| 0003827 | Arch | Bug | public | 2019-02-09 16:26 | 2019-02-20 13:08 |
| Reporter | kazan417 | Assigned To | yorik | ||
| Platform | PC | OS | windows | OS Version | 10 |
| Summary | 0003827: Can not add panel in language different to english | ||||
| Description | In language different from English, panel tools is not working. | ||||
| Steps To Reproduce | Select edit->preferences, chose language(Russian for example), press apply. In arch workbench select panel tools(Инструменты панели). Select point in 3d space and nothing happened. Panel is not creating. | ||||
| Additional Information | It is not working for many languages different from English. | ||||
@kazan417 is there a forum thread discussion created for this thread? |
No. Forom thread does not exist. |
I have no problem using the Arch Panel tool in any language, I just tested russian, it works fine... Please inform your FreeCAD version as asked in the yellow note at the top of this page? |
OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15806 (Git) Build type: Release Branch: master Hash: 18b5f238ae53e3c19cb6e985f450a098dc0d6d23 Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: Russian/RussianFederation (ru_RU) |
Here is video of glitch |
Very strange, I can do the same as you, but the panel works without problems. Can you check this: 1) Open the report panel from menu Views->Panels and check that no error message appears when using the panel tool 2) Do other Arch tools (wall, structure,..) work? 3) Do 2D tools (line, rectangle,..) work? |
I got long log with many errors, so attching it as file. (looks like this errors related to another bug) errorlog.txt (141,532 bytes)
Enumeration index -1 is out of range, ignore it
Upgrading Structure Role property to IfcRole
Upgrading Upper floor main beam Role property to IfcRole
Upgrading Upper floor front beam 02 Role property to IfcRole
Upgrading Upper floor front beam 01 Role property to IfcRole
Upgrading Upper floor slab Role property to IfcRole
Upgrading Roof main beam Role property to IfcRole
Upgrading Roof front beam 02 Role property to IfcRole
Upgrading Roof front beam 01 Role property to IfcRole
Upgrading Structure009 Role property to IfcRole
Upgrading Ground floor main beam Role property to IfcRole
Upgrading Footing Role property to IfcRole
Upgrading Roof slab Role property to IfcRole
Upgrading Ground floor slab 02 Role property to IfcRole
Upgrading Ground floor slab 01 Role property to IfcRole
Upgrading Curb slab Role property to IfcRole
Upgrading Curb border Role property to IfcRole
Upgrading Balcony horizontal support 02 Role property to IfcRole
Upgrading Balcony horizontal support 01 Role property to IfcRole
Upgrading Balcony beam 01 Role property to IfcRole
Upgrading Balcony beam 02 Role property to IfcRole
Upgrading Balcony slab Role property to IfcRole
Upgrading Roof wall Role property to IfcRole
Upgrading Upper floor column Role property to IfcRole
Upgrading Ground floor column Role property to IfcRole
���� �������� : [:������� ������ �������, Z:�������� �� Z, Q:������� ������������ ���� �������, ]:������ ������ �������, Y:�������� �� Y, X:�������� �� X, S:������� ���/���
<type 'exceptions.AttributeError'>
File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftSnap.py", line 1182, in move
self.pt = FreeCADGui.Snapper.snap(mousepos,lastpoint=last,active=ctrl,constrain=shift)
File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftSnap.py", line 303, in snap
snaps.extend(self.snapToSpecials(obj,lastpoint,eline))
File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftSnap.py", line 921, in snapToSpecials
if obj.ViewObject.ShowNodes:
AttributeError: 'Gui.ViewProviderDocumentObject' object has no attribute 'ShowNodes'
typecheck[tup]: None is not <type 'Base.Vector'>
<type 'exceptions.TypeError'>
File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftSnap.py", line 1186, in move
movecallback(self.pt,self.snapInfo)
File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Arch\ArchPanel.py", line 287, in update
self.tracker.pos(point)
File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftTrackers.py", line 938, in pos
self.trans.translation.setValue(DraftVecUtils.tup(p))
File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftVecUtils.py", line 75, in tup
typecheck ([(u,Vector)], "tup");
File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftVecUtils.py", line 56, in typecheck
raise TypeError("fcvec." + str(name))
TypeError: fcvec.tup
UnicodeEncodeError: 'ascii' codec can't encode characters in position 0-6: ordinal not in range(128) I think last line shows that something with language encoding is wrong |
