| 0003807 | FreeCAD | Bug | public | 2019-01-28 23:42 | 2019-07-29 14:57 |
| Reporter | mywave82 | Assigned To | wmayer | ||
| OS Version | git master | ||||
| Summary | 0003807: STEP export with BaseFeature does not hide BaseObject | ||||
| Description | When creating an object that can have BaseFeature, both the original and the child reference gets exported. | ||||
| Steps To Reproduce | * Install FCGear Module * Create a Gear * Optionally move the Gear into a part/body, creating a BaseFeature of the Gear * Add more operations to the Body (examples being rotation, translation and subtracting functions) * (In the Part-Designer in FreeCAD, everything looks normal) * File->Export As, and make a STEP model The exported STEP file now contains two copies of the Gear. One original and one that contains the operation done in the part/body. STEP file is too large for upload (15M) | ||||
| Tags | export, STEP | ||||
@mywave82 please add the file via 3rd party hosting service (dropbox, google drive etc..) Also please post the full FreeCAD version you are using Help > About FreeCAD > Copy to clipboard and also the FCGear version you are using. |
OS: Ubuntu 18.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15703 +6 (Git) Build type: Debug Branch: cMake-report Hash: bd66a158cd1d43ce717c342183c885bbecf14e62 Python version: 3.6.7 Qt version: 5.12.0 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United States (en_US) Built using https://github.com/FreeCAD/FreeCAD/pull/1930 -- Python: [/usr/bin/python3] [.cpython-36m-x86_64-linux-gnu] -- PCL: not enabled -- pybind11: not enabled -- Boost: 106501 -- XercesC: [/usr/lib/x86_64-linux-gnu/libxerces-c.so] [/usr/include] -- ZLIB: 1.2.11 -- PyCXX: [/home/stian/FreeCAD/FreeCAD.mywave82-4/src] -- OCC: 7.3.0 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBin;TKBool;TKBO;TKCDF;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEP;TKSTEPBase;TKSTEPAttr;TKHLR;TKFeat] -- SMESH: build internal -- MEDFile: [/usr/lib/x86_64-linux-gnu/libmedC.so;/usr/lib/x86_64-linux-gnu/libmed.so] [/usr/include] -- HDF5: 1.8.13 -- VTK: 8.2.0 -- NETGEN: 6.2-dev [-DNO_PARALLEL_THREADS;-DOCCGEOMETRY;-DNETGEN_VERSION=393728] [] [/usr/local/include/include;/usr/local/include] [nglib] [/usr/local/include/include;/usr/local/include] -- SWIG: 3.0.12 -- Eigen3 3.3.4 -- Qt5Core: 5.12.0 -- Qt5Network: 5.12.0 -- Qt5Xml: 5.12.0 -- Qt5Widgets: 5.12.0 -- Qt5PrintSupport: 5.12.0 -- Qt5OpenGL: 5.12.0 -- Qt5Svg: 5.12.0 -- Qt5UiTools: 5.12.0 -- Qt5Concurrent: 5.12.0 -- Qt5WebKitWidgets: not needed (BUILD_WEB) -- Shiboken2: 5.12.1 [/home/stian/pyside-setup/pyside3_install/py3.6-qt5.12.0-64bit-release/lib/cmake/Shiboken2-5.12.1] [/home/stian/pyside-setup/pyside3_install/py3.6-qt5.12.0-64bit-release/include/shiboken2] -- PySide2: 5.12.1 [/home/stian/pyside-setup/pyside3_install/py3.6-qt5.12.0-64bit-release/include/PySide2] -- PySide2Tools: [/home/stian/pyside-setup/pyside3_install/py3.6-qt5.12.0-64bit-release/bin/pyside2-uic] [/home/stian/pyside-setup/pyside3_install/py3.6-qt5.12.0-64bit-release/bin/pyside2-rcc] -- Freetype: 2.8.1 -- OpenGLU: /usr/lib/x86_64-linux-gnu/libGLU.so [/usr/lib/x86_64-linux-gnu/libGLU.so][/usr/include] -- Coin3D: [/usr/local/lib/libCoin.so] [/usr/local/include] -- SPNAV: [/usr/lib/libspnav.so] [/usr/include] -- Matplotlib: 2.1.1 -- Rift: not enabled (BUILD_VR) -- Doxygen: not found FCGears I do not think have any proper versioning, but it has not been updated a lot lately. https://github.com/looooo/freecad.gears $ |
test1.step (via Google Drive) |
https://github.com/FreeCAD/FreeCAD/commit/0852dde409a0375f0be99e5713c39f3f0c5d4810 A workaround for older versions is to move the imported gear outside the Part container. |
| 2019-01-28 23:42 | mywave82 | New Issue | |
| 2019-01-28 23:42 | mywave82 | File Added: Screenshot at 2019-01-26 05-19-27.png | |
| 2019-01-28 23:42 | mywave82 | File Added: Screenshot at 2019-01-29 00-31-24.png | |
| 2019-01-28 23:42 | mywave82 | File Added: Screenshot at 2019-01-29 00-34-06.png | |
| 2019-01-29 18:24 | Kunda1 | Note Added: 0012556 | |
| 2019-01-29 18:24 | Kunda1 | Tag Attached: STEP | |
| 2019-01-29 18:24 | Kunda1 | Tag Attached: export | |
| 2019-01-29 18:25 | Kunda1 | Status | new => feedback |
| 2019-01-29 18:43 | mywave82 | Note Added: 0012559 | |
| 2019-01-29 18:43 | mywave82 | Status | feedback => new |
| 2019-01-29 18:45 | mywave82 | File Added: test1.FCStd | |
| 2019-01-29 18:47 | mywave82 | Note Added: 0012560 | |
| 2019-02-23 18:45 | wmayer | Assigned To | => wmayer |
| 2019-02-23 18:45 | wmayer | Status | new => closed |
| 2019-02-23 18:45 | wmayer | Resolution | open => fixed |
| 2019-02-23 18:45 | wmayer | Fixed in Version | => 0.18 |
| 2019-02-23 18:45 | wmayer | Note Added: 0012733 | |
| 2019-07-29 14:57 | Kunda1 | Changeset attached | => FreeCAD releases/FreeCAD-0-18 0852dde4 |
