| 0003924 | FreeCAD | Bug | public | 2019-04-04 14:52 | 2021-02-11 17:13 |
| Reporter | Geoplace | Assigned To | |||
| Summary | 0003924: Text (Annotation) moves greatly when placement edited. | ||||
| Description | The place where the Text (annotation) are shown is disproportionately modified even when the placement has been edited by 1mm. The placement edition of one Text note affects others notes, even when you edit a windows placement it also distorts Text showed in the 3D space. OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16093 (Git) Build type: Release Branch: releases/FreeCAD-0-18 Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 | ||||
| Steps To Reproduce | 1.- Open FreeCAD v18 . Switch to Arch workbench. 2.- Create a Rectangle and make face false. (Being in the default top view) 3.- Create Text (Annotations) one at each corner of the rectangle. 4.- Use the wall tool in the rectangle to get walls. 5.- Use windows tool and insert one at the front wall. 6.- Change the windows (or text) placement parameter by opening it from the properties/data window and edit for example de X axis by 1mm. Clic Apply or OK. 7.- Now the texts go far away, at least 3 of them. The recompute don’t fix its shown positions. | ||||
| Additional Information | The text placement parameters stay the same. Lucky when we save and reopen the file its Texts takes the correct place. The same happen in the Linux OpenSuse Version 0.18. And Windows v 0.19. OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.16267 (Git) Build type: Release Branch: master Hash: ddb335cfe057336f1958d68126bb0471328d735c Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 It's an annoying bug because when you have a larger file that takes times to load, the open-close workaround to see the correct result would waste a lot more time. Here is the link to the forum with steps with images: https://forum.freecad.org/viewtopic.php?f=8&t=35307 Here is a test file you just need do the step 6 to see the bug. | ||||
| 2019-04-04 14:52 | Geoplace | New Issue | |
| 2019-04-04 14:52 | Geoplace | File Added: Prueba Annoation Windows wall-wind.FCStd | |
| 2021-02-11 17:12 | Kunda1 | File Deleted: Prueba Annoation Windows wall-wind.FCStd | |
| 2021-02-11 17:13 | Kunda1 | Note Added: 0015324 | |
| 2021-02-11 17:13 | Kunda1 | File Added: Prueba Annoation Windows wall-wind.FCStd |
