| 0003800 | TechDraw | Bug | public | 2019-01-27 03:47 | 2019-02-14 20:44 |
| Reporter | uwestoehr | Assigned To | wandererfan | ||
| Summary | 0003800: wrong PDF page size on exporting tech drawings | ||||
| Description | I stumbled above a bug in FreeCAD Windows 7 64-bit Version: 0.18.15694 (Git) - create a drawing from a body of your choice and select as template "A2_Landscape_ISO7200TD.svg" - use the menu File -> Export and export the drawing to a PDF result: the resulting PDF is neither in the format A2 nor landscape - it is A4 portrait I know that I can use instead the menu File -> Export PDF but the menu File -> Export should work as well. p.s. I tried to report this first to the Open discussion forum but the software only tells me "You cannot make another post so soon after your last." but https://forum.freecadweb.org/search.php?search_id=egosearch tells me that I have not made any post. (which is obviously correct) p.p.s Forum post: https://forum.freecadweb.org/viewtopic.php?f=35&t=33760 | ||||
| Tags | TechDraw | ||||
Hmm, now after a few hours my forum post went through: https://forum.freecadweb.org/viewtopic.php?f=35&t=33760 |
Assigning to wandererfan |
https://github.com/FreeCAD/FreeCAD/commit/a2bca22fc9dbc3cbecc210bbf41d0c920f34f036 |
| 2019-01-27 03:47 | uwestoehr | New Issue | |
| 2019-01-27 03:47 | uwestoehr | Tag Attached: TechDraw | |
| 2019-01-27 14:42 | uwestoehr | Note Added: 0012533 | |
| 2019-01-29 18:26 | Kunda1 | Description Updated | |
| 2019-01-29 18:26 | Kunda1 | Assigned To | => wandererfan |
| 2019-01-29 18:26 | Kunda1 | Status | new => assigned |
| 2019-01-29 18:26 | Kunda1 | Note Added: 0012557 | |
| 2019-02-14 20:44 | wmayer | Status | assigned => closed |
| 2019-02-14 20:44 | wmayer | Resolution | open => fixed |
| 2019-02-14 20:44 | wmayer | Fixed in Version | => 0.18 |
| 2019-02-14 20:44 | wmayer | Note Added: 0012640 |
