| 0003962 | FreeCAD | Bug | public | 2019-05-08 20:45 | 2019-05-13 16:38 |
| Reporter | unknown-error | Assigned To | wmayer | ||
| Platform | i7, intel gfx, 16GB ram | OS | Ubuntu | OS Version | 16.04 |
| Summary | 0003962: Mesh section with plane uses wrong rotation when mesh is previously rotated | ||||
| Description | Mesh sections are done with non-rotated data, although the data appears rotated on the screen. See linked forum post for a screenshot. | ||||
| Steps To Reproduce | steps to reproduce: imported a mesh from mesh design workbench, rotate it around z by 180 degrees (menu: edit, placement, typed in 180) go to part workbench, create a plane. switch back to mesh workbench. use from the menu: meshes, cutting, create section from mesh and plane. expected result: section lies on the plane and goes through the mesh. actual result: section lies outside the mesh (rotated around z). it seems to me it uses the original position of the mesh instead of the rotated mesh (tried it with different rotation angles to verify that) | ||||
| Additional Information | https://forum.freecadweb.org/viewtopic.php?f=3&t=36196&p=306634#p306634 | ||||
| Tags | Mesh, plane, rotate, section | ||||
@unknown-error thanks for posting to the forum first and getting confirmation to open a ticket. Quick feedback, please always add the Help > About FreeCAD > Copy to clipboard info to your ticket (like you correctly did in the forum thread). Also please find a way going forward to use v0.18 built on Python3 and Qt5 |
https://github.com/FreeCAD/FreeCAD/commit/0644ed8e6 c:FreeCAD:0644ed8e6: |
| 2019-05-08 20:45 | unknown-error | New Issue | |
| 2019-05-08 20:45 | unknown-error | Tag Attached: Mesh | |
| 2019-05-08 20:45 | unknown-error | Tag Attached: plane | |
| 2019-05-08 20:45 | unknown-error | Tag Attached: rotate | |
| 2019-05-08 20:45 | unknown-error | Tag Attached: section | |
| 2019-05-09 11:29 | Kunda1 | Status | new => feedback |
| 2019-05-09 11:29 | Kunda1 | Note Added: 0013089 | |
| 2019-05-13 15:49 | wmayer | Assigned To | => wmayer |
| 2019-05-13 15:49 | wmayer | Status | feedback => closed |
| 2019-05-13 15:49 | wmayer | Resolution | open => fixed |
| 2019-05-13 15:49 | wmayer | Fixed in Version | => 0.19 |
| 2019-05-13 16:38 | Kunda1 | Note Added: 0013105 |
