0003855DraftBugpublic2022-01-25 18:22
Reporter_HackerBoss_ Assigned ToKunda1
Status closedResolutionduplicate
PlatformLinux (4.15.0-45-generic)OSUbuntu (64-bit)OS Version18.04.2 LTS
Product Version0.17
Target Version0.20
Summary0003855: UI becomes unresponsive when attempting to download and use DXF import libraries (python legacy)
DescriptionWhen not using legacy, it appears to draw nothing at all, but does not fail in the same way. The UI becomes unresponsive at the OS level, with Ctrl+Alt+T and similar shortcuts not working. This makes it difficult to gather more information about the problem, I ended up restarting with the power button after waiting several seconds. I also tried after installing (successfully through the add-on manager) the dxf_library add-on, with the same result.
Steps To Reproduce
  1. Start up FreeCAD
  2. Go to Edit->Preferences->Import-Export and check
    Use legacy python importer
    and
    Automatic update (legacy importer only)
  3. Apply the changes and attempt to open my DXF file
  4. Wait
  5. Wait longer
  6. Try to stop the operation
  7. Try to close FreeCAD through the UI
  8. Try to access a terminal
  9. Restart the machine with the power button
Additional InformationOS: Ubuntu 18.04.2 LTS
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Hash: 9948ee4f1570df9216862a79705afb367b2c6ffb
Python version: 2.7.15rc1
Qt version: 5.9.5
Tags#tobeclosed, DXF, file format, import, linux
Relationships
duplicate of 0003854 closed File formats UI becomes unresponsive when attempting to download and use DXF import libraries (python legacy)
2019-03-12 15:46
administrator   ~0012896
https://forum.freecad.org/viewtopic.php?f=8&t=34857
2020-07-16 11:50
administrator   ~0014651
@_HackerBoss_ please respond to the thread
chennes
2021-12-29 05:24
administrator   ~0016164
Marking this as #tobeclosed pending any further details or input.
2022-01-25 18:22
administrator   ~0016303
Closing
2019-02-23 17:25 _HackerBoss_ New Issue
2019-02-23 17:25 _HackerBoss_ Tag Attached: addon-manager
2019-02-23 17:25 _HackerBoss_ Tag Attached: Draft
2019-02-23 17:25 _HackerBoss_ Tag Attached: DXF
2019-02-23 17:25 _HackerBoss_ Tag Attached: file format
2019-02-23 17:25 _HackerBoss_ Tag Attached: GUI
2019-02-23 17:25 _HackerBoss_ Tag Attached: import
2019-02-23 17:25 _HackerBoss_ Tag Attached: keyboard
2019-02-23 17:25 _HackerBoss_ Tag Attached: linux
2019-02-23 17:25 _HackerBoss_ Tag Attached: mouse
2019-02-23 18:47 wmayer Relationship added duplicate of 0003854
2019-03-12 15:46 Kunda1 Note Added: 0012896
2020-07-16 11:50 Kunda1 Status new => feedback
2020-07-16 11:50 Kunda1 Note Added: 0014651
2020-07-16 11:51 Kunda1 Tag Detached: addon-manager
2020-07-16 11:51 Kunda1 Tag Detached: Draft
2020-07-16 11:51 Kunda1 Tag Detached: GUI
2020-07-16 11:51 Kunda1 Tag Detached: keyboard
2020-07-16 11:51 Kunda1 Tag Detached: mouse
2020-07-16 11:51 Kunda1 Target Version => 0.19
2020-07-16 11:53 Kunda1 Tag Attached: #pending-forum
2021-02-06 06:45 abdullah Target Version => 0.20
2021-12-29 05:23 chennes Tag Detached: #pending-forum
2021-12-29 05:24 chennes Tag Attached: #tobeclosed
2021-12-29 05:24 chennes Note Added: 0016164
2022-01-25 18:22 Kunda1 Assigned To => Kunda1
2022-01-25 18:22 Kunda1 Status feedback => closed
2022-01-25 18:22 Kunda1 Resolution open => duplicate
2022-01-25 18:22 Kunda1 Note Added: 0016303
