| 0003912 | FreeCAD | Bug | public | 2019-03-20 09:32 | 2019-09-05 21:49 |
| Reporter | daviddavid | Assigned To | |||
| Summary | 0003912: freecad 0.18 fails to build against Python3 and Qt5 | ||||
| Description | Hi, I tried on Mageia Cauldron to build latest freecad against Qt5 and Python3 but it fails to build with the following error:
Attached full compile log. Regards, David | ||||
log.freecad (760,670 bytes)
Executing(%prep): /bin/sh -e /home/david/mgarepo/freecad/BUILDROOT/rpm-tmp.rYjmYL
+ umask 022
+ cd /home/david/mgarepo/freecad/BUILD
+ '[' 1 -eq 1 ']'
+ '[' 1 -eq 1 ']'
+ '[' 1 -eq 1 ']'
+ rm -rf FreeCAD-0.18
+ /usr/bin/gzip -dc /home/david/mgarepo/freecad/SOURCES/FreeCAD-0.18.tar.gz
+ /usr/bin/tar -xof -
+ STATUS=0
+ '[' 0 -ne 0 ']'
+ cd FreeCAD-0.18
+ /usr/bin/chmod -Rf a+rX,u+w,g-w,o-w .
+ /usr/bin/cat /home/david/mgarepo/freecad/SOURCES/freecad-0.17-zipios.patch
+ /usr/bin/patch -p1 -s --fuzz=0 --no-backup-if-mismatch
+ /usr/bin/cat /home/david/mgarepo/freecad/SOURCES/freecad-0.17-Version_h.patch
+ rm -rf src/CXX
+ rm -rf src/zipios++
+ sed -i 's|target_link_libraries(FreeCADBase \${FreeCADBase_LIBS})|target_link_libraries(FreeCADBase \${FreeCADBase_LIBS} -lpython3.7)|' src/Base/CMakeLists.txt
+ exit 0
Executing(%build): /bin/sh -e /home/david/mgarepo/freecad/BUILDROOT/rpm-tmp.DWaMFQ
+ umask 022
+ cd FreeCAD-0.18
+ '[' 1 -eq 1 ']'
+ '[' 1 -eq 1 ']'
+ LDFLAGS='-Wl,--as-needed -Wl,--no-undefined'
+ export LDFLAGS
+ CFLAGS='-O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables'
+ export CFLAGS
+ CXXFLAGS='-O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables'
+ export CXXFLAGS
+ FFLAGS='-O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables'
+ export FFLAGS
+ export LDFLAGS
+ mkdir -p build
+ cd build
++ pkg-config --variable=includedir PyCXX
++ pkg-config --variable=srcdir PyCXX
+ /usr/bin/cmake .. -DCMAKE_INSTALL_PREFIX:PATH=/usr -DCMAKE_INSTALL_LIBDIR:PATH=/usr/lib64 -DCMAKE_INSTALL_LIBEXECDIR:PATH=/usr/libexec -DCMAKE_INSTALL_RUNSTATEDIR:PATH=/run -DCMAKE_INSTALL_SYSCONFDIR:PATH=/etc -DINCLUDE_INSTALL_DIR:PATH=/usr/include -DLIB_INSTALL_DIR:PATH=/usr/lib64 -DSYSCONF_INSTALL_DIR:PATH=/etc -DSHARE_INSTALL_PREFIX:PATH=/usr/share -DCMAKE_BUILD_TYPE=RelWithDebInfo -DCMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-DNDEBUG -DCMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-DNDEBUG -DLIB_SUFFIX=64 -DCMAKE_SKIP_RPATH:BOOL=ON -DCMAKE_VERBOSE_MAKEFILE:BOOL=ON '-DCMAKE_MODULE_LINKER_FLAGS=-Wl,--as-needed -Wl,-z,relro -Wl,-O1 -Wl,--build-id -Wl,--enable-new-dtags' -DBUILD_SHARED_LIBS:BOOL=ON -DBUILD_STATIC_LIBS:BOOL=OFF -DCMAKE_INSTALL_PREFIX=/usr/lib64/freecad -DCMAKE_INSTALL_LIBDIR=/usr/lib64/freecad/lib -DCMAKE_INSTALL_DATADIR=/usr/share/freecad -DCMAKE_INSTALL_DOCDIR=/usr/share/doc/freecad -DCMAKE_INSTALL_INCLUDEDIR=/usr/include -DRESOURCEDIR=/usr/share/freecad -DOpenGL_GL_PREFERENCE=GLVND -DCOIN3D_INCLUDE_DIR=/usr/include/Coin3 -DCOIN3D_DOC_PATH=/usr/share/Coin -DFREECAD_USE_EXTERNAL_PIVY=TRUE -DFREECAD_USE_EXTERNAL_SMESH=FALSE -DSMESH_INCLUDE_DIR=/usr/include/smesh -DFREECAD_USE_EXTERNAL_ZIPIOS=TRUE -DPYCXX_INCLUDE_DIR=/usr/include -DPYCXX_SOURCE_DIR=/usr/src/CXX -DMEDFILE_INCLUDE_DIRS=/usr/include/med -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3 -DPYTHON_CONFIG_SUFFIX=.cpython-37m-x86_64-linux-gnu ../
-- The C compiler identification is GNU 8.3.1
-- The CXX compiler identification is GNU 8.3.1
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Compiler: GNU, version: 8.3.1
-- Looking for GL/gl.h
-- Looking for GL/gl.h - found
-- Looking for C++ include istream
-- Looking for C++ include istream - found
-- Looking for C++ include ostream
-- Looking for C++ include ostream - found
-- Looking for C++ include fstream
-- Looking for C++ include fstream - found
-- Looking for C++ include sstream
-- Looking for C++ include sstream - found
-- Looking for C++ include ios
-- Looking for C++ include ios - found
-- Looking for C++ include iostream
-- Looking for C++ include iostream - found
-- Looking for C++ include iomanip
-- Looking for C++ include iomanip - found
-- Check for STD namespace
-- Check for STD namespace - found
-- prefix: /usr/lib64/freecad
-- datadir: /usr/share/freecad
-- docdir: /usr/share/doc/freecad
-- includedir: /usr/include
-- libdir: /usr/lib64/freecad/lib
-- cmake: 3.13.4
-- Found PythonInterp: /usr/bin/python3 (found version "3.7.2")
-- Found PythonLibs: /usr/lib64/libpython3.7m.so (found suitable exact version "3.7.2")
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Boost version: 1.68.0
-- Found the following Boost libraries:
-- filesystem
-- program_options
-- regex
-- system
-- thread
-- chrono
-- date_time
-- atomic
-- Found Xerces-C: /usr/lib64/libxerces-c.so
-- Found ZLIB: /usr/lib64/libz.so (found version "1.2.11")
-- PyCXX found:
-- Headers: /usr/include
-- Sources: /usr/src/CXX
-- Version: 7.1.0
-- -- OpenCASCADE Community Edition has been found.
-- Found OCC: /usr/share/cmake/OCE/../../../include/opencascade (found version "6.9.1")
-- -- Found OCE/OpenCASCADE version: 6.9.1
-- -- OCE/OpenCASCADE include directory: /usr/share/cmake/OCE/../../../include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory:
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkIOMPIParallel;vtkParallelMPI;vtkhdf5;vtkFiltersParallelDIY2;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
-- Check for medfile (libmed and libmedc) ...
-- Found MEDFile: /usr/include/med
-- Found PkgConfig: /usr/bin/pkg-config (found version "1.5.4")
-- We guess that libmed was built using hdf5-serial version
-- Checking for one of the modules 'hdf5-serial'
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- Found HDF5: /usr/lib64/libhdf5.so;/usr/lib64/libz.so;/usr/lib64/libdl.so;/usr/lib64/libm.so (found version "1.8.21")
-- Checking for one of the modules 'ompi-cxx'
CMake Warning at CMakeLists.txt:745 (message):
mpi.h was not found. Check for error above.
-- Found SWIG: /usr/bin/swig (found version "3.0.12")
-- Found Eigen3: /usr/include (Required is at least version "2.91.0")
-- Found Freetype: /usr/lib64/libfreetype.so (found version "2.9.1")
-- Found OpenGL: /usr/lib64/libGL.so
-- Found OpenGLU: /usr/lib64/libGLU.so
-- Checking for module 'Coin'
-- Found Coin, version 3.1.3
-- Found Spnav: /usr/lib64/libspnav.so
-- libshiboken built for Release
-- PYTHON_CONFIG_SUFFIX: .cpython-37m-x86_64-linux-gnu
-- -- matplotlib-2.2.2 has been found.
-- Platform is 64-bit, set -D_OCC64
-- Build type: RelWithDebInfo
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
/bin/sh: bzr: command not found
svn: warning: W155010: The node '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18' was not found.
svn: E200009: Could not display info for all targets because some targets don't exist
Unknown version control
/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Build/Version.h.out written
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/BaseClassPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/BoundBoxPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/CoordinateSystemPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/PersistencePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/VectorPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/MatrixPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/RotationPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/PlacementPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/AxisPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/UnitPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/QuantityPy.cpp
-- Found zipios++: /usr/lib64/libzipios.so
-- Found zipios++ headers.
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/DocumentPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/DocumentObjectPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/ExtensionPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/ExtensionContainerPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/DocumentObjectExtensionPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/GroupExtensionPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/DocumentObjectGroupPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/GeoFeaturePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/GeoFeatureGroupExtensionPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/OriginGroupExtensionPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/PartPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/ComplexGeoDataPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/PropertyContainerPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/App/MaterialPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Points/App/PointsPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Mesh/App/FacetPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Mesh/App/MeshFeaturePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Mesh/App/MeshPointPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Mesh/App/MeshPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Mesh/Gui/ViewProviderMeshPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/ArcPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/ArcOfConicPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/ArcOfCirclePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/ArcOfParabolaPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/BodyBasePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/ConicPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/CirclePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/ArcOfEllipsePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/EllipsePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/HyperbolaPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/ArcOfHyperbolaPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/ParabolaPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/OffsetCurvePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/GeometryPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/GeometryCurvePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/BoundedCurvePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/TrimmedCurvePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/GeometrySurfacePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/LinePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/LineSegmentPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/PointPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/BezierCurvePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/BSplineCurvePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/PlanePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/ConePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/CylinderPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/SpherePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/ToroidPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/BezierSurfacePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/BSplineSurfacePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/OffsetSurfacePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/PlateSurfacePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/RectangularTrimmedSurfacePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/SurfaceOfExtrusionPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/SurfaceOfRevolutionPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/PartFeaturePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/AttachExtensionPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Part2DObjectPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/AttachEnginePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/TopoShapePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/TopoShapeCompoundPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/TopoShapeCompSolidPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/TopoShapeEdgePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/TopoShapeFacePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/TopoShapeShellPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/TopoShapeSolidPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/TopoShapeVertexPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/TopoShapeWirePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/BRepOffsetAPI_MakePipeShellPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/ArcOfCircle2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/ArcOfConic2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/ArcOfEllipse2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/ArcOfHyperbola2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/ArcOfParabola2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/BezierCurve2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/BSplineCurve2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/Circle2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/Conic2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/Ellipse2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/Geometry2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/Hyperbola2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/Curve2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/Line2dSegmentPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/Line2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/OffsetCurve2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/App/Geom2d/Parabola2dPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign/App/BodyPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign/App/FeaturePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign/Gui/ViewProviderPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher/App/SketchObjectSFPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher/App/SketchObjectPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher/App/ConstraintPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher/App/SketchPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot/App/Robot6AxisPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot/App/TrajectoryPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot/App/WaypointPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot/App/RobotObjectPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App/StepShapePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/App/FemMeshPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/App/FemPostPipelinePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui/ViewProviderFemMeshPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Spreadsheet/App/SheetPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Spreadsheet/App/PropertySheetPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Spreadsheet/App/PropertyColumnWidthsPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Spreadsheet/App/PropertyRowHeightsPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/App/CommandPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/App/PathPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/App/ToolPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/App/TooltablePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/App/FeaturePathCompoundPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/App/AreaPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/App/FeatureAreaPy.cpp
-- setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors
-- python37
-- found Boost: 1_68
-- boost-incude dirs are: /usr/include
-- boost-python lib is:
-- boost_LIBRARY_DIRS is: /usr/lib64
-- Boost_LIBRARIES is: /usr/lib64/libboost_python37.so
-- area module (for Path Workbench) will be installed to: /usr/lib64/freecad/lib
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/PathSimulator/App/PathSimPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Measure/App/MeasurementPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawPagePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawViewPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawViewPartPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawViewSymbolPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawTemplatePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawParametricTemplatePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawSVGTemplatePy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawViewClipPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawViewDimensionPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawHatchPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawGeomHatchPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawViewCollectionPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawProjGroupPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawProjGroupItemPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/TechDraw/App/DrawViewAnnotationPy.cpp
Created file /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/doc/freecad.qch
-- Found Doxygen: /usr/bin/doxygen (found version "1.8.15") found components: doxygen dot
-- Coin3D doc is installed
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Gui/DocumentPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Gui/PythonWorkbenchPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Gui/ViewProviderPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Gui/ViewProviderDocumentObjectPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Gui/WorkbenchPy.cpp
-- /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Gui/SelectionObjectPy.cpp
Now run 'make' to build FreeCAD
-- Configuring done
-- Generating done
-- Build files have been written to: /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build
+ /usr/bin/make -O -j4
/usr/bin/cmake -S/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 -B/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build --check-build-system CMakeFiles/Makefile.cmake 0
/usr/bin/cmake -E cmake_progress_start /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/CMakeFiles /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/CMakeFiles/progress.marks
/usr/bin/make -f CMakeFiles/Makefile2 all
/usr/bin/make -f src/3rdParty/salomesmesh/CMakeFiles/MEFISTO2.dir/build.make src/3rdParty/salomesmesh/CMakeFiles/MEFISTO2.dir/depend
/usr/bin/make -f src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/build.make src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/depend
/usr/bin/make -f src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/build.make src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/depend
/usr/bin/make -f src/Base/CMakeFiles/FreeCADBase.dir/build.make src/Base/CMakeFiles/FreeCADBase.dir/depend
make[2]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/DependInfo.cmake --color=
Scanning dependencies of target Driver
make[2]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
/usr/bin/make -f src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/build.make src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/build
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh/CMakeFiles/MEFISTO2.dir/DependInfo.cmake --color=
Scanning dependencies of target MEFISTO2
/usr/bin/make -f src/3rdParty/salomesmesh/CMakeFiles/MEFISTO2.dir/build.make src/3rdParty/salomesmesh/CMakeFiles/MEFISTO2.dir/build
[ 0%] Generating moc_FutureWatcherProgress.cpp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/lib64/qt5/bin/moc @/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/moc_FutureWatcherProgress.cpp_parameters
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/DependInfo.cmake --color=
Scanning dependencies of target SMDS
/usr/bin/make -f src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/build.make src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/build
[ 0%] Generating moc_Debugger.cpp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/lib64/qt5/bin/moc @/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/moc_Debugger.cpp_parameters
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base/CMakeFiles/FreeCADBase.dir/DependInfo.cmake --color=
Scanning dependencies of target FreeCADBase
/usr/bin/make -f src/Base/CMakeFiles/FreeCADBase.dir/build.make src/Base/CMakeFiles/FreeCADBase.dir/build
[ 0%] Building C object src/Base/CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxxextensions.c.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/cc -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -DNDEBUG -fPIC -fPIC -o CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxxextensions.c.o -c /usr/src/CXX/cxxextensions.c
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_Document.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DDriver_EXPORTS -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -o CMakeFiles/Driver.dir/src/Driver/Driver_Document.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver/Driver_Document.cpp
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/MEFISTO2.dir/src/MEFISTO2/aptrte.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DMEFISTO2_EXPORTS -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -DMEFISTO2D_EXPORTS -o CMakeFiles/MEFISTO2.dir/src/MEFISTO2/aptrte.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/MEFISTO2/aptrte.cpp
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_BallElement.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_BallElement.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_BallElement.cpp
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_Mesh.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DDriver_EXPORTS -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -o CMakeFiles/Driver.dir/src/Driver/Driver_Mesh.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver/Driver_Mesh.cpp
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_SMDS_Mesh.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DDriver_EXPORTS -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -o CMakeFiles/Driver.dir/src/Driver/Driver_SMDS_Mesh.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver/Driver_SMDS_Mesh.cpp
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_SMESHDS_Mesh.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DDriver_EXPORTS -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -o CMakeFiles/Driver.dir/src/Driver/Driver_SMESHDS_Mesh.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver/Driver_SMESHDS_Mesh.cpp
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxx_extensions.cxx.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxx_extensions.cxx.o -c /usr/src/CXX/cxx_extensions.cxx
[ 0%] Building C object src/3rdParty/salomesmesh/CMakeFiles/MEFISTO2.dir/src/MEFISTO2/trte.c.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/cc -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DMEFISTO2_EXPORTS -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -DNDEBUG -fPIC -DMEFISTO2D_EXPORTS -o CMakeFiles/MEFISTO2.dir/src/MEFISTO2/trte.c.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/MEFISTO2/trte.c
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxxsupport.cxx.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxxsupport.cxx.o -c /usr/src/CXX/cxxsupport.cxx
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_Downward.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_Downward.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_Downward.cpp
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/usr/src/CXX/IndirectPythonInterface.cxx.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/usr/src/CXX/IndirectPythonInterface.cxx.o -c /usr/src/CXX/IndirectPythonInterface.cxx
[ 0%] Linking CXX shared library ../../../lib/libDriver.so
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/cmake -E cmake_link_script CMakeFiles/Driver.dir/link.txt --verbose=1
/usr/bin/c++ -fPIC -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -Wl,--as-needed -Wl,--no-undefined -Wl,--no-undefined -shared -Wl,-soname,libDriver.so -o ../../../lib/libDriver.so CMakeFiles/Driver.dir/src/Driver/Driver_Document.cpp.o CMakeFiles/Driver.dir/src/Driver/Driver_Mesh.cpp.o CMakeFiles/Driver.dir/src/Driver/Driver_SMDS_Mesh.cpp.o CMakeFiles/Driver.dir/src/Driver/Driver_SMESHDS_Mesh.cpp.o /usr/lib64/libTKSTL.so.11.0.0 /usr/lib64/libTKBin.so.11.0.0 /usr/lib64/libTKFeat.so.11.0.0 /usr/lib64/libTKXDESTEP.so.11.0.0 /usr/lib64/libTKXDEIGES.so.11.0.0 /usr/lib64/libTKMeshVS.so.11.0.0 /usr/lib64/libTKBinL.so.11.0.0 /usr/lib64/libTKSTEP.so.11.0.0 /usr/lib64/libTKSTEP209.so.11.0.0 /usr/lib64/libTKSTEPAttr.so.11.0.0 /usr/lib64/libTKSTEPBase.so.11.0.0 /usr/lib64/libTKIGES.so.11.0.0 /usr/lib64/libTKOffset.so.11.0.0 /usr/lib64/libTKFillet.so.11.0.0 /usr/lib64/libTKBool.so.11.0.0 /usr/lib64/libTKXSBase.so.11.0.0 /usr/lib64/libTKXCAF.so.11.0.0 /usr/lib64/libTKCAF.so.11.0.0 /usr/lib64/libTKBO.so.11.0.0 /usr/lib64/libTKPrim.so.11.0.0 /usr/lib64/libTKLCAF.so.11.0.0 /usr/lib64/libTKCDF.so.11.0.0 /usr/lib64/libTKV3d.so.11.0.0 /usr/lib64/libTKMesh.so.11.0.0 /usr/lib64/libTKHLR.so.11.0.0 /usr/lib64/libTKService.so.11.0.0 /usr/lib64/libTKShHealing.so.11.0.0 /usr/lib64/libTKTopAlgo.so.11.0.0 /usr/lib64/libTKGeomAlgo.so.11.0.0 /usr/lib64/libTKBRep.so.11.0.0 /usr/lib64/libTKGeomBase.so.11.0.0 /usr/lib64/libTKG3d.so.11.0.0 /usr/lib64/libTKG2d.so.11.0.0 /usr/lib64/libTKMath.so.11.0.0 /usr/lib64/libTKernel.so.11.0.0 -lpthread -ldl -lm /usr/lib64/libSM.so /usr/lib64/libICE.so /usr/lib64/libX11.so /usr/lib64/libXext.so /usr/lib64/libGL.so /usr/lib64/libGLU.so /usr/lib64/libfreetype.so
make[1]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 0%] Built target Driver
make[1]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
/usr/bin/make -f src/Mod/Complete/CMakeFiles/Complete.dir/build.make src/Mod/Complete/CMakeFiles/Complete.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Complete /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Complete /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Complete/CMakeFiles/Complete.dir/DependInfo.cmake --color=
Scanning dependencies of target Complete
/usr/bin/make -f src/Mod/Complete/CMakeFiles/Complete.dir/build.make src/Mod/Complete/CMakeFiles/Complete.dir/build
[ 0%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Complete/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Complete/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Complete && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Complete/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Complete/Init.py
[ 0%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Complete/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Complete/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Complete && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Complete/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Complete/InitGui.py
[ 0%] Built target Complete
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Axis.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Axis.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Axis.cpp
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxx_exceptions.cxx.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxx_exceptions.cxx.o -c /usr/src/CXX/cxx_exceptions.cxx
[ 0%] Linking CXX shared library ../../../lib/libMEFISTO2.so
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/cmake -E cmake_link_script CMakeFiles/MEFISTO2.dir/link.txt --verbose=1
/usr/bin/c++ -fPIC -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -Wl,--as-needed -Wl,--no-undefined -Wl,--no-undefined -shared -Wl,-soname,libMEFISTO2.so -o ../../../lib/libMEFISTO2.so CMakeFiles/MEFISTO2.dir/src/MEFISTO2/aptrte.cpp.o CMakeFiles/MEFISTO2.dir/src/MEFISTO2/trte.c.o /usr/lib64/libTKSTL.so.11.0.0 /usr/lib64/libTKBin.so.11.0.0 /usr/lib64/libTKFeat.so.11.0.0 /usr/lib64/libTKXDESTEP.so.11.0.0 /usr/lib64/libTKXDEIGES.so.11.0.0 /usr/lib64/libTKMeshVS.so.11.0.0 /usr/lib64/libTKBinL.so.11.0.0 /usr/lib64/libTKSTEP.so.11.0.0 /usr/lib64/libTKSTEP209.so.11.0.0 /usr/lib64/libTKSTEPAttr.so.11.0.0 /usr/lib64/libTKSTEPBase.so.11.0.0 /usr/lib64/libTKIGES.so.11.0.0 /usr/lib64/libTKOffset.so.11.0.0 /usr/lib64/libTKFillet.so.11.0.0 /usr/lib64/libTKBool.so.11.0.0 /usr/lib64/libTKXSBase.so.11.0.0 /usr/lib64/libTKXCAF.so.11.0.0 /usr/lib64/libTKCAF.so.11.0.0 /usr/lib64/libTKBO.so.11.0.0 /usr/lib64/libTKPrim.so.11.0.0 /usr/lib64/libTKLCAF.so.11.0.0 /usr/lib64/libTKCDF.so.11.0.0 /usr/lib64/libTKV3d.so.11.0.0 /usr/lib64/libTKMesh.so.11.0.0 /usr/lib64/libTKHLR.so.11.0.0 /usr/lib64/libTKService.so.11.0.0 /usr/lib64/libTKShHealing.so.11.0.0 /usr/lib64/libTKTopAlgo.so.11.0.0 /usr/lib64/libTKGeomAlgo.so.11.0.0 /usr/lib64/libTKBRep.so.11.0.0 /usr/lib64/libTKGeomBase.so.11.0.0 /usr/lib64/libTKG3d.so.11.0.0 /usr/lib64/libTKG2d.so.11.0.0 /usr/lib64/libTKMath.so.11.0.0 /usr/lib64/libTKernel.so.11.0.0 -lpthread -ldl -lm /usr/lib64/libSM.so /usr/lib64/libICE.so /usr/lib64/libX11.so /usr/lib64/libXext.so /usr/lib64/libGL.so /usr/lib64/libGLU.so /usr/lib64/libfreetype.so
[ 0%] Built target MEFISTO2
/usr/bin/make -f src/Mod/Complete/Gui/CMakeFiles/CompleteGui.dir/build.make src/Mod/Complete/Gui/CMakeFiles/CompleteGui.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Complete/Gui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Complete/Gui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Complete/Gui/CMakeFiles/CompleteGui.dir/DependInfo.cmake --color=
Scanning dependencies of target CompleteGui
/usr/bin/make -f src/Mod/Complete/Gui/CMakeFiles/CompleteGui.dir/build.make src/Mod/Complete/Gui/CMakeFiles/CompleteGui.dir/build
[ 0%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Complete/Gui/Resources/icons/CompleteWorkbench.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Complete/Resources/icons/CompleteWorkbench.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Complete/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Complete/Gui/Resources/icons/CompleteWorkbench.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Complete/Resources/icons/CompleteWorkbench.svg
[ 0%] Built target CompleteGui
/usr/bin/make -f src/Mod/Test/CMakeFiles/Test.dir/build.make src/Mod/Test/CMakeFiles/Test.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test/CMakeFiles/Test.dir/DependInfo.cmake --color=
Scanning dependencies of target Test
/usr/bin/make -f src/Mod/Test/CMakeFiles/Test.dir/build.make src/Mod/Test/CMakeFiles/Test.dir/build
[ 0%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/__init__.py
[ 0%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/Init.py
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/BaseTests.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/BaseTests.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/BaseTests.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/BaseTests.py
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/Document.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/Document.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/Document.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/Document.py
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/Menu.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/Menu.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/Menu.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/Menu.py
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/TestApp.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/TestApp.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/TestApp.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/TestApp.py
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/TestGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/TestGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/TestGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/TestGui.py
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/UnicodeTests.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/UnicodeTests.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/UnicodeTests.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/UnicodeTests.py
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/UnitTests.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/UnitTests.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/UnitTests.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/UnitTests.py
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/Workbench.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/Workbench.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/Workbench.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/Workbench.py
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/unittestgui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/unittestgui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/unittestgui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/unittestgui.py
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/testmakeWireString.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/testmakeWireString.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/testmakeWireString.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/testmakeWireString.py
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Base64.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Base64.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Base64.cpp
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/TestPythonSyntax.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/TestPythonSyntax.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/TestPythonSyntax.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/TestPythonSyntax.py
[ 1%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Test && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Test/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Test/InitGui.py
[ 1%] Built target Test
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_EdgePosition.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_EdgePosition.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_EdgePosition.cpp
[ 1%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/BaseClass.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/BaseClass.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/BaseClass.cpp
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_FaceOfEdges.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_FaceOfEdges.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_FaceOfEdges.cpp
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/AxisPyImp.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/AxisPyImp.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/AxisPyImp.cpp
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_FaceOfNodes.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_FaceOfNodes.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_FaceOfNodes.cpp
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_FacePosition.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_FacePosition.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_FacePosition.cpp
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_IteratorOfElements.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_IteratorOfElements.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_IteratorOfElements.cpp
