAR_EXTRUSION('',#9995,#9999);
#9995 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#9996,#9997,#9998),
#9996 = CARTESIAN_POINT('',(-0.503,-7.506,8.));
#9997 = CARTESIAN_POINT('',(-0.292,-7.506,8.));
#9998 = CARTESIAN_POINT('',(-0.219,-7.325,8.));
#9999 = VECTOR('',#10000,1.);
#10000 = DIRECTION('',(-0.,-0.,-1.));
#10001 = DEFINITIONAL_REPRESENTATION('',(#10002),#10006);
#10002 = LINE('',#10003,#10004);
#10003 = CARTESIAN_POINT('',(0.,0.));
#10004 = VECTOR('',#10005,1.);
#10005 = DIRECTION('',(0.,-1.));
#10006 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10007 = ORIENTED_EDGE('',*,*,#10008,.F.);
#10008 = EDGE_CURVE('',#9903,#9979,#10009,.T.);
#10009 = SURFACE_CURVE('',#10010,(#10014,#10021),.PCURVE_S1.);
#10010 = LINE('',#10011,#10012);
#10011 = CARTESIAN_POINT('',(-1.6,-7.506,8.));
#10012 = VECTOR('',#10013,1.);
#10013 = DIRECTION('',(1.,0.,0.));
#10014 = PCURVE('',#9918,#10015);
#10015 = DEFINITIONAL_REPRESENTATION('',(#10016),#10020);
#10016 = LINE('',#10017,#10018);
#10017 = CARTESIAN_POINT('',(0.,0.));
#10018 = VECTOR('',#10019,1.);
#10019 = DIRECTION('',(1.,0.));
#10020 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10021 = PCURVE('',#9399,#10022);
#10022 = DEFINITIONAL_REPRESENTATION('',(#10023),#10027);
#10023 = LINE('',#10024,#10025);
#10024 = CARTESIAN_POINT('',(-0.406858113058,-0.90465509305));
#10025 = VECTOR('',#10026,1.);
#10026 = DIRECTION('',(0.,1.));
#10027 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10028 = ADVANCED_FACE('',(#10029),#9994,.T.);
#10029 = FACE_BOUND('',#10030,.T.);
#10030 = EDGE_LOOP('',(#10031,#10032,#10055,#10085));
#10031 = ORIENTED_EDGE('',*,*,#9978,.T.);
#10032 = ORIENTED_EDGE('',*,*,#10033,.T.);
#10033 = EDGE_CURVE('',#9956,#10034,#10036,.T.);
#10034 = VERTEX_POINT('',#10035);
#10035 = CARTESIAN_POINT('',(-0.219,-7.325,8.2));
#10036 = SURFACE_CURVE('',#10037,(#10041,#10048),.PCURVE_S1.);
#10037 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10038,#10039,#10040),
#10038 = CARTESIAN_POINT('',(-0.503,-7.506,8.2));
#10039 = CARTESIAN_POINT('',(-0.292,-7.506,8.2));
#10040 = CARTESIAN_POINT('',(-0.219,-7.325,8.2));
#10041 = PCURVE('',#9994,#10042);
#10042 = DEFINITIONAL_REPRESENTATION('',(#10043),#10047);
#10043 = LINE('',#10044,#10045);
#10044 = CARTESIAN_POINT('',(0.,-0.2));
#10045 = VECTOR('',#10046,1.);
#10046 = DIRECTION('',(1.,0.));
#10047 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10048 = PCURVE('',#9345,#10049);
#10049 = DEFINITIONAL_REPRESENTATION('',(#10050),#10054);
#10050 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10051,#10052,#10053),
#10051 = CARTESIAN_POINT('',(-0.406858113058,0.19234490695));
#10052 = CARTESIAN_POINT('',(-0.406858113058,0.40334490695));
#10053 = CARTESIAN_POINT('',(-0.225858113058,0.47634490695));
#10054 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10055 = ORIENTED_EDGE('',*,*,#10056,.F.);
#10056 = EDGE_CURVE('',#10057,#10034,#10059,.T.);
#10057 = VERTEX_POINT('',#10058);
#10058 = CARTESIAN_POINT('',(-0.219,-7.325,8.));
#10059 = SURFACE_CURVE('',#10060,(#10064,#10071),.PCURVE_S1.);
#10060 = LINE('',#10061,#10062);
#10061 = CARTESIAN_POINT('',(-0.219,-7.325,8.));
#10062 = VECTOR('',#10063,1.);
#10063 = DIRECTION('',(0.,0.,1.));
#10064 = PCURVE('',#9994,#10065);
#10065 = DEFINITIONAL_REPRESENTATION('',(#10066),#10070);
#10066 = LINE('',#10067,#10068);
#10067 = CARTESIAN_POINT('',(1.,0.));
#10068 = VECTOR('',#10069,1.);
#10069 = DIRECTION('',(0.,-1.));
#10070 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10071 = PCURVE('',#10072,#10079);
#10072 = SURFACE_OF_LINEAR_EXTRUSION('',#10073,#10077);
#10073 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10074,#10075,#10076),
#10074 = CARTESIAN_POINT('',(-0.219,-7.325,8.));
#10075 = CARTESIAN_POINT('',(-0.192,-7.257,8.));
#10076 = CARTESIAN_POINT('',(-0.192,-7.174,8.));
#10077 = VECTOR('',#10078,1.);
#10078 = DIRECTION('',(-0.,-0.,-1.));
#10079 = DEFINITIONAL_REPRESENTATION('',(#10080),#10084);
#10080 = LINE('',#10081,#10082);
#10081 = CARTESIAN_POINT('',(0.,0.));
#10082 = VECTOR('',#10083,1.);
#10083 = DIRECTION('',(0.,-1.));
#10084 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10085 = ORIENTED_EDGE('',*,*,#10086,.F.);
#10086 = EDGE_CURVE('',#9979,#10057,#10087,.T.);
#10087 = SURFACE_CURVE('',#10088,(#10092,#10099),.PCURVE_S1.);
#10088 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10089,#10090,#10091),
#10089 = CARTESIAN_POINT('',(-0.503,-7.506,8.));
#10090 = CARTESIAN_POINT('',(-0.292,-7.506,8.));
#10091 = CARTESIAN_POINT('',(-0.219,-7.325,8.));
#10092 = PCURVE('',#9994,#10093);
#10093 = DEFINITIONAL_REPRESENTATION('',(#10094),#10098);
#10094 = LINE('',#10095,#10096);
#10095 = CARTESIAN_POINT('',(0.,0.));
#10096 = VECTOR('',#10097,1.);
#10097 = DIRECTION('',(1.,0.));
#10098 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10099 = PCURVE('',#9399,#10100);
#10100 = DEFINITIONAL_REPRESENTATION('',(#10101),#10105);
#10101 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10102,#10103,#10104),
#10102 = CARTESIAN_POINT('',(-0.406858113058,0.19234490695));
#10103 = CARTESIAN_POINT('',(-0.406858113058,0.40334490695));
#10104 = CARTESIAN_POINT('',(-0.225858113058,0.47634490695));
#10105 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10106 = ADVANCED_FACE('',(#10107),#10072,.T.);
#10107 = FACE_BOUND('',#10108,.T.);
#10108 = EDGE_LOOP('',(#10109,#10110,#10133,#10163));
#10109 = ORIENTED_EDGE('',*,*,#10056,.T.);
#10110 = ORIENTED_EDGE('',*,*,#10111,.T.);
#10111 = EDGE_CURVE('',#10034,#10112,#10114,.T.);
#10112 = VERTEX_POINT('',#10113);
#10113 = CARTESIAN_POINT('',(-0.192,-7.174,8.2));
#10114 = SURFACE_CURVE('',#10115,(#10119,#10126),.PCURVE_S1.);
#10115 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10116,#10117,#10118),
#10116 = CARTESIAN_POINT('',(-0.219,-7.325,8.2));
#10117 = CARTESIAN_POINT('',(-0.192,-7.257,8.2));
#10118 = CARTESIAN_POINT('',(-0.192,-7.174,8.2));
#10119 = PCURVE('',#10072,#10120);
#10120 = DEFINITIONAL_REPRESENTATION('',(#10121),#10125);
#10121 = LINE('',#10122,#10123);
#10122 = CARTESIAN_POINT('',(0.,-0.2));
#10123 = VECTOR('',#10124,1.);
#10124 = DIRECTION('',(1.,0.));
#10125 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10126 = PCURVE('',#9345,#10127);
#10127 = DEFINITIONAL_REPRESENTATION('',(#10128),#10132);
#10128 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10129,#10130,#10131),
#10129 = CARTESIAN_POINT('',(-0.225858113058,0.47634490695));
#10130 = CARTESIAN_POINT('',(-0.157858113058,0.50334490695));
#10131 = CARTESIAN_POINT('',(-7.485811305773E-02,0.50334490695));
#10132 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10133 = ORIENTED_EDGE('',*,*,#10134,.F.);
#10134 = EDGE_CURVE('',#10135,#10112,#10137,.T.);
#10135 = VERTEX_POINT('',#10136);
#10136 = CARTESIAN_POINT('',(-0.192,-7.174,8.));
#10137 = SURFACE_CURVE('',#10138,(#10142,#10149),.PCURVE_S1.);
#10138 = LINE('',#10139,#10140);
#10139 = CARTESIAN_POINT('',(-0.192,-7.174,8.));
#10140 = VECTOR('',#10141,1.);
#10141 = DIRECTION('',(0.,0.,1.));
#10142 = PCURVE('',#10072,#10143);
#10143 = DEFINITIONAL_REPRESENTATION('',(#10144),#10148);
#10144 = LINE('',#10145,#10146);
#10145 = CARTESIAN_POINT('',(1.,0.));
#10146 = VECTOR('',#10147,1.);
#10147 = DIRECTION('',(0.,-1.));
#10148 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10149 = PCURVE('',#10150,#10157);
#10150 = SURFACE_OF_LINEAR_EXTRUSION('',#10151,#10155);
#10151 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10152,#10153,#10154),
#10152 = CARTESIAN_POINT('',(-0.192,-7.174,8.));
#10153 = CARTESIAN_POINT('',(-0.192,-6.916,8.));
#10154 = CARTESIAN_POINT('',(-0.425,-6.803,8.));
#10155 = VECTOR('',#10156,1.);
#10156 = DIRECTION('',(-0.,-0.,-1.));
#10157 = DEFINITIONAL_REPRESENTATION('',(#10158),#10162);
#10158 = LINE('',#10159,#10160);
#10159 = CARTESIAN_POINT('',(0.,0.));
#10160 = VECTOR('',#10161,1.);
#10161 = DIRECTION('',(0.,-1.));
#10162 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10163 = ORIENTED_EDGE('',*,*,#10164,.F.);
#10164 = EDGE_CURVE('',#10057,#10135,#10165,.T.);
#10165 = SURFACE_CURVE('',#10166,(#10170,#10177),.PCURVE_S1.);
#10166 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10167,#10168,#10169),
#10167 = CARTESIAN_POINT('',(-0.219,-7.325,8.));
#10168 = CARTESIAN_POINT('',(-0.192,-7.257,8.));
#10169 = CARTESIAN_POINT('',(-0.192,-7.174,8.));
#10170 = PCURVE('',#10072,#10171);
#10171 = DEFINITIONAL_REPRESENTATION('',(#10172),#10176);
#10172 = LINE('',#10173,#10174);
#10173 = CARTESIAN_POINT('',(0.,0.));
#10174 = VECTOR('',#10175,1.);
#10175 = DIRECTION('',(1.,0.));
#10176 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10177 = PCURVE('',#9399,#10178);
#10178 = DEFINITIONAL_REPRESENTATION('',(#10179),#10183);
#10179 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10180,#10181,#10182),
#10180 = CARTESIAN_POINT('',(-0.225858113058,0.47634490695));
#10181 = CARTESIAN_POINT('',(-0.157858113058,0.50334490695));
#10182 = CARTESIAN_POINT('',(-7.485811305773E-02,0.50334490695));
#10183 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10184 = ADVANCED_FACE('',(#10185),#10150,.T.);
#10185 = FACE_BOUND('',#10186,.T.);
#10186 = EDGE_LOOP('',(#10187,#10188,#10211,#10241));
#10187 = ORIENTED_EDGE('',*,*,#10134,.T.);
#10188 = ORIENTED_EDGE('',*,*,#10189,.T.);
#10189 = EDGE_CURVE('',#10112,#10190,#10192,.T.);
#10190 = VERTEX_POINT('',#10191);
#10191 = CARTESIAN_POINT('',(-0.425,-6.803,8.2));
#10192 = SURFACE_CURVE('',#10193,(#10197,#10204),.PCURVE_S1.);
#10193 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10194,#10195,#10196),
#10194 = CARTESIAN_POINT('',(-0.192,-7.174,8.2));
#10195 = CARTESIAN_POINT('',(-0.192,-6.916,8.2));
#10196 = CARTESIAN_POINT('',(-0.425,-6.803,8.2));
#10197 = PCURVE('',#10150,#10198);
#10198 = DEFINITIONAL_REPRESENTATION('',(#10199),#10203);
#10199 = LINE('',#10200,#10201);
#10200 = CARTESIAN_POINT('',(0.,-0.2));
#10201 = VECTOR('',#10202,1.);
#10202 = DIRECTION('',(1.,0.));
#10203 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10204 = PCURVE('',#9345,#10205);
#10205 = DEFINITIONAL_REPRESENTATION('',(#10206),#10210);
#10206 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10207,#10208,#10209),
#10207 = CARTESIAN_POINT('',(-7.485811305773E-02,0.50334490695));
#10208 = CARTESIAN_POINT('',(0.183141886942,0.50334490695));
#10209 = CARTESIAN_POINT('',(0.296141886942,0.27034490695));
#10210 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10211 = ORIENTED_EDGE('',*,*,#10212,.F.);
#10212 = EDGE_CURVE('',#10213,#10190,#10215,.T.);
#10213 = VERTEX_POINT('',#10214);
#10214 = CARTESIAN_POINT('',(-0.425,-6.803,8.));
#10215 = SURFACE_CURVE('',#10216,(#10220,#10227),.PCURVE_S1.);
#10216 = LINE('',#10217,#10218);
#10217 = CARTESIAN_POINT('',(-0.425,-6.803,8.));
#10218 = VECTOR('',#10219,1.);
#10219 = DIRECTION('',(0.,0.,1.));
#10220 = PCURVE('',#10150,#10221);
#10221 = DEFINITIONAL_REPRESENTATION('',(#10222),#10226);
#10222 = LINE('',#10223,#10224);
#10223 = CARTESIAN_POINT('',(1.,0.));
#10224 = VECTOR('',#10225,1.);
#10225 = DIRECTION('',(0.,-1.));
#10226 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10227 = PCURVE('',#10228,#10235);
#10228 = SURFACE_OF_LINEAR_EXTRUSION('',#10229,#10233);
#10229 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10230,#10231,#10232),
#10230 = CARTESIAN_POINT('',(-0.425,-6.803,8.));
#10231 = CARTESIAN_POINT('',(-0.555,-6.738,8.));
#10232 = CARTESIAN_POINT('',(-0.727,-6.738,8.));
#10233 = VECTOR('',#10234,1.);
#10234 = DIRECTION('',(-0.,-0.,-1.));
#10235 = DEFINITIONAL_REPRESENTATION('',(#10236),#10240);
#10236 = LINE('',#10237,#10238);
#10237 = CARTESIAN_POINT('',(0.,0.));
#10238 = VECTOR('',#10239,1.);
#10239 = DIRECTION('',(0.,-1.));
#10240 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10241 = ORIENTED_EDGE('',*,*,#10242,.F.);
#10242 = EDGE_CURVE('',#10135,#10213,#10243,.T.);
#10243 = SURFACE_CURVE('',#10244,(#10248,#10255),.PCURVE_S1.);
#10244 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10245,#10246,#10247),
#10245 = CARTESIAN_POINT('',(-0.192,-7.174,8.));
#10246 = CARTESIAN_POINT('',(-0.192,-6.916,8.));
#10247 = CARTESIAN_POINT('',(-0.425,-6.803,8.));
#10248 = PCURVE('',#10150,#10249);
#10249 = DEFINITIONAL_REPRESENTATION('',(#10250),#10254);
#10250 = LINE('',#10251,#10252);
#10251 = CARTESIAN_POINT('',(0.,0.));
#10252 = VECTOR('',#10253,1.);
#10253 = DIRECTION('',(1.,0.));
#10254 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10255 = PCURVE('',#9399,#10256);
#10256 = DEFINITIONAL_REPRESENTATION('',(#10257),#10261);
#10257 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10258,#10259,#10260),
#10258 = CARTESIAN_POINT('',(-7.485811305773E-02,0.50334490695));
#10259 = CARTESIAN_POINT('',(0.183141886942,0.50334490695));
#10260 = CARTESIAN_POINT('',(0.296141886942,0.27034490695));
#10261 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10262 = ADVANCED_FACE('',(#10263),#10228,.T.);
#10263 = FACE_BOUND('',#10264,.T.);
#10264 = EDGE_LOOP('',(#10265,#10266,#10289,#10317));
#10265 = ORIENTED_EDGE('',*,*,#10212,.T.);
#10266 = ORIENTED_EDGE('',*,*,#10267,.T.);
#10267 = EDGE_CURVE('',#10190,#10268,#10270,.T.);
#10268 = VERTEX_POINT('',#10269);
#10269 = CARTESIAN_POINT('',(-0.727,-6.738,8.2));
#10270 = SURFACE_CURVE('',#10271,(#10275,#10282),.PCURVE_S1.);
#10271 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10272,#10273,#10274),
#10272 = CARTESIAN_POINT('',(-0.425,-6.803,8.2));
#10273 = CARTESIAN_POINT('',(-0.555,-6.738,8.2));
#10274 = CARTESIAN_POINT('',(-0.727,-6.738,8.2));
#10275 = PCURVE('',#10228,#10276);
#10276 = DEFINITIONAL_REPRESENTATION('',(#10277),#10281);
#10277 = LINE('',#10278,#10279);
#10278 = CARTESIAN_POINT('',(0.,-0.2));
#10279 = VECTOR('',#10280,1.);
#10280 = DIRECTION('',(1.,0.));
#10281 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10282 = PCURVE('',#9345,#10283);
#10283 = DEFINITIONAL_REPRESENTATION('',(#10284),#10288);
#10284 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10285,#10286,#10287),
#10285 = CARTESIAN_POINT('',(0.296141886942,0.27034490695));
#10286 = CARTESIAN_POINT('',(0.361141886942,0.14034490695));
#10287 = CARTESIAN_POINT('',(0.361141886942,-3.165509304972E-02));
#10288 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10289 = ORIENTED_EDGE('',*,*,#10290,.F.);
#10290 = EDGE_CURVE('',#10291,#10268,#10293,.T.);
#10291 = VERTEX_POINT('',#10292);
#10292 = CARTESIAN_POINT('',(-0.727,-6.738,8.));
#10293 = SURFACE_CURVE('',#10294,(#10298,#10305),.PCURVE_S1.);
#10294 = LINE('',#10295,#10296);
#10295 = CARTESIAN_POINT('',(-0.727,-6.738,8.));
#10296 = VECTOR('',#10297,1.);
#10297 = DIRECTION('',(0.,0.,1.));
#10298 = PCURVE('',#10228,#10299);
#10299 = DEFINITIONAL_REPRESENTATION('',(#10300),#10304);
#10300 = LINE('',#10301,#10302);
#10301 = CARTESIAN_POINT('',(1.,0.));
#10302 = VECTOR('',#10303,1.);
#10303 = DIRECTION('',(0.,-1.));
#10304 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10305 = PCURVE('',#10306,#10311);
#10306 = PLANE('',#10307);
#10307 = AXIS2_PLACEMENT_3D('',#10308,#10309,#10310);
#10308 = CARTESIAN_POINT('',(-0.727,-6.738,8.));
#10309 = DIRECTION('',(-2.2E-16,-1.,0.));
#10310 = DIRECTION('',(-1.,2.2E-16,0.));
#10311 = DEFINITIONAL_REPRESENTATION('',(#10312),#10316);
#10312 = LINE('',#10313,#10314);
#10313 = CARTESIAN_POINT('',(-4.4E-16,0.));
#10314 = VECTOR('',#10315,1.);
#10315 = DIRECTION('',(0.,-1.));
#10316 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10317 = ORIENTED_EDGE('',*,*,#10318,.F.);
#10318 = EDGE_CURVE('',#10213,#10291,#10319,.T.);
#10319 = SURFACE_CURVE('',#10320,(#10324,#10331),.PCURVE_S1.);
#10320 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10321,#10322,#10323),
#10321 = CARTESIAN_POINT('',(-0.425,-6.803,8.));
#10322 = CARTESIAN_POINT('',(-0.555,-6.738,8.));
#10323 = CARTESIAN_POINT('',(-0.727,-6.738,8.));
#10324 = PCURVE('',#10228,#10325);
#10325 = DEFINITIONAL_REPRESENTATION('',(#10326),#10330);
#10326 = LINE('',#10327,#10328);
#10327 = CARTESIAN_POINT('',(0.,0.));
#10328 = VECTOR('',#10329,1.);
#10329 = DIRECTION('',(1.,0.));
#10330 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10331 = PCURVE('',#9399,#10332);
#10332 = DEFINITIONAL_REPRESENTATION('',(#10333),#10337);
#10333 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#10334,#10335,#10336),
#10334 = CARTESIAN_POINT('',(0.296141886942,0.27034490695));
#10335 = CARTESIAN_POINT('',(0.361141886942,0.14034490695));
#10336 = CARTESIAN_POINT('',(0.361141886942,-3.165509304972E-02));
#10337 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10338 = ADVANCED_FACE('',(#10339),#10306,.T.);
#10339 = FACE_BOUND('',#10340,.T.);
#10340 = EDGE_LOOP('',(#10341,#10342,#10365,#10393));
#10341 = ORIENTED_EDGE('',*,*,#10290,.T.);
#10342 = ORIENTED_EDGE('',*,*,#10343,.T.);
#10343 = EDGE_CURVE('',#10268,#10344,#10346,.T.);
#10344 = VERTEX_POINT('',#10345);
#10345 = CARTESIAN_POINT('',(-1.6,-6.738,8.2));
#10346 = SURFACE_CURVE('',#10347,(#10351,#10358),.PCURVE_S1.);
#10347 = LINE('',#10348,#10349);
#10348 = CARTESIAN_POINT('',(-0.727,-6.738,8.2));
#10349 = VECTOR('',#10350,1.);
#10350 = DIRECTION('',(-1.,0.,0.));
#10351 = PCURVE('',#10306,#10352);
#10352 = DEFINITIONAL_REPRESENTATION('',(#10353),#10357);
#10353 = LINE('',#10354,#10355);
#10354 = CARTESIAN_POINT('',(0.,-0.2));
#10355 = VECTOR('',#10356,1.);
#10356 = DIRECTION('',(1.,0.));
#10357 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10358 = PCURVE('',#9345,#10359);
#10359 = DEFINITIONAL_REPRESENTATION('',(#10360),#10364);
#10360 = LINE('',#10361,#10362);
#10361 = CARTESIAN_POINT('',(0.361141886942,-3.165509304972E-02));
#10362 = VECTOR('',#10363,1.);
#10363 = DIRECTION('',(0.,-1.));
#10364 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10365 = ORIENTED_EDGE('',*,*,#10366,.F.);
#10366 = EDGE_CURVE('',#10367,#10344,#10369,.T.);
#10367 = VERTEX_POINT('',#10368);
#10368 = CARTESIAN_POINT('',(-1.6,-6.738,8.));
#10369 = SURFACE_CURVE('',#10370,(#10374,#10381),.PCURVE_S1.);
#10370 = LINE('',#10371,#10372);
#10371 = CARTESIAN_POINT('',(-1.6,-6.738,8.));
#10372 = VECTOR('',#10373,1.);
#10373 = DIRECTION('',(0.,0.,1.));
#10374 = PCURVE('',#10306,#10375);
#10375 = DEFINITIONAL_REPRESENTATION('',(#10376),#10380);
#10376 = LINE('',#10377,#10378);
#10377 = CARTESIAN_POINT('',(0.873,0.));
#10378 = VECTOR('',#10379,1.);
#10379 = DIRECTION('',(0.,-1.));
#10380 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10381 = PCURVE('',#10382,#10387);
#10382 = PLANE('',#10383);
#10383 = AXIS2_PLACEMENT_3D('',#10384,#10385,#10386);
#10384 = CARTESIAN_POINT('',(-1.6,-6.738,8.));
#10385 = DIRECTION('',(-1.,2.2E-16,0.));
#10386 = DIRECTION('',(2.2E-16,1.,0.));
#10387 = DEFINITIONAL_REPRESENTATION('',(#10388),#10392);
#10388 = LINE('',#10389,#10390);
#10389 = CARTESIAN_POINT('',(-8.9E-16,0.));
#10390 = VECTOR('',#10391,1.);
#10391 = DIRECTION('',(0.,-1.));
#10392 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10393 = ORIENTED_EDGE('',*,*,#10394,.F.);
#10394 = EDGE_CURVE('',#10291,#10367,#10395,.T.);
#10395 = SURFACE_CURVE('',#10396,(#10400,#10407),.PCURVE_S1.);
#10396 = LINE('',#10397,#10398);
#10397 = CARTESIAN_POINT('',(-0.727,-6.738,8.));
#10398 = VECTOR('',#10399,1.);
#10399 = DIRECTION('',(-1.,0.,0.));
#10400 = PCURVE('',#10306,#10401);
#10401 = DEFINITIONAL_REPRESENTATION('',(#10402),#10406);
#10402 = LINE('',#10403,#10404);
#10403 = CARTESIAN_POINT('',(0.,0.));
#10404 = VECTOR('',#10405,1.);
#10405 = DIRECTION('',(1.,0.));
#10406 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10407 = PCURVE('',#9399,#10408);
#10408 = DEFINITIONAL_REPRESENTATION('',(#10409),#10413);
#10409 = LINE('',#10410,#10411);
#10410 = CARTESIAN_POINT('',(0.361141886942,-3.165509304972E-02));
#10411 = VECTOR('',#10412,1.);
#10412 = DIRECTION('',(0.,-1.));
#10413 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10414 = ADVANCED_FACE('',(#10415),#10382,.T.);
#10415 = FACE_BOUND('',#10416,.T.);
#10416 = EDGE_LOOP('',(#10417,#10418,#10441,#10464));
#10417 = ORIENTED_EDGE('',*,*,#10366,.T.);
#10418 = ORIENTED_EDGE('',*,*,#10419,.T.);
#10419 = EDGE_CURVE('',#10344,#10420,#10422,.T.);
#10420 = VERTEX_POINT('',#10421);
#10421 = CARTESIAN_POINT('',(-1.6,-6.48,8.2));
#10422 = SURFACE_CURVE('',#10423,(#10427,#10434),.PCURVE_S1.);
#10423 = LINE('',#10424,#10425);
#10424 = CARTESIAN_POINT('',(-1.6,-6.738,8.2));
#10425 = VECTOR('',#10426,1.);
#10426 = DIRECTION('',(0.,1.,0.));
#10427 = PCURVE('',#10382,#10428);
#10428 = DEFINITIONAL_REPRESENTATION('',(#10429),#10433);
#10429 = LINE('',#10430,#10431);
#10430 = CARTESIAN_POINT('',(0.,-0.2));
#10431 = VECTOR('',#10432,1.);
#10432 = DIRECTION('',(1.,0.));
#10433 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10434 = PCURVE('',#9345,#10435);
#10435 = DEFINITIONAL_REPRESENTATION('',(#10436),#10440);
#10436 = LINE('',#10437,#10438);
#10437 = CARTESIAN_POINT('',(0.361141886942,-0.90465509305));
#10438 = VECTOR('',#10439,1.);
#10439 = DIRECTION('',(1.,0.));
#10440 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10441 = ORIENTED_EDGE('',*,*,#10442,.F.);
#10442 = EDGE_CURVE('',#10443,#10420,#10445,.T.);
#10443 = VERTEX_POINT('',#10444);
#10444 = CARTESIAN_POINT('',(-1.6,-6.48,8.));
#10445 = SURFACE_CURVE('',#10446,(#10450,#10457),.PCURVE_S1.);
#10446 = LINE('',#10447,#10448);
#10447 = CARTESIAN_POINT('',(-1.6,-6.48,8.));
#10448 = VECTOR('',#10449,1.);
#10449 = DIRECTION('',(0.,0.,1.));
#10450 = PCURVE('',#10382,#10451);
#10451 = DEFINITIONAL_REPRESENTATION('',(#10452),#10456);
#10452 = LINE('',#10453,#10454);
#10453 = CARTESIAN_POINT('',(0.258,0.));
#10454 = VECTOR('',#10455,1.);
#10455 = DIRECTION('',(0.,-1.));
#10456 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10457 = PCURVE('',#9317,#10458);
#10458 = DEFINITIONAL_REPRESENTATION('',(#10459),#10463);
#10459 = LINE('',#10460,#10461);
#10460 = CARTESIAN_POINT('',(1.33E-15,0.));
#10461 = VECTOR('',#10462,1.);
#10462 = DIRECTION('',(0.,-1.));
#10463 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10464 = ORIENTED_EDGE('',*,*,#10465,.F.);
#10465 = EDGE_CURVE('',#10367,#10443,#10466,.T.);
#10466 = SURFACE_CURVE('',#10467,(#10471,#10478),.PCURVE_S1.);
#10467 = LINE('',#10468,#10469);
#10468 = CARTESIAN_POINT('',(-1.6,-6.738,8.));
#10469 = VECTOR('',#10470,1.);
#10470 = DIRECTION('',(0.,1.,0.));
#10471 = PCURVE('',#10382,#10472);
#10472 = DEFINITIONAL_REPRESENTATION('',(#10473),#10477);
#10473 = LINE('',#10474,#10475);
#10474 = CARTESIAN_POINT('',(0.,0.));
#10475 = VECTOR('',#10476,1.);
#10476 = DIRECTION('',(1.,0.));
#10477 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10478 = PCURVE('',#9399,#10479);
#10479 = DEFINITIONAL_REPRESENTATION('',(#10480),#10484);
#10480 = LINE('',#10481,#10482);
#10481 = CARTESIAN_POINT('',(0.361141886942,-0.90465509305));
#10482 = VECTOR('',#10483,1.);
#10483 = DIRECTION('',(1.,0.));
#10484 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10485 = ADVANCED_FACE('',(#10486),#9317,.T.);
#10486 = FACE_BOUND('',#10487,.T.);
#10487 = EDGE_LOOP('',(#10488,#10489,#10510,#10511));
#10488 = ORIENTED_EDGE('',*,*,#10442,.T.);
#10489 = ORIENTED_EDGE('',*,*,#10490,.T.);
#10490 = EDGE_CURVE('',#10420,#9297,#10491,.T.);
#10491 = SURFACE_CURVE('',#10492,(#10496,#10503),.PCURVE_S1.);
#10492 = LINE('',#10493,#10494);
#10493 = CARTESIAN_POINT('',(-1.6,-6.48,8.2));
#10494 = VECTOR('',#10495,1.);
#10495 = DIRECTION('',(1.,0.,0.));
#10496 = PCURVE('',#9317,#10497);
#10497 = DEFINITIONAL_REPRESENTATION('',(#10498),#10502);
#10498 = LINE('',#10499,#10500);
#10499 = CARTESIAN_POINT('',(0.,-0.2));
#10500 = VECTOR('',#10501,1.);
#10501 = DIRECTION('',(1.,0.));
#10502 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10503 = PCURVE('',#9345,#10504);
#10504 = DEFINITIONAL_REPRESENTATION('',(#10505),#10509);
#10505 = LINE('',#10506,#10507);
#10506 = CARTESIAN_POINT('',(0.619141886942,-0.90465509305));
#10507 = VECTOR('',#10508,1.);
#10508 = DIRECTION('',(0.,1.));
#10509 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10510 = ORIENTED_EDGE('',*,*,#9294,.F.);
#10511 = ORIENTED_EDGE('',*,*,#10512,.F.);
#10512 = EDGE_CURVE('',#10443,#9295,#10513,.T.);
#10513 = SURFACE_CURVE('',#10514,(#10518,#10525),.PCURVE_S1.);
#10514 = LINE('',#10515,#10516);
#10515 = CARTESIAN_POINT('',(-1.6,-6.48,8.));
#10516 = VECTOR('',#10517,1.);
#10517 = DIRECTION('',(1.,0.,0.));
#10518 = PCURVE('',#9317,#10519);
#10519 = DEFINITIONAL_REPRESENTATION('',(#10520),#10524);
#10520 = LINE('',#10521,#10522);
#10521 = CARTESIAN_POINT('',(0.,0.));
#10522 = VECTOR('',#10523,1.);
#10523 = DIRECTION('',(1.,0.));
#10524 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10525 = PCURVE('',#9399,#10526);
#10526 = DEFINITIONAL_REPRESENTATION('',(#10527),#10531);
#10527 = LINE('',#10528,#10529);
#10528 = CARTESIAN_POINT('',(0.619141886942,-0.90465509305));
#10529 = VECTOR('',#10530,1.);
#10530 = DIRECTION('',(0.,1.));
#10531 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10532 = ADVANCED_FACE('',(#10533),#9399,.T.);
#10533 = FACE_BOUND('',#10534,.T.);
#10534 = EDGE_LOOP('',(#10535,#10536,#10537,#10538,#10539,#10540,#10541,
#10542,#10543,#10544,#10545,#10546,#10547,#10548,#10549,#10550));
#10535 = ORIENTED_EDGE('',*,*,#9385,.T.);
#10536 = ORIENTED_EDGE('',*,*,#9468,.T.);
#10537 = ORIENTED_EDGE('',*,*,#9546,.T.);
#10538 = ORIENTED_EDGE('',*,*,#9624,.T.);
#10539 = ORIENTED_EDGE('',*,*,#9702,.T.);
#10540 = ORIENTED_EDGE('',*,*,#9778,.T.);
#10541 = ORIENTED_EDGE('',*,*,#9854,.T.);
#10542 = ORIENTED_EDGE('',*,*,#9930,.T.);
#10543 = ORIENTED_EDGE('',*,*,#10008,.T.);
#10544 = ORIENTED_EDGE('',*,*,#10086,.T.);
#10545 = ORIENTED_EDGE('',*,*,#10164,.T.);
#10546 = ORIENTED_EDGE('',*,*,#10242,.T.);
#10547 = ORIENTED_EDGE('',*,*,#10318,.T.);
#10548 = ORIENTED_EDGE('',*,*,#10394,.T.);
#10549 = ORIENTED_EDGE('',*,*,#10465,.T.);
#10550 = ORIENTED_EDGE('',*,*,#10512,.T.);
#10551 = ADVANCED_FACE('',(#10552),#9345,.F.);
#10552 = FACE_BOUND('',#10553,.F.);
#10553 = EDGE_LOOP('',(#10554,#10555,#10556,#10557,#10558,#10559,#10560,
#10561,#10562,#10563,#10564,#10565,#10566,#10567,#10568,#10569));
#10554 = ORIENTED_EDGE('',*,*,#9329,.T.);
#10555 = ORIENTED_EDGE('',*,*,#9415,.T.);
#10556 = ORIENTED_EDGE('',*,*,#9493,.T.);
#10557 = ORIENTED_EDGE('',*,*,#9571,.T.);
#10558 = ORIENTED_EDGE('',*,*,#9649,.T.);
#10559 = ORIENTED_EDGE('',*,*,#9727,.T.);
#10560 = ORIENTED_EDGE('',*,*,#9803,.T.);
#10561 = ORIENTED_EDGE('',*,*,#9879,.T.);
#10562 = ORIENTED_EDGE('',*,*,#9955,.T.);
#10563 = ORIENTED_EDGE('',*,*,#10033,.T.);
#10564 = ORIENTED_EDGE('',*,*,#10111,.T.);
#10565 = ORIENTED_EDGE('',*,*,#10189,.T.);
#10566 = ORIENTED_EDGE('',*,*,#10267,.T.);
#10567 = ORIENTED_EDGE('',*,*,#10343,.T.);
#10568 = ORIENTED_EDGE('',*,*,#10419,.T.);
#10569 = ORIENTED_EDGE('',*,*,#10490,.T.);
#10570 = MANIFOLD_SOLID_BREP('',#10571);
#10571 = CLOSED_SHELL('',(#10572,#10692,#10768,#10839,#10886,#10893));
#10572 = ADVANCED_FACE('',(#10573),#10587,.T.);
#10573 = FACE_BOUND('',#10574,.T.);
#10574 = EDGE_LOOP('',(#10575,#10610,#10638,#10666));
#10575 = ORIENTED_EDGE('',*,*,#10576,.T.);
#10576 = EDGE_CURVE('',#10577,#10579,#10581,.T.);
#10577 = VERTEX_POINT('',#10578);
#10578 = CARTESIAN_POINT('',(-2.E-15,-8.421,8.));
#10579 = VERTEX_POINT('',#10580);
#10580 = CARTESIAN_POINT('',(-2.E-15,-8.421,8.2));
#10581 = SURFACE_CURVE('',#10582,(#10586,#10598),.PCURVE_S1.);
#10582 = LINE('',#10583,#10584);
#10583 = CARTESIAN_POINT('',(-1.78E-15,-8.421,8.));
#10584 = VECTOR('',#10585,1.);
#10585 = DIRECTION('',(0.,0.,1.));
#10586 = PCURVE('',#10587,#10592);
#10587 = PLANE('',#10588);
#10588 = AXIS2_PLACEMENT_3D('',#10589,#10590,#10591);
#10589 = CARTESIAN_POINT('',(-1.78E-15,-8.421,8.));
#10590 = DIRECTION('',(-2.2E-16,-1.,0.));
#10591 = DIRECTION('',(-1.,2.2E-16,0.));
#10592 = DEFINITIONAL_REPRESENTATION('',(#10593),#10597);
#10593 = LINE('',#10594,#10595);
#10594 = CARTESIAN_POINT('',(0.,0.));
#10595 = VECTOR('',#10596,1.);
#10596 = DIRECTION('',(0.,-1.));
#10597 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10598 = PCURVE('',#10599,#10604);
#10599 = PLANE('',#10600);
#10600 = AXIS2_PLACEMENT_3D('',#10601,#10602,#10603);
#10601 = CARTESIAN_POINT('',(-1.78E-15,-8.166,8.));
#10602 = DIRECTION('',(1.,-2.2E-16,0.));
#10603 = DIRECTION('',(-2.2E-16,-1.,0.));
#10604 = DEFINITIONAL_REPRESENTATION('',(#10605),#10609);
#10605 = LINE('',#10606,#10607);
#10606 = CARTESIAN_POINT('',(0.255,-0.));
#10607 = VECTOR('',#10608,1.);
#10608 = DIRECTION('',(0.,-1.));
#10609 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10610 = ORIENTED_EDGE('',*,*,#10611,.T.);
#10611 = EDGE_CURVE('',#10579,#10612,#10614,.T.);
#10612 = VERTEX_POINT('',#10613);
#10613 = CARTESIAN_POINT('',(-1.6,-8.421,8.2));
#10614 = SURFACE_CURVE('',#10615,(#10619,#10626),.PCURVE_S1.);
#10615 = LINE('',#10616,#10617);
#10616 = CARTESIAN_POINT('',(0.,-8.421,8.2));
#10617 = VECTOR('',#10618,1.);
#10618 = DIRECTION('',(-1.,0.,0.));
#10619 = PCURVE('',#10587,#10620);
#10620 = DEFINITIONAL_REPRESENTATION('',(#10621),#10625);
#10621 = LINE('',#10622,#10623);
#10622 = CARTESIAN_POINT('',(0.,-0.2));
#10623 = VECTOR('',#10624,1.);
#10624 = DIRECTION('',(1.,0.));
#10625 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10626 = PCURVE('',#10627,#10632);
#10627 = PLANE('',#10628);
#10628 = AXIS2_PLACEMENT_3D('',#10629,#10630,#10631);
#10629 = CARTESIAN_POINT('',(-0.8,-8.2935,8.2));
#10630 = DIRECTION('',(-0.,0.,-1.));
#10631 = DIRECTION('',(0.,1.,0.));
#10632 = DEFINITIONAL_REPRESENTATION('',(#10633),#10637);
#10633 = LINE('',#10634,#10635);
#10634 = CARTESIAN_POINT('',(-0.1275,0.8));
#10635 = VECTOR('',#10636,1.);
#10636 = DIRECTION('',(0.,-1.));
#10637 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10638 = ORIENTED_EDGE('',*,*,#10639,.F.);
#10639 = EDGE_CURVE('',#10640,#10612,#10642,.T.);
#10640 = VERTEX_POINT('',#10641);
#10641 = CARTESIAN_POINT('',(-1.6,-8.421,8.));
#10642 = SURFACE_CURVE('',#10643,(#10647,#10654),.PCURVE_S1.);
#10643 = LINE('',#10644,#10645);
#10644 = CARTESIAN_POINT('',(-1.6,-8.421,8.));
#10645 = VECTOR('',#10646,1.);
#10646 = DIRECTION('',(0.,0.,1.));
#10647 = PCURVE('',#10587,#10648);
#10648 = DEFINITIONAL_REPRESENTATION('',(#10649),#10653);
#10649 = LINE('',#10650,#10651);
#10650 = CARTESIAN_POINT('',(1.6,0.));
#10651 = VECTOR('',#10652,1.);
#10652 = DIRECTION('',(0.,-1.));
#10653 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10654 = PCURVE('',#10655,#10660);
#10655 = PLANE('',#10656);
#10656 = AXIS2_PLACEMENT_3D('',#10657,#10658,#10659);
#10657 = CARTESIAN_POINT('',(-1.6,-8.421,8.));
#10658 = DIRECTION('',(-1.,2.2E-16,0.));
#10659 = DIRECTION('',(2.2E-16,1.,0.));
#10660 = DEFINITIONAL_REPRESENTATION('',(#10661),#10665);
#10661 = LINE('',#10662,#10663);
#10662 = CARTESIAN_POINT('',(1.78E-15,0.));
#10663 = VECTOR('',#10664,1.);
#10664 = DIRECTION('',(0.,-1.));
#10665 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10666 = ORIENTED_EDGE('',*,*,#10667,.F.);
#10667 = EDGE_CURVE('',#10577,#10640,#10668,.T.);
#10668 = SURFACE_CURVE('',#10669,(#10673,#10680),.PCURVE_S1.);
#10669 = LINE('',#10670,#10671);
#10670 = CARTESIAN_POINT('',(0.,-8.421,8.));
#10671 = VECTOR('',#10672,1.);
#10672 = DIRECTION('',(-1.,0.,0.));
#10673 = PCURVE('',#10587,#10674);
#10674 = DEFINITIONAL_REPRESENTATION('',(#10675),#10679);
#10675 = LINE('',#10676,#10677);
#10676 = CARTESIAN_POINT('',(0.,0.));
#10677 = VECTOR('',#10678,1.);
#10678 = DIRECTION('',(1.,0.));
#10679 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10680 = PCURVE('',#10681,#10686);
#10681 = PLANE('',#10682);
#10682 = AXIS2_PLACEMENT_3D('',#10683,#10684,#10685);
#10683 = CARTESIAN_POINT('',(-0.8,-8.2935,8.));
#10684 = DIRECTION('',(-0.,0.,-1.));
#10685 = DIRECTION('',(0.,1.,0.));
#10686 = DEFINITIONAL_REPRESENTATION('',(#10687),#10691);
#10687 = LINE('',#10688,#10689);
#10688 = CARTESIAN_POINT('',(-0.1275,0.8));
#10689 = VECTOR('',#10690,1.);
#10690 = DIRECTION('',(0.,-1.));
#10691 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10692 = ADVANCED_FACE('',(#10693),#10655,.T.);
#10693 = FACE_BOUND('',#10694,.T.);
#10694 = EDGE_LOOP('',(#10695,#10696,#10719,#10747));
#10695 = ORIENTED_EDGE('',*,*,#10639,.T.);
#10696 = ORIENTED_EDGE('',*,*,#10697,.T.);
#10697 = EDGE_CURVE('',#10612,#10698,#10700,.T.);
#10698 = VERTEX_POINT('',#10699);
#10699 = CARTESIAN_POINT('',(-1.6,-8.166,8.2));
#10700 = SURFACE_CURVE('',#10701,(#10705,#10712),.PCURVE_S1.);
#10701 = LINE('',#10702,#10703);
#10702 = CARTESIAN_POINT('',(-1.6,-8.421,8.2));
#10703 = VECTOR('',#10704,1.);
#10704 = DIRECTION('',(0.,1.,0.));
#10705 = PCURVE('',#10655,#10706);
#10706 = DEFINITIONAL_REPRESENTATION('',(#10707),#10711);
#10707 = LINE('',#10708,#10709);
#10708 = CARTESIAN_POINT('',(0.,-0.2));
#10709 = VECTOR('',#10710,1.);
#10710 = DIRECTION('',(1.,0.));
#10711 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10712 = PCURVE('',#10627,#10713);
#10713 = DEFINITIONAL_REPRESENTATION('',(#10714),#10718);
#10714 = LINE('',#10715,#10716);
#10715 = CARTESIAN_POINT('',(-0.1275,-0.8));
#10716 = VECTOR('',#10717,1.);
#10717 = DIRECTION('',(1.,0.));
#10718 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10719 = ORIENTED_EDGE('',*,*,#10720,.F.);
#10720 = EDGE_CURVE('',#10721,#10698,#10723,.T.);
#10721 = VERTEX_POINT('',#10722);
#10722 = CARTESIAN_POINT('',(-1.6,-8.166,8.));
#10723 = SURFACE_CURVE('',#10724,(#10728,#10735),.PCURVE_S1.);
#10724 = LINE('',#10725,#10726);
#10725 = CARTESIAN_POINT('',(-1.6,-8.166,8.));
#10726 = VECTOR('',#10727,1.);
#10727 = DIRECTION('',(0.,0.,1.));
#10728 = PCURVE('',#10655,#10729);
#10729 = DEFINITIONAL_REPRESENTATION('',(#10730),#10734);
#10730 = LINE('',#10731,#10732);
#10731 = CARTESIAN_POINT('',(0.255,0.));
#10732 = VECTOR('',#10733,1.);
#10733 = DIRECTION('',(0.,-1.));
#10734 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10735 = PCURVE('',#10736,#10741);
#10736 = PLANE('',#10737);
#10737 = AXIS2_PLACEMENT_3D('',#10738,#10739,#10740);
#10738 = CARTESIAN_POINT('',(-1.6,-8.166,8.));
#10739 = DIRECTION('',(2.2E-16,1.,0.));
#10740 = DIRECTION('',(1.,-2.2E-16,0.));
#10741 = DEFINITIONAL_REPRESENTATION('',(#10742),#10746);
#10742 = LINE('',#10743,#10744);
#10743 = CARTESIAN_POINT('',(1.78E-15,0.));
#10744 = VECTOR('',#10745,1.);
#10745 = DIRECTION('',(0.,-1.));
#10746 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10747 = ORIENTED_EDGE('',*,*,#10748,.F.);
#10748 = EDGE_CURVE('',#10640,#10721,#10749,.T.);
#10749 = SURFACE_CURVE('',#10750,(#10754,#10761),.PCURVE_S1.);
#10750 = LINE('',#10751,#10752);
#10751 = CARTESIAN_POINT('',(-1.6,-8.421,8.));
#10752 = VECTOR('',#10753,1.);
#10753 = DIRECTION('',(0.,1.,0.));
#10754 = PCURVE('',#10655,#10755);
#10755 = DEFINITIONAL_REPRESENTATION('',(#10756),#10760);
#10756 = LINE('',#10757,#10758);
#10757 = CARTESIAN_POINT('',(0.,0.));
#10758 = VECTOR('',#10759,1.);
#10759 = DIRECTION('',(1.,0.));
#10760 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10761 = PCURVE('',#10681,#10762);
#10762 = DEFINITIONAL_REPRESENTATION('',(#10763),#10767);
#10763 = LINE('',#10764,#10765);
#10764 = CARTESIAN_POINT('',(-0.1275,-0.8));
#10765 = VECTOR('',#10766,1.);
#10766 = DIRECTION('',(1.,0.));
#10767 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10768 = ADVANCED_FACE('',(#10769),#10736,.T.);
#10769 = FACE_BOUND('',#10770,.T.);
#10770 = EDGE_LOOP('',(#10771,#10772,#10795,#10818));
#10771 = ORIENTED_EDGE('',*,*,#10720,.T.);
#10772 = ORIENTED_EDGE('',*,*,#10773,.T.);
#10773 = EDGE_CURVE('',#10698,#10774,#10776,.T.);
#10774 = VERTEX_POINT('',#10775);
#10775 = CARTESIAN_POINT('',(-2.E-15,-8.166,8.2));
#10776 = SURFACE_CURVE('',#10777,(#10781,#10788),.PCURVE_S1.);
#10777 = LINE('',#10778,#10779);
#10778 = CARTESIAN_POINT('',(-1.6,-8.166,8.2));
#10779 = VECTOR('',#10780,1.);
#10780 = DIRECTION('',(1.,0.,0.));
#10781 = PCURVE('',#10736,#10782);
#10782 = DEFINITIONAL_REPRESENTATION('',(#10783),#10787);
#10783 = LINE('',#10784,#10785);
#10784 = CARTESIAN_POINT('',(0.,-0.2));
#10785 = VECTOR('',#10786,1.);
#10786 = DIRECTION('',(1.,0.));
#10787 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10788 = PCURVE('',#10627,#10789);
#10789 = DEFINITIONAL_REPRESENTATION('',(#10790),#10794);
#10790 = LINE('',#10791,#10792);
#10791 = CARTESIAN_POINT('',(0.1275,-0.8));
#10792 = VECTOR('',#10793,1.);
#10793 = DIRECTION('',(0.,1.));
#10794 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10795 = ORIENTED_EDGE('',*,*,#10796,.F.);
#10796 = EDGE_CURVE('',#10797,#10774,#10799,.T.);
#10797 = VERTEX_POINT('',#10798);
#10798 = CARTESIAN_POINT('',(-2.E-15,-8.166,8.));
#10799 = SURFACE_CURVE('',#10800,(#10804,#10811),.PCURVE_S1.);
#10800 = LINE('',#10801,#10802);
#10801 = CARTESIAN_POINT('',(-1.78E-15,-8.166,8.));
#10802 = VECTOR('',#10803,1.);
#10803 = DIRECTION('',(0.,0.,1.));
#10804 = PCURVE('',#10736,#10805);
#10805 = DEFINITIONAL_REPRESENTATION('',(#10806),#10810);
#10806 = LINE('',#10807,#10808);
#10807 = CARTESIAN_POINT('',(1.6,0.));
#10808 = VECTOR('',#10809,1.);
#10809 = DIRECTION('',(0.,-1.));
#10810 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10811 = PCURVE('',#10599,#10812);
#10812 = DEFINITIONAL_REPRESENTATION('',(#10813),#10817);
#10813 = LINE('',#10814,#10815);
#10814 = CARTESIAN_POINT('',(0.,0.));
#10815 = VECTOR('',#10816,1.);
#10816 = DIRECTION('',(0.,-1.));
#10817 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10818 = ORIENTED_EDGE('',*,*,#10819,.F.);
#10819 = EDGE_CURVE('',#10721,#10797,#10820,.T.);
#10820 = SURFACE_CURVE('',#10821,(#10825,#10832),.PCURVE_S1.);
#10821 = LINE('',#10822,#10823);
#10822 = CARTESIAN_POINT('',(-1.6,-8.166,8.));
#10823 = VECTOR('',#10824,1.);
#10824 = DIRECTION('',(1.,0.,0.));
#10825 = PCURVE('',#10736,#10826);
#10826 = DEFINITIONAL_REPRESENTATION('',(#10827),#10831);
#10827 = LINE('',#10828,#10829);
#10828 = CARTESIAN_POINT('',(0.,0.));
#10829 = VECTOR('',#10830,1.);
#10830 = DIRECTION('',(1.,0.));
#10831 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10832 = PCURVE('',#10681,#10833);
#10833 = DEFINITIONAL_REPRESENTATION('',(#10834),#10838);
#10834 = LINE('',#10835,#10836);
#10835 = CARTESIAN_POINT('',(0.1275,-0.8));
#10836 = VECTOR('',#10837,1.);
#10837 = DIRECTION('',(0.,1.));
#10838 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10839 = ADVANCED_FACE('',(#10840),#10599,.T.);
#10840 = FACE_BOUND('',#10841,.T.);
#10841 = EDGE_LOOP('',(#10842,#10843,#10864,#10865));
#10842 = ORIENTED_EDGE('',*,*,#10796,.T.);
#10843 = ORIENTED_EDGE('',*,*,#10844,.T.);
#10844 = EDGE_CURVE('',#10774,#10579,#10845,.T.);
