0003857PartFeaturepublic2020-12-01 11:29
Reporteruwestoehr Assigned Touwestoehr
PrioritynormalSeveritytweakReproducibilityalways
Status closedResolutionfixed
Product Version0.18
Summary0003857: Helix is not editable via its task dialog
Description- create a helix with the Part WB
This opens a task dialog where you can specify its settings
- after the creation, double-click on the helix in the model tree
result: the task dialog to change its settings does not show up
Since there exists a nice task dialog for helices, it should be shown.
Additional InformationIn principle the same issue than with ShapeStrings: 0003853
TagsTask View
Relationships
related to 0003853 assignedyorik Draft ShapeString is not editable
uwestoehr
2019-02-24 14:00
manager   ~0012741
2019-02-24 17:20
administrator   ~0012751
Might be in principle the same as with the ShapeString but this ticket is clearly a feature request and not a bug.
uwestoehr
2019-02-24 18:13
manager   ~0012757
The issue is not only about helices, it applies for all parametric primitives in the Part WB.
uwestoehr
2020-11-08 21:24
manager   ~0014967
This was implemented yesterday:
- https://github.com/FreeCAD/FreeCAD/commit/6d831627839daff3e856682848dcfd6e6c4ff96c
- https://github.com/FreeCAD/FreeCAD/commit/80626d3a1f5e412463d2caabbf50f5c962554010
- https://github.com/FreeCAD/FreeCAD/commit/f23187cd0eb4e6153c8b2190753a26678714dc75
Meanwhile the editing has also a live preview.
2020-11-16 22:52
administrator   ~0014995
FreeCAD master 6d831627
FreeCAD master 80626d3a
FreeCAD master f23187cd
2020-12-01 11:29
administrator   ~0015036
Closing ticket
Related Changesets
FreeCAD: master 6d831627
2020-10-25 21:52:31
uwestoehr
[Part] allow to edit helices via a dialog
fixes https://tracker.freecad.org/view.php?id=3857
Currently primitives of the Part WB can only be created suing a dialog. Editing is not possible that way.
This PR makes the first step in achieving this:
- Helices can now be edited using the same dialog ans when created
- New location dialog. The Gui::LocationWidget used there is not aware of the rotation angle and it treats the rotation axis as direction. To fix this, I set changed the dialog so that one can define every parameter as in the PartDesign attacher dialog (Placement, rotation axis and rotation angle separately). Another reason for this change was that one could not use the location dialog, fill it with the placement properties of the object, and close the dialog without any change. Because of the missing angle info the objects was then always rotated despite nothing was changed.
If this PR goes in, I will extend it for the other primitives.
Todo for the future: allow a preview of the changes made in the dialog. (I could not find out how this is done.)
Affected Issues
0003857
mod - src/Mod/Part/Gui/DlgPrimitives.cpp Diff File
mod - src/Mod/Part/Gui/DlgPrimitives.h Diff File
mod - src/Mod/Part/Gui/Location.ui Diff File
mod - src/Mod/Part/Gui/ViewProviderHelixParametric.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderHelixParametric.h Diff File
FreeCAD: master 80626d3a
2020-11-06 18:59:14
Details Diff
+ add class ViewProviderPrimitive to avoid to re-implement setEdit/unsetEdit methods for each sub-class separately
+ avoid using global variables
+ when editing a feature directly pass it to the dialogs
+ when editing a feature then do not use active document as this could point to the wrong object
+ fix undo/redo message
+ re-add '3D View' button to location dialog
Affected Issues
0003857
mod - src/Mod/Part/Gui/AppPartGui.cpp Diff File
mod - src/Mod/Part/Gui/ViewProvider.cpp Diff File
mod - src/Mod/Part/Gui/ViewProvider.h Diff File
mod - src/Mod/Part/Gui/ViewProviderBox.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderBox.h Diff File
mod - src/Mod/Part/Gui/ViewProviderCircleParametric.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderCircleParametric.h Diff File
mod - src/Mod/Part/Gui/ViewProviderConeParametric.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderConeParametric.h Diff File
mod - src/Mod/Part/Gui/ViewProviderCylinderParametric.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderCylinderParametric.h Diff File
mod - src/Mod/Part/Gui/ViewProviderEllipseParametric.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderEllipseParametric.h Diff File
mod - src/Mod/Part/Gui/ViewProviderLineParametric.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderLineParametric.h Diff File
mod - src/Mod/Part/Gui/ViewProviderPlaneParametric.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderPlaneParametric.h Diff File
mod - src/Mod/Part/Gui/ViewProviderPointParametric.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderPointParametric.h Diff File
mod - src/Mod/Part/Gui/ViewProviderPrism.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderPrism.h Diff File
mod - src/Mod/Part/Gui/ViewProviderRegularPolygon.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderRegularPolygon.h Diff File
mod - src/Mod/Part/Gui/ViewProviderSphereParametric.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderSphereParametric.h Diff File
mod - src/Mod/Part/Gui/ViewProviderTorusParametric.cpp Diff File
mod - src/Mod/Part/Gui/ViewProviderTorusParametric.h Diff File
FreeCAD: master f23187cd
2020-11-06 22:12:40
Details Diff
Part: allow to edit primitives via dialog Affected Issues
0003857
2019-02-24 13:51 uwestoehr New Issue
2019-02-24 14:00 uwestoehr Tag Attached: Task View
2019-02-24 14:00 uwestoehr Note Added: 0012741
2019-02-24 17:20 wmayer Category Bug => Feature
2019-02-24 17:20 wmayer Note Added: 0012751
2019-02-24 18:13 uwestoehr Note Added: 0012757
2020-11-08 21:24 uwestoehr Assigned To => uwestoehr
2020-11-08 21:24 uwestoehr Status new => resolved
2020-11-08 21:24 uwestoehr Resolution open => fixed
2020-11-08 21:24 uwestoehr Fixed in Version => 0.19
2020-11-08 21:24 uwestoehr Note Added: 0014967
2020-11-16 22:52 Kunda1 Note Added: 0014995
2020-11-16 22:53 Kunda1 Changeset attached => FreeCAD master 6d831627
2020-11-16 22:53 Kunda1 Note Edited: 0014995
2020-11-16 22:54 Kunda1 Changeset attached => FreeCAD master 80626d3a
2020-11-16 22:54 Kunda1 Changeset attached => FreeCAD master f23187cd
2020-11-16 23:44 Kunda1 Relationship added related to 0003853
2020-11-16 23:45 Kunda1 Additional Information Updated
2020-12-01 11:29 Kunda1 Status resolved => closed
2020-12-01 11:29 Kunda1 Note Added: 0015036
