| 0003809 | TechDraw | Bug | public | 2019-01-29 20:05 | 2019-02-14 20:43 |
| Reporter | uwestoehr | Assigned To | wandererfan | ||
| Summary | 0003809: Some ProjGroup settings have no effect | ||||
| Description | - select a body and create a new drawing page - use the menu TechDraw -> Insert Projection Group to create a projected view - now select the ProjGroup and go into the property window - change the rotation and the x- and y-position result: nothing happens, no rotation, no displacement Other settings like e.g. the Scale for fine, only position and rotation do not. If they are intended to have no effect in this respect, the fields should be disabled. | ||||
| Additional Information | Forum thread: https://forum.freecadweb.org/viewtopic.php?p=283111#p283111 Windows 7 64-bit, Version: 0.18.15711 (Git) | ||||
Rotation property is not applicable to ProjectionGroup. The Rotation property for ProjectionGroups has been hidden by commit 0c5629870c. |
@wandererfan so this is has changed in to a feature request? |
> so this is has changed in to a feature request? No. The rotation issue has been solved. The problem remains that for ProjectionGroup FC offers a displacement feature. Either this do actually displace. if Displacement is not applicable for ProjectionGroup this property must be hidden or disabled. |
@Kunda1 wrote: "@wandererfan so this is has changed in to a feature request?" Still a bug. X/Y properties need to be fixed. Rotation was an easy fix I could do while travelling. |
https://github.com/FreeCAD/FreeCAD/commit/41ab00c1164ab0781f5c7db0da7245784312d86f |
| 2019-01-29 20:05 | uwestoehr | New Issue | |
| 2019-01-30 14:17 | wandererfan | Note Added: 0012563 | |
| 2019-01-30 14:19 | wandererfan | Assigned To | => wandererfan |
| 2019-01-30 14:19 | wandererfan | Status | new => acknowledged |
| 2019-01-30 14:19 | wandererfan | Target Version | => 0.18 |
| 2019-01-30 14:19 | wandererfan | Summary | ProjGroup settings have no effect => Some ProjGroup settings have no effect |
| 2019-02-11 11:02 | Kunda1 | Note Added: 0012623 | |
| 2019-02-11 12:29 | uwestoehr | Note Added: 0012625 | |
| 2019-02-11 13:50 | wandererfan | Note Added: 0012627 | |
| 2019-02-14 20:43 | wmayer | Status | acknowledged => closed |
| 2019-02-14 20:43 | wmayer | Resolution | open => fixed |
| 2019-02-14 20:43 | wmayer | Fixed in Version | => 0.18 |
| 2019-02-14 20:43 | wmayer | Note Added: 0012639 |