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_LinearEdge.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_LinearEdge.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_LinearEdge.cpp
[ 1%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/BaseClassPyImp.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/BaseClassPyImp.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/BaseClassPyImp.cpp
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh0DElement.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh0DElement.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_Mesh0DElement.cpp
[ 1%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/BoundBoxPyImp.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/BoundBoxPyImp.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/BoundBoxPyImp.cpp
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshCell.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshCell.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_MeshCell.cpp
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshEdge.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshEdge.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_MeshEdge.cpp
make[2]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshElement.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshElement.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_MeshElement.cpp
make[2]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 1%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Console.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Console.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Console.cpp
[ 1%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/CoordinateSystem.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/CoordinateSystem.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/CoordinateSystem.cpp
[ 1%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Builder3D.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Builder3D.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Builder3D.cpp
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshElementIDFactory.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshElementIDFactory.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_MeshElementIDFactory.cpp
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_Mesh.cpp
[ 2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshFace.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshFace.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_MeshFace.cpp
[ 1%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Debugger.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Debugger.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Debugger.cpp
[ 1%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/CoordinateSystemPyImp.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/CoordinateSystemPyImp.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/CoordinateSystemPyImp.cpp
[ 2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshIDFactory.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshIDFactory.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_MeshIDFactory.cpp
[ 2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshGroup.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshGroup.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_MeshGroup.cpp
[ 2%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/ExceptionFactory.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/ExceptionFactory.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/ExceptionFactory.cpp
[ 2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshNodeIDFactory.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshNodeIDFactory.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_MeshNodeIDFactory.cpp
[ 2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshObject.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshObject.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_MeshObject.cpp
[ 2%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Exception.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Exception.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Exception.cpp
[ 2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshNode.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshNode.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_MeshNode.cpp
[ 2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshVolume.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshVolume.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_MeshVolume.cpp
[ 2%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Factory.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Factory.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Factory.cpp
[ 2%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/FileTemplate.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/FileTemplate.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/FileTemplate.cpp
[ 2%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/FileInfo.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/FileInfo.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/FileInfo.cpp
[ 2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_PolygonalFaceOfNodes.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_PolygonalFaceOfNodes.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_PolygonalFaceOfNodes.cpp
[ 2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_PolyhedralVolumeOfNodes.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_PolyhedralVolumeOfNodes.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_PolyhedralVolumeOfNodes.cpp
[ 2%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/gzstream.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/gzstream.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/gzstream.cpp
[ 2%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/FutureWatcherProgress.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/FutureWatcherProgress.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/FutureWatcherProgress.cpp
[ 2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_Position.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_Position.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_Position.cpp
[ 2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_QuadraticEdge.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_QuadraticEdge.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_QuadraticEdge.cpp
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Handle.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Handle.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Handle.cpp
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/GeometryPyCXX.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/GeometryPyCXX.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/GeometryPyCXX.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_QuadraticFaceOfNodes.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_QuadraticFaceOfNodes.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_QuadraticFaceOfNodes.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_QuadraticVolumeOfNodes.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_QuadraticVolumeOfNodes.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_QuadraticVolumeOfNodes.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_SpacePosition.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_SpacePosition.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_SpacePosition.cpp
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/InputSource.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/InputSource.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/InputSource.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_VertexPosition.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VertexPosition.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_VertexPosition.cpp
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Matrix.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Matrix.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Matrix.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_VolumeOfFaces.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VolumeOfFaces.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_VolumeOfFaces.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_UnstructuredGrid.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_UnstructuredGrid.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_UnstructuredGrid.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_VolumeOfNodes.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VolumeOfNodes.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_VolumeOfNodes.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkCellIterator.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkCellIterator.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_VtkCellIterator.cpp
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Interpreter.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Interpreter.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Interpreter.cpp
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/MemDebug.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/MemDebug.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/MemDebug.cpp
make[2]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkEdge.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkEdge.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_VtkEdge.cpp
make[2]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/MatrixPyImp.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/MatrixPyImp.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/MatrixPyImp.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_VolumeTool.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VolumeTool.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_VolumeTool.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkFace.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkFace.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_VtkFace.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/Utils_SALOME_Exception.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/Utils_SALOME_Exception.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/Utils_SALOME_Exception.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkVolume.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkVolume.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/SMDS_VtkVolume.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/chrono.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/chrono.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/chrono.cpp
[ 3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/duplicate.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -DPYCXX_6_2_COMPATIBILITY -DSMDS_EXPORTS -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/Driver -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverUNV -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverDAT -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/DriverSTL -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/StdMeshers -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/inc -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh -I/usr/share/cmake/OCE/../../../include/opencascade -I//include/vtk-8.2 -I/usr/include/double-conversion -I/usr/include/jsoncpp -I/usr/include/freetype2 -I/usr/include/med -isystem /usr/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -fPIC -std=gnu++11 -o CMakeFiles/SMDS.dir/src/SMDS/duplicate.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/3rdParty/salomesmesh/src/SMDS/duplicate.cpp
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Parameter.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Parameter.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Parameter.cpp
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Persistence.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Persistence.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Persistence.cpp
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Placement.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Placement.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Placement.cpp
[ 3%] Linking CXX shared library ../../../lib/libSMDS.so
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/3rdParty/salomesmesh && /usr/bin/cmake -E cmake_link_script CMakeFiles/SMDS.dir/link.txt --verbose=1
/usr/bin/c++ -fPIC -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -DNDEBUG -Wl,--as-needed -Wl,--no-undefined -Wl,--no-undefined -shared -Wl,-soname,libSMDS.so -o ../../../lib/libSMDS.so CMakeFiles/SMDS.dir/src/SMDS/SMDS_BallElement.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_Downward.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_EdgePosition.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_FaceOfEdges.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_FaceOfNodes.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_FacePosition.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_IteratorOfElements.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_LinearEdge.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh0DElement.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshCell.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshEdge.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshElement.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshElementIDFactory.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshFace.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshGroup.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshIDFactory.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshNode.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshNodeIDFactory.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshObject.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_MeshVolume.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_PolygonalFaceOfNodes.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_PolyhedralVolumeOfNodes.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_Position.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_QuadraticEdge.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_QuadraticFaceOfNodes.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_QuadraticVolumeOfNodes.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_SpacePosition.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_UnstructuredGrid.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VertexPosition.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VolumeOfFaces.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VolumeOfNodes.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VolumeTool.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkCellIterator.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkEdge.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkFace.cpp.o CMakeFiles/SMDS.dir/src/SMDS/SMDS_VtkVolume.cpp.o CMakeFiles/SMDS.dir/src/SMDS/Utils_SALOME_Exception.cpp.o CMakeFiles/SMDS.dir/src/SMDS/chrono.cpp.o CMakeFiles/SMDS.dir/src/SMDS/duplicate.cpp.o /usr/lib64/libTKSTL.so.11.0.0 /usr/lib64/libTKBin.so.11.0.0 /usr/lib64/libTKFeat.so.11.0.0 /usr/lib64/libTKXDESTEP.so.11.0.0 /usr/lib64/libTKXDEIGES.so.11.0.0 /usr/lib64/libTKMeshVS.so.11.0.0 /usr/lib64/vtk-8.2/libvtkFiltersVerdict-8.2.so.1 /usr/lib64/vtk-8.2/libvtkverdict-8.2.so.1 /usr/lib64/libdouble-conversion.so /usr/lib64/liblz4.so /usr/lib64/liblzma.so /usr/lib64/libz.so /usr/lib64/libexpat.so /usr/lib64/vtk-8.2/libvtkIOMPIParallel-8.2.so.1 /usr/lib64/libjpeg.so /usr/lib64/libpng.so /usr/lib64/libtiff.so /usr/lib64/vtk-8.2/libvtkIOParallel-8.2.so.1 /usr/lib64/vtk-8.2/libvtkIONetCDF-8.2.so.1 /usr/lib64/libnetcdf.so /usr/lib64/libhdf5.so /usr/lib64/libdl.so -lm /usr/lib64/libhdf5_hl.so /usr/lib64/vtk-8.2/libvtkexodusII-8.2.so.1 /usr/lib64/libjsoncpp.so /usr/lib64/vtk-8.2/libvtkFiltersParallelDIY2-8.2.so.1 /usr/lib64/vtk-8.2/libvtkInteractionStyle-8.2.so.1 /usr/lib64/vtk-8.2/libvtkRenderingFreeType-8.2.so.1 /usr/lib64/libfreetype.so /usr/lib64/vtk-8.2/libvtkRenderingOpenGL2-8.2.so.1 /usr/lib64/libGLEW.so /usr/lib64/libTKBinL.so.11.0.0 /usr/lib64/libTKSTEP.so.11.0.0 /usr/lib64/libTKSTEP209.so.11.0.0 /usr/lib64/libTKSTEPAttr.so.11.0.0 /usr/lib64/libTKSTEPBase.so.11.0.0 /usr/lib64/libTKIGES.so.11.0.0 /usr/lib64/libTKOffset.so.11.0.0 /usr/lib64/libTKFillet.so.11.0.0 /usr/lib64/libTKBool.so.11.0.0 /usr/lib64/libTKXSBase.so.11.0.0 /usr/lib64/libTKXCAF.so.11.0.0 /usr/lib64/libTKCAF.so.11.0.0 /usr/lib64/libTKBO.so.11.0.0 /usr/lib64/libTKPrim.so.11.0.0 /usr/lib64/libTKLCAF.so.11.0.0 /usr/lib64/libTKCDF.so.11.0.0 /usr/lib64/libTKV3d.so.11.0.0 /usr/lib64/libTKMesh.so.11.0.0 /usr/lib64/libTKHLR.so.11.0.0 /usr/lib64/libTKService.so.11.0.0 /usr/lib64/libTKShHealing.so.11.0.0 /usr/lib64/libTKTopAlgo.so.11.0.0 /usr/lib64/libTKGeomAlgo.so.11.0.0 /usr/lib64/libTKBRep.so.11.0.0 /usr/lib64/libTKGeomBase.so.11.0.0 /usr/lib64/libTKG3d.so.11.0.0 /usr/lib64/libTKG2d.so.11.0.0 /usr/lib64/libTKMath.so.11.0.0 /usr/lib64/libTKernel.so.11.0.0 -lpthread -lm /usr/lib64/libGL.so /usr/lib64/libGLU.so /usr/lib64/vtk-8.2/libvtkIOGeometry-8.2.so.1 /usr/lib64/vtk-8.2/libvtkIOImage-8.2.so.1 /usr/lib64/vtk-8.2/libvtkDICOMParser-8.2.so.1 /usr/lib64/vtk-8.2/libvtkmetaio-8.2.so.1 /usr/lib64/libz.so /usr/lib64/libnetcdf.so /usr/lib64/vtk-8.2/libvtkIOXML-8.2.so.1 /usr/lib64/vtk-8.2/libvtkIOXMLParser-8.2.so.1 /usr/lib64/vtk-8.2/libvtkFiltersParallel-8.2.so.1 /usr/lib64/vtk-8.2/libvtkFiltersModeling-8.2.so.1 /usr/lib64/vtk-8.2/libvtkParallelMPI-8.2.so.1 /usr/lib64/vtk-8.2/libvtkParallelCore-8.2.so.1 /usr/lib64/vtk-8.2/libvtkIOLegacy-8.2.so.1 /usr/lib64/vtk-8.2/libvtkIOCore-8.2.so.1 /usr/lib64/vtk-8.2/libvtkFiltersExtraction-8.2.so.1 /usr/lib64/vtk-8.2/libvtkFiltersStatistics-8.2.so.1 /usr/lib64/vtk-8.2/libvtkImagingFourier-8.2.so.1 /usr/lib64/vtk-8.2/libvtkImagingCore-8.2.so.1 /usr/lib64/libfreetype.so /usr/lib64/vtk-8.2/libvtkRenderingCore-8.2.so.1 /usr/lib64/vtk-8.2/libvtkFiltersSources-8.2.so.1 /usr/lib64/vtk-8.2/libvtkFiltersGeneral-8.2.so.1 /usr/lib64/vtk-8.2/libvtkCommonComputationalGeometry-8.2.so.1 /usr/lib64/vtk-8.2/libvtkFiltersGeometry-8.2.so.1 /usr/lib64/vtk-8.2/libvtkFiltersCore-8.2.so.1 /usr/lib64/vtk-8.2/libvtkCommonExecutionModel-8.2.so.1 /usr/lib64/vtk-8.2/libvtkCommonColor-8.2.so.1 /usr/lib64/vtk-8.2/libvtkCommonDataModel-8.2.so.1 /usr/lib64/vtk-8.2/libvtkCommonMisc-8.2.so.1 /usr/lib64/vtk-8.2/libvtkCommonSystem-8.2.so.1 /usr/lib64/vtk-8.2/libvtksys-8.2.so.1 -ldl /usr/lib64/vtk-8.2/libvtkCommonTransforms-8.2.so.1 /usr/lib64/vtk-8.2/libvtkCommonMath-8.2.so.1 /usr/lib64/vtk-8.2/libvtkCommonCore-8.2.so.1 /usr/lib64/libSM.so /usr/lib64/libICE.so /usr/lib64/libX11.so /usr/lib64/libXext.so /usr/lib64/libXt.so
make[1]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 3%] Built target SMDS
make[1]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
/usr/bin/make -f src/Mod/Image/CMakeFiles/ImageScripts.dir/build.make src/Mod/Image/CMakeFiles/ImageScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Image /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Image /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Image/CMakeFiles/ImageScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target ImageScripts
/usr/bin/make -f src/Mod/Image/CMakeFiles/ImageScripts.dir/build.make src/Mod/Image/CMakeFiles/ImageScripts.dir/build
[ 3%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Image/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Image/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Image && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Image/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Image/Init.py
[ 3%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Image/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Image/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Image && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Image/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Image/InitGui.py
[ 3%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Image/ImageTools/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Image/ImageTools/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Image && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Image/ImageTools/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Image/ImageTools/__init__.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Image/ImageTools/_CommandImageScaling.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Image/ImageTools/_CommandImageScaling.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Image && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Image/ImageTools/_CommandImageScaling.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Image/ImageTools/_CommandImageScaling.py
[ 4%] Built target ImageScripts
/usr/bin/make -f src/Mod/Mesh/CMakeFiles/MeshScripts.dir/build.make src/Mod/Mesh/CMakeFiles/MeshScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Mesh /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Mesh /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Mesh/CMakeFiles/MeshScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target MeshScripts
/usr/bin/make -f src/Mod/Mesh/CMakeFiles/MeshScripts.dir/build.make src/Mod/Mesh/CMakeFiles/MeshScripts.dir/build
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Mesh/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Mesh/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Mesh && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Mesh/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Mesh/Init.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Mesh/BuildRegularGeoms.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Mesh/BuildRegularGeoms.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Mesh && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Mesh/BuildRegularGeoms.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Mesh/BuildRegularGeoms.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Mesh/App/MeshTestsApp.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Mesh/MeshTestsApp.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Mesh && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Mesh/App/MeshTestsApp.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Mesh/MeshTestsApp.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Mesh/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Mesh/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Mesh && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Mesh/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Mesh/InitGui.py
[ 4%] Built target MeshScripts
/usr/bin/make -f src/Mod/Part/CMakeFiles/PartScripts.dir/build.make src/Mod/Part/CMakeFiles/PartScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part/CMakeFiles/PartScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target PartScripts
/usr/bin/make -f src/Mod/Part/CMakeFiles/PartScripts.dir/build.make src/Mod/Part/CMakeFiles/PartScripts.dir/build
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/Init.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/JoinFeatures.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/JoinFeatures.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/JoinFeatures.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/JoinFeatures.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/MakeBottle.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/MakeBottle.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/MakeBottle.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/MakeBottle.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/TestPartApp.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/TestPartApp.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/TestPartApp.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/TestPartApp.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/InitGui.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/TestPartGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/TestPartGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/TestPartGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/TestPartGui.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/AttachmentEditor/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/AttachmentEditor/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/AttachmentEditor/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/AttachmentEditor/__init__.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/AttachmentEditor/Commands.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/AttachmentEditor/Commands.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/AttachmentEditor/Commands.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/AttachmentEditor/Commands.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/AttachmentEditor/FrozenClass.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/AttachmentEditor/FrozenClass.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/AttachmentEditor/FrozenClass.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/AttachmentEditor/FrozenClass.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/AttachmentEditor/TaskAttachmentEditor.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/AttachmentEditor/TaskAttachmentEditor.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/AttachmentEditor/TaskAttachmentEditor.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/AttachmentEditor/TaskAttachmentEditor.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/AttachmentEditor/TaskAttachmentEditor.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/AttachmentEditor/TaskAttachmentEditor.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/AttachmentEditor/TaskAttachmentEditor.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/AttachmentEditor/TaskAttachmentEditor.ui
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BasicShapes/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BasicShapes/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BasicShapes/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BasicShapes/__init__.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BasicShapes/Shapes.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BasicShapes/Shapes.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BasicShapes/Shapes.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BasicShapes/Shapes.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/__init__.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/GeneralFuseResult.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/GeneralFuseResult.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/GeneralFuseResult.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/GeneralFuseResult.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/JoinAPI.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/JoinAPI.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/JoinAPI.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/JoinAPI.py
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/ParameterPy.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/ParameterPy.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/ParameterPy.cpp
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/JoinFeatures.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/JoinFeatures.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/JoinFeatures.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/JoinFeatures.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/ShapeMerge.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/ShapeMerge.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/ShapeMerge.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/ShapeMerge.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/SplitAPI.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/SplitAPI.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/SplitAPI.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/SplitAPI.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/SplitFeatures.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/SplitFeatures.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/SplitFeatures.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/SplitFeatures.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/Utils.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/Utils.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/BOPTools/Utils.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/BOPTools/Utils.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/CompoundTools/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/CompoundTools/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/CompoundTools/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/CompoundTools/__init__.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/CompoundTools/_CommandCompoundFilter.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/CompoundTools/_CommandCompoundFilter.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/CompoundTools/_CommandCompoundFilter.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/CompoundTools/_CommandCompoundFilter.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/CompoundTools/_CommandExplodeCompound.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/CompoundTools/_CommandExplodeCompound.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/CompoundTools/_CommandExplodeCompound.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/CompoundTools/_CommandExplodeCompound.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/CompoundTools/CompoundFilter.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/CompoundTools/CompoundFilter.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/CompoundTools/CompoundFilter.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/CompoundTools/CompoundFilter.py
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/CompoundTools/Explode.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/CompoundTools/Explode.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Part && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Part/CompoundTools/Explode.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Part/CompoundTools/Explode.py
[ 4%] Built target PartScripts
/usr/bin/make -f src/Mod/Material/CMakeFiles/MaterialLib.dir/build.make src/Mod/Material/CMakeFiles/MaterialLib.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material/CMakeFiles/MaterialLib.dir/DependInfo.cmake --color=
Scanning dependencies of target MaterialLib
/usr/bin/make -f src/Mod/Material/CMakeFiles/MaterialLib.dir/build.make src/Mod/Material/CMakeFiles/MaterialLib.dir/build
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/None.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/None.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/None.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/None.FCMat
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/ABS-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/ABS-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/ABS-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/ABS-Generic.FCMat
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Acrylic-Glass-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Acrylic-Glass-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Acrylic-Glass-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Acrylic-Glass-Generic.FCMat
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/CalculiX-Steel.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/CalculiX-Steel.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/CalculiX-Steel.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/CalculiX-Steel.FCMat
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Concrete-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Concrete-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Concrete-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Concrete-Generic.FCMat
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Glass-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Glass-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Glass-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Glass-Generic.FCMat
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PA6-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PA6-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PA6-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PA6-Generic.FCMat
[ 4%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PET-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PET-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PET-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PET-Generic.FCMat
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PLA-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PLA-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PLA-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PLA-Generic.FCMat
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PP-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PP-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PP-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PP-Generic.FCMat
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PTFE-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PTFE-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PTFE-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PTFE-Generic.FCMat
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PVC-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PVC-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/PVC-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/PVC-Generic.FCMat
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Steel-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Steel-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Steel-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Steel-Generic.FCMat
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/TEMPLATE.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/TEMPLATE.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/TEMPLATE.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/TEMPLATE.FCMat
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Wood-Generic.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Wood-Generic.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Wood-Generic.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Wood-Generic.FCMat
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Readme.txt to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Readme.txt
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/StandardMaterial/Readme.txt /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/StandardMaterial/Readme.txt
[ 5%] Built target MaterialLib
/usr/bin/make -f src/Mod/Material/CMakeFiles/Material.dir/build.make src/Mod/Material/CMakeFiles/Material.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material/CMakeFiles/Material.dir/DependInfo.cmake --color=
/usr/bin/make -f src/Mod/Material/CMakeFiles/Material.dir/build.make src/Mod/Material/CMakeFiles/Material.dir/build