#10845 = SURFACE_CURVE('',#10846,(#10850,#10857),.PCURVE_S1.);
#10846 = LINE('',#10847,#10848);
#10847 = CARTESIAN_POINT('',(0.,-8.166,8.2));
#10848 = VECTOR('',#10849,1.);
#10849 = DIRECTION('',(0.,-1.,0.));
#10850 = PCURVE('',#10599,#10851);
#10851 = DEFINITIONAL_REPRESENTATION('',(#10852),#10856);
#10852 = LINE('',#10853,#10854);
#10853 = CARTESIAN_POINT('',(0.,-0.2));
#10854 = VECTOR('',#10855,1.);
#10855 = DIRECTION('',(1.,-0.));
#10856 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10857 = PCURVE('',#10627,#10858);
#10858 = DEFINITIONAL_REPRESENTATION('',(#10859),#10863);
#10859 = LINE('',#10860,#10861);
#10860 = CARTESIAN_POINT('',(0.1275,0.8));
#10861 = VECTOR('',#10862,1.);
#10862 = DIRECTION('',(-1.,0.));
#10863 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10864 = ORIENTED_EDGE('',*,*,#10576,.F.);
#10865 = ORIENTED_EDGE('',*,*,#10866,.F.);
#10866 = EDGE_CURVE('',#10797,#10577,#10867,.T.);
#10867 = SURFACE_CURVE('',#10868,(#10872,#10879),.PCURVE_S1.);
#10868 = LINE('',#10869,#10870);
#10869 = CARTESIAN_POINT('',(0.,-8.166,8.));
#10870 = VECTOR('',#10871,1.);
#10871 = DIRECTION('',(0.,-1.,0.));
#10872 = PCURVE('',#10599,#10873);
#10873 = DEFINITIONAL_REPRESENTATION('',(#10874),#10878);
#10874 = LINE('',#10875,#10876);
#10875 = CARTESIAN_POINT('',(0.,0.));
#10876 = VECTOR('',#10877,1.);
#10877 = DIRECTION('',(1.,-0.));
#10878 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10879 = PCURVE('',#10681,#10880);
#10880 = DEFINITIONAL_REPRESENTATION('',(#10881),#10885);
#10881 = LINE('',#10882,#10883);
#10882 = CARTESIAN_POINT('',(0.1275,0.8));
#10883 = VECTOR('',#10884,1.);
#10884 = DIRECTION('',(-1.,0.));
#10885 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10886 = ADVANCED_FACE('',(#10887),#10681,.T.);
#10887 = FACE_BOUND('',#10888,.T.);
#10888 = EDGE_LOOP('',(#10889,#10890,#10891,#10892));
#10889 = ORIENTED_EDGE('',*,*,#10667,.T.);
#10890 = ORIENTED_EDGE('',*,*,#10748,.T.);
#10891 = ORIENTED_EDGE('',*,*,#10819,.T.);
#10892 = ORIENTED_EDGE('',*,*,#10866,.T.);
#10893 = ADVANCED_FACE('',(#10894),#10627,.F.);
#10894 = FACE_BOUND('',#10895,.F.);
#10895 = EDGE_LOOP('',(#10896,#10897,#10898,#10899));
#10896 = ORIENTED_EDGE('',*,*,#10611,.T.);
#10897 = ORIENTED_EDGE('',*,*,#10697,.T.);
#10898 = ORIENTED_EDGE('',*,*,#10773,.T.);
#10899 = ORIENTED_EDGE('',*,*,#10844,.T.);
#10900 = MANIFOLD_SOLID_BREP('',#10901);
#10901 = CLOSED_SHELL('',(#10902,#11022,#11098,#11169,#11216,#11223));
#10902 = ADVANCED_FACE('',(#10903),#10917,.T.);
#10903 = FACE_BOUND('',#10904,.T.);
#10904 = EDGE_LOOP('',(#10905,#10940,#10968,#10996));
#10905 = ORIENTED_EDGE('',*,*,#10906,.T.);
#10906 = EDGE_CURVE('',#10907,#10909,#10911,.T.);
#10907 = VERTEX_POINT('',#10908);
#10908 = CARTESIAN_POINT('',(0.64,-8.421,8.));
#10909 = VERTEX_POINT('',#10910);
#10910 = CARTESIAN_POINT('',(0.64,-8.421,8.2));
#10911 = SURFACE_CURVE('',#10912,(#10916,#10928),.PCURVE_S1.);
#10912 = LINE('',#10913,#10914);
#10913 = CARTESIAN_POINT('',(0.64,-8.421,8.));
#10914 = VECTOR('',#10915,1.);
#10915 = DIRECTION('',(0.,0.,1.));
#10916 = PCURVE('',#10917,#10922);
#10917 = PLANE('',#10918);
#10918 = AXIS2_PLACEMENT_3D('',#10919,#10920,#10921);
#10919 = CARTESIAN_POINT('',(0.64,-8.421,8.));
#10920 = DIRECTION('',(-2.2E-16,-1.,0.));
#10921 = DIRECTION('',(-1.,2.2E-16,0.));
#10922 = DEFINITIONAL_REPRESENTATION('',(#10923),#10927);
#10923 = LINE('',#10924,#10925);
#10924 = CARTESIAN_POINT('',(3.3E-16,0.));
#10925 = VECTOR('',#10926,1.);
#10926 = DIRECTION('',(0.,-1.));
#10927 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10928 = PCURVE('',#10929,#10934);
#10929 = PLANE('',#10930);
#10930 = AXIS2_PLACEMENT_3D('',#10931,#10932,#10933);
#10931 = CARTESIAN_POINT('',(0.64,-8.163,8.));
#10932 = DIRECTION('',(1.,-2.2E-16,0.));
#10933 = DIRECTION('',(-2.2E-16,-1.,0.));
#10934 = DEFINITIONAL_REPRESENTATION('',(#10935),#10939);
#10935 = LINE('',#10936,#10937);
#10936 = CARTESIAN_POINT('',(0.258,-0.));
#10937 = VECTOR('',#10938,1.);
#10938 = DIRECTION('',(0.,-1.));
#10939 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10940 = ORIENTED_EDGE('',*,*,#10941,.T.);
#10941 = EDGE_CURVE('',#10909,#10942,#10944,.T.);
#10942 = VERTEX_POINT('',#10943);
#10943 = CARTESIAN_POINT('',(0.32,-8.421,8.2));
#10944 = SURFACE_CURVE('',#10945,(#10949,#10956),.PCURVE_S1.);
#10945 = LINE('',#10946,#10947);
#10946 = CARTESIAN_POINT('',(0.64,-8.421,8.2));
#10947 = VECTOR('',#10948,1.);
#10948 = DIRECTION('',(-1.,0.,0.));
#10949 = PCURVE('',#10917,#10950);
#10950 = DEFINITIONAL_REPRESENTATION('',(#10951),#10955);
#10951 = LINE('',#10952,#10953);
#10952 = CARTESIAN_POINT('',(0.,-0.2));
#10953 = VECTOR('',#10954,1.);
#10954 = DIRECTION('',(1.,0.));
#10955 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10956 = PCURVE('',#10957,#10962);
#10957 = PLANE('',#10958);
#10958 = AXIS2_PLACEMENT_3D('',#10959,#10960,#10961);
#10959 = CARTESIAN_POINT('',(0.48,-8.292,8.2));
#10960 = DIRECTION('',(-0.,0.,-1.));
#10961 = DIRECTION('',(0.,1.,0.));
#10962 = DEFINITIONAL_REPRESENTATION('',(#10963),#10967);
#10963 = LINE('',#10964,#10965);
#10964 = CARTESIAN_POINT('',(-0.129,0.16));
#10965 = VECTOR('',#10966,1.);
#10966 = DIRECTION('',(0.,-1.));
#10967 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10968 = ORIENTED_EDGE('',*,*,#10969,.F.);
#10969 = EDGE_CURVE('',#10970,#10942,#10972,.T.);
#10970 = VERTEX_POINT('',#10971);
#10971 = CARTESIAN_POINT('',(0.32,-8.421,8.));
#10972 = SURFACE_CURVE('',#10973,(#10977,#10984),.PCURVE_S1.);
#10973 = LINE('',#10974,#10975);
#10974 = CARTESIAN_POINT('',(0.32,-8.421,8.));
#10975 = VECTOR('',#10976,1.);
#10976 = DIRECTION('',(0.,0.,1.));
#10977 = PCURVE('',#10917,#10978);
#10978 = DEFINITIONAL_REPRESENTATION('',(#10979),#10983);
#10979 = LINE('',#10980,#10981);
#10980 = CARTESIAN_POINT('',(0.32,0.));
#10981 = VECTOR('',#10982,1.);
#10982 = DIRECTION('',(0.,-1.));
#10983 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10984 = PCURVE('',#10985,#10990);
#10985 = PLANE('',#10986);
#10986 = AXIS2_PLACEMENT_3D('',#10987,#10988,#10989);
#10987 = CARTESIAN_POINT('',(0.32,-8.421,8.));
#10988 = DIRECTION('',(-1.,2.2E-16,0.));
#10989 = DIRECTION('',(2.2E-16,1.,0.));
#10990 = DEFINITIONAL_REPRESENTATION('',(#10991),#10995);
#10991 = LINE('',#10992,#10993);
#10992 = CARTESIAN_POINT('',(1.78E-15,0.));
#10993 = VECTOR('',#10994,1.);
#10994 = DIRECTION('',(0.,-1.));
#10995 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#10996 = ORIENTED_EDGE('',*,*,#10997,.F.);
#10997 = EDGE_CURVE('',#10907,#10970,#10998,.T.);
#10998 = SURFACE_CURVE('',#10999,(#11003,#11010),.PCURVE_S1.);
#10999 = LINE('',#11000,#11001);
#11000 = CARTESIAN_POINT('',(0.64,-8.421,8.));
#11001 = VECTOR('',#11002,1.);
#11002 = DIRECTION('',(-1.,0.,0.));
#11003 = PCURVE('',#10917,#11004);
#11004 = DEFINITIONAL_REPRESENTATION('',(#11005),#11009);
#11005 = LINE('',#11006,#11007);
#11006 = CARTESIAN_POINT('',(0.,0.));
#11007 = VECTOR('',#11008,1.);
#11008 = DIRECTION('',(1.,0.));
#11009 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11010 = PCURVE('',#11011,#11016);
#11011 = PLANE('',#11012);
#11012 = AXIS2_PLACEMENT_3D('',#11013,#11014,#11015);
#11013 = CARTESIAN_POINT('',(0.48,-8.292,8.));
#11014 = DIRECTION('',(-0.,0.,-1.));
#11015 = DIRECTION('',(0.,1.,0.));
#11016 = DEFINITIONAL_REPRESENTATION('',(#11017),#11021);
#11017 = LINE('',#11018,#11019);
#11018 = CARTESIAN_POINT('',(-0.129,0.16));
#11019 = VECTOR('',#11020,1.);
#11020 = DIRECTION('',(0.,-1.));
#11021 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11022 = ADVANCED_FACE('',(#11023),#10985,.T.);
#11023 = FACE_BOUND('',#11024,.T.);
#11024 = EDGE_LOOP('',(#11025,#11026,#11049,#11077));
#11025 = ORIENTED_EDGE('',*,*,#10969,.T.);
#11026 = ORIENTED_EDGE('',*,*,#11027,.T.);
#11027 = EDGE_CURVE('',#10942,#11028,#11030,.T.);
#11028 = VERTEX_POINT('',#11029);
#11029 = CARTESIAN_POINT('',(0.32,-8.163,8.2));
#11030 = SURFACE_CURVE('',#11031,(#11035,#11042),.PCURVE_S1.);
#11031 = LINE('',#11032,#11033);
#11032 = CARTESIAN_POINT('',(0.32,-8.421,8.2));
#11033 = VECTOR('',#11034,1.);
#11034 = DIRECTION('',(0.,1.,0.));
#11035 = PCURVE('',#10985,#11036);
#11036 = DEFINITIONAL_REPRESENTATION('',(#11037),#11041);
#11037 = LINE('',#11038,#11039);
#11038 = CARTESIAN_POINT('',(0.,-0.2));
#11039 = VECTOR('',#11040,1.);
#11040 = DIRECTION('',(1.,0.));
#11041 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11042 = PCURVE('',#10957,#11043);
#11043 = DEFINITIONAL_REPRESENTATION('',(#11044),#11048);
#11044 = LINE('',#11045,#11046);
#11045 = CARTESIAN_POINT('',(-0.129,-0.16));
#11046 = VECTOR('',#11047,1.);
#11047 = DIRECTION('',(1.,0.));
#11048 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11049 = ORIENTED_EDGE('',*,*,#11050,.F.);
#11050 = EDGE_CURVE('',#11051,#11028,#11053,.T.);
#11051 = VERTEX_POINT('',#11052);
#11052 = CARTESIAN_POINT('',(0.32,-8.163,8.));
#11053 = SURFACE_CURVE('',#11054,(#11058,#11065),.PCURVE_S1.);
#11054 = LINE('',#11055,#11056);
#11055 = CARTESIAN_POINT('',(0.32,-8.163,8.));
#11056 = VECTOR('',#11057,1.);
#11057 = DIRECTION('',(0.,0.,1.));
#11058 = PCURVE('',#10985,#11059);
#11059 = DEFINITIONAL_REPRESENTATION('',(#11060),#11064);
#11060 = LINE('',#11061,#11062);
#11061 = CARTESIAN_POINT('',(0.258,0.));
#11062 = VECTOR('',#11063,1.);
#11063 = DIRECTION('',(0.,-1.));
#11064 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11065 = PCURVE('',#11066,#11071);
#11066 = PLANE('',#11067);
#11067 = AXIS2_PLACEMENT_3D('',#11068,#11069,#11070);
#11068 = CARTESIAN_POINT('',(0.32,-8.163,8.));
#11069 = DIRECTION('',(2.2E-16,1.,0.));
#11070 = DIRECTION('',(1.,-2.2E-16,0.));
#11071 = DEFINITIONAL_REPRESENTATION('',(#11072),#11076);
#11072 = LINE('',#11073,#11074);
#11073 = CARTESIAN_POINT('',(-6.E-17,0.));
#11074 = VECTOR('',#11075,1.);
#11075 = DIRECTION('',(0.,-1.));
#11076 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11077 = ORIENTED_EDGE('',*,*,#11078,.F.);
#11078 = EDGE_CURVE('',#10970,#11051,#11079,.T.);
#11079 = SURFACE_CURVE('',#11080,(#11084,#11091),.PCURVE_S1.);
#11080 = LINE('',#11081,#11082);
#11081 = CARTESIAN_POINT('',(0.32,-8.421,8.));
#11082 = VECTOR('',#11083,1.);
#11083 = DIRECTION('',(0.,1.,0.));
#11084 = PCURVE('',#10985,#11085);
#11085 = DEFINITIONAL_REPRESENTATION('',(#11086),#11090);
#11086 = LINE('',#11087,#11088);
#11087 = CARTESIAN_POINT('',(0.,0.));
#11088 = VECTOR('',#11089,1.);
#11089 = DIRECTION('',(1.,0.));
#11090 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11091 = PCURVE('',#11011,#11092);
#11092 = DEFINITIONAL_REPRESENTATION('',(#11093),#11097);
#11093 = LINE('',#11094,#11095);
#11094 = CARTESIAN_POINT('',(-0.129,-0.16));
#11095 = VECTOR('',#11096,1.);
#11096 = DIRECTION('',(1.,0.));
#11097 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11098 = ADVANCED_FACE('',(#11099),#11066,.T.);
#11099 = FACE_BOUND('',#11100,.T.);
#11100 = EDGE_LOOP('',(#11101,#11102,#11125,#11148));
#11101 = ORIENTED_EDGE('',*,*,#11050,.T.);
#11102 = ORIENTED_EDGE('',*,*,#11103,.T.);
#11103 = EDGE_CURVE('',#11028,#11104,#11106,.T.);
#11104 = VERTEX_POINT('',#11105);
#11105 = CARTESIAN_POINT('',(0.64,-8.163,8.2));
#11106 = SURFACE_CURVE('',#11107,(#11111,#11118),.PCURVE_S1.);
#11107 = LINE('',#11108,#11109);
#11108 = CARTESIAN_POINT('',(0.32,-8.163,8.2));
#11109 = VECTOR('',#11110,1.);
#11110 = DIRECTION('',(1.,0.,0.));
#11111 = PCURVE('',#11066,#11112);
#11112 = DEFINITIONAL_REPRESENTATION('',(#11113),#11117);
#11113 = LINE('',#11114,#11115);
#11114 = CARTESIAN_POINT('',(0.,-0.2));
#11115 = VECTOR('',#11116,1.);
#11116 = DIRECTION('',(1.,0.));
#11117 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11118 = PCURVE('',#10957,#11119);
#11119 = DEFINITIONAL_REPRESENTATION('',(#11120),#11124);
#11120 = LINE('',#11121,#11122);
#11121 = CARTESIAN_POINT('',(0.129,-0.16));
#11122 = VECTOR('',#11123,1.);
#11123 = DIRECTION('',(0.,1.));
#11124 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11125 = ORIENTED_EDGE('',*,*,#11126,.F.);
#11126 = EDGE_CURVE('',#11127,#11104,#11129,.T.);
#11127 = VERTEX_POINT('',#11128);
#11128 = CARTESIAN_POINT('',(0.64,-8.163,8.));
#11129 = SURFACE_CURVE('',#11130,(#11134,#11141),.PCURVE_S1.);
#11130 = LINE('',#11131,#11132);
#11131 = CARTESIAN_POINT('',(0.64,-8.163,8.));
#11132 = VECTOR('',#11133,1.);
#11133 = DIRECTION('',(0.,0.,1.));
#11134 = PCURVE('',#11066,#11135);
#11135 = DEFINITIONAL_REPRESENTATION('',(#11136),#11140);
#11136 = LINE('',#11137,#11138);
#11137 = CARTESIAN_POINT('',(0.32,0.));
#11138 = VECTOR('',#11139,1.);
#11139 = DIRECTION('',(0.,-1.));
#11140 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11141 = PCURVE('',#10929,#11142);
#11142 = DEFINITIONAL_REPRESENTATION('',(#11143),#11147);
#11143 = LINE('',#11144,#11145);
#11144 = CARTESIAN_POINT('',(-1.78E-15,0.));
#11145 = VECTOR('',#11146,1.);
#11146 = DIRECTION('',(0.,-1.));
#11147 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11148 = ORIENTED_EDGE('',*,*,#11149,.F.);
#11149 = EDGE_CURVE('',#11051,#11127,#11150,.T.);
#11150 = SURFACE_CURVE('',#11151,(#11155,#11162),.PCURVE_S1.);
#11151 = LINE('',#11152,#11153);
#11152 = CARTESIAN_POINT('',(0.32,-8.163,8.));
#11153 = VECTOR('',#11154,1.);
#11154 = DIRECTION('',(1.,0.,0.));
#11155 = PCURVE('',#11066,#11156);
#11156 = DEFINITIONAL_REPRESENTATION('',(#11157),#11161);
#11157 = LINE('',#11158,#11159);
#11158 = CARTESIAN_POINT('',(0.,0.));
#11159 = VECTOR('',#11160,1.);
#11160 = DIRECTION('',(1.,0.));
#11161 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11162 = PCURVE('',#11011,#11163);
#11163 = DEFINITIONAL_REPRESENTATION('',(#11164),#11168);
#11164 = LINE('',#11165,#11166);
#11165 = CARTESIAN_POINT('',(0.129,-0.16));
#11166 = VECTOR('',#11167,1.);
#11167 = DIRECTION('',(0.,1.));
#11168 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11169 = ADVANCED_FACE('',(#11170),#10929,.T.);
#11170 = FACE_BOUND('',#11171,.T.);
#11171 = EDGE_LOOP('',(#11172,#11173,#11194,#11195));
#11172 = ORIENTED_EDGE('',*,*,#11126,.T.);
#11173 = ORIENTED_EDGE('',*,*,#11174,.T.);
#11174 = EDGE_CURVE('',#11104,#10909,#11175,.T.);
#11175 = SURFACE_CURVE('',#11176,(#11180,#11187),.PCURVE_S1.);
#11176 = LINE('',#11177,#11178);
#11177 = CARTESIAN_POINT('',(0.64,-8.163,8.2));
#11178 = VECTOR('',#11179,1.);
#11179 = DIRECTION('',(0.,-1.,0.));
#11180 = PCURVE('',#10929,#11181);
#11181 = DEFINITIONAL_REPRESENTATION('',(#11182),#11186);
#11182 = LINE('',#11183,#11184);
#11183 = CARTESIAN_POINT('',(0.,-0.2));
#11184 = VECTOR('',#11185,1.);
#11185 = DIRECTION('',(1.,-0.));
#11186 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11187 = PCURVE('',#10957,#11188);
#11188 = DEFINITIONAL_REPRESENTATION('',(#11189),#11193);
#11189 = LINE('',#11190,#11191);
#11190 = CARTESIAN_POINT('',(0.129,0.16));
#11191 = VECTOR('',#11192,1.);
#11192 = DIRECTION('',(-1.,0.));
#11193 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11194 = ORIENTED_EDGE('',*,*,#10906,.F.);
#11195 = ORIENTED_EDGE('',*,*,#11196,.F.);
#11196 = EDGE_CURVE('',#11127,#10907,#11197,.T.);
#11197 = SURFACE_CURVE('',#11198,(#11202,#11209),.PCURVE_S1.);
#11198 = LINE('',#11199,#11200);
#11199 = CARTESIAN_POINT('',(0.64,-8.163,8.));
#11200 = VECTOR('',#11201,1.);
#11201 = DIRECTION('',(0.,-1.,0.));
#11202 = PCURVE('',#10929,#11203);
#11203 = DEFINITIONAL_REPRESENTATION('',(#11204),#11208);
#11204 = LINE('',#11205,#11206);
#11205 = CARTESIAN_POINT('',(0.,0.));
#11206 = VECTOR('',#11207,1.);
#11207 = DIRECTION('',(1.,-0.));
#11208 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11209 = PCURVE('',#11011,#11210);
#11210 = DEFINITIONAL_REPRESENTATION('',(#11211),#11215);
#11211 = LINE('',#11212,#11213);
#11212 = CARTESIAN_POINT('',(0.129,0.16));
#11213 = VECTOR('',#11214,1.);
#11214 = DIRECTION('',(-1.,0.));
#11215 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11216 = ADVANCED_FACE('',(#11217),#11011,.T.);
#11217 = FACE_BOUND('',#11218,.T.);
#11218 = EDGE_LOOP('',(#11219,#11220,#11221,#11222));
#11219 = ORIENTED_EDGE('',*,*,#10997,.T.);
#11220 = ORIENTED_EDGE('',*,*,#11078,.T.);
#11221 = ORIENTED_EDGE('',*,*,#11149,.T.);
#11222 = ORIENTED_EDGE('',*,*,#11196,.T.);
#11223 = ADVANCED_FACE('',(#11224),#10957,.F.);
#11224 = FACE_BOUND('',#11225,.F.);
#11225 = EDGE_LOOP('',(#11226,#11227,#11228,#11229));
#11226 = ORIENTED_EDGE('',*,*,#10941,.T.);
#11227 = ORIENTED_EDGE('',*,*,#11027,.T.);
#11228 = ORIENTED_EDGE('',*,*,#11103,.T.);
#11229 = ORIENTED_EDGE('',*,*,#11174,.T.);
#11230 = MANIFOLD_SOLID_BREP('',#11231);
#11231 = CLOSED_SHELL('',(#11232,#11352,#11430,#11508,#11586,#11664,
#11740,#11816,#11892,#11970,#12048,#12126,#12204,#12280,#12356,
#12427,#12474,#12493));
#11232 = ADVANCED_FACE('',(#11233),#11247,.T.);
#11233 = FACE_BOUND('',#11234,.T.);
#11234 = EDGE_LOOP('',(#11235,#11270,#11298,#11326));
#11235 = ORIENTED_EDGE('',*,*,#11236,.T.);
#11236 = EDGE_CURVE('',#11237,#11239,#11241,.T.);
#11237 = VERTEX_POINT('',#11238);
#11238 = CARTESIAN_POINT('',(-1.6,-10.129,8.));
#11239 = VERTEX_POINT('',#11240);
#11240 = CARTESIAN_POINT('',(-1.6,-10.129,8.2));
#11241 = SURFACE_CURVE('',#11242,(#11246,#11258),.PCURVE_S1.);
#11242 = LINE('',#11243,#11244);
#11243 = CARTESIAN_POINT('',(-1.6,-10.129,8.));
#11244 = VECTOR('',#11245,1.);
#11245 = DIRECTION('',(0.,0.,1.));
#11246 = PCURVE('',#11247,#11252);
#11247 = PLANE('',#11248);
#11248 = AXIS2_PLACEMENT_3D('',#11249,#11250,#11251);
#11249 = CARTESIAN_POINT('',(-1.6,-10.129,8.));
#11250 = DIRECTION('',(-1.,2.2E-16,0.));
#11251 = DIRECTION('',(2.2E-16,1.,0.));
#11252 = DEFINITIONAL_REPRESENTATION('',(#11253),#11257);
#11253 = LINE('',#11254,#11255);
#11254 = CARTESIAN_POINT('',(0.,0.));
#11255 = VECTOR('',#11256,1.);
#11256 = DIRECTION('',(0.,-1.));
#11257 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
PARAMETRIC_REPRESENTATION_CONTEXT() REPRESENTATION_CONTEXT('2D SPACE',''
#11258 = PCURVE('',#11259,#11264);
#11259 = PLANE('',#11260);
#11260 = AXIS2_PLACEMENT_3D('',#11261,#11262,#11263);
#11261 = CARTESIAN_POINT('',(-2.22E-15,-10.129,8.));
#11262 = DIRECTION('',(-2.2E-16,-1.,0.));
#11263 = DIRECTION('',(-1.,2.2E-16,0.));
#11264 = DEFINITIONAL_REPRESENTATION('',(#11265),#11269);
#11265 = LINE('',#11266,#11267);
#11266 = CARTESIAN_POINT('',(1.6,0.));
#11267 = VECTOR('',#11268,1.);
#11268 = DIRECTION('',(0.,-1.));
#11269 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11270 = ORIENTED_EDGE('',*,*,#11271,.T.);
#11271 = EDGE_CURVE('',#11239,#11272,#11274,.T.);
#11272 = VERTEX_POINT('',#11273);
#11273 = CARTESIAN_POINT('',(-1.6,-9.899,8.2));
#11274 = SURFACE_CURVE('',#11275,(#11279,#11286),.PCURVE_S1.);
#11275 = LINE('',#11276,#11277);
#11276 = CARTESIAN_POINT('',(-1.6,-10.129,8.2));
#11277 = VECTOR('',#11278,1.);
#11278 = DIRECTION('',(0.,1.,0.));
#11279 = PCURVE('',#11247,#11280);
#11280 = DEFINITIONAL_REPRESENTATION('',(#11281),#11285);
#11281 = LINE('',#11282,#11283);
#11282 = CARTESIAN_POINT('',(0.,-0.2));
#11283 = VECTOR('',#11284,1.);
#11284 = DIRECTION('',(1.,0.));
#11285 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11286 = PCURVE('',#11287,#11292);
#11287 = PLANE('',#11288);
#11288 = AXIS2_PLACEMENT_3D('',#11289,#11290,#11291);
#11289 = CARTESIAN_POINT('',(-0.903525599899,-9.508778786624,8.2));
#11290 = DIRECTION('',(-0.,0.,-1.));
#11291 = DIRECTION('',(0.,1.,0.));
#11292 = DEFINITIONAL_REPRESENTATION('',(#11293),#11297);
#11293 = LINE('',#11294,#11295);
#11294 = CARTESIAN_POINT('',(-0.620221213376,-0.696474400101));
#11295 = VECTOR('',#11296,1.);
#11296 = DIRECTION('',(1.,0.));
#11297 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11298 = ORIENTED_EDGE('',*,*,#11299,.F.);
#11299 = EDGE_CURVE('',#11300,#11272,#11302,.T.);
#11300 = VERTEX_POINT('',#11301);
#11301 = CARTESIAN_POINT('',(-1.6,-9.899,8.));
#11302 = SURFACE_CURVE('',#11303,(#11307,#11314),.PCURVE_S1.);
#11303 = LINE('',#11304,#11305);
#11304 = CARTESIAN_POINT('',(-1.6,-9.899,8.));
#11305 = VECTOR('',#11306,1.);
#11306 = DIRECTION('',(0.,0.,1.));
#11307 = PCURVE('',#11247,#11308);
#11308 = DEFINITIONAL_REPRESENTATION('',(#11309),#11313);
#11309 = LINE('',#11310,#11311);
#11310 = CARTESIAN_POINT('',(0.23,0.));
#11311 = VECTOR('',#11312,1.);
#11312 = DIRECTION('',(0.,-1.));
#11313 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11314 = PCURVE('',#11315,#11320);
#11315 = PLANE('',#11316);
#11316 = AXIS2_PLACEMENT_3D('',#11317,#11318,#11319);
#11317 = CARTESIAN_POINT('',(-1.6,-9.899,8.));
#11318 = DIRECTION('',(2.2E-16,1.,0.));
#11319 = DIRECTION('',(1.,-2.2E-16,0.));
#11320 = DEFINITIONAL_REPRESENTATION('',(#11321),#11325);
#11321 = LINE('',#11322,#11323);
#11322 = CARTESIAN_POINT('',(2.E-15,0.));
#11323 = VECTOR('',#11324,1.);
#11324 = DIRECTION('',(0.,-1.));
#11325 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11326 = ORIENTED_EDGE('',*,*,#11327,.F.);
#11327 = EDGE_CURVE('',#11237,#11300,#11328,.T.);
#11328 = SURFACE_CURVE('',#11329,(#11333,#11340),.PCURVE_S1.);
#11329 = LINE('',#11330,#11331);
#11330 = CARTESIAN_POINT('',(-1.6,-10.129,8.));
#11331 = VECTOR('',#11332,1.);
#11332 = DIRECTION('',(0.,1.,0.));
#11333 = PCURVE('',#11247,#11334);
#11334 = DEFINITIONAL_REPRESENTATION('',(#11335),#11339);
#11335 = LINE('',#11336,#11337);
#11336 = CARTESIAN_POINT('',(0.,0.));
#11337 = VECTOR('',#11338,1.);
#11338 = DIRECTION('',(1.,0.));
#11339 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11340 = PCURVE('',#11341,#11346);
#11341 = PLANE('',#11342);
#11342 = AXIS2_PLACEMENT_3D('',#11343,#11344,#11345);
#11343 = CARTESIAN_POINT('',(-0.903525599899,-9.508778786624,8.));
#11344 = DIRECTION('',(-0.,0.,-1.));
#11345 = DIRECTION('',(0.,1.,0.));
#11346 = DEFINITIONAL_REPRESENTATION('',(#11347),#11351);
#11347 = LINE('',#11348,#11349);
#11348 = CARTESIAN_POINT('',(-0.620221213376,-0.696474400101));
#11349 = VECTOR('',#11350,1.);
#11350 = DIRECTION('',(1.,0.));
#11351 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11352 = ADVANCED_FACE('',(#11353),#11315,.T.);
#11353 = FACE_BOUND('',#11354,.T.);
#11354 = EDGE_LOOP('',(#11355,#11356,#11379,#11409));
#11355 = ORIENTED_EDGE('',*,*,#11299,.T.);
#11356 = ORIENTED_EDGE('',*,*,#11357,.T.);
#11357 = EDGE_CURVE('',#11272,#11358,#11360,.T.);
#11358 = VERTEX_POINT('',#11359);
#11359 = CARTESIAN_POINT('',(-1.34,-9.899,8.2));
#11360 = SURFACE_CURVE('',#11361,(#11365,#11372),.PCURVE_S1.);
#11361 = LINE('',#11362,#11363);
#11362 = CARTESIAN_POINT('',(-1.6,-9.899,8.2));
#11363 = VECTOR('',#11364,1.);
#11364 = DIRECTION('',(1.,0.,0.));
#11365 = PCURVE('',#11315,#11366);
#11366 = DEFINITIONAL_REPRESENTATION('',(#11367),#11371);
#11367 = LINE('',#11368,#11369);
#11368 = CARTESIAN_POINT('',(0.,-0.2));
#11369 = VECTOR('',#11370,1.);
#11370 = DIRECTION('',(1.,0.));
#11371 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11372 = PCURVE('',#11287,#11373);
#11373 = DEFINITIONAL_REPRESENTATION('',(#11374),#11378);
#11374 = LINE('',#11375,#11376);
#11375 = CARTESIAN_POINT('',(-0.390221213376,-0.696474400101));
#11376 = VECTOR('',#11377,1.);
#11377 = DIRECTION('',(0.,1.));
#11378 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11379 = ORIENTED_EDGE('',*,*,#11380,.F.);
#11380 = EDGE_CURVE('',#11381,#11358,#11383,.T.);
#11381 = VERTEX_POINT('',#11382);
#11382 = CARTESIAN_POINT('',(-1.34,-9.899,8.));
#11383 = SURFACE_CURVE('',#11384,(#11388,#11395),.PCURVE_S1.);
#11384 = LINE('',#11385,#11386);
#11385 = CARTESIAN_POINT('',(-1.34,-9.899,8.));
#11386 = VECTOR('',#11387,1.);
#11387 = DIRECTION('',(0.,0.,1.));
#11388 = PCURVE('',#11315,#11389);
#11389 = DEFINITIONAL_REPRESENTATION('',(#11390),#11394);
#11390 = LINE('',#11391,#11392);
#11391 = CARTESIAN_POINT('',(0.26,0.));
#11392 = VECTOR('',#11393,1.);
#11393 = DIRECTION('',(0.,-1.));
#11394 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11395 = PCURVE('',#11396,#11403);
#11396 = SURFACE_OF_LINEAR_EXTRUSION('',#11397,#11401);
#11397 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11398,#11399,#11400),
.UNSPECIFIED.,.F.,.F.,(3,3),(0.,1.),.PIECEWISE_BEZIER_KNOTS.);
#11398 = CARTESIAN_POINT('',(-1.34,-9.899,8.));
#11399 = CARTESIAN_POINT('',(-1.607,-9.727,8.));
#11400 = CARTESIAN_POINT('',(-1.65,-9.499,8.));
#11401 = VECTOR('',#11402,1.);
#11402 = DIRECTION('',(-0.,-0.,-1.));
#11403 = DEFINITIONAL_REPRESENTATION('',(#11404),#11408);
#11404 = LINE('',#11405,#11406);
#11405 = CARTESIAN_POINT('',(0.,0.));
#11406 = VECTOR('',#11407,1.);
#11407 = DIRECTION('',(0.,-1.));
#11408 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11409 = ORIENTED_EDGE('',*,*,#11410,.F.);
#11410 = EDGE_CURVE('',#11300,#11381,#11411,.T.);
#11411 = SURFACE_CURVE('',#11412,(#11416,#11423),.PCURVE_S1.);
#11412 = LINE('',#11413,#11414);
#11413 = CARTESIAN_POINT('',(-1.6,-9.899,8.));
#11414 = VECTOR('',#11415,1.);
#11415 = DIRECTION('',(1.,0.,0.));
#11416 = PCURVE('',#11315,#11417);
#11417 = DEFINITIONAL_REPRESENTATION('',(#11418),#11422);
#11418 = LINE('',#11419,#11420);
#11419 = CARTESIAN_POINT('',(0.,0.));
#11420 = VECTOR('',#11421,1.);
#11421 = DIRECTION('',(1.,0.));
#11422 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11423 = PCURVE('',#11341,#11424);
#11424 = DEFINITIONAL_REPRESENTATION('',(#11425),#11429);
#11425 = LINE('',#11426,#11427);
#11426 = CARTESIAN_POINT('',(-0.390221213376,-0.696474400101));
#11427 = VECTOR('',#11428,1.);
#11428 = DIRECTION('',(0.,1.));
#11429 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11430 = ADVANCED_FACE('',(#11431),#11396,.T.);
#11431 = FACE_BOUND('',#11432,.T.);
#11432 = EDGE_LOOP('',(#11433,#11434,#11457,#11487));
#11433 = ORIENTED_EDGE('',*,*,#11380,.T.);
#11434 = ORIENTED_EDGE('',*,*,#11435,.T.);
#11435 = EDGE_CURVE('',#11358,#11436,#11438,.T.);
#11436 = VERTEX_POINT('',#11437);
#11437 = CARTESIAN_POINT('',(-1.65,-9.499,8.2));
#11438 = SURFACE_CURVE('',#11439,(#11443,#11450),.PCURVE_S1.);
#11439 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11440,#11441,#11442),
#11440 = CARTESIAN_POINT('',(-1.34,-9.899,8.2));
#11441 = CARTESIAN_POINT('',(-1.607,-9.727,8.2));
#11442 = CARTESIAN_POINT('',(-1.65,-9.499,8.2));
#11443 = PCURVE('',#11396,#11444);
#11444 = DEFINITIONAL_REPRESENTATION('',(#11445),#11449);
#11445 = LINE('',#11446,#11447);
#11446 = CARTESIAN_POINT('',(0.,-0.2));
#11447 = VECTOR('',#11448,1.);
#11448 = DIRECTION('',(1.,0.));
#11449 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11450 = PCURVE('',#11287,#11451);
#11451 = DEFINITIONAL_REPRESENTATION('',(#11452),#11456);
#11452 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11453,#11454,#11455),
#11453 = CARTESIAN_POINT('',(-0.390221213376,-0.436474400101));
#11454 = CARTESIAN_POINT('',(-0.218221213376,-0.703474400101));
#11455 = CARTESIAN_POINT('',(9.778786623837E-03,-0.746474400101));
#11456 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11457 = ORIENTED_EDGE('',*,*,#11458,.F.);
#11458 = EDGE_CURVE('',#11459,#11436,#11461,.T.);
#11459 = VERTEX_POINT('',#11460);
#11460 = CARTESIAN_POINT('',(-1.65,-9.499,8.));
#11461 = SURFACE_CURVE('',#11462,(#11466,#11473),.PCURVE_S1.);
#11462 = LINE('',#11463,#11464);
#11463 = CARTESIAN_POINT('',(-1.65,-9.499,8.));
#11464 = VECTOR('',#11465,1.);
#11465 = DIRECTION('',(0.,0.,1.));
#11466 = PCURVE('',#11396,#11467);
#11467 = DEFINITIONAL_REPRESENTATION('',(#11468),#11472);
#11468 = LINE('',#11469,#11470);
#11469 = CARTESIAN_POINT('',(1.,0.));
#11470 = VECTOR('',#11471,1.);
#11471 = DIRECTION('',(0.,-1.));
#11472 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11473 = PCURVE('',#11474,#11481);
#11474 = SURFACE_OF_LINEAR_EXTRUSION('',#11475,#11479);
#11475 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11476,#11477,#11478),
#11476 = CARTESIAN_POINT('',(-1.65,-9.499,8.));
#11477 = CARTESIAN_POINT('',(-1.664,-9.435,8.));
#11478 = CARTESIAN_POINT('',(-1.664,-9.361,8.));
#11479 = VECTOR('',#11480,1.);
#11480 = DIRECTION('',(-0.,-0.,-1.));
#11481 = DEFINITIONAL_REPRESENTATION('',(#11482),#11486);
#11482 = LINE('',#11483,#11484);
#11483 = CARTESIAN_POINT('',(0.,0.));
#11484 = VECTOR('',#11485,1.);
#11485 = DIRECTION('',(0.,-1.));
#11486 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11487 = ORIENTED_EDGE('',*,*,#11488,.F.);
#11488 = EDGE_CURVE('',#11381,#11459,#11489,.T.);
#11489 = SURFACE_CURVE('',#11490,(#11494,#11501),.PCURVE_S1.);
#11490 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11491,#11492,#11493),
#11491 = CARTESIAN_POINT('',(-1.34,-9.899,8.));
#11492 = CARTESIAN_POINT('',(-1.607,-9.727,8.));
#11493 = CARTESIAN_POINT('',(-1.65,-9.499,8.));
#11494 = PCURVE('',#11396,#11495);
#11495 = DEFINITIONAL_REPRESENTATION('',(#11496),#11500);
#11496 = LINE('',#11497,#11498);
#11497 = CARTESIAN_POINT('',(0.,0.));
#11498 = VECTOR('',#11499,1.);
#11499 = DIRECTION('',(1.,0.));
#11500 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11501 = PCURVE('',#11341,#11502);
#11502 = DEFINITIONAL_REPRESENTATION('',(#11503),#11507);
#11503 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11504,#11505,#11506),
#11504 = CARTESIAN_POINT('',(-0.390221213376,-0.436474400101));
#11505 = CARTESIAN_POINT('',(-0.218221213376,-0.703474400101));
#11506 = CARTESIAN_POINT('',(9.778786623837E-03,-0.746474400101));
#11507 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11508 = ADVANCED_FACE('',(#11509),#11474,.T.);
#11509 = FACE_BOUND('',#11510,.T.);
#11510 = EDGE_LOOP('',(#11511,#11512,#11535,#11565));
#11511 = ORIENTED_EDGE('',*,*,#11458,.T.);
#11512 = ORIENTED_EDGE('',*,*,#11513,.T.);
#11513 = EDGE_CURVE('',#11436,#11514,#11516,.T.);
#11514 = VERTEX_POINT('',#11515);
#11515 = CARTESIAN_POINT('',(-1.664,-9.361,8.2));
#11516 = SURFACE_CURVE('',#11517,(#11521,#11528),.PCURVE_S1.);
#11517 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11518,#11519,#11520),
#11518 = CARTESIAN_POINT('',(-1.65,-9.499,8.2));
#11519 = CARTESIAN_POINT('',(-1.664,-9.435,8.2));
#11520 = CARTESIAN_POINT('',(-1.664,-9.361,8.2));
#11521 = PCURVE('',#11474,#11522);
#11522 = DEFINITIONAL_REPRESENTATION('',(#11523),#11527);
#11523 = LINE('',#11524,#11525);
#11524 = CARTESIAN_POINT('',(0.,-0.2));
#11525 = VECTOR('',#11526,1.);
#11526 = DIRECTION('',(1.,0.));
#11527 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11528 = PCURVE('',#11287,#11529);
#11529 = DEFINITIONAL_REPRESENTATION('',(#11530),#11534);
#11530 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11531,#11532,#11533),
#11531 = CARTESIAN_POINT('',(9.778786623837E-03,-0.746474400101));
#11532 = CARTESIAN_POINT('',(7.377878662384E-02,-0.760474400101));
#11533 = CARTESIAN_POINT('',(0.147778786624,-0.760474400101));
#11534 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11535 = ORIENTED_EDGE('',*,*,#11536,.F.);
#11536 = EDGE_CURVE('',#11537,#11514,#11539,.T.);
#11537 = VERTEX_POINT('',#11538);
#11538 = CARTESIAN_POINT('',(-1.664,-9.361,8.));
#11539 = SURFACE_CURVE('',#11540,(#11544,#11551),.PCURVE_S1.);
#11540 = LINE('',#11541,#11542);
#11541 = CARTESIAN_POINT('',(-1.664,-9.361,8.));
#11542 = VECTOR('',#11543,1.);
#11543 = DIRECTION('',(0.,0.,1.));
#11544 = PCURVE('',#11474,#11545);
#11545 = DEFINITIONAL_REPRESENTATION('',(#11546),#11550);
#11546 = LINE('',#11547,#11548);
#11547 = CARTESIAN_POINT('',(1.,0.));
#11548 = VECTOR('',#11549,1.);
#11549 = DIRECTION('',(0.,-1.));
#11550 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11551 = PCURVE('',#11552,#11559);
#11552 = SURFACE_OF_LINEAR_EXTRUSION('',#11553,#11557);
#11553 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11554,#11555,#11556),
#11554 = CARTESIAN_POINT('',(-1.664,-9.361,8.));
#11555 = CARTESIAN_POINT('',(-1.664,-9.032,8.));
#11556 = CARTESIAN_POINT('',(-1.451,-8.906,8.));
#11557 = VECTOR('',#11558,1.);
#11558 = DIRECTION('',(-0.,-0.,-1.));
#11559 = DEFINITIONAL_REPRESENTATION('',(#11560),#11564);
#11560 = LINE('',#11561,#11562);
#11561 = CARTESIAN_POINT('',(0.,0.));
#11562 = VECTOR('',#11563,1.);
#11563 = DIRECTION('',(0.,-1.));
#11564 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11565 = ORIENTED_EDGE('',*,*,#11566,.F.);
#11566 = EDGE_CURVE('',#11459,#11537,#11567,.T.);
#11567 = SURFACE_CURVE('',#11568,(#11572,#11579),.PCURVE_S1.);
#11568 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11569,#11570,#11571),
#11569 = CARTESIAN_POINT('',(-1.65,-9.499,8.));
#11570 = CARTESIAN_POINT('',(-1.664,-9.435,8.));
#11571 = CARTESIAN_POINT('',(-1.664,-9.361,8.));
#11572 = PCURVE('',#11474,#11573);
#11573 = DEFINITIONAL_REPRESENTATION('',(#11574),#11578);
#11574 = LINE('',#11575,#11576);
#11575 = CARTESIAN_POINT('',(0.,0.));
#11576 = VECTOR('',#11577,1.);
#11577 = DIRECTION('',(1.,0.));
#11578 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11579 = PCURVE('',#11341,#11580);
#11580 = DEFINITIONAL_REPRESENTATION('',(#11581),#11585);
#11581 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11582,#11583,#11584),
#11582 = CARTESIAN_POINT('',(9.778786623837E-03,-0.746474400101));
#11583 = CARTESIAN_POINT('',(7.377878662384E-02,-0.760474400101));
#11584 = CARTESIAN_POINT('',(0.147778786624,-0.760474400101));
#11585 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11586 = ADVANCED_FACE('',(#11587),#11552,.T.);
#11587 = FACE_BOUND('',#11588,.T.);
#11588 = EDGE_LOOP('',(#11589,#11590,#11613,#11643));
#11589 = ORIENTED_EDGE('',*,*,#11536,.T.);
#11590 = ORIENTED_EDGE('',*,*,#11591,.T.);
#11591 = EDGE_CURVE('',#11514,#11592,#11594,.T.);
#11592 = VERTEX_POINT('',#11593);
#11593 = CARTESIAN_POINT('',(-1.451,-8.906,8.2));
#11594 = SURFACE_CURVE('',#11595,(#11599,#11606),.PCURVE_S1.);
#11595 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11596,#11597,#11598),
#11596 = CARTESIAN_POINT('',(-1.664,-9.361,8.2));
#11597 = CARTESIAN_POINT('',(-1.664,-9.032,8.2));
#11598 = CARTESIAN_POINT('',(-1.451,-8.906,8.2));
#11599 = PCURVE('',#11552,#11600);
#11600 = DEFINITIONAL_REPRESENTATION('',(#11601),#11605);
#11601 = LINE('',#11602,#11603);
#11602 = CARTESIAN_POINT('',(0.,-0.2));
#11603 = VECTOR('',#11604,1.);
#11604 = DIRECTION('',(1.,0.));
#11605 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11606 = PCURVE('',#11287,#11607);
#11607 = DEFINITIONAL_REPRESENTATION('',(#11608),#11612);
#11608 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11609,#11610,#11611),
#11609 = CARTESIAN_POINT('',(0.147778786624,-0.760474400101));
#11610 = CARTESIAN_POINT('',(0.476778786624,-0.760474400101));
#11611 = CARTESIAN_POINT('',(0.602778786624,-0.547474400101));
#11612 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11613 = ORIENTED_EDGE('',*,*,#11614,.F.);
#11614 = EDGE_CURVE('',#11615,#11592,#11617,.T.);
#11615 = VERTEX_POINT('',#11616);
#11616 = CARTESIAN_POINT('',(-1.451,-8.906,8.));
#11617 = SURFACE_CURVE('',#11618,(#11622,#11629),.PCURVE_S1.);
#11618 = LINE('',#11619,#11620);
#11619 = CARTESIAN_POINT('',(-1.451,-8.906,8.));
#11620 = VECTOR('',#11621,1.);
#11621 = DIRECTION('',(0.,0.,1.));
#11622 = PCURVE('',#11552,#11623);
#11623 = DEFINITIONAL_REPRESENTATION('',(#11624),#11628);
#11624 = LINE('',#11625,#11626);
#11625 = CARTESIAN_POINT('',(1.,0.));
#11626 = VECTOR('',#11627,1.);
#11627 = DIRECTION('',(0.,-1.));
#11628 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11629 = PCURVE('',#11630,#11637);
#11630 = SURFACE_OF_LINEAR_EXTRUSION('',#11631,#11635);
#11631 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11632,#11633,#11634),
#11632 = CARTESIAN_POINT('',(-1.451,-8.906,8.));
#11633 = CARTESIAN_POINT('',(-1.351,-8.848,8.));
#11634 = CARTESIAN_POINT('',(-1.229,-8.848,8.));
#11635 = VECTOR('',#11636,1.);
#11636 = DIRECTION('',(-0.,-0.,-1.));
#11637 = DEFINITIONAL_REPRESENTATION('',(#11638),#11642);
#11638 = LINE('',#11639,#11640);
#11639 = CARTESIAN_POINT('',(0.,0.));
#11640 = VECTOR('',#11641,1.);
#11641 = DIRECTION('',(0.,-1.));
#11642 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11643 = ORIENTED_EDGE('',*,*,#11644,.F.);
#11644 = EDGE_CURVE('',#11537,#11615,#11645,.T.);
#11645 = SURFACE_CURVE('',#11646,(#11650,#11657),.PCURVE_S1.);
#11646 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11647,#11648,#11649),
#11647 = CARTESIAN_POINT('',(-1.664,-9.361,8.));
#11648 = CARTESIAN_POINT('',(-1.664,-9.032,8.));
#11649 = CARTESIAN_POINT('',(-1.451,-8.906,8.));
#11650 = PCURVE('',#11552,#11651);
#11651 = DEFINITIONAL_REPRESENTATION('',(#11652),#11656);
#11652 = LINE('',#11653,#11654);
#11653 = CARTESIAN_POINT('',(0.,0.));
#11654 = VECTOR('',#11655,1.);
#11655 = DIRECTION('',(1.,0.));
#11656 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11657 = PCURVE('',#11341,#11658);
#11658 = DEFINITIONAL_REPRESENTATION('',(#11659),#11663);
#11659 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11660,#11661,#11662),
#11660 = CARTESIAN_POINT('',(0.147778786624,-0.760474400101));
#11661 = CARTESIAN_POINT('',(0.476778786624,-0.760474400101));
#11662 = CARTESIAN_POINT('',(0.602778786624,-0.547474400101));
#11663 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11664 = ADVANCED_FACE('',(#11665),#11630,.T.);
#11665 = FACE_BOUND('',#11666,.T.);
#11666 = EDGE_LOOP('',(#11667,#11668,#11691,#11719));
#11667 = ORIENTED_EDGE('',*,*,#11614,.T.);
#11668 = ORIENTED_EDGE('',*,*,#11669,.T.);
#11669 = EDGE_CURVE('',#11592,#11670,#11672,.T.);
#11670 = VERTEX_POINT('',#11671);
#11671 = CARTESIAN_POINT('',(-1.229,-8.848,8.2));
#11672 = SURFACE_CURVE('',#11673,(#11677,#11684),.PCURVE_S1.);
#11673 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11674,#11675,#11676),
#11674 = CARTESIAN_POINT('',(-1.451,-8.906,8.2));
#11675 = CARTESIAN_POINT('',(-1.351,-8.848,8.2));
#11676 = CARTESIAN_POINT('',(-1.229,-8.848,8.2));
#11677 = PCURVE('',#11630,#11678);
#11678 = DEFINITIONAL_REPRESENTATION('',(#11679),#11683);
#11679 = LINE('',#11680,#11681);
#11680 = CARTESIAN_POINT('',(0.,-0.2));
#11681 = VECTOR('',#11682,1.);
#11682 = DIRECTION('',(1.,0.));
#11683 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11684 = PCURVE('',#11287,#11685);
#11685 = DEFINITIONAL_REPRESENTATION('',(#11686),#11690);
#11686 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11687,#11688,#11689),
#11687 = CARTESIAN_POINT('',(0.602778786624,-0.547474400101));
#11688 = CARTESIAN_POINT('',(0.660778786624,-0.447474400101));
#11689 = CARTESIAN_POINT('',(0.660778786624,-0.325474400101));
#11690 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11691 = ORIENTED_EDGE('',*,*,#11692,.F.);
#11692 = EDGE_CURVE('',#11693,#11670,#11695,.T.);
#11693 = VERTEX_POINT('',#11694);
#11694 = CARTESIAN_POINT('',(-1.229,-8.848,8.));
#11695 = SURFACE_CURVE('',#11696,(#11700,#11707),.PCURVE_S1.);
#11696 = LINE('',#11697,#11698);
#11697 = CARTESIAN_POINT('',(-1.229,-8.848,8.));
