| 0003860 | FreeCAD | Bug | public | 2019-02-25 02:26 | 2019-07-29 15:03 |
| Reporter | kkremitzki | Assigned To | wmayer | ||
| Summary | 0003860: Debian bug #920971 - C++ exception on DXF import | ||||
| Description | The following description is copy+pasted from https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=920971 I tried to import the file houseplan.dxf (http://wookware.org/house/houseplan.dxf) I got this error: Gui::Command::activated(0): Unknown C++ exception thrown However I did also get a model containing Shape001 to Shape2829 which all appear to be individual lines (so that's probably correct as 'Create simple part shapes' was selected in the import preferences dialog). Not very useful but 'correct' :-) The exception seems bad though. Possibly this bug should be redirected to the DXF parsing library, but I'm not sure which one is in use. Wookey | ||||
What happens is that inside OnReadArc the three parameters s, e, and c are identical and thus creates a degenerate arc, i.e. start and end point and center of the arc collapse to a single point. Then of course OCCT raises an error because it cannot create a shape from the geometry. This exception isn't handled locally so that it goes up to Gui::Command::invoke. |
https://github.com/FreeCAD/FreeCAD/commit/d3e008e46cdb48ddf33d8e238d4893679cf2bc92 |
| 2019-02-25 02:26 | kkremitzki | New Issue | |
| 2019-02-25 21:58 | wmayer | Target Version | => 0.18 |
| 2019-02-25 22:46 | wmayer | Note Added: 0012769 | |
| 2019-02-25 22:48 | wmayer | Assigned To | => wmayer |
| 2019-02-25 22:48 | wmayer | Status | new => closed |
| 2019-02-25 22:48 | wmayer | Resolution | open => fixed |
| 2019-02-25 22:48 | wmayer | Fixed in Version | => 0.18 |
| 2019-02-25 22:48 | wmayer | Note Added: 0012770 | |
| 2019-07-29 15:03 | Kunda1 | Changeset attached | => FreeCAD releases/FreeCAD-0-18 d3e008e4 |