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/Init.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/InitGui.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/Material.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/Material.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/Material.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/Material.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/importFCMat.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/importFCMat.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/importFCMat.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/importFCMat.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/MaterialEditor.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/MaterialEditor.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/MaterialEditor.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/MaterialEditor.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/materials-editor.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/materials-editor.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/materials-editor.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/materials-editor.ui
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/MatPropDict.xml to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/MatPropDict.xml
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/MatPropDict.xml /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/MatPropDict.xml
[ 5%] Generating Material_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/pyside2-rcc /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/Resources/Material.qrc -o /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material/Material_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && sed -i /^#\ /d /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material/Material_rc.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material/Material_rc.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/Material_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material/Material_rc.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Material/Material_rc.py
/usr/bin/make -f src/Mod/Material/CMakeFiles/FluidMaterialLib.dir/build.make src/Mod/Material/CMakeFiles/FluidMaterialLib.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material/CMakeFiles/FluidMaterialLib.dir/DependInfo.cmake --color=
Scanning dependencies of target FluidMaterialLib
/usr/bin/make -f src/Mod/Material/CMakeFiles/FluidMaterialLib.dir/build.make src/Mod/Material/CMakeFiles/FluidMaterialLib.dir/build
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/FluidMaterial/None.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/FluidMaterial/None.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/FluidMaterial/None.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/FluidMaterial/None.FCMat
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/FluidMaterial/Air.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/FluidMaterial/Air.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/FluidMaterial/Air.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/FluidMaterial/Air.FCMat
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/FluidMaterial/Water.FCMat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/FluidMaterial/Water.FCMat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/FluidMaterial/Water.FCMat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/FluidMaterial/Water.FCMat
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/FluidMaterial/Readme.txt to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/FluidMaterial/Readme.txt
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Material && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Material/FluidMaterial/Readme.txt /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Material/FluidMaterial/Readme.txt
[ 5%] Built target FluidMaterialLib
/usr/bin/make -f src/Mod/PartDesign/CMakeFiles/WizardShaft.dir/build.make src/Mod/PartDesign/CMakeFiles/WizardShaft.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign/CMakeFiles/WizardShaft.dir/DependInfo.cmake --color=
Scanning dependencies of target WizardShaft
/usr/bin/make -f src/Mod/PartDesign/CMakeFiles/WizardShaft.dir/build.make src/Mod/PartDesign/CMakeFiles/WizardShaft.dir/build
make[2]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/__init__.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/WizardShaft.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/WizardShaft.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/WizardShaft.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/WizardShaft.svg
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/WizardShaft.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/WizardShaft.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/WizardShaft.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/WizardShaft.py
make[2]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/WizardShaftTable.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/WizardShaftTable.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/WizardShaftTable.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/WizardShaftTable.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/Shaft.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/Shaft.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/Shaft.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/Shaft.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/ShaftFeature.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/ShaftFeature.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/ShaftFeature.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/ShaftFeature.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/ShaftDiagram.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/ShaftDiagram.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/ShaftDiagram.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/ShaftDiagram.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/SegmentFunction.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/SegmentFunction.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/WizardShaft/SegmentFunction.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/WizardShaft/SegmentFunction.py
[ 5%] Built target WizardShaft
/usr/bin/make -f src/Mod/PartDesign/CMakeFiles/PartDesignScripts.dir/build.make src/Mod/PartDesign/CMakeFiles/PartDesignScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign/CMakeFiles/PartDesignScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target PartDesignScripts
/usr/bin/make -f src/Mod/PartDesign/CMakeFiles/PartDesignScripts.dir/build.make src/Mod/PartDesign/CMakeFiles/PartDesignScripts.dir/build
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/__init__.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Init.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/TestPartDesignApp.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/TestPartDesignApp.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/TestPartDesignApp.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/TestPartDesignApp.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/InitGui.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/TestPartDesignGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/TestPartDesignGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/TestPartDesignGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/TestPartDesignGui.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/InvoluteGearFeature.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/InvoluteGearFeature.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/InvoluteGearFeature.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/InvoluteGearFeature.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/InvoluteGearFeature.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/InvoluteGearFeature.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/InvoluteGearFeature.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/InvoluteGearFeature.ui
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/__init__.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/DistanceBolt.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/DistanceBolt.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/DistanceBolt.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/DistanceBolt.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/Epitrochoid.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/Epitrochoid.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/Epitrochoid.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/Epitrochoid.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/FilletArc.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/FilletArc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/FilletArc.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/FilletArc.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/Gear.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/Gear.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/Gear.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/Gear.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/Parallelepiped.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/Parallelepiped.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/Parallelepiped.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/Parallelepiped.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/RadialCopy.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/RadialCopy.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/RadialCopy.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/RadialCopy.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/Spring.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/Spring.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/Scripts/Spring.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/Scripts/Spring.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/__init__.py
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestDatum.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestDatum.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestDatum.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestDatum.py
[ 4%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/PyExport.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/PyExport.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/PyExport.cpp
[ 5%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestShapeBinder.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestShapeBinder.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestShapeBinder.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestShapeBinder.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestPad.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestPad.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestPad.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestPad.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestPocket.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestPocket.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestPocket.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestPocket.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestHole.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestHole.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestHole.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestHole.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestRevolve.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestRevolve.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestRevolve.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestRevolve.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestLoft.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestLoft.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestLoft.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestLoft.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestPipe.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestPipe.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestPipe.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestPipe.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestPrimitive.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestPrimitive.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestPrimitive.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestPrimitive.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestMirrored.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestMirrored.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestMirrored.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestMirrored.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestLinearPattern.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestLinearPattern.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestLinearPattern.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestLinearPattern.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestPolarPattern.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestPolarPattern.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestPolarPattern.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestPolarPattern.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestMultiTransform.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestMultiTransform.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestMultiTransform.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestMultiTransform.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestBoolean.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestBoolean.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestBoolean.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestBoolean.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestFillet.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestFillet.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestFillet.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestFillet.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestChamfer.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestChamfer.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestChamfer.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestChamfer.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestDraft.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestDraft.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestDraft.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestDraft.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestThickness.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestThickness.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/PartDesignTests/TestThickness.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/PartDesignTests/TestThickness.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/fcgear/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/fcgear/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/fcgear/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/fcgear/__init__.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/fcgear/fcgear.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/fcgear/fcgear.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/fcgear/fcgear.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/fcgear/fcgear.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/fcgear/fcgeardialog.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/fcgear/fcgeardialog.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/fcgear/fcgeardialog.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/fcgear/fcgeardialog.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/fcgear/involute.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/fcgear/involute.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/fcgear/involute.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/fcgear/involute.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/fcgear/svggear.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/fcgear/svggear.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/PartDesign && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/PartDesign/fcgear/svggear.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/PartDesign/fcgear/svggear.py
make[1]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 6%] Built target PartDesignScripts
make[1]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
/usr/bin/make -f src/Mod/Raytracing/CMakeFiles/RaytracingScripts.dir/build.make src/Mod/Raytracing/CMakeFiles/RaytracingScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Raytracing /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Raytracing/CMakeFiles/RaytracingScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target RaytracingScripts
/usr/bin/make -f src/Mod/Raytracing/CMakeFiles/RaytracingScripts.dir/build.make src/Mod/Raytracing/CMakeFiles/RaytracingScripts.dir/build
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Raytracing/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Raytracing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Raytracing/Init.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/RaytracingExample.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Raytracing/RaytracingExample.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Raytracing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/RaytracingExample.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Raytracing/RaytracingExample.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Raytracing/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Raytracing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Raytracing/InitGui.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Templates/LuxClassic.lxs to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Raytracing/Templates/LuxClassic.lxs
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Raytracing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Templates/LuxClassic.lxs /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Raytracing/Templates/LuxClassic.lxs
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Templates/LuxOutdoor.lxs to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Raytracing/Templates/LuxOutdoor.lxs
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Raytracing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Templates/LuxOutdoor.lxs /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Raytracing/Templates/LuxOutdoor.lxs
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Templates/ProjectStd.pov to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Raytracing/Templates/ProjectStd.pov
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Raytracing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Templates/ProjectStd.pov /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Raytracing/Templates/ProjectStd.pov
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Templates/RadiosityNormal.pov to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Raytracing/Templates/RadiosityNormal.pov
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Raytracing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Templates/RadiosityNormal.pov /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Raytracing/Templates/RadiosityNormal.pov
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Templates/RadiosityOutdoorHQ.pov to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Raytracing/Templates/RadiosityOutdoorHQ.pov
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Raytracing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Raytracing/Templates/RadiosityOutdoorHQ.pov /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Raytracing/Templates/RadiosityOutdoorHQ.pov
[ 6%] Built target RaytracingScripts
/usr/bin/make -f src/Mod/Drawing/CMakeFiles/DrawingScripts.dir/build.make src/Mod/Drawing/CMakeFiles/DrawingScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing/CMakeFiles/DrawingScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target DrawingScripts
/usr/bin/make -f src/Mod/Drawing/CMakeFiles/DrawingScripts.dir/build.make src/Mod/Drawing/CMakeFiles/DrawingScripts.dir/build
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Drawing/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Drawing/Init.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/DrawingExample.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Drawing/DrawingExample.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/DrawingExample.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Drawing/DrawingExample.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/DrawingTests.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Drawing/DrawingTests.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/DrawingTests.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Drawing/DrawingTests.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/DrawingPatterns.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Drawing/DrawingPatterns.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/DrawingPatterns.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Drawing/DrawingPatterns.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Drawing/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Drawing/InitGui.py
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A0_Landscape_ISO7200.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A0_Landscape_ISO7200.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A0_Landscape_ISO7200.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A0_Landscape_ISO7200.svg
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A0_Landscape_plain.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A0_Landscape_plain.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A0_Landscape_plain.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A0_Landscape_plain.svg
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A0_Portrait_plain.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A0_Portrait_plain.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A0_Portrait_plain.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A0_Portrait_plain.svg
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A1_Landscape_ISO7200.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A1_Landscape_ISO7200.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A1_Landscape_ISO7200.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A1_Landscape_ISO7200.svg
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A1_Landscape_plain.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A1_Landscape_plain.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A1_Landscape_plain.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A1_Landscape_plain.svg
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A1_Portrait_plain.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A1_Portrait_plain.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A1_Portrait_plain.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A1_Portrait_plain.svg
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A2_Landscape_ISO7200.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A2_Landscape_ISO7200.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A2_Landscape_ISO7200.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A2_Landscape_ISO7200.svg
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A2_Landscape_plain.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A2_Landscape_plain.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A2_Landscape_plain.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A2_Landscape_plain.svg
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A2_Portrait_plain.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A2_Portrait_plain.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A2_Portrait_plain.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A2_Portrait_plain.svg
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A3_Landscape.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A3_Landscape.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape.svg
[ 6%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A3_Landscape_ISO7200.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape_ISO7200.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A3_Landscape_ISO7200.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape_ISO7200.svg
[ 7%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A3_Landscape_plain.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape_plain.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A3_Landscape_plain.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape_plain.svg
[ 7%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A3_Portrait_plain.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A3_Portrait_plain.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A3_Portrait_plain.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A3_Portrait_plain.svg
[ 7%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A4_Landscape.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A4_Landscape.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape.svg
[ 7%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A4_Landscape_ISO7200.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape_ISO7200.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A4_Landscape_ISO7200.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape_ISO7200.svg
[ 7%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A4_Landscape_plain.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape_plain.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A4_Landscape_plain.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape_plain.svg
[ 7%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A4_Portrait_ISO7200.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A4_Portrait_ISO7200.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A4_Portrait_ISO7200.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A4_Portrait_ISO7200.svg
[ 7%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A4_Portrait_plain.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A4_Portrait_plain.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Drawing && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Drawing/Templates/A4_Portrait_plain.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Drawing/Templates/A4_Portrait_plain.svg
[ 7%] Built target DrawingScripts
/usr/bin/make -f src/Mod/Sketcher/CMakeFiles/SketcherScripts.dir/build.make src/Mod/Sketcher/CMakeFiles/SketcherScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher/CMakeFiles/SketcherScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target SketcherScripts
/usr/bin/make -f src/Mod/Sketcher/CMakeFiles/SketcherScripts.dir/build.make src/Mod/Sketcher/CMakeFiles/SketcherScripts.dir/build
[ 7%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/Init.py
[ 7%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/SketcherExample.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/SketcherExample.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/SketcherExample.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/SketcherExample.py
[ 7%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/TestSketcherApp.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/TestSketcherApp.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/TestSketcherApp.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/TestSketcherApp.py
[ 7%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/Profiles.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/Profiles.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/Profiles.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/Profiles.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/InitGui.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/TestSketcherGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/TestSketcherGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/TestSketcherGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/TestSketcherGui.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/ProfileLib/Hexagon.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/ProfileLib/Hexagon.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/ProfileLib/Hexagon.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/ProfileLib/Hexagon.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/ProfileLib/RegularPolygon.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/ProfileLib/RegularPolygon.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/ProfileLib/RegularPolygon.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/ProfileLib/RegularPolygon.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/ProfileLib/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/ProfileLib/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Sketcher && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Sketcher/ProfileLib/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Sketcher/ProfileLib/__init__.py
[ 8%] Built target SketcherScripts
/usr/bin/make -f src/Mod/Robot/CMakeFiles/RobotScripts.dir/build.make src/Mod/Robot/CMakeFiles/RobotScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot/CMakeFiles/RobotScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target RobotScripts
/usr/bin/make -f src/Mod/Robot/CMakeFiles/RobotScripts.dir/build.make src/Mod/Robot/CMakeFiles/RobotScripts.dir/build
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/Init.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/KukaExporter.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/KukaExporter.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/KukaExporter.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/KukaExporter.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/RobotExample.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/RobotExample.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/RobotExample.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/RobotExample.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/RobotExampleTrajectoryOutOfShapes.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/RobotExampleTrajectoryOutOfShapes.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/RobotExampleTrajectoryOutOfShapes.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/RobotExampleTrajectoryOutOfShapes.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/InitGui.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/MovieTool.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/MovieTool.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/MovieTool.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Robot/MovieTool.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr500_1.wrl to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr500_1.wrl
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr500_1.wrl /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr500_1.wrl
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr500_1.csv to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr500_1.csv
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr500_1.csv /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr500_1.csv
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_500_2.pdf to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_500_2.pdf
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_500_2.pdf /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_500_2.pdf
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr210.WRL to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr210.WRL
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr210.WRL /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr210.WRL
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_210_2.csv to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_210_2.csv
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_210_2.csv /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_210_2.csv
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_210_2.pdf to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_210_2.pdf
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_210_2.pdf /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_210_2.pdf
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr16.wrl to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr16.wrl
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr16.wrl /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr16.wrl
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_16.csv to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_16.csv
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_16.csv /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_16.csv
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_16.pdf to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_16.pdf
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_16.pdf /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_16.pdf
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr125_3.wrl to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr125_3.wrl
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr125_3.wrl /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr125_3.wrl
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_125.csv to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_125.csv
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr_125.csv /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_125.csv
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr125_2.pdf to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr125_2.pdf
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Robot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Robot/Lib/Kuka/kr125_2.pdf /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Robot/Lib/Kuka/kr125_2.pdf
[ 8%] Built target RobotScripts
/usr/bin/make -f src/Mod/ReverseEngineering/CMakeFiles/ReverseEngineeringScripts.dir/build.make src/Mod/ReverseEngineering/CMakeFiles/ReverseEngineeringScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/ReverseEngineering /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/ReverseEngineering /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/ReverseEngineering/CMakeFiles/ReverseEngineeringScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target ReverseEngineeringScripts
/usr/bin/make -f src/Mod/ReverseEngineering/CMakeFiles/ReverseEngineeringScripts.dir/build.make src/Mod/ReverseEngineering/CMakeFiles/ReverseEngineeringScripts.dir/build
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/ReverseEngineering/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/ReverseEngineering/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/ReverseEngineering && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/ReverseEngineering/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/ReverseEngineering/Init.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/ReverseEngineering/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/ReverseEngineering/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/ReverseEngineering && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/ReverseEngineering/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/ReverseEngineering/InitGui.py
