| 0003917 | PartDesign | Bug | public | 2019-03-25 12:14 | 2020-09-10 15:19 |
| Reporter | bernard_01 | Assigned To | |||
| Platform | 64 bit | OS | Windows | OS Version | 7 |
| Summary | 0003917: Version 0.18 fails to display drawing, shows exceptions in log file. | ||||
| Description | The drawing pops up for a while but cannot be rotated. Eventually it disappears. There are errors in the log file. | ||||
| Steps To Reproduce | Start FreeCad with the -l switch to enable logging. Load the attached file. Expected: I should see the 3D navigation control in the right hand corned of the screen. Actual: No navigation control, while it is actually present in another file open at the same time, so it is not a settings issue. Expected: I should be able do rotate the drawing using OpenInventor. Actual: Nothing happens, or only sometimes after a few seconds. | ||||
| Additional Information | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16093 (Git) Build type: Release Branch: releases/FreeCAD-0-18 Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/NewZealand (en_NZ) | ||||
| related to | 0003915 | closed | FreeCAD | Image does not get loaded in Image workbench |
FreeCAD.log (13,913 bytes)
Msg: FreeCAD 0.18, Libs: 0.18R16093 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Log: Time = Tue Mar 26 00:15:28 2019 Log: AppDataSkipVendor = true Log: AppHomePath = C:/Program Files/FreeCAD 0.18/ Log: AppIcon = freecad Log: AppTempPath = C:\Users\user\AppData\Local\Temp\ Log: BinPath = C:/Program Files/FreeCAD 0.18/bin\ Log: BuildRepositoryURL = git://github.com/FreeCAD/FreeCAD.git releases/FreeCAD-0-18 Log: BuildRevision = 16093 (Git) Log: BuildRevisionBranch = releases/FreeCAD-0-18 Log: BuildRevisionDate = 2019/03/12 13:38:07 Log: BuildRevisionHash = 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce Log: BuildVersionMajor = 0 Log: BuildVersionMinor = 18 Log: Console = 0 Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Log: Debug = 0 Log: DocPath = C:/Program Files/FreeCAD 0.18/doc\ Log: ExeName = FreeCAD Log: ExeVendor = FreeCAD Log: ExeVersion = 0.18 Log: LoggingFile = 1 Log: LoggingFileName = C:\Users\user\AppData\Roaming\FreeCAD\FreeCAD.log Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page Log: PATH = C:\Program Files\FreeCAD 0.18\bin\Library\bin;C:\bt\win\bin;C:\Program Files\Java\jdk1.8.0_172\bin;C:\oraclexe\app\oracle\product\11.2.0\server\bin;;C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\prog\MinGW\bin;C:\prog\MinGW\msys\1.0\bin;C:\Program Files\Git\cmd;C:\Program Files\nodejs\;C:\Program Files\Mercurial;C:\prog\apache-maven-3.5.0/bin;C:\Program Files\nodejs;C:\Program Files\nodejs\node_modules\npm\bin;C:\Program Files\Heroku\bin;C:\prog\groovy\groovy-2.4.14\bin;C:\prog\grails-3.3.3\bin;C:\Program Files\Docker Toolbox Log: PythonSearchPath = C:\Program Files\FreeCAD 0.18\bin\python36.zip;C:\Program Files\FreeCAD 0.18\bin;C:\Program Files\FreeCAD 0.18\bin\DLLs;C:\Program Files\FreeCAD 0.18\bin\lib;C:\Program Files\FreeCAD 0.18\bin Log: RunMode = Gui Log: SplashAlignment = Bottom|Left Log: SplashInfoColor = #c8c8c8 Log: SplashScreen = freecadsplash Log: SplashTextColor = #ffffff Log: StartWorkbench = StartWorkbench Log: SystemParameter = C:\Users\user\AppData\Roaming\FreeCAD\system.cfg Log: UserAppData = C:\Users\user\AppData\Roaming\FreeCAD\ Log: UserHomePath = C:\Users\user\Documents Log: UserParameter = C:\Users\user\AppData\Roaming\FreeCAD\user.cfg Log: Verbose = Log: Create Application Log: Run App init script Log: Init: starting App::FreeCADInit.py Log: Init: Searching for modules... Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\AddonManager... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Arch... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Complete... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Draft... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Drawing... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Fem... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Idf... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Image... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Import... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Inspection... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Material... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Measure... