| 0003844 | FreeCAD | Bug | public | 2019-02-17 18:11 | 2021-04-21 20:00 |
| Priority | high | Severity | major | Reproducibility | have not tried |
| Summary | 0003844: PVS: The pointer was not released in destructor. A memory leak is possible. | ||||
| Description | At the moment the CommandBase class has a couple of member variables of type const char*. Now the strings passed to the constructor are compiled into the binaries so that in the destructors the memory mustn't be freed. However, there are also setter methods to change the strings and usually the passed arguments have only a tmp. lifetime. So, the method strdup() must be used. However, on destruction time we don't know whether the memory was allocated on the heap or not. To be on the safe side nothing is freed but in case the setter methods have been used we have a major memory leak. So, to solve all the hassles it's best to use std::string as members. This may cause a certain overhead but at least makes sure that all memory is freed. | ||||
| Tags | #pending | ||||
General Analysis Command.cpp:742 Medium V773 The 'sScriptName' pointer was not released in destructor. A memory leak is possible. General Analysis Command.cpp:141 Medium V773 The 'sMenuText' pointer was not released in destructor. A memory leak is possible. General Analysis Command.cpp:141 Medium V773 The 'sToolTipText' pointer was not released in destructor. A memory leak is possible. General Analysis Command.cpp:141 Medium V773 The 'sWhatsThis' pointer was not released in destructor. A memory leak is possible. General Analysis Command.cpp:141 Medium V773 The 'sStatusTip' pointer was not released in destructor. A memory leak is possible. General Analysis Command.cpp:141 Medium V773 The 'sPixmap' pointer was not released in destructor. A memory leak is possible. General Analysis Command.cpp:141 Medium V773 The 'sAccel' pointer was not released in destructor. A memory leak is possible. General Analysis Command.cpp:225 Medium V773 The 'sAppModule' pointer was not released in destructor. A memory leak is possible. General Analysis Command.cpp:225 Medium V773 The 'sGroup' pointer was not released in destructor. A memory leak is possible. |
@chennes are these still valid? |
Yes, this is still valid. I believe the lines in question are Command.h 291-296, which @wmayer is suggesting should be std::string, rather than char *. |
The only problem with std::string is that it's rather fat. While a plain C string only requires 8 bytes (as it's a pointer) std::string already has 32 bytes. But it seems QByteArray is a good alternative as this also only requires 8 bytes, too.
EDIT: QByteArray uses a pointer to QTypedArrayData<char> so, that's why sizeof said 8 bytes. But for QTypedArrayData<char> sizeof says it's 24 so in the end QByteArray is not better than std::string. |
I did not benchmark it for memory consumption, but I have a local branch where I've done this migration (to std::string), so I can take a look later this week and see if it's a big enough memory hit to be worth worrying about (or maybe you already have a sense for that). |
| 2019-02-17 18:11 | wmayer | New Issue | |
| 2019-02-17 18:11 | wmayer | Status | new => assigned |
| 2019-02-17 18:11 | wmayer | Assigned To | => wmayer |
| 2019-02-17 18:13 | wmayer | Note Added: 0012672 | |
| 2019-06-20 13:17 | Kunda1 | Relationship added | related to 0003993 |
| 2021-02-21 03:51 | Kunda1 | Note Added: 0015405 | |
| 2021-02-21 03:52 | Kunda1 | Target Version | 0.20 => 0.19 |
| 2021-02-21 03:52 | Kunda1 | Tag Attached: #pending | |
| 2021-02-22 15:49 | chennes | Note Added: 0015418 | |
| 2021-02-23 12:01 | wmayer | Note Added: 0015422 | |
| 2021-02-23 12:02 | wmayer | Target Version | 0.19 => 0.20 |
| 2021-02-23 13:59 | wmayer | Note Edited: 0015422 | |
| 2021-02-23 16:12 | chennes | Note Added: 0015423 | |
| 2021-04-21 20:00 | wmayer | Changeset attached | => FreeCAD master b7aee7bf |
| 2021-04-21 20:00 | wmayer | Note Added: 0015640 | |
| 2021-04-21 20:00 | wmayer | Status | assigned => closed |
| 2021-04-21 20:00 | wmayer | Resolution | open => fixed |