[ 8%] Built target ReverseEngineeringScripts
/usr/bin/make -f src/Mod/Draft/CMakeFiles/Draft.dir/build.make src/Mod/Draft/CMakeFiles/Draft.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft/CMakeFiles/Draft.dir/DependInfo.cmake --color=
Scanning dependencies of target Draft
/usr/bin/make -f src/Mod/Draft/CMakeFiles/Draft.dir/build.make src/Mod/Draft/CMakeFiles/Draft.dir/build
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/Init.py
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/PlacementPyImp.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/PlacementPyImp.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/PlacementPyImp.cpp
make[2]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/InitGui.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/Draft.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/Draft.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/Draft.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/Draft.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftTools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftTools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftTools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftTools.py
make[2]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftGui.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftSnap.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftSnap.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftSnap.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftSnap.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftTrackers.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftTrackers.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftTrackers.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftTrackers.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftVecUtils.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftVecUtils.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftVecUtils.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftVecUtils.py
[ 8%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftGeomUtils.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftGeomUtils.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/DraftGeomUtils.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/DraftGeomUtils.py
[ 3%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/PersistencePyImp.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/PersistencePyImp.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/PersistencePyImp.cpp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/WorkingPlane.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/WorkingPlane.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/WorkingPlane.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/WorkingPlane.py
[ 5%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/PyObjectBase.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/PyObjectBase.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/PyObjectBase.cpp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/getSVG.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/getSVG.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/getSVG.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/getSVG.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/importDXF.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/importDXF.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/importDXF.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/importDXF.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/importOCA.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/importOCA.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/importOCA.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/importOCA.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/importSVG.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/importSVG.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/importSVG.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/importSVG.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/importDWG.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/importDWG.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/importDWG.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/importDWG.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/importAirfoilDAT.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/importAirfoilDAT.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/importAirfoilDAT.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/importAirfoilDAT.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/TestDraft.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/TestDraft.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/TestDraft.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/TestDraft.py
[ 9%] Generating Draft_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/pyside2-rcc /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/Resources/Draft.qrc -o /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft/Draft_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && sed -i /^#\ /d /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft/Draft_rc.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/Resources/icons/DraftWorkbench.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Draft/Resources/icons/DraftWorkbench.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Draft/Resources/icons/DraftWorkbench.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Draft/Resources/icons/DraftWorkbench.svg
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft/Draft_rc.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/Draft_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Draft/Draft_rc.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Draft/Draft_rc.py
[ 9%] Built target Draft
/usr/bin/make -f src/Mod/Web/CMakeFiles/WebScripts.dir/build.make src/Mod/Web/CMakeFiles/WebScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Web /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Web /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Web/CMakeFiles/WebScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target WebScripts
/usr/bin/make -f src/Mod/Web/CMakeFiles/WebScripts.dir/build.make src/Mod/Web/CMakeFiles/WebScripts.dir/build
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Web/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Web/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Web && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Web/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Web/Init.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Web/TestWebGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Web/TestWebGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Web && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Web/TestWebGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Web/TestWebGui.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Web/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Web/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Web && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Web/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Web/InitGui.py
[ 9%] Built target WebScripts
/usr/bin/make -f src/Mod/Surface/CMakeFiles/SurfaceScripts.dir/build.make src/Mod/Surface/CMakeFiles/SurfaceScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Surface /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Surface /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Surface/CMakeFiles/SurfaceScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target SurfaceScripts
/usr/bin/make -f src/Mod/Surface/CMakeFiles/SurfaceScripts.dir/build.make src/Mod/Surface/CMakeFiles/SurfaceScripts.dir/build
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Surface/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Surface/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Surface && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Surface/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Surface/Init.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Surface/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Surface/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Surface && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Surface/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Surface/InitGui.py
[ 9%] Built target SurfaceScripts
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Rotation.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Rotation.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Rotation.cpp
[ 8%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Reader.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Reader.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Reader.cpp
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Sequencer.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Sequencer.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Sequencer.cpp
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Swap.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Swap.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Swap.cpp
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Stream.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Stream.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Stream.cpp
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/swigpyrun.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/swigpyrun.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/swigpyrun.cpp
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/TimeInfo.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/TimeInfo.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/TimeInfo.cpp
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Tools2D.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Tools2D.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Tools2D.cpp
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/RotationPyImp.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/RotationPyImp.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/RotationPyImp.cpp
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Type.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Type.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Type.cpp
/usr/bin/make -f src/Mod/Start/CMakeFiles/StartScripts.dir/build.make src/Mod/Start/CMakeFiles/StartScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/CMakeFiles/StartScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target StartScripts
/usr/bin/make -f src/Mod/Start/CMakeFiles/StartScripts.dir/build.make src/Mod/Start/CMakeFiles/StartScripts.dir/build
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Start/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Start/Init.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Start/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Start/InitGui.py
make[1]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 9%] Built target StartScripts
make[1]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
/usr/bin/make -f src/Mod/Start/StartPage/CMakeFiles/StartPage.dir/build.make src/Mod/Start/StartPage/CMakeFiles/StartPage.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage/CMakeFiles/StartPage.dir/DependInfo.cmake --color=
Scanning dependencies of target StartPage
/usr/bin/make -f src/Mod/Start/StartPage/CMakeFiles/StartPage.dir/build.make src/Mod/Start/StartPage/CMakeFiles/StartPage.dir/build
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/StartPage.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Start/StartPage/StartPage.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/StartPage.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Start/StartPage/StartPage.py
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Uuid.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Uuid.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Uuid.cpp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/TranslationTexts.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Start/StartPage/TranslationTexts.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/TranslationTexts.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Start/StartPage/TranslationTexts.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Start/StartPage/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Start/StartPage/__init__.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/LoadMRU.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/LoadMRU.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/LoadMRU.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/LoadMRU.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/LoadExample.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/LoadExample.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/LoadExample.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/LoadExample.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/LoadNew.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/LoadNew.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/LoadNew.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/LoadNew.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/LoadCustom.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/LoadCustom.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/LoadCustom.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/LoadCustom.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/StartPage.css to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/StartPage.css
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/StartPage.css /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/StartPage.css
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/StartPage.js to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/StartPage.js
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/StartPage.js /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/StartPage.js
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/StartPage.html to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/StartPage.html
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/StartPage.html /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/StartPage.html
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/EnableDownload.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/EnableDownload.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/EnableDownload.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/EnableDownload.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/userhub.png to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/userhub.png
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/userhub.png /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/userhub.png
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/poweruserhub.png to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/poweruserhub.png
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/poweruserhub.png /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/poweruserhub.png
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/developerhub.png to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/developerhub.png
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/developerhub.png /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/developerhub.png
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/manual.png to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/manual.png
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/manual.png /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/manual.png
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/freecad.png to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/freecad.png
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/freecad.png /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/freecad.png
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/installed.png to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/installed.png
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/installed.png /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/installed.png
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/new_file_thumbnail.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/new_file_thumbnail.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Start/StartPage && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Start/StartPage/images/new_file_thumbnail.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Start/StartPage/images/new_file_thumbnail.svg
[ 9%] Built target StartPage
/usr/bin/make -f src/Mod/Idf/CMakeFiles/Idf.dir/build.make src/Mod/Idf/CMakeFiles/Idf.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf/CMakeFiles/Idf.dir/DependInfo.cmake --color=
Scanning dependencies of target Idf
/usr/bin/make -f src/Mod/Idf/CMakeFiles/Idf.dir/build.make src/Mod/Idf/CMakeFiles/Idf.dir/build
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Init.py
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Translate.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Translate.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Translate.cpp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idf.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idf.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idf.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idf.py
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/License.txt to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/License.txt
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/License.txt /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/License.txt
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/0603_SMD.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/0603_SMD.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/0603_SMD.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/0603_SMD.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/0805_SMD.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/0805_SMD.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/0805_SMD.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/0805_SMD.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/1206_SMD.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/1206_SMD.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/1206_SMD.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/1206_SMD.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/1210_SMD.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/1210_SMD.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/1210_SMD.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/1210_SMD.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/1812_SMD.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/1812_SMD.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/1812_SMD.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/1812_SMD.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/2225_SMD.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/2225_SMD.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/2225_SMD.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/2225_SMD.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/2512_SMD.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/2512_SMD.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/2512_SMD.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/2512_SMD.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/CAP_50SGV_8_10.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/CAP_50SGV_8_10.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/CAP_50SGV_8_10.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/CAP_50SGV_8_10.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/EPL22_6_16.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/EPL22_6_16.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/EPL22_6_16.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/EPL22_6_16.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/footprints_models.csv to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/footprints_models.csv
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/footprints_models.csv /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/footprints_models.csv
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/I22_2_5_16.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/I22_2_5_16.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/I22_2_5_16.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/I22_2_5_16.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/I22_2_5_16withEPL22_6_16.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/I22_2_5_16withEPL22_6_16.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/I22_2_5_16withEPL22_6_16.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/I22_2_5_16withEPL22_6_16.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/MSOP_10.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/MSOP_10.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/MSOP_10.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/MSOP_10.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/RLF_12545.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/RLF_12545.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/RLF_12545.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/RLF_12545.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/RLF_7030.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/RLF_7030.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/RLF_7030.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/RLF_7030.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SMB_DO_214AA.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SMB_DO_214AA.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SMB_DO_214AA.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SMB_DO_214AA.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SMC_DO_214AB.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SMC_DO_214AB.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SMC_DO_214AB.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SMC_DO_214AB.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOD_323.igs to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOD_323.igs
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOD_323.igs /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOD_323.igs
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOD_323.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOD_323.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOD_323.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOD_323.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOD_523.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOD_523.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOD_523.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOD_523.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT23.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT23.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT23.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT23.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT404.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT404.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT404.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT404.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT428_DPAK.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT428_DPAK.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT428_DPAK.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT428_DPAK.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT_323_3.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT_323_3.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT_323_3.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT_323_3.stp
[ 9%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT_96.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT_96.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT_96.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT_96.stp
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/TCMT1107_4.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/TCMT1107_4.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/TCMT1107_4.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/TCMT1107_4.stp
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/TSM_103_01_L_DV_A.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/TSM_103_01_L_DV_A.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/TSM_103_01_L_DV_A.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/TSM_103_01_L_DV_A.stp
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/TSM_104_01_L_DV_A.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/TSM_104_01_L_DV_A.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/TSM_104_01_L_DV_A.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/TSM_104_01_L_DV_A.stp
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/TSS0P_8.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/TSS0P_8.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/TSS0P_8.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/TSS0P_8.stp
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/VC0603_SMD.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/VC0603_SMD.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/VC0603_SMD.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/VC0603_SMD.stp
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/RLF_12545.igs to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/RLF_12545.igs
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/RLF_12545.igs /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/RLF_12545.igs
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT23.igs to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT23.igs
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT23.igs /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT23.igs
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT404.igs to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT404.igs
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Idf && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Idf/Idflibs/SOT404.igs /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Idf/Idflibs/SOT404.igs
[ 10%] Built target Idf
/usr/bin/make -f src/Mod/Import/CMakeFiles/ImportScripts.dir/build.make src/Mod/Import/CMakeFiles/ImportScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/CMakeFiles/ImportScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target ImportScripts
/usr/bin/make -f src/Mod/Import/CMakeFiles/ImportScripts.dir/build.make src/Mod/Import/CMakeFiles/ImportScripts.dir/build
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/Init.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/gzip_utf8.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/gzip_utf8.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/gzip_utf8.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/gzip_utf8.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/stepZ.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/stepZ.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/stepZ.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/stepZ.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/InitGui.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/blocks10.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/blocks10.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/blocks10.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/blocks10.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/blocks112.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/blocks112.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/blocks112.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/blocks112.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/blocks114.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/blocks114.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/blocks114.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/blocks114.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/classes14.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/classes14.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/classes14.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/classes14.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/entities0.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/entities0.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/entities0.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/entities0.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/entities12.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/entities12.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/entities12.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/entities12.rub
make[2]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/entities14.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/entities14.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/entities14.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/entities14.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/header0.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/header0.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/header0.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/header0.rub
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Tools.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Tools.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Tools.cpp
make[2]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/header12.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/header12.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/header12.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/header12.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/header14.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/header14.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/header14.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/header14.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/objects14.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/objects14.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/objects14.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/objects14.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables10.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables10.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables10.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables10.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables112.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables112.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables112.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables112.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables114.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables114.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables114.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables114.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables20.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables20.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables20.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables20.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables212.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables212.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables212.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables212.rub
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables214.rub to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables214.rub
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/DxfPlate/tables214.rub /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Import/DxfPlate/tables214.rub
[ 10%] Built target ImportScripts
/usr/bin/make -f src/Mod/Import/App/CMakeFiles/ImportPy.dir/build.make src/Mod/Import/App/CMakeFiles/ImportPy.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App/CMakeFiles/ImportPy.dir/DependInfo.cmake --color=
Scanning dependencies of target ImportPy
/usr/bin/make -f src/Mod/Import/App/CMakeFiles/ImportPy.dir/build.make src/Mod/Import/App/CMakeFiles/ImportPy.dir/build
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/__init__.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/AggregationDataTypes.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/AggregationDataTypes.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/AggregationDataTypes.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/AggregationDataTypes.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/BaseType.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/BaseType.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/BaseType.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/BaseType.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Builtin.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Builtin.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Builtin.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Builtin.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/ConstructedDataTypes.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/ConstructedDataTypes.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/ConstructedDataTypes.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/ConstructedDataTypes.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/essa_par.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/essa_par.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/essa_par.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/essa_par.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Model.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Model.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Model.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Model.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Part21.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Part21.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Part21.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Part21.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Rules.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Rules.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Rules.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Rules.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/SCLBase.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/SCLBase.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/SCLBase.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/SCLBase.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/SimpleDataTypes.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/SimpleDataTypes.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/SimpleDataTypes.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/SimpleDataTypes.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/TypeChecker.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/TypeChecker.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/TypeChecker.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/TypeChecker.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Utils.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Utils.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Utils.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Utils.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/SimpleReader.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/SimpleReader.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/SimpleReader.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/SimpleReader.py
