| 0004004 | FreeCAD | Bug | public | 2019-06-06 06:34 | 2021-02-11 17:36 |
| Reporter | mhabakuk | Assigned To | |||
| Summary | 0004004: Skripts funktionieren nicht mehr unter 0.18 | ||||
| Description | Skripts wie ScreMaker oder Bolts funktionieren nicht mehr unter Version 0.18, jedoch auf gleichem Gerät noch unter 0.17. Es kommt folgende Fehlermeldung (exemplarisch) Traceback (most recent call last): File "G:/delta/knuth.V2/AppData/Roaming/FreeCAD/Macro/start_bolts.FCMacro", line 1, in <module> import BOLTS File "G:\delta\knuth.V2\AppData\Roaming\FreeCAD\Mod\BOLTSFC\BOLTS\__init__.py", line 40, in <module> from .gui import freecad_bolts as boltsgui File "G:\delta\knuth.V2\AppData\Roaming\FreeCAD\Mod\BOLTSFC\BOLTS\gui\freecad_bolts.py", line 29, in <module> Ui_BoltsWidget,QBoltsWidget = uic.loadUiType(join(bolts_path,'bolts_widget.ui')) <class 'SyntaxError'>: Missing parentheses in call to 'exec' (<string>, line 15) Manchmal, leider nicht immer, entbugt ein Neutippen der Zeile den Code - leider nicht komplett sondern bestenfalls abschnittsweise. | ||||
| Steps To Reproduce | im og. Fall einfach das Macro start_bolts.FCMacro nach Anleitung ausführen | ||||
Maybe a new rule something like "(7) Write ticket in english" should be added in the yellow banner. ;-) Even if this ticket also tends to prove that yellow banner isn't read... :-/ |
The issue should be addressed to the addon maintainer as BOLTS is not official part of FreeCAD. Nevertheless, the problem is caused because FreeCAD v0.17 uses Python2 which BOLTS apparently does too but your FreeCAD v0.18 obviously uses Python3. Two things you can try: 1. Get FreeCAD v0.18 that uses Python2 -- but this is not a long-term solution as for the next release Python2 won't be supported any more 2. Ask the maintainer of the BOLTS addon to port it to Python3 |
Closing |
| 2019-06-06 06:34 | mhabakuk | New Issue | |
| 2019-06-07 16:29 | openBrain | Note Added: 0013161 | |
| 2019-06-12 14:30 | wmayer | Note Added: 0013187 | |
| 2021-02-11 17:36 | Kunda1 | Status | new => closed |
| 2021-02-11 17:36 | Kunda1 | Resolution | open => no change required |
| 2021-02-11 17:36 | Kunda1 | Note Added: 0015327 |