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Mesh... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\MeshPart... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\OpenSCAD... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Part... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\PartDesign... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Path... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Plot(Init.py not found)... ignore Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Points... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Raytracing... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Robot... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Ship(Init.py not found)... ignore Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Show(Init.py not found)... ignore Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Sketcher... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Spreadsheet... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Start... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Surface... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\TechDraw... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Test... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Tux(Init.py not found)... ignore Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Web... done Log: Using C:\Program Files\FreeCAD 0.18\Mod as module path! Log: System path after init: Log: C:\Program Files\FreeCAD 0.18\bin Log: C:\Program Files\FreeCAD 0.18\Mod\AddonManager Log: C:\Program Files\FreeCAD 0.18\Mod\Arch Log: C:\Program Files\FreeCAD 0.18\Mod\Complete Log: C:\Program Files\FreeCAD 0.18\Mod\Draft Log: C:\Program Files\FreeCAD 0.18\Mod\Drawing Log: C:\Program Files\FreeCAD 0.18\Mod\Fem Log: C:\Program Files\FreeCAD 0.18\Mod\Idf Log: C:\Program Files\FreeCAD 0.18\Mod\Image Log: C:\Program Files\FreeCAD 0.18\Mod\Import Log: C:\Program Files\FreeCAD 0.18\Mod\Inspection Log: C:\Program Files\FreeCAD 0.18\Mod\Material Log: C:\Program Files\FreeCAD 0.18\Mod\Measure Log: C:\Program Files\FreeCAD 0.18\Mod\Mesh Log: C:\Program Files\FreeCAD 0.18\Mod\MeshPart Log: C:\Program Files\FreeCAD 0.18\Mod\OpenSCAD Log: C:\Program Files\FreeCAD 0.18\Mod\Part Log: C:\Program Files\FreeCAD 0.18\Mod\PartDesign Log: C:\Program Files\FreeCAD 0.18\Mod\Path Log: C:\Program Files\FreeCAD 0.18\Mod\Plot Log: C:\Program Files\FreeCAD 0.18\Mod\Points Log: C:\Program Files\FreeCAD 0.18\Mod\Raytracing Log: C:\Program Files\FreeCAD 0.18\Mod\Robot Log: C:\Program Files\FreeCAD 0.18\Mod\Ship Log: C:\Program Files\FreeCAD 0.18\Mod\Show Log: C:\Program Files\FreeCAD 0.18\Mod\Sketcher Log: C:\Program Files\FreeCAD 0.18\Mod\Spreadsheet Log: C:\Program Files\FreeCAD 0.18\Mod\Start Log: C:\Program Files\FreeCAD 0.18\Mod\Surface Log: C:\Program Files\FreeCAD 0.18\Mod\TechDraw Log: C:\Program Files\FreeCAD 0.18\Mod\Test Log: C:\Program Files\FreeCAD 0.18\Mod\Tux Log: C:\Program Files\FreeCAD 0.18\Mod\Web Log: C:\Program Files\FreeCAD 0.18\bin\Library\bin Log: C:\bt\win\bin Log: C:\Program Files\Java\jdk1.8.0_172\bin Log: C:\oraclexe\app\oracle\product\11.2.0\server\bin Log: Log: C:\ProgramData\Oracle\Java\javapath Log: C:\Windows\system32 Log: C:\Windows Log: C:\Windows\System32\Wbem Log: C:\Windows\System32\WindowsPowerShell\v1.0\ Log: C:\prog\MinGW\bin Log: C:\prog\MinGW\msys\1.0\bin Log: C:\Program Files\Git\cmd Log: C:\Program Files\nodejs\ Log: C:\Program Files\Mercurial Log: C:\prog\apache-maven-3.5.0/bin Log: C:\Program Files\nodejs Log: C:\Program Files\nodejs\node_modules\npm\bin Log: C:\Program Files\Heroku\bin Log: C:\prog\groovy\groovy-2.4.14\bin Log: C:\prog\grails-3.3.3\bin Log: C:\Program Files\Docker Toolbox Log: Init: App::FreeCADInit.py done Log: Init: Creating Gui::Application and QApplication Log: Local server 'FreeCAD' started Log: OpenGL version is: 4.3 (4.3.12618 Compatibility Profile Context 13.251.0.0) Log: Run Gui init script Log: Init: Running FreeCADGuiInit.py start script... Log: Init: Searching modules... Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\AddonManager... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Arch... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Complete... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Draft... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Drawing... