| 0003973 | Sketcher | Bug | public | 2019-05-15 13:14 | 2019-06-28 08:49 |
| Reporter | uwestoehr | Assigned To | abdullah | ||
| Summary | 0003973: Carbon copy of a sketch results in unresolvable sketch | ||||
| Description | Sometimes after a carbon copy action the resulting sketch is unresolvable but fully constrained. To reproduce: - open the attached file - open the empty sketch "Sketch-CC" and make a carbon copy of the initial sketch I also made a screencast to demonstrate the problem: https://forum.freecadweb.org/viewtopic.php?f=3&t=36393#p308380 | ||||
| Additional Information | Forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=36393 Confirmed by @abdullah. | ||||
Confirmed by abdullah in the forum thread |
Fix committed to releases/FreeCAD-0-18 branch. |
FreeCAD: master b9417938 2019-06-23 13:10:48 Committer: abdullahtahiriyo Details Diff |
Sketcher: Fix Carbon copy leads to unsolvable sketch ==================================================== fixes 0003973 https://forum.freecadweb.org/viewtopic.php?p=316251#p316198 This commit disables an old "axis orientation correction mode", which tried to solve a problem with orientation of the axis. It never worked fine and it should have never been introduced, as everything it intends to do should be done by setting the appropriate placement offset. |
Affected Issues 0003973 |
FreeCAD: releases/FreeCAD-0-18 0572853d 2019-06-23 13:10:48 Committer: wmayer Details Diff |
| 2019-05-15 13:14 | uwestoehr | New Issue | |
| 2019-05-15 13:14 | uwestoehr | File Added: CarbonCopy-sketch-test.FCStd | |
| 2019-05-15 17:41 | Kunda1 | Status | new => confirmed |
| 2019-05-15 17:41 | Kunda1 | Note Added: 0013112 | |
| 2019-05-15 17:42 | Kunda1 | Target Version | => 0.19 |
| 2019-06-17 10:07 | uwestoehr | Additional Information Updated | |
| 2019-06-23 13:16 | abdullah | Changeset attached | => FreeCAD master b9417938 |
| 2019-06-23 13:16 | abdullah | Note Added: 0013302 | |
| 2019-06-23 13:16 | abdullah | Assigned To | => abdullah |
| 2019-06-23 13:16 | abdullah | Status | confirmed => closed |
| 2019-06-23 13:16 | abdullah | Resolution | open => fixed |
| 2019-06-28 08:49 | wmayer | Changeset attached | => FreeCAD releases/FreeCAD-0-18 0572853d |
| 2019-06-28 08:49 | abdullah | Note Added: 0013316 |
