| 0003936 | FreeCAD | General | public | 2019-04-17 16:18 | 2019-09-05 19:42 |
| Reporter | freedman | Assigned To | |||
| Summary | 0003936: When property (combo view) data is modified the enter key does not work correctly. | ||||
| Description | Normal computer usage is to use the "Enter key" to confirm some kind of data change. When changing property data the Enter key doesn't follow the correct procedure to bring the data into the program and process the data i.e. recompute. https://forum.freecadweb.org/viewtopic.php?f=3&t=34875 | ||||
| Steps To Reproduce | In the property fields when a data value is modified, the only way to trigger a recompute is to mouse click in a field above or below, using the Enter key does not trigger a recompute. Using the Enter key is almost worse because the "property change data flag" is reset I presume, this makes it so clicking above or below (the edited field) doesn't work. The only way to recompute at that point is to modify data without using the Enter key. | ||||
| Additional Information | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16093 +17 (Git) Build type: Release Branch: (HEAD detached at 0.18.1) Hash: f7dccfaa909e5b9da26bf50c4a22ccca9bb10c40 Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: English/UnitedStates (en_US) | ||||
| related to | 0003950 | closed | Part | when you change sphere settings in part it doesn't refresh when pressing enter |
To reproduce, make a cube and change the height. Then use the enter key. |
Can't reproduce this bug anymore with 0.19 version of 2019/08/21. Everything works as expected. The view is even updated in real-time when entering value. Is this ticket still useful ? |
@freedman : could you test with latest 0.19 and confirm it's fixed ? |
I have tested the current version of 0.19.17421 and the problem does looked fixed. Good work, thank you. |
Great. Thanks to all for the effort here. Marking fixed in 0.19 and closing |
| 2019-04-17 16:18 | freedman | New Issue | |
| 2019-04-17 16:35 | freedman | Note Added: 0013029 | |
| 2019-04-22 14:42 | Kunda1 | Summary | When property ( combo view) data is modified the enter key does not work correctly. => When property (combo view) data is modified the enter key does not work correctly. |
| 2019-08-31 11:39 | openBrain | Note Added: 0013497 | |
| 2019-08-31 11:40 | openBrain | Relationship added | related to 0003950 |
| 2019-09-03 15:27 | openBrain | Note Added: 0013523 | |
| 2019-09-04 18:14 | freedman | Note Added: 0013532 | |
| 2019-09-05 19:42 | Kunda1 | Status | new => closed |
| 2019-09-05 19:42 | Kunda1 | Resolution | open => fixed |
| 2019-09-05 19:42 | Kunda1 | Fixed in Version | => 0.19 |
| 2019-09-05 19:42 | Kunda1 | Note Added: 0013534 |
