| Reporter | ArnoVersfeld | Assigned To | | |
| Priority | urgent | Severity | major | Reproducibility | always |
| Status | feedback | Resolution | open | |
| Platform | Intel® Core™ i7-3770 CPU @ 3.40G | OS | Ubuntu | OS Version | 18.04.2 |
| Product Version | 0.18 | |
| Target Version | 0.20 | |
| Summary | 0003922: Preferences, General, Units, user system MKS(m/kg/s/degree) displaying dimensions as millimetres and not metres |
| Description | I installed FreeCAD and set the Preferences as shown in the summary.
When I go to Arch, Draft or Drawing workbench and draw a simple image like a square then use the dimension tool I get a display in millimetres and not metres. I closed FreeCAD.
I deleted the file in the .FreeCAD folder namely user.cfg and cookies and opened FreeCAD again and got the same results.
I uninstalled FreeCAD from the system and reinstalled it after again deleting the files in the FreeCAD folder and got the same results, namely, "display in millimetres and not metres".
When I go to the combo view of a rectangle that I've drawn the Height is 8,00 mm and the Length 12,00 mm these dimensions should be 0,80 m and 1,20 m. |
| Steps To Reproduce | When I go to Arch, Draft or Drawing workbench and draw a simple image like a square then use the dimension tool I get a display in millimetres and not metres. I closed FreeCAD.
| Additional Information | Contents of the user.cfg file:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<FCParameters>
<FCParamGroup Name="Root">
<FCParamGroup Name="BaseApp">
<FCParamGroup Name="LogLevels">
<FCInt Name="Default" Value="2"/>
</FCParamGroup>
<FCParamGroup Name="Preferences">
<FCParamGroup Name="General">
<FCText Name="FileOpenSavePath">/home/arno</FCText>
<FCText Name="AutoloadModule">StartWorkbench</FCText>
<FCBool Name="ShowSplasher" Value="1"/>
<FCBool Name="PythonWordWrap" Value="1"/>
<FCInt Name="ToolbarIconSize" Value="24"/>
</FCParamGroup>
<FCParamGroup Name="Units">
<FCInt Name="UserSchema" Value="1"/>
<FCInt Name="Decimals" Value="2"/>
<FCInt Name="FracInch" Value="8"/>
</FCParamGroup>
<FCParamGroup Name="Macro">
<FCBool Name="LocalEnvironment" Value="1"/>
<FCText Name="MacroPath">/home/arno/.FreeCAD/Macro</FCText>
<FCBool Name="RecordGui" Value="1"/>
<FCBool Name="GuiAsComment" Value="1"/>
<FCBool Name="ScriptToPyConsole" Value="1"/>
<FCBool Name="ScriptToFile" Value="0"/>
<FCText Name="ScriptFile">FullScript.FCScript</FCText>
</FCParamGroup>
<FCParamGroup Name="Mod">
<FCParamGroup Name="OpenSCAD"/>
<FCParamGroup Name="Import">
<FCParamGroup Name="hSTEP">
<FCBool Name="ReadShapeCompoundMode" Value="1"/>
</FCParamGroup>
</FCParamGroup>
<FCParamGroup Name="Start">
<FCUInt Name="BackgroundColor1" Value="1331197183"/>
<FCUInt Name="BackgroundTextColor" Value="4294703103"/>
<FCUInt Name="PageColor" Value="4294967295"/>
