| 0003967 | PartDesign | Bug | public | 2019-05-12 21:36 | 2020-10-23 02:50 |
| Reporter | uwestoehr | Assigned To | uwestoehr | ||
| Summary | 0003967: Datum plane yaw setting is ignored | ||||
| Description | The datum plane yaw setting is ignored if the pitch angle is >= 90°. Attached is a simple FC file. It contains 2 datum planes. - edit plane 2 and set its yaw angle to -10° result: In the preview it looks perfect - both planes are parallel But when I click OK to finish the editing, the plane yaw angle is reset to 0°, so the change was in fact ignored. - now set the yaw to -10° and pitch to 89° result: this works - now set the yaw to -10° and pitch to 91° result: you end up with pitch set to 89° and yaw 180° So in fact the angle setting for datum planes seems to be broken. | ||||
| Additional Information | https://forum.freecadweb.org/viewtopic.php?f=3&t=36321 Confirmed by @DeepSOIC OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16110 (Git) Build type: Release Branch: (HEAD detached at upstream/releases/FreeCAD-0-18) Hash: f7dccfaa909e5b9da26bf50c4a22ccca9bb10c40 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
| Tags | Part Design | ||||
With FC 0.19.18234 it is not better: - take the initially attached FC file - edit plane 2 and set its yaw angle subsequently (keeping the task dialog open) to -1, -2, -3 and -4° result: In the preview it looks as if both planes are parallel. But this is wrong because one needs -10° to have both planes parallel - nevertheless, keep the -4° and click OK to close the task dialog - open the task dialog for plane2 again result: you see that the yaw is 0° - nevertheless to have some fun, set the yaw again to -1, -2 down to -10° result: you see that the plane is jumping wildly around, for example when going from -7 to -8° or -10 to -11° -- OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18234 (Git) Build type: Release Branch: master Hash: 3af5d97e9b2a60823815f662aba25422c4bc45bb Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) |
I can no longer reproduce the issue with OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22831 (Git) Build type: Release Branch: master Hash: fc89f4eb0c2c6295a1bc02a5cd3db0a22547fc22 Python version: 3.6.8 Qt version: 5.12.6 Coin version: 4.0.0a OCC version: 7.4.0.beta Locale: German/Germany (de_DE) |
Closing ticket |
| 2019-05-12 21:36 | uwestoehr | New Issue | |
| 2019-05-12 21:36 | uwestoehr | Tag Attached: Part Design | |
| 2019-05-12 21:36 | uwestoehr | File Added: Datum-Plane-Bug.FCStd | |
| 2019-05-13 00:17 | uwestoehr | Description Updated | |
| 2019-05-13 16:44 | Kunda1 | Status | new => confirmed |
| 2019-05-13 16:44 | Kunda1 | Target Version | => 0.19 |
| 2019-06-17 10:07 | uwestoehr | Additional Information Updated | |
| 2019-06-17 10:08 | uwestoehr | Additional Information Updated | |
| 2019-09-16 11:58 | uwestoehr | Note Added: 0013607 | |
| 2020-10-23 00:36 | uwestoehr | Note Added: 0014938 | |
| 2020-10-23 00:37 | uwestoehr | Assigned To | => uwestoehr |
| 2020-10-23 00:37 | uwestoehr | Status | confirmed => resolved |
| 2020-10-23 00:37 | uwestoehr | Resolution | open => fixed |
| 2020-10-23 00:37 | uwestoehr | Fixed in Version | => 0.19 |
| 2020-10-23 00:37 | uwestoehr | Note Added: 0014939 | |
| 2020-10-23 02:50 | Kunda1 | Status | resolved => closed |
| 2020-10-23 02:50 | Kunda1 | Note Added: 0014940 |
