| 0003978 | Sketcher | Bug | public | 2019-05-17 09:38 | 2020-03-22 22:21 |
| Reporter | uwestoehr | Assigned To | wmayer | ||
| Summary | 0003978: unchanged reference dimensions lose reference mode | ||||
| Description | - take e.g. this simple sketch: https://forum.freecadweb.org/download/file.php?id=83827 - There are several reference-mode dimensions in it, double click on a reference-mode dimension and then do nothing, just press cancel in the appearing dialog result: the dimension is no longer in reference mode but a normal mandatory dimension (turns from blue to red). But the dimension was not changed so there must not be any automatic change the user. Cancel must just cancel, nothing else. (The problem is that in real life documents the suddenly new real dimensions make sketches over-constrained. Moreover the change from reference-mode for the dimensions cannot simply be undone. Therefore it is really hard to work with the reference mode.) | ||||
| Additional Information | forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=36433 confirmed by @openBrain and @kisolre | ||||
| Tags | undo | ||||
https://github.com/FreeCAD/FreeCAD/pull/3183 |
https://github.com/FreeCAD/FreeCAD/commit/2d9c2c64407032403f81e340655c838435cf0e79 |
FreeCAD: master 2d9c2c64 2020-03-17 21:15:04 0penBrain Committer: wmayer Details Diff |
[Sketcher] Constraint driving/driven status integration in dimension edition dialog This integrates the ability to manage dimensional constraint driving/driven status in the constraint edition dialog box. It adds a checkbox in the dialog to show/select whether a constraint is driving or driven. When the constraint value is modified, it is automatically set as driving. Main focus is to allow to edit name (alias) of reference (driven) constraints directly in the constraint edition box. Resolves 0003793, 0003978 |
Affected Issues 0003793, 0003978 |
| mod - src/Mod/Sketcher/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Sketcher/Gui/CommandConstraints.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/EditDatumDialog.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/EditDatumDialog.h | Diff File | ||
| mod - src/Mod/Sketcher/Gui/InsertDatum.ui | Diff File | ||
| 2019-05-17 09:38 | uwestoehr | New Issue | |
| 2019-05-28 11:54 | Kunda1 | Summary | unchanged reference dimensions loose reference mode => unchanged reference dimensions lose reference mode |
| 2019-05-28 11:56 | Kunda1 | Relationship added | related to 0003793 |
| 2019-05-28 12:04 | Kunda1 | Status | new => confirmed |
| 2019-05-28 12:04 | Kunda1 | Target Version | => 0.19 |
| 2019-06-17 10:06 | uwestoehr | Additional Information Updated | |
| 2020-02-20 21:09 | Kunda1 | Tag Attached: undo | |
| 2020-03-17 23:29 | openBrain | Assigned To | => openBrain |
| 2020-03-17 23:29 | openBrain | Status | confirmed => assigned |
| 2020-03-17 23:29 | openBrain | Note Added: 0014237 | |
| 2020-03-19 13:00 | wmayer | Status | assigned => closed |
| 2020-03-19 13:00 | wmayer | Resolution | open => fixed |
| 2020-03-19 13:00 | wmayer | Fixed in Version | => 0.19 |
| 2020-03-19 13:00 | wmayer | Note Added: 0014239 | |
| 2020-03-22 22:21 | wmayer | Changeset attached | => FreeCAD master 2d9c2c64 |
| 2020-03-22 22:21 | wmayer | Note Added: 0014262 | |
| 2020-03-22 22:21 | wmayer | Assigned To | openBrain => wmayer |