<FCUInt Name="PageTextColor" Value="255"/>
<FCUInt Name="BoxColor" Value="3722305023"/>
<FCUInt Name="LinkColor" Value="65535"/>
<FCUInt Name="BackgroundColor2" Value="2141107711"/>
<FCText Name="Template"></FCText>
<FCText Name="BackgroundImage"></FCText>
<FCText Name="ShowCustomFolder"></FCText>
<FCBool Name="InWeb" Value="0"/>
<FCBool Name="InBrowser" Value="1"/>
<FCBool Name="ShowNotes" Value="0"/>
<FCBool Name="ShowExamples" Value="1"/>
<FCBool Name="closeStart" Value="0"/>
<FCBool Name="DoNotShowOnOpen" Value="0"/>
<FCBool Name="ShowForum" Value="0"/>
<FCBool Name="UseStyleSheet" Value="0"/>
<FCBool Name="NewFileGradient" Value="0"/>
<FCText Name="FontFamily"></FCText>
<FCInt Name="FontSize" Value="13"/>
</FCParamGroup>
<FCParamGroup Name="Draft">
<FCFloat Name="dxfScaling" Value="1.000000000000"/>
<FCFloat Name="maxsegmentlength" Value="5.000000000000"/>
<FCBool Name="dxfShowDialog" Value="0"/>
<FCBool Name="dxfUseLegacyImporter" Value="0"/>
<FCBool Name="dxfAllowDownload" Value="0"/>
<FCBool Name="dxftext" Value="0"/>
<FCBool Name="dxfImportPoints" Value="0"/>
<FCBool Name="dxflayout" Value="0"/>
<FCBool Name="dxfstarblocks" Value="0"/>
<FCBool Name="dxfGetOriginalColors" Value="0"/>
<FCBool Name="joingeometry" Value="0"/>
<FCBool Name="groupLayers" Value="0"/>
<FCBool Name="dxfStdSize" Value="0"/>
<FCBool Name="dxfUseDraftVisGroups" Value="0"/>
<FCBool Name="importDxfHatches" Value="0"/>
<FCBool Name="renderPolylineWidth" Value="0"/>
<FCBool Name="DiscretizeEllipses" Value="1"/>
<FCBool Name="dxfmesh" Value="0"/>
<FCBool Name="dxfExportBlocks" Value="1"/>
<FCBool Name="dxfproject" Value="0"/>
<FCBool Name="dxfCreatePart" Value="1"/>
<FCBool Name="dxfCreateDraft" Value="0"/>
<FCBool Name="dxfCreateSketch" Value="0"/>
<FCText Name="TeighaFileConverter"></FCText>
<FCFloat Name="svgDiscretization" Value="0.000000000000"/>
<FCInt Name="svgstyle" Value="0"/>
<FCInt Name="svg_export_style" Value="0"/>
<FCBool Name="svgDisableUnitScaling" Value="0"/>
<FCBool Name="SvgLinesBlack" Value="1"/>
<FCBool Name="ocaareas" Value="0"/>
<FCText Name="snapModes">111111111101111</FCText>
<FCInt Name="precision" Value="6"/>
<FCFloat Name="tolerance" Value="0.050000000000"/>
<FCText Name="ClonePrefix"></FCText>
<FCText Name="constructiongroupname">Construction</FCText>
<FCInt Name="UiMode" Value="1"/>
<FCInt Name="defaultWP" Value="0"/>
<FCBool Name="Verbose" Value="1"/>
<FCBool Name="copymode" Value="1"/>
<FCBool Name="selectBaseObjects" Value="0"/>
<FCBool Name="UsePartPrimitives" Value="0"/>
<FCBool Name="fillmode" Value="1"/>
<FCBool Name="focusOnLength" Value="0"/>
<FCUInt Name="constructioncolor" Value="746455039"/>
<FCInt Name="gridEvery" Value="10"/>
<FCInt Name="gridSize" Value="100"/>
<FCFloat Name="gridSpacing" Value="1.000000000000"/>
<FCInt Name="modsnap" Value="1"/>
