| 0003963 | FreeCAD | Bug | public | 2019-05-08 22:31 | 2022-01-03 11:23 |
| Reporter | openBrain | Assigned To | openBrain | ||
| Status | resolved | Resolution | fixed | ||
| Summary | 0003963: Only alpha comma key can be used as decimal separator | ||||
| Description | On some values in the Property editor panel, only the alpha comma key is accepted as decimal separator. This is suboptimal (mainly compared to num dot key) when entering numbers  | ||||
| Steps To Reproduce | Edit a value directly in the property editing panel. Some will indifferently accept comma or dot (alpha comma, alpha dot, num dot) - eg Placement Angle - and some will enforce user to use alpha comma - eg Placement x Axis -. | ||||
| Additional Information | Linked forum thread AFAIK, no FC forumer natively using dot sign as decimal separator (eg en_US) has confirmed or not the bug. Only users using comma as decimal separator did. Proposed fix in the forum discussion :
| Tags | 0.18, input, keyboard, units | ||||
|  | https://github.com/FreeCAD/FreeCAD/pull/3256 |
|  | For specific case of TechDraw in the forum discussion, UI files have to be updated to use 'Gui::DoubleSpinBox' instead of 'QDoubleSpinBox' |
|  | Duplicate of 0003795 |
|  | Not duplicate. Related to. |
|  | I know there has been some work in this direction recently: where does this bug report stand @openBrain and @uwestoehr? |
|  | @chennes : to me the problem as described in this ticket is indeed solved. I had no complaints about the fix till now, so I guess we can close. |
|  | Fixed in FC 0.20dev but cannot be backported to FC 0.19 -> marking the bug fixed but keep it open to be transferred to GitHub as reference for 0.19 users. |
|  | This ticket has been migrated to GitHub as issue 5928. |
| 2019-05-08 22:31 | openBrain | New Issue | |
| 2019-05-08 22:31 | openBrain | Tag Attached: 0.18 | |
| 2019-05-08 22:31 | openBrain | Tag Attached: input | |
| 2019-05-08 22:31 | openBrain | Tag Attached: keyboard | |
| 2019-05-09 01:25 | Kunda1 | Tag Attached: units | |
| 2019-05-09 01:26 | Kunda1 | Target Version | => 0.19 |
| 2020-01-11 13:12 | Kunda1 | Status | new => confirmed |
| 2020-03-24 11:46 | openBrain | Assigned To | => openBrain |
| 2020-03-24 11:46 | openBrain | Status | confirmed => assigned |
| 2020-03-24 12:09 | openBrain | Note Added: 0014276 | |
| 2020-03-24 12:40 | openBrain | Note Added: 0014277 | |
| 2020-03-24 13:25 | uwestoehr | Note Added: 0014279 | |
| 2020-03-24 13:26 | uwestoehr | Status | assigned => closed |
| 2020-03-24 13:26 | uwestoehr | Resolution | open => fixed |
| 2020-03-24 13:26 | uwestoehr | Note Added: 0014280 | |
| 2020-03-24 13:26 | uwestoehr | Relationship added | duplicate of 0003795 |
| 2020-03-24 13:57 | openBrain | Status | closed => feedback |
| 2020-03-24 13:57 | openBrain | Resolution | fixed => reopened |
| 2020-03-24 13:57 | openBrain | Note Added: 0014281 | |
| 2020-03-24 13:57 | openBrain | Relationship deleted | 0003795 |
| 2020-03-24 13:57 | openBrain | Relationship added | related to 0003795 |
| 2020-04-09 17:47 | openBrain | Status | feedback => assigned |
| 2021-12-29 05:15 | chennes | Note Added: 0016160 | |
| 2022-01-03 08:51 | openBrain | Note Added: 0016182 | |
| 2022-01-03 11:23 | uwestoehr | Status | assigned => resolved |
| 2022-01-03 11:23 | uwestoehr | Resolution | reopened => fixed |
| 2022-01-03 11:23 | uwestoehr | Fixed in Version | => 0.20 |
| 2022-01-03 11:23 | uwestoehr | Note Added: 0016187 |