[ 10%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Aufspannung.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Aufspannung.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Aufspannung.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Aufspannung.stp
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/gasket1.p21 to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/gasket1.p21
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/gasket1.p21 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/gasket1.p21
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Product1.stp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Product1.stp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/SCL/Product1.stp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/SCL/Product1.stp
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/automotive_design.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/automotive_design.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/automotive_design.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/automotive_design.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/ifc2x3.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/ifc2x3.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/ifc2x3.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/ifc2x3.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/ifc4.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/ifc4.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/ifc4.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/ifc4.py
[ 10%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/ViewProj.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/ViewProj.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/ViewProj.cpp
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/PlmXmlParser.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/PlmXmlParser.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Import/App && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Import/App/PlmXmlParser.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Import/PlmXmlParser.py
[ 11%] Built target ImportPy
/usr/bin/make -f src/Mod/Arch/CMakeFiles/Arch.dir/build.make src/Mod/Arch/CMakeFiles/Arch.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch/CMakeFiles/Arch.dir/DependInfo.cmake --color=
Scanning dependencies of target Arch
/usr/bin/make -f src/Mod/Arch/CMakeFiles/Arch.dir/build.make src/Mod/Arch/CMakeFiles/Arch.dir/build
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Init.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/InitGui.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchComponent.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchComponent.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchComponent.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchComponent.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchWall.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchWall.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchWall.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchWall.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importIFC.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importIFC.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importIFC.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importIFC.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importIFClegacy.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importIFClegacy.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importIFClegacy.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importIFClegacy.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Arch.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Arch.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Arch.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Arch.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchBuilding.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchBuilding.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchBuilding.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchBuilding.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchFloor.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchFloor.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchFloor.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchFloor.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchSite.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchSite.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchSite.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchSite.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchStructure.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchStructure.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchStructure.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchStructure.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchCommands.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchCommands.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchCommands.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchCommands.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchSectionPlane.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchSectionPlane.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchSectionPlane.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchSectionPlane.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importDAE.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importDAE.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importDAE.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importDAE.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importOBJ.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importOBJ.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importOBJ.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importOBJ.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchWindow.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchWindow.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchWindow.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchWindow.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchAxis.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchAxis.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchAxis.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchAxis.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchVRM.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchVRM.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchVRM.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchVRM.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchRoof.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchRoof.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchRoof.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchRoof.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchStairs.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchStairs.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchStairs.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchStairs.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importWebGL.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importWebGL.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importWebGL.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importWebGL.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importJSON.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importJSON.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importJSON.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importJSON.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchSpace.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchSpace.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchSpace.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchSpace.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchRebar.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchRebar.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchRebar.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchRebar.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/TestArch.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/TestArch.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/TestArch.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/TestArch.py
[ 11%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchFrame.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchFrame.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchFrame.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchFrame.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchPanel.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchEquipment.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchEquipment.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchEquipment.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchEquipment.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchCutPlane.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchCutPlane.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchCutPlane.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchCutPlane.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchMaterial.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchMaterial.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchMaterial.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchMaterial.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchSchedule.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchSchedule.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchSchedule.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchSchedule.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchProfile.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchProfile.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchProfile.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchProfile.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/import3DS.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/import3DS.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/import3DS.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/import3DS.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchPrecast.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchPrecast.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchPrecast.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchPrecast.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importSH3D.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importSH3D.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/importSH3D.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/importSH3D.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchPipe.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchPipe.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchPipe.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchPipe.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchNesting.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchNesting.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchNesting.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchNesting.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchBuildingPart.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchBuildingPart.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchBuildingPart.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchBuildingPart.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchReference.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchReference.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/ArchReference.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/ArchReference.py
[ 12%] Generating Arch_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/pyside2-rcc /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Resources/Arch.qrc -o /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch/Arch_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && sed -i /^#\ /d /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch/Arch_rc.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Dice3DS/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Dice3DS/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Dice3DS/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Dice3DS/__init__.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Dice3DS/util.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Dice3DS/util.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Dice3DS/util.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Dice3DS/util.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Dice3DS/dom3ds.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Dice3DS/dom3ds.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Dice3DS/dom3ds.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Dice3DS/dom3ds.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Presets/profiles.csv to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Arch/Presets/profiles.csv
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Presets/profiles.csv /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Arch/Presets/profiles.csv
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Presets/pset_definitions.csv to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Arch/Presets/pset_definitions.csv
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Presets/pset_definitions.csv /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Arch/Presets/pset_definitions.csv
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Resources/icons/ArchWorkbench.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Arch/Resources/icons/ArchWorkbench.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Arch/Resources/icons/ArchWorkbench.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Arch/Resources/icons/ArchWorkbench.svg
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch/Arch_rc.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Arch_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Arch/Arch_rc.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Arch/Arch_rc.py
make[1]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 12%] Built target Arch
make[1]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
/usr/bin/make -f src/Mod/Fem/CMakeFiles/FemGuiScriptsTarget.dir/build.make src/Mod/Fem/CMakeFiles/FemGuiScriptsTarget.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/CMakeFiles/FemGuiScriptsTarget.dir/DependInfo.cmake --color=
Scanning dependencies of target FemGuiScriptsTarget
/usr/bin/make -f src/Mod/Fem/CMakeFiles/FemGuiScriptsTarget.dir/build.make src/Mod/Fem/CMakeFiles/FemGuiScriptsTarget.dir/build
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/__init__.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_TaskPanelFemSolverControl.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_TaskPanelFemSolverControl.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_TaskPanelFemSolverControl.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_TaskPanelFemSolverControl.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemConstraintBodyHeatSource.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemConstraintBodyHeatSource.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemConstraintBodyHeatSource.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemConstraintBodyHeatSource.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemConstraintElectrostaticPotential.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemConstraintElectrostaticPotential.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemConstraintElectrostaticPotential.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemConstraintElectrostaticPotential.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemConstraintFlowVelocity.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemConstraintFlowVelocity.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemConstraintFlowVelocity.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemConstraintFlowVelocity.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemConstraintInitialFlowVelocity.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemConstraintInitialFlowVelocity.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemConstraintInitialFlowVelocity.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemConstraintInitialFlowVelocity.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemConstraintSelfWeight.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemConstraintSelfWeight.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemConstraintSelfWeight.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemConstraintSelfWeight.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemElementFluid1D.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemElementFluid1D.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemElementFluid1D.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemElementFluid1D.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemElementGeometry1D.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemElementGeometry1D.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemElementGeometry1D.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemElementGeometry1D.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemElementGeometry2D.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemElementGeometry2D.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemElementGeometry2D.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemElementGeometry2D.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemElementRotation1D.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemElementRotation1D.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemElementRotation1D.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemElementRotation1D.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMaterial.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMaterial.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMaterial.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMaterial.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMaterialMechanicalNonlinear.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMaterialMechanicalNonlinear.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMaterialMechanicalNonlinear.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMaterialMechanicalNonlinear.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMeshBoundaryLayer.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMeshBoundaryLayer.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMeshBoundaryLayer.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMeshBoundaryLayer.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMeshGmsh.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMeshGmsh.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMeshGmsh.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMeshGmsh.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMeshGroup.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMeshGroup.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMeshGroup.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMeshGroup.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMeshRegion.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMeshRegion.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMeshRegion.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMeshRegion.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMeshResult.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMeshResult.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemMeshResult.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemMeshResult.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemResultMechanical.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemResultMechanical.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemResultMechanical.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemResultMechanical.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemSolverCalculix.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemSolverCalculix.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/_ViewProviderFemSolverCalculix.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/_ViewProviderFemSolverCalculix.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/FemSelectionWidgets.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/FemSelectionWidgets.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/FemSelectionWidgets.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/FemSelectionWidgets.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/ViewProviderFemConstraint.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/ViewProviderFemConstraint.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femguiobjects/ViewProviderFemConstraint.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femguiobjects/ViewProviderFemConstraint.py
[ 12%] Built target FemGuiScriptsTarget
/usr/bin/make -f src/Mod/Fem/CMakeFiles/FemScriptsTarget.dir/build.make src/Mod/Fem/CMakeFiles/FemScriptsTarget.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/CMakeFiles/FemScriptsTarget.dir/DependInfo.cmake --color=
Scanning dependencies of target FemScriptsTarget
/usr/bin/make -f src/Mod/Fem/CMakeFiles/FemScriptsTarget.dir/build.make src/Mod/Fem/CMakeFiles/FemScriptsTarget.dir/build
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Init.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/InitGui.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/ObjectsFem.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/ObjectsFem.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/ObjectsFem.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/ObjectsFem.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/TestFem.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/TestFem.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/TestFem.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/TestFem.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femcommands/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femcommands/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femcommands/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femcommands/__init__.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femcommands/commands.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femcommands/commands.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femcommands/commands.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femcommands/commands.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femcommands/manager.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femcommands/manager.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femcommands/manager.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femcommands/manager.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/__init__.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/convert2TetGen.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/convert2TetGen.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/convert2TetGen.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/convert2TetGen.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importCcxDatResults.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importCcxDatResults.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importCcxDatResults.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importCcxDatResults.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importCcxFrdResults.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importCcxFrdResults.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importCcxFrdResults.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importCcxFrdResults.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importFenicsMesh.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importFenicsMesh.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importFenicsMesh.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importFenicsMesh.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importInpMesh.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importInpMesh.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importInpMesh.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importInpMesh.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importToolsFem.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importToolsFem.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importToolsFem.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importToolsFem.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importVTKResults.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importVTKResults.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importVTKResults.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importVTKResults.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importZ88Mesh.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importZ88Mesh.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importZ88Mesh.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importZ88Mesh.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importZ88O2Results.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importZ88O2Results.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/importZ88O2Results.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/importZ88O2Results.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/readFenicsXDMF.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/readFenicsXDMF.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/readFenicsXDMF.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/readFenicsXDMF.py
make[2]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/readFenicsXML.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/readFenicsXML.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/readFenicsXML.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/readFenicsXML.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/writeFenicsXDMF.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/writeFenicsXDMF.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/writeFenicsXDMF.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/writeFenicsXDMF.py
[ 12%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/writeFenicsXML.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/writeFenicsXML.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/feminout/writeFenicsXML.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/feminout/writeFenicsXML.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femmesh/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femmesh/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femmesh/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femmesh/__init__.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femmesh/femmesh2mesh.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femmesh/femmesh2mesh.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femmesh/femmesh2mesh.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femmesh/femmesh2mesh.py
make[2]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femmesh/gmshtools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femmesh/gmshtools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femmesh/gmshtools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femmesh/gmshtools.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femmesh/meshtools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femmesh/meshtools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femmesh/meshtools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femmesh/meshtools.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femresult/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femresult/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femresult/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femresult/__init__.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femresult/resulttools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femresult/resulttools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femresult/resulttools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femresult/resulttools.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/__init__.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/equationbase.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/equationbase.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/equationbase.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/equationbase.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/report.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/report.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/report.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/report.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/reportdialog.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/reportdialog.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/reportdialog.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/reportdialog.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/run.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/run.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/run.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/run.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/settings.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/settings.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/settings.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/settings.py
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Vector3D.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Vector3D.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Vector3D.cpp
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/signal.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/signal.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/signal.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/signal.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/solverbase.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/solverbase.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/solverbase.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/solverbase.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/task.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/task.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/task.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/task.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/writerbase.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/writerbase.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/writerbase.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/writerbase.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/calculix/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/calculix/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/calculix/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/calculix/__init__.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/calculix/solver.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/calculix/solver.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/calculix/solver.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/calculix/solver.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/calculix/tasks.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/calculix/tasks.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/calculix/tasks.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/calculix/tasks.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/calculix/writer.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/calculix/writer.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/calculix/writer.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/calculix/writer.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/__init__.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/sifio.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/sifio.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/sifio.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/sifio.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/solver.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/solver.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/solver.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/solver.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/tasks.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/tasks.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/tasks.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/tasks.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/writer.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/writer.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/writer.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/writer.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/__init__.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/electrostatic.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/electrostatic.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/electrostatic.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/electrostatic.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/elasticity.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/elasticity.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/elasticity.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/elasticity.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/equation.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/equation.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/equation.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/equation.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/flow.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/flow.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/flow.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/flow.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/fluxsolver.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/fluxsolver.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/fluxsolver.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/fluxsolver.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/heat.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/heat.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/heat.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/heat.py