<FCInt Name="modalt" Value="2"/>
<FCInt Name="modconstrain" Value="0"/>
<FCBool Name="showSnapBar" Value="1"/>
<FCBool Name="hideSnapBar" Value="0"/>
<FCBool Name="alwaysSnap" Value="1"/>
<FCBool Name="grid" Value="1"/>
<FCBool Name="alwaysShowGrid" Value="1"/>
<FCInt Name="linewidth" Value="2"/>
<FCInt Name="HatchPatternResolution" Value="128"/>
<FCText Name="svgDashedLine">0.09,0.05</FCText>
<FCText Name="svgDashdotLine">0.09,0.05,0.02,0.05</FCText>
<FCText Name="svgDottedLine">0.02,0.02</FCText>
<FCText Name="template"></FCText>
<FCText Name="patternFile"></FCText>
<FCInt Name="snapStyle" Value="0"/>
<FCBool Name="saveonexit" Value="0"/>
<FCBool Name="showPlaneTracker" Value="0"/>
<FCBool Name="preserveFaceColor" Value="0"/>
<FCBool Name="preserveFaceNames" Value="0"/>
<FCUInt Name="color" Value="255"/>
<FCUInt Name="snapcolor" Value="4294967295"/>
<FCInt Name="dimPrecision" Value="2"/>
<FCFloat Name="textheight" Value="0.200000000000"/>
<FCFloat Name="extlines" Value="0.300000000000"/>
<FCFloat Name="extovershoot" Value="0.000000000000"/>
<FCFloat Name="dimovershoot" Value="0.000000000000"/>
<FCFloat Name="arrowsize" Value="0.100000000000"/>
<FCFloat Name="dimspacing" Value="0.050000000000"/>
<FCText Name="textfont"></FCText>
<FCText Name="FontFile"></FCText>
<FCInt Name="dimstyle" Value="0"/>
<FCInt Name="dimsymbol" Value="0"/>
<FCInt Name="dimorientation" Value="0"/>
<FCBool Name="showUnit" Value="1"/>
</FCParamGroup>
<FCParamGroup Name="Arch">
<FCText Name="ifcRootElement">IfcProduct</FCText>
<FCText Name="ifcSkip"></FCText>
<FCInt Name="ifcImportModeArch" Value="0"/>
<FCInt Name="ifcImportModeStruct" Value="0"/>
<FCBool Name="ifcShowDialog" Value="0"/>
<FCBool Name="ifcDebug" Value="0"/>
<FCBool Name="ifcCreateClones" Value="1"/>
<FCBool Name="ifcSeparateOpenings" Value="0"/>
<FCBool Name="ifcGetExtrusions" Value="0"/>
<FCBool Name="ifcSplitLayers" Value="0"/>
<FCBool Name="ifcPrefixNumbers" Value="0"/>
<FCBool Name="ifcMergeMaterials" Value="0"/>
<FCBool Name="ifcImportProperties" Value="0"/>
<FCBool Name="ifcFitViewOnImport" Value="0"/>
<FCBool Name="ifcExportAsBrep" Value="0"/>
<FCBool Name="ifcUseDaeOptions" Value="0"/>
<FCBool Name="ifcJoinCoplanarFacets" Value="0"/>
<FCBool Name="ifcStoreUid" Value="1"/>
<FCBool Name="ifcSerialize" Value="0"/>
<FCBool Name="ifcExport2D" Value="1"/>
<FCBool Name="IfcExportFreeCADProperties" Value="0"/>
<FCBool Name="ifcCompress" Value="1"/>
<FCBool Name="DisableIfcRectangleProfileDef" Value="0"/>
<FCInt Name="ColladaSegsPerEdge" Value="1"/>
<FCInt Name="ColladaSegsPerRadius" Value="2"/>
<FCFloat Name="ColladaScalingFactor" Value="1.000000000000"/>
<FCFloat Name="ColladaTessellation" Value="1.000000000000"/>
<FCFloat Name="ColladaGrading" Value="0.300000000000"/>
<FCInt Name="ColladaMesher" Value="0"/>