#11698 = VECTOR('',#11699,1.);
#11699 = DIRECTION('',(0.,0.,1.));
#11700 = PCURVE('',#11630,#11701);
#11701 = DEFINITIONAL_REPRESENTATION('',(#11702),#11706);
#11702 = LINE('',#11703,#11704);
#11703 = CARTESIAN_POINT('',(1.,0.));
#11704 = VECTOR('',#11705,1.);
#11705 = DIRECTION('',(0.,-1.));
#11706 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11707 = PCURVE('',#11708,#11713);
#11708 = PLANE('',#11709);
#11709 = AXIS2_PLACEMENT_3D('',#11710,#11711,#11712);
#11710 = CARTESIAN_POINT('',(-1.229,-8.848,8.));
#11711 = DIRECTION('',(2.2E-16,1.,0.));
#11712 = DIRECTION('',(1.,-2.2E-16,0.));
#11713 = DEFINITIONAL_REPRESENTATION('',(#11714),#11718);
#11714 = LINE('',#11715,#11716);
#11715 = CARTESIAN_POINT('',(1.78E-15,0.));
#11716 = VECTOR('',#11717,1.);
#11717 = DIRECTION('',(0.,-1.));
#11718 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11719 = ORIENTED_EDGE('',*,*,#11720,.F.);
#11720 = EDGE_CURVE('',#11615,#11693,#11721,.T.);
#11721 = SURFACE_CURVE('',#11722,(#11726,#11733),.PCURVE_S1.);
#11722 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11723,#11724,#11725),
#11723 = CARTESIAN_POINT('',(-1.451,-8.906,8.));
#11724 = CARTESIAN_POINT('',(-1.351,-8.848,8.));
#11725 = CARTESIAN_POINT('',(-1.229,-8.848,8.));
#11726 = PCURVE('',#11630,#11727);
#11727 = DEFINITIONAL_REPRESENTATION('',(#11728),#11732);
#11728 = LINE('',#11729,#11730);
#11729 = CARTESIAN_POINT('',(0.,0.));
#11730 = VECTOR('',#11731,1.);
#11731 = DIRECTION('',(1.,0.));
#11732 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11733 = PCURVE('',#11341,#11734);
#11734 = DEFINITIONAL_REPRESENTATION('',(#11735),#11739);
#11735 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11736,#11737,#11738),
#11736 = CARTESIAN_POINT('',(0.602778786624,-0.547474400101));
#11737 = CARTESIAN_POINT('',(0.660778786624,-0.447474400101));
#11738 = CARTESIAN_POINT('',(0.660778786624,-0.325474400101));
#11739 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11740 = ADVANCED_FACE('',(#11741),#11708,.T.);
#11741 = FACE_BOUND('',#11742,.T.);
#11742 = EDGE_LOOP('',(#11743,#11744,#11767,#11795));
#11743 = ORIENTED_EDGE('',*,*,#11692,.T.);
#11744 = ORIENTED_EDGE('',*,*,#11745,.T.);
#11745 = EDGE_CURVE('',#11670,#11746,#11748,.T.);
#11746 = VERTEX_POINT('',#11747);
#11747 = CARTESIAN_POINT('',(-2.E-15,-8.848,8.2));
#11748 = SURFACE_CURVE('',#11749,(#11753,#11760),.PCURVE_S1.);
#11749 = LINE('',#11750,#11751);
#11750 = CARTESIAN_POINT('',(-1.229,-8.848,8.2));
#11751 = VECTOR('',#11752,1.);
#11752 = DIRECTION('',(1.,0.,0.));
#11753 = PCURVE('',#11708,#11754);
#11754 = DEFINITIONAL_REPRESENTATION('',(#11755),#11759);
#11755 = LINE('',#11756,#11757);
#11756 = CARTESIAN_POINT('',(0.,-0.2));
#11757 = VECTOR('',#11758,1.);
#11758 = DIRECTION('',(1.,0.));
#11759 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11760 = PCURVE('',#11287,#11761);
#11761 = DEFINITIONAL_REPRESENTATION('',(#11762),#11766);
#11762 = LINE('',#11763,#11764);
#11763 = CARTESIAN_POINT('',(0.660778786624,-0.325474400101));
#11764 = VECTOR('',#11765,1.);
#11765 = DIRECTION('',(0.,1.));
#11766 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11767 = ORIENTED_EDGE('',*,*,#11768,.F.);
#11768 = EDGE_CURVE('',#11769,#11746,#11771,.T.);
#11769 = VERTEX_POINT('',#11770);
#11770 = CARTESIAN_POINT('',(-2.E-15,-8.848,8.));
#11771 = SURFACE_CURVE('',#11772,(#11776,#11783),.PCURVE_S1.);
#11772 = LINE('',#11773,#11774);
#11773 = CARTESIAN_POINT('',(-1.78E-15,-8.848,8.));
#11774 = VECTOR('',#11775,1.);
#11775 = DIRECTION('',(0.,0.,1.));
#11776 = PCURVE('',#11708,#11777);
#11777 = DEFINITIONAL_REPRESENTATION('',(#11778),#11782);
#11778 = LINE('',#11779,#11780);
#11779 = CARTESIAN_POINT('',(1.229,0.));
#11780 = VECTOR('',#11781,1.);
#11781 = DIRECTION('',(0.,-1.));
#11782 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11783 = PCURVE('',#11784,#11789);
#11784 = PLANE('',#11785);
#11785 = AXIS2_PLACEMENT_3D('',#11786,#11787,#11788);
#11786 = CARTESIAN_POINT('',(-1.78E-15,-8.848,8.));
#11787 = DIRECTION('',(1.,-2.2E-16,0.));
#11788 = DIRECTION('',(-2.2E-16,-1.,0.));
#11789 = DEFINITIONAL_REPRESENTATION('',(#11790),#11794);
#11790 = LINE('',#11791,#11792);
#11791 = CARTESIAN_POINT('',(1.78E-15,-0.));
#11792 = VECTOR('',#11793,1.);
#11793 = DIRECTION('',(0.,-1.));
#11794 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11795 = ORIENTED_EDGE('',*,*,#11796,.F.);
#11796 = EDGE_CURVE('',#11693,#11769,#11797,.T.);
#11797 = SURFACE_CURVE('',#11798,(#11802,#11809),.PCURVE_S1.);
#11798 = LINE('',#11799,#11800);
#11799 = CARTESIAN_POINT('',(-1.229,-8.848,8.));
#11800 = VECTOR('',#11801,1.);
#11801 = DIRECTION('',(1.,0.,0.));
#11802 = PCURVE('',#11708,#11803);
#11803 = DEFINITIONAL_REPRESENTATION('',(#11804),#11808);
#11804 = LINE('',#11805,#11806);
#11805 = CARTESIAN_POINT('',(0.,0.));
#11806 = VECTOR('',#11807,1.);
#11807 = DIRECTION('',(1.,0.));
#11808 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11809 = PCURVE('',#11341,#11810);
#11810 = DEFINITIONAL_REPRESENTATION('',(#11811),#11815);
#11811 = LINE('',#11812,#11813);
#11812 = CARTESIAN_POINT('',(0.660778786624,-0.325474400101));
#11813 = VECTOR('',#11814,1.);
#11814 = DIRECTION('',(0.,1.));
#11815 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11816 = ADVANCED_FACE('',(#11817),#11784,.T.);
#11817 = FACE_BOUND('',#11818,.T.);
#11818 = EDGE_LOOP('',(#11819,#11820,#11843,#11871));
#11819 = ORIENTED_EDGE('',*,*,#11768,.T.);
#11820 = ORIENTED_EDGE('',*,*,#11821,.T.);
#11821 = EDGE_CURVE('',#11746,#11822,#11824,.T.);
#11822 = VERTEX_POINT('',#11823);
#11823 = CARTESIAN_POINT('',(-2.E-15,-9.103,8.2));
#11824 = SURFACE_CURVE('',#11825,(#11829,#11836),.PCURVE_S1.);
#11825 = LINE('',#11826,#11827);
#11826 = CARTESIAN_POINT('',(0.,-8.848,8.2));
#11827 = VECTOR('',#11828,1.);
#11828 = DIRECTION('',(0.,-1.,0.));
#11829 = PCURVE('',#11784,#11830);
#11830 = DEFINITIONAL_REPRESENTATION('',(#11831),#11835);
#11831 = LINE('',#11832,#11833);
#11832 = CARTESIAN_POINT('',(0.,-0.2));
#11833 = VECTOR('',#11834,1.);
#11834 = DIRECTION('',(1.,-0.));
#11835 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11836 = PCURVE('',#11287,#11837);
#11837 = DEFINITIONAL_REPRESENTATION('',(#11838),#11842);
#11838 = LINE('',#11839,#11840);
#11839 = CARTESIAN_POINT('',(0.660778786624,0.903525599899));
#11840 = VECTOR('',#11841,1.);
#11841 = DIRECTION('',(-1.,0.));
#11842 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11843 = ORIENTED_EDGE('',*,*,#11844,.F.);
#11844 = EDGE_CURVE('',#11845,#11822,#11847,.T.);
#11845 = VERTEX_POINT('',#11846);
#11846 = CARTESIAN_POINT('',(-2.E-15,-9.103,8.));
#11847 = SURFACE_CURVE('',#11848,(#11852,#11859),.PCURVE_S1.);
#11848 = LINE('',#11849,#11850);
#11849 = CARTESIAN_POINT('',(-2.E-15,-9.103,8.));
#11850 = VECTOR('',#11851,1.);
#11851 = DIRECTION('',(0.,0.,1.));
#11852 = PCURVE('',#11784,#11853);
#11853 = DEFINITIONAL_REPRESENTATION('',(#11854),#11858);
#11854 = LINE('',#11855,#11856);
#11855 = CARTESIAN_POINT('',(0.255,-0.));
#11856 = VECTOR('',#11857,1.);
#11857 = DIRECTION('',(0.,-1.));
#11858 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11859 = PCURVE('',#11860,#11865);
#11860 = PLANE('',#11861);
#11861 = AXIS2_PLACEMENT_3D('',#11862,#11863,#11864);
#11862 = CARTESIAN_POINT('',(-2.E-15,-9.103,8.));
#11863 = DIRECTION('',(-2.2E-16,-1.,0.));
#11864 = DIRECTION('',(-1.,2.2E-16,0.));
#11865 = DEFINITIONAL_REPRESENTATION('',(#11866),#11870);
#11866 = LINE('',#11867,#11868);
#11867 = CARTESIAN_POINT('',(-0.,0.));
#11868 = VECTOR('',#11869,1.);
#11869 = DIRECTION('',(0.,-1.));
#11870 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11871 = ORIENTED_EDGE('',*,*,#11872,.F.);
#11872 = EDGE_CURVE('',#11769,#11845,#11873,.T.);
#11873 = SURFACE_CURVE('',#11874,(#11878,#11885),.PCURVE_S1.);
#11874 = LINE('',#11875,#11876);
#11875 = CARTESIAN_POINT('',(0.,-8.848,8.));
#11876 = VECTOR('',#11877,1.);
#11877 = DIRECTION('',(0.,-1.,0.));
#11878 = PCURVE('',#11784,#11879);
#11879 = DEFINITIONAL_REPRESENTATION('',(#11880),#11884);
#11880 = LINE('',#11881,#11882);
#11881 = CARTESIAN_POINT('',(0.,0.));
#11882 = VECTOR('',#11883,1.);
#11883 = DIRECTION('',(1.,-0.));
#11884 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11885 = PCURVE('',#11341,#11886);
#11886 = DEFINITIONAL_REPRESENTATION('',(#11887),#11891);
#11887 = LINE('',#11888,#11889);
#11888 = CARTESIAN_POINT('',(0.660778786624,0.903525599899));
#11889 = VECTOR('',#11890,1.);
#11890 = DIRECTION('',(-1.,0.));
#11891 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11892 = ADVANCED_FACE('',(#11893),#11860,.T.);
#11893 = FACE_BOUND('',#11894,.T.);
#11894 = EDGE_LOOP('',(#11895,#11896,#11919,#11949));
#11895 = ORIENTED_EDGE('',*,*,#11844,.T.);
#11896 = ORIENTED_EDGE('',*,*,#11897,.T.);
#11897 = EDGE_CURVE('',#11822,#11898,#11900,.T.);
#11898 = VERTEX_POINT('',#11899);
#11899 = CARTESIAN_POINT('',(-1.102,-9.103,8.2));
#11900 = SURFACE_CURVE('',#11901,(#11905,#11912),.PCURVE_S1.);
#11901 = LINE('',#11902,#11903);
#11902 = CARTESIAN_POINT('',(0.,-9.103,8.2));
#11903 = VECTOR('',#11904,1.);
#11904 = DIRECTION('',(-1.,0.,0.));
#11905 = PCURVE('',#11860,#11906);
#11906 = DEFINITIONAL_REPRESENTATION('',(#11907),#11911);
#11907 = LINE('',#11908,#11909);
#11908 = CARTESIAN_POINT('',(0.,-0.2));
#11909 = VECTOR('',#11910,1.);
#11910 = DIRECTION('',(1.,0.));
#11911 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11912 = PCURVE('',#11287,#11913);
#11913 = DEFINITIONAL_REPRESENTATION('',(#11914),#11918);
#11914 = LINE('',#11915,#11916);
#11915 = CARTESIAN_POINT('',(0.405778786624,0.903525599899));
#11916 = VECTOR('',#11917,1.);
#11917 = DIRECTION('',(0.,-1.));
#11918 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11919 = ORIENTED_EDGE('',*,*,#11920,.F.);
#11920 = EDGE_CURVE('',#11921,#11898,#11923,.T.);
#11921 = VERTEX_POINT('',#11922);
#11922 = CARTESIAN_POINT('',(-1.102,-9.103,8.));
#11923 = SURFACE_CURVE('',#11924,(#11928,#11935),.PCURVE_S1.);
#11924 = LINE('',#11925,#11926);
#11925 = CARTESIAN_POINT('',(-1.102,-9.103,8.));
#11926 = VECTOR('',#11927,1.);
#11927 = DIRECTION('',(0.,0.,1.));
#11928 = PCURVE('',#11860,#11929);
#11929 = DEFINITIONAL_REPRESENTATION('',(#11930),#11934);
#11930 = LINE('',#11931,#11932);
#11931 = CARTESIAN_POINT('',(1.102,0.));
#11932 = VECTOR('',#11933,1.);
#11933 = DIRECTION('',(0.,-1.));
#11934 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11935 = PCURVE('',#11936,#11943);
#11936 = SURFACE_OF_LINEAR_EXTRUSION('',#11937,#11941);
#11937 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11938,#11939,#11940),
#11938 = CARTESIAN_POINT('',(-1.102,-9.103,8.));
#11939 = CARTESIAN_POINT('',(-1.31,-9.103,8.));
#11940 = CARTESIAN_POINT('',(-1.381,-9.284,8.));
#11941 = VECTOR('',#11942,1.);
#11942 = DIRECTION('',(-0.,-0.,-1.));
#11943 = DEFINITIONAL_REPRESENTATION('',(#11944),#11948);
#11944 = LINE('',#11945,#11946);
#11945 = CARTESIAN_POINT('',(0.,0.));
#11946 = VECTOR('',#11947,1.);
#11947 = DIRECTION('',(0.,-1.));
#11948 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11949 = ORIENTED_EDGE('',*,*,#11950,.F.);
#11950 = EDGE_CURVE('',#11845,#11921,#11951,.T.);
#11951 = SURFACE_CURVE('',#11952,(#11956,#11963),.PCURVE_S1.);
#11952 = LINE('',#11953,#11954);
#11953 = CARTESIAN_POINT('',(0.,-9.103,8.));
#11954 = VECTOR('',#11955,1.);
#11955 = DIRECTION('',(-1.,0.,0.));
#11956 = PCURVE('',#11860,#11957);
#11957 = DEFINITIONAL_REPRESENTATION('',(#11958),#11962);
#11958 = LINE('',#11959,#11960);
#11959 = CARTESIAN_POINT('',(0.,0.));
#11960 = VECTOR('',#11961,1.);
#11961 = DIRECTION('',(1.,0.));
#11962 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11963 = PCURVE('',#11341,#11964);
#11964 = DEFINITIONAL_REPRESENTATION('',(#11965),#11969);
#11965 = LINE('',#11966,#11967);
#11966 = CARTESIAN_POINT('',(0.405778786624,0.903525599899));
#11967 = VECTOR('',#11968,1.);
#11968 = DIRECTION('',(0.,-1.));
#11969 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11970 = ADVANCED_FACE('',(#11971),#11936,.T.);
#11971 = FACE_BOUND('',#11972,.T.);
#11972 = EDGE_LOOP('',(#11973,#11974,#11997,#12027));
#11973 = ORIENTED_EDGE('',*,*,#11920,.T.);
#11974 = ORIENTED_EDGE('',*,*,#11975,.T.);
#11975 = EDGE_CURVE('',#11898,#11976,#11978,.T.);
#11976 = VERTEX_POINT('',#11977);
#11977 = CARTESIAN_POINT('',(-1.381,-9.284,8.2));
#11978 = SURFACE_CURVE('',#11979,(#11983,#11990),.PCURVE_S1.);
#11979 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11980,#11981,#11982),
#11980 = CARTESIAN_POINT('',(-1.102,-9.103,8.2));
#11981 = CARTESIAN_POINT('',(-1.31,-9.103,8.2));
#11982 = CARTESIAN_POINT('',(-1.381,-9.284,8.2));
#11983 = PCURVE('',#11936,#11984);
#11984 = DEFINITIONAL_REPRESENTATION('',(#11985),#11989);
#11985 = LINE('',#11986,#11987);
#11986 = CARTESIAN_POINT('',(0.,-0.2));
#11987 = VECTOR('',#11988,1.);
#11988 = DIRECTION('',(1.,0.));
#11989 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11990 = PCURVE('',#11287,#11991);
#11991 = DEFINITIONAL_REPRESENTATION('',(#11992),#11996);
#11992 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#11993,#11994,#11995),
#11993 = CARTESIAN_POINT('',(0.405778786624,-0.198474400101));
#11994 = CARTESIAN_POINT('',(0.405778786624,-0.406474400101));
#11995 = CARTESIAN_POINT('',(0.224778786624,-0.477474400101));
#11996 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#11997 = ORIENTED_EDGE('',*,*,#11998,.F.);
#11998 = EDGE_CURVE('',#11999,#11976,#12001,.T.);
#11999 = VERTEX_POINT('',#12000);
#12000 = CARTESIAN_POINT('',(-1.381,-9.284,8.));
#12001 = SURFACE_CURVE('',#12002,(#12006,#12013),.PCURVE_S1.);
#12002 = LINE('',#12003,#12004);
#12003 = CARTESIAN_POINT('',(-1.381,-9.284,8.));
#12004 = VECTOR('',#12005,1.);
#12005 = DIRECTION('',(0.,0.,1.));
#12006 = PCURVE('',#11936,#12007);
#12007 = DEFINITIONAL_REPRESENTATION('',(#12008),#12012);
#12008 = LINE('',#12009,#12010);
#12009 = CARTESIAN_POINT('',(1.,0.));
#12010 = VECTOR('',#12011,1.);
#12011 = DIRECTION('',(0.,-1.));
#12012 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12013 = PCURVE('',#12014,#12021);
#12014 = SURFACE_OF_LINEAR_EXTRUSION('',#12015,#12019);
#12015 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12016,#12017,#12018),
#12016 = CARTESIAN_POINT('',(-1.381,-9.284,8.));
#12017 = CARTESIAN_POINT('',(-1.408,-9.352,8.));
#12018 = CARTESIAN_POINT('',(-1.408,-9.435,8.));
#12019 = VECTOR('',#12020,1.);
#12020 = DIRECTION('',(-0.,-0.,-1.));
#12021 = DEFINITIONAL_REPRESENTATION('',(#12022),#12026);
#12022 = LINE('',#12023,#12024);
#12023 = CARTESIAN_POINT('',(0.,0.));
#12024 = VECTOR('',#12025,1.);
#12025 = DIRECTION('',(0.,-1.));
#12026 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12027 = ORIENTED_EDGE('',*,*,#12028,.F.);
#12028 = EDGE_CURVE('',#11921,#11999,#12029,.T.);
#12029 = SURFACE_CURVE('',#12030,(#12034,#12041),.PCURVE_S1.);
#12030 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12031,#12032,#12033),
#12031 = CARTESIAN_POINT('',(-1.102,-9.103,8.));
#12032 = CARTESIAN_POINT('',(-1.31,-9.103,8.));
#12033 = CARTESIAN_POINT('',(-1.381,-9.284,8.));
#12034 = PCURVE('',#11936,#12035);
#12035 = DEFINITIONAL_REPRESENTATION('',(#12036),#12040);
#12036 = LINE('',#12037,#12038);
#12037 = CARTESIAN_POINT('',(0.,0.));
#12038 = VECTOR('',#12039,1.);
#12039 = DIRECTION('',(1.,0.));
#12040 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12041 = PCURVE('',#11341,#12042);
#12042 = DEFINITIONAL_REPRESENTATION('',(#12043),#12047);
#12043 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12044,#12045,#12046),
#12044 = CARTESIAN_POINT('',(0.405778786624,-0.198474400101));
#12045 = CARTESIAN_POINT('',(0.405778786624,-0.406474400101));
#12046 = CARTESIAN_POINT('',(0.224778786624,-0.477474400101));
#12047 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12048 = ADVANCED_FACE('',(#12049),#12014,.T.);
#12049 = FACE_BOUND('',#12050,.T.);
#12050 = EDGE_LOOP('',(#12051,#12052,#12075,#12105));
#12051 = ORIENTED_EDGE('',*,*,#11998,.T.);
#12052 = ORIENTED_EDGE('',*,*,#12053,.T.);
#12053 = EDGE_CURVE('',#11976,#12054,#12056,.T.);
#12054 = VERTEX_POINT('',#12055);
#12055 = CARTESIAN_POINT('',(-1.408,-9.435,8.2));
#12056 = SURFACE_CURVE('',#12057,(#12061,#12068),.PCURVE_S1.);
#12057 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12058,#12059,#12060),
#12058 = CARTESIAN_POINT('',(-1.381,-9.284,8.2));
#12059 = CARTESIAN_POINT('',(-1.408,-9.352,8.2));
#12060 = CARTESIAN_POINT('',(-1.408,-9.435,8.2));
#12061 = PCURVE('',#12014,#12062);
#12062 = DEFINITIONAL_REPRESENTATION('',(#12063),#12067);
#12063 = LINE('',#12064,#12065);
#12064 = CARTESIAN_POINT('',(0.,-0.2));
#12065 = VECTOR('',#12066,1.);
#12066 = DIRECTION('',(1.,0.));
#12067 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12068 = PCURVE('',#11287,#12069);
#12069 = DEFINITIONAL_REPRESENTATION('',(#12070),#12074);
#12070 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12071,#12072,#12073),
#12071 = CARTESIAN_POINT('',(0.224778786624,-0.477474400101));
#12072 = CARTESIAN_POINT('',(0.156778786624,-0.504474400101));
#12073 = CARTESIAN_POINT('',(7.377878662384E-02,-0.504474400101));
#12074 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12075 = ORIENTED_EDGE('',*,*,#12076,.F.);
#12076 = EDGE_CURVE('',#12077,#12054,#12079,.T.);
#12077 = VERTEX_POINT('',#12078);
#12078 = CARTESIAN_POINT('',(-1.408,-9.435,8.));
#12079 = SURFACE_CURVE('',#12080,(#12084,#12091),.PCURVE_S1.);
#12080 = LINE('',#12081,#12082);
#12081 = CARTESIAN_POINT('',(-1.408,-9.435,8.));
#12082 = VECTOR('',#12083,1.);
#12083 = DIRECTION('',(0.,0.,1.));
#12084 = PCURVE('',#12014,#12085);
#12085 = DEFINITIONAL_REPRESENTATION('',(#12086),#12090);
#12086 = LINE('',#12087,#12088);
#12087 = CARTESIAN_POINT('',(1.,0.));
#12088 = VECTOR('',#12089,1.);
#12089 = DIRECTION('',(0.,-1.));
#12090 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12091 = PCURVE('',#12092,#12099);
#12092 = SURFACE_OF_LINEAR_EXTRUSION('',#12093,#12097);
#12093 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12094,#12095,#12096),
#12094 = CARTESIAN_POINT('',(-1.408,-9.435,8.));
#12095 = CARTESIAN_POINT('',(-1.408,-9.696,8.));
#12096 = CARTESIAN_POINT('',(-1.176,-9.813,8.));
#12097 = VECTOR('',#12098,1.);
#12098 = DIRECTION('',(-0.,-0.,-1.));
#12099 = DEFINITIONAL_REPRESENTATION('',(#12100),#12104);
#12100 = LINE('',#12101,#12102);
#12101 = CARTESIAN_POINT('',(0.,0.));
#12102 = VECTOR('',#12103,1.);
#12103 = DIRECTION('',(0.,-1.));
#12104 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12105 = ORIENTED_EDGE('',*,*,#12106,.F.);
#12106 = EDGE_CURVE('',#11999,#12077,#12107,.T.);
#12107 = SURFACE_CURVE('',#12108,(#12112,#12119),.PCURVE_S1.);
#12108 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12109,#12110,#12111),
#12109 = CARTESIAN_POINT('',(-1.381,-9.284,8.));
#12110 = CARTESIAN_POINT('',(-1.408,-9.352,8.));
#12111 = CARTESIAN_POINT('',(-1.408,-9.435,8.));
#12112 = PCURVE('',#12014,#12113);
#12113 = DEFINITIONAL_REPRESENTATION('',(#12114),#12118);
#12114 = LINE('',#12115,#12116);
#12115 = CARTESIAN_POINT('',(0.,0.));
#12116 = VECTOR('',#12117,1.);
#12117 = DIRECTION('',(1.,0.));
#12118 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12119 = PCURVE('',#11341,#12120);
#12120 = DEFINITIONAL_REPRESENTATION('',(#12121),#12125);
#12121 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12122,#12123,#12124),
#12122 = CARTESIAN_POINT('',(0.224778786624,-0.477474400101));
#12123 = CARTESIAN_POINT('',(0.156778786624,-0.504474400101));
#12124 = CARTESIAN_POINT('',(7.377878662384E-02,-0.504474400101));
#12125 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12126 = ADVANCED_FACE('',(#12127),#12092,.T.);
#12127 = FACE_BOUND('',#12128,.T.);
#12128 = EDGE_LOOP('',(#12129,#12130,#12153,#12183));
#12129 = ORIENTED_EDGE('',*,*,#12076,.T.);
#12130 = ORIENTED_EDGE('',*,*,#12131,.T.);
#12131 = EDGE_CURVE('',#12054,#12132,#12134,.T.);
#12132 = VERTEX_POINT('',#12133);
#12133 = CARTESIAN_POINT('',(-1.176,-9.813,8.2));
#12134 = SURFACE_CURVE('',#12135,(#12139,#12146),.PCURVE_S1.);
#12135 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12136,#12137,#12138),
#12136 = CARTESIAN_POINT('',(-1.408,-9.435,8.2));
#12137 = CARTESIAN_POINT('',(-1.408,-9.696,8.2));
#12138 = CARTESIAN_POINT('',(-1.176,-9.813,8.2));
#12139 = PCURVE('',#12092,#12140);
#12140 = DEFINITIONAL_REPRESENTATION('',(#12141),#12145);
#12141 = LINE('',#12142,#12143);
#12142 = CARTESIAN_POINT('',(0.,-0.2));
#12143 = VECTOR('',#12144,1.);
#12144 = DIRECTION('',(1.,0.));
#12145 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12146 = PCURVE('',#11287,#12147);
#12147 = DEFINITIONAL_REPRESENTATION('',(#12148),#12152);
#12148 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12149,#12150,#12151),
#12149 = CARTESIAN_POINT('',(7.377878662384E-02,-0.504474400101));
#12150 = CARTESIAN_POINT('',(-0.187221213376,-0.504474400101));
#12151 = CARTESIAN_POINT('',(-0.304221213376,-0.272474400101));
#12152 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12153 = ORIENTED_EDGE('',*,*,#12154,.F.);
#12154 = EDGE_CURVE('',#12155,#12132,#12157,.T.);
#12155 = VERTEX_POINT('',#12156);
#12156 = CARTESIAN_POINT('',(-1.176,-9.813,8.));
#12157 = SURFACE_CURVE('',#12158,(#12162,#12169),.PCURVE_S1.);
#12158 = LINE('',#12159,#12160);
#12159 = CARTESIAN_POINT('',(-1.176,-9.813,8.));
#12160 = VECTOR('',#12161,1.);
#12161 = DIRECTION('',(0.,0.,1.));
#12162 = PCURVE('',#12092,#12163);
#12163 = DEFINITIONAL_REPRESENTATION('',(#12164),#12168);
#12164 = LINE('',#12165,#12166);
#12165 = CARTESIAN_POINT('',(1.,0.));
#12166 = VECTOR('',#12167,1.);
#12167 = DIRECTION('',(0.,-1.));
#12168 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12169 = PCURVE('',#12170,#12177);
#12170 = SURFACE_OF_LINEAR_EXTRUSION('',#12171,#12175);
#12171 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12172,#12173,#12174),
#12172 = CARTESIAN_POINT('',(-1.176,-9.813,8.));
#12173 = CARTESIAN_POINT('',(-1.049,-9.874,8.));
#12174 = CARTESIAN_POINT('',(-0.882,-9.874,8.));
#12175 = VECTOR('',#12176,1.);
#12176 = DIRECTION('',(-0.,-0.,-1.));
#12177 = DEFINITIONAL_REPRESENTATION('',(#12178),#12182);
#12178 = LINE('',#12179,#12180);
#12179 = CARTESIAN_POINT('',(0.,0.));
#12180 = VECTOR('',#12181,1.);
#12181 = DIRECTION('',(0.,-1.));
#12182 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12183 = ORIENTED_EDGE('',*,*,#12184,.F.);
#12184 = EDGE_CURVE('',#12077,#12155,#12185,.T.);
#12185 = SURFACE_CURVE('',#12186,(#12190,#12197),.PCURVE_S1.);
#12186 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12187,#12188,#12189),
#12187 = CARTESIAN_POINT('',(-1.408,-9.435,8.));
#12188 = CARTESIAN_POINT('',(-1.408,-9.696,8.));
#12189 = CARTESIAN_POINT('',(-1.176,-9.813,8.));
#12190 = PCURVE('',#12092,#12191);
#12191 = DEFINITIONAL_REPRESENTATION('',(#12192),#12196);
#12192 = LINE('',#12193,#12194);
#12193 = CARTESIAN_POINT('',(0.,0.));
#12194 = VECTOR('',#12195,1.);
#12195 = DIRECTION('',(1.,0.));
#12196 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12197 = PCURVE('',#11341,#12198);
#12198 = DEFINITIONAL_REPRESENTATION('',(#12199),#12203);
#12199 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12200,#12201,#12202),
#12200 = CARTESIAN_POINT('',(7.377878662384E-02,-0.504474400101));
#12201 = CARTESIAN_POINT('',(-0.187221213376,-0.504474400101));
#12202 = CARTESIAN_POINT('',(-0.304221213376,-0.272474400101));
#12203 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12204 = ADVANCED_FACE('',(#12205),#12170,.T.);
#12205 = FACE_BOUND('',#12206,.T.);
#12206 = EDGE_LOOP('',(#12207,#12208,#12231,#12259));
#12207 = ORIENTED_EDGE('',*,*,#12154,.T.);
#12208 = ORIENTED_EDGE('',*,*,#12209,.T.);
#12209 = EDGE_CURVE('',#12132,#12210,#12212,.T.);
#12210 = VERTEX_POINT('',#12211);
#12211 = CARTESIAN_POINT('',(-0.882,-9.874,8.2));
#12212 = SURFACE_CURVE('',#12213,(#12217,#12224),.PCURVE_S1.);
#12213 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12214,#12215,#12216),
#12214 = CARTESIAN_POINT('',(-1.176,-9.813,8.2));
#12215 = CARTESIAN_POINT('',(-1.049,-9.874,8.2));
#12216 = CARTESIAN_POINT('',(-0.882,-9.874,8.2));
#12217 = PCURVE('',#12170,#12218);
#12218 = DEFINITIONAL_REPRESENTATION('',(#12219),#12223);
#12219 = LINE('',#12220,#12221);
#12220 = CARTESIAN_POINT('',(0.,-0.2));
#12221 = VECTOR('',#12222,1.);
#12222 = DIRECTION('',(1.,0.));
#12223 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12224 = PCURVE('',#11287,#12225);
#12225 = DEFINITIONAL_REPRESENTATION('',(#12226),#12230);
#12226 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12227,#12228,#12229),
#12227 = CARTESIAN_POINT('',(-0.304221213376,-0.272474400101));
#12228 = CARTESIAN_POINT('',(-0.365221213376,-0.145474400101));
#12229 = CARTESIAN_POINT('',(-0.365221213376,2.152559989929E-02));
#12230 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12231 = ORIENTED_EDGE('',*,*,#12232,.F.);
#12232 = EDGE_CURVE('',#12233,#12210,#12235,.T.);
#12233 = VERTEX_POINT('',#12234);
#12234 = CARTESIAN_POINT('',(-0.882,-9.874,8.));
#12235 = SURFACE_CURVE('',#12236,(#12240,#12247),.PCURVE_S1.);
#12236 = LINE('',#12237,#12238);
#12237 = CARTESIAN_POINT('',(-0.882,-9.874,8.));
#12238 = VECTOR('',#12239,1.);
#12239 = DIRECTION('',(0.,0.,1.));
#12240 = PCURVE('',#12170,#12241);
#12241 = DEFINITIONAL_REPRESENTATION('',(#12242),#12246);
#12242 = LINE('',#12243,#12244);
#12243 = CARTESIAN_POINT('',(1.,0.));
#12244 = VECTOR('',#12245,1.);
#12245 = DIRECTION('',(0.,-1.));
#12246 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12247 = PCURVE('',#12248,#12253);
#12248 = PLANE('',#12249);
#12249 = AXIS2_PLACEMENT_3D('',#12250,#12251,#12252);
#12250 = CARTESIAN_POINT('',(-0.882,-9.874,8.));
#12251 = DIRECTION('',(2.2E-16,1.,0.));
#12252 = DIRECTION('',(1.,-2.2E-16,0.));
#12253 = DEFINITIONAL_REPRESENTATION('',(#12254),#12258);
#12254 = LINE('',#12255,#12256);
#12255 = CARTESIAN_POINT('',(2.2E-16,0.));
#12256 = VECTOR('',#12257,1.);
#12257 = DIRECTION('',(0.,-1.));
#12258 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12259 = ORIENTED_EDGE('',*,*,#12260,.F.);
#12260 = EDGE_CURVE('',#12155,#12233,#12261,.T.);
#12261 = SURFACE_CURVE('',#12262,(#12266,#12273),.PCURVE_S1.);
#12262 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12263,#12264,#12265),
#12263 = CARTESIAN_POINT('',(-1.176,-9.813,8.));
#12264 = CARTESIAN_POINT('',(-1.049,-9.874,8.));
#12265 = CARTESIAN_POINT('',(-0.882,-9.874,8.));
#12266 = PCURVE('',#12170,#12267);
#12267 = DEFINITIONAL_REPRESENTATION('',(#12268),#12272);
#12268 = LINE('',#12269,#12270);
#12269 = CARTESIAN_POINT('',(0.,0.));
#12270 = VECTOR('',#12271,1.);
#12271 = DIRECTION('',(1.,0.));
#12272 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12273 = PCURVE('',#11341,#12274);
#12274 = DEFINITIONAL_REPRESENTATION('',(#12275),#12279);
#12275 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12276,#12277,#12278),
#12276 = CARTESIAN_POINT('',(-0.304221213376,-0.272474400101));
#12277 = CARTESIAN_POINT('',(-0.365221213376,-0.145474400101));
#12278 = CARTESIAN_POINT('',(-0.365221213376,2.152559989929E-02));
#12279 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12280 = ADVANCED_FACE('',(#12281),#12248,.T.);
#12281 = FACE_BOUND('',#12282,.T.);
#12282 = EDGE_LOOP('',(#12283,#12284,#12307,#12335));
#12283 = ORIENTED_EDGE('',*,*,#12232,.T.);
#12284 = ORIENTED_EDGE('',*,*,#12285,.T.);
#12285 = EDGE_CURVE('',#12210,#12286,#12288,.T.);
#12286 = VERTEX_POINT('',#12287);
#12287 = CARTESIAN_POINT('',(-2.E-15,-9.874,8.2));
#12288 = SURFACE_CURVE('',#12289,(#12293,#12300),.PCURVE_S1.);
#12289 = LINE('',#12290,#12291);
#12290 = CARTESIAN_POINT('',(-0.882,-9.874,8.2));
#12291 = VECTOR('',#12292,1.);
#12292 = DIRECTION('',(1.,0.,0.));
#12293 = PCURVE('',#12248,#12294);
#12294 = DEFINITIONAL_REPRESENTATION('',(#12295),#12299);
#12295 = LINE('',#12296,#12297);
#12296 = CARTESIAN_POINT('',(0.,-0.2));
#12297 = VECTOR('',#12298,1.);
#12298 = DIRECTION('',(1.,0.));
#12299 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12300 = PCURVE('',#11287,#12301);
#12301 = DEFINITIONAL_REPRESENTATION('',(#12302),#12306);
#12302 = LINE('',#12303,#12304);
#12303 = CARTESIAN_POINT('',(-0.365221213376,2.152559989929E-02));
#12304 = VECTOR('',#12305,1.);
#12305 = DIRECTION('',(0.,1.));
#12306 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12307 = ORIENTED_EDGE('',*,*,#12308,.F.);
#12308 = EDGE_CURVE('',#12309,#12286,#12311,.T.);
#12309 = VERTEX_POINT('',#12310);
#12310 = CARTESIAN_POINT('',(-2.E-15,-9.874,8.));
#12311 = SURFACE_CURVE('',#12312,(#12316,#12323),.PCURVE_S1.);
#12312 = LINE('',#12313,#12314);
#12313 = CARTESIAN_POINT('',(-2.E-15,-9.874,8.));
#12314 = VECTOR('',#12315,1.);
#12315 = DIRECTION('',(0.,0.,1.));
#12316 = PCURVE('',#12248,#12317);
#12317 = DEFINITIONAL_REPRESENTATION('',(#12318),#12322);
#12318 = LINE('',#12319,#12320);
#12319 = CARTESIAN_POINT('',(0.882,0.));
#12320 = VECTOR('',#12321,1.);
#12321 = DIRECTION('',(0.,-1.));
#12322 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12323 = PCURVE('',#12324,#12329);
#12324 = PLANE('',#12325);
#12325 = AXIS2_PLACEMENT_3D('',#12326,#12327,#12328);
#12326 = CARTESIAN_POINT('',(-2.E-15,-9.874,8.));
#12327 = DIRECTION('',(1.,-2.2E-16,0.));
#12328 = DIRECTION('',(-2.2E-16,-1.,0.));
#12329 = DEFINITIONAL_REPRESENTATION('',(#12330),#12334);
#12330 = LINE('',#12331,#12332);
#12331 = CARTESIAN_POINT('',(0.,0.));
#12332 = VECTOR('',#12333,1.);
#12333 = DIRECTION('',(0.,-1.));
#12334 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12335 = ORIENTED_EDGE('',*,*,#12336,.F.);
#12336 = EDGE_CURVE('',#12233,#12309,#12337,.T.);
#12337 = SURFACE_CURVE('',#12338,(#12342,#12349),.PCURVE_S1.);
#12338 = LINE('',#12339,#12340);
#12339 = CARTESIAN_POINT('',(-0.882,-9.874,8.));
#12340 = VECTOR('',#12341,1.);
#12341 = DIRECTION('',(1.,0.,0.));
#12342 = PCURVE('',#12248,#12343);
#12343 = DEFINITIONAL_REPRESENTATION('',(#12344),#12348);
#12344 = LINE('',#12345,#12346);
#12345 = CARTESIAN_POINT('',(0.,0.));
#12346 = VECTOR('',#12347,1.);
#12347 = DIRECTION('',(1.,0.));
#12348 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12349 = PCURVE('',#11341,#12350);
#12350 = DEFINITIONAL_REPRESENTATION('',(#12351),#12355);
#12351 = LINE('',#12352,#12353);
#12352 = CARTESIAN_POINT('',(-0.365221213376,2.152559989929E-02));
#12353 = VECTOR('',#12354,1.);
#12354 = DIRECTION('',(0.,1.));
#12355 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12356 = ADVANCED_FACE('',(#12357),#12324,.T.);
#12357 = FACE_BOUND('',#12358,.T.);
#12358 = EDGE_LOOP('',(#12359,#12360,#12383,#12406));
#12359 = ORIENTED_EDGE('',*,*,#12308,.T.);
#12360 = ORIENTED_EDGE('',*,*,#12361,.T.);
#12361 = EDGE_CURVE('',#12286,#12362,#12364,.T.);
#12362 = VERTEX_POINT('',#12363);
#12363 = CARTESIAN_POINT('',(-2.E-15,-10.129,8.2));
#12364 = SURFACE_CURVE('',#12365,(#12369,#12376),.PCURVE_S1.);
#12365 = LINE('',#12366,#12367);
#12366 = CARTESIAN_POINT('',(0.,-9.874,8.2));
#12367 = VECTOR('',#12368,1.);
#12368 = DIRECTION('',(0.,-1.,0.));
#12369 = PCURVE('',#12324,#12370);
#12370 = DEFINITIONAL_REPRESENTATION('',(#12371),#12375);
#12371 = LINE('',#12372,#12373);
#12372 = CARTESIAN_POINT('',(0.,-0.2));
#12373 = VECTOR('',#12374,1.);
#12374 = DIRECTION('',(1.,-0.));
#12375 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12376 = PCURVE('',#11287,#12377);
#12377 = DEFINITIONAL_REPRESENTATION('',(#12378),#12382);
#12378 = LINE('',#12379,#12380);
#12379 = CARTESIAN_POINT('',(-0.365221213376,0.903525599899));
#12380 = VECTOR('',#12381,1.);
#12381 = DIRECTION('',(-1.,0.));
#12382 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12383 = ORIENTED_EDGE('',*,*,#12384,.F.);
#12384 = EDGE_CURVE('',#12385,#12362,#12387,.T.);
#12385 = VERTEX_POINT('',#12386);
#12386 = CARTESIAN_POINT('',(-2.E-15,-10.129,8.));
#12387 = SURFACE_CURVE('',#12388,(#12392,#12399),.PCURVE_S1.);
#12388 = LINE('',#12389,#12390);
#12389 = CARTESIAN_POINT('',(-2.22E-15,-10.129,8.));
#12390 = VECTOR('',#12391,1.);
#12391 = DIRECTION('',(0.,0.,1.));
#12392 = PCURVE('',#12324,#12393);
#12393 = DEFINITIONAL_REPRESENTATION('',(#12394),#12398);
#12394 = LINE('',#12395,#12396);
#12395 = CARTESIAN_POINT('',(0.255,-0.));
#12396 = VECTOR('',#12397,1.);
#12397 = DIRECTION('',(0.,-1.));
#12398 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12399 = PCURVE('',#11259,#12400);
#12400 = DEFINITIONAL_REPRESENTATION('',(#12401),#12405);
#12401 = LINE('',#12402,#12403);
#12402 = CARTESIAN_POINT('',(-0.,0.));
#12403 = VECTOR('',#12404,1.);
#12404 = DIRECTION('',(0.,-1.));
#12405 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12406 = ORIENTED_EDGE('',*,*,#12407,.F.);
#12407 = EDGE_CURVE('',#12309,#12385,#12408,.T.);
#12408 = SURFACE_CURVE('',#12409,(#12413,#12420),.PCURVE_S1.);
#12409 = LINE('',#12410,#12411);
#12410 = CARTESIAN_POINT('',(0.,-9.874,8.));
#12411 = VECTOR('',#12412,1.);
#12412 = DIRECTION('',(0.,-1.,0.));
#12413 = PCURVE('',#12324,#12414);
#12414 = DEFINITIONAL_REPRESENTATION('',(#12415),#12419);
#12415 = LINE('',#12416,#12417);
#12416 = CARTESIAN_POINT('',(0.,0.));
#12417 = VECTOR('',#12418,1.);
#12418 = DIRECTION('',(1.,-0.));
#12419 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12420 = PCURVE('',#11341,#12421);
#12421 = DEFINITIONAL_REPRESENTATION('',(#12422),#12426);
#12422 = LINE('',#12423,#12424);
#12423 = CARTESIAN_POINT('',(-0.365221213376,0.903525599899));
#12424 = VECTOR('',#12425,1.);
#12425 = DIRECTION('',(-1.,0.));
#12426 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12427 = ADVANCED_FACE('',(#12428),#11259,.T.);
#12428 = FACE_BOUND('',#12429,.T.);
#12429 = EDGE_LOOP('',(#12430,#12431,#12452,#12453));
#12430 = ORIENTED_EDGE('',*,*,#12384,.T.);
#12431 = ORIENTED_EDGE('',*,*,#12432,.T.);
#12432 = EDGE_CURVE('',#12362,#11239,#12433,.T.);
#12433 = SURFACE_CURVE('',#12434,(#12438,#12445),.PCURVE_S1.);
#12434 = LINE('',#12435,#12436);
#12435 = CARTESIAN_POINT('',(0.,-10.129,8.2));
#12436 = VECTOR('',#12437,1.);
#12437 = DIRECTION('',(-1.,0.,0.));
#12438 = PCURVE('',#11259,#12439);
#12439 = DEFINITIONAL_REPRESENTATION('',(#12440),#12444);
#12440 = LINE('',#12441,#12442);
#12441 = CARTESIAN_POINT('',(0.,-0.2));
#12442 = VECTOR('',#12443,1.);
#12443 = DIRECTION('',(1.,0.));
#12444 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12445 = PCURVE('',#11287,#12446);
#12446 = DEFINITIONAL_REPRESENTATION('',(#12447),#12451);
#12447 = LINE('',#12448,#12449);
#12448 = CARTESIAN_POINT('',(-0.620221213376,0.903525599899));
#12449 = VECTOR('',#12450,1.);
#12450 = DIRECTION('',(0.,-1.));
#12451 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12452 = ORIENTED_EDGE('',*,*,#11236,.F.);
#12453 = ORIENTED_EDGE('',*,*,#12454,.F.);
#12454 = EDGE_CURVE('',#12385,#11237,#12455,.T.);
#12455 = SURFACE_CURVE('',#12456,(#12460,#12467),.PCURVE_S1.);
#12456 = LINE('',#12457,#12458);
#12457 = CARTESIAN_POINT('',(0.,-10.129,8.));
#12458 = VECTOR('',#12459,1.);
#12459 = DIRECTION('',(-1.,0.,0.));
#12460 = PCURVE('',#11259,#12461);
#12461 = DEFINITIONAL_REPRESENTATION('',(#12462),#12466);
#12462 = LINE('',#12463,#12464);
#12463 = CARTESIAN_POINT('',(0.,0.));
#12464 = VECTOR('',#12465,1.);
#12465 = DIRECTION('',(1.,0.));
#12466 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12467 = PCURVE('',#11341,#12468);
#12468 = DEFINITIONAL_REPRESENTATION('',(#12469),#12473);
#12469 = LINE('',#12470,#12471);
#12470 = CARTESIAN_POINT('',(-0.620221213376,0.903525599899));
#12471 = VECTOR('',#12472,1.);
#12472 = DIRECTION('',(0.,-1.));
#12473 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12474 = ADVANCED_FACE('',(#12475),#11341,.T.);
#12475 = FACE_BOUND('',#12476,.T.);
#12476 = EDGE_LOOP('',(#12477,#12478,#12479,#12480,#12481,#12482,#12483,
#12484,#12485,#12486,#12487,#12488,#12489,#12490,#12491,#12492));
#12477 = ORIENTED_EDGE('',*,*,#11327,.T.);
#12478 = ORIENTED_EDGE('',*,*,#11410,.T.);
#12479 = ORIENTED_EDGE('',*,*,#11488,.T.);
#12480 = ORIENTED_EDGE('',*,*,#11566,.T.);
#12481 = ORIENTED_EDGE('',*,*,#11644,.T.);
#12482 = ORIENTED_EDGE('',*,*,#11720,.T.);
#12483 = ORIENTED_EDGE('',*,*,#11796,.T.);
#12484 = ORIENTED_EDGE('',*,*,#11872,.T.);
#12485 = ORIENTED_EDGE('',*,*,#11950,.T.);
#12486 = ORIENTED_EDGE('',*,*,#12028,.T.);
#12487 = ORIENTED_EDGE('',*,*,#12106,.T.);
#12488 = ORIENTED_EDGE('',*,*,#12184,.T.);
#12489 = ORIENTED_EDGE('',*,*,#12260,.T.);
#12490 = ORIENTED_EDGE('',*,*,#12336,.T.);
#12491 = ORIENTED_EDGE('',*,*,#12407,.T.);
#12492 = ORIENTED_EDGE('',*,*,#12454,.T.);
#12493 = ADVANCED_FACE('',(#12494),#11287,.F.);
#12494 = FACE_BOUND('',#12495,.F.);
#12495 = EDGE_LOOP('',(#12496,#12497,#12498,#12499,#12500,#12501,#12502,
#12503,#12504,#12505,#12506,#12507,#12508,#12509,#12510,#12511));
#12496 = ORIENTED_EDGE('',*,*,#11271,.T.);
#12497 = ORIENTED_EDGE('',*,*,#11357,.T.);
#12498 = ORIENTED_EDGE('',*,*,#11435,.T.);
#12499 = ORIENTED_EDGE('',*,*,#11513,.T.);
#12500 = ORIENTED_EDGE('',*,*,#11591,.T.);
#12501 = ORIENTED_EDGE('',*,*,#11669,.T.);
#12502 = ORIENTED_EDGE('',*,*,#11745,.T.);
#12503 = ORIENTED_EDGE('',*,*,#11821,.T.);
#12504 = ORIENTED_EDGE('',*,*,#11897,.T.);
#12505 = ORIENTED_EDGE('',*,*,#11975,.T.);
#12506 = ORIENTED_EDGE('',*,*,#12053,.T.);
#12507 = ORIENTED_EDGE('',*,*,#12131,.T.);
#12508 = ORIENTED_EDGE('',*,*,#12209,.T.);
#12509 = ORIENTED_EDGE('',*,*,#12285,.T.);
#12510 = ORIENTED_EDGE('',*,*,#12361,.T.);
#12511 = ORIENTED_EDGE('',*,*,#12432,.T.);
#12512 = MANIFOLD_SOLID_BREP('',#12513);
#12513 = CLOSED_SHELL('',(#12514,#12638,#12716,#12794,#12872,#12950,
#13028,#13106,#13182,#13260,#13338,#13416,#13494,#13572,#13650,
#13728,#13799,#13846,#13866));
#12514 = ADVANCED_FACE('',(#12515),#12529,.T.);
#12515 = FACE_BOUND('',#12516,.T.);
#12516 = EDGE_LOOP('',(#12517,#12554,#12582,#12612));
#12517 = ORIENTED_EDGE('',*,*,#12518,.T.);
#12518 = EDGE_CURVE('',#12519,#12521,#12523,.T.);
#12519 = VERTEX_POINT('',#12520);
#12520 = CARTESIAN_POINT('',(-0.512,-11.772,8.));
#12521 = VERTEX_POINT('',#12522);
#12522 = CARTESIAN_POINT('',(-0.512,-11.772,8.2));
#12523 = SURFACE_CURVE('',#12524,(#12528,#12540),.PCURVE_S1.);
#12524 = LINE('',#12525,#12526);
#12525 = CARTESIAN_POINT('',(-0.512,-11.772,8.));
#12526 = VECTOR('',#12527,1.);
#12527 = DIRECTION('',(0.,0.,1.));
#12528 = PCURVE('',#12529,#12534);
#12529 = PLANE('',#12530);
#12530 = AXIS2_PLACEMENT_3D('',#12531,#12532,#12533);
#12531 = CARTESIAN_POINT('',(-0.512,-11.772,8.));
#12532 = DIRECTION('',(-1.,2.2E-16,0.));
#12533 = DIRECTION('',(2.2E-16,1.,0.));
#12534 = DEFINITIONAL_REPRESENTATION('',(#12535),#12539);
#12535 = LINE('',#12536,#12537);
