| 0003842 | Sketcher | Bug | public | 2019-02-16 18:38 | 2020-06-05 17:23 |
| Reporter | uwestoehr | Assigned To | abdullah | ||
| Summary | 0003842: undo of move operation results in new state | ||||
| Description | - input a hexagon to a sketch via the corresponding toolbar button - select a line of the hexagon at the right side (not the complete hexagon) - use the new move toolbar button - set the movement vector to the left (so that it crosses the hexagon) Now you see that you made a mistake because e.g. you wanted to move the whole hexagon, therefore - press undo result: you will need 2 undo steps and the result is not the same as before the movement action. | ||||
| Additional Information | forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=34253&start=10#p287301 | ||||
| Tags | undo | ||||
Set 0.19 target |
PR: https://github.com/FreeCAD/FreeCAD/pull/3536 |
git commit 28222fe066b60ae5c99dce4e5b022d270cad250f |
| 2019-02-16 18:38 | uwestoehr | New Issue | |
| 2019-02-16 20:59 | wmayer | Assigned To | => abdullah |
| 2019-02-16 20:59 | wmayer | Status | new => confirmed |
| 2019-08-23 02:48 | Kunda1 | Fixed in Version | => 0.19 |
| 2019-08-23 02:48 | Kunda1 | Note Added: 0013459 | |
| 2019-08-23 02:51 | Kunda1 | Fixed in Version | 0.19 => |
| 2019-08-23 02:51 | Kunda1 | Target Version | => 0.19 |
| 2020-02-20 21:07 | Kunda1 | Tag Attached: undo | |
| 2020-05-31 07:20 | abdullah | Note Added: 0014450 | |
| 2020-05-31 18:55 | abdullah | Status | confirmed => closed |
| 2020-05-31 18:55 | abdullah | Resolution | open => fixed |
| 2020-05-31 18:55 | abdullah | Fixed in Version | => 0.19 |
| 2020-05-31 18:55 | abdullah | Note Added: 0014452 | |
| 2020-06-05 17:23 | abdullah | Changeset attached | => FreeCAD master 28222fe0 |
| 2020-06-05 17:23 | abdullah | Note Added: 0014475 |