<FCBool Name="ColladaSecondOrder" Value="0"/>
<FCBool Name="ColladaOptimize" Value="1"/>
<FCBool Name="ColladaAllowQuads" Value="0"/>
<FCInt Name="MaxComputeAreas" Value="20"/>
<FCInt Name="ReferenceCheckInterval" Value="60"/>
<FCFloat Name="ConversionTolerance" Value="0.001000000000"/>
<FCFloat Name="CutLineThickness" Value="2.000000000000"/>
<FCFloat Name="SymbolLineThickness" Value="0.600000000000"/>
<FCFloat Name="patternScale" Value="0.010000000000"/>
<FCText Name="archHiddenPattern">30, 10</FCText>
<FCText Name="BimServerUrl">http://localhost:8082</FCText>
<FCBool Name="autoJoinWalls" Value="1"/>
<FCBool Name="joinWallSketches" Value="0"/>
<FCBool Name="archRemoveExternal" Value="0"/>
<FCBool Name="applyconstructionStyle" Value="0"/>
<FCBool Name="MoveWithHost" Value="0"/>
<FCBool Name="ConversionFast" Value="1"/>
<FCBool Name="ConversionFlat" Value="0"/>
<FCBool Name="ConversionCut" Value="1"/>
<FCBool Name="ShowVRMDebug" Value="0"/>
<FCBool Name="BimServerBrowser" Value="0"/>
<FCBool Name="surveyUnits" Value="1"/>
<FCInt Name="WindowTransparency" Value="85"/>
<FCInt Name="StairsSteps" Value="17"/>
<FCFloat Name="WallWidth" Value="200.000000000000"/>
<FCFloat Name="WallHeight" Value="3000.000000000000"/>
<FCFloat Name="StructureLength" Value="100.000000000000"/>
<FCFloat Name="StructureWidth" Value="100.000000000000"/>
<FCFloat Name="StructureHeight" Value="1000.000000000000"/>
<FCFloat Name="RebarDiameter" Value="6.000000000000"/>
<FCFloat Name="RebarOffset" Value="30.000000000000"/>
<FCFloat Name="WindowWidth" Value="1000.000000000000"/>
<FCFloat Name="WindowHeight" Value="1000.000000000000"/>
<FCFloat Name="WindowThickness" Value="100.000000000000"/>
<FCFloat Name="StairsLength" Value="4500.000000000000"/>
<FCFloat Name="StairsWidth" Value="1000.000000000000"/>
<FCFloat Name="StairsHeight" Value="3000.000000000000"/>
<FCFloat Name="PanelLength" Value="1000.000000000000"/>
<FCFloat Name="PanelWidth" Value="1000.000000000000"/>
<FCFloat Name="PanelThickness" Value="10.000000000000"/>
<FCFloat Name="PipeDiameter" Value="50.000000000000"/>
<FCBool Name="WallSketches" Value="1"/>
<FCUInt Name="WallColor" Value="3604403967"/>
<FCUInt Name="StructureColor" Value="2527705855"/>
<FCUInt Name="RebarColor" Value="3111475967"/>
<FCUInt Name="WindowColor" Value="556614399"/>
<FCUInt Name="WindowGlassColor" Value="1572326399"/>
<FCUInt Name="PanelColor" Value="3416289279"/>
<FCUInt Name="ColorHelpers" Value="674321151"/>
</FCParamGroup>
<FCParamGroup Name="Part">
<FCParamGroup Name="General"/>
<FCParamGroup Name="IGES"/>
<FCParamGroup Name="STEP"/>
</FCParamGroup>
</FCParamGroup>
<FCParamGroup Name="Document">
<FCBool Name="CreateNewDoc" Value="0"/>
<FCInt Name="CompressionLevel" Value="3"/>
<FCBool Name="UsingUndo" Value="1"/>
<FCInt Name="MaxUndoSize" Value="20"/>