#12536 = CARTESIAN_POINT('',(0.,0.));
#12537 = VECTOR('',#12538,1.);
#12538 = DIRECTION('',(0.,-1.));
#12539 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12540 = PCURVE('',#12541,#12548);
#12541 = SURFACE_OF_LINEAR_EXTRUSION('',#12542,#12546);
#12542 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12543,#12544,#12545),
#12543 = CARTESIAN_POINT('',(-0.271,-11.714,8.));
#12544 = CARTESIAN_POINT('',(-0.379,-11.76,8.));
#12545 = CARTESIAN_POINT('',(-0.512,-11.772,8.));
#12546 = VECTOR('',#12547,1.);
#12547 = DIRECTION('',(-0.,-0.,-1.));
#12548 = DEFINITIONAL_REPRESENTATION('',(#12549),#12553);
#12549 = LINE('',#12550,#12551);
#12550 = CARTESIAN_POINT('',(1.,0.));
#12551 = VECTOR('',#12552,1.);
#12552 = DIRECTION('',(0.,-1.));
#12553 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12554 = ORIENTED_EDGE('',*,*,#12555,.T.);
#12555 = EDGE_CURVE('',#12521,#12556,#12558,.T.);
#12556 = VERTEX_POINT('',#12557);
#12557 = CARTESIAN_POINT('',(-0.512,-11.514,8.2));
#12558 = SURFACE_CURVE('',#12559,(#12563,#12570),.PCURVE_S1.);
#12559 = LINE('',#12560,#12561);
#12560 = CARTESIAN_POINT('',(-0.512,-11.772,8.2));
#12561 = VECTOR('',#12562,1.);
#12562 = DIRECTION('',(0.,1.,0.));
#12563 = PCURVE('',#12529,#12564);
#12564 = DEFINITIONAL_REPRESENTATION('',(#12565),#12569);
#12565 = LINE('',#12566,#12567);
#12566 = CARTESIAN_POINT('',(0.,-0.2));
#12567 = VECTOR('',#12568,1.);
#12568 = DIRECTION('',(1.,0.));
#12569 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12570 = PCURVE('',#12571,#12576);
#12571 = PLANE('',#12572);
#12572 = AXIS2_PLACEMENT_3D('',#12573,#12574,#12575);
#12573 = CARTESIAN_POINT('',(-0.802336392677,-11.08346388701,8.2));
#12574 = DIRECTION('',(-0.,0.,-1.));
#12575 = DIRECTION('',(0.,1.,0.));
#12576 = DEFINITIONAL_REPRESENTATION('',(#12577),#12581);
#12577 = LINE('',#12578,#12579);
#12578 = CARTESIAN_POINT('',(-0.688536112984,0.290336392677));
#12579 = VECTOR('',#12580,1.);
#12580 = DIRECTION('',(1.,0.));
#12581 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12582 = ORIENTED_EDGE('',*,*,#12583,.F.);
#12583 = EDGE_CURVE('',#12584,#12556,#12586,.T.);
#12584 = VERTEX_POINT('',#12585);
#12585 = CARTESIAN_POINT('',(-0.512,-11.514,8.));
#12586 = SURFACE_CURVE('',#12587,(#12591,#12598),.PCURVE_S1.);
#12587 = LINE('',#12588,#12589);
#12588 = CARTESIAN_POINT('',(-0.512,-11.514,8.));
#12589 = VECTOR('',#12590,1.);
#12590 = DIRECTION('',(0.,0.,1.));
#12591 = PCURVE('',#12529,#12592);
#12592 = DEFINITIONAL_REPRESENTATION('',(#12593),#12597);
#12593 = LINE('',#12594,#12595);
#12594 = CARTESIAN_POINT('',(0.258,0.));
#12595 = VECTOR('',#12596,1.);
#12596 = DIRECTION('',(0.,-1.));
#12597 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12598 = PCURVE('',#12599,#12606);
#12599 = SURFACE_OF_LINEAR_EXTRUSION('',#12600,#12604);
#12600 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12601,#12602,#12603),
#12601 = CARTESIAN_POINT('',(-0.512,-11.514,8.));
#12602 = CARTESIAN_POINT('',(-0.24,-11.474,8.));
#12603 = CARTESIAN_POINT('',(-0.198,-11.216,8.));
#12604 = VECTOR('',#12605,1.);
#12605 = DIRECTION('',(-0.,-0.,-1.));
#12606 = DEFINITIONAL_REPRESENTATION('',(#12607),#12611);
#12607 = LINE('',#12608,#12609);
#12608 = CARTESIAN_POINT('',(0.,0.));
#12609 = VECTOR('',#12610,1.);
#12610 = DIRECTION('',(0.,-1.));
#12611 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
PARAMETRIC_REPRESENTATION_CONTEXT() REPRESENTATION_CONTEXT('2D SPACE',''
#12612 = ORIENTED_EDGE('',*,*,#12613,.F.);
#12613 = EDGE_CURVE('',#12519,#12584,#12614,.T.);
#12614 = SURFACE_CURVE('',#12615,(#12619,#12626),.PCURVE_S1.);
#12615 = LINE('',#12616,#12617);
#12616 = CARTESIAN_POINT('',(-0.512,-11.772,8.));
#12617 = VECTOR('',#12618,1.);
#12618 = DIRECTION('',(0.,1.,0.));
#12619 = PCURVE('',#12529,#12620);
#12620 = DEFINITIONAL_REPRESENTATION('',(#12621),#12625);
#12621 = LINE('',#12622,#12623);
#12622 = CARTESIAN_POINT('',(0.,0.));
#12623 = VECTOR('',#12624,1.);
#12624 = DIRECTION('',(1.,0.));
#12625 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12626 = PCURVE('',#12627,#12632);
#12627 = PLANE('',#12628);
#12628 = AXIS2_PLACEMENT_3D('',#12629,#12630,#12631);
#12629 = CARTESIAN_POINT('',(-0.802336392677,-11.08346388701,8.));
#12630 = DIRECTION('',(-0.,0.,-1.));
#12631 = DIRECTION('',(0.,1.,0.));
#12632 = DEFINITIONAL_REPRESENTATION('',(#12633),#12637);
#12633 = LINE('',#12634,#12635);
#12634 = CARTESIAN_POINT('',(-0.688536112984,0.290336392677));
#12635 = VECTOR('',#12636,1.);
#12636 = DIRECTION('',(1.,0.));
#12637 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12638 = ADVANCED_FACE('',(#12639),#12599,.T.);
#12639 = FACE_BOUND('',#12640,.T.);
#12640 = EDGE_LOOP('',(#12641,#12642,#12665,#12695));
#12641 = ORIENTED_EDGE('',*,*,#12583,.T.);
#12642 = ORIENTED_EDGE('',*,*,#12643,.T.);
#12643 = EDGE_CURVE('',#12556,#12644,#12646,.T.);
#12644 = VERTEX_POINT('',#12645);
#12645 = CARTESIAN_POINT('',(-0.198,-11.216,8.2));
#12646 = SURFACE_CURVE('',#12647,(#12651,#12658),.PCURVE_S1.);
#12647 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12648,#12649,#12650),
#12648 = CARTESIAN_POINT('',(-0.512,-11.514,8.2));
#12649 = CARTESIAN_POINT('',(-0.24,-11.474,8.2));
#12650 = CARTESIAN_POINT('',(-0.198,-11.216,8.2));
#12651 = PCURVE('',#12599,#12652);
#12652 = DEFINITIONAL_REPRESENTATION('',(#12653),#12657);
#12653 = LINE('',#12654,#12655);
#12654 = CARTESIAN_POINT('',(0.,-0.2));
#12655 = VECTOR('',#12656,1.);
#12656 = DIRECTION('',(1.,0.));
#12657 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12658 = PCURVE('',#12571,#12659);
#12659 = DEFINITIONAL_REPRESENTATION('',(#12660),#12664);
#12660 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12661,#12662,#12663),
#12661 = CARTESIAN_POINT('',(-0.430536112984,0.290336392677));
#12662 = CARTESIAN_POINT('',(-0.390536112984,0.562336392677));
#12663 = CARTESIAN_POINT('',(-0.132536112984,0.604336392677));
#12664 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12665 = ORIENTED_EDGE('',*,*,#12666,.F.);
#12666 = EDGE_CURVE('',#12667,#12644,#12669,.T.);
#12667 = VERTEX_POINT('',#12668);
#12668 = CARTESIAN_POINT('',(-0.198,-11.216,8.));
#12669 = SURFACE_CURVE('',#12670,(#12674,#12681),.PCURVE_S1.);
#12670 = LINE('',#12671,#12672);
#12671 = CARTESIAN_POINT('',(-0.198,-11.216,8.));
#12672 = VECTOR('',#12673,1.);
#12673 = DIRECTION('',(0.,0.,1.));
#12674 = PCURVE('',#12599,#12675);
#12675 = DEFINITIONAL_REPRESENTATION('',(#12676),#12680);
#12676 = LINE('',#12677,#12678);
#12677 = CARTESIAN_POINT('',(1.,0.));
#12678 = VECTOR('',#12679,1.);
#12679 = DIRECTION('',(0.,-1.));
#12680 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12681 = PCURVE('',#12682,#12689);
#12682 = SURFACE_OF_LINEAR_EXTRUSION('',#12683,#12687);
#12683 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12684,#12685,#12686),
#12684 = CARTESIAN_POINT('',(-0.198,-11.216,8.));
#12685 = CARTESIAN_POINT('',(-0.192,-11.176,8.));
#12686 = CARTESIAN_POINT('',(-0.192,-11.133,8.));
#12687 = VECTOR('',#12688,1.);
#12688 = DIRECTION('',(-0.,-0.,-1.));
#12689 = DEFINITIONAL_REPRESENTATION('',(#12690),#12694);
#12690 = LINE('',#12691,#12692);
#12691 = CARTESIAN_POINT('',(0.,0.));
#12692 = VECTOR('',#12693,1.);
#12693 = DIRECTION('',(0.,-1.));
#12694 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12695 = ORIENTED_EDGE('',*,*,#12696,.F.);
#12696 = EDGE_CURVE('',#12584,#12667,#12697,.T.);
#12697 = SURFACE_CURVE('',#12698,(#12702,#12709),.PCURVE_S1.);
#12698 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12699,#12700,#12701),
#12699 = CARTESIAN_POINT('',(-0.512,-11.514,8.));
#12700 = CARTESIAN_POINT('',(-0.24,-11.474,8.));
#12701 = CARTESIAN_POINT('',(-0.198,-11.216,8.));
#12702 = PCURVE('',#12599,#12703);
#12703 = DEFINITIONAL_REPRESENTATION('',(#12704),#12708);
#12704 = LINE('',#12705,#12706);
#12705 = CARTESIAN_POINT('',(0.,0.));
#12706 = VECTOR('',#12707,1.);
#12707 = DIRECTION('',(1.,0.));
#12708 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12709 = PCURVE('',#12627,#12710);
#12710 = DEFINITIONAL_REPRESENTATION('',(#12711),#12715);
#12711 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12712,#12713,#12714),
#12712 = CARTESIAN_POINT('',(-0.430536112984,0.290336392677));
#12713 = CARTESIAN_POINT('',(-0.390536112984,0.562336392677));
#12714 = CARTESIAN_POINT('',(-0.132536112984,0.604336392677));
#12715 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12716 = ADVANCED_FACE('',(#12717),#12682,.T.);
#12717 = FACE_BOUND('',#12718,.T.);
#12718 = EDGE_LOOP('',(#12719,#12720,#12743,#12773));
#12719 = ORIENTED_EDGE('',*,*,#12666,.T.);
#12720 = ORIENTED_EDGE('',*,*,#12721,.T.);
#12721 = EDGE_CURVE('',#12644,#12722,#12724,.T.);
#12722 = VERTEX_POINT('',#12723);
#12723 = CARTESIAN_POINT('',(-0.192,-11.133,8.2));
#12724 = SURFACE_CURVE('',#12725,(#12729,#12736),.PCURVE_S1.);
#12725 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12726,#12727,#12728),
#12726 = CARTESIAN_POINT('',(-0.198,-11.216,8.2));
#12727 = CARTESIAN_POINT('',(-0.192,-11.176,8.2));
#12728 = CARTESIAN_POINT('',(-0.192,-11.133,8.2));
#12729 = PCURVE('',#12682,#12730);
#12730 = DEFINITIONAL_REPRESENTATION('',(#12731),#12735);
#12731 = LINE('',#12732,#12733);
#12732 = CARTESIAN_POINT('',(0.,-0.2));
#12733 = VECTOR('',#12734,1.);
#12734 = DIRECTION('',(1.,0.));
#12735 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12736 = PCURVE('',#12571,#12737);
#12737 = DEFINITIONAL_REPRESENTATION('',(#12738),#12742);
#12738 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12739,#12740,#12741),
#12739 = CARTESIAN_POINT('',(-0.132536112984,0.604336392677));
#12740 = CARTESIAN_POINT('',(-9.253611298445E-02,0.610336392677));
#12741 = CARTESIAN_POINT('',(-4.953611298445E-02,0.610336392677));
#12742 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12743 = ORIENTED_EDGE('',*,*,#12744,.F.);
#12744 = EDGE_CURVE('',#12745,#12722,#12747,.T.);
#12745 = VERTEX_POINT('',#12746);
#12746 = CARTESIAN_POINT('',(-0.192,-11.133,8.));
#12747 = SURFACE_CURVE('',#12748,(#12752,#12759),.PCURVE_S1.);
#12748 = LINE('',#12749,#12750);
#12749 = CARTESIAN_POINT('',(-0.192,-11.133,8.));
#12750 = VECTOR('',#12751,1.);
#12751 = DIRECTION('',(0.,0.,1.));
#12752 = PCURVE('',#12682,#12753);
#12753 = DEFINITIONAL_REPRESENTATION('',(#12754),#12758);
#12754 = LINE('',#12755,#12756);
#12755 = CARTESIAN_POINT('',(1.,0.));
#12756 = VECTOR('',#12757,1.);
#12757 = DIRECTION('',(0.,-1.));
#12758 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12759 = PCURVE('',#12760,#12767);
#12760 = SURFACE_OF_LINEAR_EXTRUSION('',#12761,#12765);
#12761 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12762,#12763,#12764),
.UNSPECIFIED.,.F.,.F.,(3,3),(0.,1.),.PIECEWISE_BEZIER_KNOTS.);
#12762 = CARTESIAN_POINT('',(-0.192,-11.133,8.));
#12763 = CARTESIAN_POINT('',(-0.192,-10.844,8.));
#12764 = CARTESIAN_POINT('',(-0.49,-10.736,8.));
#12765 = VECTOR('',#12766,1.);
#12766 = DIRECTION('',(-0.,-0.,-1.));
#12767 = DEFINITIONAL_REPRESENTATION('',(#12768),#12772);
#12768 = LINE('',#12769,#12770);
#12769 = CARTESIAN_POINT('',(0.,0.));
#12770 = VECTOR('',#12771,1.);
#12771 = DIRECTION('',(0.,-1.));
#12772 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12773 = ORIENTED_EDGE('',*,*,#12774,.F.);
#12774 = EDGE_CURVE('',#12667,#12745,#12775,.T.);
#12775 = SURFACE_CURVE('',#12776,(#12780,#12787),.PCURVE_S1.);
#12776 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12777,#12778,#12779),
#12777 = CARTESIAN_POINT('',(-0.198,-11.216,8.));
#12778 = CARTESIAN_POINT('',(-0.192,-11.176,8.));
#12779 = CARTESIAN_POINT('',(-0.192,-11.133,8.));
#12780 = PCURVE('',#12682,#12781);
#12781 = DEFINITIONAL_REPRESENTATION('',(#12782),#12786);
#12782 = LINE('',#12783,#12784);
#12783 = CARTESIAN_POINT('',(0.,0.));
#12784 = VECTOR('',#12785,1.);
#12785 = DIRECTION('',(1.,0.));
#12786 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12787 = PCURVE('',#12627,#12788);
#12788 = DEFINITIONAL_REPRESENTATION('',(#12789),#12793);
#12789 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12790,#12791,#12792),
#12790 = CARTESIAN_POINT('',(-0.132536112984,0.604336392677));
#12791 = CARTESIAN_POINT('',(-9.253611298445E-02,0.610336392677));
#12792 = CARTESIAN_POINT('',(-4.953611298445E-02,0.610336392677));
#12793 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12794 = ADVANCED_FACE('',(#12795),#12760,.T.);
#12795 = FACE_BOUND('',#12796,.T.);
#12796 = EDGE_LOOP('',(#12797,#12798,#12821,#12851));
#12797 = ORIENTED_EDGE('',*,*,#12744,.T.);
#12798 = ORIENTED_EDGE('',*,*,#12799,.T.);
#12799 = EDGE_CURVE('',#12722,#12800,#12802,.T.);
#12800 = VERTEX_POINT('',#12801);
#12801 = CARTESIAN_POINT('',(-0.49,-10.736,8.2));
#12802 = SURFACE_CURVE('',#12803,(#12807,#12814),.PCURVE_S1.);
#12803 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12804,#12805,#12806),
#12804 = CARTESIAN_POINT('',(-0.192,-11.133,8.2));
#12805 = CARTESIAN_POINT('',(-0.192,-10.844,8.2));
#12806 = CARTESIAN_POINT('',(-0.49,-10.736,8.2));
#12807 = PCURVE('',#12760,#12808);
#12808 = DEFINITIONAL_REPRESENTATION('',(#12809),#12813);
#12809 = LINE('',#12810,#12811);
#12810 = CARTESIAN_POINT('',(0.,-0.2));
#12811 = VECTOR('',#12812,1.);
#12812 = DIRECTION('',(1.,0.));
#12813 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12814 = PCURVE('',#12571,#12815);
#12815 = DEFINITIONAL_REPRESENTATION('',(#12816),#12820);
#12816 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12817,#12818,#12819),
#12817 = CARTESIAN_POINT('',(-4.953611298445E-02,0.610336392677));
#12818 = CARTESIAN_POINT('',(0.239463887016,0.610336392677));
#12819 = CARTESIAN_POINT('',(0.347463887016,0.312336392677));
#12820 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12821 = ORIENTED_EDGE('',*,*,#12822,.F.);
#12822 = EDGE_CURVE('',#12823,#12800,#12825,.T.);
#12823 = VERTEX_POINT('',#12824);
#12824 = CARTESIAN_POINT('',(-0.49,-10.736,8.));
#12825 = SURFACE_CURVE('',#12826,(#12830,#12837),.PCURVE_S1.);
#12826 = LINE('',#12827,#12828);
#12827 = CARTESIAN_POINT('',(-0.49,-10.736,8.));
#12828 = VECTOR('',#12829,1.);
#12829 = DIRECTION('',(0.,0.,1.));
#12830 = PCURVE('',#12760,#12831);
#12831 = DEFINITIONAL_REPRESENTATION('',(#12832),#12836);
#12832 = LINE('',#12833,#12834);
#12833 = CARTESIAN_POINT('',(1.,0.));
#12834 = VECTOR('',#12835,1.);
#12835 = DIRECTION('',(0.,-1.));
#12836 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12837 = PCURVE('',#12838,#12845);
#12838 = SURFACE_OF_LINEAR_EXTRUSION('',#12839,#12843);
#12839 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12840,#12841,#12842),
#12840 = CARTESIAN_POINT('',(-0.49,-10.736,8.));
#12841 = CARTESIAN_POINT('',(-0.63,-10.687,8.));
#12842 = CARTESIAN_POINT('',(-0.815,-10.687,8.));
#12843 = VECTOR('',#12844,1.);
#12844 = DIRECTION('',(-0.,-0.,-1.));
#12845 = DEFINITIONAL_REPRESENTATION('',(#12846),#12850);
#12846 = LINE('',#12847,#12848);
#12847 = CARTESIAN_POINT('',(0.,0.));
#12848 = VECTOR('',#12849,1.);
#12849 = DIRECTION('',(0.,-1.));
#12850 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12851 = ORIENTED_EDGE('',*,*,#12852,.F.);
#12852 = EDGE_CURVE('',#12745,#12823,#12853,.T.);
#12853 = SURFACE_CURVE('',#12854,(#12858,#12865),.PCURVE_S1.);
#12854 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12855,#12856,#12857),
#12855 = CARTESIAN_POINT('',(-0.192,-11.133,8.));
#12856 = CARTESIAN_POINT('',(-0.192,-10.844,8.));
#12857 = CARTESIAN_POINT('',(-0.49,-10.736,8.));
#12858 = PCURVE('',#12760,#12859);
#12859 = DEFINITIONAL_REPRESENTATION('',(#12860),#12864);
#12860 = LINE('',#12861,#12862);
#12861 = CARTESIAN_POINT('',(0.,0.));
#12862 = VECTOR('',#12863,1.);
#12863 = DIRECTION('',(1.,0.));
#12864 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12865 = PCURVE('',#12627,#12866);
#12866 = DEFINITIONAL_REPRESENTATION('',(#12867),#12871);
#12867 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12868,#12869,#12870),
#12868 = CARTESIAN_POINT('',(-4.953611298445E-02,0.610336392677));
#12869 = CARTESIAN_POINT('',(0.239463887016,0.610336392677));
#12870 = CARTESIAN_POINT('',(0.347463887016,0.312336392677));
#12871 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12872 = ADVANCED_FACE('',(#12873),#12838,.T.);
#12873 = FACE_BOUND('',#12874,.T.);
#12874 = EDGE_LOOP('',(#12875,#12876,#12899,#12929));
#12875 = ORIENTED_EDGE('',*,*,#12822,.T.);
#12876 = ORIENTED_EDGE('',*,*,#12877,.T.);
#12877 = EDGE_CURVE('',#12800,#12878,#12880,.T.);
#12878 = VERTEX_POINT('',#12879);
#12879 = CARTESIAN_POINT('',(-0.815,-10.687,8.2));
#12880 = SURFACE_CURVE('',#12881,(#12885,#12892),.PCURVE_S1.);
#12881 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12882,#12883,#12884),
#12882 = CARTESIAN_POINT('',(-0.49,-10.736,8.2));
#12883 = CARTESIAN_POINT('',(-0.63,-10.687,8.2));
#12884 = CARTESIAN_POINT('',(-0.815,-10.687,8.2));
#12885 = PCURVE('',#12838,#12886);
#12886 = DEFINITIONAL_REPRESENTATION('',(#12887),#12891);
#12887 = LINE('',#12888,#12889);
#12888 = CARTESIAN_POINT('',(0.,-0.2));
#12889 = VECTOR('',#12890,1.);
#12890 = DIRECTION('',(1.,0.));
#12891 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12892 = PCURVE('',#12571,#12893);
#12893 = DEFINITIONAL_REPRESENTATION('',(#12894),#12898);
#12894 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12895,#12896,#12897),
#12895 = CARTESIAN_POINT('',(0.347463887016,0.312336392677));
#12896 = CARTESIAN_POINT('',(0.396463887016,0.172336392677));
#12897 = CARTESIAN_POINT('',(0.396463887016,-1.266360732324E-02));
#12898 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12899 = ORIENTED_EDGE('',*,*,#12900,.F.);
#12900 = EDGE_CURVE('',#12901,#12878,#12903,.T.);
#12901 = VERTEX_POINT('',#12902);
#12902 = CARTESIAN_POINT('',(-0.815,-10.687,8.));
#12903 = SURFACE_CURVE('',#12904,(#12908,#12915),.PCURVE_S1.);
#12904 = LINE('',#12905,#12906);
#12905 = CARTESIAN_POINT('',(-0.815,-10.687,8.));
#12906 = VECTOR('',#12907,1.);
#12907 = DIRECTION('',(0.,0.,1.));
#12908 = PCURVE('',#12838,#12909);
#12909 = DEFINITIONAL_REPRESENTATION('',(#12910),#12914);
#12910 = LINE('',#12911,#12912);
#12911 = CARTESIAN_POINT('',(1.,0.));
#12912 = VECTOR('',#12913,1.);
#12913 = DIRECTION('',(0.,-1.));
#12914 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12915 = PCURVE('',#12916,#12923);
#12916 = SURFACE_OF_LINEAR_EXTRUSION('',#12917,#12921);
#12917 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12918,#12919,#12920),
#12918 = CARTESIAN_POINT('',(-0.815,-10.687,8.));
#12919 = CARTESIAN_POINT('',(-1.223,-10.687,8.));
#12920 = CARTESIAN_POINT('',(-1.357,-10.93,8.));
#12921 = VECTOR('',#12922,1.);
#12922 = DIRECTION('',(-0.,-0.,-1.));
#12923 = DEFINITIONAL_REPRESENTATION('',(#12924),#12928);
#12924 = LINE('',#12925,#12926);
#12925 = CARTESIAN_POINT('',(0.,0.));
#12926 = VECTOR('',#12927,1.);
#12927 = DIRECTION('',(0.,-1.));
#12928 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12929 = ORIENTED_EDGE('',*,*,#12930,.F.);
#12930 = EDGE_CURVE('',#12823,#12901,#12931,.T.);
#12931 = SURFACE_CURVE('',#12932,(#12936,#12943),.PCURVE_S1.);
#12932 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12933,#12934,#12935),
#12933 = CARTESIAN_POINT('',(-0.49,-10.736,8.));
#12934 = CARTESIAN_POINT('',(-0.63,-10.687,8.));
#12935 = CARTESIAN_POINT('',(-0.815,-10.687,8.));
#12936 = PCURVE('',#12838,#12937);
#12937 = DEFINITIONAL_REPRESENTATION('',(#12938),#12942);
#12938 = LINE('',#12939,#12940);
#12939 = CARTESIAN_POINT('',(0.,0.));
#12940 = VECTOR('',#12941,1.);
#12941 = DIRECTION('',(1.,0.));
#12942 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12943 = PCURVE('',#12627,#12944);
#12944 = DEFINITIONAL_REPRESENTATION('',(#12945),#12949);
#12945 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12946,#12947,#12948),
#12946 = CARTESIAN_POINT('',(0.347463887016,0.312336392677));
#12947 = CARTESIAN_POINT('',(0.396463887016,0.172336392677));
#12948 = CARTESIAN_POINT('',(0.396463887016,-1.266360732324E-02));
#12949 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12950 = ADVANCED_FACE('',(#12951),#12916,.T.);
#12951 = FACE_BOUND('',#12952,.T.);
#12952 = EDGE_LOOP('',(#12953,#12954,#12977,#13007));
#12953 = ORIENTED_EDGE('',*,*,#12900,.T.);
#12954 = ORIENTED_EDGE('',*,*,#12955,.T.);
#12955 = EDGE_CURVE('',#12878,#12956,#12958,.T.);
#12956 = VERTEX_POINT('',#12957);
#12957 = CARTESIAN_POINT('',(-1.357,-10.93,8.2));
#12958 = SURFACE_CURVE('',#12959,(#12963,#12970),.PCURVE_S1.);
#12959 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12960,#12961,#12962),
#12960 = CARTESIAN_POINT('',(-0.815,-10.687,8.2));
#12961 = CARTESIAN_POINT('',(-1.223,-10.687,8.2));
#12962 = CARTESIAN_POINT('',(-1.357,-10.93,8.2));
#12963 = PCURVE('',#12916,#12964);
#12964 = DEFINITIONAL_REPRESENTATION('',(#12965),#12969);
#12965 = LINE('',#12966,#12967);
#12966 = CARTESIAN_POINT('',(0.,-0.2));
#12967 = VECTOR('',#12968,1.);
#12968 = DIRECTION('',(1.,0.));
#12969 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12970 = PCURVE('',#12571,#12971);
#12971 = DEFINITIONAL_REPRESENTATION('',(#12972),#12976);
#12972 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12973,#12974,#12975),
#12973 = CARTESIAN_POINT('',(0.396463887016,-1.266360732324E-02));
#12974 = CARTESIAN_POINT('',(0.396463887016,-0.420663607323));
#12975 = CARTESIAN_POINT('',(0.153463887016,-0.554663607323));
#12976 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12977 = ORIENTED_EDGE('',*,*,#12978,.F.);
#12978 = EDGE_CURVE('',#12979,#12956,#12981,.T.);
#12979 = VERTEX_POINT('',#12980);
#12980 = CARTESIAN_POINT('',(-1.357,-10.93,8.));
#12981 = SURFACE_CURVE('',#12982,(#12986,#12993),.PCURVE_S1.);
#12982 = LINE('',#12983,#12984);
#12983 = CARTESIAN_POINT('',(-1.357,-10.93,8.));
#12984 = VECTOR('',#12985,1.);
#12985 = DIRECTION('',(0.,0.,1.));
#12986 = PCURVE('',#12916,#12987);
#12987 = DEFINITIONAL_REPRESENTATION('',(#12988),#12992);
#12988 = LINE('',#12989,#12990);
#12989 = CARTESIAN_POINT('',(1.,0.));
#12990 = VECTOR('',#12991,1.);
#12991 = DIRECTION('',(0.,-1.));
#12992 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#12993 = PCURVE('',#12994,#13001);
#12994 = SURFACE_OF_LINEAR_EXTRUSION('',#12995,#12999);
#12995 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#12996,#12997,#12998),
#12996 = CARTESIAN_POINT('',(-1.357,-10.93,8.));
#12997 = CARTESIAN_POINT('',(-1.408,-11.022,8.));
#12998 = CARTESIAN_POINT('',(-1.408,-11.139,8.));
#12999 = VECTOR('',#13000,1.);
#13000 = DIRECTION('',(-0.,-0.,-1.));
#13001 = DEFINITIONAL_REPRESENTATION('',(#13002),#13006);
#13002 = LINE('',#13003,#13004);
#13003 = CARTESIAN_POINT('',(0.,0.));
#13004 = VECTOR('',#13005,1.);
#13005 = DIRECTION('',(0.,-1.));
#13006 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13007 = ORIENTED_EDGE('',*,*,#13008,.F.);
#13008 = EDGE_CURVE('',#12901,#12979,#13009,.T.);
#13009 = SURFACE_CURVE('',#13010,(#13014,#13021),.PCURVE_S1.);
#13010 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13011,#13012,#13013),
#13011 = CARTESIAN_POINT('',(-0.815,-10.687,8.));
#13012 = CARTESIAN_POINT('',(-1.223,-10.687,8.));
#13013 = CARTESIAN_POINT('',(-1.357,-10.93,8.));
#13014 = PCURVE('',#12916,#13015);
#13015 = DEFINITIONAL_REPRESENTATION('',(#13016),#13020);
#13016 = LINE('',#13017,#13018);
#13017 = CARTESIAN_POINT('',(0.,0.));
#13018 = VECTOR('',#13019,1.);
#13019 = DIRECTION('',(1.,0.));
#13020 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13021 = PCURVE('',#12627,#13022);
#13022 = DEFINITIONAL_REPRESENTATION('',(#13023),#13027);
#13023 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13024,#13025,#13026),
#13024 = CARTESIAN_POINT('',(0.396463887016,-1.266360732324E-02));
#13025 = CARTESIAN_POINT('',(0.396463887016,-0.420663607323));
#13026 = CARTESIAN_POINT('',(0.153463887016,-0.554663607323));
#13027 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13028 = ADVANCED_FACE('',(#13029),#12994,.T.);
#13029 = FACE_BOUND('',#13030,.T.);
#13030 = EDGE_LOOP('',(#13031,#13032,#13055,#13085));
#13031 = ORIENTED_EDGE('',*,*,#12978,.T.);
#13032 = ORIENTED_EDGE('',*,*,#13033,.T.);
#13033 = EDGE_CURVE('',#12956,#13034,#13036,.T.);
#13034 = VERTEX_POINT('',#13035);
#13035 = CARTESIAN_POINT('',(-1.408,-11.139,8.2));
#13036 = SURFACE_CURVE('',#13037,(#13041,#13048),.PCURVE_S1.);
#13037 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13038,#13039,#13040),
#13038 = CARTESIAN_POINT('',(-1.357,-10.93,8.2));
#13039 = CARTESIAN_POINT('',(-1.408,-11.022,8.2));
#13040 = CARTESIAN_POINT('',(-1.408,-11.139,8.2));
#13041 = PCURVE('',#12994,#13042);
#13042 = DEFINITIONAL_REPRESENTATION('',(#13043),#13047);
#13043 = LINE('',#13044,#13045);
#13044 = CARTESIAN_POINT('',(0.,-0.2));
#13045 = VECTOR('',#13046,1.);
#13046 = DIRECTION('',(1.,0.));
#13047 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13048 = PCURVE('',#12571,#13049);
#13049 = DEFINITIONAL_REPRESENTATION('',(#13050),#13054);
#13050 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13051,#13052,#13053),
#13051 = CARTESIAN_POINT('',(0.153463887016,-0.554663607323));
#13052 = CARTESIAN_POINT('',(6.146388701555E-02,-0.605663607323));
#13053 = CARTESIAN_POINT('',(-5.553611298445E-02,-0.605663607323));
#13054 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13055 = ORIENTED_EDGE('',*,*,#13056,.F.);
#13056 = EDGE_CURVE('',#13057,#13034,#13059,.T.);
#13057 = VERTEX_POINT('',#13058);
#13058 = CARTESIAN_POINT('',(-1.408,-11.139,8.));
#13059 = SURFACE_CURVE('',#13060,(#13064,#13071),.PCURVE_S1.);
#13060 = LINE('',#13061,#13062);
#13061 = CARTESIAN_POINT('',(-1.408,-11.139,8.));
#13062 = VECTOR('',#13063,1.);
#13063 = DIRECTION('',(0.,0.,1.));
#13064 = PCURVE('',#12994,#13065);
#13065 = DEFINITIONAL_REPRESENTATION('',(#13066),#13070);
#13066 = LINE('',#13067,#13068);
#13067 = CARTESIAN_POINT('',(1.,0.));
#13068 = VECTOR('',#13069,1.);
#13069 = DIRECTION('',(0.,-1.));
#13070 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13071 = PCURVE('',#13072,#13079);
#13072 = SURFACE_OF_LINEAR_EXTRUSION('',#13073,#13077);
#13073 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13074,#13075,#13076),
#13074 = CARTESIAN_POINT('',(-1.408,-11.139,8.));
#13075 = CARTESIAN_POINT('',(-1.403,-11.464,8.));
#13076 = CARTESIAN_POINT('',(-1.088,-11.532,8.));
#13077 = VECTOR('',#13078,1.);
#13078 = DIRECTION('',(-0.,-0.,-1.));
#13079 = DEFINITIONAL_REPRESENTATION('',(#13080),#13084);
#13080 = LINE('',#13081,#13082);
#13081 = CARTESIAN_POINT('',(0.,0.));
#13082 = VECTOR('',#13083,1.);
#13083 = DIRECTION('',(0.,-1.));
#13084 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13085 = ORIENTED_EDGE('',*,*,#13086,.F.);
#13086 = EDGE_CURVE('',#12979,#13057,#13087,.T.);
#13087 = SURFACE_CURVE('',#13088,(#13092,#13099),.PCURVE_S1.);
#13088 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13089,#13090,#13091),
#13089 = CARTESIAN_POINT('',(-1.357,-10.93,8.));
#13090 = CARTESIAN_POINT('',(-1.408,-11.022,8.));
#13091 = CARTESIAN_POINT('',(-1.408,-11.139,8.));
#13092 = PCURVE('',#12994,#13093);
#13093 = DEFINITIONAL_REPRESENTATION('',(#13094),#13098);
#13094 = LINE('',#13095,#13096);
#13095 = CARTESIAN_POINT('',(0.,0.));
#13096 = VECTOR('',#13097,1.);
#13097 = DIRECTION('',(1.,0.));
#13098 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13099 = PCURVE('',#12627,#13100);
#13100 = DEFINITIONAL_REPRESENTATION('',(#13101),#13105);
#13101 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13102,#13103,#13104),
#13102 = CARTESIAN_POINT('',(0.153463887016,-0.554663607323));
#13103 = CARTESIAN_POINT('',(6.146388701555E-02,-0.605663607323));
#13104 = CARTESIAN_POINT('',(-5.553611298445E-02,-0.605663607323));
#13105 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13106 = ADVANCED_FACE('',(#13107),#13072,.T.);
#13107 = FACE_BOUND('',#13108,.T.);
#13108 = EDGE_LOOP('',(#13109,#13110,#13133,#13161));
#13109 = ORIENTED_EDGE('',*,*,#13056,.T.);
#13110 = ORIENTED_EDGE('',*,*,#13111,.T.);
#13111 = EDGE_CURVE('',#13034,#13112,#13114,.T.);
#13112 = VERTEX_POINT('',#13113);
#13113 = CARTESIAN_POINT('',(-1.088,-11.532,8.2));
#13114 = SURFACE_CURVE('',#13115,(#13119,#13126),.PCURVE_S1.);
#13115 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13116,#13117,#13118),
#13116 = CARTESIAN_POINT('',(-1.408,-11.139,8.2));
#13117 = CARTESIAN_POINT('',(-1.403,-11.464,8.2));
#13118 = CARTESIAN_POINT('',(-1.088,-11.532,8.2));
#13119 = PCURVE('',#13072,#13120);
#13120 = DEFINITIONAL_REPRESENTATION('',(#13121),#13125);
#13121 = LINE('',#13122,#13123);
#13122 = CARTESIAN_POINT('',(0.,-0.2));
#13123 = VECTOR('',#13124,1.);
#13124 = DIRECTION('',(1.,0.));
#13125 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13126 = PCURVE('',#12571,#13127);
#13127 = DEFINITIONAL_REPRESENTATION('',(#13128),#13132);
#13128 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13129,#13130,#13131),
#13129 = CARTESIAN_POINT('',(-5.553611298445E-02,-0.605663607323));
#13130 = CARTESIAN_POINT('',(-0.380536112984,-0.600663607323));
#13131 = CARTESIAN_POINT('',(-0.448536112984,-0.285663607323));
#13132 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13133 = ORIENTED_EDGE('',*,*,#13134,.F.);
#13134 = EDGE_CURVE('',#13135,#13112,#13137,.T.);
#13135 = VERTEX_POINT('',#13136);
#13136 = CARTESIAN_POINT('',(-1.088,-11.532,8.));
#13137 = SURFACE_CURVE('',#13138,(#13142,#13149),.PCURVE_S1.);
#13138 = LINE('',#13139,#13140);
#13139 = CARTESIAN_POINT('',(-1.088,-11.532,8.));
#13140 = VECTOR('',#13141,1.);
#13141 = DIRECTION('',(0.,0.,1.));
#13142 = PCURVE('',#13072,#13143);
#13143 = DEFINITIONAL_REPRESENTATION('',(#13144),#13148);
#13144 = LINE('',#13145,#13146);
#13145 = CARTESIAN_POINT('',(1.,0.));
#13146 = VECTOR('',#13147,1.);
#13147 = DIRECTION('',(0.,-1.));
#13148 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13149 = PCURVE('',#13150,#13155);
#13150 = PLANE('',#13151);
#13151 = AXIS2_PLACEMENT_3D('',#13152,#13153,#13154);
#13152 = CARTESIAN_POINT('',(-1.088,-11.532,8.));
#13153 = DIRECTION('',(1.,-2.2E-16,0.));
#13154 = DIRECTION('',(-2.2E-16,-1.,0.));
#13155 = DEFINITIONAL_REPRESENTATION('',(#13156),#13160);
#13156 = LINE('',#13157,#13158);
#13157 = CARTESIAN_POINT('',(0.,0.));
#13158 = VECTOR('',#13159,1.);
#13159 = DIRECTION('',(0.,-1.));
#13160 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13161 = ORIENTED_EDGE('',*,*,#13162,.F.);
#13162 = EDGE_CURVE('',#13057,#13135,#13163,.T.);
#13163 = SURFACE_CURVE('',#13164,(#13168,#13175),.PCURVE_S1.);
#13164 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13165,#13166,#13167),
#13165 = CARTESIAN_POINT('',(-1.408,-11.139,8.));
#13166 = CARTESIAN_POINT('',(-1.403,-11.464,8.));
#13167 = CARTESIAN_POINT('',(-1.088,-11.532,8.));
#13168 = PCURVE('',#13072,#13169);
#13169 = DEFINITIONAL_REPRESENTATION('',(#13170),#13174);
#13170 = LINE('',#13171,#13172);
#13171 = CARTESIAN_POINT('',(0.,0.));
#13172 = VECTOR('',#13173,1.);
#13173 = DIRECTION('',(1.,0.));
#13174 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13175 = PCURVE('',#12627,#13176);
#13176 = DEFINITIONAL_REPRESENTATION('',(#13177),#13181);
#13177 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13178,#13179,#13180),
#13178 = CARTESIAN_POINT('',(-5.553611298445E-02,-0.605663607323));
#13179 = CARTESIAN_POINT('',(-0.380536112984,-0.600663607323));
#13180 = CARTESIAN_POINT('',(-0.448536112984,-0.285663607323));
#13181 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13182 = ADVANCED_FACE('',(#13183),#13150,.T.);
#13183 = FACE_BOUND('',#13184,.T.);
#13184 = EDGE_LOOP('',(#13185,#13186,#13209,#13239));
#13185 = ORIENTED_EDGE('',*,*,#13134,.T.);
#13186 = ORIENTED_EDGE('',*,*,#13187,.T.);
#13187 = EDGE_CURVE('',#13112,#13188,#13190,.T.);
#13188 = VERTEX_POINT('',#13189);
#13189 = CARTESIAN_POINT('',(-1.088,-11.79,8.2));
#13190 = SURFACE_CURVE('',#13191,(#13195,#13202),.PCURVE_S1.);
#13191 = LINE('',#13192,#13193);
#13192 = CARTESIAN_POINT('',(-1.088,-11.532,8.2));
#13193 = VECTOR('',#13194,1.);
#13194 = DIRECTION('',(0.,-1.,0.));
#13195 = PCURVE('',#13150,#13196);
#13196 = DEFINITIONAL_REPRESENTATION('',(#13197),#13201);
#13197 = LINE('',#13198,#13199);
#13198 = CARTESIAN_POINT('',(0.,-0.2));
#13199 = VECTOR('',#13200,1.);
#13200 = DIRECTION('',(1.,-0.));
#13201 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13202 = PCURVE('',#12571,#13203);
#13203 = DEFINITIONAL_REPRESENTATION('',(#13204),#13208);
#13204 = LINE('',#13205,#13206);
#13205 = CARTESIAN_POINT('',(-0.448536112984,-0.285663607323));
#13206 = VECTOR('',#13207,1.);
#13207 = DIRECTION('',(-1.,0.));
#13208 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13209 = ORIENTED_EDGE('',*,*,#13210,.F.);
#13210 = EDGE_CURVE('',#13211,#13188,#13213,.T.);
#13211 = VERTEX_POINT('',#13212);
#13212 = CARTESIAN_POINT('',(-1.088,-11.79,8.));
#13213 = SURFACE_CURVE('',#13214,(#13218,#13225),.PCURVE_S1.);
#13214 = LINE('',#13215,#13216);
#13215 = CARTESIAN_POINT('',(-1.088,-11.79,8.));
#13216 = VECTOR('',#13217,1.);
#13217 = DIRECTION('',(0.,0.,1.));
#13218 = PCURVE('',#13150,#13219);
#13219 = DEFINITIONAL_REPRESENTATION('',(#13220),#13224);
#13220 = LINE('',#13221,#13222);
#13221 = CARTESIAN_POINT('',(0.258,0.));
#13222 = VECTOR('',#13223,1.);
#13223 = DIRECTION('',(0.,-1.));
#13224 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13225 = PCURVE('',#13226,#13233);
#13226 = SURFACE_OF_LINEAR_EXTRUSION('',#13227,#13231);
#13227 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13228,#13229,#13230),
#13228 = CARTESIAN_POINT('',(-1.088,-11.79,8.));
#13229 = CARTESIAN_POINT('',(-1.477,-11.756,8.));
#13230 = CARTESIAN_POINT('',(-1.607,-11.437,8.));
#13231 = VECTOR('',#13232,1.);
#13232 = DIRECTION('',(-0.,-0.,-1.));
#13233 = DEFINITIONAL_REPRESENTATION('',(#13234),#13238);
#13234 = LINE('',#13235,#13236);
#13235 = CARTESIAN_POINT('',(0.,0.));
#13236 = VECTOR('',#13237,1.);
#13237 = DIRECTION('',(0.,-1.));
#13238 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13239 = ORIENTED_EDGE('',*,*,#13240,.F.);
#13240 = EDGE_CURVE('',#13135,#13211,#13241,.T.);
#13241 = SURFACE_CURVE('',#13242,(#13246,#13253),.PCURVE_S1.);
#13242 = LINE('',#13243,#13244);
#13243 = CARTESIAN_POINT('',(-1.088,-11.532,8.));
#13244 = VECTOR('',#13245,1.);
#13245 = DIRECTION('',(0.,-1.,0.));
#13246 = PCURVE('',#13150,#13247);
#13247 = DEFINITIONAL_REPRESENTATION('',(#13248),#13252);
#13248 = LINE('',#13249,#13250);
#13249 = CARTESIAN_POINT('',(0.,0.));
#13250 = VECTOR('',#13251,1.);
#13251 = DIRECTION('',(1.,-0.));
#13252 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13253 = PCURVE('',#12627,#13254);
#13254 = DEFINITIONAL_REPRESENTATION('',(#13255),#13259);
#13255 = LINE('',#13256,#13257);
#13256 = CARTESIAN_POINT('',(-0.448536112984,-0.285663607323));
#13257 = VECTOR('',#13258,1.);
#13258 = DIRECTION('',(-1.,0.));
#13259 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13260 = ADVANCED_FACE('',(#13261),#13226,.T.);
#13261 = FACE_BOUND('',#13262,.T.);
#13262 = EDGE_LOOP('',(#13263,#13264,#13287,#13317));
#13263 = ORIENTED_EDGE('',*,*,#13210,.T.);
#13264 = ORIENTED_EDGE('',*,*,#13265,.T.);
#13265 = EDGE_CURVE('',#13188,#13266,#13268,.T.);
#13266 = VERTEX_POINT('',#13267);
#13267 = CARTESIAN_POINT('',(-1.607,-11.437,8.2));
#13268 = SURFACE_CURVE('',#13269,(#13273,#13280),.PCURVE_S1.);
#13269 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13270,#13271,#13272),
#13270 = CARTESIAN_POINT('',(-1.088,-11.79,8.2));
#13271 = CARTESIAN_POINT('',(-1.477,-11.756,8.2));
#13272 = CARTESIAN_POINT('',(-1.607,-11.437,8.2));
#13273 = PCURVE('',#13226,#13274);
#13274 = DEFINITIONAL_REPRESENTATION('',(#13275),#13279);
#13275 = LINE('',#13276,#13277);
#13276 = CARTESIAN_POINT('',(0.,-0.2));
#13277 = VECTOR('',#13278,1.);
#13278 = DIRECTION('',(1.,0.));
#13279 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13280 = PCURVE('',#12571,#13281);
#13281 = DEFINITIONAL_REPRESENTATION('',(#13282),#13286);
#13282 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13283,#13284,#13285),
#13283 = CARTESIAN_POINT('',(-0.706536112984,-0.285663607323));
#13284 = CARTESIAN_POINT('',(-0.672536112984,-0.674663607323));
#13285 = CARTESIAN_POINT('',(-0.353536112984,-0.804663607323));
#13286 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13287 = ORIENTED_EDGE('',*,*,#13288,.F.);
#13288 = EDGE_CURVE('',#13289,#13266,#13291,.T.);
#13289 = VERTEX_POINT('',#13290);
#13290 = CARTESIAN_POINT('',(-1.607,-11.437,8.));
#13291 = SURFACE_CURVE('',#13292,(#13296,#13303),.PCURVE_S1.);
#13292 = LINE('',#13293,#13294);
#13293 = CARTESIAN_POINT('',(-1.607,-11.437,8.));
#13294 = VECTOR('',#13295,1.);
#13295 = DIRECTION('',(0.,0.,1.));
#13296 = PCURVE('',#13226,#13297);
#13297 = DEFINITIONAL_REPRESENTATION('',(#13298),#13302);
#13298 = LINE('',#13299,#13300);
#13299 = CARTESIAN_POINT('',(1.,0.));
#13300 = VECTOR('',#13301,1.);
#13301 = DIRECTION('',(0.,-1.));
#13302 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13303 = PCURVE('',#13304,#13311);
#13304 = SURFACE_OF_LINEAR_EXTRUSION('',#13305,#13309);
#13305 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13306,#13307,#13308),
#13306 = CARTESIAN_POINT('',(-1.607,-11.437,8.));
#13307 = CARTESIAN_POINT('',(-1.664,-11.301,8.));
#13308 = CARTESIAN_POINT('',(-1.664,-11.133,8.));
#13309 = VECTOR('',#13310,1.);
#13310 = DIRECTION('',(-0.,-0.,-1.));
#13311 = DEFINITIONAL_REPRESENTATION('',(#13312),#13316);
#13312 = LINE('',#13313,#13314);
#13313 = CARTESIAN_POINT('',(0.,0.));
#13314 = VECTOR('',#13315,1.);
#13315 = DIRECTION('',(0.,-1.));
#13316 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13317 = ORIENTED_EDGE('',*,*,#13318,.F.);
#13318 = EDGE_CURVE('',#13211,#13289,#13319,.T.);
#13319 = SURFACE_CURVE('',#13320,(#13324,#13331),.PCURVE_S1.);
#13320 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13321,#13322,#13323),
#13321 = CARTESIAN_POINT('',(-1.088,-11.79,8.));
#13322 = CARTESIAN_POINT('',(-1.477,-11.756,8.));
#13323 = CARTESIAN_POINT('',(-1.607,-11.437,8.));
#13324 = PCURVE('',#13226,#13325);
#13325 = DEFINITIONAL_REPRESENTATION('',(#13326),#13330);
#13326 = LINE('',#13327,#13328);
#13327 = CARTESIAN_POINT('',(0.,0.));
#13328 = VECTOR('',#13329,1.);
#13329 = DIRECTION('',(1.,0.));
#13330 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13331 = PCURVE('',#12627,#13332);
#13332 = DEFINITIONAL_REPRESENTATION('',(#13333),#13337);
#13333 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13334,#13335,#13336),
#13334 = CARTESIAN_POINT('',(-0.706536112984,-0.285663607323));
#13335 = CARTESIAN_POINT('',(-0.672536112984,-0.674663607323));
#13336 = CARTESIAN_POINT('',(-0.353536112984,-0.804663607323));
