| 0003890 | Part | Bug | public | 2019-03-06 22:09 | 2019-07-16 11:42 |
| Reporter | uwestoehr | Assigned To | |||
| Priority | normal | Severity | text | Reproducibility | always |
| Summary | 0003890: missing tooltips in the Part preferences | ||||
| Description | This bug collects missing and unclear tooltips in the Part preferences. Missing or incomplete tooltips will be denoted in the Wiki page: https://www.freecadweb.org/wiki/Preferences_Editor as '??' until information is available. If so, I will post them to this bug report to be implemented in form of tooltips. In the IGES preferences: The following tooltips are missing: - Units for export of IGES - Groups of Trimmed Surfaces (type 144) -> I added some info here that can be used for a tooltip: https://www.freecadweb.org/wiki/Preferences_Editor#IGES - Solids (type 186) and Shells (type 514) / B-REP mode -> I added some info here that can be used for a tooltip: https://www.freecadweb.org/wiki/Preferences_Editor#IGES - Skip blank entities - Header (maybe not necessary because is self-explanatory) In the STEP preferences: The following tooltips are missing: - Units for export of STEP (maybe tell the user why this setting is important, maybe not necessary) - Header (maybe not necessary because is self-explanatory) | ||||
| Tags | #lowhangingfruit, tooltips | ||||
| 2019-03-06 22:09 | uwestoehr | New Issue | |
| 2019-03-06 22:09 | uwestoehr | Tag Attached: tooltips | |
| 2019-03-31 16:14 | Kunda1 | Tag Attached: #lowhangingfruit | |
| 2019-03-31 16:14 | Kunda1 | Status | new => confirmed |
| 2019-03-31 16:14 | Kunda1 | Target Version | => 0.19 |
| 2019-07-15 23:32 | uwestoehr | Note Added: 0013348 | |
| 2019-07-16 11:41 | wmayer | Changeset attached | => FreeCAD master 4b4e48d5 |
| 2019-07-16 11:42 | wmayer | Status | confirmed => closed |
| 2019-07-16 11:42 | wmayer | Resolution | open => fixed |
| 2019-07-16 11:42 | wmayer | Fixed in Version | => 0.19 |
