| 0003829 | FreeCAD | Bug | public | 2019-02-12 01:37 | 2021-03-13 21:35 |
| Reporter | fb | Assigned To | |||
| Platform | GNU/Linux | OS | Fedora 29 (Workstation 64-bit) | OS Version | 29 |
| Summary | 0003829: External display dropdown menu offset | ||||
| Description | Using FreeCAD 0.18 AppImage with an external display there is a big offset between the main menu entries and the corresponding dropdown menu. The dropdown menu looks aligned to the relative position of the main display so you can't get a window higher than the one of the main display without such an offset. This problem is shown for the 'File' entry in the attached screenshot. This occurs either with FreeCAD and FreeCAD Qt5 Conda. Other Qt based applications like Krita, Scribus, QGIS, and VLC work without this problem. Forum thread: https://forum.freecad.org/viewtopic.php?f=3&t=34109 | ||||
| Steps To Reproduce | 1. Launch FreeCAD or FreeCAD Qt5 Conda AppImage 2. Put the window of FreeCAD on the external display 3. Offset between the main menu entry and its dropdown menu increases each time you increase the height of the FreeCAD window. | ||||
| Additional Information | OS: Fedora 29 (Workstation Edition) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15780 (Git) AppImage Build type: Release Branch: master Hash: f94e76c1116ec3b818961ff65131b3d86fa5b95e Python version: 3.6.7 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
After further research, I found out that the problem arises with a layout in which top edge of secondary screen (external display) is above top edge of primary screen (Built-in display of the laptop). So, the problem probably does not come from FreeCAD. |
Closing as this most likely is a bug unrelated to FC. If it isn't please re-open |
| 2019-02-12 01:37 | fb | New Issue | |
| 2019-02-12 01:37 | fb | File Added: FreeCAD_Conda-daily_8664-Libs_0.18R15780-External_display_dropdown_menu_offset.png | |
| 2019-02-13 17:16 | fb | Note Added: 0012633 | |
| 2021-03-13 21:35 | Kunda1 | Status | new => closed |
| 2021-03-13 21:35 | Kunda1 | Resolution | open => no change required |
| 2021-03-13 21:35 | Kunda1 | Note Added: 0015509 |
