| 0003926 | Sketcher | Bug | public | 2019-04-05 16:58 | 2019-06-28 08:49 |
| Reporter | kisolre | Assigned To | abdullah | ||
| Summary | 0003926: Carbon copy in construction mode reports wrong constraint redundancy. | ||||
| Description | In the attached file when trying to carbon copy that sketch(fully constrained, no redundancies) to a new empty sketch in construction mode two constraints are reported as redundant. . | ||||
| Steps To Reproduce | Open the file. Create new sketch, XY plane. Toggle construction mode On. Make sure Auto Remove Redundants is Off Carbon Copy Sketch005 - constraints 21,24 are showed as redundant. Undo Toggle construction mode Off. Carbon Copy Sketch005 - no redundant constraints. | ||||
| Additional Information | Forum thread Versions tested:
0.17 shows only 24 as redundant | ||||
FreeCAD: master e632e9fe 2019-06-22 21:12:19 Committer: abdullahtahiriyo Details Diff |
Sketcher: Fix carbon copy construction points ============================================= fixes 0003926 Points made of construction type are special non-constrainable points, such as (current) bspline knots. This was not intended in Carbon Copy. |
Affected Issues 0003926 |
FreeCAD: releases/FreeCAD-0-18 2f0c3a79 2019-06-22 21:12:19 Committer: wmayer Details Diff |
| 2019-04-05 16:58 | kisolre | New Issue | |
| 2019-04-05 16:58 | kisolre | File Added: CarbonCopyConstructionMode.FCStd | |
| 2019-04-05 22:05 | Kunda1 | Status | new => confirmed |
| 2019-04-05 22:05 | Kunda1 | Target Version | => 0.19 |
| 2019-04-05 22:05 | Kunda1 | Description Updated | |
| 2019-04-05 22:05 | Kunda1 | Steps to Reproduce Updated | |
| 2019-04-05 22:05 | Kunda1 | Additional Information Updated | |
| 2019-06-22 21:15 | abdullah | Changeset attached | => FreeCAD master e632e9fe |
| 2019-06-22 21:15 | abdullah | Note Added: 0013300 | |
| 2019-06-22 21:15 | abdullah | Assigned To | => abdullah |
| 2019-06-22 21:15 | abdullah | Status | confirmed => closed |
| 2019-06-22 21:15 | abdullah | Resolution | open => fixed |
| 2019-06-28 08:49 | wmayer | Changeset attached | => FreeCAD releases/FreeCAD-0-18 2f0c3a79 |
| 2019-06-28 08:49 | abdullah | Note Added: 0013315 |
