| 0003756 | Part | Bug | public | 2018-12-31 18:58 | 2019-07-29 14:58 |
| Reporter | normandc | Assigned To | wmayer | ||
| Summary | 0003756: Tooltips should not start with the internal name of the tool | ||||
| Description | Many tooltips for Part command start with the internal name. For example, the tooltip for Part_Offset2D is The internal name should not appear in the tooltip, also it creates confusion for translators. These commands are the only ones in the whole FreeCAD GUI that do that. Affected tooltips: Part_Offset Part_Offset2D Part_JoinConnect Part_BooleanFragments Part_XOR Part_MakeFace Part_Slice Part_SliceApart | ||||
FreeCAD: master 70aaf3e9 2019-01-01 09:54:12 wmayer Details Diff |
fixes 0003756: Tooltips should not start with the internal name of the tool |
Affected Issues 0003756 |
| mod - src/Mod/Part/BOPTools/JoinFeatures.py | Diff File | ||
| mod - src/Mod/Part/BOPTools/SplitFeatures.py | Diff File | ||
| mod - src/Mod/Part/Gui/Command.cpp | Diff File | ||
| 2018-12-31 18:58 | normandc | New Issue | |
| 2019-01-01 15:54 | wmayer | Assigned To | => wmayer |
| 2019-01-01 15:54 | wmayer | Status | new => closed |
| 2019-01-01 15:54 | wmayer | Resolution | open => fixed |
| 2019-01-01 15:54 | wmayer | Fixed in Version | => 0.18 |
| 2019-01-01 15:54 | wmayer | Note Added: 0012357 | |
| 2019-07-29 14:58 | Kunda1 | Changeset attached | => FreeCAD master 70aaf3e9 |
