| 0003868 | Arch | Bug | public | 2019-02-28 00:24 | 2019-08-23 02:20 |
| Reporter | uwestoehr | Assigned To | uwestoehr | ||
| Priority | normal | Severity | text | Reproducibility | always |
| Summary | 0003868: missing tooltips in the Arch preferences | ||||
| Description | This bug collects missing and unclear tooltips in the Arch preferences. In the IFC preferences: The following tooltips are missing: - Create clones when objects have shared geometry - Exclude list - Export 2D objects as IfcAnnotations Incomplete is the tooltip for: - Use IfcOpenShell serializer if available Typos are in: - Import Ifc Properties in spreadsheet (should be "Import IFC properties in spreadsheet") | ||||
| Tags | tooltips | ||||
For information: Missing or incomplete tooltips will be denoted in the Wiki page: https://www.freecadweb.org/wiki/Preferences_Editor as '??' until information is available. If so, I will post them to this bug report to be implemented in form of tooltips. |
The tooltip Store IFC universal ID in FreeCAD objects seems to have a wrong name since in the IFC specs there is no universal ID but only a IfcGloballyUniqueId |
In the DAE preferences: The following tooltip is missing: - Scaling factor Outdated is the tooltip for: - Mesher -> there is no preferences setting for the Mesh WB where Netgen can or must be enabled Incomplete is the tooltip for: - Grading -> The Netgen docs doesn't tell anything about grading or what this means. Maybe the option was renamed? |
Assigning to 0.19 milestone |
The bug is fixed by this PR: https://github.com/FreeCAD/FreeCAD/pull/2351 |
Attached 4 commits related to this ticket. Closing. @uwestoehr thank for you work on this. In the future please consider using the Github<->MantisBT keywords in https://www.freecadweb.org/wiki/Tracker#GitHub_and_MantisBT |
FreeCAD: master 91db0484 2019-07-17 00:03:41 donovaly Committer: yorik Details Diff |
add, update and uniform tooltips for Arch preferences |
Affected Issues 0003868 |
| mod - src/Mod/Arch/Resources/ui/preferences-dae.ui | Diff File | ||
| mod - src/Mod/Arch/Resources/ui/preferences-ifc.ui | Diff File | ||
FreeCAD: master f54df863 2019-07-17 20:09:24 donovaly Committer: wmayer Details Diff |
add tooltips for meshing dialogs |
| mod - src/Mod/Mesh/Gui/DlgSettingsImportExport.ui | Diff File | ||
| mod - src/Mod/MeshPart/Gui/Tessellation.ui | Diff File | ||
FreeCAD: master b6da0b81 2019-07-17 20:25:41 donovaly Committer: yorik Details Diff |
preferences-ifc.ui: requested whitespace fixes |
FreeCAD: master c32056cf 2019-07-17 20:37:36 donovaly Committer: yorik Details Diff |
preferences-ifc.ui; some more requested whitespace fixes |
| 2019-02-28 00:24 | uwestoehr | New Issue | |
| 2019-02-28 00:42 | uwestoehr | Note Added: 0012800 | |
| 2019-02-28 00:50 | uwestoehr | Note Added: 0012801 | |
| 2019-02-28 23:13 | uwestoehr | Note Added: 0012812 | |
| 2019-05-12 19:13 | Kunda1 | Target Version | => 0.19 |
| 2019-05-12 19:13 | Kunda1 | Note Added: 0013098 | |
| 2019-07-16 22:29 | uwestoehr | Tag Attached: tooltips | |
| 2019-07-16 22:29 | uwestoehr | Assigned To | => uwestoehr |
| 2019-07-16 22:29 | uwestoehr | Status | new => assigned |
| 2019-07-17 00:07 | uwestoehr | Note Added: 0013354 | |
| 2019-08-23 02:16 | Kunda1 | Changeset attached | => FreeCAD master c32056cf |
| 2019-08-23 02:17 | Kunda1 | Changeset attached | => FreeCAD master b6da0b81 |
| 2019-08-23 02:17 | Kunda1 | Changeset attached | => FreeCAD master f54df863 |
| 2019-08-23 02:18 | Kunda1 | Changeset attached | => FreeCAD master 91db0484 |
| 2019-08-23 02:20 | Kunda1 | Status | assigned => closed |
| 2019-08-23 02:20 | Kunda1 | Resolution | open => fixed |
| 2019-08-23 02:20 | Kunda1 | Fixed in Version | => 0.19 |
| 2019-08-23 02:20 | Kunda1 | Note Added: 0013456 |
