| 0003904 | FreeCAD | Bug | public | 2019-03-13 08:19 | 2021-02-06 06:50 |
| Reporter | carlopav | Assigned To | |||
| Summary | 0003904: Draft _ Delete objects while command is active | ||||
| Description | Draft _ Delete objects while command is active | ||||
| Steps To Reproduce | set "when drawing lines set focus on Lenght instead of X coordinate" preference Draft Draw a line Activate a command like move Press "del" The entity is deleted and the command crash | ||||
| Additional Information | https://forum.freecadweb.org/viewtopic.php?f=23&t=34771 | ||||
| Tags | Draft | ||||
| 2019-03-13 08:19 | carlopav | New Issue | |
| 2019-03-13 08:19 | carlopav | Tag Attached: Draft | |
| 2019-03-15 22:23 | Kunda1 | Status | new => confirmed |
| 2019-03-15 22:23 | Kunda1 | Note Added: 0012911 | |
| 2019-03-15 22:23 | Kunda1 | Target Version | => 0.19 |