#13337 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13338 = ADVANCED_FACE('',(#13339),#13304,.T.);
#13339 = FACE_BOUND('',#13340,.T.);
#13340 = EDGE_LOOP('',(#13341,#13342,#13365,#13395));
#13341 = ORIENTED_EDGE('',*,*,#13288,.T.);
#13342 = ORIENTED_EDGE('',*,*,#13343,.T.);
#13343 = EDGE_CURVE('',#13266,#13344,#13346,.T.);
#13344 = VERTEX_POINT('',#13345);
#13345 = CARTESIAN_POINT('',(-1.664,-11.133,8.2));
#13346 = SURFACE_CURVE('',#13347,(#13351,#13358),.PCURVE_S1.);
#13347 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13348,#13349,#13350),
#13348 = CARTESIAN_POINT('',(-1.607,-11.437,8.2));
#13349 = CARTESIAN_POINT('',(-1.664,-11.301,8.2));
#13350 = CARTESIAN_POINT('',(-1.664,-11.133,8.2));
#13351 = PCURVE('',#13304,#13352);
#13352 = DEFINITIONAL_REPRESENTATION('',(#13353),#13357);
#13353 = LINE('',#13354,#13355);
#13354 = CARTESIAN_POINT('',(0.,-0.2));
#13355 = VECTOR('',#13356,1.);
#13356 = DIRECTION('',(1.,0.));
#13357 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13358 = PCURVE('',#12571,#13359);
#13359 = DEFINITIONAL_REPRESENTATION('',(#13360),#13364);
#13360 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13361,#13362,#13363),
#13361 = CARTESIAN_POINT('',(-0.353536112984,-0.804663607323));
#13362 = CARTESIAN_POINT('',(-0.217536112984,-0.861663607323));
#13363 = CARTESIAN_POINT('',(-4.953611298445E-02,-0.861663607323));
#13364 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13365 = ORIENTED_EDGE('',*,*,#13366,.F.);
#13366 = EDGE_CURVE('',#13367,#13344,#13369,.T.);
#13367 = VERTEX_POINT('',#13368);
#13368 = CARTESIAN_POINT('',(-1.664,-11.133,8.));
#13369 = SURFACE_CURVE('',#13370,(#13374,#13381),.PCURVE_S1.);
#13370 = LINE('',#13371,#13372);
#13371 = CARTESIAN_POINT('',(-1.664,-11.133,8.));
#13372 = VECTOR('',#13373,1.);
#13373 = DIRECTION('',(0.,0.,1.));
#13374 = PCURVE('',#13304,#13375);
#13375 = DEFINITIONAL_REPRESENTATION('',(#13376),#13380);
#13376 = LINE('',#13377,#13378);
#13377 = CARTESIAN_POINT('',(1.,0.));
#13378 = VECTOR('',#13379,1.);
#13379 = DIRECTION('',(0.,-1.));
#13380 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13381 = PCURVE('',#13382,#13389);
#13382 = SURFACE_OF_LINEAR_EXTRUSION('',#13383,#13387);
#13383 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13384,#13385,#13386),
#13384 = CARTESIAN_POINT('',(-1.664,-11.133,8.));
#13385 = CARTESIAN_POINT('',(-1.664,-10.736,8.));
#13386 = CARTESIAN_POINT('',(-1.341,-10.546,8.));
#13387 = VECTOR('',#13388,1.);
#13388 = DIRECTION('',(-0.,-0.,-1.));
#13389 = DEFINITIONAL_REPRESENTATION('',(#13390),#13394);
#13390 = LINE('',#13391,#13392);
#13391 = CARTESIAN_POINT('',(0.,0.));
#13392 = VECTOR('',#13393,1.);
#13393 = DIRECTION('',(0.,-1.));
#13394 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13395 = ORIENTED_EDGE('',*,*,#13396,.F.);
#13396 = EDGE_CURVE('',#13289,#13367,#13397,.T.);
#13397 = SURFACE_CURVE('',#13398,(#13402,#13409),.PCURVE_S1.);
#13398 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13399,#13400,#13401),
#13399 = CARTESIAN_POINT('',(-1.607,-11.437,8.));
#13400 = CARTESIAN_POINT('',(-1.664,-11.301,8.));
#13401 = CARTESIAN_POINT('',(-1.664,-11.133,8.));
#13402 = PCURVE('',#13304,#13403);
#13403 = DEFINITIONAL_REPRESENTATION('',(#13404),#13408);
#13404 = LINE('',#13405,#13406);
#13405 = CARTESIAN_POINT('',(0.,0.));
#13406 = VECTOR('',#13407,1.);
#13407 = DIRECTION('',(1.,0.));
#13408 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13409 = PCURVE('',#12627,#13410);
#13410 = DEFINITIONAL_REPRESENTATION('',(#13411),#13415);
#13411 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13412,#13413,#13414),
#13412 = CARTESIAN_POINT('',(-0.353536112984,-0.804663607323));
#13413 = CARTESIAN_POINT('',(-0.217536112984,-0.861663607323));
#13414 = CARTESIAN_POINT('',(-4.953611298445E-02,-0.861663607323));
#13415 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13416 = ADVANCED_FACE('',(#13417),#13382,.T.);
#13417 = FACE_BOUND('',#13418,.T.);
#13418 = EDGE_LOOP('',(#13419,#13420,#13443,#13473));
#13419 = ORIENTED_EDGE('',*,*,#13366,.T.);
#13420 = ORIENTED_EDGE('',*,*,#13421,.T.);
#13421 = EDGE_CURVE('',#13344,#13422,#13424,.T.);
#13422 = VERTEX_POINT('',#13423);
#13423 = CARTESIAN_POINT('',(-1.341,-10.546,8.2));
#13424 = SURFACE_CURVE('',#13425,(#13429,#13436),.PCURVE_S1.);
#13425 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13426,#13427,#13428),
#13426 = CARTESIAN_POINT('',(-1.664,-11.133,8.2));
#13427 = CARTESIAN_POINT('',(-1.664,-10.736,8.2));
#13428 = CARTESIAN_POINT('',(-1.341,-10.546,8.2));
#13429 = PCURVE('',#13382,#13430);
#13430 = DEFINITIONAL_REPRESENTATION('',(#13431),#13435);
#13431 = LINE('',#13432,#13433);
#13432 = CARTESIAN_POINT('',(0.,-0.2));
#13433 = VECTOR('',#13434,1.);
#13434 = DIRECTION('',(1.,0.));
#13435 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13436 = PCURVE('',#12571,#13437);
#13437 = DEFINITIONAL_REPRESENTATION('',(#13438),#13442);
#13438 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13439,#13440,#13441),
#13439 = CARTESIAN_POINT('',(-4.953611298445E-02,-0.861663607323));
#13440 = CARTESIAN_POINT('',(0.347463887016,-0.861663607323));
#13441 = CARTESIAN_POINT('',(0.537463887016,-0.538663607323));
#13442 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13443 = ORIENTED_EDGE('',*,*,#13444,.F.);
#13444 = EDGE_CURVE('',#13445,#13422,#13447,.T.);
#13445 = VERTEX_POINT('',#13446);
#13446 = CARTESIAN_POINT('',(-1.341,-10.546,8.));
#13447 = SURFACE_CURVE('',#13448,(#13452,#13459),.PCURVE_S1.);
#13448 = LINE('',#13449,#13450);
#13449 = CARTESIAN_POINT('',(-1.341,-10.546,8.));
#13450 = VECTOR('',#13451,1.);
#13451 = DIRECTION('',(0.,0.,1.));
#13452 = PCURVE('',#13382,#13453);
#13453 = DEFINITIONAL_REPRESENTATION('',(#13454),#13458);
#13454 = LINE('',#13455,#13456);
#13455 = CARTESIAN_POINT('',(1.,0.));
#13456 = VECTOR('',#13457,1.);
#13457 = DIRECTION('',(0.,-1.));
#13458 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13459 = PCURVE('',#13460,#13467);
#13460 = SURFACE_OF_LINEAR_EXTRUSION('',#13461,#13465);
#13461 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13462,#13463,#13464),
#13462 = CARTESIAN_POINT('',(-1.341,-10.546,8.));
#13463 = CARTESIAN_POINT('',(-1.126,-10.42,8.));
#13464 = CARTESIAN_POINT('',(-0.815,-10.42,8.));
#13465 = VECTOR('',#13466,1.);
#13466 = DIRECTION('',(-0.,-0.,-1.));
#13467 = DEFINITIONAL_REPRESENTATION('',(#13468),#13472);
#13468 = LINE('',#13469,#13470);
#13469 = CARTESIAN_POINT('',(0.,0.));
#13470 = VECTOR('',#13471,1.);
#13471 = DIRECTION('',(0.,-1.));
#13472 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13473 = ORIENTED_EDGE('',*,*,#13474,.F.);
#13474 = EDGE_CURVE('',#13367,#13445,#13475,.T.);
#13475 = SURFACE_CURVE('',#13476,(#13480,#13487),.PCURVE_S1.);
#13476 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13477,#13478,#13479),
#13477 = CARTESIAN_POINT('',(-1.664,-11.133,8.));
#13478 = CARTESIAN_POINT('',(-1.664,-10.736,8.));
#13479 = CARTESIAN_POINT('',(-1.341,-10.546,8.));
#13480 = PCURVE('',#13382,#13481);
#13481 = DEFINITIONAL_REPRESENTATION('',(#13482),#13486);
#13482 = LINE('',#13483,#13484);
#13483 = CARTESIAN_POINT('',(0.,0.));
#13484 = VECTOR('',#13485,1.);
#13485 = DIRECTION('',(1.,0.));
#13486 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13487 = PCURVE('',#12627,#13488);
#13488 = DEFINITIONAL_REPRESENTATION('',(#13489),#13493);
#13489 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13490,#13491,#13492),
#13490 = CARTESIAN_POINT('',(-4.953611298445E-02,-0.861663607323));
#13491 = CARTESIAN_POINT('',(0.347463887016,-0.861663607323));
#13492 = CARTESIAN_POINT('',(0.537463887016,-0.538663607323));
#13493 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13494 = ADVANCED_FACE('',(#13495),#13460,.T.);
#13495 = FACE_BOUND('',#13496,.T.);
#13496 = EDGE_LOOP('',(#13497,#13498,#13521,#13551));
#13497 = ORIENTED_EDGE('',*,*,#13444,.T.);
#13498 = ORIENTED_EDGE('',*,*,#13499,.T.);
#13499 = EDGE_CURVE('',#13422,#13500,#13502,.T.);
#13500 = VERTEX_POINT('',#13501);
#13501 = CARTESIAN_POINT('',(-0.815,-10.42,8.2));
#13502 = SURFACE_CURVE('',#13503,(#13507,#13514),.PCURVE_S1.);
#13503 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13504,#13505,#13506),
#13504 = CARTESIAN_POINT('',(-1.341,-10.546,8.2));
#13505 = CARTESIAN_POINT('',(-1.126,-10.42,8.2));
#13506 = CARTESIAN_POINT('',(-0.815,-10.42,8.2));
#13507 = PCURVE('',#13460,#13508);
#13508 = DEFINITIONAL_REPRESENTATION('',(#13509),#13513);
#13509 = LINE('',#13510,#13511);
#13510 = CARTESIAN_POINT('',(0.,-0.2));
#13511 = VECTOR('',#13512,1.);
#13512 = DIRECTION('',(1.,0.));
#13513 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13514 = PCURVE('',#12571,#13515);
#13515 = DEFINITIONAL_REPRESENTATION('',(#13516),#13520);
#13516 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13517,#13518,#13519),
#13517 = CARTESIAN_POINT('',(0.537463887016,-0.538663607323));
#13518 = CARTESIAN_POINT('',(0.663463887016,-0.323663607323));
#13519 = CARTESIAN_POINT('',(0.663463887016,-1.266360732324E-02));
#13520 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13521 = ORIENTED_EDGE('',*,*,#13522,.F.);
#13522 = EDGE_CURVE('',#13523,#13500,#13525,.T.);
#13523 = VERTEX_POINT('',#13524);
#13524 = CARTESIAN_POINT('',(-0.815,-10.42,8.));
#13525 = SURFACE_CURVE('',#13526,(#13530,#13537),.PCURVE_S1.);
#13526 = LINE('',#13527,#13528);
#13527 = CARTESIAN_POINT('',(-0.815,-10.42,8.));
#13528 = VECTOR('',#13529,1.);
#13529 = DIRECTION('',(0.,0.,1.));
#13530 = PCURVE('',#13460,#13531);
#13531 = DEFINITIONAL_REPRESENTATION('',(#13532),#13536);
#13532 = LINE('',#13533,#13534);
#13533 = CARTESIAN_POINT('',(1.,0.));
#13534 = VECTOR('',#13535,1.);
#13535 = DIRECTION('',(0.,-1.));
#13536 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13537 = PCURVE('',#13538,#13545);
#13538 = SURFACE_OF_LINEAR_EXTRUSION('',#13539,#13543);
#13539 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13540,#13541,#13542),
#13540 = CARTESIAN_POINT('',(-0.815,-10.42,8.));
#13541 = CARTESIAN_POINT('',(-0.323,-10.42,8.));
#13542 = CARTESIAN_POINT('',(-8.7E-02,-10.703,8.));
#13543 = VECTOR('',#13544,1.);
#13544 = DIRECTION('',(-0.,-0.,-1.));
#13545 = DEFINITIONAL_REPRESENTATION('',(#13546),#13550);
#13546 = LINE('',#13547,#13548);
#13547 = CARTESIAN_POINT('',(0.,0.));
#13548 = VECTOR('',#13549,1.);
#13549 = DIRECTION('',(0.,-1.));
#13550 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13551 = ORIENTED_EDGE('',*,*,#13552,.F.);
#13552 = EDGE_CURVE('',#13445,#13523,#13553,.T.);
#13553 = SURFACE_CURVE('',#13554,(#13558,#13565),.PCURVE_S1.);
#13554 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13555,#13556,#13557),
#13555 = CARTESIAN_POINT('',(-1.341,-10.546,8.));
#13556 = CARTESIAN_POINT('',(-1.126,-10.42,8.));
#13557 = CARTESIAN_POINT('',(-0.815,-10.42,8.));
#13558 = PCURVE('',#13460,#13559);
#13559 = DEFINITIONAL_REPRESENTATION('',(#13560),#13564);
#13560 = LINE('',#13561,#13562);
#13561 = CARTESIAN_POINT('',(0.,0.));
#13562 = VECTOR('',#13563,1.);
#13563 = DIRECTION('',(1.,0.));
#13564 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13565 = PCURVE('',#12627,#13566);
#13566 = DEFINITIONAL_REPRESENTATION('',(#13567),#13571);
#13567 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13568,#13569,#13570),
#13568 = CARTESIAN_POINT('',(0.537463887016,-0.538663607323));
#13569 = CARTESIAN_POINT('',(0.663463887016,-0.323663607323));
#13570 = CARTESIAN_POINT('',(0.663463887016,-1.266360732324E-02));
#13571 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13572 = ADVANCED_FACE('',(#13573),#13538,.T.);
#13573 = FACE_BOUND('',#13574,.T.);
#13574 = EDGE_LOOP('',(#13575,#13576,#13599,#13629));
#13575 = ORIENTED_EDGE('',*,*,#13522,.T.);
#13576 = ORIENTED_EDGE('',*,*,#13577,.T.);
#13577 = EDGE_CURVE('',#13500,#13578,#13580,.T.);
#13578 = VERTEX_POINT('',#13579);
#13579 = CARTESIAN_POINT('',(-8.7E-02,-10.703,8.2));
#13580 = SURFACE_CURVE('',#13581,(#13585,#13592),.PCURVE_S1.);
#13581 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13582,#13583,#13584),
#13582 = CARTESIAN_POINT('',(-0.815,-10.42,8.2));
#13583 = CARTESIAN_POINT('',(-0.323,-10.42,8.2));
#13584 = CARTESIAN_POINT('',(-8.7E-02,-10.703,8.2));
#13585 = PCURVE('',#13538,#13586);
#13586 = DEFINITIONAL_REPRESENTATION('',(#13587),#13591);
#13587 = LINE('',#13588,#13589);
#13588 = CARTESIAN_POINT('',(0.,-0.2));
#13589 = VECTOR('',#13590,1.);
#13590 = DIRECTION('',(1.,0.));
#13591 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13592 = PCURVE('',#12571,#13593);
#13593 = DEFINITIONAL_REPRESENTATION('',(#13594),#13598);
#13594 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13595,#13596,#13597),
#13595 = CARTESIAN_POINT('',(0.663463887016,-1.266360732324E-02));
#13596 = CARTESIAN_POINT('',(0.663463887016,0.479336392677));
#13597 = CARTESIAN_POINT('',(0.380463887016,0.715336392677));
#13598 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13599 = ORIENTED_EDGE('',*,*,#13600,.F.);
#13600 = EDGE_CURVE('',#13601,#13578,#13603,.T.);
#13601 = VERTEX_POINT('',#13602);
#13602 = CARTESIAN_POINT('',(-8.7E-02,-10.703,8.));
#13603 = SURFACE_CURVE('',#13604,(#13608,#13615),.PCURVE_S1.);
#13604 = LINE('',#13605,#13606);
#13605 = CARTESIAN_POINT('',(-8.7E-02,-10.703,8.));
#13606 = VECTOR('',#13607,1.);
#13607 = DIRECTION('',(0.,0.,1.));
#13608 = PCURVE('',#13538,#13609);
#13609 = DEFINITIONAL_REPRESENTATION('',(#13610),#13614);
#13610 = LINE('',#13611,#13612);
#13611 = CARTESIAN_POINT('',(1.,0.));
#13612 = VECTOR('',#13613,1.);
#13613 = DIRECTION('',(0.,-1.));
#13614 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13615 = PCURVE('',#13616,#13623);
#13616 = SURFACE_OF_LINEAR_EXTRUSION('',#13617,#13621);
#13617 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13618,#13619,#13620),
#13618 = CARTESIAN_POINT('',(-8.7E-02,-10.703,8.));
#13619 = CARTESIAN_POINT('',(6.4E-02,-10.884,8.));
#13620 = CARTESIAN_POINT('',(6.4E-02,-11.136,8.));
#13621 = VECTOR('',#13622,1.);
#13622 = DIRECTION('',(-0.,-0.,-1.));
#13623 = DEFINITIONAL_REPRESENTATION('',(#13624),#13628);
#13624 = LINE('',#13625,#13626);
#13625 = CARTESIAN_POINT('',(0.,0.));
#13626 = VECTOR('',#13627,1.);
#13627 = DIRECTION('',(0.,-1.));
#13628 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13629 = ORIENTED_EDGE('',*,*,#13630,.F.);
#13630 = EDGE_CURVE('',#13523,#13601,#13631,.T.);
#13631 = SURFACE_CURVE('',#13632,(#13636,#13643),.PCURVE_S1.);
#13632 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13633,#13634,#13635),
#13633 = CARTESIAN_POINT('',(-0.815,-10.42,8.));
#13634 = CARTESIAN_POINT('',(-0.323,-10.42,8.));
#13635 = CARTESIAN_POINT('',(-8.7E-02,-10.703,8.));
#13636 = PCURVE('',#13538,#13637);
#13637 = DEFINITIONAL_REPRESENTATION('',(#13638),#13642);
#13638 = LINE('',#13639,#13640);
#13639 = CARTESIAN_POINT('',(0.,0.));
#13640 = VECTOR('',#13641,1.);
#13641 = DIRECTION('',(1.,0.));
#13642 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13643 = PCURVE('',#12627,#13644);
#13644 = DEFINITIONAL_REPRESENTATION('',(#13645),#13649);
#13645 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13646,#13647,#13648),
#13646 = CARTESIAN_POINT('',(0.663463887016,-1.266360732324E-02));
#13647 = CARTESIAN_POINT('',(0.663463887016,0.479336392677));
#13648 = CARTESIAN_POINT('',(0.380463887016,0.715336392677));
#13649 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13650 = ADVANCED_FACE('',(#13651),#13616,.T.);
#13651 = FACE_BOUND('',#13652,.T.);
#13652 = EDGE_LOOP('',(#13653,#13654,#13677,#13707));
#13653 = ORIENTED_EDGE('',*,*,#13600,.T.);
#13654 = ORIENTED_EDGE('',*,*,#13655,.T.);
#13655 = EDGE_CURVE('',#13578,#13656,#13658,.T.);
#13656 = VERTEX_POINT('',#13657);
#13657 = CARTESIAN_POINT('',(6.4E-02,-11.136,8.2));
#13658 = SURFACE_CURVE('',#13659,(#13663,#13670),.PCURVE_S1.);
#13659 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13660,#13661,#13662),
#13660 = CARTESIAN_POINT('',(-8.7E-02,-10.703,8.2));
#13661 = CARTESIAN_POINT('',(6.4E-02,-10.884,8.2));
#13662 = CARTESIAN_POINT('',(6.4E-02,-11.136,8.2));
#13663 = PCURVE('',#13616,#13664);
#13664 = DEFINITIONAL_REPRESENTATION('',(#13665),#13669);
#13665 = LINE('',#13666,#13667);
#13666 = CARTESIAN_POINT('',(0.,-0.2));
#13667 = VECTOR('',#13668,1.);
#13668 = DIRECTION('',(1.,0.));
#13669 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13670 = PCURVE('',#12571,#13671);
#13671 = DEFINITIONAL_REPRESENTATION('',(#13672),#13676);
#13672 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13673,#13674,#13675),
#13673 = CARTESIAN_POINT('',(0.380463887016,0.715336392677));
#13674 = CARTESIAN_POINT('',(0.199463887016,0.866336392677));
#13675 = CARTESIAN_POINT('',(-5.253611298445E-02,0.866336392677));
#13676 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13677 = ORIENTED_EDGE('',*,*,#13678,.F.);
#13678 = EDGE_CURVE('',#13679,#13656,#13681,.T.);
#13679 = VERTEX_POINT('',#13680);
#13680 = CARTESIAN_POINT('',(6.4E-02,-11.136,8.));
#13681 = SURFACE_CURVE('',#13682,(#13686,#13693),.PCURVE_S1.);
#13682 = LINE('',#13683,#13684);
#13683 = CARTESIAN_POINT('',(6.4E-02,-11.136,8.));
#13684 = VECTOR('',#13685,1.);
#13685 = DIRECTION('',(0.,0.,1.));
#13686 = PCURVE('',#13616,#13687);
#13687 = DEFINITIONAL_REPRESENTATION('',(#13688),#13692);
#13688 = LINE('',#13689,#13690);
#13689 = CARTESIAN_POINT('',(1.,0.));
#13690 = VECTOR('',#13691,1.);
#13691 = DIRECTION('',(0.,-1.));
#13692 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13693 = PCURVE('',#13694,#13701);
#13694 = SURFACE_OF_LINEAR_EXTRUSION('',#13695,#13699);
#13695 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13696,#13697,#13698),
#13696 = CARTESIAN_POINT('',(6.4E-02,-11.136,8.));
#13697 = CARTESIAN_POINT('',(6.4E-02,-11.569,8.));
#13698 = CARTESIAN_POINT('',(-0.271,-11.714,8.));
#13699 = VECTOR('',#13700,1.);
#13700 = DIRECTION('',(-0.,-0.,-1.));
#13701 = DEFINITIONAL_REPRESENTATION('',(#13702),#13706);
#13702 = LINE('',#13703,#13704);
#13703 = CARTESIAN_POINT('',(0.,0.));
#13704 = VECTOR('',#13705,1.);
#13705 = DIRECTION('',(0.,-1.));
#13706 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13707 = ORIENTED_EDGE('',*,*,#13708,.F.);
#13708 = EDGE_CURVE('',#13601,#13679,#13709,.T.);
#13709 = SURFACE_CURVE('',#13710,(#13714,#13721),.PCURVE_S1.);
#13710 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13711,#13712,#13713),
#13711 = CARTESIAN_POINT('',(-8.7E-02,-10.703,8.));
#13712 = CARTESIAN_POINT('',(6.4E-02,-10.884,8.));
#13713 = CARTESIAN_POINT('',(6.4E-02,-11.136,8.));
#13714 = PCURVE('',#13616,#13715);
#13715 = DEFINITIONAL_REPRESENTATION('',(#13716),#13720);
#13716 = LINE('',#13717,#13718);
#13717 = CARTESIAN_POINT('',(0.,0.));
#13718 = VECTOR('',#13719,1.);
#13719 = DIRECTION('',(1.,0.));
#13720 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13721 = PCURVE('',#12627,#13722);
#13722 = DEFINITIONAL_REPRESENTATION('',(#13723),#13727);
#13723 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13724,#13725,#13726),
#13724 = CARTESIAN_POINT('',(0.380463887016,0.715336392677));
#13725 = CARTESIAN_POINT('',(0.199463887016,0.866336392677));
#13726 = CARTESIAN_POINT('',(-5.253611298445E-02,0.866336392677));
#13727 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13728 = ADVANCED_FACE('',(#13729),#13694,.T.);
#13729 = FACE_BOUND('',#13730,.T.);
#13730 = EDGE_LOOP('',(#13731,#13732,#13755,#13778));
#13731 = ORIENTED_EDGE('',*,*,#13678,.T.);
#13732 = ORIENTED_EDGE('',*,*,#13733,.T.);
#13733 = EDGE_CURVE('',#13656,#13734,#13736,.T.);
#13734 = VERTEX_POINT('',#13735);
#13735 = CARTESIAN_POINT('',(-0.271,-11.714,8.2));
#13736 = SURFACE_CURVE('',#13737,(#13741,#13748),.PCURVE_S1.);
#13737 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13738,#13739,#13740),
#13738 = CARTESIAN_POINT('',(6.4E-02,-11.136,8.2));
#13739 = CARTESIAN_POINT('',(6.4E-02,-11.569,8.2));
#13740 = CARTESIAN_POINT('',(-0.271,-11.714,8.2));
#13741 = PCURVE('',#13694,#13742);
#13742 = DEFINITIONAL_REPRESENTATION('',(#13743),#13747);
#13743 = LINE('',#13744,#13745);
#13744 = CARTESIAN_POINT('',(0.,-0.2));
#13745 = VECTOR('',#13746,1.);
#13746 = DIRECTION('',(1.,0.));
#13747 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13748 = PCURVE('',#12571,#13749);
#13749 = DEFINITIONAL_REPRESENTATION('',(#13750),#13754);
#13750 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13751,#13752,#13753),
#13751 = CARTESIAN_POINT('',(-5.253611298445E-02,0.866336392677));
#13752 = CARTESIAN_POINT('',(-0.485536112984,0.866336392677));
#13753 = CARTESIAN_POINT('',(-0.630536112984,0.531336392677));
#13754 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13755 = ORIENTED_EDGE('',*,*,#13756,.F.);
#13756 = EDGE_CURVE('',#13757,#13734,#13759,.T.);
#13757 = VERTEX_POINT('',#13758);
#13758 = CARTESIAN_POINT('',(-0.271,-11.714,8.));
#13759 = SURFACE_CURVE('',#13760,(#13764,#13771),.PCURVE_S1.);
#13760 = LINE('',#13761,#13762);
#13761 = CARTESIAN_POINT('',(-0.271,-11.714,8.));
#13762 = VECTOR('',#13763,1.);
#13763 = DIRECTION('',(0.,0.,1.));
#13764 = PCURVE('',#13694,#13765);
#13765 = DEFINITIONAL_REPRESENTATION('',(#13766),#13770);
#13766 = LINE('',#13767,#13768);
#13767 = CARTESIAN_POINT('',(1.,0.));
#13768 = VECTOR('',#13769,1.);
#13769 = DIRECTION('',(0.,-1.));
#13770 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13771 = PCURVE('',#12541,#13772);
#13772 = DEFINITIONAL_REPRESENTATION('',(#13773),#13777);
#13773 = LINE('',#13774,#13775);
#13774 = CARTESIAN_POINT('',(0.,0.));
#13775 = VECTOR('',#13776,1.);
#13776 = DIRECTION('',(0.,-1.));
#13777 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13778 = ORIENTED_EDGE('',*,*,#13779,.F.);
#13779 = EDGE_CURVE('',#13679,#13757,#13780,.T.);
#13780 = SURFACE_CURVE('',#13781,(#13785,#13792),.PCURVE_S1.);
#13781 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13782,#13783,#13784),
#13782 = CARTESIAN_POINT('',(6.4E-02,-11.136,8.));
#13783 = CARTESIAN_POINT('',(6.4E-02,-11.569,8.));
#13784 = CARTESIAN_POINT('',(-0.271,-11.714,8.));
#13785 = PCURVE('',#13694,#13786);
#13786 = DEFINITIONAL_REPRESENTATION('',(#13787),#13791);
#13787 = LINE('',#13788,#13789);
#13788 = CARTESIAN_POINT('',(0.,0.));
#13789 = VECTOR('',#13790,1.);
#13790 = DIRECTION('',(1.,0.));
#13791 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13792 = PCURVE('',#12627,#13793);
#13793 = DEFINITIONAL_REPRESENTATION('',(#13794),#13798);
#13794 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13795,#13796,#13797),
#13795 = CARTESIAN_POINT('',(-5.253611298445E-02,0.866336392677));
#13796 = CARTESIAN_POINT('',(-0.485536112984,0.866336392677));
#13797 = CARTESIAN_POINT('',(-0.630536112984,0.531336392677));
#13798 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13799 = ADVANCED_FACE('',(#13800),#12541,.T.);
#13800 = FACE_BOUND('',#13801,.T.);
#13801 = EDGE_LOOP('',(#13802,#13803,#13824,#13825));
#13802 = ORIENTED_EDGE('',*,*,#13756,.T.);
#13803 = ORIENTED_EDGE('',*,*,#13804,.T.);
#13804 = EDGE_CURVE('',#13734,#12521,#13805,.T.);
#13805 = SURFACE_CURVE('',#13806,(#13810,#13817),.PCURVE_S1.);
#13806 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13807,#13808,#13809),
#13807 = CARTESIAN_POINT('',(-0.271,-11.714,8.2));
#13808 = CARTESIAN_POINT('',(-0.379,-11.76,8.2));
#13809 = CARTESIAN_POINT('',(-0.512,-11.772,8.2));
#13810 = PCURVE('',#12541,#13811);
#13811 = DEFINITIONAL_REPRESENTATION('',(#13812),#13816);
#13812 = LINE('',#13813,#13814);
#13813 = CARTESIAN_POINT('',(0.,-0.2));
#13814 = VECTOR('',#13815,1.);
#13815 = DIRECTION('',(1.,0.));
#13816 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13817 = PCURVE('',#12571,#13818);
#13818 = DEFINITIONAL_REPRESENTATION('',(#13819),#13823);
#13819 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13820,#13821,#13822),
#13820 = CARTESIAN_POINT('',(-0.630536112984,0.531336392677));
#13821 = CARTESIAN_POINT('',(-0.676536112984,0.423336392677));
#13822 = CARTESIAN_POINT('',(-0.688536112984,0.290336392677));
#13823 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13824 = ORIENTED_EDGE('',*,*,#12518,.F.);
#13825 = ORIENTED_EDGE('',*,*,#13826,.F.);
#13826 = EDGE_CURVE('',#13757,#12519,#13827,.T.);
#13827 = SURFACE_CURVE('',#13828,(#13832,#13839),.PCURVE_S1.);
#13828 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13829,#13830,#13831),
#13829 = CARTESIAN_POINT('',(-0.271,-11.714,8.));
#13830 = CARTESIAN_POINT('',(-0.379,-11.76,8.));
#13831 = CARTESIAN_POINT('',(-0.512,-11.772,8.));
#13832 = PCURVE('',#12541,#13833);
#13833 = DEFINITIONAL_REPRESENTATION('',(#13834),#13838);
#13834 = LINE('',#13835,#13836);
#13835 = CARTESIAN_POINT('',(0.,0.));
#13836 = VECTOR('',#13837,1.);
#13837 = DIRECTION('',(1.,0.));
#13838 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13839 = PCURVE('',#12627,#13840);
#13840 = DEFINITIONAL_REPRESENTATION('',(#13841),#13845);
#13841 = B_SPLINE_CURVE_WITH_KNOTS('',2,(#13842,#13843,#13844),
#13842 = CARTESIAN_POINT('',(-0.630536112984,0.531336392677));
#13843 = CARTESIAN_POINT('',(-0.676536112984,0.423336392677));
#13844 = CARTESIAN_POINT('',(-0.688536112984,0.290336392677));
#13845 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13846 = ADVANCED_FACE('',(#13847),#12627,.T.);
#13847 = FACE_BOUND('',#13848,.T.);
#13848 = EDGE_LOOP('',(#13849,#13850,#13851,#13852,#13853,#13854,#13855,
#13856,#13857,#13858,#13859,#13860,#13861,#13862,#13863,#13864,
#13865));
#13849 = ORIENTED_EDGE('',*,*,#12613,.T.);
#13850 = ORIENTED_EDGE('',*,*,#12696,.T.);
#13851 = ORIENTED_EDGE('',*,*,#12774,.T.);
#13852 = ORIENTED_EDGE('',*,*,#12852,.T.);
#13853 = ORIENTED_EDGE('',*,*,#12930,.T.);
#13854 = ORIENTED_EDGE('',*,*,#13008,.T.);
#13855 = ORIENTED_EDGE('',*,*,#13086,.T.);
#13856 = ORIENTED_EDGE('',*,*,#13162,.T.);
#13857 = ORIENTED_EDGE('',*,*,#13240,.T.);
#13858 = ORIENTED_EDGE('',*,*,#13318,.T.);
#13859 = ORIENTED_EDGE('',*,*,#13396,.T.);
#13860 = ORIENTED_EDGE('',*,*,#13474,.T.);
#13861 = ORIENTED_EDGE('',*,*,#13552,.T.);
#13862 = ORIENTED_EDGE('',*,*,#13630,.T.);
#13863 = ORIENTED_EDGE('',*,*,#13708,.T.);
#13864 = ORIENTED_EDGE('',*,*,#13779,.T.);
#13865 = ORIENTED_EDGE('',*,*,#13826,.T.);
#13866 = ADVANCED_FACE('',(#13867),#12571,.F.);
#13867 = FACE_BOUND('',#13868,.F.);
#13868 = EDGE_LOOP('',(#13869,#13870,#13871,#13872,#13873,#13874,#13875,
#13876,#13877,#13878,#13879,#13880,#13881,#13882,#13883,#13884,
#13885));
#13869 = ORIENTED_EDGE('',*,*,#12555,.T.);
#13870 = ORIENTED_EDGE('',*,*,#12643,.T.);
#13871 = ORIENTED_EDGE('',*,*,#12721,.T.);
#13872 = ORIENTED_EDGE('',*,*,#12799,.T.);
#13873 = ORIENTED_EDGE('',*,*,#12877,.T.);
#13874 = ORIENTED_EDGE('',*,*,#12955,.T.);
#13875 = ORIENTED_EDGE('',*,*,#13033,.T.);
#13876 = ORIENTED_EDGE('',*,*,#13111,.T.);
#13877 = ORIENTED_EDGE('',*,*,#13187,.T.);
#13878 = ORIENTED_EDGE('',*,*,#13265,.T.);
#13879 = ORIENTED_EDGE('',*,*,#13343,.T.);
#13880 = ORIENTED_EDGE('',*,*,#13421,.T.);
#13881 = ORIENTED_EDGE('',*,*,#13499,.T.);
#13882 = ORIENTED_EDGE('',*,*,#13577,.T.);
#13883 = ORIENTED_EDGE('',*,*,#13655,.T.);
#13884 = ORIENTED_EDGE('',*,*,#13733,.T.);
#13885 = ORIENTED_EDGE('',*,*,#13804,.T.);
#13886 = MANIFOLD_SOLID_BREP('',#13887);
#13887 = CLOSED_SHELL('',(#13888,#14008,#14084,#14160,#14236,#14312,
#14388,#14459,#14506,#14616,#14687,#14734,#14750));
#13888 = ADVANCED_FACE('',(#13889),#13903,.T.);
#13889 = FACE_BOUND('',#13890,.T.);
#13890 = EDGE_LOOP('',(#13891,#13926,#13954,#13982));
#13891 = ORIENTED_EDGE('',*,*,#13892,.T.);
#13892 = EDGE_CURVE('',#13893,#13895,#13897,.T.);
#13893 = VERTEX_POINT('',#13894);
#13894 = CARTESIAN_POINT('',(-0.96,-14.082,8.));
#13895 = VERTEX_POINT('',#13896);
#13896 = CARTESIAN_POINT('',(-0.96,-14.082,8.2));
#13897 = SURFACE_CURVE('',#13898,(#13902,#13914),.PCURVE_S1.);
#13898 = LINE('',#13899,#13900);
#13899 = CARTESIAN_POINT('',(-0.96,-14.082,8.));
#13900 = VECTOR('',#13901,1.);
#13901 = DIRECTION('',(0.,0.,1.));
#13902 = PCURVE('',#13903,#13908);
#13903 = PLANE('',#13904);
#13904 = AXIS2_PLACEMENT_3D('',#13905,#13906,#13907);
#13905 = CARTESIAN_POINT('',(-0.96,-14.082,8.));
#13906 = DIRECTION('',(-1.,2.2E-16,0.));
#13907 = DIRECTION('',(2.2E-16,1.,0.));
#13908 = DEFINITIONAL_REPRESENTATION('',(#13909),#13913);
#13909 = LINE('',#13910,#13911);
#13910 = CARTESIAN_POINT('',(-1.78E-15,0.));
#13911 = VECTOR('',#13912,1.);
#13912 = DIRECTION('',(0.,-1.));
#13913 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
PARAMETRIC_REPRESENTATION_CONTEXT() REPRESENTATION_CONTEXT('2D SPACE',''
#13914 = PCURVE('',#13915,#13920);
#13915 = PLANE('',#13916);
#13916 = AXIS2_PLACEMENT_3D('',#13917,#13918,#13919);
#13917 = CARTESIAN_POINT('',(-1.6,-14.312,8.));
#13918 = DIRECTION('',(-0.338198726163,0.94107471628,0.));
#13919 = DIRECTION('',(0.94107471628,0.338198726163,0.));
#13920 = DEFINITIONAL_REPRESENTATION('',(#13921),#13925);
#13921 = LINE('',#13922,#13923);
#13922 = CARTESIAN_POINT('',(0.680073525437,0.));
#13923 = VECTOR('',#13924,1.);
#13924 = DIRECTION('',(0.,-1.));
#13925 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13926 = ORIENTED_EDGE('',*,*,#13927,.T.);
#13927 = EDGE_CURVE('',#13895,#13928,#13930,.T.);
#13928 = VERTEX_POINT('',#13929);
#13929 = CARTESIAN_POINT('',(-0.96,-13.219,8.2));
#13930 = SURFACE_CURVE('',#13931,(#13935,#13942),.PCURVE_S1.);
#13931 = LINE('',#13932,#13933);
#13932 = CARTESIAN_POINT('',(-0.96,-14.082,8.2));
#13933 = VECTOR('',#13934,1.);
#13934 = DIRECTION('',(0.,1.,0.));
#13935 = PCURVE('',#13903,#13936);
#13936 = DEFINITIONAL_REPRESENTATION('',(#13937),#13941);
#13937 = LINE('',#13938,#13939);
#13938 = CARTESIAN_POINT('',(0.,-0.2));
#13939 = VECTOR('',#13940,1.);
#13940 = DIRECTION('',(1.,0.));
#13941 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13942 = PCURVE('',#13943,#13948);
#13943 = PLANE('',#13944);
#13944 = AXIS2_PLACEMENT_3D('',#13945,#13946,#13947);
#13945 = CARTESIAN_POINT('',(-0.704716995541,-13.65638844519,8.2));
#13946 = DIRECTION('',(-0.,0.,-1.));
#13947 = DIRECTION('',(0.,1.,0.));
#13948 = DEFINITIONAL_REPRESENTATION('',(#13949),#13953);
#13949 = LINE('',#13950,#13951);
#13950 = CARTESIAN_POINT('',(-0.425611554806,-0.255283004459));
#13951 = VECTOR('',#13952,1.);
#13952 = DIRECTION('',(1.,0.));
#13953 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13954 = ORIENTED_EDGE('',*,*,#13955,.F.);
#13955 = EDGE_CURVE('',#13956,#13928,#13958,.T.);
#13956 = VERTEX_POINT('',#13957);
#13957 = CARTESIAN_POINT('',(-0.96,-13.219,8.));
#13958 = SURFACE_CURVE('',#13959,(#13963,#13970),.PCURVE_S1.);
#13959 = LINE('',#13960,#13961);
#13960 = CARTESIAN_POINT('',(-0.96,-13.219,8.));
#13961 = VECTOR('',#13962,1.);
#13962 = DIRECTION('',(0.,0.,1.));
#13963 = PCURVE('',#13903,#13964);
#13964 = DEFINITIONAL_REPRESENTATION('',(#13965),#13969);
#13965 = LINE('',#13966,#13967);
#13966 = CARTESIAN_POINT('',(0.863,0.));
#13967 = VECTOR('',#13968,1.);
#13968 = DIRECTION('',(0.,-1.));
#13969 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13970 = PCURVE('',#13971,#13976);
#13971 = PLANE('',#13972);
#13972 = AXIS2_PLACEMENT_3D('',#13973,#13974,#13975);
#13973 = CARTESIAN_POINT('',(-0.96,-13.219,8.));
#13974 = DIRECTION('',(-0.347266632791,-0.93776643454,0.));
#13975 = DIRECTION('',(-0.93776643454,0.347266632791,0.));
#13976 = DEFINITIONAL_REPRESENTATION('',(#13977),#13981);
#13977 = LINE('',#13978,#13979);
#13978 = CARTESIAN_POINT('',(1.E-16,0.));
#13979 = VECTOR('',#13980,1.);
#13980 = DIRECTION('',(0.,-1.));
#13981 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13982 = ORIENTED_EDGE('',*,*,#13983,.F.);
#13983 = EDGE_CURVE('',#13893,#13956,#13984,.T.);
#13984 = SURFACE_CURVE('',#13985,(#13989,#13996),.PCURVE_S1.);
#13985 = LINE('',#13986,#13987);
#13986 = CARTESIAN_POINT('',(-0.96,-14.082,8.));
#13987 = VECTOR('',#13988,1.);
#13988 = DIRECTION('',(0.,1.,0.));
#13989 = PCURVE('',#13903,#13990);
#13990 = DEFINITIONAL_REPRESENTATION('',(#13991),#13995);
#13991 = LINE('',#13992,#13993);
#13992 = CARTESIAN_POINT('',(0.,0.));
#13993 = VECTOR('',#13994,1.);
#13994 = DIRECTION('',(1.,0.));
#13995 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#13996 = PCURVE('',#13997,#14002);
#13997 = PLANE('',#13998);
#13998 = AXIS2_PLACEMENT_3D('',#13999,#14000,#14001);
#13999 = CARTESIAN_POINT('',(-0.704716995541,-13.65638844519,8.));
#14000 = DIRECTION('',(-0.,0.,-1.));
#14001 = DIRECTION('',(0.,1.,0.));
#14002 = DEFINITIONAL_REPRESENTATION('',(#14003),#14007);
#14003 = LINE('',#14004,#14005);
#14004 = CARTESIAN_POINT('',(-0.425611554806,-0.255283004459));
#14005 = VECTOR('',#14006,1.);
#14006 = DIRECTION('',(1.,0.));
#14007 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14008 = ADVANCED_FACE('',(#14009),#13971,.T.);
#14009 = FACE_BOUND('',#14010,.T.);
#14010 = EDGE_LOOP('',(#14011,#14012,#14035,#14063));
#14011 = ORIENTED_EDGE('',*,*,#13955,.T.);
#14012 = ORIENTED_EDGE('',*,*,#14013,.T.);
#14013 = EDGE_CURVE('',#13928,#14014,#14016,.T.);
#14014 = VERTEX_POINT('',#14015);
#14015 = CARTESIAN_POINT('',(-1.6,-12.982,8.2));
#14016 = SURFACE_CURVE('',#14017,(#14021,#14028),.PCURVE_S1.);
#14017 = LINE('',#14018,#14019);
#14018 = CARTESIAN_POINT('',(-0.96,-13.219,8.2));
#14019 = VECTOR('',#14020,1.);
#14020 = DIRECTION('',(-0.93776643454,0.347266632791,0.));
#14021 = PCURVE('',#13971,#14022);
#14022 = DEFINITIONAL_REPRESENTATION('',(#14023),#14027);
#14023 = LINE('',#14024,#14025);
#14024 = CARTESIAN_POINT('',(0.,-0.2));
#14025 = VECTOR('',#14026,1.);
#14026 = DIRECTION('',(1.,0.));
#14027 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14028 = PCURVE('',#13943,#14029);
#14029 = DEFINITIONAL_REPRESENTATION('',(#14030),#14034);
#14030 = LINE('',#14031,#14032);
#14031 = CARTESIAN_POINT('',(0.437388445194,-0.255283004459));
#14032 = VECTOR('',#14033,1.);
#14033 = DIRECTION('',(0.347266632791,-0.93776643454));
#14034 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14035 = ORIENTED_EDGE('',*,*,#14036,.F.);
#14036 = EDGE_CURVE('',#14037,#14014,#14039,.T.);
#14037 = VERTEX_POINT('',#14038);
#14038 = CARTESIAN_POINT('',(-1.6,-12.982,8.));
#14039 = SURFACE_CURVE('',#14040,(#14044,#14051),.PCURVE_S1.);
#14040 = LINE('',#14041,#14042);
#14041 = CARTESIAN_POINT('',(-1.6,-12.982,8.));
#14042 = VECTOR('',#14043,1.);
#14043 = DIRECTION('',(0.,0.,1.));
#14044 = PCURVE('',#13971,#14045);
#14045 = DEFINITIONAL_REPRESENTATION('',(#14046),#14050);
#14046 = LINE('',#14047,#14048);
#14047 = CARTESIAN_POINT('',(0.682472710077,0.));
#14048 = VECTOR('',#14049,1.);
#14049 = DIRECTION('',(0.,-1.));
#14050 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14051 = PCURVE('',#14052,#14057);
#14052 = PLANE('',#14053);
#14053 = AXIS2_PLACEMENT_3D('',#14054,#14055,#14056);
#14054 = CARTESIAN_POINT('',(-1.6,-12.982,8.));
#14055 = DIRECTION('',(-1.,2.2E-16,0.));
#14056 = DIRECTION('',(2.2E-16,1.,0.));
#14057 = DEFINITIONAL_REPRESENTATION('',(#14058),#14062);
#14058 = LINE('',#14059,#14060);
#14059 = CARTESIAN_POINT('',(0.,0.));
#14060 = VECTOR('',#14061,1.);
#14061 = DIRECTION('',(0.,-1.));
#14062 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14063 = ORIENTED_EDGE('',*,*,#14064,.F.);
#14064 = EDGE_CURVE('',#13956,#14037,#14065,.T.);
#14065 = SURFACE_CURVE('',#14066,(#14070,#14077),.PCURVE_S1.);
#14066 = LINE('',#14067,#14068);
#14067 = CARTESIAN_POINT('',(-0.96,-13.219,8.));
#14068 = VECTOR('',#14069,1.);
#14069 = DIRECTION('',(-0.93776643454,0.347266632791,0.));
#14070 = PCURVE('',#13971,#14071);
#14071 = DEFINITIONAL_REPRESENTATION('',(#14072),#14076);
#14072 = LINE('',#14073,#14074);
#14073 = CARTESIAN_POINT('',(0.,0.));
#14074 = VECTOR('',#14075,1.);
#14075 = DIRECTION('',(1.,0.));
#14076 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14077 = PCURVE('',#13997,#14078);
#14078 = DEFINITIONAL_REPRESENTATION('',(#14079),#14083);
#14079 = LINE('',#14080,#14081);
#14080 = CARTESIAN_POINT('',(0.437388445194,-0.255283004459));
#14081 = VECTOR('',#14082,1.);
#14082 = DIRECTION('',(0.347266632791,-0.93776643454));
#14083 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14084 = ADVANCED_FACE('',(#14085),#14052,.T.);
#14085 = FACE_BOUND('',#14086,.T.);
#14086 = EDGE_LOOP('',(#14087,#14088,#14111,#14139));
#14087 = ORIENTED_EDGE('',*,*,#14036,.T.);
#14088 = ORIENTED_EDGE('',*,*,#14089,.T.);
#14089 = EDGE_CURVE('',#14014,#14090,#14092,.T.);
#14090 = VERTEX_POINT('',#14091);
#14091 = CARTESIAN_POINT('',(-1.6,-12.678,8.2));
#14092 = SURFACE_CURVE('',#14093,(#14097,#14104),.PCURVE_S1.);
#14093 = LINE('',#14094,#14095);
#14094 = CARTESIAN_POINT('',(-1.6,-12.982,8.2));
#14095 = VECTOR('',#14096,1.);
#14096 = DIRECTION('',(0.,1.,0.));
#14097 = PCURVE('',#14052,#14098);
#14098 = DEFINITIONAL_REPRESENTATION('',(#14099),#14103);
#14099 = LINE('',#14100,#14101);
#14100 = CARTESIAN_POINT('',(0.,-0.2));
#14101 = VECTOR('',#14102,1.);
#14102 = DIRECTION('',(1.,0.));
#14103 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14104 = PCURVE('',#13943,#14105);
#14105 = DEFINITIONAL_REPRESENTATION('',(#14106),#14110);
#14106 = LINE('',#14107,#14108);
#14107 = CARTESIAN_POINT('',(0.674388445194,-0.895283004459));
#14108 = VECTOR('',#14109,1.);
#14109 = DIRECTION('',(1.,0.));
#14110 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14111 = ORIENTED_EDGE('',*,*,#14112,.F.);
#14112 = EDGE_CURVE('',#14113,#14090,#14115,.T.);
#14113 = VERTEX_POINT('',#14114);
#14114 = CARTESIAN_POINT('',(-1.6,-12.678,8.));
#14115 = SURFACE_CURVE('',#14116,(#14120,#14127),.PCURVE_S1.);
#14116 = LINE('',#14117,#14118);
#14117 = CARTESIAN_POINT('',(-1.6,-12.678,8.));
#14118 = VECTOR('',#14119,1.);
#14119 = DIRECTION('',(0.,0.,1.));
#14120 = PCURVE('',#14052,#14121);
#14121 = DEFINITIONAL_REPRESENTATION('',(#14122),#14126);
#14122 = LINE('',#14123,#14124);
#14123 = CARTESIAN_POINT('',(0.304,0.));
#14124 = VECTOR('',#14125,1.);
#14125 = DIRECTION('',(0.,-1.));
#14126 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14127 = PCURVE('',#14128,#14133);
#14128 = PLANE('',#14129);
#14129 = AXIS2_PLACEMENT_3D('',#14130,#14131,#14132);
#14130 = CARTESIAN_POINT('',(-1.6,-12.678,8.));
#14131 = DIRECTION('',(0.33596345631,0.941875021446,0.));
#14132 = DIRECTION('',(0.941875021446,-0.33596345631,0.));
#14133 = DEFINITIONAL_REPRESENTATION('',(#14134),#14138);
#14134 = LINE('',#14135,#14136);
#14135 = CARTESIAN_POINT('',(3.32E-15,0.));
#14136 = VECTOR('',#14137,1.);
#14137 = DIRECTION('',(0.,-1.));
#14138 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14139 = ORIENTED_EDGE('',*,*,#14140,.F.);
#14140 = EDGE_CURVE('',#14037,#14113,#14141,.T.);
#14141 = SURFACE_CURVE('',#14142,(#14146,#14153),.PCURVE_S1.);
#14142 = LINE('',#14143,#14144);
