| 0003931 | FreeCAD | Bug | public | 2019-04-11 19:19 | 2020-12-06 20:41 |
| Reporter | rgamelville | Assigned To | vejmarie | ||
| Platform | x86_64 | OS | OpenSuse Leap | OS Version | 15.0 |
| Summary | 0003931: After successful flatpak download from flatpak hub, 'flatpak run' gives seg fault | ||||
| Description | After successful flatpak download from flatpak hub, 'flatpak run' gives seg fault linux-svxg:/home/rob # flatpak install flathub org.freecadweb.FreeCAD Required runtime for org.freecadweb.FreeCAD/x86_64/stable (org.kde.Platform/x86_64/5.12) is not installed, searching... Found in remote flathub, do you want to install it? [y/n]: y Installing: org.kde.Platform/x86_64/5.12 from flathub [####################] 12 delta parts, 139 loose fetched; 360158 KiB transferred in 42 seconds Installing: org.freedesktop.Platform.VAAPI.Intel/x86_64/18.08 from flathub [####################] 1 delta parts, 2 loose fetched; 1783 KiB transferred in 0 seconds Installing: org.freedesktop.Platform.html5-codecs/x86_64/18.08 from flathub [####################] 1 delta parts, 2 loose fetched; 4497 KiB transferred in 0 seconds Installing: org.kde.KStyle.Adwaita/x86_64/5.12 from flathub [####################] 1 delta parts, 2 loose fetched; 4559 KiB transferred in 0 seconds Installing: org.kde.Platform.Locale/x86_64/5.12 from flathub [####################] 8 delta parts, 143 loose fetched; 142664 KiB transferred in 17 seconds Installing: org.freecadweb.FreeCAD/x86_64/stable from flathub [####################] 7 delta parts, 131 loose fetched; 219895 KiB transferred in 32 seconds linux-svxg:/home/rob # flatpak run org.freecadweb.FreeCAD FreeCAD 0.18, Libs: 0.18R14555 (Git shallow) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Program received signal SIGSEGV, Segmentation fault. #0 /usr/lib/x86_64-linux-gnu/libc.so.6(+0x382d0) [0x7f10939882d0] #1 /usr/lib/x86_64-linux-gnu/libKF5WidgetsAddons.so.5(+0) [0x7f108d378000] linux-svxg:/home/rob # | ||||
| Steps To Reproduce | # flatpak install flathub org.freecadweb.FreeCAD # flatpak run org.freecadweb.FreeCAD | ||||
| Additional Information | Splash screen appears briefly (difficult to spot last command but appears to be a Python script initialising the UI. | ||||
| Tags | #post-to-forum, 0.18, crash, flatpak, packaging, Start Workbench | ||||
Hey @vejmarie assigning to you. Is there a place where flatpak users can post flatpak related bugs to or are you intending that this be the place ? |
@vejmarie is this still reproducible ? |
@rgamelville can you still reproduce ? |
Closing ticket, no response from OP |
| 2019-04-11 19:19 | rgamelville | New Issue | |
| 2019-04-11 19:19 | rgamelville | Tag Attached: 0.18 | |
| 2019-04-11 19:19 | rgamelville | Tag Attached: crash | |
| 2019-04-11 19:19 | rgamelville | Tag Attached: Start Workbench | |
| 2019-04-15 11:23 | Kunda1 | Note Added: 0013028 | |
| 2019-04-15 11:23 | Kunda1 | Assigned To | => vejmarie |
| 2019-04-15 11:23 | Kunda1 | Status | new => assigned |
| 2019-04-15 11:24 | Kunda1 | Tag Attached: flatpak | |
| 2019-09-05 20:28 | Kunda1 | Note Added: 0013540 | |
| 2019-09-05 20:29 | Kunda1 | Tag Attached: packaging | |
| 2019-09-05 20:30 | Kunda1 | Target Version | => 0.19 |
| 2020-01-08 18:21 | Kunda1 | Note Added: 0014021 | |
| 2020-01-08 18:22 | Kunda1 | Tag Attached: #post-to-forum | |
| 2020-03-27 13:30 | Kunda1 | Note Added: 0014305 | |
| 2020-03-27 13:30 | Kunda1 | Status | assigned => feedback |
| 2020-12-06 20:41 | Kunda1 | Status | feedback => closed |
| 2020-12-06 20:41 | Kunda1 | Resolution | open => no change required |
| 2020-12-06 20:41 | Kunda1 | Note Added: 0015101 |