[ 13%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/linear.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/linear.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/linear.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/linear.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/nonlinear.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/nonlinear.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/elmer/equations/nonlinear.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/elmer/equations/nonlinear.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/fenics/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/fenics/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/fenics/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/fenics/__init__.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/fenics/fenics_tools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/fenics/fenics_tools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/fenics/fenics_tools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/fenics/fenics_tools.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/z88/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/z88/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/z88/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/z88/__init__.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/z88/solver.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/z88/solver.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/z88/solver.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/z88/solver.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/z88/tasks.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/z88/tasks.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/z88/tasks.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/z88/tasks.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/z88/writer.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/z88/writer.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femsolver/z88/writer.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femsolver/z88/writer.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/__init__.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testccxtools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testccxtools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testccxtools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testccxtools.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testcommon.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testcommon.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testcommon.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testcommon.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testmesh.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testmesh.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testmesh.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testmesh.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testobject.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testobject.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testobject.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testobject.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testresult.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testresult.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testresult.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testresult.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testsolverframework.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testsolverframework.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testsolverframework.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testsolverframework.py
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/utilstest.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/utilstest.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/utilstest.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/utilstest.py
[ 9%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/VectorPyImp.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/VectorPyImp.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/VectorPyImp.cpp
[ 14%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/__init__.py
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/__init__.py
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_mesh.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_mesh.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_mesh.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_mesh.py
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_frequency.inp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_frequency.inp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_frequency.inp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_frequency.inp
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_frequency.dat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_frequency.dat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_frequency.dat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_frequency.dat
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_frequency.frd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_frequency.frd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_frequency.frd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_frequency.frd
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_frequency_expected_values to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_frequency_expected_values
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_frequency_expected_values /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_frequency_expected_values
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_frequency.FCStd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_frequency.FCStd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_frequency.FCStd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_frequency.FCStd
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_static.inp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_static.inp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_static.inp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_static.inp
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_static.dat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_static.dat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_static.dat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_static.dat
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_static.frd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_static.frd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_static.frd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_static.frd
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_static_expected_values to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_static_expected_values
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_static_expected_values /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_static_expected_values
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_static.FCStd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_static.FCStd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube_static.FCStd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube_static.FCStd
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube.FCStd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube.FCStd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/cube.FCStd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/cube.FCStd
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/multimat.inp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/multimat.inp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/multimat.inp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/multimat.inp
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/multimat_mesh.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/multimat_mesh.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/multimat_mesh.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/multimat_mesh.py
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_mesh.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_mesh.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_mesh.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_mesh.py
[ 15%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.inp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.inp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.inp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.inp
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.dat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.dat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.dat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.dat
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.frd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.frd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.frd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.frd
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_thermomech_expected_values to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_thermomech_expected_values
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_thermomech_expected_values /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_thermomech_expected_values
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.FCStd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.FCStd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.FCStd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/spine_thermomech.FCStd
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_mesh.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_mesh.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_mesh.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_mesh.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.inp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.inp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.inp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.inp
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.dat to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.dat
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.dat /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.dat
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.frd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.frd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.frd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.frd
[ 13%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/XMLTools.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/XMLTools.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/XMLTools.cpp
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech_expected_values to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech_expected_values
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech_expected_values /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech_expected_values
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech_inout_nodes.txt to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech_inout_nodes.txt
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech_inout_nodes.txt /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech_inout_nodes.txt
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.FCStd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.FCStd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.FCStd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/ccx/Flow1D_thermomech.FCStd
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/elmer/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/elmer/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/elmer/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/elmer/__init__.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/elmer/case.sif to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/elmer/case.sif
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/elmer/case.sif /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/elmer/case.sif
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/elmer/group_mesh.geo to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/elmer/group_mesh.geo
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/elmer/group_mesh.geo /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/elmer/group_mesh.geo
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/elmer/ELMERSOLVER_STARTINFO to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/elmer/ELMERSOLVER_STARTINFO
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/elmer/ELMERSOLVER_STARTINFO /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/elmer/ELMERSOLVER_STARTINFO
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/mesh/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/mesh/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/mesh/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/mesh/__init__.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.inp to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.inp
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.inp /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.inp
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.unv to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.unv
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.unv /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.unv
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.vtk to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.vtk
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.vtk /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.vtk
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.z88 to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.z88
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.z88 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtest/testfiles/mesh/tetra10_mesh.z88
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtools/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtools/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtools/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtools/__init__.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtools/ccxtools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtools/ccxtools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtools/ccxtools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtools/ccxtools.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtools/femutils.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtools/femutils.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femtools/femutils.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femtools/femutils.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/__init__.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemConstraintBodyHeatSource.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemConstraintBodyHeatSource.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemConstraintBodyHeatSource.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemConstraintBodyHeatSource.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemConstraintElectrostaticPotential.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemConstraintElectrostaticPotential.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemConstraintElectrostaticPotential.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemConstraintElectrostaticPotential.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemConstraintFlowVelocity.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemConstraintFlowVelocity.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemConstraintFlowVelocity.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemConstraintFlowVelocity.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemConstraintInitialFlowVelocity.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemConstraintInitialFlowVelocity.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemConstraintInitialFlowVelocity.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemConstraintInitialFlowVelocity.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemConstraintSelfWeight.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemConstraintSelfWeight.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemConstraintSelfWeight.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemConstraintSelfWeight.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemElementFluid1D.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemElementFluid1D.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemElementFluid1D.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemElementFluid1D.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemElementGeometry1D.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemElementGeometry1D.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemElementGeometry1D.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemElementGeometry1D.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemElementGeometry2D.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemElementGeometry2D.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemElementGeometry2D.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemElementGeometry2D.py
[ 16%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemElementRotation1D.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemElementRotation1D.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemElementRotation1D.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemElementRotation1D.py
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMaterial.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMaterial.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMaterial.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMaterial.py
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMaterialMechanicalNonlinear.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMaterialMechanicalNonlinear.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMaterialMechanicalNonlinear.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMaterialMechanicalNonlinear.py
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMeshBoundaryLayer.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMeshBoundaryLayer.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMeshBoundaryLayer.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMeshBoundaryLayer.py
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMeshGmsh.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMeshGmsh.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMeshGmsh.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMeshGmsh.py
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMeshGroup.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMeshGroup.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMeshGroup.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMeshGroup.py
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMeshRegion.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMeshRegion.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMeshRegion.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMeshRegion.py
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMeshResult.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMeshResult.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemMeshResult.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemMeshResult.py
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemResultMechanical.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemResultMechanical.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemResultMechanical.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemResultMechanical.py
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemSolverCalculix.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemSolverCalculix.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/_FemSolverCalculix.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/_FemSolverCalculix.py
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/FemConstraint.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/FemConstraint.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/femobjects/FemConstraint.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/femobjects/FemConstraint.py
make[1]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 17%] Built target FemScriptsTarget
make[1]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
/usr/bin/make -f src/Mod/Fem/Gui/CMakeFiles/FemPythonUi.dir/build.make src/Mod/Fem/Gui/CMakeFiles/FemPythonUi.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui/CMakeFiles/FemPythonUi.dir/DependInfo.cmake --color=
Scanning dependencies of target FemPythonUi
/usr/bin/make -f src/Mod/Fem/Gui/CMakeFiles/FemPythonUi.dir/build.make src/Mod/Fem/Gui/CMakeFiles/FemPythonUi.dir/build
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ElectrostaticPotential.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ElectrostaticPotential.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ElectrostaticPotential.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ElectrostaticPotential.ui
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ElementFluid1D.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ElementFluid1D.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ElementFluid1D.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ElementFluid1D.ui
[ 17%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ElementGeometry1D.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ElementGeometry1D.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ElementGeometry1D.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ElementGeometry1D.ui
make[2]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ElementGeometry2D.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ElementGeometry2D.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ElementGeometry2D.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ElementGeometry2D.ui
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ElementRotation1D.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ElementRotation1D.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ElementRotation1D.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ElementRotation1D.ui
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/FlowVelocity.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/FlowVelocity.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/FlowVelocity.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/FlowVelocity.ui
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/InitialFlowVelocity.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/InitialFlowVelocity.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/InitialFlowVelocity.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/InitialFlowVelocity.ui
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/Material.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/Material.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/Material.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/Material.ui
make[2]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/MeshBoundaryLayer.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/MeshBoundaryLayer.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/MeshBoundaryLayer.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/MeshBoundaryLayer.ui
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/MeshGmsh.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/MeshGmsh.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/MeshGmsh.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/MeshGmsh.ui
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/MeshGroup.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/MeshGroup.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/MeshGroup.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/MeshGroup.ui
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/MeshGroupXDMFExport.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/MeshGroupXDMFExport.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/MeshGroupXDMFExport.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/MeshGroupXDMFExport.ui
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/MeshRegion.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/MeshRegion.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/MeshRegion.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/MeshRegion.ui
[ 15%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/UnitsApi.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/UnitsApi.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/UnitsApi.cpp
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ResultShow.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ResultShow.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/ResultShow.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/ResultShow.ui
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/SolverCalculix.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/SolverCalculix.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Fem/Gui && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Fem/Gui/Resources/ui/SolverCalculix.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Fem/Resources/ui/SolverCalculix.ui
[ 18%] Built target FemPythonUi
/usr/bin/make -f src/Mod/Ship/CMakeFiles/Ship.dir/build.make src/Mod/Ship/CMakeFiles/Ship.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship/CMakeFiles/Ship.dir/DependInfo.cmake --color=
Scanning dependencies of target Ship
/usr/bin/make -f src/Mod/Ship/CMakeFiles/Ship.dir/build.make src/Mod/Ship/CMakeFiles/Ship.dir/build
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/InitGui.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/ShipGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/ShipGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/ShipGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/ShipGui.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/Instance.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/Instance.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/Instance.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/Instance.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/TankInstance.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/TankInstance.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/TankInstance.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/TankInstance.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/WeightInstance.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/WeightInstance.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/WeightInstance.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/WeightInstance.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/resources/examples/s60.fcstd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/resources/examples/s60.fcstd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/resources/examples/s60.fcstd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/resources/examples/s60.fcstd
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/resources/examples/s60_katamaran.fcstd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/resources/examples/s60_katamaran.fcstd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/resources/examples/s60_katamaran.fcstd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/resources/examples/s60_katamaran.fcstd
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/resources/examples/wigley.fcstd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/resources/examples/wigley.fcstd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/resources/examples/wigley.fcstd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/resources/examples/wigley.fcstd
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/resources/examples/wigley_katamaran.fcstd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/resources/examples/wigley_katamaran.fcstd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/resources/examples/wigley_katamaran.fcstd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/resources/examples/wigley_katamaran.fcstd
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipLoadExample/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipLoadExample/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipLoadExample/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipLoadExample/__init__.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipLoadExample/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipLoadExample/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipLoadExample/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipLoadExample/TaskPanel.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipLoadExample/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipLoadExample/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipLoadExample/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipLoadExample/TaskPanel.ui
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateShip/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateShip/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateShip/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateShip/__init__.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateShip/Preview.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateShip/Preview.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateShip/Preview.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateShip/Preview.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateShip/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateShip/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateShip/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateShip/TaskPanel.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateShip/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateShip/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateShip/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateShip/TaskPanel.ui
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateShip/Tools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateShip/Tools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateShip/Tools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateShip/Tools.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipOutlineDraw/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipOutlineDraw/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipOutlineDraw/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipOutlineDraw/__init__.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipOutlineDraw/Preview.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipOutlineDraw/Preview.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipOutlineDraw/Preview.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipOutlineDraw/Preview.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipOutlineDraw/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipOutlineDraw/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipOutlineDraw/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipOutlineDraw/TaskPanel.py
[ 18%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipOutlineDraw/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipOutlineDraw/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipOutlineDraw/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipOutlineDraw/TaskPanel.ui
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipAreasCurve/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipAreasCurve/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipAreasCurve/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipAreasCurve/__init__.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipAreasCurve/PlotAux.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipAreasCurve/PlotAux.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipAreasCurve/PlotAux.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipAreasCurve/PlotAux.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipAreasCurve/Preview.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipAreasCurve/Preview.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipAreasCurve/Preview.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipAreasCurve/Preview.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipAreasCurve/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipAreasCurve/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipAreasCurve/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipAreasCurve/TaskPanel.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipAreasCurve/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipAreasCurve/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipAreasCurve/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipAreasCurve/TaskPanel.ui
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipHydrostatics/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipHydrostatics/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipHydrostatics/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipHydrostatics/__init__.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipHydrostatics/PlotAux.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipHydrostatics/PlotAux.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipHydrostatics/PlotAux.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipHydrostatics/PlotAux.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipHydrostatics/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipHydrostatics/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipHydrostatics/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipHydrostatics/TaskPanel.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipHydrostatics/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipHydrostatics/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipHydrostatics/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipHydrostatics/TaskPanel.ui
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipHydrostatics/Tools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipHydrostatics/Tools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipHydrostatics/Tools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipHydrostatics/Tools.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateWeight/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateWeight/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateWeight/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateWeight/__init__.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateWeight/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateWeight/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateWeight/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateWeight/TaskPanel.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateWeight/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateWeight/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateWeight/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateWeight/TaskPanel.ui
