| 0000382 | Assembly | Feature | public | 2011-06-21 04:12 | 2019-05-09 01:15 |
| Reporter | tombrown19 | Assigned To | yorik | ||
| Summary | 0000382: Feature request: note fields on objects | ||||
| Description | I would like to request the addition of two fields for each object. Notes - QTextEdit for storing notes about an object (ie: specific thoughts on how to machine the object, etc... eg: waterjet and then face mill after cryo treatment) Material - QLineEdit for entering the material type (eg: plywood, aluminum, etc.) | ||||
Actually do that for every object would be overkill. I will do that for the Assembly objects which will get a full set of STEP product properties, including those you mentioned. |
Unassigning Jriegel |
Both these features are available in Arch (Description property and Material) as well as several other workbenches now... I think we can consider it implemented |
| 2011-06-21 04:12 | tombrown19 | New Issue | |
| 2011-06-24 15:17 |
Status | new => assigned |
| 2011-06-24 15:17 |
Assigned To | => Jriegel |
| 2011-06-24 15:19 |
Note Added: 0000910 | |
| 2017-02-21 17:45 | Kunda1 | Project | FreeCAD => Assembly |
| 2018-06-13 13:26 | Kunda1 | Assigned To | Jriegel => |
| 2018-06-13 13:26 | Kunda1 | Status | assigned => confirmed |
| 2018-06-13 13:26 | Kunda1 | Note Added: 0011422 | |
| 2019-05-09 01:15 | yorik | Note Added: 0013086 | |
| 2019-05-09 01:15 | yorik | Assigned To | => yorik |
| 2019-05-09 01:15 | yorik | Status | confirmed => closed |
| 2019-05-09 01:15 | yorik | Resolution | open => fixed |
| 2019-05-09 01:15 | yorik | Fixed in Version | => 0.17 |