#14143 = CARTESIAN_POINT('',(-1.6,-12.982,8.));
#14144 = VECTOR('',#14145,1.);
#14145 = DIRECTION('',(0.,1.,0.));
#14146 = PCURVE('',#14052,#14147);
#14147 = DEFINITIONAL_REPRESENTATION('',(#14148),#14152);
#14148 = LINE('',#14149,#14150);
#14149 = CARTESIAN_POINT('',(0.,0.));
#14150 = VECTOR('',#14151,1.);
#14151 = DIRECTION('',(1.,0.));
#14152 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14153 = PCURVE('',#13997,#14154);
#14154 = DEFINITIONAL_REPRESENTATION('',(#14155),#14159);
#14155 = LINE('',#14156,#14157);
#14156 = CARTESIAN_POINT('',(0.674388445194,-0.895283004459));
#14157 = VECTOR('',#14158,1.);
#14158 = DIRECTION('',(1.,0.));
#14159 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14160 = ADVANCED_FACE('',(#14161),#14128,.T.);
#14161 = FACE_BOUND('',#14162,.T.);
#14162 = EDGE_LOOP('',(#14163,#14164,#14187,#14215));
#14163 = ORIENTED_EDGE('',*,*,#14112,.T.);
#14164 = ORIENTED_EDGE('',*,*,#14165,.T.);
#14165 = EDGE_CURVE('',#14090,#14166,#14168,.T.);
#14166 = VERTEX_POINT('',#14167);
#14167 = CARTESIAN_POINT('',(0.64,-13.477,8.2));
#14168 = SURFACE_CURVE('',#14169,(#14173,#14180),.PCURVE_S1.);
#14169 = LINE('',#14170,#14171);
#14170 = CARTESIAN_POINT('',(-1.6,-12.678,8.2));
#14171 = VECTOR('',#14172,1.);
#14172 = DIRECTION('',(0.941875021446,-0.33596345631,0.));
#14173 = PCURVE('',#14128,#14174);
#14174 = DEFINITIONAL_REPRESENTATION('',(#14175),#14179);
#14175 = LINE('',#14176,#14177);
#14176 = CARTESIAN_POINT('',(0.,-0.2));
#14177 = VECTOR('',#14178,1.);
#14178 = DIRECTION('',(1.,0.));
#14179 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14180 = PCURVE('',#13943,#14181);
#14181 = DEFINITIONAL_REPRESENTATION('',(#14182),#14186);
#14182 = LINE('',#14183,#14184);
#14183 = CARTESIAN_POINT('',(0.978388445194,-0.895283004459));
#14184 = VECTOR('',#14185,1.);
#14185 = DIRECTION('',(-0.33596345631,0.941875021446));
#14186 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14187 = ORIENTED_EDGE('',*,*,#14188,.F.);
#14188 = EDGE_CURVE('',#14189,#14166,#14191,.T.);
#14189 = VERTEX_POINT('',#14190);
#14190 = CARTESIAN_POINT('',(0.64,-13.477,8.));
#14191 = SURFACE_CURVE('',#14192,(#14196,#14203),.PCURVE_S1.);
#14192 = LINE('',#14193,#14194);
#14193 = CARTESIAN_POINT('',(0.64,-13.477,8.));
#14194 = VECTOR('',#14195,1.);
#14195 = DIRECTION('',(0.,0.,1.));
#14196 = PCURVE('',#14128,#14197);
#14197 = DEFINITIONAL_REPRESENTATION('',(#14198),#14202);
#14198 = LINE('',#14199,#14200);
#14199 = CARTESIAN_POINT('',(2.378234849631,0.));
#14200 = VECTOR('',#14201,1.);
#14201 = DIRECTION('',(0.,-1.));
#14202 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14203 = PCURVE('',#14204,#14209);
#14204 = PLANE('',#14205);
#14205 = AXIS2_PLACEMENT_3D('',#14206,#14207,#14208);
#14206 = CARTESIAN_POINT('',(0.64,-13.477,8.));
#14207 = DIRECTION('',(1.,-2.2E-16,0.));
#14208 = DIRECTION('',(-2.2E-16,-1.,0.));
#14209 = DEFINITIONAL_REPRESENTATION('',(#14210),#14214);
#14210 = LINE('',#14211,#14212);
#14211 = CARTESIAN_POINT('',(0.,0.));
#14212 = VECTOR('',#14213,1.);
#14213 = DIRECTION('',(0.,-1.));
#14214 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14215 = ORIENTED_EDGE('',*,*,#14216,.F.);
#14216 = EDGE_CURVE('',#14113,#14189,#14217,.T.);
#14217 = SURFACE_CURVE('',#14218,(#14222,#14229),.PCURVE_S1.);
#14218 = LINE('',#14219,#14220);
#14219 = CARTESIAN_POINT('',(-1.6,-12.678,8.));
#14220 = VECTOR('',#14221,1.);
#14221 = DIRECTION('',(0.941875021446,-0.33596345631,0.));
#14222 = PCURVE('',#14128,#14223);
#14223 = DEFINITIONAL_REPRESENTATION('',(#14224),#14228);
#14224 = LINE('',#14225,#14226);
#14225 = CARTESIAN_POINT('',(0.,0.));
#14226 = VECTOR('',#14227,1.);
#14227 = DIRECTION('',(1.,0.));
#14228 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14229 = PCURVE('',#13997,#14230);
#14230 = DEFINITIONAL_REPRESENTATION('',(#14231),#14235);
#14231 = LINE('',#14232,#14233);
#14232 = CARTESIAN_POINT('',(0.978388445194,-0.895283004459));
#14233 = VECTOR('',#14234,1.);
#14234 = DIRECTION('',(-0.33596345631,0.941875021446));
#14235 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14236 = ADVANCED_FACE('',(#14237),#14204,.T.);
#14237 = FACE_BOUND('',#14238,.T.);
#14238 = EDGE_LOOP('',(#14239,#14240,#14263,#14291));
#14239 = ORIENTED_EDGE('',*,*,#14188,.T.);
#14240 = ORIENTED_EDGE('',*,*,#14241,.T.);
#14241 = EDGE_CURVE('',#14166,#14242,#14244,.T.);
#14242 = VERTEX_POINT('',#14243);
#14243 = CARTESIAN_POINT('',(0.64,-13.845,8.2));
#14244 = SURFACE_CURVE('',#14245,(#14249,#14256),.PCURVE_S1.);
#14245 = LINE('',#14246,#14247);
#14246 = CARTESIAN_POINT('',(0.64,-13.477,8.2));
#14247 = VECTOR('',#14248,1.);
#14248 = DIRECTION('',(0.,-1.,0.));
#14249 = PCURVE('',#14204,#14250);
#14250 = DEFINITIONAL_REPRESENTATION('',(#14251),#14255);
#14251 = LINE('',#14252,#14253);
#14252 = CARTESIAN_POINT('',(0.,-0.2));
#14253 = VECTOR('',#14254,1.);
#14254 = DIRECTION('',(1.,-0.));
#14255 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14256 = PCURVE('',#13943,#14257);
#14257 = DEFINITIONAL_REPRESENTATION('',(#14258),#14262);
#14258 = LINE('',#14259,#14260);
#14259 = CARTESIAN_POINT('',(0.179388445194,1.344716995541));
#14260 = VECTOR('',#14261,1.);
#14261 = DIRECTION('',(-1.,0.));
#14262 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14263 = ORIENTED_EDGE('',*,*,#14264,.F.);
#14264 = EDGE_CURVE('',#14265,#14242,#14267,.T.);
#14265 = VERTEX_POINT('',#14266);
#14266 = CARTESIAN_POINT('',(0.64,-13.845,8.));
#14267 = SURFACE_CURVE('',#14268,(#14272,#14279),.PCURVE_S1.);
#14268 = LINE('',#14269,#14270);
#14269 = CARTESIAN_POINT('',(0.64,-13.845,8.));
#14270 = VECTOR('',#14271,1.);
#14271 = DIRECTION('',(0.,0.,1.));
#14272 = PCURVE('',#14204,#14273);
#14273 = DEFINITIONAL_REPRESENTATION('',(#14274),#14278);
#14274 = LINE('',#14275,#14276);
#14275 = CARTESIAN_POINT('',(0.368,-0.));
#14276 = VECTOR('',#14277,1.);
#14277 = DIRECTION('',(0.,-1.));
#14278 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14279 = PCURVE('',#14280,#14285);
#14280 = PLANE('',#14281);
#14281 = AXIS2_PLACEMENT_3D('',#14282,#14283,#14284);
#14282 = CARTESIAN_POINT('',(0.64,-13.845,8.));
#14283 = DIRECTION('',(0.331475862355,-0.943463699713,0.));
#14284 = DIRECTION('',(-0.943463699713,-0.331475862355,0.));
#14285 = DEFINITIONAL_REPRESENTATION('',(#14286),#14290);
#14286 = LINE('',#14287,#14288);
#14287 = CARTESIAN_POINT('',(0.,0.));
#14288 = VECTOR('',#14289,1.);
#14289 = DIRECTION('',(0.,-1.));
#14290 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14291 = ORIENTED_EDGE('',*,*,#14292,.F.);
#14292 = EDGE_CURVE('',#14189,#14265,#14293,.T.);
#14293 = SURFACE_CURVE('',#14294,(#14298,#14305),.PCURVE_S1.);
#14294 = LINE('',#14295,#14296);
#14295 = CARTESIAN_POINT('',(0.64,-13.477,8.));
#14296 = VECTOR('',#14297,1.);
#14297 = DIRECTION('',(0.,-1.,0.));
#14298 = PCURVE('',#14204,#14299);
#14299 = DEFINITIONAL_REPRESENTATION('',(#14300),#14304);
#14300 = LINE('',#14301,#14302);
#14301 = CARTESIAN_POINT('',(0.,0.));
#14302 = VECTOR('',#14303,1.);
#14303 = DIRECTION('',(1.,-0.));
#14304 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14305 = PCURVE('',#13997,#14306);
#14306 = DEFINITIONAL_REPRESENTATION('',(#14307),#14311);
#14307 = LINE('',#14308,#14309);
#14308 = CARTESIAN_POINT('',(0.179388445194,1.344716995541));
#14309 = VECTOR('',#14310,1.);
#14310 = DIRECTION('',(-1.,0.));
#14311 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14312 = ADVANCED_FACE('',(#14313),#14280,.T.);
#14313 = FACE_BOUND('',#14314,.T.);
#14314 = EDGE_LOOP('',(#14315,#14316,#14339,#14367));
#14315 = ORIENTED_EDGE('',*,*,#14264,.T.);
#14316 = ORIENTED_EDGE('',*,*,#14317,.T.);
#14317 = EDGE_CURVE('',#14242,#14318,#14320,.T.);
#14318 = VERTEX_POINT('',#14319);
#14319 = CARTESIAN_POINT('',(-1.6,-14.632,8.2));
#14320 = SURFACE_CURVE('',#14321,(#14325,#14332),.PCURVE_S1.);
#14321 = LINE('',#14322,#14323);
#14322 = CARTESIAN_POINT('',(0.64,-13.845,8.2));
#14323 = VECTOR('',#14324,1.);
#14324 = DIRECTION('',(-0.943463699713,-0.331475862355,0.));
#14325 = PCURVE('',#14280,#14326);
#14326 = DEFINITIONAL_REPRESENTATION('',(#14327),#14331);
#14327 = LINE('',#14328,#14329);
#14328 = CARTESIAN_POINT('',(0.,-0.2));
#14329 = VECTOR('',#14330,1.);
#14330 = DIRECTION('',(1.,-0.));
#14331 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14332 = PCURVE('',#13943,#14333);
#14333 = DEFINITIONAL_REPRESENTATION('',(#14334),#14338);
#14334 = LINE('',#14335,#14336);
#14335 = CARTESIAN_POINT('',(-0.188611554806,1.344716995541));
#14336 = VECTOR('',#14337,1.);
#14337 = DIRECTION('',(-0.331475862355,-0.943463699713));
#14338 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14339 = ORIENTED_EDGE('',*,*,#14340,.F.);
#14340 = EDGE_CURVE('',#14341,#14318,#14343,.T.);
#14341 = VERTEX_POINT('',#14342);
#14342 = CARTESIAN_POINT('',(-1.6,-14.632,8.));
#14343 = SURFACE_CURVE('',#14344,(#14348,#14355),.PCURVE_S1.);
#14344 = LINE('',#14345,#14346);
#14345 = CARTESIAN_POINT('',(-1.6,-14.632,8.));
#14346 = VECTOR('',#14347,1.);
#14347 = DIRECTION('',(0.,0.,1.));
#14348 = PCURVE('',#14280,#14349);
#14349 = DEFINITIONAL_REPRESENTATION('',(#14350),#14354);
#14350 = LINE('',#14351,#14352);
#14351 = CARTESIAN_POINT('',(2.37423019103,-0.));
#14352 = VECTOR('',#14353,1.);
#14353 = DIRECTION('',(0.,-1.));
#14354 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14355 = PCURVE('',#14356,#14361);
#14356 = PLANE('',#14357);
#14357 = AXIS2_PLACEMENT_3D('',#14358,#14359,#14360);
#14358 = CARTESIAN_POINT('',(-1.6,-14.632,8.));
#14359 = DIRECTION('',(-1.,2.2E-16,0.));
#14360 = DIRECTION('',(2.2E-16,1.,0.));
#14361 = DEFINITIONAL_REPRESENTATION('',(#14362),#14366);
#14362 = LINE('',#14363,#14364);
#14363 = CARTESIAN_POINT('',(0.,0.));
#14364 = VECTOR('',#14365,1.);
#14365 = DIRECTION('',(0.,-1.));
#14366 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14367 = ORIENTED_EDGE('',*,*,#14368,.F.);
#14368 = EDGE_CURVE('',#14265,#14341,#14369,.T.);
#14369 = SURFACE_CURVE('',#14370,(#14374,#14381),.PCURVE_S1.);
#14370 = LINE('',#14371,#14372);
#14371 = CARTESIAN_POINT('',(0.64,-13.845,8.));
#14372 = VECTOR('',#14373,1.);
#14373 = DIRECTION('',(-0.943463699713,-0.331475862355,0.));
#14374 = PCURVE('',#14280,#14375);
#14375 = DEFINITIONAL_REPRESENTATION('',(#14376),#14380);
#14376 = LINE('',#14377,#14378);
#14377 = CARTESIAN_POINT('',(0.,0.));
#14378 = VECTOR('',#14379,1.);
#14379 = DIRECTION('',(1.,-0.));
#14380 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14381 = PCURVE('',#13997,#14382);
#14382 = DEFINITIONAL_REPRESENTATION('',(#14383),#14387);
#14383 = LINE('',#14384,#14385);
#14384 = CARTESIAN_POINT('',(-0.188611554806,1.344716995541));
#14385 = VECTOR('',#14386,1.);
#14386 = DIRECTION('',(-0.331475862355,-0.943463699713));
#14387 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14388 = ADVANCED_FACE('',(#14389),#14356,.T.);
#14389 = FACE_BOUND('',#14390,.T.);
#14390 = EDGE_LOOP('',(#14391,#14392,#14415,#14438));
#14391 = ORIENTED_EDGE('',*,*,#14340,.T.);
#14392 = ORIENTED_EDGE('',*,*,#14393,.T.);
#14393 = EDGE_CURVE('',#14318,#14394,#14396,.T.);
#14394 = VERTEX_POINT('',#14395);
#14395 = CARTESIAN_POINT('',(-1.6,-14.312,8.2));
#14396 = SURFACE_CURVE('',#14397,(#14401,#14408),.PCURVE_S1.);
#14397 = LINE('',#14398,#14399);
#14398 = CARTESIAN_POINT('',(-1.6,-14.632,8.2));
#14399 = VECTOR('',#14400,1.);
#14400 = DIRECTION('',(0.,1.,0.));
#14401 = PCURVE('',#14356,#14402);
#14402 = DEFINITIONAL_REPRESENTATION('',(#14403),#14407);
#14403 = LINE('',#14404,#14405);
#14404 = CARTESIAN_POINT('',(0.,-0.2));
#14405 = VECTOR('',#14406,1.);
#14406 = DIRECTION('',(1.,0.));
#14407 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14408 = PCURVE('',#13943,#14409);
#14409 = DEFINITIONAL_REPRESENTATION('',(#14410),#14414);
#14410 = LINE('',#14411,#14412);
#14411 = CARTESIAN_POINT('',(-0.975611554806,-0.895283004459));
#14412 = VECTOR('',#14413,1.);
#14413 = DIRECTION('',(1.,0.));
#14414 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14415 = ORIENTED_EDGE('',*,*,#14416,.F.);
#14416 = EDGE_CURVE('',#14417,#14394,#14419,.T.);
#14417 = VERTEX_POINT('',#14418);
#14418 = CARTESIAN_POINT('',(-1.6,-14.312,8.));
#14419 = SURFACE_CURVE('',#14420,(#14424,#14431),.PCURVE_S1.);
#14420 = LINE('',#14421,#14422);
#14421 = CARTESIAN_POINT('',(-1.6,-14.312,8.));
#14422 = VECTOR('',#14423,1.);
#14423 = DIRECTION('',(0.,0.,1.));
#14424 = PCURVE('',#14356,#14425);
#14425 = DEFINITIONAL_REPRESENTATION('',(#14426),#14430);
#14426 = LINE('',#14427,#14428);
#14427 = CARTESIAN_POINT('',(0.32,0.));
#14428 = VECTOR('',#14429,1.);
#14429 = DIRECTION('',(0.,-1.));
#14430 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14431 = PCURVE('',#13915,#14432);
#14432 = DEFINITIONAL_REPRESENTATION('',(#14433),#14437);
#14433 = LINE('',#14434,#14435);
#14434 = CARTESIAN_POINT('',(3.11E-15,0.));
#14435 = VECTOR('',#14436,1.);
#14436 = DIRECTION('',(0.,-1.));
#14437 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14438 = ORIENTED_EDGE('',*,*,#14439,.F.);
#14439 = EDGE_CURVE('',#14341,#14417,#14440,.T.);
#14440 = SURFACE_CURVE('',#14441,(#14445,#14452),.PCURVE_S1.);
#14441 = LINE('',#14442,#14443);
#14442 = CARTESIAN_POINT('',(-1.6,-14.632,8.));
#14443 = VECTOR('',#14444,1.);
#14444 = DIRECTION('',(0.,1.,0.));
#14445 = PCURVE('',#14356,#14446);
#14446 = DEFINITIONAL_REPRESENTATION('',(#14447),#14451);
#14447 = LINE('',#14448,#14449);
#14448 = CARTESIAN_POINT('',(0.,0.));
#14449 = VECTOR('',#14450,1.);
#14450 = DIRECTION('',(1.,0.));
#14451 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14452 = PCURVE('',#13997,#14453);
#14453 = DEFINITIONAL_REPRESENTATION('',(#14454),#14458);
#14454 = LINE('',#14455,#14456);
#14455 = CARTESIAN_POINT('',(-0.975611554806,-0.895283004459));
#14456 = VECTOR('',#14457,1.);
#14457 = DIRECTION('',(1.,0.));
#14458 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14459 = ADVANCED_FACE('',(#14460),#13915,.T.);
#14460 = FACE_BOUND('',#14461,.T.);
#14461 = EDGE_LOOP('',(#14462,#14463,#14484,#14485));
#14462 = ORIENTED_EDGE('',*,*,#14416,.T.);
#14463 = ORIENTED_EDGE('',*,*,#14464,.T.);
#14464 = EDGE_CURVE('',#14394,#13895,#14465,.T.);
#14465 = SURFACE_CURVE('',#14466,(#14470,#14477),.PCURVE_S1.);
#14466 = LINE('',#14467,#14468);
#14467 = CARTESIAN_POINT('',(-1.6,-14.312,8.2));
#14468 = VECTOR('',#14469,1.);
#14469 = DIRECTION('',(0.94107471628,0.338198726163,0.));
#14470 = PCURVE('',#13915,#14471);
#14471 = DEFINITIONAL_REPRESENTATION('',(#14472),#14476);
#14472 = LINE('',#14473,#14474);
#14473 = CARTESIAN_POINT('',(0.,-0.2));
#14474 = VECTOR('',#14475,1.);
#14475 = DIRECTION('',(1.,0.));
#14476 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14477 = PCURVE('',#13943,#14478);
#14478 = DEFINITIONAL_REPRESENTATION('',(#14479),#14483);
#14479 = LINE('',#14480,#14481);
#14480 = CARTESIAN_POINT('',(-0.655611554806,-0.895283004459));
#14481 = VECTOR('',#14482,1.);
#14482 = DIRECTION('',(0.338198726163,0.94107471628));
#14483 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14484 = ORIENTED_EDGE('',*,*,#13892,.F.);
#14485 = ORIENTED_EDGE('',*,*,#14486,.F.);
#14486 = EDGE_CURVE('',#14417,#13893,#14487,.T.);
#14487 = SURFACE_CURVE('',#14488,(#14492,#14499),.PCURVE_S1.);
#14488 = LINE('',#14489,#14490);
#14489 = CARTESIAN_POINT('',(-1.6,-14.312,8.));
#14490 = VECTOR('',#14491,1.);
#14491 = DIRECTION('',(0.94107471628,0.338198726163,0.));
#14492 = PCURVE('',#13915,#14493);
#14493 = DEFINITIONAL_REPRESENTATION('',(#14494),#14498);
#14494 = LINE('',#14495,#14496);
#14495 = CARTESIAN_POINT('',(0.,0.));
#14496 = VECTOR('',#14497,1.);
#14497 = DIRECTION('',(1.,0.));
#14498 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14499 = PCURVE('',#13997,#14500);
#14500 = DEFINITIONAL_REPRESENTATION('',(#14501),#14505);
#14501 = LINE('',#14502,#14503);
#14502 = CARTESIAN_POINT('',(-0.655611554806,-0.895283004459));
#14503 = VECTOR('',#14504,1.);
#14504 = DIRECTION('',(0.338198726163,0.94107471628));
#14505 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14506 = ADVANCED_FACE('',(#14507),#14521,.T.);
#14507 = FACE_BOUND('',#14508,.T.);
#14508 = EDGE_LOOP('',(#14509,#14544,#14567,#14595));
#14509 = ORIENTED_EDGE('',*,*,#14510,.T.);
#14510 = EDGE_CURVE('',#14511,#14513,#14515,.T.);
#14511 = VERTEX_POINT('',#14512);
#14512 = CARTESIAN_POINT('',(-0.704,-14.002,8.));
#14513 = VERTEX_POINT('',#14514);
#14514 = CARTESIAN_POINT('',(-0.704,-14.002,8.2));
#14515 = SURFACE_CURVE('',#14516,(#14520,#14532),.PCURVE_S1.);
#14516 = LINE('',#14517,#14518);
#14517 = CARTESIAN_POINT('',(-0.704,-14.002,8.));
#14518 = VECTOR('',#14519,1.);
#14519 = DIRECTION('',(0.,0.,1.));
#14520 = PCURVE('',#14521,#14526);
#14521 = PLANE('',#14522);
#14522 = AXIS2_PLACEMENT_3D('',#14523,#14524,#14525);
#14523 = CARTESIAN_POINT('',(-0.704,-14.002,8.));
#14524 = DIRECTION('',(-0.315952212958,0.94877510461,0.));
#14525 = DIRECTION('',(0.94877510461,0.315952212958,0.));
#14526 = DEFINITIONAL_REPRESENTATION('',(#14527),#14531);
#14527 = LINE('',#14528,#14529);
#14528 = CARTESIAN_POINT('',(1.1E-16,0.));
#14529 = VECTOR('',#14530,1.);
#14530 = DIRECTION('',(0.,-1.));
#14531 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14532 = PCURVE('',#14533,#14538);
#14533 = PLANE('',#14534);
#14534 = AXIS2_PLACEMENT_3D('',#14535,#14536,#14537);
#14535 = CARTESIAN_POINT('',(-0.704,-13.289,8.));
#14536 = DIRECTION('',(1.,-2.2E-16,0.));
#14537 = DIRECTION('',(-2.2E-16,-1.,0.));
#14538 = DEFINITIONAL_REPRESENTATION('',(#14539),#14543);
#14539 = LINE('',#14540,#14541);
#14540 = CARTESIAN_POINT('',(0.713,-0.));
#14541 = VECTOR('',#14542,1.);
#14542 = DIRECTION('',(0.,-1.));
#14543 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14544 = ORIENTED_EDGE('',*,*,#14545,.T.);
#14545 = EDGE_CURVE('',#14513,#14546,#14548,.T.);
#14546 = VERTEX_POINT('',#14547);
#14547 = CARTESIAN_POINT('',(0.329,-13.658,8.2));
#14548 = SURFACE_CURVE('',#14549,(#14553,#14560),.PCURVE_S1.);
#14549 = LINE('',#14550,#14551);
#14550 = CARTESIAN_POINT('',(-0.704,-14.002,8.2));
#14551 = VECTOR('',#14552,1.);
#14552 = DIRECTION('',(0.94877510461,0.315952212958,0.));
#14553 = PCURVE('',#14521,#14554);
#14554 = DEFINITIONAL_REPRESENTATION('',(#14555),#14559);
#14555 = LINE('',#14556,#14557);
#14556 = CARTESIAN_POINT('',(0.,-0.2));
#14557 = VECTOR('',#14558,1.);
#14558 = DIRECTION('',(1.,0.));
#14559 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14560 = PCURVE('',#13943,#14561);
#14561 = DEFINITIONAL_REPRESENTATION('',(#14562),#14566);
#14562 = LINE('',#14563,#14564);
#14563 = CARTESIAN_POINT('',(-0.345611554806,7.169955411367E-04));
#14564 = VECTOR('',#14565,1.);
#14565 = DIRECTION('',(0.315952212958,0.94877510461));
#14566 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14567 = ORIENTED_EDGE('',*,*,#14568,.F.);
#14568 = EDGE_CURVE('',#14569,#14546,#14571,.T.);
#14569 = VERTEX_POINT('',#14570);
#14570 = CARTESIAN_POINT('',(0.329,-13.658,8.));
#14571 = SURFACE_CURVE('',#14572,(#14576,#14583),.PCURVE_S1.);
#14572 = LINE('',#14573,#14574);
#14573 = CARTESIAN_POINT('',(0.329,-13.658,8.));
#14574 = VECTOR('',#14575,1.);
#14575 = DIRECTION('',(0.,0.,1.));
#14576 = PCURVE('',#14521,#14577);
#14577 = DEFINITIONAL_REPRESENTATION('',(#14578),#14582);
#14578 = LINE('',#14579,#14580);
#14579 = CARTESIAN_POINT('',(1.088772244319,0.));
#14580 = VECTOR('',#14581,1.);
#14581 = DIRECTION('',(0.,-1.));
#14582 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14583 = PCURVE('',#14584,#14589);
#14584 = PLANE('',#14585);
#14585 = AXIS2_PLACEMENT_3D('',#14586,#14587,#14588);
#14586 = CARTESIAN_POINT('',(0.329,-13.658,8.));
#14587 = DIRECTION('',(-0.336394147142,-0.941721284547,0.));
#14588 = DIRECTION('',(-0.941721284547,0.336394147142,0.));
#14589 = DEFINITIONAL_REPRESENTATION('',(#14590),#14594);
#14590 = LINE('',#14591,#14592);
#14591 = CARTESIAN_POINT('',(5.E-17,0.));
#14592 = VECTOR('',#14593,1.);
#14593 = DIRECTION('',(0.,-1.));
#14594 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14595 = ORIENTED_EDGE('',*,*,#14596,.F.);
#14596 = EDGE_CURVE('',#14511,#14569,#14597,.T.);
#14597 = SURFACE_CURVE('',#14598,(#14602,#14609),.PCURVE_S1.);
#14598 = LINE('',#14599,#14600);
#14599 = CARTESIAN_POINT('',(-0.704,-14.002,8.));
#14600 = VECTOR('',#14601,1.);
#14601 = DIRECTION('',(0.94877510461,0.315952212958,0.));
#14602 = PCURVE('',#14521,#14603);
#14603 = DEFINITIONAL_REPRESENTATION('',(#14604),#14608);
#14604 = LINE('',#14605,#14606);
#14605 = CARTESIAN_POINT('',(0.,0.));
#14606 = VECTOR('',#14607,1.);
#14607 = DIRECTION('',(1.,0.));
#14608 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14609 = PCURVE('',#13997,#14610);
#14610 = DEFINITIONAL_REPRESENTATION('',(#14611),#14615);
#14611 = LINE('',#14612,#14613);
#14612 = CARTESIAN_POINT('',(-0.345611554806,7.169955411367E-04));
#14613 = VECTOR('',#14614,1.);
#14614 = DIRECTION('',(0.315952212958,0.94877510461));
#14615 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14616 = ADVANCED_FACE('',(#14617),#14584,.T.);
#14617 = FACE_BOUND('',#14618,.T.);
#14618 = EDGE_LOOP('',(#14619,#14620,#14643,#14666));
#14619 = ORIENTED_EDGE('',*,*,#14568,.T.);
#14620 = ORIENTED_EDGE('',*,*,#14621,.T.);
#14621 = EDGE_CURVE('',#14546,#14622,#14624,.T.);
#14622 = VERTEX_POINT('',#14623);
#14623 = CARTESIAN_POINT('',(-0.704,-13.289,8.2));
#14624 = SURFACE_CURVE('',#14625,(#14629,#14636),.PCURVE_S1.);
#14625 = LINE('',#14626,#14627);
#14626 = CARTESIAN_POINT('',(0.329,-13.658,8.2));
#14627 = VECTOR('',#14628,1.);
#14628 = DIRECTION('',(-0.941721284547,0.336394147142,0.));
#14629 = PCURVE('',#14584,#14630);
#14630 = DEFINITIONAL_REPRESENTATION('',(#14631),#14635);
#14631 = LINE('',#14632,#14633);
#14632 = CARTESIAN_POINT('',(0.,-0.2));
#14633 = VECTOR('',#14634,1.);
#14634 = DIRECTION('',(1.,0.));
#14635 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14636 = PCURVE('',#13943,#14637);
#14637 = DEFINITIONAL_REPRESENTATION('',(#14638),#14642);
#14638 = LINE('',#14639,#14640);
#14639 = CARTESIAN_POINT('',(-1.611554805915E-03,1.033716995541));
#14640 = VECTOR('',#14641,1.);
#14641 = DIRECTION('',(0.336394147142,-0.941721284547));
#14642 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14643 = ORIENTED_EDGE('',*,*,#14644,.F.);
#14644 = EDGE_CURVE('',#14645,#14622,#14647,.T.);
#14645 = VERTEX_POINT('',#14646);
#14646 = CARTESIAN_POINT('',(-0.704,-13.289,8.));
#14647 = SURFACE_CURVE('',#14648,(#14652,#14659),.PCURVE_S1.);
#14648 = LINE('',#14649,#14650);
#14649 = CARTESIAN_POINT('',(-0.704,-13.289,8.));
#14650 = VECTOR('',#14651,1.);
#14651 = DIRECTION('',(0.,0.,1.));
#14652 = PCURVE('',#14584,#14653);
#14653 = DEFINITIONAL_REPRESENTATION('',(#14654),#14658);
#14654 = LINE('',#14655,#14656);
#14655 = CARTESIAN_POINT('',(1.096927527232,0.));
#14656 = VECTOR('',#14657,1.);
#14657 = DIRECTION('',(0.,-1.));
#14658 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14659 = PCURVE('',#14533,#14660);
#14660 = DEFINITIONAL_REPRESENTATION('',(#14661),#14665);
#14661 = LINE('',#14662,#14663);
#14662 = CARTESIAN_POINT('',(0.,0.));
#14663 = VECTOR('',#14664,1.);
#14664 = DIRECTION('',(0.,-1.));
#14665 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14666 = ORIENTED_EDGE('',*,*,#14667,.F.);
#14667 = EDGE_CURVE('',#14569,#14645,#14668,.T.);
#14668 = SURFACE_CURVE('',#14669,(#14673,#14680),.PCURVE_S1.);
#14669 = LINE('',#14670,#14671);
#14670 = CARTESIAN_POINT('',(0.329,-13.658,8.));
#14671 = VECTOR('',#14672,1.);
#14672 = DIRECTION('',(-0.941721284547,0.336394147142,0.));
#14673 = PCURVE('',#14584,#14674);
#14674 = DEFINITIONAL_REPRESENTATION('',(#14675),#14679);
#14675 = LINE('',#14676,#14677);
#14676 = CARTESIAN_POINT('',(0.,0.));
#14677 = VECTOR('',#14678,1.);
#14678 = DIRECTION('',(1.,0.));
#14679 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14680 = PCURVE('',#13997,#14681);
#14681 = DEFINITIONAL_REPRESENTATION('',(#14682),#14686);
#14682 = LINE('',#14683,#14684);
#14683 = CARTESIAN_POINT('',(-1.611554805915E-03,1.033716995541));
#14684 = VECTOR('',#14685,1.);
#14685 = DIRECTION('',(0.336394147142,-0.941721284547));
#14686 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14687 = ADVANCED_FACE('',(#14688),#14533,.T.);
#14688 = FACE_BOUND('',#14689,.T.);
#14689 = EDGE_LOOP('',(#14690,#14691,#14712,#14713));
#14690 = ORIENTED_EDGE('',*,*,#14644,.T.);
#14691 = ORIENTED_EDGE('',*,*,#14692,.T.);
#14692 = EDGE_CURVE('',#14622,#14513,#14693,.T.);
#14693 = SURFACE_CURVE('',#14694,(#14698,#14705),.PCURVE_S1.);
#14694 = LINE('',#14695,#14696);
#14695 = CARTESIAN_POINT('',(-0.704,-13.289,8.2));
#14696 = VECTOR('',#14697,1.);
#14697 = DIRECTION('',(0.,-1.,0.));
#14698 = PCURVE('',#14533,#14699);
#14699 = DEFINITIONAL_REPRESENTATION('',(#14700),#14704);
#14700 = LINE('',#14701,#14702);
#14701 = CARTESIAN_POINT('',(0.,-0.2));
#14702 = VECTOR('',#14703,1.);
#14703 = DIRECTION('',(1.,-0.));
#14704 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14705 = PCURVE('',#13943,#14706);
#14706 = DEFINITIONAL_REPRESENTATION('',(#14707),#14711);
#14707 = LINE('',#14708,#14709);
#14708 = CARTESIAN_POINT('',(0.367388445194,7.169955411367E-04));
#14709 = VECTOR('',#14710,1.);
#14710 = DIRECTION('',(-1.,0.));
#14711 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14712 = ORIENTED_EDGE('',*,*,#14510,.F.);
#14713 = ORIENTED_EDGE('',*,*,#14714,.F.);
#14714 = EDGE_CURVE('',#14645,#14511,#14715,.T.);
#14715 = SURFACE_CURVE('',#14716,(#14720,#14727),.PCURVE_S1.);
#14716 = LINE('',#14717,#14718);
#14717 = CARTESIAN_POINT('',(-0.704,-13.289,8.));
#14718 = VECTOR('',#14719,1.);
#14719 = DIRECTION('',(0.,-1.,0.));
#14720 = PCURVE('',#14533,#14721);
#14721 = DEFINITIONAL_REPRESENTATION('',(#14722),#14726);
#14722 = LINE('',#14723,#14724);
#14723 = CARTESIAN_POINT('',(0.,0.));
#14724 = VECTOR('',#14725,1.);
#14725 = DIRECTION('',(1.,-0.));
#14726 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14727 = PCURVE('',#13997,#14728);
#14728 = DEFINITIONAL_REPRESENTATION('',(#14729),#14733);
#14729 = LINE('',#14730,#14731);
#14730 = CARTESIAN_POINT('',(0.367388445194,7.169955411367E-04));
#14731 = VECTOR('',#14732,1.);
#14732 = DIRECTION('',(-1.,0.));
#14733 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14734 = ADVANCED_FACE('',(#14735,#14745),#13997,.T.);
#14735 = FACE_BOUND('',#14736,.T.);
#14736 = EDGE_LOOP('',(#14737,#14738,#14739,#14740,#14741,#14742,#14743,
#14744));
#14737 = ORIENTED_EDGE('',*,*,#13983,.T.);
#14738 = ORIENTED_EDGE('',*,*,#14064,.T.);
#14739 = ORIENTED_EDGE('',*,*,#14140,.T.);
#14740 = ORIENTED_EDGE('',*,*,#14216,.T.);
#14741 = ORIENTED_EDGE('',*,*,#14292,.T.);
#14742 = ORIENTED_EDGE('',*,*,#14368,.T.);
#14743 = ORIENTED_EDGE('',*,*,#14439,.T.);
#14744 = ORIENTED_EDGE('',*,*,#14486,.T.);
#14745 = FACE_BOUND('',#14746,.T.);
#14746 = EDGE_LOOP('',(#14747,#14748,#14749));
#14747 = ORIENTED_EDGE('',*,*,#14596,.T.);
#14748 = ORIENTED_EDGE('',*,*,#14667,.T.);
#14749 = ORIENTED_EDGE('',*,*,#14714,.T.);
#14750 = ADVANCED_FACE('',(#14751,#14761),#13943,.F.);
#14751 = FACE_BOUND('',#14752,.F.);
#14752 = EDGE_LOOP('',(#14753,#14754,#14755,#14756,#14757,#14758,#14759,
#14760));
#14753 = ORIENTED_EDGE('',*,*,#13927,.T.);
#14754 = ORIENTED_EDGE('',*,*,#14013,.T.);
#14755 = ORIENTED_EDGE('',*,*,#14089,.T.);
#14756 = ORIENTED_EDGE('',*,*,#14165,.T.);
#14757 = ORIENTED_EDGE('',*,*,#14241,.T.);
#14758 = ORIENTED_EDGE('',*,*,#14317,.T.);
#14759 = ORIENTED_EDGE('',*,*,#14393,.T.);
#14760 = ORIENTED_EDGE('',*,*,#14464,.T.);
#14761 = FACE_BOUND('',#14762,.F.);
#14762 = EDGE_LOOP('',(#14763,#14764,#14765));
#14763 = ORIENTED_EDGE('',*,*,#14545,.T.);
#14764 = ORIENTED_EDGE('',*,*,#14621,.T.);
#14765 = ORIENTED_EDGE('',*,*,#14692,.T.);
#14766 = MANIFOLD_SOLID_BREP('',#14767);
#14767 = CLOSED_SHELL('',(#14768,#14888,#14964,#15035,#15082,#15089));
#14768 = ADVANCED_FACE('',(#14769),#14783,.T.);
#14769 = FACE_BOUND('',#14770,.T.);
#14770 = EDGE_LOOP('',(#14771,#14806,#14834,#14862));
#14771 = ORIENTED_EDGE('',*,*,#14772,.T.);
#14772 = EDGE_CURVE('',#14773,#14775,#14777,.T.);
#14773 = VERTEX_POINT('',#14774);
#14774 = CARTESIAN_POINT('',(-1.28,-15.245,8.));
#14775 = VERTEX_POINT('',#14776);
#14776 = CARTESIAN_POINT('',(-1.28,-15.245,8.2));
#14777 = SURFACE_CURVE('',#14778,(#14782,#14794),.PCURVE_S1.);
#14778 = LINE('',#14779,#14780);
#14779 = CARTESIAN_POINT('',(-1.28,-15.245,8.));
#14780 = VECTOR('',#14781,1.);
#14781 = DIRECTION('',(0.,0.,1.));
#14782 = PCURVE('',#14783,#14788);
#14783 = PLANE('',#14784);
#14784 = AXIS2_PLACEMENT_3D('',#14785,#14786,#14787);
#14785 = CARTESIAN_POINT('',(-1.28,-15.245,8.));
#14786 = DIRECTION('',(-2.2E-16,-1.,0.));
#14787 = DIRECTION('',(-1.,2.2E-16,0.));
#14788 = DEFINITIONAL_REPRESENTATION('',(#14789),#14793);
#14789 = LINE('',#14790,#14791);
#14790 = CARTESIAN_POINT('',(-3.33E-15,0.));
#14791 = VECTOR('',#14792,1.);
#14792 = DIRECTION('',(0.,-1.));
#14793 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14794 = PCURVE('',#14795,#14800);
#14795 = PLANE('',#14796);
#14796 = AXIS2_PLACEMENT_3D('',#14797,#14798,#14799);
#14797 = CARTESIAN_POINT('',(-1.28,-14.926,8.));
#14798 = DIRECTION('',(1.,-2.2E-16,0.));
#14799 = DIRECTION('',(-2.2E-16,-1.,0.));
#14800 = DEFINITIONAL_REPRESENTATION('',(#14801),#14805);
#14801 = LINE('',#14802,#14803);
#14802 = CARTESIAN_POINT('',(0.319,0.));
#14803 = VECTOR('',#14804,1.);
#14804 = DIRECTION('',(0.,-1.));
#14805 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14806 = ORIENTED_EDGE('',*,*,#14807,.T.);
#14807 = EDGE_CURVE('',#14775,#14808,#14810,.T.);
#14808 = VERTEX_POINT('',#14809);
#14809 = CARTESIAN_POINT('',(-1.6,-15.245,8.2));
#14810 = SURFACE_CURVE('',#14811,(#14815,#14822),.PCURVE_S1.);
#14811 = LINE('',#14812,#14813);
#14812 = CARTESIAN_POINT('',(-1.28,-15.245,8.2));
#14813 = VECTOR('',#14814,1.);
#14814 = DIRECTION('',(-1.,0.,0.));
#14815 = PCURVE('',#14783,#14816);
#14816 = DEFINITIONAL_REPRESENTATION('',(#14817),#14821);
#14817 = LINE('',#14818,#14819);
#14818 = CARTESIAN_POINT('',(0.,-0.2));
#14819 = VECTOR('',#14820,1.);
#14820 = DIRECTION('',(1.,0.));
#14821 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14822 = PCURVE('',#14823,#14828);
#14823 = PLANE('',#14824);
#14824 = AXIS2_PLACEMENT_3D('',#14825,#14826,#14827);
#14825 = CARTESIAN_POINT('',(-1.44,-15.0855,8.2));
#14826 = DIRECTION('',(-0.,0.,-1.));
#14827 = DIRECTION('',(0.,1.,0.));
#14828 = DEFINITIONAL_REPRESENTATION('',(#14829),#14833);
#14829 = LINE('',#14830,#14831);
#14830 = CARTESIAN_POINT('',(-0.1595,0.16));
#14831 = VECTOR('',#14832,1.);
#14832 = DIRECTION('',(0.,-1.));
#14833 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14834 = ORIENTED_EDGE('',*,*,#14835,.F.);
#14835 = EDGE_CURVE('',#14836,#14808,#14838,.T.);
#14836 = VERTEX_POINT('',#14837);
#14837 = CARTESIAN_POINT('',(-1.6,-15.245,8.));
#14838 = SURFACE_CURVE('',#14839,(#14843,#14850),.PCURVE_S1.);
#14839 = LINE('',#14840,#14841);
#14840 = CARTESIAN_POINT('',(-1.6,-15.245,8.));
#14841 = VECTOR('',#14842,1.);
#14842 = DIRECTION('',(0.,0.,1.));
#14843 = PCURVE('',#14783,#14844);
#14844 = DEFINITIONAL_REPRESENTATION('',(#14845),#14849);
#14845 = LINE('',#14846,#14847);
#14846 = CARTESIAN_POINT('',(0.32,0.));
#14847 = VECTOR('',#14848,1.);
#14848 = DIRECTION('',(0.,-1.));
#14849 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14850 = PCURVE('',#14851,#14856);
#14851 = PLANE('',#14852);
#14852 = AXIS2_PLACEMENT_3D('',#14853,#14854,#14855);
#14853 = CARTESIAN_POINT('',(-1.6,-15.245,8.));
#14854 = DIRECTION('',(-1.,2.2E-16,0.));
#14855 = DIRECTION('',(2.2E-16,1.,0.));
#14856 = DEFINITIONAL_REPRESENTATION('',(#14857),#14861);
#14857 = LINE('',#14858,#14859);
#14858 = CARTESIAN_POINT('',(0.,0.));
#14859 = VECTOR('',#14860,1.);
#14860 = DIRECTION('',(0.,-1.));
#14861 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14862 = ORIENTED_EDGE('',*,*,#14863,.F.);
#14863 = EDGE_CURVE('',#14773,#14836,#14864,.T.);
#14864 = SURFACE_CURVE('',#14865,(#14869,#14876),.PCURVE_S1.);
#14865 = LINE('',#14866,#14867);
#14866 = CARTESIAN_POINT('',(-1.28,-15.245,8.));
#14867 = VECTOR('',#14868,1.);
#14868 = DIRECTION('',(-1.,0.,0.));
#14869 = PCURVE('',#14783,#14870);
#14870 = DEFINITIONAL_REPRESENTATION('',(#14871),#14875);
#14871 = LINE('',#14872,#14873);
#14872 = CARTESIAN_POINT('',(0.,0.));
#14873 = VECTOR('',#14874,1.);
#14874 = DIRECTION('',(1.,0.));
#14875 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14876 = PCURVE('',#14877,#14882);
#14877 = PLANE('',#14878);
#14878 = AXIS2_PLACEMENT_3D('',#14879,#14880,#14881);
#14879 = CARTESIAN_POINT('',(-1.44,-15.0855,8.));
#14880 = DIRECTION('',(-0.,0.,-1.));
#14881 = DIRECTION('',(0.,1.,0.));
#14882 = DEFINITIONAL_REPRESENTATION('',(#14883),#14887);
#14883 = LINE('',#14884,#14885);
#14884 = CARTESIAN_POINT('',(-0.1595,0.16));
#14885 = VECTOR('',#14886,1.);
#14886 = DIRECTION('',(0.,-1.));
#14887 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14888 = ADVANCED_FACE('',(#14889),#14851,.T.);
#14889 = FACE_BOUND('',#14890,.T.);
#14890 = EDGE_LOOP('',(#14891,#14892,#14915,#14943));
#14891 = ORIENTED_EDGE('',*,*,#14835,.T.);
#14892 = ORIENTED_EDGE('',*,*,#14893,.T.);
#14893 = EDGE_CURVE('',#14808,#14894,#14896,.T.);
#14894 = VERTEX_POINT('',#14895);
#14895 = CARTESIAN_POINT('',(-1.6,-14.926,8.2));
#14896 = SURFACE_CURVE('',#14897,(#14901,#14908),.PCURVE_S1.);
#14897 = LINE('',#14898,#14899);
#14898 = CARTESIAN_POINT('',(-1.6,-15.245,8.2));
#14899 = VECTOR('',#14900,1.);
#14900 = DIRECTION('',(0.,1.,0.));
#14901 = PCURVE('',#14851,#14902);
#14902 = DEFINITIONAL_REPRESENTATION('',(#14903),#14907);
#14903 = LINE('',#14904,#14905);
#14904 = CARTESIAN_POINT('',(0.,-0.2));
#14905 = VECTOR('',#14906,1.);
#14906 = DIRECTION('',(1.,0.));
#14907 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14908 = PCURVE('',#14823,#14909);
#14909 = DEFINITIONAL_REPRESENTATION('',(#14910),#14914);
#14910 = LINE('',#14911,#14912);
#14911 = CARTESIAN_POINT('',(-0.1595,-0.16));
#14912 = VECTOR('',#14913,1.);
#14913 = DIRECTION('',(1.,0.));
#14914 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14915 = ORIENTED_EDGE('',*,*,#14916,.F.);
#14916 = EDGE_CURVE('',#14917,#14894,#14919,.T.);
#14917 = VERTEX_POINT('',#14918);
#14918 = CARTESIAN_POINT('',(-1.6,-14.926,8.));
#14919 = SURFACE_CURVE('',#14920,(#14924,#14931),.PCURVE_S1.);
#14920 = LINE('',#14921,#14922);
#14921 = CARTESIAN_POINT('',(-1.6,-14.926,8.));
#14922 = VECTOR('',#14923,1.);
#14923 = DIRECTION('',(0.,0.,1.));
#14924 = PCURVE('',#14851,#14925);
#14925 = DEFINITIONAL_REPRESENTATION('',(#14926),#14930);
#14926 = LINE('',#14927,#14928);
#14927 = CARTESIAN_POINT('',(0.319,0.));
#14928 = VECTOR('',#14929,1.);
#14929 = DIRECTION('',(0.,-1.));
#14930 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14931 = PCURVE('',#14932,#14937);
#14932 = PLANE('',#14933);
#14933 = AXIS2_PLACEMENT_3D('',#14934,#14935,#14936);
#14934 = CARTESIAN_POINT('',(-1.6,-14.926,8.));
#14935 = DIRECTION('',(2.2E-16,1.,0.));
#14936 = DIRECTION('',(1.,-2.2E-16,0.));
#14937 = DEFINITIONAL_REPRESENTATION('',(#14938),#14942);
#14938 = LINE('',#14939,#14940);
#14939 = CARTESIAN_POINT('',(3.11E-15,0.));
#14940 = VECTOR('',#14941,1.);
#14941 = DIRECTION('',(0.,-1.));
#14942 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14943 = ORIENTED_EDGE('',*,*,#14944,.F.);
#14944 = EDGE_CURVE('',#14836,#14917,#14945,.T.);
#14945 = SURFACE_CURVE('',#14946,(#14950,#14957),.PCURVE_S1.);
#14946 = LINE('',#14947,#14948);
#14947 = CARTESIAN_POINT('',(-1.6,-15.245,8.));
#14948 = VECTOR('',#14949,1.);
#14949 = DIRECTION('',(0.,1.,0.));
#14950 = PCURVE('',#14851,#14951);
#14951 = DEFINITIONAL_REPRESENTATION('',(#14952),#14956);
#14952 = LINE('',#14953,#14954);
#14953 = CARTESIAN_POINT('',(0.,0.));
#14954 = VECTOR('',#14955,1.);
#14955 = DIRECTION('',(1.,0.));
#14956 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14957 = PCURVE('',#14877,#14958);
#14958 = DEFINITIONAL_REPRESENTATION('',(#14959),#14963);
#14959 = LINE('',#14960,#14961);
#14960 = CARTESIAN_POINT('',(-0.1595,-0.16));
#14961 = VECTOR('',#14962,1.);
#14962 = DIRECTION('',(1.,0.));
#14963 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14964 = ADVANCED_FACE('',(#14965),#14932,.T.);
#14965 = FACE_BOUND('',#14966,.T.);
#14966 = EDGE_LOOP('',(#14967,#14968,#14991,#15014));
#14967 = ORIENTED_EDGE('',*,*,#14916,.T.);
#14968 = ORIENTED_EDGE('',*,*,#14969,.T.);
#14969 = EDGE_CURVE('',#14894,#14970,#14972,.T.);
#14970 = VERTEX_POINT('',#14971);
#14971 = CARTESIAN_POINT('',(-1.28,-14.926,8.2));
#14972 = SURFACE_CURVE('',#14973,(#14977,#14984),.PCURVE_S1.);
#14973 = LINE('',#14974,#14975);
#14974 = CARTESIAN_POINT('',(-1.6,-14.926,8.2));
#14975 = VECTOR('',#14976,1.);
#14976 = DIRECTION('',(1.,0.,0.));
#14977 = PCURVE('',#14932,#14978);
#14978 = DEFINITIONAL_REPRESENTATION('',(#14979),#14983);
#14979 = LINE('',#14980,#14981);
#14980 = CARTESIAN_POINT('',(0.,-0.2));
#14981 = VECTOR('',#14982,1.);
#14982 = DIRECTION('',(1.,0.));
#14983 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14984 = PCURVE('',#14823,#14985);
#14985 = DEFINITIONAL_REPRESENTATION('',(#14986),#14990);
#14986 = LINE('',#14987,#14988);
#14987 = CARTESIAN_POINT('',(0.1595,-0.16));
#14988 = VECTOR('',#14989,1.);
#14989 = DIRECTION('',(0.,1.));
#14990 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#14991 = ORIENTED_EDGE('',*,*,#14992,.F.);
#14992 = EDGE_CURVE('',#14993,#14970,#14995,.T.);
#14993 = VERTEX_POINT('',#14994);
#14994 = CARTESIAN_POINT('',(-1.28,-14.926,8.));
#14995 = SURFACE_CURVE('',#14996,(#15000,#15007),.PCURVE_S1.);
#14996 = LINE('',#14997,#14998);
#14997 = CARTESIAN_POINT('',(-1.28,-14.926,8.));
#14998 = VECTOR('',#14999,1.);
#14999 = DIRECTION('',(0.,0.,1.));
#15000 = PCURVE('',#14932,#15001);
#15001 = DEFINITIONAL_REPRESENTATION('',(#15002),#15006);
#15002 = LINE('',#15003,#15004);
#15003 = CARTESIAN_POINT('',(0.32,0.));
#15004 = VECTOR('',#15005,1.);
#15005 = DIRECTION('',(0.,-1.));
#15006 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#15007 = PCURVE('',#14795,#15008);
#15008 = DEFINITIONAL_REPRESENTATION('',(#15009),#15013);
#15009 = LINE('',#15010,#15011);
#15010 = CARTESIAN_POINT('',(0.,0.));
#15011 = VECTOR('',#15012,1.);
#15012 = DIRECTION('',(0.,-1.));
#15013 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#15014 = ORIENTED_EDGE('',*,*,#15015,.F.);
#15015 = EDGE_CURVE('',#14917,#14993,#15016,.T.);
#15016 = SURFACE_CURVE('',#15017,(#15021,#15028),.PCURVE_S1.);
#15017 = LINE('',#15018,#15019);
#15018 = CARTESIAN_POINT('',(-1.6,-14.926,8.));