now i got shorter log from japanese language (also can not create panel) 点 オプション : [:スナップ半径を増やす, Z:Z 制限, Q:カスタムスナップポイントを追加, ]:スナップ半径を減らす, Y:Y 制限, X:X 制限, S:スナップのオン/オフ <type 'exceptions.UnicodeEncodeError'> Traceback (most recent call last): File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftSnap.py", line 1199, in click accept() File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftSnap.py", line 1213, in accept callback(self.pt,obj) File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Arch\ArchPanel.py", line 201, in getPoint FreeCAD.ActiveDocument.openTransaction(str(translate("Arch","Create Panel"))) UnicodeEncodeError: 'ascii' codec can't encode characters in position 0-5: ordinal not in range(128) |
Wall is working. |
dont know how wall objects should work, but something strange happening |
some errors with walls Traceback (most recent call last): File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftSnap.py", line 1182, in move self.pt = FreeCADGui.Snapper.snap(mousepos,lastpoint=last,active=ctrl,constrain=shift) File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftSnap.py", line 303, in snap snaps.extend(self.snapToSpecials(obj,lastpoint,eline)) File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Draft\DraftSnap.py", line 921, in snapToSpecials if obj.ViewObject.ShowNodes: AttributeError: 'Gui.ViewProviderDocumentObject' object has no attribute 'ShowNodes' |
also self-test with TestArch giving error --------------------------- Error: testSection (TestArch.ArchTest) --------------------------- Traceback (most recent call last): File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\bin\lib\unittest\case.py", line 329, in run testMethod() File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Arch\TestArch.py", line 119, in testSection v = Arch.makeSectionView(s) File "C:\Users\KAZAN\Downloads\FreeCAD_0.18.15806_x64_dev_win\Mod\Arch\ArchSectionPlane.py", line 88, in makeSectionView page = FreeCAD.ActiveDocument.addObject("Drawing::FeaturePage",translate("Arch","Page")) UnicodeEncodeError: 'ascii' codec can't encode characters in position 0-7: ordinal not in range(128) --------------------------- OK Скрыть подробности... --------------------------- |
OK UnicodeEncodeError: 'ascii' codec can't encode characters in position 0-7: ordinal not in range(128) is related to this bug But it is looks like i discover another bug with point picker when hovering some object it stops working errorlog.txt is related to this |
Other objects like wall or structure working fine. 2D objects also working correctly. |
Thanks for the feedback.. Indeed those are two encoding bugs. I thought I had them all cleaned but there is always one that escaped :) This should now be fixed with https://github.com/FreeCAD/FreeCAD/commit/21dc8c50546f8f0b29987e879ef11a7146d17626 |
Just checked your last commit it fixes issue with adding panel and now it works correctly. |
Great! Thanks a lot for the feedback! |
| 2019-02-09 16:26 | kazan417 | New Issue | |
| 2019-02-11 10:49 | Kunda1 | Note Added: 0012622 | |
| 2019-02-11 14:18 | kazan417 | Note Added: 0012628 | |
| 2019-02-11 21:32 | Kunda1 | Assigned To | => wmayer |
| 2019-02-11 21:32 | Kunda1 | Status | new => assigned |
| 2019-02-11 21:32 | Kunda1 | Target Version | => 0.18 |
| 2019-02-15 00:39 | yorik | Note Added: 0012654 | |
| 2019-02-15 00:40 | yorik | Note Edited: 0012654 | |
| 2019-02-16 22:03 | wmayer | Assigned To | wmayer => |
| 2019-02-16 22:22 | yorik | Assigned To | => yorik |
| 2019-02-16 22:22 | yorik | Status | assigned => feedback |
| 2019-02-18 12:48 | kazan417 | Note Added: 0012674 | |
| 2019-02-18 12:48 | kazan417 | Status | feedback => assigned |
| 2019-02-18 13:03 | kazan417 | File Added: freecad-glitch.flv | |
| 2019-02-18 13:03 | kazan417 | Note Added: 0012675 | |
| 2019-02-19 02:31 | yorik | Note Added: 0012680 | |
| 2019-02-19 11:48 | kazan417 | File Added: errorlog.txt | |
| 2019-02-19 11:48 | kazan417 | Note Added: 0012684 | |
| 2019-02-19 11:52 | kazan417 | Note Added: 0012685 | |
| 2019-02-19 12:22 | kazan417 | Note Added: 0012686 | |
| 2019-02-19 12:25 | kazan417 | Note Added: 0012687 | |
| 2019-02-19 12:48 | kazan417 | File Added: freecad wall glitch.flv | |
| 2019-02-19 12:48 | kazan417 | Note Added: 0012688 | |
| 2019-02-19 12:51 | kazan417 | Note Added: 0012689 | |
| 2019-02-19 12:55 | kazan417 | Note Added: 0012690 | |
| 2019-02-19 13:36 | kazan417 | Note Added: 0012692 | |
| 2019-02-19 13:39 | kazan417 | Note Edited: 0012684 | |
| 2019-02-19 14:30 | kazan417 | Note Edited: 0012688 | |
| 2019-02-19 14:48 | kazan417 | Note Added: 0012694 | |
| 2019-02-19 15:08 | kazan417 | Note Edited: 0012694 | |
| 2019-02-19 23:06 | yorik | Note Added: 0012698 | |
| 2019-02-20 09:12 | kazan417 | Note Added: 0012701 | |
| 2019-02-20 13:08 | yorik | Note Added: 0012703 | |
| 2019-02-20 13:08 | yorik | Status | assigned => closed |
| 2019-02-20 13:08 | yorik | Resolution | open => fixed |
| 2019-02-20 13:08 | yorik | Fixed in Version | => 0.18 |
