| 0003882 | Arch | Bug | public | 2019-03-04 20:41 | 2021-02-06 06:28 |
| Reporter | brjhaverkamp | Assigned To | |||
| Summary | 0003882: Add and subtract in Arch workbench don't follow object selection order | ||||
| Description | When trying to subtract 2 structures in the Arch workbench, the order in which the 2 objects are selected is not used. Therefore in the attached example there is no way to subtract structure 2 from structure 1. This is related to forum thread https://forum.freecadweb.org/viewtopic.php?f=23&t=34293 and possibly to https://forum.freecadweb.org/viewtopic.php?f=23&t=34429 where a similar issue is discussed with the add button in Arch. I tested this in a couple of the latest builds, currently running OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15998 (Git) Build type: Release Branch: master Hash: 5791c341be797ff2eee99eccac53df71db510fae Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: English/UnitedStates (en_US) | ||||
| Steps To Reproduce | How to reproduce: open the simplified example file attached. Select structure 1, ctrl+ select structure 2, hit substract, and you end up with structure 2 minus structure 1. Selecg structure 2, ctrl+ select structure 1, hit substract, and you end up with structure 2 minus structure 1. There is no way to create structure 1 minus structure 2 with the subtract function! | ||||
@brjhaverkamp Please also confirm in Python3/Qt5 build. Thanks |
Hi Kunda1, I hadn't realised the build I downloaded was without QT5/Python3. So here the update, I confirm it is also happening in the QT5/Python3 build. I added a bit more realistic example (example subtract 2) that comes from an actual project I am working on. I want to cutout a stairwell hole in a floor structure. But all I manage is to cut out the floor from the hole structure. Irrespective from which object is selected first and which one is added with Ctrl pressed. Mind you that this is _only_ if I use the big blue minus sign button on the arch workbench toolbar. I meanwhile found a workaround by manually adding the subtracting object in the data view of the floor structure. That way it works perfectly. But the minus sign should do the same thing. OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16028 (Git) Build type: Release Branch: master Hash: 9079de7516eca945587e18f6076ec74eb7bd043c Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) |
@brjhaverkamp thank you. BTW, next time you encounter an issue, please open a forum thread dedicated to it first. it's easier and more efficient to get direct help and possibly a bug fix if you first post because the amount of exposure. @paullee care to weigh in on this ticket? |
Hi Kunda1 The Forum thread is mentioned in my first submission . Regis an Roy weight in on the matter and there was quite some discussion on it. The second thread I mentioned in the initial bug submission looks related in my view, but I could be wrong. Regards, Bert |
Hi all, I had checked the thread previously and noted Regis etc. are helping. See discussion thread - should be a bug. |
This ticket has been migrated to GitHub as issue 5890. |
| 2019-03-04 20:41 | brjhaverkamp | New Issue | |
| 2019-03-04 20:41 | brjhaverkamp | File Added: example subtract.FCStd | |
| 2019-03-06 00:32 | Kunda1 | Note Added: 0012852 | |
| 2019-03-06 00:33 | Kunda1 | Status | new => feedback |
| 2019-03-07 07:24 | brjhaverkamp | File Added: example subtract 2.FCStd | |
| 2019-03-07 07:24 | brjhaverkamp | Note Added: 0012855 | |
| 2019-03-07 07:24 | brjhaverkamp | Status | feedback => new |
| 2019-03-07 13:21 | Kunda1 | Note Added: 0012856 | |
| 2019-03-08 08:16 | brjhaverkamp | Note Added: 0012860 | |
| 2019-03-08 13:41 | paullee | Note Added: 0012863 | |
| 2019-06-17 07:40 | Kunda1 | Status | new => confirmed |
| 2019-06-17 07:41 | Kunda1 | Target Version | => 0.19 |
| 2019-06-17 07:41 | Kunda1 | Steps to Reproduce Updated | |
| 2021-02-06 06:28 | abdullah | Target Version | => 0.20 |