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Fem... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Idf(InitGui.py not found)... ignore Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Image... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Import... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Inspection... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Material... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Measure(InitGui.py not found)... ignore Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Mesh... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\MeshPart... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\OpenSCAD... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Part... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\PartDesign... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Path... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Plot... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Points... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Raytracing... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Robot... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Ship... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Show(InitGui.py not found)... ignore Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Sketcher... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Spreadsheet... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Start... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Surface... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\TechDraw... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Test... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Tux... done Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Web... done Log: Init: Loading FreeCAD GUI Log: Init: Running FreeCADGuiInit.py start script... done Log: Init: Activating default workbench StartWorkbench Log: Loading GUI of Web module... done Log: Loading GUI of Start module... done Log: Loading Start module... done Log: Init: Showing main window Log: Main window restored Log: Show main window Log: Toolbars restored Log: 3Dconnexion device not attached. Log: Init: Entering event loop Log: Init: Processing command line files Log: Module: Part Log: Loading Part module... done Log: Loading Sketcher module... done Log: Loading PartDesign module... done Log: Loading GUI of Part module... done Log: Loading GUI of Sketcher module... done Log: Loading GUI of PartDesign module... done Err: Unhandled Base::Exception caught in GUIApplication::notify. The error message is: Access violation Log: The event type 12 was sent to QOpenGLWidget Object tree: QOpenGLWidget is child of SIM::Coin3D::Quarter::QuarterWidget is child of QStackedWidget is child of Gui::View3DInventor is child of QMdiSubWindow is child of QWidget is child of QMdiArea is child of Gui::MainWindowErr: Unhandled Base::Exception caught in GUIApplication::notify. The error message is: Access violation Log: The event type 12 was sent to QOpenGLWidget Object tree: QOpenGLWidget is child of SIM::Coin3D::Quarter::QuarterWidget is child of QStackedWidget is child of Gui::View3DInventor is child of QMdiSubWindow is child of QWidget is child of QMdiArea is child of Gui::MainWindowErr: Unhandled Base::Exception caught in GUIApplication::notify. The error message is: Access violation Log: The event type 12 was sent to QOpenGLWidget Object tree: QOpenGLWidget is child of SIM::Coin3D::Quarter::QuarterWidget is child of QStackedWidget is child of Gui::View3DInventor is child of QMdiSubWindow is child of QWidget is child of QMdiArea is child of Gui::MainWindowErr: Unhandled Base::Exception caught in GUIApplication::notify. The error message is: Access violation Log: The event type 12 was sent to QOpenGLWidget Object tree: QOpenGLWidget is child of SIM::Coin3D::Quarter::QuarterWidget is child of QStackedWidget is child of Gui::View3DInventor is child of QMdiSubWindow is child of QWidget is child of QMdiArea is child of Gui::MainWindowLog: Hide main window Log: Finish: Event loop left Log: Destruct Gui::Application Log: FreeCAD terminating... Log: Saving system parameter... Log: Saving system parameter...done Log: Saving user parameter... Log: Saving user parameter...done |
Perhaps related to 0003915 specifically 0003915:0012950 @kisolre care to weigh in ? |
