| 0003792 | FreeCAD | Bug | public | 2019-01-25 06:56 | 2019-01-29 18:22 |
| Reporter | Juzujka | Assigned To | |||
| Priority | normal | Severity | block | Reproducibility | have not tried |
| Platform | Linux | OS | Ubuntu | OS Version | 18.04.1 LTS |
| Summary | 0003792: part disappears after adding sketch | ||||
| Description | I wanted to make a sketch inside part. | ||||
| Steps To Reproduce | 1. add sketch 2. move to part (SFP_module_sealed_connector_medium) part in tree, but invisible 3. I move some bodies outside part, body appears | ||||
| Tags | Sketch | ||||
other steps to reproduce 1) I have project with parts inside parts. 2) choose Sketcher. 3) New Sketch. 4) In the Tree view move sketch from root to part in part. 5) Try to edit Sketch 6) CRUSH |
Your project has a cyclic dependency and thus is broken. The part container SFP_module_sealed_connector_medium (internal name is Part009) has a dependency to itself. Run the Python snippet below to see if this fixes it. |
@Juzujka please follow our guidelines (big yellow banner at the top of the page). We ask not to post only 0.18dev tickets and also to verify if the issue is in fact a bug by first confirming in the forums. Marking this ticket as 'Feedback' |
Thank you, wmayer. The part appears. Can you tell me, how have you find it? How to find cyclic dependencies in a FreeCAD project? (and do not make it). I do not see in Python console messages about dependencies.
and nothing more. |
I have found Tools->Dependency graph This tool helps! |
No change required Closing ticket |
| 2019-01-25 06:56 | Juzujka | New Issue | |
| 2019-01-25 06:56 | Juzujka | Tag Attached: Sketch | |
| 2019-01-25 06:56 | Juzujka | File Added: Screenshot from 2019-01-25 09-43-11.png | |
| 2019-01-25 06:56 | Juzujka | File Added: error_part_disappears.FCStd | |
| 2019-01-25 09:07 | Juzujka | Note Added: 0012506 | |
| 2019-01-25 17:11 | wmayer | Note Added: 0012508 | |
| 2019-01-25 17:26 | Kunda1 | Status | new => feedback |
| 2019-01-25 17:26 | Kunda1 | Note Added: 0012513 | |
| 2019-01-28 07:21 | Juzujka | Note Added: 0012537 | |
| 2019-01-28 07:21 | Juzujka | Status | feedback => new |
| 2019-01-28 07:22 | Juzujka | Note Edited: 0012537 | |
| 2019-01-28 16:28 | Juzujka | Note Added: 0012545 | |
| 2019-01-29 18:22 | Kunda1 | Status | new => closed |
| 2019-01-29 18:22 | Kunda1 | Resolution | open => no change required |
| 2019-01-29 18:22 | Kunda1 | Note Added: 0012555 |