<FCBool Name="SaveTransactions" Value="0"/>
<FCBool Name="TransactionsDiscard" Value="0"/>
<FCBool Name="SaveThumbnail" Value="0"/>
<FCBool Name="AddThumbnailLogo" Value="1"/>
<FCBool Name="CreateBackupFiles" Value="1"/>
<FCInt Name="CountBackupFiles" Value="1"/>
<FCBool Name="DuplicateLabels" Value="0"/>
<FCInt Name="prefLicenseType" Value="0"/>
<FCText Name="prefLicenseUrl">http://en.wikipedia.org/wiki/All_rights_reserved</FCText>
<FCText Name="prefAuthor"></FCText>
<FCBool Name="prefSetAuthorOnSave" Value="0"/>
<FCText Name="prefCompany"></FCText>
<FCBool Name="RecoveryEnabled" Value="1"/>
<FCBool Name="AutoSaveEnabled" Value="1"/>
<FCInt Name="AutoSaveTimeout" Value="15"/>
</FCParamGroup>
<FCParamGroup Name="Bitmaps">
<FCParamGroup Name="Theme"/>
</FCParamGroup>
<FCParamGroup Name="View">
<FCText Name="NavigationStyle">Gui::CADNavigationStyle</FCText>
<FCInt Name="OrbitStyle" Value="1"/>
<FCInt Name="AntiAliasing" Value="0"/>
<FCInt Name="CornerNaviCube" Value="1"/>
<FCInt Name="MarkerSize" Value="9"/>
<FCBool Name="ZoomAtCursor" Value="1"/>
<FCBool Name="InvertZoom" Value="1"/>
<FCBool Name="DisableTouchTilt" Value="1"/>
<FCFloat Name="ZoomStep" Value="0.200000000000"/>
<FCBool Name="DragAtCursor" Value="0"/>
<FCBool Name="CornerCoordSystem" Value="1"/>
<FCBool Name="ShowFPS" Value="0"/>
<FCBool Name="UseVBO" Value="0"/>
<FCBool Name="ShowNaviCube" Value="1"/>
<FCBool Name="UseAutoRotation" Value="0"/>
<FCFloat Name="EyeDistance" Value="5.000000000000"/>
<FCBool Name="EnableBacklight" Value="0"/>
<FCUInt Name="BacklightColor" Value="4294967295"/>
<FCInt Name="BacklightIntensity" Value="100"/>
<FCBool Name="Perspective" Value="0"/>
<FCBool Name="Orthographic" Value="1"/>
<FCText Name="NewDocumentCameraOrientation">Top</FCText>
<FCUInt Name="BackgroundColor" Value="336897023"/>
<FCUInt Name="BackgroundColor2" Value="859006463"/>
<FCUInt Name="BackgroundColor3" Value="2543299327"/>
<FCUInt Name="BackgroundColor4" Value="1869583359"/>
<FCBool Name="Simple" Value="0"/>
<FCBool Name="Gradient" Value="1"/>
<FCBool Name="UseBackgroundColorMid" Value="0"/>
<FCBool Name="EnablePreselection" Value="1"/>
<FCBool Name="EnableSelection" Value="1"/>
<FCUInt Name="HighlightColor" Value="3789624575"/>
<FCUInt Name="SelectionColor" Value="481107199"/>
<FCFloat Name="PickRadius" Value="5.000000000000"/>
</FCParamGroup>
<FCParamGroup Name="OutputWindow">
<FCBool Name="checkLogging" Value="0"/>
<FCBool Name="checkWarning" Value="1"/>
<FCBool Name="checkError" Value="1"/>
<FCUInt Name="colorText" Value="255"/>
<FCUInt Name="colorLogging" Value="65535"/>
<FCUInt Name="colorWarning" Value="4289331455"/>
<FCUInt Name="colorError" Value="4278190335"/>
<FCBool Name="RedirectPythonOutput" Value="1"/>
<FCBool Name="RedirectPythonErrors" Value="1"/>
</FCParamGroup>
<FCParamGroup Name="DockWindows">
