| 0003896 | FreeCAD | Feature | public | 2019-03-10 17:47 | 2021-03-28 10:31 |
| Reporter | craig9 | Assigned To | |||
| Priority | none | Severity | feature | Reproducibility | N/A |
| Target Version | 0.20 | Fixed in Version | 0.19 | ||
| Summary | 0003896: Dependency Graph: Panning | ||||
| Description | To improve dependency graph panning/scrolling, we should map the pan action of the 2D and 3D views, to the scrolling action of the dependency graph. e.g. When using Gesture Mode, right-click-drag pans the 2D and 3D drawing views, this change would allow that action to scroll the dependency graph too. Forum discussion here: https://forum.freecadweb.org/viewtopic.php?f=3&t=34791 | ||||
| Tags | #pending-PR, graphviz, mouse-gestures, UI | ||||
Hello, I created a PR that allows for panning the dependency graph with the left mouse button. This is just a subset of the feature proposed in this ticket, as it does not use the navigation mode set by the user. But, it seems to me that there is no easy way to get this information out from the classes that inherit from NavigationStyle anyways. I might be wrong - in this case, let me know and I will adjust accordingly. |
FreeCAD Pull Request 4638 |
FreeCAD master 07804a8c |
https://github.com/FreeCAD/FreeCAD/commit/07804a8c85fb2f8bc93155e118cadd99699607bf |
Back ported to v0.19 |
| 2019-03-10 17:47 | craig9 | New Issue | |
| 2019-03-10 20:51 | Kunda1 | Tag Attached: UI | |
| 2019-03-10 20:51 | Kunda1 | Tag Attached: mouse-gestures | |
| 2019-03-10 20:51 | Kunda1 | Tag Attached: graphviz | |
| 2019-03-10 20:52 | Kunda1 | Target Version | => 0.19 |
| 2019-03-10 20:53 | Kunda1 | Status | new => confirmed |
| 2021-03-19 10:26 | lvk88 | Note Added: 0015532 | |
| 2021-03-27 10:44 | Kunda1 | Tag Attached: #pending-PR | |
| 2021-03-27 11:19 | Kunda1 | Note Added: 0015553 | |
| 2021-03-27 11:19 | Kunda1 | Note Edited: 0015553 | |
| 2021-03-28 10:13 | Kunda1 | Note Added: 0015560 | |
| 2021-03-28 10:30 | wmayer | Changeset attached | => FreeCAD master 07804a8c |
| 2021-03-28 10:30 | wmayer | Note Added: 0015561 | |
| 2021-03-28 10:31 | wmayer | Status | confirmed => closed |
| 2021-03-28 10:31 | wmayer | Resolution | open => fixed |
| 2021-03-28 10:31 | wmayer | Fixed in Version | => 0.19 |
| 2021-03-28 10:31 | wmayer | Note Added: 0015562 |