#15019 = VECTOR('',#15020,1.);
#15020 = DIRECTION('',(1.,0.,0.));
#15021 = PCURVE('',#14932,#15022);
#15022 = DEFINITIONAL_REPRESENTATION('',(#15023),#15027);
#15023 = LINE('',#15024,#15025);
#15024 = CARTESIAN_POINT('',(0.,0.));
#15025 = VECTOR('',#15026,1.);
#15026 = DIRECTION('',(1.,0.));
#15027 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#15028 = PCURVE('',#14877,#15029);
#15029 = DEFINITIONAL_REPRESENTATION('',(#15030),#15034);
#15030 = LINE('',#15031,#15032);
#15031 = CARTESIAN_POINT('',(0.1595,-0.16));
#15032 = VECTOR('',#15033,1.);
#15033 = DIRECTION('',(0.,1.));
#15034 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#15035 = ADVANCED_FACE('',(#15036),#14795,.T.);
#15036 = FACE_BOUND('',#15037,.T.);
#15037 = EDGE_LOOP('',(#15038,#15039,#15060,#15061));
#15038 = ORIENTED_EDGE('',*,*,#14992,.T.);
#15039 = ORIENTED_EDGE('',*,*,#15040,.T.);
#15040 = EDGE_CURVE('',#14970,#14775,#15041,.T.);
#15041 = SURFACE_CURVE('',#15042,(#15046,#15053),.PCURVE_S1.);
#15042 = LINE('',#15043,#15044);
#15043 = CARTESIAN_POINT('',(-1.28,-14.926,8.2));
#15044 = VECTOR('',#15045,1.);
#15045 = DIRECTION('',(0.,-1.,0.));
#15046 = PCURVE('',#14795,#15047);
#15047 = DEFINITIONAL_REPRESENTATION('',(#15048),#15052);
#15048 = LINE('',#15049,#15050);
#15049 = CARTESIAN_POINT('',(0.,-0.2));
#15050 = VECTOR('',#15051,1.);
#15051 = DIRECTION('',(1.,-0.));
#15052 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#15053 = PCURVE('',#14823,#15054);
#15054 = DEFINITIONAL_REPRESENTATION('',(#15055),#15059);
#15055 = LINE('',#15056,#15057);
#15056 = CARTESIAN_POINT('',(0.1595,0.16));
#15057 = VECTOR('',#15058,1.);
#15058 = DIRECTION('',(-1.,0.));
#15059 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#15060 = ORIENTED_EDGE('',*,*,#14772,.F.);
#15061 = ORIENTED_EDGE('',*,*,#15062,.F.);
#15062 = EDGE_CURVE('',#14993,#14773,#15063,.T.);
#15063 = SURFACE_CURVE('',#15064,(#15068,#15075),.PCURVE_S1.);
#15064 = LINE('',#15065,#15066);
#15065 = CARTESIAN_POINT('',(-1.28,-14.926,8.));
#15066 = VECTOR('',#15067,1.);
#15067 = DIRECTION('',(0.,-1.,0.));
#15068 = PCURVE('',#14795,#15069);
#15069 = DEFINITIONAL_REPRESENTATION('',(#15070),#15074);
#15070 = LINE('',#15071,#15072);
#15071 = CARTESIAN_POINT('',(0.,0.));
#15072 = VECTOR('',#15073,1.);
#15073 = DIRECTION('',(1.,-0.));
#15074 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#15075 = PCURVE('',#14877,#15076);
#15076 = DEFINITIONAL_REPRESENTATION('',(#15077),#15081);
#15077 = LINE('',#15078,#15079);
#15078 = CARTESIAN_POINT('',(0.1595,0.16));
#15079 = VECTOR('',#15080,1.);
#15080 = DIRECTION('',(-1.,0.));
#15081 = ( GEOMETRIC_REPRESENTATION_CONTEXT(2)
#15082 = ADVANCED_FACE('',(#15083),#14877,.T.);
#15083 = FACE_BOUND('',#15084,.T.);
#15084 = EDGE_LOOP('',(#15085,#15086,#15087,#15088));
#15085 = ORIENTED_EDGE('',*,*,#14863,.T.);
#15086 = ORIENTED_EDGE('',*,*,#14944,.T.);
#15087 = ORIENTED_EDGE('',*,*,#15015,.T.);
#15088 = ORIENTED_EDGE('',*,*,#15062,.T.);
#15089 = ADVANCED_FACE('',(#15090),#14823,.F.);
#15090 = FACE_BOUND('',#15091,.F.);
#15091 = EDGE_LOOP('',(#15092,#15093,#15094,#15095));
#15092 = ORIENTED_EDGE('',*,*,#14807,.T.);
#15093 = ORIENTED_EDGE('',*,*,#14893,.T.);
#15094 = ORIENTED_EDGE('',*,*,#14969,.T.);
#15095 = ORIENTED_EDGE('',*,*,#15040,.T.);
#15096 = ( GEOMETRIC_REPRESENTATION_CONTEXT(3)
GLOBAL_UNCERTAINTY_ASSIGNED_CONTEXT((#15100))
GLOBAL_UNIT_ASSIGNED_CONTEXT((#15097,#15098,#15099))
REPRESENTATION_CONTEXT('Context #1',
'3D Context with UNIT and UNCERTAINTY') );
#15097 = ( LENGTH_UNIT() NAMED_UNIT(*) SI_UNIT(.MILLI.,.METRE.) );
#15098 = ( NAMED_UNIT(*) PLANE_ANGLE_UNIT() SI_UNIT($,.RADIAN.) );
#15099 = ( NAMED_UNIT(*) SI_UNIT($,.STERADIAN.) SOLID_ANGLE_UNIT() );
#15100 = UNCERTAINTY_MEASURE_WITH_UNIT(LENGTH_MEASURE(1.E-07),#15097,
'distance_accuracy_value','confusion accuracy');
#15101 = SHAPE_DEFINITION_REPRESENTATION(#15102,#727);
#15102 = PRODUCT_DEFINITION_SHAPE('','',#15103);
#15103 = PRODUCT_DEFINITION('design','',#15104,#15107);
#15104 = PRODUCT_DEFINITION_FORMATION('','',#15105);
#15105 = PRODUCT('Fusion','Fusion','',(#15106));
#15106 = PRODUCT_CONTEXT('',#2,'mechanical');
#15107 = PRODUCT_DEFINITION_CONTEXT('part definition',#2,'design');
#15108 = CONTEXT_DEPENDENT_SHAPE_REPRESENTATION(#15109,#15111);
#15109 = ( REPRESENTATION_RELATIONSHIP('','',#727,#10)
REPRESENTATION_RELATIONSHIP_WITH_TRANSFORMATION(#15110)
SHAPE_REPRESENTATION_RELATIONSHIP() );
#15110 = ITEM_DEFINED_TRANSFORMATION('','',#11,#27);
#15111 = PRODUCT_DEFINITION_SHAPE('Placement','Placement of an item',
#15112);
#15112 = NEXT_ASSEMBLY_USAGE_OCCURRENCE('4','=>[0:1:1:5]','',#5,#15103,$
#15113 = PRODUCT_RELATED_PRODUCT_CATEGORY('part',$,(#15105));
#15114 = MECHANICAL_DESIGN_GEOMETRIC_PRESENTATION_REPRESENTATION('',(
#15115,#15123,#15130,#15137,#15144),#709);
#15115 = STYLED_ITEM('color',(#15116),#500);
#15116 = PRESENTATION_STYLE_ASSIGNMENT((#15117));
#15117 = SURFACE_STYLE_USAGE(.BOTH.,#15118);
#15118 = SURFACE_SIDE_STYLE('',(#15119));
#15119 = SURFACE_STYLE_FILL_AREA(#15120);
#15120 = FILL_AREA_STYLE('',(#15121));
#15121 = FILL_AREA_STYLE_COLOUR('',#15122);
#15122 = COLOUR_RGB('',0.823529422283,0.819607853889,0.780392169952);
#15123 = STYLED_ITEM('color',(#15124),#589);
#15124 = PRESENTATION_STYLE_ASSIGNMENT((#15125));
#15125 = SURFACE_STYLE_USAGE(.BOTH.,#15126);
#15126 = SURFACE_SIDE_STYLE('',(#15127));
#15127 = SURFACE_STYLE_FILL_AREA(#15128);
#15128 = FILL_AREA_STYLE('',(#15129));
#15129 = FILL_AREA_STYLE_COLOUR('',#15122);
#15130 = STYLED_ITEM('color',(#15131),#643);
#15131 = PRESENTATION_STYLE_ASSIGNMENT((#15132));
#15132 = SURFACE_STYLE_USAGE(.BOTH.,#15133);
#15133 = SURFACE_SIDE_STYLE('',(#15134));
#15134 = SURFACE_STYLE_FILL_AREA(#15135);
#15135 = FILL_AREA_STYLE('',(#15136));
#15136 = FILL_AREA_STYLE_COLOUR('',#15122);
#15137 = STYLED_ITEM('color',(#15138),#701);
#15138 = PRESENTATION_STYLE_ASSIGNMENT((#15139));
#15139 = SURFACE_STYLE_USAGE(.BOTH.,#15140);
#15140 = SURFACE_SIDE_STYLE('',(#15141));
#15141 = SURFACE_STYLE_FILL_AREA(#15142);
#15142 = FILL_AREA_STYLE('',(#15143));
#15143 = FILL_AREA_STYLE_COLOUR('',#15122);
#15144 = STYLED_ITEM('color',(#15145),#705);
#15145 = PRESENTATION_STYLE_ASSIGNMENT((#15146));
#15146 = SURFACE_STYLE_USAGE(.BOTH.,#15147);
#15147 = SURFACE_SIDE_STYLE('',(#15148));
#15148 = SURFACE_STYLE_FILL_AREA(#15149);
#15149 = FILL_AREA_STYLE('',(#15150));
#15150 = FILL_AREA_STYLE_COLOUR('',#15122);
#15151 = MECHANICAL_DESIGN_GEOMETRIC_PRESENTATION_REPRESENTATION('',(
#15152,#15159,#15166,#15173,#15180),#479);
#15152 = STYLED_ITEM('color',(#15153),#270);
#15153 = PRESENTATION_STYLE_ASSIGNMENT((#15154));
#15154 = SURFACE_STYLE_USAGE(.BOTH.,#15155);
#15155 = SURFACE_SIDE_STYLE('',(#15156));
#15156 = SURFACE_STYLE_FILL_AREA(#15157);
#15157 = FILL_AREA_STYLE('',(#15158));
#15158 = FILL_AREA_STYLE_COLOUR('',#15122);
#15159 = STYLED_ITEM('color',(#15160),#359);
#15160 = PRESENTATION_STYLE_ASSIGNMENT((#15161));
#15161 = SURFACE_STYLE_USAGE(.BOTH.,#15162);
#15162 = SURFACE_SIDE_STYLE('',(#15163));
#15163 = SURFACE_STYLE_FILL_AREA(#15164);
#15164 = FILL_AREA_STYLE('',(#15165));
#15165 = FILL_AREA_STYLE_COLOUR('',#15122);
#15166 = STYLED_ITEM('color',(#15167),#413);
#15167 = PRESENTATION_STYLE_ASSIGNMENT((#15168));
#15168 = SURFACE_STYLE_USAGE(.BOTH.,#15169);
#15169 = SURFACE_SIDE_STYLE('',(#15170));
#15170 = SURFACE_STYLE_FILL_AREA(#15171);
#15171 = FILL_AREA_STYLE('',(#15172));
#15172 = FILL_AREA_STYLE_COLOUR('',#15122);
#15173 = STYLED_ITEM('color',(#15174),#471);
#15174 = PRESENTATION_STYLE_ASSIGNMENT((#15175));
#15175 = SURFACE_STYLE_USAGE(.BOTH.,#15176);
#15176 = SURFACE_SIDE_STYLE('',(#15177));
#15177 = SURFACE_STYLE_FILL_AREA(#15178);
#15178 = FILL_AREA_STYLE('',(#15179));
#15179 = FILL_AREA_STYLE_COLOUR('',#15122);
#15180 = STYLED_ITEM('color',(#15181),#475);
#15181 = PRESENTATION_STYLE_ASSIGNMENT((#15182));
#15182 = SURFACE_STYLE_USAGE(.BOTH.,#15183);
#15183 = SURFACE_SIDE_STYLE('',(#15184));
#15184 = SURFACE_STYLE_FILL_AREA(#15185);
#15185 = FILL_AREA_STYLE('',(#15186));
#15186 = FILL_AREA_STYLE_COLOUR('',#15122);
#15187 = MECHANICAL_DESIGN_GEOMETRIC_PRESENTATION_REPRESENTATION('',(
#15188,#15195,#15202,#15209,#15216),#249);
#15188 = STYLED_ITEM('color',(#15189),#40);
#15189 = PRESENTATION_STYLE_ASSIGNMENT((#15190));
#15190 = SURFACE_STYLE_USAGE(.BOTH.,#15191);
#15191 = SURFACE_SIDE_STYLE('',(#15192));
#15192 = SURFACE_STYLE_FILL_AREA(#15193);
#15193 = FILL_AREA_STYLE('',(#15194));
#15194 = FILL_AREA_STYLE_COLOUR('',#15122);
#15195 = STYLED_ITEM('color',(#15196),#129);
#15196 = PRESENTATION_STYLE_ASSIGNMENT((#15197));
#15197 = SURFACE_STYLE_USAGE(.BOTH.,#15198);
#15198 = SURFACE_SIDE_STYLE('',(#15199));
#15199 = SURFACE_STYLE_FILL_AREA(#15200);
#15200 = FILL_AREA_STYLE('',(#15201));
#15201 = FILL_AREA_STYLE_COLOUR('',#15122);
#15202 = STYLED_ITEM('color',(#15203),#183);
#15203 = PRESENTATION_STYLE_ASSIGNMENT((#15204));
#15204 = SURFACE_STYLE_USAGE(.BOTH.,#15205);
#15205 = SURFACE_SIDE_STYLE('',(#15206));
#15206 = SURFACE_STYLE_FILL_AREA(#15207);
#15207 = FILL_AREA_STYLE('',(#15208));
#15208 = FILL_AREA_STYLE_COLOUR('',#15122);
#15209 = STYLED_ITEM('color',(#15210),#241);
#15210 = PRESENTATION_STYLE_ASSIGNMENT((#15211));
#15211 = SURFACE_STYLE_USAGE(.BOTH.,#15212);
#15212 = SURFACE_SIDE_STYLE('',(#15213));
#15213 = SURFACE_STYLE_FILL_AREA(#15214);
#15214 = FILL_AREA_STYLE('',(#15215));
#15215 = FILL_AREA_STYLE_COLOUR('',#15122);
#15216 = STYLED_ITEM('color',(#15217),#245);
#15217 = PRESENTATION_STYLE_ASSIGNMENT((#15218));
#15218 = SURFACE_STYLE_USAGE(.BOTH.,#15219);
#15219 = SURFACE_SIDE_STYLE('',(#15220));
#15220 = SURFACE_STYLE_FILL_AREA(#15221);
#15221 = FILL_AREA_STYLE('',(#15222));
#15222 = FILL_AREA_STYLE_COLOUR('',#15122);
#15223 = MECHANICAL_DESIGN_GEOMETRIC_PRESENTATION_REPRESENTATION('',(
#15224,#15232,#15239,#15246,#15253,#15260,#15267,#15274,#15281,
#15288,#15295,#15303,#15310,#15317,#15324,#15331,#15338,#15345,
#15352,#15359,#15366,#15373,#15380,#15387,#15394,#15401,#15408,
#15415,#15422,#15429,#15436,#15443,#15450,#15457,#15464,#15471,
#15478,#15485,#15492,#15499,#15506,#15513,#15520,#15527,#15534,
#15541,#15548,#15555,#15562,#15569,#15576,#15583,#15590,#15597,
#15604,#15611,#15618,#15625,#15632,#15639,#15646,#15653,#15660,
#15667,#15674,#15681,#15688,#15695,#15702,#15709,#15716,#15723,
#15730,#15737,#15744,#15751,#15758,#15765,#15772,#15779,#15786,
#15793,#15800,#15807,#15814,#15821,#15828,#15835,#15842,#15849,
#15856,#15863,#15870,#15877,#15884,#15891,#15898,#15905,#15912,
#15919,#15926,#15933,#15940,#15947,#15954,#15961,#15968,#15975,
#15982,#15989,#15996,#16003,#16010,#16017,#16024,#16031,#16038,
#16045,#16052,#16059,#16066,#16073,#16080,#16087,#16094,#16101,
#16108,#16115,#16122,#16129,#16136,#16143,#16150,#16157,#16164,
#16171,#16178,#16185,#16192,#16199,#16206,#16213,#16220,#16227,
#16234,#16241,#16248,#16255,#16262,#16269,#16276,#16283,#16290,
#16297,#16304,#16311,#16318,#16325,#16332,#16339,#16346,#16353,
#16360,#16367,#16374,#16381,#16388,#16395,#16402,#16409,#16416,
#16423,#16430,#16437,#16444,#16451,#16458,#16465,#16472,#16479,
#16486,#16493,#16500,#16507,#16514,#16521,#16528,#16535,#16542,
#16549,#16556,#16563,#16570,#16577,#16584,#16591,#16598,#16605,
#16612,#16619,#16626,#16633,#16640,#16647,#16654,#16661),#15096);
#15224 = STYLED_ITEM('color',(#15225),#730);
#15225 = PRESENTATION_STYLE_ASSIGNMENT((#15226));
#15226 = SURFACE_STYLE_USAGE(.BOTH.,#15227);
#15227 = SURFACE_SIDE_STYLE('',(#15228));
#15228 = SURFACE_STYLE_FILL_AREA(#15229);
#15229 = FILL_AREA_STYLE('',(#15230));
#15230 = FILL_AREA_STYLE_COLOUR('',#15231);
#15231 = COLOUR_RGB('',0.145098045468,0.145098045468,0.145098045468);
#15232 = STYLED_ITEM('color',(#15233),#852);
#15233 = PRESENTATION_STYLE_ASSIGNMENT((#15234));
#15234 = SURFACE_STYLE_USAGE(.BOTH.,#15235);
#15235 = SURFACE_SIDE_STYLE('',(#15236));
#15236 = SURFACE_STYLE_FILL_AREA(#15237);
#15237 = FILL_AREA_STYLE('',(#15238));
#15238 = FILL_AREA_STYLE_COLOUR('',#15231);
#15239 = STYLED_ITEM('color',(#15240),#938);
#15240 = PRESENTATION_STYLE_ASSIGNMENT((#15241));
#15241 = SURFACE_STYLE_USAGE(.BOTH.,#15242);
#15242 = SURFACE_SIDE_STYLE('',(#15243));
#15243 = SURFACE_STYLE_FILL_AREA(#15244);
#15244 = FILL_AREA_STYLE('',(#15245));
#15245 = FILL_AREA_STYLE_COLOUR('',#15231);
#15246 = STYLED_ITEM('color',(#15247),#1018);
#15247 = PRESENTATION_STYLE_ASSIGNMENT((#15248));
#15248 = SURFACE_STYLE_USAGE(.BOTH.,#15249);
#15249 = SURFACE_SIDE_STYLE('',(#15250));
#15250 = SURFACE_STYLE_FILL_AREA(#15251);
#15251 = FILL_AREA_STYLE('',(#15252));
#15252 = FILL_AREA_STYLE_COLOUR('',#15231);
#15253 = STYLED_ITEM('color',(#15254),#1098);
#15254 = PRESENTATION_STYLE_ASSIGNMENT((#15255));
#15255 = SURFACE_STYLE_USAGE(.BOTH.,#15256);
#15256 = SURFACE_SIDE_STYLE('',(#15257));
#15257 = SURFACE_STYLE_FILL_AREA(#15258);
#15258 = FILL_AREA_STYLE('',(#15259));
#15259 = FILL_AREA_STYLE_COLOUR('',#15231);
#15260 = STYLED_ITEM('color',(#15261),#1174);
#15261 = PRESENTATION_STYLE_ASSIGNMENT((#15262));
#15262 = SURFACE_STYLE_USAGE(.BOTH.,#15263);
#15263 = SURFACE_SIDE_STYLE('',(#15264));
#15264 = SURFACE_STYLE_FILL_AREA(#15265);
#15265 = FILL_AREA_STYLE('',(#15266));
#15266 = FILL_AREA_STYLE_COLOUR('',#15231);
#15267 = STYLED_ITEM('color',(#15268),#1227);
#15268 = PRESENTATION_STYLE_ASSIGNMENT((#15269));
#15269 = SURFACE_STYLE_USAGE(.BOTH.,#15270);
#15270 = SURFACE_SIDE_STYLE('',(#15271));
#15271 = SURFACE_STYLE_FILL_AREA(#15272);
#15272 = FILL_AREA_STYLE('',(#15273));
#15273 = FILL_AREA_STYLE_COLOUR('',#15231);
#15274 = STYLED_ITEM('color',(#15275),#1280);
#15275 = PRESENTATION_STYLE_ASSIGNMENT((#15276));
#15276 = SURFACE_STYLE_USAGE(.BOTH.,#15277);
#15277 = SURFACE_SIDE_STYLE('',(#15278));
#15278 = SURFACE_STYLE_FILL_AREA(#15279);
#15279 = FILL_AREA_STYLE('',(#15280));
#15280 = FILL_AREA_STYLE_COLOUR('',#15231);
#15281 = STYLED_ITEM('color',(#15282),#1358);
#15282 = PRESENTATION_STYLE_ASSIGNMENT((#15283));
#15283 = SURFACE_STYLE_USAGE(.BOTH.,#15284);
#15284 = SURFACE_SIDE_STYLE('',(#15285));
#15285 = SURFACE_STYLE_FILL_AREA(#15286);
#15286 = FILL_AREA_STYLE('',(#15287));
#15287 = FILL_AREA_STYLE_COLOUR('',#15231);
#15288 = STYLED_ITEM('color',(#15289),#1522);
#15289 = PRESENTATION_STYLE_ASSIGNMENT((#15290));
#15290 = SURFACE_STYLE_USAGE(.BOTH.,#15291);
#15291 = SURFACE_SIDE_STYLE('',(#15292));
#15292 = SURFACE_STYLE_FILL_AREA(#15293);
#15293 = FILL_AREA_STYLE('',(#15294));
#15294 = FILL_AREA_STYLE_COLOUR('',#15231);
#15295 = STYLED_ITEM('color',(#15296),#1548);
#15296 = PRESENTATION_STYLE_ASSIGNMENT((#15297));
#15297 = SURFACE_STYLE_USAGE(.BOTH.,#15298);
#15298 = SURFACE_SIDE_STYLE('',(#15299));
#15299 = SURFACE_STYLE_FILL_AREA(#15300);
#15300 = FILL_AREA_STYLE('',(#15301));
#15301 = FILL_AREA_STYLE_COLOUR('',#15302);
#15302 = COLOUR_RGB('',0.701960802078,9.803921729326E-02,
4.705882444978E-02);
#15303 = STYLED_ITEM('color',(#15304),#1712);
#15304 = PRESENTATION_STYLE_ASSIGNMENT((#15305));
#15305 = SURFACE_STYLE_USAGE(.BOTH.,#15306);
#15306 = SURFACE_SIDE_STYLE('',(#15307));
#15307 = SURFACE_STYLE_FILL_AREA(#15308);
#15308 = FILL_AREA_STYLE('',(#15309));
#15309 = FILL_AREA_STYLE_COLOUR('',#15231);
#15310 = STYLED_ITEM('color',(#15311),#1738);
#15311 = PRESENTATION_STYLE_ASSIGNMENT((#15312));
#15312 = SURFACE_STYLE_USAGE(.BOTH.,#15313);
#15313 = SURFACE_SIDE_STYLE('',(#15314));
#15314 = SURFACE_STYLE_FILL_AREA(#15315);
#15315 = FILL_AREA_STYLE('',(#15316));
#15316 = FILL_AREA_STYLE_COLOUR('',#15231);
#15317 = STYLED_ITEM('color',(#15318),#1816);
#15318 = PRESENTATION_STYLE_ASSIGNMENT((#15319));
#15319 = SURFACE_STYLE_USAGE(.BOTH.,#15320);
#15320 = SURFACE_SIDE_STYLE('',(#15321));
#15321 = SURFACE_STYLE_FILL_AREA(#15322);
#15322 = FILL_AREA_STYLE('',(#15323));
#15323 = FILL_AREA_STYLE_COLOUR('',#15231);
#15324 = STYLED_ITEM('color',(#15325),#1842);
#15325 = PRESENTATION_STYLE_ASSIGNMENT((#15326));
#15326 = SURFACE_STYLE_USAGE(.BOTH.,#15327);
#15327 = SURFACE_SIDE_STYLE('',(#15328));
#15328 = SURFACE_STYLE_FILL_AREA(#15329);
#15329 = FILL_AREA_STYLE('',(#15330));
#15330 = FILL_AREA_STYLE_COLOUR('',#15231);
#15331 = STYLED_ITEM('color',(#15332),#1868);
#15332 = PRESENTATION_STYLE_ASSIGNMENT((#15333));
#15333 = SURFACE_STYLE_USAGE(.BOTH.,#15334);
#15334 = SURFACE_SIDE_STYLE('',(#15335));
#15335 = SURFACE_STYLE_FILL_AREA(#15336);
#15336 = FILL_AREA_STYLE('',(#15337));
#15337 = FILL_AREA_STYLE_COLOUR('',#15231);
#15338 = STYLED_ITEM('color',(#15339),#1944);
#15339 = PRESENTATION_STYLE_ASSIGNMENT((#15340));
#15340 = SURFACE_STYLE_USAGE(.BOTH.,#15341);
#15341 = SURFACE_SIDE_STYLE('',(#15342));
#15342 = SURFACE_STYLE_FILL_AREA(#15343);
#15343 = FILL_AREA_STYLE('',(#15344));
#15344 = FILL_AREA_STYLE_COLOUR('',#15231);
#15345 = STYLED_ITEM('color',(#15346),#1970);
#15346 = PRESENTATION_STYLE_ASSIGNMENT((#15347));
#15347 = SURFACE_STYLE_USAGE(.BOTH.,#15348);
#15348 = SURFACE_SIDE_STYLE('',(#15349));
#15349 = SURFACE_STYLE_FILL_AREA(#15350);
#15350 = FILL_AREA_STYLE('',(#15351));
#15351 = FILL_AREA_STYLE_COLOUR('',#15231);
#15352 = STYLED_ITEM('color',(#15353),#1996);
#15353 = PRESENTATION_STYLE_ASSIGNMENT((#15354));
#15354 = SURFACE_STYLE_USAGE(.BOTH.,#15355);
#15355 = SURFACE_SIDE_STYLE('',(#15356));
#15356 = SURFACE_STYLE_FILL_AREA(#15357);
#15357 = FILL_AREA_STYLE('',(#15358));
#15358 = FILL_AREA_STYLE_COLOUR('',#15231);
#15359 = STYLED_ITEM('color',(#15360),#2044);
#15360 = PRESENTATION_STYLE_ASSIGNMENT((#15361));
#15361 = SURFACE_STYLE_USAGE(.BOTH.,#15362);
#15362 = SURFACE_SIDE_STYLE('',(#15363));
#15363 = SURFACE_STYLE_FILL_AREA(#15364);
#15364 = FILL_AREA_STYLE('',(#15365));
#15365 = FILL_AREA_STYLE_COLOUR('',#15231);
#15366 = STYLED_ITEM('color',(#15367),#2072);
#15367 = PRESENTATION_STYLE_ASSIGNMENT((#15368));
#15368 = SURFACE_STYLE_USAGE(.BOTH.,#15369);
#15369 = SURFACE_SIDE_STYLE('',(#15370));
#15370 = SURFACE_STYLE_FILL_AREA(#15371);
#15371 = FILL_AREA_STYLE('',(#15372));
#15372 = FILL_AREA_STYLE_COLOUR('',#15231);
#15373 = STYLED_ITEM('color',(#15374),#2098);
#15374 = PRESENTATION_STYLE_ASSIGNMENT((#15375));
#15375 = SURFACE_STYLE_USAGE(.BOTH.,#15376);
#15376 = SURFACE_SIDE_STYLE('',(#15377));
#15377 = SURFACE_STYLE_FILL_AREA(#15378);
#15378 = FILL_AREA_STYLE('',(#15379));
#15379 = FILL_AREA_STYLE_COLOUR('',#15231);
#15380 = STYLED_ITEM('color',(#15381),#2124);
#15381 = PRESENTATION_STYLE_ASSIGNMENT((#15382));
#15382 = SURFACE_STYLE_USAGE(.BOTH.,#15383);
#15383 = SURFACE_SIDE_STYLE('',(#15384));
#15384 = SURFACE_STYLE_FILL_AREA(#15385);
#15385 = FILL_AREA_STYLE('',(#15386));
#15386 = FILL_AREA_STYLE_COLOUR('',#15231);
#15387 = STYLED_ITEM('color',(#15388),#2172);
#15388 = PRESENTATION_STYLE_ASSIGNMENT((#15389));
#15389 = SURFACE_STYLE_USAGE(.BOTH.,#15390);
#15390 = SURFACE_SIDE_STYLE('',(#15391));
#15391 = SURFACE_STYLE_FILL_AREA(#15392);
#15392 = FILL_AREA_STYLE('',(#15393));
#15393 = FILL_AREA_STYLE_COLOUR('',#15231);
#15394 = STYLED_ITEM('color',(#15395),#2200);
#15395 = PRESENTATION_STYLE_ASSIGNMENT((#15396));
#15396 = SURFACE_STYLE_USAGE(.BOTH.,#15397);
#15397 = SURFACE_SIDE_STYLE('',(#15398));
#15398 = SURFACE_STYLE_FILL_AREA(#15399);
#15399 = FILL_AREA_STYLE('',(#15400));
#15400 = FILL_AREA_STYLE_COLOUR('',#15231);
#15401 = STYLED_ITEM('color',(#15402),#2227);
#15402 = PRESENTATION_STYLE_ASSIGNMENT((#15403));
#15403 = SURFACE_STYLE_USAGE(.BOTH.,#15404);
#15404 = SURFACE_SIDE_STYLE('',(#15405));
#15405 = SURFACE_STYLE_FILL_AREA(#15406);
#15406 = FILL_AREA_STYLE('',(#15407));
#15407 = FILL_AREA_STYLE_COLOUR('',#15231);
#15408 = STYLED_ITEM('color',(#15409),#2236);
#15409 = PRESENTATION_STYLE_ASSIGNMENT((#15410));
#15410 = SURFACE_STYLE_USAGE(.BOTH.,#15411);
#15411 = SURFACE_SIDE_STYLE('',(#15412));
#15412 = SURFACE_STYLE_FILL_AREA(#15413);
#15413 = FILL_AREA_STYLE('',(#15414));
#15414 = FILL_AREA_STYLE_COLOUR('',#15231);
#15415 = STYLED_ITEM('color',(#15416),#2362);
#15416 = PRESENTATION_STYLE_ASSIGNMENT((#15417));
#15417 = SURFACE_STYLE_USAGE(.BOTH.,#15418);
#15418 = SURFACE_SIDE_STYLE('',(#15419));
#15419 = SURFACE_STYLE_FILL_AREA(#15420);
#15420 = FILL_AREA_STYLE('',(#15421));
#15421 = FILL_AREA_STYLE_COLOUR('',#15231);
#15422 = STYLED_ITEM('color',(#15423),#2440);
#15423 = PRESENTATION_STYLE_ASSIGNMENT((#15424));
#15424 = SURFACE_STYLE_USAGE(.BOTH.,#15425);
#15425 = SURFACE_SIDE_STYLE('',(#15426));
#15426 = SURFACE_STYLE_FILL_AREA(#15427);
#15427 = FILL_AREA_STYLE('',(#15428));
#15428 = FILL_AREA_STYLE_COLOUR('',#15231);
#15429 = STYLED_ITEM('color',(#15430),#2518);
#15430 = PRESENTATION_STYLE_ASSIGNMENT((#15431));
#15431 = SURFACE_STYLE_USAGE(.BOTH.,#15432);
#15432 = SURFACE_SIDE_STYLE('',(#15433));
#15433 = SURFACE_STYLE_FILL_AREA(#15434);
#15434 = FILL_AREA_STYLE('',(#15435));
#15435 = FILL_AREA_STYLE_COLOUR('',#15231);
#15436 = STYLED_ITEM('color',(#15437),#2594);
#15437 = PRESENTATION_STYLE_ASSIGNMENT((#15438));
#15438 = SURFACE_STYLE_USAGE(.BOTH.,#15439);
#15439 = SURFACE_SIDE_STYLE('',(#15440));
#15440 = SURFACE_STYLE_FILL_AREA(#15441);
#15441 = FILL_AREA_STYLE('',(#15442));
#15442 = FILL_AREA_STYLE_COLOUR('',#15231);
#15443 = STYLED_ITEM('color',(#15444),#2670);
#15444 = PRESENTATION_STYLE_ASSIGNMENT((#15445));
#15445 = SURFACE_STYLE_USAGE(.BOTH.,#15446);
#15446 = SURFACE_SIDE_STYLE('',(#15447));
#15447 = SURFACE_STYLE_FILL_AREA(#15448);
#15448 = FILL_AREA_STYLE('',(#15449));
#15449 = FILL_AREA_STYLE_COLOUR('',#15231);
#15450 = STYLED_ITEM('color',(#15451),#2746);
#15451 = PRESENTATION_STYLE_ASSIGNMENT((#15452));
#15452 = SURFACE_STYLE_USAGE(.BOTH.,#15453);
#15453 = SURFACE_SIDE_STYLE('',(#15454));
#15454 = SURFACE_STYLE_FILL_AREA(#15455);
#15455 = FILL_AREA_STYLE('',(#15456));
#15456 = FILL_AREA_STYLE_COLOUR('',#15231);
#15457 = STYLED_ITEM('color',(#15458),#2822);
#15458 = PRESENTATION_STYLE_ASSIGNMENT((#15459));
#15459 = SURFACE_STYLE_USAGE(.BOTH.,#15460);
#15460 = SURFACE_SIDE_STYLE('',(#15461));
#15461 = SURFACE_STYLE_FILL_AREA(#15462);
#15462 = FILL_AREA_STYLE('',(#15463));
#15463 = FILL_AREA_STYLE_COLOUR('',#15231);
#15464 = STYLED_ITEM('color',(#15465),#2898);
#15465 = PRESENTATION_STYLE_ASSIGNMENT((#15466));
#15466 = SURFACE_STYLE_USAGE(.BOTH.,#15467);
#15467 = SURFACE_SIDE_STYLE('',(#15468));
#15468 = SURFACE_STYLE_FILL_AREA(#15469);
#15469 = FILL_AREA_STYLE('',(#15470));
#15470 = FILL_AREA_STYLE_COLOUR('',#15231);
#15471 = STYLED_ITEM('color',(#15472),#2974);
#15472 = PRESENTATION_STYLE_ASSIGNMENT((#15473));
#15473 = SURFACE_STYLE_USAGE(.BOTH.,#15474);
#15474 = SURFACE_SIDE_STYLE('',(#15475));
#15475 = SURFACE_STYLE_FILL_AREA(#15476);
#15476 = FILL_AREA_STYLE('',(#15477));
#15477 = FILL_AREA_STYLE_COLOUR('',#15231);
#15478 = STYLED_ITEM('color',(#15479),#3050);
#15479 = PRESENTATION_STYLE_ASSIGNMENT((#15480));
#15480 = SURFACE_STYLE_USAGE(.BOTH.,#15481);
#15481 = SURFACE_SIDE_STYLE('',(#15482));
#15482 = SURFACE_STYLE_FILL_AREA(#15483);
#15483 = FILL_AREA_STYLE('',(#15484));
#15484 = FILL_AREA_STYLE_COLOUR('',#15231);
#15485 = STYLED_ITEM('color',(#15486),#3128);
#15486 = PRESENTATION_STYLE_ASSIGNMENT((#15487));
#15487 = SURFACE_STYLE_USAGE(.BOTH.,#15488);
#15488 = SURFACE_SIDE_STYLE('',(#15489));
#15489 = SURFACE_STYLE_FILL_AREA(#15490);
#15490 = FILL_AREA_STYLE('',(#15491));
#15491 = FILL_AREA_STYLE_COLOUR('',#15231);
#15492 = STYLED_ITEM('color',(#15493),#3206);
#15493 = PRESENTATION_STYLE_ASSIGNMENT((#15494));
#15494 = SURFACE_STYLE_USAGE(.BOTH.,#15495);
#15495 = SURFACE_SIDE_STYLE('',(#15496));
#15496 = SURFACE_STYLE_FILL_AREA(#15497);
#15497 = FILL_AREA_STYLE('',(#15498));
#15498 = FILL_AREA_STYLE_COLOUR('',#15231);
#15499 = STYLED_ITEM('color',(#15500),#3284);
#15500 = PRESENTATION_STYLE_ASSIGNMENT((#15501));
#15501 = SURFACE_STYLE_USAGE(.BOTH.,#15502);
#15502 = SURFACE_SIDE_STYLE('',(#15503));
#15503 = SURFACE_STYLE_FILL_AREA(#15504);
#15504 = FILL_AREA_STYLE('',(#15505));
#15505 = FILL_AREA_STYLE_COLOUR('',#15231);
#15506 = STYLED_ITEM('color',(#15507),#3362);
#15507 = PRESENTATION_STYLE_ASSIGNMENT((#15508));
#15508 = SURFACE_STYLE_USAGE(.BOTH.,#15509);
#15509 = SURFACE_SIDE_STYLE('',(#15510));
#15510 = SURFACE_STYLE_FILL_AREA(#15511);
#15511 = FILL_AREA_STYLE('',(#15512));
#15512 = FILL_AREA_STYLE_COLOUR('',#15231);
#15513 = STYLED_ITEM('color',(#15514),#3440);
#15514 = PRESENTATION_STYLE_ASSIGNMENT((#15515));
#15515 = SURFACE_STYLE_USAGE(.BOTH.,#15516);
#15516 = SURFACE_SIDE_STYLE('',(#15517));
#15517 = SURFACE_STYLE_FILL_AREA(#15518);
#15518 = FILL_AREA_STYLE('',(#15519));
#15519 = FILL_AREA_STYLE_COLOUR('',#15231);
#15520 = STYLED_ITEM('color',(#15521),#3518);
#15521 = PRESENTATION_STYLE_ASSIGNMENT((#15522));
#15522 = SURFACE_STYLE_USAGE(.BOTH.,#15523);
#15523 = SURFACE_SIDE_STYLE('',(#15524));
#15524 = SURFACE_STYLE_FILL_AREA(#15525);
#15525 = FILL_AREA_STYLE('',(#15526));
#15526 = FILL_AREA_STYLE_COLOUR('',#15231);
#15527 = STYLED_ITEM('color',(#15528),#3596);
#15528 = PRESENTATION_STYLE_ASSIGNMENT((#15529));
#15529 = SURFACE_STYLE_USAGE(.BOTH.,#15530);
#15530 = SURFACE_SIDE_STYLE('',(#15531));
#15531 = SURFACE_STYLE_FILL_AREA(#15532);
#15532 = FILL_AREA_STYLE('',(#15533));
#15533 = FILL_AREA_STYLE_COLOUR('',#15231);
#15534 = STYLED_ITEM('color',(#15535),#3672);
#15535 = PRESENTATION_STYLE_ASSIGNMENT((#15536));
#15536 = SURFACE_STYLE_USAGE(.BOTH.,#15537);
#15537 = SURFACE_SIDE_STYLE('',(#15538));
#15538 = SURFACE_STYLE_FILL_AREA(#15539);
#15539 = FILL_AREA_STYLE('',(#15540));
#15540 = FILL_AREA_STYLE_COLOUR('',#15231);
#15541 = STYLED_ITEM('color',(#15542),#3750);
#15542 = PRESENTATION_STYLE_ASSIGNMENT((#15543));
#15543 = SURFACE_STYLE_USAGE(.BOTH.,#15544);
#15544 = SURFACE_SIDE_STYLE('',(#15545));
#15545 = SURFACE_STYLE_FILL_AREA(#15546);
#15546 = FILL_AREA_STYLE('',(#15547));
#15547 = FILL_AREA_STYLE_COLOUR('',#15231);
#15548 = STYLED_ITEM('color',(#15549),#3828);
#15549 = PRESENTATION_STYLE_ASSIGNMENT((#15550));
#15550 = SURFACE_STYLE_USAGE(.BOTH.,#15551);
#15551 = SURFACE_SIDE_STYLE('',(#15552));
#15552 = SURFACE_STYLE_FILL_AREA(#15553);
#15553 = FILL_AREA_STYLE('',(#15554));
#15554 = FILL_AREA_STYLE_COLOUR('',#15231);
#15555 = STYLED_ITEM('color',(#15556),#3906);
#15556 = PRESENTATION_STYLE_ASSIGNMENT((#15557));
#15557 = SURFACE_STYLE_USAGE(.BOTH.,#15558);
#15558 = SURFACE_SIDE_STYLE('',(#15559));
#15559 = SURFACE_STYLE_FILL_AREA(#15560);
#15560 = FILL_AREA_STYLE('',(#15561));
#15561 = FILL_AREA_STYLE_COLOUR('',#15231);
#15562 = STYLED_ITEM('color',(#15563),#3977);
#15563 = PRESENTATION_STYLE_ASSIGNMENT((#15564));
#15564 = SURFACE_STYLE_USAGE(.BOTH.,#15565);
#15565 = SURFACE_SIDE_STYLE('',(#15566));
#15566 = SURFACE_STYLE_FILL_AREA(#15567);
#15567 = FILL_AREA_STYLE('',(#15568));
#15568 = FILL_AREA_STYLE_COLOUR('',#15231);
#15569 = STYLED_ITEM('color',(#15570),#4024);
#15570 = PRESENTATION_STYLE_ASSIGNMENT((#15571));
#15571 = SURFACE_STYLE_USAGE(.BOTH.,#15572);
#15572 = SURFACE_SIDE_STYLE('',(#15573));
#15573 = SURFACE_STYLE_FILL_AREA(#15574);
#15574 = FILL_AREA_STYLE('',(#15575));
#15575 = FILL_AREA_STYLE_COLOUR('',#15231);
#15576 = STYLED_ITEM('color',(#15577),#4050);
#15577 = PRESENTATION_STYLE_ASSIGNMENT((#15578));
#15578 = SURFACE_STYLE_USAGE(.BOTH.,#15579);
#15579 = SURFACE_SIDE_STYLE('',(#15580));
#15580 = SURFACE_STYLE_FILL_AREA(#15581);
#15581 = FILL_AREA_STYLE('',(#15582));
#15582 = FILL_AREA_STYLE_COLOUR('',#15231);
#15583 = STYLED_ITEM('color',(#15584),#4078);
#15584 = PRESENTATION_STYLE_ASSIGNMENT((#15585));
#15585 = SURFACE_STYLE_USAGE(.BOTH.,#15586);
#15586 = SURFACE_SIDE_STYLE('',(#15587));
#15587 = SURFACE_STYLE_FILL_AREA(#15588);
#15588 = FILL_AREA_STYLE('',(#15589));
#15589 = FILL_AREA_STYLE_COLOUR('',#15231);
#15590 = STYLED_ITEM('color',(#15591),#4202);
#15591 = PRESENTATION_STYLE_ASSIGNMENT((#15592));
#15592 = SURFACE_STYLE_USAGE(.BOTH.,#15593);
#15593 = SURFACE_SIDE_STYLE('',(#15594));
#15594 = SURFACE_STYLE_FILL_AREA(#15595);
#15595 = FILL_AREA_STYLE('',(#15596));
#15596 = FILL_AREA_STYLE_COLOUR('',#15231);
#15597 = STYLED_ITEM('color',(#15598),#4280);
#15598 = PRESENTATION_STYLE_ASSIGNMENT((#15599));
#15599 = SURFACE_STYLE_USAGE(.BOTH.,#15600);
#15600 = SURFACE_SIDE_STYLE('',(#15601));
#15601 = SURFACE_STYLE_FILL_AREA(#15602);
#15602 = FILL_AREA_STYLE('',(#15603));
#15603 = FILL_AREA_STYLE_COLOUR('',#15231);
#15604 = STYLED_ITEM('color',(#15605),#4356);
#15605 = PRESENTATION_STYLE_ASSIGNMENT((#15606));
#15606 = SURFACE_STYLE_USAGE(.BOTH.,#15607);
#15607 = SURFACE_SIDE_STYLE('',(#15608));
#15608 = SURFACE_STYLE_FILL_AREA(#15609);
#15609 = FILL_AREA_STYLE('',(#15610));
#15610 = FILL_AREA_STYLE_COLOUR('',#15231);
#15611 = STYLED_ITEM('color',(#15612),#4434);
#15612 = PRESENTATION_STYLE_ASSIGNMENT((#15613));
#15613 = SURFACE_STYLE_USAGE(.BOTH.,#15614);
#15614 = SURFACE_SIDE_STYLE('',(#15615));
#15615 = SURFACE_STYLE_FILL_AREA(#15616);
#15616 = FILL_AREA_STYLE('',(#15617));
#15617 = FILL_AREA_STYLE_COLOUR('',#15231);
#15618 = STYLED_ITEM('color',(#15619),#4512);
#15619 = PRESENTATION_STYLE_ASSIGNMENT((#15620));
#15620 = SURFACE_STYLE_USAGE(.BOTH.,#15621);
#15621 = SURFACE_SIDE_STYLE('',(#15622));
#15622 = SURFACE_STYLE_FILL_AREA(#15623);
#15623 = FILL_AREA_STYLE('',(#15624));
#15624 = FILL_AREA_STYLE_COLOUR('',#15231);
#15625 = STYLED_ITEM('color',(#15626),#4588);
#15626 = PRESENTATION_STYLE_ASSIGNMENT((#15627));
#15627 = SURFACE_STYLE_USAGE(.BOTH.,#15628);
#15628 = SURFACE_SIDE_STYLE('',(#15629));
#15629 = SURFACE_STYLE_FILL_AREA(#15630);
#15630 = FILL_AREA_STYLE('',(#15631));
#15631 = FILL_AREA_STYLE_COLOUR('',#15231);
#15632 = STYLED_ITEM('color',(#15633),#4666);
#15633 = PRESENTATION_STYLE_ASSIGNMENT((#15634));
#15634 = SURFACE_STYLE_USAGE(.BOTH.,#15635);
#15635 = SURFACE_SIDE_STYLE('',(#15636));
#15636 = SURFACE_STYLE_FILL_AREA(#15637);
#15637 = FILL_AREA_STYLE('',(#15638));
#15638 = FILL_AREA_STYLE_COLOUR('',#15231);
#15639 = STYLED_ITEM('color',(#15640),#4744);
#15640 = PRESENTATION_STYLE_ASSIGNMENT((#15641));
#15641 = SURFACE_STYLE_USAGE(.BOTH.,#15642);
#15642 = SURFACE_SIDE_STYLE('',(#15643));
#15643 = SURFACE_STYLE_FILL_AREA(#15644);
#15644 = FILL_AREA_STYLE('',(#15645));
#15645 = FILL_AREA_STYLE_COLOUR('',#15231);
#15646 = STYLED_ITEM('color',(#15647),#4822);
#15647 = PRESENTATION_STYLE_ASSIGNMENT((#15648));
#15648 = SURFACE_STYLE_USAGE(.BOTH.,#15649);
#15649 = SURFACE_SIDE_STYLE('',(#15650));
#15650 = SURFACE_STYLE_FILL_AREA(#15651);
#15651 = FILL_AREA_STYLE('',(#15652));
#15652 = FILL_AREA_STYLE_COLOUR('',#15231);
#15653 = STYLED_ITEM('color',(#15654),#4900);
#15654 = PRESENTATION_STYLE_ASSIGNMENT((#15655));
#15655 = SURFACE_STYLE_USAGE(.BOTH.,#15656);
#15656 = SURFACE_SIDE_STYLE('',(#15657));
#15657 = SURFACE_STYLE_FILL_AREA(#15658);
#15658 = FILL_AREA_STYLE('',(#15659));
#15659 = FILL_AREA_STYLE_COLOUR('',#15231);
#15660 = STYLED_ITEM('color',(#15661),#4978);
#15661 = PRESENTATION_STYLE_ASSIGNMENT((#15662));
#15662 = SURFACE_STYLE_USAGE(.BOTH.,#15663);
#15663 = SURFACE_SIDE_STYLE('',(#15664));
#15664 = SURFACE_STYLE_FILL_AREA(#15665);
#15665 = FILL_AREA_STYLE('',(#15666));
#15666 = FILL_AREA_STYLE_COLOUR('',#15231);
#15667 = STYLED_ITEM('color',(#15668),#5056);
#15668 = PRESENTATION_STYLE_ASSIGNMENT((#15669));
#15669 = SURFACE_STYLE_USAGE(.BOTH.,#15670);
#15670 = SURFACE_SIDE_STYLE('',(#15671));
#15671 = SURFACE_STYLE_FILL_AREA(#15672);
#15672 = FILL_AREA_STYLE('',(#15673));
#15673 = FILL_AREA_STYLE_COLOUR('',#15231);
#15674 = STYLED_ITEM('color',(#15675),#5134);
#15675 = PRESENTATION_STYLE_ASSIGNMENT((#15676));
#15676 = SURFACE_STYLE_USAGE(.BOTH.,#15677);
#15677 = SURFACE_SIDE_STYLE('',(#15678));
#15678 = SURFACE_STYLE_FILL_AREA(#15679);
#15679 = FILL_AREA_STYLE('',(#15680));
#15680 = FILL_AREA_STYLE_COLOUR('',#15231);
#15681 = STYLED_ITEM('color',(#15682),#5212);
#15682 = PRESENTATION_STYLE_ASSIGNMENT((#15683));
#15683 = SURFACE_STYLE_USAGE(.BOTH.,#15684);
#15684 = SURFACE_SIDE_STYLE('',(#15685));
#15685 = SURFACE_STYLE_FILL_AREA(#15686);
#15686 = FILL_AREA_STYLE('',(#15687));
#15687 = FILL_AREA_STYLE_COLOUR('',#15231);
#15688 = STYLED_ITEM('color',(#15689),#5288);
#15689 = PRESENTATION_STYLE_ASSIGNMENT((#15690));
#15690 = SURFACE_STYLE_USAGE(.BOTH.,#15691);
#15691 = SURFACE_SIDE_STYLE('',(#15692));
#15692 = SURFACE_STYLE_FILL_AREA(#15693);
#15693 = FILL_AREA_STYLE('',(#15694));
#15694 = FILL_AREA_STYLE_COLOUR('',#15231);
#15695 = STYLED_ITEM('color',(#15696),#5364);
#15696 = PRESENTATION_STYLE_ASSIGNMENT((#15697));
#15697 = SURFACE_STYLE_USAGE(.BOTH.,#15698);
#15698 = SURFACE_SIDE_STYLE('',(#15699));
#15699 = SURFACE_STYLE_FILL_AREA(#15700);
#15700 = FILL_AREA_STYLE('',(#15701));
#15701 = FILL_AREA_STYLE_COLOUR('',#15231);
#15702 = STYLED_ITEM('color',(#15703),#5440);
#15703 = PRESENTATION_STYLE_ASSIGNMENT((#15704));
#15704 = SURFACE_STYLE_USAGE(.BOTH.,#15705);
#15705 = SURFACE_SIDE_STYLE('',(#15706));
#15706 = SURFACE_STYLE_FILL_AREA(#15707);
#15707 = FILL_AREA_STYLE('',(#15708));
#15708 = FILL_AREA_STYLE_COLOUR('',#15231);
#15709 = STYLED_ITEM('color',(#15710),#5516);
#15710 = PRESENTATION_STYLE_ASSIGNMENT((#15711));
#15711 = SURFACE_STYLE_USAGE(.BOTH.,#15712);
#15712 = SURFACE_SIDE_STYLE('',(#15713));
#15713 = SURFACE_STYLE_FILL_AREA(#15714);
#15714 = FILL_AREA_STYLE('',(#15715));
#15715 = FILL_AREA_STYLE_COLOUR('',#15231);
#15716 = STYLED_ITEM('color',(#15717),#5592);
#15717 = PRESENTATION_STYLE_ASSIGNMENT((#15718));
#15718 = SURFACE_STYLE_USAGE(.BOTH.,#15719);
#15719 = SURFACE_SIDE_STYLE('',(#15720));
#15720 = SURFACE_STYLE_FILL_AREA(#15721);
#15721 = FILL_AREA_STYLE('',(#15722));
#15722 = FILL_AREA_STYLE_COLOUR('',#15231);
#15723 = STYLED_ITEM('color',(#15724),#5668);
#15724 = PRESENTATION_STYLE_ASSIGNMENT((#15725));
#15725 = SURFACE_STYLE_USAGE(.BOTH.,#15726);
#15726 = SURFACE_SIDE_STYLE('',(#15727));
#15727 = SURFACE_STYLE_FILL_AREA(#15728);
#15728 = FILL_AREA_STYLE('',(#15729));
#15729 = FILL_AREA_STYLE_COLOUR('',#15231);
#15730 = STYLED_ITEM('color',(#15731),#5746);
#15731 = PRESENTATION_STYLE_ASSIGNMENT((#15732));
#15732 = SURFACE_STYLE_USAGE(.BOTH.,#15733);
#15733 = SURFACE_SIDE_STYLE('',(#15734));
#15734 = SURFACE_STYLE_FILL_AREA(#15735);
#15735 = FILL_AREA_STYLE('',(#15736));
#15736 = FILL_AREA_STYLE_COLOUR('',#15231);
#15737 = STYLED_ITEM('color',(#15738),#5824);
#15738 = PRESENTATION_STYLE_ASSIGNMENT((#15739));
#15739 = SURFACE_STYLE_USAGE(.BOTH.,#15740);
#15740 = SURFACE_SIDE_STYLE('',(#15741));
#15741 = SURFACE_STYLE_FILL_AREA(#15742);
#15742 = FILL_AREA_STYLE('',(#15743));
#15743 = FILL_AREA_STYLE_COLOUR('',#15231);
#15744 = STYLED_ITEM('color',(#15745),#5900);
#15745 = PRESENTATION_STYLE_ASSIGNMENT((#15746));
#15746 = SURFACE_STYLE_USAGE(.BOTH.,#15747);
#15747 = SURFACE_SIDE_STYLE('',(#15748));
#15748 = SURFACE_STYLE_FILL_AREA(#15749);
#15749 = FILL_AREA_STYLE('',(#15750));
#15750 = FILL_AREA_STYLE_COLOUR('',#15231);
#15751 = STYLED_ITEM('color',(#15752),#5978);
#15752 = PRESENTATION_STYLE_ASSIGNMENT((#15753));
#15753 = SURFACE_STYLE_USAGE(.BOTH.,#15754);
#15754 = SURFACE_SIDE_STYLE('',(#15755));
#15755 = SURFACE_STYLE_FILL_AREA(#15756);
#15756 = FILL_AREA_STYLE('',(#15757));
#15757 = FILL_AREA_STYLE_COLOUR('',#15231);
#15758 = STYLED_ITEM('color',(#15759),#6056);
#15759 = PRESENTATION_STYLE_ASSIGNMENT((#15760));
#15760 = SURFACE_STYLE_USAGE(.BOTH.,#15761);
#15761 = SURFACE_SIDE_STYLE('',(#15762));
#15762 = SURFACE_STYLE_FILL_AREA(#15763);
#15763 = FILL_AREA_STYLE('',(#15764));
#15764 = FILL_AREA_STYLE_COLOUR('',#15231);
#15765 = STYLED_ITEM('color',(#15766),#6134);
#15766 = PRESENTATION_STYLE_ASSIGNMENT((#15767));
#15767 = SURFACE_STYLE_USAGE(.BOTH.,#15768);
#15768 = SURFACE_SIDE_STYLE('',(#15769));
#15769 = SURFACE_STYLE_FILL_AREA(#15770);
#15770 = FILL_AREA_STYLE('',(#15771));
#15771 = FILL_AREA_STYLE_COLOUR('',#15231);
#15772 = STYLED_ITEM('color',(#15773),#6212);
#15773 = PRESENTATION_STYLE_ASSIGNMENT((#15774));
#15774 = SURFACE_STYLE_USAGE(.BOTH.,#15775);
#15775 = SURFACE_SIDE_STYLE('',(#15776));
#15776 = SURFACE_STYLE_FILL_AREA(#15777);
#15777 = FILL_AREA_STYLE('',(#15778));
#15778 = FILL_AREA_STYLE_COLOUR('',#15231);
#15779 = STYLED_ITEM('color',(#15780),#6283);
#15780 = PRESENTATION_STYLE_ASSIGNMENT((#15781));
#15781 = SURFACE_STYLE_USAGE(.BOTH.,#15782);
#15782 = SURFACE_SIDE_STYLE('',(#15783));
#15783 = SURFACE_STYLE_FILL_AREA(#15784);
#15784 = FILL_AREA_STYLE('',(#15785));
#15785 = FILL_AREA_STYLE_COLOUR('',#15231);
#15786 = STYLED_ITEM('color',(#15787),#6330);
#15787 = PRESENTATION_STYLE_ASSIGNMENT((#15788));
#15788 = SURFACE_STYLE_USAGE(.BOTH.,#15789);
#15789 = SURFACE_SIDE_STYLE('',(#15790));
#15790 = SURFACE_STYLE_FILL_AREA(#15791);
#15791 = FILL_AREA_STYLE('',(#15792));
#15792 = FILL_AREA_STYLE_COLOUR('',#15231);
#15793 = STYLED_ITEM('color',(#15794),#6446);
#15794 = PRESENTATION_STYLE_ASSIGNMENT((#15795));
#15795 = SURFACE_STYLE_USAGE(.BOTH.,#15796);
#15796 = SURFACE_SIDE_STYLE('',(#15797));
#15797 = SURFACE_STYLE_FILL_AREA(#15798);
#15798 = FILL_AREA_STYLE('',(#15799));
#15799 = FILL_AREA_STYLE_COLOUR('',#15231);
#15800 = STYLED_ITEM('color',(#15801),#6522);
#15801 = PRESENTATION_STYLE_ASSIGNMENT((#15802));
#15802 = SURFACE_STYLE_USAGE(.BOTH.,#15803);
#15803 = SURFACE_SIDE_STYLE('',(#15804));
#15804 = SURFACE_STYLE_FILL_AREA(#15805);
#15805 = FILL_AREA_STYLE('',(#15806));
#15806 = FILL_AREA_STYLE_COLOUR('',#15231);
#15807 = STYLED_ITEM('color',(#15808),#6600);
#15808 = PRESENTATION_STYLE_ASSIGNMENT((#15809));
#15809 = SURFACE_STYLE_USAGE(.BOTH.,#15810);
#15810 = SURFACE_SIDE_STYLE('',(#15811));
#15811 = SURFACE_STYLE_FILL_AREA(#15812);
#15812 = FILL_AREA_STYLE('',(#15813));
#15813 = FILL_AREA_STYLE_COLOUR('',#15231);
#15814 = STYLED_ITEM('color',(#15815),#6678);
#15815 = PRESENTATION_STYLE_ASSIGNMENT((#15816));
#15816 = SURFACE_STYLE_USAGE(.BOTH.,#15817);
#15817 = SURFACE_SIDE_STYLE('',(#15818));
#15818 = SURFACE_STYLE_FILL_AREA(#15819);
#15819 = FILL_AREA_STYLE('',(#15820));
#15820 = FILL_AREA_STYLE_COLOUR('',#15231);
#15821 = STYLED_ITEM('color',(#15822),#6756);
#15822 = PRESENTATION_STYLE_ASSIGNMENT((#15823));
#15823 = SURFACE_STYLE_USAGE(.BOTH.,#15824);
#15824 = SURFACE_SIDE_STYLE('',(#15825));
#15825 = SURFACE_STYLE_FILL_AREA(#15826);
#15826 = FILL_AREA_STYLE('',(#15827));
#15827 = FILL_AREA_STYLE_COLOUR('',#15231);
#15828 = STYLED_ITEM('color',(#15829),#6834);
#15829 = PRESENTATION_STYLE_ASSIGNMENT((#15830));
#15830 = SURFACE_STYLE_USAGE(.BOTH.,#15831);
#15831 = SURFACE_SIDE_STYLE('',(#15832));
#15832 = SURFACE_STYLE_FILL_AREA(#15833);
#15833 = FILL_AREA_STYLE('',(#15834));
#15834 = FILL_AREA_STYLE_COLOUR('',#15231);
