| 0003790 | Path | Bug | public | 2019-01-24 10:35 | 2021-02-06 06:33 |
| Reporter | sleeply4cat | Assigned To | shaiseger | ||
| Platform | Linux | OS | Ubuntu | OS Version | 16.04, 18.04 |
| Summary | 0003790: Volumetric milling simulation of arcs creating artifacts | ||||
| Description | The volumetric simulation of gear-like objects is pretty inaccurate:![]() Looks like it caused by a defect of the arc's end cup: its angular size two times smaller than it should be. | ||||
| Steps To Reproduce | 1. create path contains a gear (or any non-smooth path with "left" turn like this), test project is attached 2. start a simulation | ||||
| Additional Information | OS: Ubuntu 18.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15694 (Git) Build type: Release Branch: master Hash: 96dee91d5e7d7fd37f43a4dcf406a120ae1f1b8a Python version: 2.7.15rc1 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) These changes can correct the situation, but I have paws.. | ||||
| Tags | #post-to-forum, Path | ||||
deferring to mlampert |
I'm not familiar with the simulation framework in path. I believe shaise would be the best person to look at this. |
Assigning to @shaiseger |
@sleeply4cat can you do us a favor and please post first to the forum to discuss? The bugtracker doesn't get as much traffic as the forum. This is obvious from the lack of activity on 0003714 |
@shaiseger ping |
This ticket has been migrated to GitHub as issue 5869. |
| 2019-01-24 10:35 | sleeply4cat | New Issue | |
| 2019-01-24 10:35 | sleeply4cat | Tag Attached: Path | |
| 2019-01-24 10:35 | sleeply4cat | File Added: test.FCStd | |
| 2019-01-25 17:09 | Kunda1 | Assigned To | => mlampert |
| 2019-01-25 17:09 | Kunda1 | Status | new => assigned |
| 2019-01-25 17:09 | Kunda1 | Note Added: 0012507 | |
| 2019-01-25 23:23 | mlampert | Assigned To | mlampert => |
| 2019-01-25 23:25 | mlampert | Assigned To | => mlampert |
| 2019-01-25 23:25 | mlampert | Status | assigned => new |
| 2019-01-25 23:25 | mlampert | Note Added: 0012520 | |
| 2019-01-25 23:25 | mlampert | Assigned To | mlampert => |
| 2019-01-25 23:26 | Kunda1 | Assigned To | => shaiseger |
| 2019-01-25 23:26 | Kunda1 | Status | new => assigned |
| 2019-01-25 23:26 | Kunda1 | Note Added: 0012521 | |
| 2019-01-25 23:29 | Kunda1 | Note Added: 0012522 | |
| 2019-01-25 23:29 | Kunda1 | Note Edited: 0012522 | |
| 2020-01-08 18:19 | Kunda1 | Tag Attached: #post-to-forum | |
| 2020-01-08 18:19 | Kunda1 | Note Added: 0014020 | |
| 2021-02-06 06:33 | abdullah | Target Version | => 0.20 |
