| 0003905 | PartDesign | Bug | public | 2019-03-14 01:45 | 2021-02-06 06:43 |
| Reporter | mihai.dumitresq | Assigned To | |||
| Summary | 0003905: Editing unlinked parts of a sketch breaks other sketches that have edges linked to it | ||||
| Description | Editing unlinked parts of a sketch breaks other sketches that have edges linked it. When using the part design workbench, if I have multiple sketches that depend on one another (have edges linked from one another) and I try to edit one of the earlier sketches that's very likely to break later sketches, even if what I'm editing is not linked by other sketches. Set the severity as "major" since often times there's no easy workaround. If I wanted to edit, say, the first sketch I would have to: - remove almost all links to the initial sketch - edit it - then add all of the links back "breaking" here means either: - Weird changes in the geometry of the dependent sketches due to edge linked changing (it's like if I originally linked something else) - Dependent sketches become invalid ("The sketch is invalid and cannot be edited") | ||||
| Steps To Reproduce | Here's an easy way to reproduce this. I) Either do this or load the attached file (invalid_sketch_test.fcstd) and skip to part II): Go to Part Design workbench. Create a new body. Create a new sketch in the XY plane. Create a rectangle in the sketch (with the tool, R). Close the sketch. Create a new sketch in the XZ plane (we want it to be dependent and fully constrained). Set to isometric view (0) so you can see the first sketch. Click "Create an edge linked to external geometry (X)" and select the two sides parallel to the Y axis. Set to front view (2). You'll have 2 linked points (not edges). Create a rectangle in the sketch (with the tool, R). Make both linked points be midpoints of two edges of the created rectangle. Make the rectangle a square by setting two adjacent sides be equal. It's now fully constrained. Close the sketch. II) Open the first sketch. Delete Constraint1 which is the first coincident constraint and should have been the constraint for the top right corner. Move the top right corner so it's not a rectangle anymore. Close the first sketch. Try to open the second sketch. Expected: Opens and is unchanged. Actual: "The sketch is invalid and cannot be edited." | ||||
| Additional Information | OS: Ubuntu 16.04.6 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16079 (Git) AppImage Build type: Release Branch: master Hash: 6363c90a20b296ab69d7b52230009928199d90df Python version: 3.6.7 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) I also tested with: OS: Ubuntu 16.04.6 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13541 (Git) AppImage Build type: None Branch: releases/FreeCAD-0-17 Hash: 9948ee4f1570df9216862a79705afb367b2c6ffb Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) | ||||
Please open a thread on the forum and link back to this ticket. (Don't forget to notate said thread URL in this ticket as well) |
I've started a thread but it's pending moderation. I'll post a link when it shows up. Were you able to reproduce the issue? Do you need more information? |
Also note that I had previously looked at other reported issues and found some similar ones: /view.php?id=922 However, they're not exactly the same issue. The issues in /view.php?id=922 are about sketches that have links to external geometry. My report is specifically about sketches that have links to other sketches. To explain more clearly, this issue is about: create sketch -> create another sketch that depends on it -> modify original sketch (problem!) /view.php?id=922 looks to be about: create sketch -> create geometry from sketch (pad, loft, etc.) and maybe chamfer/fillet, etc. -> create another sketch that depends on the geometry -> modify original sketch (problem!) |
Once again this is the topological naming issue at work, and yes, this is what 0000922 is about. This report is therefore unnecessary because redundant. |
https://www.freecad.org/wiki/Glossary#Topological_Naming |
That's the interesting thing: I don't think it's the same issue or at least this bug has a much much simpler solution than topological naming. The ids of the edges in the sketch don't change! (in my repro case) invalid_sketch_test.Sketch.Edge1 through Edge4 are the same in the Sketcher view, before and after removing Constraint1 as per my repro steps. See attached screenshots. |
Looks like there's a mismatch between the edge names when in the full PartDesign view compared to when in the Sketcher view (i.e. when "Sketch" is opened). The same edge is called: invalid_sketch_test.Sketch.Edge1 when the sketch is open invalid_sketch_test.Sketch.Edge4 when the sketch is closed Can anyone point me to the code that assigns edge names? (i.e. the code that resulting in invalid_sketch_test.Sketch.Edge4 being assigned here?) And yes, I realize that this is getting closer and closer to topological naming and @normandc is right but I still think that this issue has a much easier fix than topological naming. |
I couldn't reproduce this issue with the latest version of https://github.com/realthunder/FreeCAD_assembly3/releases And the more complex model that I was editing that prompted this issue works perfectly. @realthunder Awesome! |
This ticket has been migrated to GitHub as issue 5897. |
| 2019-03-14 01:45 | mihai.dumitresq | New Issue | |
| 2019-03-14 01:45 | mihai.dumitresq | File Added: invalid_sketch_test.fcstd | |
| 2019-03-15 22:18 | Kunda1 | Status | new => feedback |
| 2019-03-15 22:18 | Kunda1 | Note Added: 0012910 | |
| 2019-03-16 12:40 | mihai.dumitresq | Note Added: 0012917 | |
| 2019-03-16 12:40 | mihai.dumitresq | Status | feedback => new |
| 2019-03-16 13:16 | mihai.dumitresq | Note Added: 0012918 | |
| 2019-03-16 13:18 | mihai.dumitresq | Note Edited: 0012918 | |
| 2019-03-16 14:15 | normandc | Note Added: 0012920 | |
| 2019-03-16 14:16 | normandc | Note Added: 0012921 | |
| 2019-03-16 14:49 | mihai.dumitresq | File Added: Screenshot from 2019-03-16 14-44-06.png | |
| 2019-03-16 14:49 | mihai.dumitresq | File Added: Screenshot from 2019-03-16 14-42-48.png | |
| 2019-03-16 14:49 | mihai.dumitresq | Note Added: 0012922 | |
| 2019-03-16 16:40 | mihai.dumitresq | File Added: Screenshot from 2019-03-16 16-27-52.png | |
| 2019-03-16 16:40 | mihai.dumitresq | Note Added: 0012923 | |
| 2019-03-16 16:41 | mihai.dumitresq | Note Edited: 0012923 | |
| 2019-03-16 17:37 | mihai.dumitresq | Note Added: 0012925 | |
| 2019-03-16 17:38 | mihai.dumitresq | Note Edited: 0012925 | |
