| 0003900 | FreeCAD | Feature | public | 2019-03-11 04:21 | 2019-03-27 23:36 |
| Reporter | H.Y.KOH | Assigned To | |||
| Summary | 0003900: Only .... FREECAD can not be installed. | ||||
| Description | I used the program FREECAD while I was using the IObit program to organize the disk. If you then run the FREECAD program, it will turn off during loading. (Repeat afterwards.) So I tried to install FREECAD again after downloading it. No matter how double clicked on the EXE file, there is no response. I feel like loading something and it disappears. If you have any other files, download and install them. Only .... FREECAD can not be installed. What's the problem? I can not do all kinds of things for a few days. | ||||
Maybe try running it from the command line and see whether it gives any error output. |
We don't know what exact version you are running since you didn't mention Help > About FreeCAD > Copy to clipboard We don't know the OS or specs of your system We ask that only 0.18_pre bugs be posted as per the large yellow banner at the top of each page of the bugtracker. Please follow our guidelines to get better help. This also sounds like an issue on your machine. You may need to remove the config files, https://forum.freecadweb.org/viewtopic.php?t=24915 |
@H.Y.KOH please reply |
The cause was IOBIT. There was a problem after the computer was cleaned up. So I had no choice but to install a new Windows 10. FREECAD was installed after that, and it was installed normally. Thank you for your manager's opinion. |
Closing ticket |
| 2019-03-11 04:21 | H.Y.KOH | New Issue | |
| 2019-03-11 05:07 | craig9 | Note Added: 0012880 | |
| 2019-03-11 11:18 | Kunda1 | Note Added: 0012882 | |
| 2019-03-11 11:18 | Kunda1 | Priority | urgent => low |
| 2019-03-11 11:18 | Kunda1 | Severity | block => minor |
| 2019-03-11 11:18 | Kunda1 | Status | new => feedback |
| 2019-03-16 02:52 | Kunda1 | Note Added: 0012912 | |
| 2019-03-27 23:33 | H.Y.KOH | Note Added: 0012971 | |
| 2019-03-27 23:33 | H.Y.KOH | Status | feedback => new |
| 2019-03-27 23:36 | Kunda1 | Status | new => closed |
| 2019-03-27 23:36 | Kunda1 | Resolution | open => no change required |
| 2019-03-27 23:36 | Kunda1 | Note Added: 0012972 |
