| 0003971 | Draft | Bug | public | 2019-05-14 16:44 | 2021-01-04 12:00 |
| Reporter | openBrain | Assigned To | yorik | ||
| Summary | 0003971: Draft Upgrade tool generate errors in Report view then crashes | ||||
| Description | When using the Draft WB -> Upgrade tool in a particular sequence, at some step it repeatedly generates error messages in the Report view, then FC crashes at subsequent step. | ||||
| Steps To Reproduce |
| Additional Information | Forum thread Confirmed with :
And | ||||
| Tags | Draft | ||||
| related to | 0004243 | closed | Crash: when using Draft Facebinder |
FreeCAD: master f1b644d1 2021-01-04 11:30:56 Committer: GitHub Details Diff |
Merge pull request 0004235 from marioalexis84/draft-facebinder Draft: Fix multiple crashes when using modification functions - fixes 0004243, 0003971 |
Affected Issues 0003971, 0004243 |
| mod - src/Mod/Draft/draftguitools/gui_array_simple.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_clone.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_downgrade.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_draft2sketch.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_facebinders.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_join.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_offset.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_patharray.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_pathtwistedarray.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_pointarray.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_shape2dview.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_split.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_upgrade.py | Diff File | ||
| 2019-05-14 16:44 | openBrain | New Issue | |
| 2019-05-14 16:44 | openBrain | Tag Attached: Draft | |
| 2019-06-17 07:05 | Kunda1 | Assigned To | => yorik |
| 2019-06-17 07:05 | Kunda1 | Status | new => assigned |
| 2019-06-17 07:05 | Kunda1 | Target Version | => 0.19 |
| 2021-01-02 14:02 | marioalexis | Note Added: 0015198 | |
| 2021-01-02 14:03 | marioalexis | Relationship added | related to 0004243 |
| 2021-01-04 12:00 | yorik | Changeset attached | => FreeCAD master f1b644d1 |
| 2021-01-04 12:00 | yorik | Note Added: 0015200 | |
| 2021-01-04 12:00 | yorik | Status | assigned => closed |
| 2021-01-04 12:00 | yorik | Resolution | open => fixed |
