| 0003894 | Part | Feature | public | 2019-03-09 17:58 | 2019-07-29 14:56 |
| Reporter | normandc | Assigned To | wmayer | ||
| Summary | 0003894: Part Thickness dialog thickness field not Expressions enabled | ||||
| Description | The input field to type in a thickness value in Part Thickness task dialog does not provide the expression icon to open the formula editor. Although it is possible to create the Thickness object, then assign an expression from the "Value" property afterwards, it would be preferable to be able to do it from the dialog at object creation. If not practical to complete the FR in 0.18, don't hesitate to bump to target version 0.19. | ||||
| Steps To Reproduce |
| Additional Information | Forum topic: https://forum.freecadweb.org/viewtopic.php?f=3&t=34777 | ||||
| 2019-03-09 17:58 | normandc | New Issue | |
| 2019-03-09 17:58 | normandc | File Added: FC_Part_Thickness_dialog_01.png | |
| 2019-03-12 00:08 | wmayer | Assigned To | => wmayer |
| 2019-03-12 00:08 | wmayer | Status | new => closed |
| 2019-03-12 00:08 | wmayer | Resolution | open => fixed |
| 2019-03-12 00:08 | wmayer | Fixed in Version | => 0.18 |
| 2019-03-12 00:08 | wmayer | Note Added: 0012890 | |
| 2019-07-29 14:56 | Kunda1 | Changeset attached | => FreeCAD releases/FreeCAD-0-18 194f5d77 |