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateWeight/Tools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateWeight/Tools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateWeight/Tools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateWeight/Tools.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateTank/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateTank/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateTank/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateTank/__init__.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateTank/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateTank/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateTank/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateTank/TaskPanel.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateTank/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateTank/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateTank/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateTank/TaskPanel.ui
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateTank/Tools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateTank/Tools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateTank/Tools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateTank/Tools.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCapacityCurve/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCapacityCurve/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCapacityCurve/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCapacityCurve/__init__.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCapacityCurve/PlotAux.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCapacityCurve/PlotAux.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCapacityCurve/PlotAux.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCapacityCurve/PlotAux.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCapacityCurve/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCapacityCurve/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCapacityCurve/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCapacityCurve/TaskPanel.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCapacityCurve/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCapacityCurve/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCapacityCurve/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCapacityCurve/TaskPanel.ui
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCapacityCurve/Tools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCapacityCurve/Tools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCapacityCurve/Tools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCapacityCurve/Tools.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateLoadCondition/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateLoadCondition/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateLoadCondition/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateLoadCondition/__init__.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateLoadCondition/Tools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateLoadCondition/Tools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipCreateLoadCondition/Tools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipCreateLoadCondition/Tools.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipGZ/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipGZ/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipGZ/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipGZ/__init__.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipGZ/PlotAux.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipGZ/PlotAux.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipGZ/PlotAux.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipGZ/PlotAux.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipGZ/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipGZ/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipGZ/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipGZ/TaskPanel.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipGZ/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipGZ/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipGZ/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipGZ/TaskPanel.ui
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipGZ/Tools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipGZ/Tools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipGZ/Tools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipGZ/Tools.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipUtils/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipUtils/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipUtils/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipUtils/__init__.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipUtils/Locale.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipUtils/Locale.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipUtils/Locale.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipUtils/Locale.py
[ 19%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipUtils/Math.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipUtils/Math.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipUtils/Math.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipUtils/Math.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipUtils/Paths.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipUtils/Paths.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipUtils/Paths.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipUtils/Paths.py
[ 16%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/UnitsApiPy.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/UnitsApiPy.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/UnitsApiPy.cpp
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipUtils/Units.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipUtils/Units.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/shipUtils/Units.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/shipUtils/Units.py
[ 20%] Generating Ship_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/pyside2-rcc /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/resources/Ship.qrc -o /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship/Ship_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && sed -i /^#\ /d /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship/Ship_rc.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/resources/icons/ShipWorkbench.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Ship/resources/icons/ShipWorkbench.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Ship/resources/icons/ShipWorkbench.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Ship/resources/icons/ShipWorkbench.svg
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship/Ship_rc.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/Ship_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Ship/Ship_rc.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Ship/Ship_rc.py
[ 20%] Built target Ship
/usr/bin/make -f src/Mod/OpenSCAD/CMakeFiles/OpenSCAD.dir/build.make src/Mod/OpenSCAD/CMakeFiles/OpenSCAD.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD/CMakeFiles/OpenSCAD.dir/DependInfo.cmake --color=
Scanning dependencies of target OpenSCAD
/usr/bin/make -f src/Mod/OpenSCAD/CMakeFiles/OpenSCAD.dir/build.make src/Mod/OpenSCAD/CMakeFiles/OpenSCAD.dir/build
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/Init.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/InitGui.py
[ 11%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Writer.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Writer.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Writer.cpp
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/OpenSCAD2Dgeom.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/OpenSCAD2Dgeom.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/OpenSCAD2Dgeom.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/OpenSCAD2Dgeom.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/OpenSCADFeatures.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/OpenSCADFeatures.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/OpenSCADFeatures.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/OpenSCADFeatures.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/OpenSCADUtils.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/OpenSCADUtils.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/OpenSCADUtils.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/OpenSCADUtils.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/OpenSCADCommands.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/OpenSCADCommands.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/OpenSCADCommands.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/OpenSCADCommands.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/exportCSG.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/exportCSG.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/exportCSG.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/exportCSG.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/importCSG.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/importCSG.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/importCSG.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/importCSG.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/tokrules.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/tokrules.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/tokrules.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/tokrules.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/colorcodeshapes.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/colorcodeshapes.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/colorcodeshapes.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/colorcodeshapes.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/expandplacements.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/expandplacements.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/expandplacements.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/expandplacements.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/replaceobj.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/replaceobj.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/replaceobj.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/replaceobj.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/ply/lex.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/ply/lex.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/ply/lex.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/ply/lex.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/ply/README to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/ply/README
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/ply/README /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/ply/README
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/ply/yacc.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/ply/yacc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/ply/yacc.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/ply/yacc.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/ply/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/ply/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/ply/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/ply/__init__.py
[ 20%] Generating OpenSCAD_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/pyside2-rcc /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/Resources/OpenSCAD.qrc -o /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD/OpenSCAD_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && sed -i /^#\ /d /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD/OpenSCAD_rc.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/Resources/icons/OpenSCADWorkbench.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/OpenSCAD/Resources/icons/OpenSCADWorkbench.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/OpenSCAD/Resources/icons/OpenSCADWorkbench.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/OpenSCAD/Resources/icons/OpenSCADWorkbench.svg
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD/OpenSCAD_rc.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/OpenSCAD_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/OpenSCAD/OpenSCAD_rc.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/OpenSCAD/OpenSCAD_rc.py
[ 20%] Built target OpenSCAD
/usr/bin/make -f src/Mod/Plot/CMakeFiles/Plot.dir/build.make src/Mod/Plot/CMakeFiles/Plot.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot/CMakeFiles/Plot.dir/DependInfo.cmake --color=
Scanning dependencies of target Plot
/usr/bin/make -f src/Mod/Plot/CMakeFiles/Plot.dir/build.make src/Mod/Plot/CMakeFiles/Plot.dir/build
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/Plot.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/Plot.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/Plot.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/Plot.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/InitGui.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/PlotGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/PlotGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/PlotGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/PlotGui.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotAxes/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotAxes/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotAxes/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotAxes/__init__.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotAxes/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotAxes/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotAxes/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotAxes/TaskPanel.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotAxes/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotAxes/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotAxes/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotAxes/TaskPanel.ui
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotLabels/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotLabels/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotLabels/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotLabels/__init__.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotLabels/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotLabels/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotLabels/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotLabels/TaskPanel.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotLabels/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotLabels/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotLabels/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotLabels/TaskPanel.ui
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotPositions/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotPositions/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotPositions/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotPositions/__init__.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotPositions/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotPositions/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotPositions/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotPositions/TaskPanel.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotPositions/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotPositions/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotPositions/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotPositions/TaskPanel.ui
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSave/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSave/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSave/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSave/__init__.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSave/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSave/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSave/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSave/TaskPanel.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSave/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSave/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSave/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSave/TaskPanel.ui
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSeries/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSeries/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSeries/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSeries/__init__.py
[ 20%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSeries/TaskPanel.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSeries/TaskPanel.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSeries/TaskPanel.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSeries/TaskPanel.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSeries/TaskPanel.ui to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSeries/TaskPanel.ui
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotSeries/TaskPanel.ui /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotSeries/TaskPanel.ui
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotUtils/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotUtils/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotUtils/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotUtils/__init__.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotUtils/Paths.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotUtils/Paths.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/plotUtils/Paths.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/plotUtils/Paths.py
[ 18%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/UnitsSchema.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/UnitsSchema.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/UnitsSchema.cpp
[ 21%] Generating Plot_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/pyside2-rcc /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/resources/Plot.qrc -o /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot/Plot_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && sed -i /^#\ /d /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot/Plot_rc.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/resources/icons/PlotWorkbench.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Plot/resources/icons/PlotWorkbench.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Plot/resources/icons/PlotWorkbench.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/usr/share/freecad/Mod/Plot/resources/icons/PlotWorkbench.svg
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot/Plot_rc.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/Plot_rc.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Plot/Plot_rc.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Plot/Plot_rc.py
make[1]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 21%] Built target Plot
make[1]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
/usr/bin/make -f src/Mod/Spreadsheet/CMakeFiles/SpreadsheetScripts.dir/build.make src/Mod/Spreadsheet/CMakeFiles/SpreadsheetScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Spreadsheet /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Spreadsheet /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Spreadsheet/CMakeFiles/SpreadsheetScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target SpreadsheetScripts
/usr/bin/make -f src/Mod/Spreadsheet/CMakeFiles/SpreadsheetScripts.dir/build.make src/Mod/Spreadsheet/CMakeFiles/SpreadsheetScripts.dir/build
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Spreadsheet/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Spreadsheet/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Spreadsheet && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Spreadsheet/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Spreadsheet/Init.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Spreadsheet/TestSpreadsheet.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Spreadsheet/TestSpreadsheet.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Spreadsheet && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Spreadsheet/TestSpreadsheet.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Spreadsheet/TestSpreadsheet.py
make[2]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Spreadsheet/importXLSX.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Spreadsheet/importXLSX.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Spreadsheet && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Spreadsheet/importXLSX.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Spreadsheet/importXLSX.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Spreadsheet/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Spreadsheet/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Spreadsheet && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Spreadsheet/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Spreadsheet/InitGui.py
[ 21%] Built target SpreadsheetScripts
/usr/bin/make -f src/Mod/Path/CMakeFiles/PathTests.dir/build.make src/Mod/Path/CMakeFiles/PathTests.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/CMakeFiles/PathTests.dir/DependInfo.cmake --color=
Scanning dependencies of target PathTests
/usr/bin/make -f src/Mod/Path/CMakeFiles/PathTests.dir/build.make src/Mod/Path/CMakeFiles/PathTests.dir/build
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/Init.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/Init.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/Init.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/Init.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathCommands.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathCommands.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathCommands.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathCommands.py
make[2]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/TestPathApp.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/TestPathApp.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/TestPathApp.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/TestPathApp.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/InitGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/InitGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/InitGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/InitGui.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/__init__.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/PathTestUtils.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/PathTestUtils.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/PathTestUtils.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/PathTestUtils.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathCore.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathCore.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathCore.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathCore.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathDeburr.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathDeburr.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathDeburr.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathDeburr.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathDepthParams.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathDepthParams.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathDepthParams.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathDepthParams.py
[ 21%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathDressupDogbone.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathDressupDogbone.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathDressupDogbone.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathDressupDogbone.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathDressupHoldingTags.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathDressupHoldingTags.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathDressupHoldingTags.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathDressupHoldingTags.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathGeom.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathGeom.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathGeom.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathGeom.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathLog.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathLog.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathLog.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathLog.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathOpTools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathOpTools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathOpTools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathOpTools.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathPost.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathPost.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathPost.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathPost.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathSetupSheet.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathSetupSheet.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathSetupSheet.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathSetupSheet.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathStock.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathStock.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathStock.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathStock.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathTool.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathTool.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathTool.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathTool.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathToolController.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathToolController.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathToolController.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathToolController.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathTooltable.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathTooltable.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathTooltable.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathTooltable.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathUtil.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathUtil.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/TestPathUtil.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/TestPathUtil.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/boxtest.fcstd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/boxtest.fcstd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/boxtest.fcstd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/boxtest.fcstd
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/test_centroid_00.ngc to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/test_centroid_00.ngc
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/test_centroid_00.ngc /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/test_centroid_00.ngc
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/test_geomop.fcstd to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/test_geomop.fcstd
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/test_geomop.fcstd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/test_geomop.fcstd
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/test_linuxcnc_00.ngc to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/test_linuxcnc_00.ngc
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathTests/test_linuxcnc_00.ngc /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathTests/test_linuxcnc_00.ngc
[ 22%] Built target PathTests
/usr/bin/make -f src/Mod/Path/CMakeFiles/PathScripts.dir/build.make src/Mod/Path/CMakeFiles/PathScripts.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/CMakeFiles/PathScripts.dir/DependInfo.cmake --color=
Scanning dependencies of target PathScripts
/usr/bin/make -f src/Mod/Path/CMakeFiles/PathScripts.dir/build.make src/Mod/Path/CMakeFiles/PathScripts.dir/build
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathAreaOp.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathAreaOp.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathAreaOp.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathAreaOp.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathArray.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathArray.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathArray.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathArray.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathCircularHoleBase.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathCircularHoleBase.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathCircularHoleBase.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathCircularHoleBase.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathCircularHoleBaseGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathCircularHoleBaseGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathCircularHoleBaseGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathCircularHoleBaseGui.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathComment.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathComment.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathComment.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathComment.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathCopy.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathCopy.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathCopy.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathCopy.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathCustom.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathCustom.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathCustom.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathCustom.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDeburr.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDeburr.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDeburr.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDeburr.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDeburrGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDeburrGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDeburrGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDeburrGui.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressup.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressup.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressup.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressup.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupAxisMap.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupAxisMap.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupAxisMap.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupAxisMap.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupDogbone.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupDogbone.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupDogbone.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupDogbone.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupDragknife.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupDragknife.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupDragknife.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupDragknife.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupHoldingTags.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupHoldingTags.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupHoldingTags.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupHoldingTags.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupLeadInOut.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupLeadInOut.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupLeadInOut.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupLeadInOut.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupRampEntry.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupRampEntry.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupRampEntry.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupRampEntry.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupTag.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupTag.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupTag.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupTag.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupTagGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupTagGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupTagGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupTagGui.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupTagPreferences.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupTagPreferences.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDressupTagPreferences.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDressupTagPreferences.py