That file works ok here when using Intel integrated graphics (when the imageplane fails). Might be something with the way transparency is handled by different cards? Most of the time (and in this file also) I make my bodies transparent to see sketches inside and hidden geometry. Attached is the same file with no transparency for OP to test. |
CamshaftGear2_kiss_no transparency.FCStd works for me with 0.1.8. I should mention that CamshaftGear2_kiss.FCStd works for me in 0.1.7 as well. |
So transparency works with 0.17 but not with 0.18 Py3Qt5 (Conda) build? Could you also try FreeCAD_0.18.16093_RC_x64_dev_win.7z from GitHub? |
There are no problems loading CamshaftGear2_kiss.FCStd with FreeCAD_0.18.16093_RC_x64_dev_win.7z |
@kisolre so this issue here is the Conda build ? |
@Kunda1 looks like it but since it does not happen here I can't test. But I noticed that in recent Conda builds transparency for imageplane looks disabled |
>> so this issue here is the Conda build ? > looks like it but since it does not happen here I can't test. > But I noticed that in recent Conda builds transparency for imageplane looks disabled CC @looo |
Latest conda build still no transparency but I noticed that image is visible also from the back - previously back was black. OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.17505 (Git) Build type: Release Branch: master Hash: 755536e9df94d2d39da1468420f1fd333c35da7a Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Bulgarian/Bulgaria (bg_BG) same version with Integrated Graphics still gives error |
Please retest with latest 0.19 and minimum Qt5.12 |
@kisolre care to retest this? |
Not sure what the actual problem was here. Here is what I tested - Start FreeCAD. Add Pad/Cube as reference. Add image, check if it is visible Ok from both sides. Change its transparency. Check if it looks Ok from both sides. Checked with Conda build OS: Windows 8.1 (6.3) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.20655 (Git) Build type: Release Branch: master Hash: e8e67e8c5ebbc9f9ed9ea67aba5b891969595ece Python version: 3.8.2 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: Bulgarian/Bulgaria (bg_BG) and LP build OS: Windows 8.1 (6.3) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.20738 (Git) Build type: Release Branch: master Hash: 0c96f77184edc0a6747483b2ff1462fc6dae46ff Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Bulgarian/Bulgaria (bg_BG) with both NVIDIA GeForce GTX 950M and integrated graphic card Intel(R) HD Graphics 530. No problems with any combination. |
Closing since no response from @bernard_01 and no other complaints. |
| 2019-03-25 12:14 | bernard_01 | New Issue | |
| 2019-03-25 12:14 | bernard_01 | File Added: FreeCAD.log | |
| 2019-03-25 12:14 | bernard_01 | File Added: CamshaftGear2_kiss.FCStd | |
| 2019-03-26 10:02 | Kunda1 | Status | new => feedback |
| 2019-03-26 10:02 | Kunda1 | Note Added: 0012956 | |
| 2019-03-26 10:33 | kisolre | File Added: CamshaftGear2_kiss_no transparency.FCStd | |
| 2019-03-26 10:33 | kisolre | Note Added: 0012959 | |
| 2019-03-27 09:14 | bernard_01 | Note Added: 0012965 | |
| 2019-03-27 09:14 | bernard_01 | Status | feedback => new |
| 2019-03-27 12:26 | kisolre | Note Added: 0012966 | |
| 2019-03-27 13:47 | bernard_01 | Note Added: 0012968 | |
| 2019-04-24 17:05 | Kunda1 | Note Added: 0013046 | |
| 2019-04-24 17:36 | kisolre | File Added: ImagePlane_Transparency.JPG | |
| 2019-04-24 17:36 | kisolre | Note Added: 0013047 | |
| 2019-09-18 01:20 | Kunda1 | Tag Attached: #post-to-forum | |
| 2019-09-20 12:28 | Kunda1 | Relationship added | related to 0003915 |
| 2019-09-20 12:35 | Kunda1 | Note Added: 0013660 | |
| 2019-09-20 14:14 | kisolre | Note Added: 0013661 | |
| 2020-01-11 12:28 | Kunda1 | Note Added: 0014046 | |
| 2020-01-11 12:28 | Kunda1 | Tag Attached: #pending | |
| 2020-04-25 14:06 | Kunda1 | Note Added: 0014378 | |
| 2020-04-25 14:06 | Kunda1 | Status | new => feedback |
| 2020-04-27 15:59 | kisolre | Note Added: 0014383 | |
| 2020-09-10 15:18 | Kunda1 | Tag Detached: #post-to-forum | |
| 2020-09-10 15:19 | Kunda1 | Tag Detached: #pending | |
| 2020-09-10 15:19 | Kunda1 | Status | feedback => closed |
| 2020-09-10 15:19 | Kunda1 | Resolution | open => unable to reproduce |
| 2020-09-10 15:19 | Kunda1 | Note Added: 0014741 |