#15835 = STYLED_ITEM('color',(#15836),#6905);
#15836 = PRESENTATION_STYLE_ASSIGNMENT((#15837));
#15837 = SURFACE_STYLE_USAGE(.BOTH.,#15838);
#15838 = SURFACE_SIDE_STYLE('',(#15839));
#15839 = SURFACE_STYLE_FILL_AREA(#15840);
#15840 = FILL_AREA_STYLE('',(#15841));
#15841 = FILL_AREA_STYLE_COLOUR('',#15231);
#15842 = STYLED_ITEM('color',(#15843),#6952);
#15843 = PRESENTATION_STYLE_ASSIGNMENT((#15844));
#15844 = SURFACE_STYLE_USAGE(.BOTH.,#15845);
#15845 = SURFACE_SIDE_STYLE('',(#15846));
#15846 = SURFACE_STYLE_FILL_AREA(#15847);
#15847 = FILL_AREA_STYLE('',(#15848));
#15848 = FILL_AREA_STYLE_COLOUR('',#15231);
#15849 = STYLED_ITEM('color',(#15850),#6994);
#15850 = PRESENTATION_STYLE_ASSIGNMENT((#15851));
#15851 = SURFACE_STYLE_USAGE(.BOTH.,#15852);
#15852 = SURFACE_SIDE_STYLE('',(#15853));
#15853 = SURFACE_STYLE_FILL_AREA(#15854);
#15854 = FILL_AREA_STYLE('',(#15855));
#15855 = FILL_AREA_STYLE_COLOUR('',#15231);
#15856 = STYLED_ITEM('color',(#15857),#7038);
#15857 = PRESENTATION_STYLE_ASSIGNMENT((#15858));
#15858 = SURFACE_STYLE_USAGE(.BOTH.,#15859);
#15859 = SURFACE_SIDE_STYLE('',(#15860));
#15860 = SURFACE_STYLE_FILL_AREA(#15861);
#15861 = FILL_AREA_STYLE('',(#15862));
#15862 = FILL_AREA_STYLE_COLOUR('',#15231);
#15863 = STYLED_ITEM('color',(#15864),#7164);
#15864 = PRESENTATION_STYLE_ASSIGNMENT((#15865));
#15865 = SURFACE_STYLE_USAGE(.BOTH.,#15866);
#15866 = SURFACE_SIDE_STYLE('',(#15867));
#15867 = SURFACE_STYLE_FILL_AREA(#15868);
#15868 = FILL_AREA_STYLE('',(#15869));
#15869 = FILL_AREA_STYLE_COLOUR('',#15231);
#15870 = STYLED_ITEM('color',(#15871),#7242);
#15871 = PRESENTATION_STYLE_ASSIGNMENT((#15872));
#15872 = SURFACE_STYLE_USAGE(.BOTH.,#15873);
#15873 = SURFACE_SIDE_STYLE('',(#15874));
#15874 = SURFACE_STYLE_FILL_AREA(#15875);
#15875 = FILL_AREA_STYLE('',(#15876));
#15876 = FILL_AREA_STYLE_COLOUR('',#15231);
#15877 = STYLED_ITEM('color',(#15878),#7320);
#15878 = PRESENTATION_STYLE_ASSIGNMENT((#15879));
#15879 = SURFACE_STYLE_USAGE(.BOTH.,#15880);
#15880 = SURFACE_SIDE_STYLE('',(#15881));
#15881 = SURFACE_STYLE_FILL_AREA(#15882);
#15882 = FILL_AREA_STYLE('',(#15883));
#15883 = FILL_AREA_STYLE_COLOUR('',#15231);
#15884 = STYLED_ITEM('color',(#15885),#7398);
#15885 = PRESENTATION_STYLE_ASSIGNMENT((#15886));
#15886 = SURFACE_STYLE_USAGE(.BOTH.,#15887);
#15887 = SURFACE_SIDE_STYLE('',(#15888));
#15888 = SURFACE_STYLE_FILL_AREA(#15889);
#15889 = FILL_AREA_STYLE('',(#15890));
#15890 = FILL_AREA_STYLE_COLOUR('',#15231);
#15891 = STYLED_ITEM('color',(#15892),#7474);
#15892 = PRESENTATION_STYLE_ASSIGNMENT((#15893));
#15893 = SURFACE_STYLE_USAGE(.BOTH.,#15894);
#15894 = SURFACE_SIDE_STYLE('',(#15895));
#15895 = SURFACE_STYLE_FILL_AREA(#15896);
#15896 = FILL_AREA_STYLE('',(#15897));
#15897 = FILL_AREA_STYLE_COLOUR('',#15231);
#15898 = STYLED_ITEM('color',(#15899),#7550);
#15899 = PRESENTATION_STYLE_ASSIGNMENT((#15900));
#15900 = SURFACE_STYLE_USAGE(.BOTH.,#15901);
#15901 = SURFACE_SIDE_STYLE('',(#15902));
#15902 = SURFACE_STYLE_FILL_AREA(#15903);
#15903 = FILL_AREA_STYLE('',(#15904));
#15904 = FILL_AREA_STYLE_COLOUR('',#15231);
#15905 = STYLED_ITEM('color',(#15906),#7626);
#15906 = PRESENTATION_STYLE_ASSIGNMENT((#15907));
#15907 = SURFACE_STYLE_USAGE(.BOTH.,#15908);
#15908 = SURFACE_SIDE_STYLE('',(#15909));
#15909 = SURFACE_STYLE_FILL_AREA(#15910);
#15910 = FILL_AREA_STYLE('',(#15911));
#15911 = FILL_AREA_STYLE_COLOUR('',#15231);
#15912 = STYLED_ITEM('color',(#15913),#7704);
#15913 = PRESENTATION_STYLE_ASSIGNMENT((#15914));
#15914 = SURFACE_STYLE_USAGE(.BOTH.,#15915);
#15915 = SURFACE_SIDE_STYLE('',(#15916));
#15916 = SURFACE_STYLE_FILL_AREA(#15917);
#15917 = FILL_AREA_STYLE('',(#15918));
#15918 = FILL_AREA_STYLE_COLOUR('',#15231);
#15919 = STYLED_ITEM('color',(#15920),#7782);
#15920 = PRESENTATION_STYLE_ASSIGNMENT((#15921));
#15921 = SURFACE_STYLE_USAGE(.BOTH.,#15922);
#15922 = SURFACE_SIDE_STYLE('',(#15923));
#15923 = SURFACE_STYLE_FILL_AREA(#15924);
#15924 = FILL_AREA_STYLE('',(#15925));
#15925 = FILL_AREA_STYLE_COLOUR('',#15231);
#15926 = STYLED_ITEM('color',(#15927),#7860);
#15927 = PRESENTATION_STYLE_ASSIGNMENT((#15928));
#15928 = SURFACE_STYLE_USAGE(.BOTH.,#15929);
#15929 = SURFACE_SIDE_STYLE('',(#15930));
#15930 = SURFACE_STYLE_FILL_AREA(#15931);
#15931 = FILL_AREA_STYLE('',(#15932));
#15932 = FILL_AREA_STYLE_COLOUR('',#15231);
#15933 = STYLED_ITEM('color',(#15934),#7938);
#15934 = PRESENTATION_STYLE_ASSIGNMENT((#15935));
#15935 = SURFACE_STYLE_USAGE(.BOTH.,#15936);
#15936 = SURFACE_SIDE_STYLE('',(#15937));
#15937 = SURFACE_STYLE_FILL_AREA(#15938);
#15938 = FILL_AREA_STYLE('',(#15939));
#15939 = FILL_AREA_STYLE_COLOUR('',#15231);
#15940 = STYLED_ITEM('color',(#15941),#8014);
#15941 = PRESENTATION_STYLE_ASSIGNMENT((#15942));
#15942 = SURFACE_STYLE_USAGE(.BOTH.,#15943);
#15943 = SURFACE_SIDE_STYLE('',(#15944));
#15944 = SURFACE_STYLE_FILL_AREA(#15945);
#15945 = FILL_AREA_STYLE('',(#15946));
#15946 = FILL_AREA_STYLE_COLOUR('',#15231);
#15947 = STYLED_ITEM('color',(#15948),#8092);
#15948 = PRESENTATION_STYLE_ASSIGNMENT((#15949));
#15949 = SURFACE_STYLE_USAGE(.BOTH.,#15950);
#15950 = SURFACE_SIDE_STYLE('',(#15951));
#15951 = SURFACE_STYLE_FILL_AREA(#15952);
#15952 = FILL_AREA_STYLE('',(#15953));
#15953 = FILL_AREA_STYLE_COLOUR('',#15231);
#15954 = STYLED_ITEM('color',(#15955),#8170);
#15955 = PRESENTATION_STYLE_ASSIGNMENT((#15956));
#15956 = SURFACE_STYLE_USAGE(.BOTH.,#15957);
#15957 = SURFACE_SIDE_STYLE('',(#15958));
#15958 = SURFACE_STYLE_FILL_AREA(#15959);
#15959 = FILL_AREA_STYLE('',(#15960));
#15960 = FILL_AREA_STYLE_COLOUR('',#15231);
#15961 = STYLED_ITEM('color',(#15962),#8248);
#15962 = PRESENTATION_STYLE_ASSIGNMENT((#15963));
#15963 = SURFACE_STYLE_USAGE(.BOTH.,#15964);
#15964 = SURFACE_SIDE_STYLE('',(#15965));
#15965 = SURFACE_STYLE_FILL_AREA(#15966);
#15966 = FILL_AREA_STYLE('',(#15967));
#15967 = FILL_AREA_STYLE_COLOUR('',#15231);
#15968 = STYLED_ITEM('color',(#15969),#8326);
#15969 = PRESENTATION_STYLE_ASSIGNMENT((#15970));
#15970 = SURFACE_STYLE_USAGE(.BOTH.,#15971);
#15971 = SURFACE_SIDE_STYLE('',(#15972));
#15972 = SURFACE_STYLE_FILL_AREA(#15973);
#15973 = FILL_AREA_STYLE('',(#15974));
#15974 = FILL_AREA_STYLE_COLOUR('',#15231);
#15975 = STYLED_ITEM('color',(#15976),#8402);
#15976 = PRESENTATION_STYLE_ASSIGNMENT((#15977));
#15977 = SURFACE_STYLE_USAGE(.BOTH.,#15978);
#15978 = SURFACE_SIDE_STYLE('',(#15979));
#15979 = SURFACE_STYLE_FILL_AREA(#15980);
#15980 = FILL_AREA_STYLE('',(#15981));
#15981 = FILL_AREA_STYLE_COLOUR('',#15231);
#15982 = STYLED_ITEM('color',(#15983),#8480);
#15983 = PRESENTATION_STYLE_ASSIGNMENT((#15984));
#15984 = SURFACE_STYLE_USAGE(.BOTH.,#15985);
#15985 = SURFACE_SIDE_STYLE('',(#15986));
#15986 = SURFACE_STYLE_FILL_AREA(#15987);
#15987 = FILL_AREA_STYLE('',(#15988));
#15988 = FILL_AREA_STYLE_COLOUR('',#15231);
#15989 = STYLED_ITEM('color',(#15990),#8551);
#15990 = PRESENTATION_STYLE_ASSIGNMENT((#15991));
#15991 = SURFACE_STYLE_USAGE(.BOTH.,#15992);
#15992 = SURFACE_SIDE_STYLE('',(#15993));
#15993 = SURFACE_STYLE_FILL_AREA(#15994);
#15994 = FILL_AREA_STYLE('',(#15995));
#15995 = FILL_AREA_STYLE_COLOUR('',#15231);
#15996 = STYLED_ITEM('color',(#15997),#8598);
#15997 = PRESENTATION_STYLE_ASSIGNMENT((#15998));
#15998 = SURFACE_STYLE_USAGE(.BOTH.,#15999);
#15999 = SURFACE_SIDE_STYLE('',(#16000));
#16000 = SURFACE_STYLE_FILL_AREA(#16001);
#16001 = FILL_AREA_STYLE('',(#16002));
#16002 = FILL_AREA_STYLE_COLOUR('',#15231);
#16003 = STYLED_ITEM('color',(#16004),#8714);
#16004 = PRESENTATION_STYLE_ASSIGNMENT((#16005));
#16005 = SURFACE_STYLE_USAGE(.BOTH.,#16006);
#16006 = SURFACE_SIDE_STYLE('',(#16007));
#16007 = SURFACE_STYLE_FILL_AREA(#16008);
#16008 = FILL_AREA_STYLE('',(#16009));
#16009 = FILL_AREA_STYLE_COLOUR('',#15231);
#16010 = STYLED_ITEM('color',(#16011),#8792);
#16011 = PRESENTATION_STYLE_ASSIGNMENT((#16012));
#16012 = SURFACE_STYLE_USAGE(.BOTH.,#16013);
#16013 = SURFACE_SIDE_STYLE('',(#16014));
#16014 = SURFACE_STYLE_FILL_AREA(#16015);
#16015 = FILL_AREA_STYLE('',(#16016));
#16016 = FILL_AREA_STYLE_COLOUR('',#15231);
#16017 = STYLED_ITEM('color',(#16018),#8870);
#16018 = PRESENTATION_STYLE_ASSIGNMENT((#16019));
#16019 = SURFACE_STYLE_USAGE(.BOTH.,#16020);
#16020 = SURFACE_SIDE_STYLE('',(#16021));
#16021 = SURFACE_STYLE_FILL_AREA(#16022);
#16022 = FILL_AREA_STYLE('',(#16023));
#16023 = FILL_AREA_STYLE_COLOUR('',#15231);
#16024 = STYLED_ITEM('color',(#16025),#8948);
#16025 = PRESENTATION_STYLE_ASSIGNMENT((#16026));
#16026 = SURFACE_STYLE_USAGE(.BOTH.,#16027);
#16027 = SURFACE_SIDE_STYLE('',(#16028));
#16028 = SURFACE_STYLE_FILL_AREA(#16029);
#16029 = FILL_AREA_STYLE('',(#16030));
#16030 = FILL_AREA_STYLE_COLOUR('',#15231);
#16031 = STYLED_ITEM('color',(#16032),#9026);
#16032 = PRESENTATION_STYLE_ASSIGNMENT((#16033));
#16033 = SURFACE_STYLE_USAGE(.BOTH.,#16034);
#16034 = SURFACE_SIDE_STYLE('',(#16035));
#16035 = SURFACE_STYLE_FILL_AREA(#16036);
#16036 = FILL_AREA_STYLE('',(#16037));
#16037 = FILL_AREA_STYLE_COLOUR('',#15231);
#16038 = STYLED_ITEM('color',(#16039),#9104);
#16039 = PRESENTATION_STYLE_ASSIGNMENT((#16040));
#16040 = SURFACE_STYLE_USAGE(.BOTH.,#16041);
#16041 = SURFACE_SIDE_STYLE('',(#16042));
#16042 = SURFACE_STYLE_FILL_AREA(#16043);
#16043 = FILL_AREA_STYLE('',(#16044));
#16044 = FILL_AREA_STYLE_COLOUR('',#15231);
#16045 = STYLED_ITEM('color',(#16046),#9175);
#16046 = PRESENTATION_STYLE_ASSIGNMENT((#16047));
#16047 = SURFACE_STYLE_USAGE(.BOTH.,#16048);
#16048 = SURFACE_SIDE_STYLE('',(#16049));
#16049 = SURFACE_STYLE_FILL_AREA(#16050);
#16050 = FILL_AREA_STYLE('',(#16051));
#16051 = FILL_AREA_STYLE_COLOUR('',#15231);
#16052 = STYLED_ITEM('color',(#16053),#9222);
#16053 = PRESENTATION_STYLE_ASSIGNMENT((#16054));
#16054 = SURFACE_STYLE_USAGE(.BOTH.,#16055);
#16055 = SURFACE_SIDE_STYLE('',(#16056));
#16056 = SURFACE_STYLE_FILL_AREA(#16057);
#16057 = FILL_AREA_STYLE('',(#16058));
#16058 = FILL_AREA_STYLE_COLOUR('',#15231);
#16059 = STYLED_ITEM('color',(#16060),#9255);
#16060 = PRESENTATION_STYLE_ASSIGNMENT((#16061));
#16061 = SURFACE_STYLE_USAGE(.BOTH.,#16062);
#16062 = SURFACE_SIDE_STYLE('',(#16063));
#16063 = SURFACE_STYLE_FILL_AREA(#16064);
#16064 = FILL_AREA_STYLE('',(#16065));
#16065 = FILL_AREA_STYLE_COLOUR('',#15231);
#16066 = STYLED_ITEM('color',(#16067),#9290);
#16067 = PRESENTATION_STYLE_ASSIGNMENT((#16068));
#16068 = SURFACE_STYLE_USAGE(.BOTH.,#16069);
#16069 = SURFACE_SIDE_STYLE('',(#16070));
#16070 = SURFACE_STYLE_FILL_AREA(#16071);
#16071 = FILL_AREA_STYLE('',(#16072));
#16072 = FILL_AREA_STYLE_COLOUR('',#15231);
#16073 = STYLED_ITEM('color',(#16074),#9410);
#16074 = PRESENTATION_STYLE_ASSIGNMENT((#16075));
#16075 = SURFACE_STYLE_USAGE(.BOTH.,#16076);
#16076 = SURFACE_SIDE_STYLE('',(#16077));
#16077 = SURFACE_STYLE_FILL_AREA(#16078);
#16078 = FILL_AREA_STYLE('',(#16079));
#16079 = FILL_AREA_STYLE_COLOUR('',#15231);
#16080 = STYLED_ITEM('color',(#16081),#9488);
#16081 = PRESENTATION_STYLE_ASSIGNMENT((#16082));
#16082 = SURFACE_STYLE_USAGE(.BOTH.,#16083);
#16083 = SURFACE_SIDE_STYLE('',(#16084));
#16084 = SURFACE_STYLE_FILL_AREA(#16085);
#16085 = FILL_AREA_STYLE('',(#16086));
#16086 = FILL_AREA_STYLE_COLOUR('',#15231);
#16087 = STYLED_ITEM('color',(#16088),#9566);
#16088 = PRESENTATION_STYLE_ASSIGNMENT((#16089));
#16089 = SURFACE_STYLE_USAGE(.BOTH.,#16090);
#16090 = SURFACE_SIDE_STYLE('',(#16091));
#16091 = SURFACE_STYLE_FILL_AREA(#16092);
#16092 = FILL_AREA_STYLE('',(#16093));
#16093 = FILL_AREA_STYLE_COLOUR('',#15231);
#16094 = STYLED_ITEM('color',(#16095),#9644);
#16095 = PRESENTATION_STYLE_ASSIGNMENT((#16096));
#16096 = SURFACE_STYLE_USAGE(.BOTH.,#16097);
#16097 = SURFACE_SIDE_STYLE('',(#16098));
#16098 = SURFACE_STYLE_FILL_AREA(#16099);
#16099 = FILL_AREA_STYLE('',(#16100));
#16100 = FILL_AREA_STYLE_COLOUR('',#15231);
#16101 = STYLED_ITEM('color',(#16102),#9722);
#16102 = PRESENTATION_STYLE_ASSIGNMENT((#16103));
#16103 = SURFACE_STYLE_USAGE(.BOTH.,#16104);
#16104 = SURFACE_SIDE_STYLE('',(#16105));
#16105 = SURFACE_STYLE_FILL_AREA(#16106);
#16106 = FILL_AREA_STYLE('',(#16107));
#16107 = FILL_AREA_STYLE_COLOUR('',#15231);
#16108 = STYLED_ITEM('color',(#16109),#9798);
#16109 = PRESENTATION_STYLE_ASSIGNMENT((#16110));
#16110 = SURFACE_STYLE_USAGE(.BOTH.,#16111);
#16111 = SURFACE_SIDE_STYLE('',(#16112));
#16112 = SURFACE_STYLE_FILL_AREA(#16113);
#16113 = FILL_AREA_STYLE('',(#16114));
#16114 = FILL_AREA_STYLE_COLOUR('',#15231);
#16115 = STYLED_ITEM('color',(#16116),#9874);
#16116 = PRESENTATION_STYLE_ASSIGNMENT((#16117));
#16117 = SURFACE_STYLE_USAGE(.BOTH.,#16118);
#16118 = SURFACE_SIDE_STYLE('',(#16119));
#16119 = SURFACE_STYLE_FILL_AREA(#16120);
#16120 = FILL_AREA_STYLE('',(#16121));
#16121 = FILL_AREA_STYLE_COLOUR('',#15231);
#16122 = STYLED_ITEM('color',(#16123),#9950);
#16123 = PRESENTATION_STYLE_ASSIGNMENT((#16124));
#16124 = SURFACE_STYLE_USAGE(.BOTH.,#16125);
#16125 = SURFACE_SIDE_STYLE('',(#16126));
#16126 = SURFACE_STYLE_FILL_AREA(#16127);
#16127 = FILL_AREA_STYLE('',(#16128));
#16128 = FILL_AREA_STYLE_COLOUR('',#15231);
#16129 = STYLED_ITEM('color',(#16130),#10028);
#16130 = PRESENTATION_STYLE_ASSIGNMENT((#16131));
#16131 = SURFACE_STYLE_USAGE(.BOTH.,#16132);
#16132 = SURFACE_SIDE_STYLE('',(#16133));
#16133 = SURFACE_STYLE_FILL_AREA(#16134);
#16134 = FILL_AREA_STYLE('',(#16135));
#16135 = FILL_AREA_STYLE_COLOUR('',#15231);
#16136 = STYLED_ITEM('color',(#16137),#10106);
#16137 = PRESENTATION_STYLE_ASSIGNMENT((#16138));
#16138 = SURFACE_STYLE_USAGE(.BOTH.,#16139);
#16139 = SURFACE_SIDE_STYLE('',(#16140));
#16140 = SURFACE_STYLE_FILL_AREA(#16141);
#16141 = FILL_AREA_STYLE('',(#16142));
#16142 = FILL_AREA_STYLE_COLOUR('',#15231);
#16143 = STYLED_ITEM('color',(#16144),#10184);
#16144 = PRESENTATION_STYLE_ASSIGNMENT((#16145));
#16145 = SURFACE_STYLE_USAGE(.BOTH.,#16146);
#16146 = SURFACE_SIDE_STYLE('',(#16147));
#16147 = SURFACE_STYLE_FILL_AREA(#16148);
#16148 = FILL_AREA_STYLE('',(#16149));
#16149 = FILL_AREA_STYLE_COLOUR('',#15231);
#16150 = STYLED_ITEM('color',(#16151),#10262);
#16151 = PRESENTATION_STYLE_ASSIGNMENT((#16152));
#16152 = SURFACE_STYLE_USAGE(.BOTH.,#16153);
#16153 = SURFACE_SIDE_STYLE('',(#16154));
#16154 = SURFACE_STYLE_FILL_AREA(#16155);
#16155 = FILL_AREA_STYLE('',(#16156));
#16156 = FILL_AREA_STYLE_COLOUR('',#15231);
#16157 = STYLED_ITEM('color',(#16158),#10338);
#16158 = PRESENTATION_STYLE_ASSIGNMENT((#16159));
#16159 = SURFACE_STYLE_USAGE(.BOTH.,#16160);
#16160 = SURFACE_SIDE_STYLE('',(#16161));
#16161 = SURFACE_STYLE_FILL_AREA(#16162);
#16162 = FILL_AREA_STYLE('',(#16163));
#16163 = FILL_AREA_STYLE_COLOUR('',#15231);
#16164 = STYLED_ITEM('color',(#16165),#10414);
#16165 = PRESENTATION_STYLE_ASSIGNMENT((#16166));
#16166 = SURFACE_STYLE_USAGE(.BOTH.,#16167);
#16167 = SURFACE_SIDE_STYLE('',(#16168));
#16168 = SURFACE_STYLE_FILL_AREA(#16169);
#16169 = FILL_AREA_STYLE('',(#16170));
#16170 = FILL_AREA_STYLE_COLOUR('',#15231);
#16171 = STYLED_ITEM('color',(#16172),#10485);
#16172 = PRESENTATION_STYLE_ASSIGNMENT((#16173));
#16173 = SURFACE_STYLE_USAGE(.BOTH.,#16174);
#16174 = SURFACE_SIDE_STYLE('',(#16175));
#16175 = SURFACE_STYLE_FILL_AREA(#16176);
#16176 = FILL_AREA_STYLE('',(#16177));
#16177 = FILL_AREA_STYLE_COLOUR('',#15231);
#16178 = STYLED_ITEM('color',(#16179),#10532);
#16179 = PRESENTATION_STYLE_ASSIGNMENT((#16180));
#16180 = SURFACE_STYLE_USAGE(.BOTH.,#16181);
#16181 = SURFACE_SIDE_STYLE('',(#16182));
#16182 = SURFACE_STYLE_FILL_AREA(#16183);
#16183 = FILL_AREA_STYLE('',(#16184));
#16184 = FILL_AREA_STYLE_COLOUR('',#15231);
#16185 = STYLED_ITEM('color',(#16186),#10551);
#16186 = PRESENTATION_STYLE_ASSIGNMENT((#16187));
#16187 = SURFACE_STYLE_USAGE(.BOTH.,#16188);
#16188 = SURFACE_SIDE_STYLE('',(#16189));
#16189 = SURFACE_STYLE_FILL_AREA(#16190);
#16190 = FILL_AREA_STYLE('',(#16191));
#16191 = FILL_AREA_STYLE_COLOUR('',#15231);
#16192 = STYLED_ITEM('color',(#16193),#10572);
#16193 = PRESENTATION_STYLE_ASSIGNMENT((#16194));
#16194 = SURFACE_STYLE_USAGE(.BOTH.,#16195);
#16195 = SURFACE_SIDE_STYLE('',(#16196));
#16196 = SURFACE_STYLE_FILL_AREA(#16197);
#16197 = FILL_AREA_STYLE('',(#16198));
#16198 = FILL_AREA_STYLE_COLOUR('',#15231);
#16199 = STYLED_ITEM('color',(#16200),#10692);
#16200 = PRESENTATION_STYLE_ASSIGNMENT((#16201));
#16201 = SURFACE_STYLE_USAGE(.BOTH.,#16202);
#16202 = SURFACE_SIDE_STYLE('',(#16203));
#16203 = SURFACE_STYLE_FILL_AREA(#16204);
#16204 = FILL_AREA_STYLE('',(#16205));
#16205 = FILL_AREA_STYLE_COLOUR('',#15231);
#16206 = STYLED_ITEM('color',(#16207),#10768);
#16207 = PRESENTATION_STYLE_ASSIGNMENT((#16208));
#16208 = SURFACE_STYLE_USAGE(.BOTH.,#16209);
#16209 = SURFACE_SIDE_STYLE('',(#16210));
#16210 = SURFACE_STYLE_FILL_AREA(#16211);
#16211 = FILL_AREA_STYLE('',(#16212));
#16212 = FILL_AREA_STYLE_COLOUR('',#15231);
#16213 = STYLED_ITEM('color',(#16214),#10839);
#16214 = PRESENTATION_STYLE_ASSIGNMENT((#16215));
#16215 = SURFACE_STYLE_USAGE(.BOTH.,#16216);
#16216 = SURFACE_SIDE_STYLE('',(#16217));
#16217 = SURFACE_STYLE_FILL_AREA(#16218);
#16218 = FILL_AREA_STYLE('',(#16219));
#16219 = FILL_AREA_STYLE_COLOUR('',#15231);
#16220 = STYLED_ITEM('color',(#16221),#10886);
#16221 = PRESENTATION_STYLE_ASSIGNMENT((#16222));
#16222 = SURFACE_STYLE_USAGE(.BOTH.,#16223);
#16223 = SURFACE_SIDE_STYLE('',(#16224));
#16224 = SURFACE_STYLE_FILL_AREA(#16225);
#16225 = FILL_AREA_STYLE('',(#16226));
#16226 = FILL_AREA_STYLE_COLOUR('',#15231);
#16227 = STYLED_ITEM('color',(#16228),#10893);
#16228 = PRESENTATION_STYLE_ASSIGNMENT((#16229));
#16229 = SURFACE_STYLE_USAGE(.BOTH.,#16230);
#16230 = SURFACE_SIDE_STYLE('',(#16231));
#16231 = SURFACE_STYLE_FILL_AREA(#16232);
#16232 = FILL_AREA_STYLE('',(#16233));
#16233 = FILL_AREA_STYLE_COLOUR('',#15231);
#16234 = STYLED_ITEM('color',(#16235),#10902);
#16235 = PRESENTATION_STYLE_ASSIGNMENT((#16236));
#16236 = SURFACE_STYLE_USAGE(.BOTH.,#16237);
#16237 = SURFACE_SIDE_STYLE('',(#16238));
#16238 = SURFACE_STYLE_FILL_AREA(#16239);
#16239 = FILL_AREA_STYLE('',(#16240));
#16240 = FILL_AREA_STYLE_COLOUR('',#15231);
#16241 = STYLED_ITEM('color',(#16242),#11022);
#16242 = PRESENTATION_STYLE_ASSIGNMENT((#16243));
#16243 = SURFACE_STYLE_USAGE(.BOTH.,#16244);
#16244 = SURFACE_SIDE_STYLE('',(#16245));
#16245 = SURFACE_STYLE_FILL_AREA(#16246);
#16246 = FILL_AREA_STYLE('',(#16247));
#16247 = FILL_AREA_STYLE_COLOUR('',#15231);
#16248 = STYLED_ITEM('color',(#16249),#11098);
#16249 = PRESENTATION_STYLE_ASSIGNMENT((#16250));
#16250 = SURFACE_STYLE_USAGE(.BOTH.,#16251);
#16251 = SURFACE_SIDE_STYLE('',(#16252));
#16252 = SURFACE_STYLE_FILL_AREA(#16253);
#16253 = FILL_AREA_STYLE('',(#16254));
#16254 = FILL_AREA_STYLE_COLOUR('',#15231);
#16255 = STYLED_ITEM('color',(#16256),#11169);
#16256 = PRESENTATION_STYLE_ASSIGNMENT((#16257));
#16257 = SURFACE_STYLE_USAGE(.BOTH.,#16258);
#16258 = SURFACE_SIDE_STYLE('',(#16259));
#16259 = SURFACE_STYLE_FILL_AREA(#16260);
#16260 = FILL_AREA_STYLE('',(#16261));
#16261 = FILL_AREA_STYLE_COLOUR('',#15231);
#16262 = STYLED_ITEM('color',(#16263),#11216);
#16263 = PRESENTATION_STYLE_ASSIGNMENT((#16264));
#16264 = SURFACE_STYLE_USAGE(.BOTH.,#16265);
#16265 = SURFACE_SIDE_STYLE('',(#16266));
#16266 = SURFACE_STYLE_FILL_AREA(#16267);
#16267 = FILL_AREA_STYLE('',(#16268));
#16268 = FILL_AREA_STYLE_COLOUR('',#15231);
#16269 = STYLED_ITEM('color',(#16270),#11223);
#16270 = PRESENTATION_STYLE_ASSIGNMENT((#16271));
#16271 = SURFACE_STYLE_USAGE(.BOTH.,#16272);
#16272 = SURFACE_SIDE_STYLE('',(#16273));
#16273 = SURFACE_STYLE_FILL_AREA(#16274);
#16274 = FILL_AREA_STYLE('',(#16275));
#16275 = FILL_AREA_STYLE_COLOUR('',#15231);
#16276 = STYLED_ITEM('color',(#16277),#11232);
#16277 = PRESENTATION_STYLE_ASSIGNMENT((#16278));
#16278 = SURFACE_STYLE_USAGE(.BOTH.,#16279);
#16279 = SURFACE_SIDE_STYLE('',(#16280));
#16280 = SURFACE_STYLE_FILL_AREA(#16281);
#16281 = FILL_AREA_STYLE('',(#16282));
#16282 = FILL_AREA_STYLE_COLOUR('',#15231);
#16283 = STYLED_ITEM('color',(#16284),#11352);
#16284 = PRESENTATION_STYLE_ASSIGNMENT((#16285));
#16285 = SURFACE_STYLE_USAGE(.BOTH.,#16286);
#16286 = SURFACE_SIDE_STYLE('',(#16287));
#16287 = SURFACE_STYLE_FILL_AREA(#16288);
#16288 = FILL_AREA_STYLE('',(#16289));
#16289 = FILL_AREA_STYLE_COLOUR('',#15231);
#16290 = STYLED_ITEM('color',(#16291),#11430);
#16291 = PRESENTATION_STYLE_ASSIGNMENT((#16292));
#16292 = SURFACE_STYLE_USAGE(.BOTH.,#16293);
#16293 = SURFACE_SIDE_STYLE('',(#16294));
#16294 = SURFACE_STYLE_FILL_AREA(#16295);
#16295 = FILL_AREA_STYLE('',(#16296));
#16296 = FILL_AREA_STYLE_COLOUR('',#15231);
#16297 = STYLED_ITEM('color',(#16298),#11508);
#16298 = PRESENTATION_STYLE_ASSIGNMENT((#16299));
#16299 = SURFACE_STYLE_USAGE(.BOTH.,#16300);
#16300 = SURFACE_SIDE_STYLE('',(#16301));
#16301 = SURFACE_STYLE_FILL_AREA(#16302);
#16302 = FILL_AREA_STYLE('',(#16303));
#16303 = FILL_AREA_STYLE_COLOUR('',#15231);
#16304 = STYLED_ITEM('color',(#16305),#11586);
#16305 = PRESENTATION_STYLE_ASSIGNMENT((#16306));
#16306 = SURFACE_STYLE_USAGE(.BOTH.,#16307);
#16307 = SURFACE_SIDE_STYLE('',(#16308));
#16308 = SURFACE_STYLE_FILL_AREA(#16309);
#16309 = FILL_AREA_STYLE('',(#16310));
#16310 = FILL_AREA_STYLE_COLOUR('',#15231);
#16311 = STYLED_ITEM('color',(#16312),#11664);
#16312 = PRESENTATION_STYLE_ASSIGNMENT((#16313));
#16313 = SURFACE_STYLE_USAGE(.BOTH.,#16314);
#16314 = SURFACE_SIDE_STYLE('',(#16315));
#16315 = SURFACE_STYLE_FILL_AREA(#16316);
#16316 = FILL_AREA_STYLE('',(#16317));
#16317 = FILL_AREA_STYLE_COLOUR('',#15231);
#16318 = STYLED_ITEM('color',(#16319),#11740);
#16319 = PRESENTATION_STYLE_ASSIGNMENT((#16320));
#16320 = SURFACE_STYLE_USAGE(.BOTH.,#16321);
#16321 = SURFACE_SIDE_STYLE('',(#16322));
#16322 = SURFACE_STYLE_FILL_AREA(#16323);
#16323 = FILL_AREA_STYLE('',(#16324));
#16324 = FILL_AREA_STYLE_COLOUR('',#15231);
#16325 = STYLED_ITEM('color',(#16326),#11816);
#16326 = PRESENTATION_STYLE_ASSIGNMENT((#16327));
#16327 = SURFACE_STYLE_USAGE(.BOTH.,#16328);
#16328 = SURFACE_SIDE_STYLE('',(#16329));
#16329 = SURFACE_STYLE_FILL_AREA(#16330);
#16330 = FILL_AREA_STYLE('',(#16331));
#16331 = FILL_AREA_STYLE_COLOUR('',#15231);
#16332 = STYLED_ITEM('color',(#16333),#11892);
#16333 = PRESENTATION_STYLE_ASSIGNMENT((#16334));
#16334 = SURFACE_STYLE_USAGE(.BOTH.,#16335);
#16335 = SURFACE_SIDE_STYLE('',(#16336));
#16336 = SURFACE_STYLE_FILL_AREA(#16337);
#16337 = FILL_AREA_STYLE('',(#16338));
#16338 = FILL_AREA_STYLE_COLOUR('',#15231);
#16339 = STYLED_ITEM('color',(#16340),#11970);
#16340 = PRESENTATION_STYLE_ASSIGNMENT((#16341));
#16341 = SURFACE_STYLE_USAGE(.BOTH.,#16342);
#16342 = SURFACE_SIDE_STYLE('',(#16343));
#16343 = SURFACE_STYLE_FILL_AREA(#16344);
#16344 = FILL_AREA_STYLE('',(#16345));
#16345 = FILL_AREA_STYLE_COLOUR('',#15231);
#16346 = STYLED_ITEM('color',(#16347),#12048);
#16347 = PRESENTATION_STYLE_ASSIGNMENT((#16348));
#16348 = SURFACE_STYLE_USAGE(.BOTH.,#16349);
#16349 = SURFACE_SIDE_STYLE('',(#16350));
#16350 = SURFACE_STYLE_FILL_AREA(#16351);
#16351 = FILL_AREA_STYLE('',(#16352));
#16352 = FILL_AREA_STYLE_COLOUR('',#15231);
#16353 = STYLED_ITEM('color',(#16354),#12126);
#16354 = PRESENTATION_STYLE_ASSIGNMENT((#16355));
#16355 = SURFACE_STYLE_USAGE(.BOTH.,#16356);
#16356 = SURFACE_SIDE_STYLE('',(#16357));
#16357 = SURFACE_STYLE_FILL_AREA(#16358);
#16358 = FILL_AREA_STYLE('',(#16359));
#16359 = FILL_AREA_STYLE_COLOUR('',#15231);
#16360 = STYLED_ITEM('color',(#16361),#12204);
#16361 = PRESENTATION_STYLE_ASSIGNMENT((#16362));
#16362 = SURFACE_STYLE_USAGE(.BOTH.,#16363);
#16363 = SURFACE_SIDE_STYLE('',(#16364));
#16364 = SURFACE_STYLE_FILL_AREA(#16365);
#16365 = FILL_AREA_STYLE('',(#16366));
#16366 = FILL_AREA_STYLE_COLOUR('',#15231);
#16367 = STYLED_ITEM('color',(#16368),#12280);
#16368 = PRESENTATION_STYLE_ASSIGNMENT((#16369));
#16369 = SURFACE_STYLE_USAGE(.BOTH.,#16370);
#16370 = SURFACE_SIDE_STYLE('',(#16371));
#16371 = SURFACE_STYLE_FILL_AREA(#16372);
#16372 = FILL_AREA_STYLE('',(#16373));
#16373 = FILL_AREA_STYLE_COLOUR('',#15231);
#16374 = STYLED_ITEM('color',(#16375),#12356);
#16375 = PRESENTATION_STYLE_ASSIGNMENT((#16376));
#16376 = SURFACE_STYLE_USAGE(.BOTH.,#16377);
#16377 = SURFACE_SIDE_STYLE('',(#16378));
#16378 = SURFACE_STYLE_FILL_AREA(#16379);
#16379 = FILL_AREA_STYLE('',(#16380));
#16380 = FILL_AREA_STYLE_COLOUR('',#15231);
#16381 = STYLED_ITEM('color',(#16382),#12427);
#16382 = PRESENTATION_STYLE_ASSIGNMENT((#16383));
#16383 = SURFACE_STYLE_USAGE(.BOTH.,#16384);
#16384 = SURFACE_SIDE_STYLE('',(#16385));
#16385 = SURFACE_STYLE_FILL_AREA(#16386);
#16386 = FILL_AREA_STYLE('',(#16387));
#16387 = FILL_AREA_STYLE_COLOUR('',#15231);
#16388 = STYLED_ITEM('color',(#16389),#12474);
#16389 = PRESENTATION_STYLE_ASSIGNMENT((#16390));
#16390 = SURFACE_STYLE_USAGE(.BOTH.,#16391);
#16391 = SURFACE_SIDE_STYLE('',(#16392));
#16392 = SURFACE_STYLE_FILL_AREA(#16393);
#16393 = FILL_AREA_STYLE('',(#16394));
#16394 = FILL_AREA_STYLE_COLOUR('',#15231);
#16395 = STYLED_ITEM('color',(#16396),#12493);
#16396 = PRESENTATION_STYLE_ASSIGNMENT((#16397));
#16397 = SURFACE_STYLE_USAGE(.BOTH.,#16398);
#16398 = SURFACE_SIDE_STYLE('',(#16399));
#16399 = SURFACE_STYLE_FILL_AREA(#16400);
#16400 = FILL_AREA_STYLE('',(#16401));
#16401 = FILL_AREA_STYLE_COLOUR('',#15231);
#16402 = STYLED_ITEM('color',(#16403),#12514);
#16403 = PRESENTATION_STYLE_ASSIGNMENT((#16404));
#16404 = SURFACE_STYLE_USAGE(.BOTH.,#16405);
#16405 = SURFACE_SIDE_STYLE('',(#16406));
#16406 = SURFACE_STYLE_FILL_AREA(#16407);
#16407 = FILL_AREA_STYLE('',(#16408));
#16408 = FILL_AREA_STYLE_COLOUR('',#15231);
#16409 = STYLED_ITEM('color',(#16410),#12638);
#16410 = PRESENTATION_STYLE_ASSIGNMENT((#16411));
#16411 = SURFACE_STYLE_USAGE(.BOTH.,#16412);
#16412 = SURFACE_SIDE_STYLE('',(#16413));
#16413 = SURFACE_STYLE_FILL_AREA(#16414);
#16414 = FILL_AREA_STYLE('',(#16415));
#16415 = FILL_AREA_STYLE_COLOUR('',#15231);
#16416 = STYLED_ITEM('color',(#16417),#12716);
#16417 = PRESENTATION_STYLE_ASSIGNMENT((#16418));
#16418 = SURFACE_STYLE_USAGE(.BOTH.,#16419);
#16419 = SURFACE_SIDE_STYLE('',(#16420));
#16420 = SURFACE_STYLE_FILL_AREA(#16421);
#16421 = FILL_AREA_STYLE('',(#16422));
#16422 = FILL_AREA_STYLE_COLOUR('',#15231);
#16423 = STYLED_ITEM('color',(#16424),#12794);
#16424 = PRESENTATION_STYLE_ASSIGNMENT((#16425));
#16425 = SURFACE_STYLE_USAGE(.BOTH.,#16426);
#16426 = SURFACE_SIDE_STYLE('',(#16427));
#16427 = SURFACE_STYLE_FILL_AREA(#16428);
#16428 = FILL_AREA_STYLE('',(#16429));
#16429 = FILL_AREA_STYLE_COLOUR('',#15231);
#16430 = STYLED_ITEM('color',(#16431),#12872);
#16431 = PRESENTATION_STYLE_ASSIGNMENT((#16432));
#16432 = SURFACE_STYLE_USAGE(.BOTH.,#16433);
#16433 = SURFACE_SIDE_STYLE('',(#16434));
#16434 = SURFACE_STYLE_FILL_AREA(#16435);
#16435 = FILL_AREA_STYLE('',(#16436));
#16436 = FILL_AREA_STYLE_COLOUR('',#15231);
#16437 = STYLED_ITEM('color',(#16438),#12950);
#16438 = PRESENTATION_STYLE_ASSIGNMENT((#16439));
#16439 = SURFACE_STYLE_USAGE(.BOTH.,#16440);
#16440 = SURFACE_SIDE_STYLE('',(#16441));
#16441 = SURFACE_STYLE_FILL_AREA(#16442);
#16442 = FILL_AREA_STYLE('',(#16443));
#16443 = FILL_AREA_STYLE_COLOUR('',#15231);
#16444 = STYLED_ITEM('color',(#16445),#13028);
#16445 = PRESENTATION_STYLE_ASSIGNMENT((#16446));
#16446 = SURFACE_STYLE_USAGE(.BOTH.,#16447);
#16447 = SURFACE_SIDE_STYLE('',(#16448));
#16448 = SURFACE_STYLE_FILL_AREA(#16449);
#16449 = FILL_AREA_STYLE('',(#16450));
#16450 = FILL_AREA_STYLE_COLOUR('',#15231);
#16451 = STYLED_ITEM('color',(#16452),#13106);
#16452 = PRESENTATION_STYLE_ASSIGNMENT((#16453));
#16453 = SURFACE_STYLE_USAGE(.BOTH.,#16454);
#16454 = SURFACE_SIDE_STYLE('',(#16455));
#16455 = SURFACE_STYLE_FILL_AREA(#16456);
#16456 = FILL_AREA_STYLE('',(#16457));
#16457 = FILL_AREA_STYLE_COLOUR('',#15231);
#16458 = STYLED_ITEM('color',(#16459),#13182);
#16459 = PRESENTATION_STYLE_ASSIGNMENT((#16460));
#16460 = SURFACE_STYLE_USAGE(.BOTH.,#16461);
#16461 = SURFACE_SIDE_STYLE('',(#16462));
#16462 = SURFACE_STYLE_FILL_AREA(#16463);
#16463 = FILL_AREA_STYLE('',(#16464));
#16464 = FILL_AREA_STYLE_COLOUR('',#15231);
#16465 = STYLED_ITEM('color',(#16466),#13260);
#16466 = PRESENTATION_STYLE_ASSIGNMENT((#16467));
#16467 = SURFACE_STYLE_USAGE(.BOTH.,#16468);
#16468 = SURFACE_SIDE_STYLE('',(#16469));
#16469 = SURFACE_STYLE_FILL_AREA(#16470);
#16470 = FILL_AREA_STYLE('',(#16471));
#16471 = FILL_AREA_STYLE_COLOUR('',#15231);
#16472 = STYLED_ITEM('color',(#16473),#13338);
#16473 = PRESENTATION_STYLE_ASSIGNMENT((#16474));
#16474 = SURFACE_STYLE_USAGE(.BOTH.,#16475);
#16475 = SURFACE_SIDE_STYLE('',(#16476));
#16476 = SURFACE_STYLE_FILL_AREA(#16477);
#16477 = FILL_AREA_STYLE('',(#16478));
#16478 = FILL_AREA_STYLE_COLOUR('',#15231);
#16479 = STYLED_ITEM('color',(#16480),#13416);
#16480 = PRESENTATION_STYLE_ASSIGNMENT((#16481));
#16481 = SURFACE_STYLE_USAGE(.BOTH.,#16482);
#16482 = SURFACE_SIDE_STYLE('',(#16483));
#16483 = SURFACE_STYLE_FILL_AREA(#16484);
#16484 = FILL_AREA_STYLE('',(#16485));
#16485 = FILL_AREA_STYLE_COLOUR('',#15231);
#16486 = STYLED_ITEM('color',(#16487),#13494);
#16487 = PRESENTATION_STYLE_ASSIGNMENT((#16488));
#16488 = SURFACE_STYLE_USAGE(.BOTH.,#16489);
#16489 = SURFACE_SIDE_STYLE('',(#16490));
#16490 = SURFACE_STYLE_FILL_AREA(#16491);
#16491 = FILL_AREA_STYLE('',(#16492));
#16492 = FILL_AREA_STYLE_COLOUR('',#15231);
#16493 = STYLED_ITEM('color',(#16494),#13572);
#16494 = PRESENTATION_STYLE_ASSIGNMENT((#16495));
#16495 = SURFACE_STYLE_USAGE(.BOTH.,#16496);
#16496 = SURFACE_SIDE_STYLE('',(#16497));
#16497 = SURFACE_STYLE_FILL_AREA(#16498);
#16498 = FILL_AREA_STYLE('',(#16499));
#16499 = FILL_AREA_STYLE_COLOUR('',#15231);
#16500 = STYLED_ITEM('color',(#16501),#13650);
#16501 = PRESENTATION_STYLE_ASSIGNMENT((#16502));
#16502 = SURFACE_STYLE_USAGE(.BOTH.,#16503);
#16503 = SURFACE_SIDE_STYLE('',(#16504));
#16504 = SURFACE_STYLE_FILL_AREA(#16505);
#16505 = FILL_AREA_STYLE('',(#16506));
#16506 = FILL_AREA_STYLE_COLOUR('',#15231);
#16507 = STYLED_ITEM('color',(#16508),#13728);
#16508 = PRESENTATION_STYLE_ASSIGNMENT((#16509));
#16509 = SURFACE_STYLE_USAGE(.BOTH.,#16510);
#16510 = SURFACE_SIDE_STYLE('',(#16511));
#16511 = SURFACE_STYLE_FILL_AREA(#16512);
#16512 = FILL_AREA_STYLE('',(#16513));
#16513 = FILL_AREA_STYLE_COLOUR('',#15231);
#16514 = STYLED_ITEM('color',(#16515),#13799);
#16515 = PRESENTATION_STYLE_ASSIGNMENT((#16516));
#16516 = SURFACE_STYLE_USAGE(.BOTH.,#16517);
#16517 = SURFACE_SIDE_STYLE('',(#16518));
#16518 = SURFACE_STYLE_FILL_AREA(#16519);
#16519 = FILL_AREA_STYLE('',(#16520));
#16520 = FILL_AREA_STYLE_COLOUR('',#15231);
#16521 = STYLED_ITEM('color',(#16522),#13846);
#16522 = PRESENTATION_STYLE_ASSIGNMENT((#16523));
#16523 = SURFACE_STYLE_USAGE(.BOTH.,#16524);
#16524 = SURFACE_SIDE_STYLE('',(#16525));
#16525 = SURFACE_STYLE_FILL_AREA(#16526);
#16526 = FILL_AREA_STYLE('',(#16527));
#16527 = FILL_AREA_STYLE_COLOUR('',#15231);
#16528 = STYLED_ITEM('color',(#16529),#13866);
#16529 = PRESENTATION_STYLE_ASSIGNMENT((#16530));
#16530 = SURFACE_STYLE_USAGE(.BOTH.,#16531);
#16531 = SURFACE_SIDE_STYLE('',(#16532));
#16532 = SURFACE_STYLE_FILL_AREA(#16533);
#16533 = FILL_AREA_STYLE('',(#16534));
#16534 = FILL_AREA_STYLE_COLOUR('',#15231);
#16535 = STYLED_ITEM('color',(#16536),#13888);
#16536 = PRESENTATION_STYLE_ASSIGNMENT((#16537));
#16537 = SURFACE_STYLE_USAGE(.BOTH.,#16538);
#16538 = SURFACE_SIDE_STYLE('',(#16539));
#16539 = SURFACE_STYLE_FILL_AREA(#16540);
#16540 = FILL_AREA_STYLE('',(#16541));
#16541 = FILL_AREA_STYLE_COLOUR('',#15231);
#16542 = STYLED_ITEM('color',(#16543),#14008);
#16543 = PRESENTATION_STYLE_ASSIGNMENT((#16544));
#16544 = SURFACE_STYLE_USAGE(.BOTH.,#16545);
#16545 = SURFACE_SIDE_STYLE('',(#16546));
#16546 = SURFACE_STYLE_FILL_AREA(#16547);
#16547 = FILL_AREA_STYLE('',(#16548));
#16548 = FILL_AREA_STYLE_COLOUR('',#15231);
#16549 = STYLED_ITEM('color',(#16550),#14084);
#16550 = PRESENTATION_STYLE_ASSIGNMENT((#16551));
#16551 = SURFACE_STYLE_USAGE(.BOTH.,#16552);
#16552 = SURFACE_SIDE_STYLE('',(#16553));
#16553 = SURFACE_STYLE_FILL_AREA(#16554);
#16554 = FILL_AREA_STYLE('',(#16555));
#16555 = FILL_AREA_STYLE_COLOUR('',#15231);
#16556 = STYLED_ITEM('color',(#16557),#14160);
#16557 = PRESENTATION_STYLE_ASSIGNMENT((#16558));
#16558 = SURFACE_STYLE_USAGE(.BOTH.,#16559);
#16559 = SURFACE_SIDE_STYLE('',(#16560));
#16560 = SURFACE_STYLE_FILL_AREA(#16561);
#16561 = FILL_AREA_STYLE('',(#16562));
#16562 = FILL_AREA_STYLE_COLOUR('',#15231);
#16563 = STYLED_ITEM('color',(#16564),#14236);
#16564 = PRESENTATION_STYLE_ASSIGNMENT((#16565));
#16565 = SURFACE_STYLE_USAGE(.BOTH.,#16566);
#16566 = SURFACE_SIDE_STYLE('',(#16567));
#16567 = SURFACE_STYLE_FILL_AREA(#16568);
#16568 = FILL_AREA_STYLE('',(#16569));
#16569 = FILL_AREA_STYLE_COLOUR('',#15231);
#16570 = STYLED_ITEM('color',(#16571),#14312);
#16571 = PRESENTATION_STYLE_ASSIGNMENT((#16572));
#16572 = SURFACE_STYLE_USAGE(.BOTH.,#16573);
#16573 = SURFACE_SIDE_STYLE('',(#16574));
#16574 = SURFACE_STYLE_FILL_AREA(#16575);
#16575 = FILL_AREA_STYLE('',(#16576));
#16576 = FILL_AREA_STYLE_COLOUR('',#15231);
#16577 = STYLED_ITEM('color',(#16578),#14388);
#16578 = PRESENTATION_STYLE_ASSIGNMENT((#16579));
#16579 = SURFACE_STYLE_USAGE(.BOTH.,#16580);
#16580 = SURFACE_SIDE_STYLE('',(#16581));
#16581 = SURFACE_STYLE_FILL_AREA(#16582);
#16582 = FILL_AREA_STYLE('',(#16583));
#16583 = FILL_AREA_STYLE_COLOUR('',#15231);
#16584 = STYLED_ITEM('color',(#16585),#14459);
#16585 = PRESENTATION_STYLE_ASSIGNMENT((#16586));
#16586 = SURFACE_STYLE_USAGE(.BOTH.,#16587);
#16587 = SURFACE_SIDE_STYLE('',(#16588));
#16588 = SURFACE_STYLE_FILL_AREA(#16589);
#16589 = FILL_AREA_STYLE('',(#16590));
#16590 = FILL_AREA_STYLE_COLOUR('',#15231);
#16591 = STYLED_ITEM('color',(#16592),#14506);
#16592 = PRESENTATION_STYLE_ASSIGNMENT((#16593));
#16593 = SURFACE_STYLE_USAGE(.BOTH.,#16594);
#16594 = SURFACE_SIDE_STYLE('',(#16595));
#16595 = SURFACE_STYLE_FILL_AREA(#16596);
#16596 = FILL_AREA_STYLE('',(#16597));
#16597 = FILL_AREA_STYLE_COLOUR('',#15231);
#16598 = STYLED_ITEM('color',(#16599),#14616);
#16599 = PRESENTATION_STYLE_ASSIGNMENT((#16600));
#16600 = SURFACE_STYLE_USAGE(.BOTH.,#16601);
#16601 = SURFACE_SIDE_STYLE('',(#16602));
#16602 = SURFACE_STYLE_FILL_AREA(#16603);
#16603 = FILL_AREA_STYLE('',(#16604));
#16604 = FILL_AREA_STYLE_COLOUR('',#15231);
#16605 = STYLED_ITEM('color',(#16606),#14687);
#16606 = PRESENTATION_STYLE_ASSIGNMENT((#16607));
#16607 = SURFACE_STYLE_USAGE(.BOTH.,#16608);
#16608 = SURFACE_SIDE_STYLE('',(#16609));
#16609 = SURFACE_STYLE_FILL_AREA(#16610);
#16610 = FILL_AREA_STYLE('',(#16611));
#16611 = FILL_AREA_STYLE_COLOUR('',#15231);
#16612 = STYLED_ITEM('color',(#16613),#14734);
#16613 = PRESENTATION_STYLE_ASSIGNMENT((#16614));
#16614 = SURFACE_STYLE_USAGE(.BOTH.,#16615);
#16615 = SURFACE_SIDE_STYLE('',(#16616));
#16616 = SURFACE_STYLE_FILL_AREA(#16617);
#16617 = FILL_AREA_STYLE('',(#16618));
#16618 = FILL_AREA_STYLE_COLOUR('',#15231);
#16619 = STYLED_ITEM('color',(#16620),#14750);
#16620 = PRESENTATION_STYLE_ASSIGNMENT((#16621));
#16621 = SURFACE_STYLE_USAGE(.BOTH.,#16622);
#16622 = SURFACE_SIDE_STYLE('',(#16623));
#16623 = SURFACE_STYLE_FILL_AREA(#16624);
#16624 = FILL_AREA_STYLE('',(#16625));
#16625 = FILL_AREA_STYLE_COLOUR('',#15231);
#16626 = STYLED_ITEM('color',(#16627),#14768);
#16627 = PRESENTATION_STYLE_ASSIGNMENT((#16628));
#16628 = SURFACE_STYLE_USAGE(.BOTH.,#16629);
#16629 = SURFACE_SIDE_STYLE('',(#16630));
#16630 = SURFACE_STYLE_FILL_AREA(#16631);
#16631 = FILL_AREA_STYLE('',(#16632));
#16632 = FILL_AREA_STYLE_COLOUR('',#15231);
#16633 = STYLED_ITEM('color',(#16634),#14888);
#16634 = PRESENTATION_STYLE_ASSIGNMENT((#16635));
#16635 = SURFACE_STYLE_USAGE(.BOTH.,#16636);
#16636 = SURFACE_SIDE_STYLE('',(#16637));
#16637 = SURFACE_STYLE_FILL_AREA(#16638);
#16638 = FILL_AREA_STYLE('',(#16639));
#16639 = FILL_AREA_STYLE_COLOUR('',#15231);
#16640 = STYLED_ITEM('color',(#16641),#14964);
#16641 = PRESENTATION_STYLE_ASSIGNMENT((#16642));
#16642 = SURFACE_STYLE_USAGE(.BOTH.,#16643);
#16643 = SURFACE_SIDE_STYLE('',(#16644));
#16644 = SURFACE_STYLE_FILL_AREA(#16645);
#16645 = FILL_AREA_STYLE('',(#16646));
#16646 = FILL_AREA_STYLE_COLOUR('',#15231);
#16647 = STYLED_ITEM('color',(#16648),#15035);
#16648 = PRESENTATION_STYLE_ASSIGNMENT((#16649));
#16649 = SURFACE_STYLE_USAGE(.BOTH.,#16650);
#16650 = SURFACE_SIDE_STYLE('',(#16651));
#16651 = SURFACE_STYLE_FILL_AREA(#16652);
#16652 = FILL_AREA_STYLE('',(#16653));
#16653 = FILL_AREA_STYLE_COLOUR('',#15231);
#16654 = STYLED_ITEM('color',(#16655),#15082);
#16655 = PRESENTATION_STYLE_ASSIGNMENT((#16656));
#16656 = SURFACE_STYLE_USAGE(.BOTH.,#16657);
#16657 = SURFACE_SIDE_STYLE('',(#16658));
#16658 = SURFACE_STYLE_FILL_AREA(#16659);
#16659 = FILL_AREA_STYLE('',(#16660));
#16660 = FILL_AREA_STYLE_COLOUR('',#15231);
#16661 = STYLED_ITEM('color',(#16662),#15089);
#16662 = PRESENTATION_STYLE_ASSIGNMENT((#16663));
#16663 = SURFACE_STYLE_USAGE(.BOTH.,#16664);
#16664 = SURFACE_SIDE_STYLE('',(#16665));
#16665 = SURFACE_STYLE_FILL_AREA(#16666);
#16666 = FILL_AREA_STYLE('',(#16667));
#16667 = FILL_AREA_STYLE_COLOUR('',#15231);
ENDSEC;
END-ISO-10303-21;
I don't have the capability to compile freecad from source, so I had to run the 0.18-devel binary with wine. I see the same issue. Also, I believe the problem is with opening the STEP file, not saving it. I am attaching a STEP file generated with freecad 0.16. 0.16 displays it just fine. 0.17 and 0.18 do not pick up the color information, and all sides are gray. |
The colors for terminal-1,2,3 are correct but for some reason the color for the fusion object is not read-in. |
https://github.com/FreeCAD/FreeCAD/commit/9c7128ea77fc1046e11ebf2fbeb41216446eac4f |
| 2018-12-14 19:32 | mrnuke | New Issue | |
| 2018-12-14 19:35 | mrnuke | File Added: excelitas-as1052ac.fcstd | |
| 2018-12-14 19:35 | mrnuke | Note Added: 0012276 | |
| 2018-12-14 19:46 | mrnuke | Note Added: 0012277 | |
| 2018-12-14 23:30 | Kunda1 | Note Added: 0012278 | |
| 2018-12-15 02:54 | mrnuke | File Added: transforner-as1052-ac.step | |
| 2018-12-15 02:54 | mrnuke | Note Added: 0012279 | |
| 2018-12-23 19:53 | wmayer | Status | new => confirmed |
| 2018-12-23 19:53 | wmayer | Note Added: 0012335 | |
| 2018-12-24 16:28 | wmayer | Assigned To | => wmayer |
| 2018-12-24 16:28 | wmayer | Status | confirmed => closed |
| 2018-12-24 16:28 | wmayer | Resolution | open => fixed |
| 2018-12-24 16:28 | wmayer | Fixed in Version | => 0.18 |
| 2018-12-24 16:28 | wmayer | Note Added: 0012340 |