[ 22%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDrilling.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDrilling.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDrilling.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDrilling.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDrillingGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDrillingGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathDrillingGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathDrillingGui.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathEngrave.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathEngrave.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathEngrave.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathEngrave.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathEngraveBase.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathEngraveBase.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathEngraveBase.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathEngraveBase.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathEngraveGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathEngraveGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathEngraveGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathEngraveGui.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathFixture.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathFixture.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathFixture.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathFixture.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathGeom.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathGeom.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathGeom.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathGeom.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathGetPoint.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathGetPoint.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathGetPoint.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathGetPoint.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathGui.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathGuiInit.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathGuiInit.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathGuiInit.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathGuiInit.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathHelix.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathHelix.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathHelix.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathHelix.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathHelixGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathHelixGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathHelixGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathHelixGui.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathHop.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathHop.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathHop.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathHop.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathIconViewProvider.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathIconViewProvider.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathIconViewProvider.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathIconViewProvider.py
[ 20%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/UnitsSchemaInternal.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/UnitsSchemaInternal.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/UnitsSchemaInternal.cpp
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathInspect.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathInspect.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathInspect.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathInspect.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathJob.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathJob.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathJob.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathJob.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathJobCmd.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathJobCmd.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathJobCmd.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathJobCmd.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathJobDlg.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathJobDlg.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathJobDlg.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathJobDlg.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathJobGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathJobGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathJobGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathJobGui.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathLog.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathLog.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathLog.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathLog.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathMillFace.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathMillFace.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathMillFace.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathMillFace.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathOp.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathOp.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathOp.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathOp.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathMillFaceGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathMillFaceGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathMillFaceGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathMillFaceGui.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathOpGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathOpGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathOpGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathOpGui.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathOpTools.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathOpTools.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathOpTools.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathOpTools.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocket.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocket.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocket.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocket.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocketBase.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocketBase.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocketBase.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocketBase.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocketBaseGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocketBaseGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocketBaseGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocketBaseGui.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocketGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocketGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocketGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocketGui.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocketShape.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocketShape.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocketShape.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocketShape.py
[ 20%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/UnitsSchemaMKS.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/UnitsSchemaMKS.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/UnitsSchemaMKS.cpp
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocketShapeGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocketShapeGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPocketShapeGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPocketShapeGui.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPost.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPost.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPost.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPost.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPostProcessor.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPostProcessor.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPostProcessor.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPostProcessor.py
[ 23%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPreferences.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPreferences.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPreferences.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPreferences.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPreferencesPathDressup.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPreferencesPathDressup.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPreferencesPathDressup.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPreferencesPathDressup.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPreferencesPathJob.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPreferencesPathJob.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathPreferencesPathJob.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathPreferencesPathJob.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileBase.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileBase.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileBase.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileBase.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileBaseGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileBaseGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileBaseGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileBaseGui.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileContour.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileContour.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileContour.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileContour.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileContourGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileContourGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileContourGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileContourGui.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileEdges.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileEdges.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileEdges.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileEdges.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileEdgesGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileEdgesGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileEdgesGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileEdgesGui.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileFaces.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileFaces.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileFaces.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileFaces.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileFacesGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileFacesGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathProfileFacesGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathProfileFacesGui.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSanity.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSanity.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSanity.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSanity.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSelection.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSelection.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSelection.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSelection.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSetupSheet.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSetupSheet.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSetupSheet.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSetupSheet.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSetupSheetGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSetupSheetGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSetupSheetGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSetupSheetGui.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSetupSheetOpPrototype.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSetupSheetOpPrototype.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSetupSheetOpPrototype.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSetupSheetOpPrototype.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSetupSheetOpPrototypeGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSetupSheetOpPrototypeGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSetupSheetOpPrototypeGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSetupSheetOpPrototypeGui.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSimpleCopy.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSimpleCopy.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSimpleCopy.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSimpleCopy.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathStock.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathStock.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathStock.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathStock.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathStop.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathStop.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathStop.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathStop.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSurface.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSurface.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSurface.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSurface.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSurfaceGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSurfaceGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSurfaceGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSurfaceGui.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathToolController.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathToolController.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathToolController.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathToolController.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathToolEdit.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathToolEdit.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathToolEdit.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathToolEdit.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathToolLibraryManager.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathToolLibraryManager.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathToolLibraryManager.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathToolLibraryManager.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathUtil.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathUtil.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathUtil.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathUtil.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathUtils.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathUtils.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathUtils.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathUtils.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSimulatorGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSimulatorGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathSimulatorGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathSimulatorGui.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PostUtils.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PostUtils.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PostUtils.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PostUtils.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathAdaptiveGui.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathAdaptiveGui.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathAdaptiveGui.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathAdaptiveGui.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathAdaptive.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathAdaptive.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/PathAdaptive.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/PathAdaptive.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/__init__.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/__init__.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/__init__.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/__init__.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/__init__.py
[ 24%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/centroid_post.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/centroid_post.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/centroid_post.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/centroid_post.py
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/comparams_post.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/comparams_post.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/comparams_post.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/comparams_post.py
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/dynapath_post.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/dynapath_post.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/dynapath_post.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/dynapath_post.py
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/example_pre.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/example_pre.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/example_pre.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/example_pre.py
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/grbl_post.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/grbl_post.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/grbl_post.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/grbl_post.py
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/grbl_G81_post.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/grbl_G81_post.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/grbl_G81_post.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/grbl_G81_post.py
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/linuxcnc_post.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/linuxcnc_post.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/linuxcnc_post.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/linuxcnc_post.py
make[2]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/opensbp_post.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/opensbp_post.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/opensbp_post.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/opensbp_post.py
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/opensbp_pre.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/opensbp_pre.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/opensbp_pre.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/opensbp_pre.py
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/philips_post.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/philips_post.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/philips_post.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/philips_post.py
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/rml_post.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/rml_post.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/rml_post.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/rml_post.py
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/slic3r_pre.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/slic3r_pre.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/slic3r_pre.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/slic3r_pre.py
make[2]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/smoothie_post.py to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/smoothie_post.py
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/PathScripts/post/smoothie_post.py /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/PathScripts/post/smoothie_post.py
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/Images/Ops/chamfer.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/Images/Ops/chamfer.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/Images/Ops/chamfer.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/Images/Ops/chamfer.svg
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/Images/Tools/drill.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/Images/Tools/drill.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/Images/Tools/drill.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/Images/Tools/drill.svg
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/Images/Tools/endmill.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/Images/Tools/endmill.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/Images/Tools/endmill.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/Images/Tools/endmill.svg
[ 25%] Copying /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/Images/Tools/v-bit.svg to /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/Images/Tools/v-bit.svg
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path && /usr/bin/cmake -E copy /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/Images/Tools/v-bit.svg /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/Mod/Path/Images/Tools/v-bit.svg
make[1]: Entering directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
[ 25%] Built target PathScripts
make[1]: Leaving directory '/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build'
/usr/bin/make -f src/Mod/Path/libarea/CMakeFiles/area-native.dir/build.make src/Mod/Path/libarea/CMakeFiles/area-native.dir/depend
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18 /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea/CMakeFiles/area-native.dir/DependInfo.cmake --color=
Scanning dependencies of target area-native
/usr/bin/make -f src/Mod/Path/libarea/CMakeFiles/area-native.dir/build.make src/Mod/Path/libarea/CMakeFiles/area-native.dir/build
[ 21%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/UnitsSchemaImperial1.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/UnitsSchemaImperial1.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/UnitsSchemaImperial1.cpp
[ 23%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/UnitsSchemaCentimeters.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/UnitsSchemaCentimeters.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/UnitsSchemaCentimeters.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/Arc.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/Arc.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/Arc.cpp
[ 23%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/UnitsSchemaMmMin.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/UnitsSchemaMmMin.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/UnitsSchemaMmMin.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/AreaDxf.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/AreaDxf.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/AreaDxf.cpp
[ 25%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Quantity.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Quantity.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Quantity.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/Area.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/Area.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/Area.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/AreaOrderer.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/AreaOrderer.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/AreaOrderer.cpp
[ 25%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/QuantityPyImp.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/QuantityPyImp.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/QuantityPyImp.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/Circle.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/Circle.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/Circle.cpp
[ 25%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Unit.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/Unit.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/Unit.cpp
[ 25%] Building C object src/Base/CMakeFiles/FreeCADBase.dir/PyTools.c.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/cc -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -DNDEBUG -fPIC -fPIC -o CMakeFiles/FreeCADBase.dir/PyTools.c.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/PyTools.c
[ 25%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/PreCompiled.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/PreCompiled.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/PreCompiled.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/AreaPocket.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/AreaPocket.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/AreaPocket.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/Curve.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/Curve.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/Curve.cpp
[ 25%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/UnitPyImp.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/c++ -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base -I/usr/include/python3.7m -isystem /usr/lib64/qt5/include -isystem /usr/lib64/qt5/include/QtCore -isystem /usr/lib64/qt5/./mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -fPIC -fPIC -std=gnu++11 -o CMakeFiles/FreeCADBase.dir/UnitPyImp.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Base/UnitPyImp.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/kurve/Construction.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/kurve/Construction.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/kurve/Construction.cpp
[ 25%] Linking CXX shared library ../../lib/libFreeCADBase.so
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Base && /usr/bin/cmake -E cmake_link_script CMakeFiles/FreeCADBase.dir/link.txt --verbose=1
/usr/bin/c++ -fPIC -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -DNDEBUG -Wl,--as-needed -Wl,--no-undefined -Wl,--no-undefined -shared -Wl,-soname,libFreeCADBase.so -o ../../lib/libFreeCADBase.so CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxxextensions.c.o CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxx_extensions.cxx.o CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxxsupport.cxx.o CMakeFiles/FreeCADBase.dir/usr/src/CXX/IndirectPythonInterface.cxx.o CMakeFiles/FreeCADBase.dir/usr/src/CXX/cxx_exceptions.cxx.o CMakeFiles/FreeCADBase.dir/Axis.cpp.o CMakeFiles/FreeCADBase.dir/AxisPyImp.cpp.o CMakeFiles/FreeCADBase.dir/Base64.cpp.o CMakeFiles/FreeCADBase.dir/BaseClass.cpp.o CMakeFiles/FreeCADBase.dir/BaseClassPyImp.cpp.o CMakeFiles/FreeCADBase.dir/BoundBoxPyImp.cpp.o CMakeFiles/FreeCADBase.dir/Builder3D.cpp.o CMakeFiles/FreeCADBase.dir/Console.cpp.o CMakeFiles/FreeCADBase.dir/CoordinateSystem.cpp.o CMakeFiles/FreeCADBase.dir/CoordinateSystemPyImp.cpp.o CMakeFiles/FreeCADBase.dir/Debugger.cpp.o CMakeFiles/FreeCADBase.dir/Exception.cpp.o CMakeFiles/FreeCADBase.dir/ExceptionFactory.cpp.o CMakeFiles/FreeCADBase.dir/Factory.cpp.o CMakeFiles/FreeCADBase.dir/FileInfo.cpp.o CMakeFiles/FreeCADBase.dir/FileTemplate.cpp.o CMakeFiles/FreeCADBase.dir/FutureWatcherProgress.cpp.o CMakeFiles/FreeCADBase.dir/gzstream.cpp.o CMakeFiles/FreeCADBase.dir/GeometryPyCXX.cpp.o CMakeFiles/FreeCADBase.dir/Handle.cpp.o CMakeFiles/FreeCADBase.dir/InputSource.cpp.o CMakeFiles/FreeCADBase.dir/Interpreter.cpp.o CMakeFiles/FreeCADBase.dir/Matrix.cpp.o CMakeFiles/FreeCADBase.dir/MatrixPyImp.cpp.o CMakeFiles/FreeCADBase.dir/MemDebug.cpp.o CMakeFiles/FreeCADBase.dir/Parameter.cpp.o CMakeFiles/FreeCADBase.dir/ParameterPy.cpp.o CMakeFiles/FreeCADBase.dir/Persistence.cpp.o CMakeFiles/FreeCADBase.dir/PersistencePyImp.cpp.o CMakeFiles/FreeCADBase.dir/Placement.cpp.o CMakeFiles/FreeCADBase.dir/PlacementPyImp.cpp.o CMakeFiles/FreeCADBase.dir/PyExport.cpp.o CMakeFiles/FreeCADBase.dir/PyObjectBase.cpp.o CMakeFiles/FreeCADBase.dir/Reader.cpp.o CMakeFiles/FreeCADBase.dir/Rotation.cpp.o CMakeFiles/FreeCADBase.dir/RotationPyImp.cpp.o CMakeFiles/FreeCADBase.dir/Sequencer.cpp.o CMakeFiles/FreeCADBase.dir/Stream.cpp.o CMakeFiles/FreeCADBase.dir/Swap.cpp.o CMakeFiles/FreeCADBase.dir/swigpyrun.cpp.o CMakeFiles/FreeCADBase.dir/TimeInfo.cpp.o CMakeFiles/FreeCADBase.dir/Tools.cpp.o CMakeFiles/FreeCADBase.dir/Tools2D.cpp.o CMakeFiles/FreeCADBase.dir/Translate.cpp.o CMakeFiles/FreeCADBase.dir/Type.cpp.o CMakeFiles/FreeCADBase.dir/Uuid.cpp.o CMakeFiles/FreeCADBase.dir/Vector3D.cpp.o CMakeFiles/FreeCADBase.dir/VectorPyImp.cpp.o CMakeFiles/FreeCADBase.dir/ViewProj.cpp.o CMakeFiles/FreeCADBase.dir/Writer.cpp.o CMakeFiles/FreeCADBase.dir/XMLTools.cpp.o CMakeFiles/FreeCADBase.dir/UnitsApi.cpp.o CMakeFiles/FreeCADBase.dir/UnitsApiPy.cpp.o CMakeFiles/FreeCADBase.dir/UnitsSchema.cpp.o CMakeFiles/FreeCADBase.dir/UnitsSchemaInternal.cpp.o CMakeFiles/FreeCADBase.dir/UnitsSchemaMKS.cpp.o CMakeFiles/FreeCADBase.dir/UnitsSchemaImperial1.cpp.o CMakeFiles/FreeCADBase.dir/UnitsSchemaCentimeters.cpp.o CMakeFiles/FreeCADBase.dir/UnitsSchemaMmMin.cpp.o CMakeFiles/FreeCADBase.dir/Quantity.cpp.o CMakeFiles/FreeCADBase.dir/QuantityPyImp.cpp.o CMakeFiles/FreeCADBase.dir/Unit.cpp.o CMakeFiles/FreeCADBase.dir/UnitPyImp.cpp.o CMakeFiles/FreeCADBase.dir/PyTools.c.o CMakeFiles/FreeCADBase.dir/PreCompiled.cpp.o /usr/lib64/libpython3.7m.so /usr/lib64/libxerces-c.so /usr/lib64/libboost_filesystem.so /usr/lib64/libboost_program_options.so /usr/lib64/libboost_regex.so /usr/lib64/libboost_system.so -lboost_thread -lpthread /usr/lib64/libboost_chrono.so /usr/lib64/libboost_date_time.so /usr/lib64/libboost_atomic.so -lpthread /usr/lib64/libz.so /usr/lib64/libQt5Core.so.5.12.1 -lutil -ldl /usr/lib64/libzipios.so -lpython3.7
/usr/bin/ld: CMakeFiles/FreeCADBase.dir/ParameterPy.cpp.o:(.data.rel.ro._ZTVN2Py15PythonExtensionIN4Base14ParameterGrpPyEEE[_ZTVN2Py15PythonExtensionIN4Base14ParameterGrpPyEEE]+0x28): undefined reference to `Py::PythonExtensionBase::print(_IO_FILE*, int)'
/usr/bin/ld: CMakeFiles/FreeCADBase.dir/ParameterPy.cpp.o:(.data.rel.ro._ZTVN4Base14ParameterGrpPyE[_ZTVN4Base14ParameterGrpPyE]+0x28): undefined reference to `Py::PythonExtensionBase::print(_IO_FILE*, int)'
collect2: error: ld returned 1 exit status
make[2]: *** [src/Base/CMakeFiles/FreeCADBase.dir/build.make:1242: lib/libFreeCADBase.so] Error 1
make[1]: *** [CMakeFiles/Makefile2:686: src/Base/CMakeFiles/FreeCADBase.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/kurve/Finite.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/kurve/Finite.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/kurve/Finite.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/kurve/Matrix.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/kurve/Matrix.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/kurve/Matrix.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/dxf.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/dxf.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/dxf.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/kurve/offset.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/kurve/offset.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/kurve/offset.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/kurve/kurve.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/kurve/kurve.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/kurve/kurve.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/AreaClipper.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/AreaClipper.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/AreaClipper.cpp
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/clipper.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/clipper.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/clipper.cpp
/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/clipper.cpp: In function 'void ClipperLib::InitEdge(ClipperLib::TEdge*, ClipperLib::TEdge*, ClipperLib::TEdge*, const ClipperLib::IntPoint&)':
/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/clipper.cpp:718:34: warning: 'void* memset(void*, int, size_t)' clearing an object of non-trivial type 'struct ClipperLib::TEdge'; use assignment or value-initialization instead [-Wclass-memaccess]
std::memset(e, 0, sizeof(TEdge));
/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/clipper.cpp:66:8: note: 'struct ClipperLib::TEdge' declared here
struct TEdge {
[ 25%] Building CXX object src/Mod/Path/libarea/CMakeFiles/area-native.dir/Adaptive.cpp.o
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/c++ -DHAVE_CONFIG_H -DPYCXX_6_2_COMPATIBILITY -D_OCC64 -Darea_native_EXPORTS -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src -I/usr/include/python3.7m -I/home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -fPIC -o CMakeFiles/area-native.dir/Adaptive.cpp.o -c /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/src/Mod/Path/libarea/Adaptive.cpp
[ 25%] Linking CXX shared library ../../../../lib/libarea-native.so
cd /home/david/mgarepo/freecad/BUILD/FreeCAD-0.18/build/src/Mod/Path/libarea && /usr/bin/cmake -E cmake_link_script CMakeFiles/area-native.dir/link.txt --verbose=1
/usr/bin/c++ -fPIC -Wall -Wextra -Wno-write-strings -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -fasynchronous-unwind-tables -std=c++11 -D_OCC64 -fPIC -DNDEBUG -Wl,--as-needed -Wl,--no-undefined -Wl,--no-undefined -shared -Wl,-soname,libarea-native.so -o ../../../../lib/libarea-native.so CMakeFiles/area-native.dir/Arc.cpp.o CMakeFiles/area-native.dir/Area.cpp.o CMakeFiles/area-native.dir/AreaDxf.cpp.o CMakeFiles/area-native.dir/AreaOrderer.cpp.o CMakeFiles/area-native.dir/AreaPocket.cpp.o CMakeFiles/area-native.dir/Circle.cpp.o CMakeFiles/area-native.dir/Curve.cpp.o CMakeFiles/area-native.dir/dxf.cpp.o CMakeFiles/area-native.dir/kurve/Construction.cpp.o CMakeFiles/area-native.dir/kurve/Finite.cpp.o CMakeFiles/area-native.dir/kurve/kurve.cpp.o CMakeFiles/area-native.dir/kurve/Matrix.cpp.o CMakeFiles/area-native.dir/kurve/offset.cpp.o CMakeFiles/area-native.dir/AreaClipper.cpp.o CMakeFiles/area-native.dir/Adaptive.cpp.o CMakeFiles/area-native.dir/clipper.cpp.o
[ 25%] Built target area-native
make: *** [Makefile:133: all] Error 2
error: Bad exit status from /home/david/mgarepo/freecad/BUILDROOT/rpm-tmp.DWaMFQ (%build)
RPM build errors:
@daviddavid please post this to the Install/Compile sub-forum https://forum.freecadweb.org/viewforum.php?f=4 Thanks for your efforts to get FC built on Mageia |
Ok done for in the Install/Compile sub-forum, and sorry! |
@daviddavid please notate the ticket URL here so we can follow it ;) |
https://forum.freecadweb.org/viewtopic.php?f=4&t=35109 |
Cauldron shows 0.18.3 is downloadable. Please follow their build scripts and patches in order to build on Mageia http://sophie.zarb.org/rpms/91dd2ae67845aff61851569f95e0c4b4/files Also consider using the Appimages (we have them for 0.18 and 0.19) see https://github.com/FreeCAD/FreeCAD/releases |
| 2019-03-20 09:32 | daviddavid | New Issue | |
| 2019-03-20 09:32 | daviddavid | File Added: log.freecad | |
| 2019-03-20 18:54 | Kunda1 | Description Updated | |
| 2019-03-20 18:55 | Kunda1 | Status | new => feedback |
| 2019-03-20 18:55 | Kunda1 | Note Added: 0012933 | |
| 2019-03-21 04:51 | daviddavid | Note Added: 0012938 | |
| 2019-03-21 04:51 | daviddavid | Status | feedback => new |
| 2019-03-26 10:04 | Kunda1 | Note Added: 0012957 | |
| 2019-03-26 10:05 | Kunda1 | Status | new => feedback |
| 2019-03-26 12:01 | daviddavid | Note Added: 0012962 | |
| 2019-03-26 12:01 | daviddavid | Status | feedback => new |
| 2019-09-05 21:49 | Kunda1 | Status | new => closed |
| 2019-09-05 21:49 | Kunda1 | Resolution | open => no change required |
| 2019-09-05 21:49 | Kunda1 | Note Added: 0013547 | |
| 2019-09-05 21:49 | Kunda1 | Resolution | no change required => fixed |
| 2019-09-05 21:49 | Kunda1 | Fixed in Version | => 0.19 |
