| 0003989 | Path | Bug | public | 2019-05-28 06:07 | 2021-02-06 06:33 |
| Reporter | Andrea3 | Assigned To | |||
| OS | Windows 7 | OS Version | 0.18.16110 (Git) | ||
| Summary | 0003989: Wrong simulation after setting a start point | ||||
| Description | Simulation shows that the object is cut completely but seems not possible due to the tool was not commanded under a specific Z value. | ||||
| Steps To Reproduce | Draw a simple cube Try to mill the surface Check the simulation --> works as expected Change the start point to z = xx in order that xx is above the solid Try to simulate --> object will cutted from the start point to the real first point where the mill should start to work. | ||||
| Additional Information | Forum link: https://forum.freecadweb.org/viewtopic.php?f=3&t=36523 FreeCAD version: OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16110 (Git) Build type: Release Branch: (HEAD detached at upstream/releases/FreeCAD-0-18) Hash: f7dccfaa909e5b9da26bf50c4a22ccca9bb10c40 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 | ||||
