| 0003941 | Draft | Bug | public | 2019-04-22 15:00 | 2019-05-09 14:07 |
| Reporter | jmaustpc | Assigned To | yorik | ||
| Platform | amd 64bit | OS | Kubuntu | OS Version | 18.04 Python3 |
| Target Version | 0.18 | ||||
| Summary | 0003941: Draft WB Label bugs with Python 3 | ||||
| Description | Draft Label https://forum.freecadweb.org/viewtopic.php?f=23&t=35780 some display issues,
| Steps To Reproduce | Draft Label https://forum.freecadweb.org/viewtopic.php?f=23&t=35780 1) I get a "b" before the value and the value within single inverted commas. For example, something like this b'1000.00mm'. 2) if I select a solid and then attach a Draft Label to it, the default in the dialogue is volume, if I change that to area I get an error
3) similar to 2) if you create the label with default "Volume" then after creation toggle the property to area in the property editor, you get the same error message above however it does actually correctly show the area despite the error message. 4)after creating a label, if you change the thing to display to something with nil value, it does not clear the previous values. Similarly if you select "Position" three values are shown, if you then select something with one value e.g. volume, it will display that Volume where X used to be but still leave Y and Z values from the previous use of "position". | ||||
| Additional Information | Installed from the Release PPA (Python3 version selected) OS: Kubuntu 18.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.1. Build type: Release Python version: 3.6.7 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/Australia (en_AU) | ||||
punting to yorik |
I fixed the two first issues (the "b" and the error), but not really sure how to cope with the problem of the value suddenly becoming null. Shoudl the label display something like <NULL VALUE>? or ### a la excel... Most other features in FreeCAD don't do that, they just don't update the shape, and mark the object as problematic in the tree. Maybe we should do that? But it might be a bit too much, not sure... (BTW I'm trying to fix the github->mantis integration too... Almost working) |
| 2019-04-22 15:00 | jmaustpc | New Issue | |
| 2019-04-22 15:00 | jmaustpc | Status | new => assigned |
| 2019-04-22 15:00 | jmaustpc | Assigned To | => yorik |
| 2019-04-22 15:00 | jmaustpc | File Added: draftlabelstestsonacube.FCStd | |
| 2019-05-09 13:30 | Kunda1 | Note Added: 0013091 | |
| 2019-05-09 14:01 | yorik | Changeset attached | => FreeCAD master 9e91c8d6 |
| 2019-05-09 14:01 | yorik | Note Added: 0013093 | |
| 2019-05-09 14:01 | yorik | Status | assigned => closed |
| 2019-05-09 14:01 | yorik | Resolution | open => fixed |
| 2019-05-09 14:07 | yorik | Note Added: 0013094 |