<FCParamGroup Name="TreeView">
<FCBool Name="Enabled" Value="1"/>
</FCParamGroup>
<FCParamGroup Name="PropertyView">
</FCParamGroup>
<FCParamGroup Name="DAGView">
<FCBool Name="Enabled" Value="0"/>
</FCParamGroup>
</FCParamGroup>
<FCUInt Name="TreeEditColor" Value="4294902015"/>
<FCUInt Name="TreeActiveColor" Value="3873898495"/>
</FCParamGroup>
<FCParamGroup Name="PropertyView"/>
<FCParamGroup Name="Editor">
<FCBool Name="EnableLineNumber" Value="1"/>
<FCBool Name="EnableFolding" Value="1"/>
<FCInt Name="TabSize" Value="4"/>
<FCInt Name="IndentSize" Value="4"/>
<FCBool Name="Tabs" Value="1"/>
<FCBool Name="Spaces" Value="0"/>
<FCUInt Name="Text" Value="0"/>
<FCUInt Name="Bookmark" Value="16776960"/>
<FCUInt Name="Breakpoint" Value="4278190080"/>
<FCUInt Name="Keyword" Value="65280"/>
<FCUInt Name="Comment" Value="11141120"/>
<FCUInt Name="Block comment" Value="2694882304"/>
<FCUInt Name="Number" Value="65280"/>
<FCUInt Name="String" Value="4278190080"/>
<FCUInt Name="Character" Value="4278190080"/>
<FCUInt Name="Class name" Value="4289331200"/>
<FCUInt Name="Define name" Value="4289331200"/>
<FCUInt Name="Operator" Value="2694882304"/>
<FCUInt Name="Python output" Value="2863300352"/>
<FCUInt Name="Python error" Value="4278190080"/>
<FCUInt Name="Current line highlight" Value="3772833792"/>
<FCInt Name="FontSize" Value="10"/>
<FCText Name="Font">Ubuntu</FCText>
</FCParamGroup>
<FCParamGroup Name="MainWindow">
<FCBool Name="TiledBackground" Value="0"/>
</FCParamGroup>
<FCParamGroup Name="DAGView"/>
<FCParamGroup Name="RecentFiles">
<FCInt Name="RecentFiles" Value="4"/>
</FCParamGroup>
<FCParamGroup Name="Browser"/>
</FCParamGroup>
<FCParamGroup Name="Macro"/>
<FCParamGroup Name="Workbench"/>
<FCParamGroup Name="Toolbars">
<FCBool Name="File" Value="1"/>
<FCBool Name="Workbench" Value="1"/>
<FCBool Name="Macro" Value="1"/>
<FCBool Name="View" Value="1"/>
<FCBool Name="Structure" Value="1"/>
<FCBool Name="Navigation" Value="0"/>
<FCBool Name="Draft tray" Value="0"/>
</FCParamGroup>
<FCBool Name="Std_ReportView" Value="0"/>
<FCBool Name="Std_TreeView" Value="1"/>
<FCBool Name="Std_PropertyView" Value="0"/>
<FCBool Name="Std_SelectionView" Value="1"/>
<FCBool Name="Std_CombiView" Value="1"/>
<FCBool Name="Std_PythonView" Value="0"/>
</FCParamGroup>
</FCParamGroup>
<FCParamGroup Name="Workbenches"/>
</FCParamGroup>
<FCParamGroup Name="Tux">
<FCParamGroup Name="NavigationIndicator">
<FCBool Name="Compact" Value="0"/>
<FCBool Name="Tooltip" Value="1"/>
</FCParamGroup>
<FCParamGroup Name="PersistentToolbars">
<FCParamGroup Name="User">
<FCParamGroup Name="StartWorkbench"/>
<FCParamGroup Name="ArchWorkbench"/>
</FCParamGroup>
<FCParamGroup Name="System">
</FCParamGroup>
</FCParamGroup>
</FCParamGroup>
</FCParamGroup>
</FCParameters>
| Tags | units |
| FreeCAD Information | |
