| 0003870 | FreeCAD | Bug | public | 2019-02-28 17:49 | 2020-03-27 13:13 |
| Reporter | jmborer | Assigned To | |||
| Platform | Apple | OS | Mac OS | OS Version | 10.14.3 |
| Summary | 0003870: 3D rendering issues that show the start page in the background on the sections | ||||
| Description | When you open the BIM sample and "unhide" the sections and rotate them, the start page appears in transparent on them even if you close the start page. OS: macOS 10.14 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15525 (Git) Build type: Release Branch: master Hash: 1a7d3d9a37fe43468c8ac84590c1db53e2b2000a Python version: 3.6.7 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
| Steps To Reproduce | See above | ||||
| Tags | #tobeclosed | ||||
Unfortunately, the MacOS builds are lagging behind (about +/-500 commits) the Linux and Windows dev builds. The macos team hasn't been available and able to overcome some dependency issues. Also can you please follow our guidelines (yellow banner at the top of the page) and please post to the forum first. |
@chrisb can you corroborate ? |
@jmborer can you please test this on the latest 0.19dev .dmg? |
@jmborer please test on latest 0.19dev |
GPU issue, right @chrisb? |
I haven't seen this for quite some time, so 0.19 is a good choice, Werner had made some changes in that area. @jmborer: If the issue persists, please retry after resetting your config. Then we can have a well defined starting point. |
Closing ticket due to lack of response from OP |
| 2019-02-28 17:49 | jmborer | New Issue | |
| 2019-02-28 17:49 | jmborer | File Added: Screenshot 2019-02-28 at 18.46.33.png | |
| 2019-02-28 17:59 | Kunda1 | Status | new => feedback |
| 2019-02-28 17:59 | Kunda1 | Note Added: 0012807 | |
| 2019-03-03 14:04 | Kunda1 | Note Added: 0012826 | |
| 2019-04-06 19:25 | Kunda1 | Note Added: 0013013 | |
| 2019-07-23 23:50 | Kunda1 | Note Added: 0013381 | |
| 2020-01-16 13:27 | Kunda1 | Note Added: 0014085 | |
| 2020-01-24 08:23 | chrisb | Note Added: 0014103 | |
| 2020-01-24 11:30 | Kunda1 | Tag Attached: #tobeclosed | |
| 2020-03-27 13:13 | Kunda1 | Status | feedback => closed |
| 2020-03-27 13:13 | Kunda1 | Resolution | open => no change required |
| 2020-03-27 13:13 | Kunda1 | Note Added: 0014300 |
